[U-Boot] [PATCH v2 2/2] test/py: Create tests for ext4 and fat testing on sandbox
The following checks are currently implemented: 1. listing a directory 2. verifying size of a file 3. veryfying md5sum for a file region 4. reading the beginning of a file
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- test/py/tests/test_fs.py | 357 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 357 insertions(+) create mode 100644 test/py/tests/test_fs.py
diff --git a/test/py/tests/test_fs.py b/test/py/tests/test_fs.py new file mode 100644 index 0000000000..7aaf8debaf --- /dev/null +++ b/test/py/tests/test_fs.py @@ -0,0 +1,357 @@ +# Copyright (c) 2016, Stefan Bruens stefan.bruens@rwth-aachen.de +# +# SPDX-License-Identifier: GPL-2.0 + +# Test U-Boot's filesystem implementations +# +# The tests are currently covering the ext4 and fat filesystem implementations. +# +# Following functionality is currently checked: +# - Listing a directory and checking for a set of files +# - Verifying the size of a file +# - Reading sparse and non-sparse files +# - File content verification using md5sums + + +from distutils.spawn import find_executable +import hashlib +import pytest +import os +import random +import re +import u_boot_utils as util + +@pytest.fixture(scope='session') +def prereq_commands(): + """Detect required commands to run file system tests.""" + for command in ['mkfs', 'mount', 'umount']: + if find_executable(command) is None: + pytest.skip('Filesystem tests, "{0}" not in PATH'.format(command)) + +""" +Scenarios: + hostfs: access image contents through the sandbox hostfs + facility, using the filesytem implementation of + the sandbox host, e.g. Linux kernel + generic: test u-boots native filesystem implementations, + using the 'generic' command names, e.g. 'load' + TODO - + fscommands: test u-boots native filesystem implementations, + using the fs specific commands, e.g. 'ext4load' +""" +@pytest.fixture(scope='class', params=['generic', 'hostfs']) +def scenario(request): + request.cls.scenario = request.param + return request.param + + +""" +Dictionary of files to use during filesystem tests. The files +are keyed by the filenames. The value is an array of strides, each tuple +contains the the start offset (inclusive) and end offset (exclusive). +""" +files = { + 'empty.file' : [(0, 0)], + '1MB.file' : [(0, 1e6)], + '1MB.sparse.file' : [(1e6-1, 1e6)], + '32MB.sparse.file' : [(0, 1e6), (4e6, 5e6), (31e6, 32e6)], + # Creating a 2.5 GB file on FAT is exceptionally slow, disable it for now + # '2_5GB.sparse.file' : [(0, 1e6), (1e9, 1e9+1e6), (2.5e9-1e6, 2.5e9)], +} + +"""Options to pass to mkfs.""" +mkfs_opts = { + 'fat' :'-t vfat', + 'ext4' : '-t ext4 -F', +} + +class FsImage: + def __init__(self, fstype, imagepath, mountpath): + """Create a new filesystem image. + + Args: + fstype: filesystem type (string) + imagepath: full path to image file + mountpath: mountpoint directory + """ + self.fstype = fstype + self.imagepath = imagepath + self.mountpath = mountpath + self.md5s = {} + with open(self.imagepath, 'w') as fd: + fd.truncate(0) + fd.seek(3e9) + fd.write(bytes([0])) + + def mkfs(self, log): + mkfsopts = mkfs_opts.get(self.fstype) + util.run_and_log(log, + 'mkfs {0} {1}'.format(mkfsopts, self.imagepath)) + + def create_file(self, log, filename, strides): + """Create a single file in the filesystem. Each file + is defined by one or more strides, which is filled with + random data. For each stride, the md5sum is calculated + and stored. + """ + md5sums = [] + with open(self.mountpath + '/' + filename, 'w') as fd: + for stride in strides: + length = int(stride[1] - stride[0]) + data = bytearray(random.getrandbits(8) for _ in xrange(length)) + md5 = hashlib.md5(data).hexdigest() + md5sums.append(md5) + log.info('{0}: write {1} bytes @ {2} : {3}'.format( + filename, int(stride[1] - stride[0]), + int(stride[0]), md5)) + fd.seek(stride[0]) + fd.write(data); + self.md5s[filename] = md5sums + + def create_files(self, log): + with log.section('Create initial files'): + for filename in files: + self.create_file(log, filename, files[filename]) + log.info('Created test files in "{0}"'.format(self.mountpath)) + util.run_and_log(log, 'ls -la {0}'.format(self.mountpath)) + util.run_and_log(log, 'sync {0}'.format(self.mountpath)) + + def mount(self, log): + if not os.path.exists(self.mountpath): + os.mkdir(self.mountpath) + log.info('Mounting {0} at {1}'.format(self.imagepath, self.mountpath)) + if self.fstype == 'ext4': + cmd = 'sudo -n mount -o loop,rw {0} {1}'.format(self.imagepath, self.mountpath) + else: + cmd = 'sudo -n mount -o loop,rw,umask=000 {0} {1}'.format(self.imagepath, self.mountpath) + util.run_and_log(log, cmd) + if self.fstype == 'ext4': + cmd = 'sudo -n chmod og+rw {0}'.format(self.mountpath) + return util.run_and_log(log, cmd) + + def unmount(self, log): + log.info('Unmounting {0}'.format(self.imagepath)) + cmd = 'sudo -n umount -l {0}'.format(self.mountpath) + util.run_and_log(log, cmd, ignore_errors=True) + + +@pytest.fixture(scope='module', params=['fat', 'ext4']) +def fsimage(prereq_commands, u_boot_config, u_boot_log, request): + """Filesystem image instance.""" + datadir = u_boot_config.result_dir + '/' + fstype = request.param + imagepath = datadir + '3GB.' + fstype + '.img' + mountpath = datadir + 'mnt_' + fstype + + with u_boot_log.section('Create image "{0}"'.format(imagepath)): + fsimage = FsImage(fstype, imagepath, mountpath) + fsimage.mkfs(u_boot_log) + + yield fsimage + fsimage.unmount(u_boot_log) + +@pytest.fixture(scope='module') +def populated_image(fsimage, u_boot_log): + """Filesystem populated with files required for tests.""" + try: + fsimage.mount(u_boot_log) + except Exception as e: + pytest.skip('{0}: could not mount "{1}"'.format( + fsimage.fstype, fsimage.imagepath)) + yield None + + fsimage.create_files(u_boot_log) + fsimage.unmount(u_boot_log) + yield fsimage + +@pytest.fixture(scope='function') +def boundimage(populated_image, u_boot_console, request): + """Filesystem image instance which is accessible from inside + the running U-Boot instance.""" + image = populated_image + request.cls.image = image + if request.cls.scenario == 'hostfs': + image.mount(u_boot_console.log) + image.rootpath = image.mountpath + '/' + yield image + image.unmount(u_boot_console.log) + else: + output = u_boot_console.run_command_list( + ['host bind 0 {0}'.format(image.imagepath)]) + image.rootpath = '/' + yield image + output = u_boot_console.run_command_list(['host bind 0 ']) + + +def test_fs_prepare_image(u_boot_config, fsimage, request): + """Dummy test to create an image file with filesystem. + Useful to isolate fixture setup from actual tests.""" + if not fsimage: + pytest.fail('Failed to create image') + +def test_fs_populate_image(populated_image, request): + """Dummy test to create initial filesystem contents.""" + if not populated_image: + pytest.fail('Failed create initial image content') + +@pytest.mark.usefixtures('u_boot_console', 'scenario', 'boundimage') +class TestFilesystems: + ignore_cleanup_errors = True + filesize_regex = re.compile('^filesize=([A-Fa-f0-9]+)') + md5sum_regex = re.compile('^md5 for .* ==> ([A-Fa-f0-9]{32})') + dirlist_regex = re.compile('\s+(\d+)\s+(\S+.file\S*)') + + commands = { + 'fat' : { + 'listcmd' : 'ls', + 'readcmd' : 'load', + 'sizecmd' : 'size', + 'writecmd' : 'size', + }, + 'ext4' : { + 'listcmd' : 'ls', + 'readcmd' : 'load', + 'sizecmd' : 'size', + 'writecmd' : 'size', + }, + } + + cmd_parameters = { + 'hostfs' : { + 'prefix' : 'host ', + 'interface' : 'hostfs -', + }, + 'generic' : { + 'prefix' : '', + 'interface' : 'host 0:0', + }, + } + + def get_filesize(self, filename): + """Get the size of the given file.""" + strides = files[filename] + return int(strides[-1][1]) + + def check_dirlist(self, string, filenames): + """Check if the output string returned by a list command + contains all given filenames.""" + m = self.dirlist_regex.findall(string) + assert(m) + for i, e in enumerate(m): + m[i] = (int(e[0]), e[1].lower()) + for f in filenames: + e = (self.get_filesize(f), f.lower()) + assert(e in m) + + def check_filesize(self, string, size): + """Check if the output string returned by a size command + matches the expected file size.""" + m = self.filesize_regex.match(string) + assert(m) + assert(int(m.group(1), 16) == size) + + def check_md5sum(self, string, md5): + """Check if the output string returned by the md5sum + command matches the expected md5.""" + m = self.md5sum_regex.match(string) + assert(m) + assert(len(m.group(1)) == 32) + assert(m.group(1) == md5) + + def run_listcmd(self, dirname): + """Run the scenario and filesystem specific list command + for the given directory name.""" + cmd = '{0}{1} {2} {3}'.format( + self.fs_params.get('prefix'), + self.fs_commands.get('listcmd'), + self.fs_params.get('interface'), + self.image.rootpath + dirname) + with self.console.log.section('List "{0}"'.format(dirname)): + output = self.console.run_command_list([cmd]) + return output[0] + + def run_readcmd(self, filename, offset, length): + """Run the scenario and filesystem specific read command + for the given file.""" + cmd = '{0}{1} {2} {3} {4} 0x{5:x} 0x{6:x}'.format( + self.fs_params.get('prefix'), + self.fs_commands.get('readcmd'), + self.fs_params.get('interface'), + '0', # address + self.image.rootpath + filename, + length, offset) + with self.console.log.section('Read file "{0}"'.format(filename)): + output = self.console.run_command_list( + [cmd, 'env print filesize', + 'md5sum 0 $filesize', 'env set filesize']) + return output[1:3] + + def run_sizecmd(self, filename): + """Run the scenario and filesystem specific size command + for the given file.""" + cmd = '{0}{1} {2} {3}'.format( + self.fs_params.get('prefix'), + self.fs_commands.get('sizecmd'), + self.fs_params.get('interface'), + self.image.rootpath + filename) + with self.console.log.section('Get size of "{0}"'.format(filename)): + output = self.console.run_command_list( + [cmd, 'env print filesize', 'env set filesize']) + return output[1] + + def setup(self): + self.fs_params = self.cmd_parameters.get(self.scenario) + self.fs_commands = self.commands.get(self.image.fstype) + + @pytest.mark.parametrize('dirname', ['', './']) + def test_fs_ls(self, u_boot_console, dirname): + """Check the contents of the given directory.""" + if self.image.fstype == 'fat' and dirname == './': + pytest.skip("FAT has no '.' entry in the root directory") + self.console = u_boot_console + self.setup() + + output = self.run_listcmd(dirname) + self.check_dirlist(output, files.keys()) + + @pytest.mark.parametrize('filename', files.keys()) + def test_fs_filesize(self, u_boot_console, filename): + """Check the filesize of the given file.""" + self.console = u_boot_console + self.setup() + + filesize = self.get_filesize(filename) + + output = self.run_sizecmd(filename) + self.check_filesize(output, filesize) + + @pytest.mark.parametrize('filename', files.keys()) + def test_fs_read(self, u_boot_console, filename): + """Read all defined strides of the given file and checks + its contents.""" + self.console = u_boot_console + self.setup() + + md5s = self.image.md5s[filename] + + for i, stride in enumerate(files[filename]): + length = int(stride[1]) - int(stride[0]) + offset = int(stride[0]) + output = self.run_readcmd(filename, offset, length) + self.check_filesize(output[0], length) + self.console.log.info('md5: {0}'.format(md5s[i])) + self.check_md5sum(output[1], md5s[i]) + + @pytest.mark.parametrize('filename', files.keys()) + def test_fs_read_head(self, u_boot_console, filename): + """Check reading the head of the given file, up to the first + 4 Megabyte (or less for smaller files). Also reads sparse + regions of a file.""" + self.console = u_boot_console + self.setup() + + filesize = self.get_filesize(filename) + filesize = min(filesize, int(4e6)) + + output = self.run_readcmd(filename, 0, filesize) + self.check_filesize(output[0], filesize)
On 4 December 2016 at 19:52, Stefan Brüns stefan.bruens@rwth-aachen.de wrote:
- listing a directory
- verifying size of a file
- veryfying md5sum for a file region
- reading the beginning of a file
Great to get this conversion going, thanks!
General comments:
1) I don't see anywhere that limits this test to sandbox. I assume it can't run on non-sandbox targets, even when using the U-Boot native filesystem commands, since there's no logic here to transfer the filesystem images to the target device.
I think this issue blocks checking in this change as-is, although all the other comments below can likely be deferred until later if you want, perhaps with the exception of (2) immediately below?
2) Doesn't mounting/unmounting require root? Nothing else in test/py does. It'd be useful to put a comment at the top of the file detailing which command one might want to add to /etc/sudoers to avoid having to run the whole thing as root, and use sudo within the test where necessary.
Is distutils part of the standard library, i.e. in a default install? If not, please add it to the requirements section of test/py/README.md.
+""" +Scenarios:
- hostfs: access image contents through the sandbox hostfs
- generic: test u-boots native filesystem implementations,
- TODO -
- fscommands: test u-boots native filesystem implementations,
Shouldn't that docstring be the first "statement" of the function, not right before it? I can't remember if Python picks up docstrings from right before objects too. If not, perhaps a comment would be better rather than a string.
+class FsImage:
- def mount(self, log):
Use os.makedirs(path) instead; you can avoid the if statement, and it'll handle parent directories too.
- """Filesystem image instance."""
- datadir = u_boot_config.result_dir + '/'
Wouldn't it be better to put this into u_boot_config.persistent_data_dir, plus avoid creating the image file if it already exists? See u_boot_utils.py's PersistentRandomFile() as an example. I wonder if that could be expanded to create files not just of size n, but with sparse layout specs like this test uses?
- fstype = request.param
- imagepath = datadir + '3GB.' + fstype + '.img'
- mountpath = datadir + 'mnt_' + fstype
- with u_boot_log.section('Create image "{0}"'.format(imagepath)):
- yield fsimage
- fsimage.unmount(u_boot_log)
Unmounting seems to happen in a lot of different places. Can we isolate it to just one place?
Also, what happens if the code throws an exception after obtaining an fsimage from this generator; I'm not sure that any cleanup happens in that case. Should there be "try: ... finally: unmount()" somewhere to clean up even in the case of an error? Alternatively, perhaps class FsImage should have a destructor that does the unmount (at least if it hasn't happened already)?
Nit: Two blank lines there.
- """Dummy test to create an image file with filesystem.
- Useful to isolate fixture setup from actual tests."""
- if not fsimage:
- """Dummy test to create initial filesystem contents."""
- if not populated_image:
Why not just fail (or raise an exception) right where the error occurs?
- def run_readcmd(self, filename, offset, length):
'0', # address
It might be a good idea to invoke u_boot_utils.find_ram_base(u_boot_console) rather than hard-coding an address of 0. I don't know if sandbox will ever change its memory layout, but if there's any chance any of this will be ported to real HW, that function will be required.
length, offset)
Out of curiosity, why not "echo $filesize"?
return output[1:3]
No error checking for output[0]? I suppose if u_boot_console_base.py's bad_pattern_defs[] included error patterns that "readcmd" was expected to emit, that'd be fine, but it doesn't currently. Maybe we expect that the other command can't possibly succeed if the read doesn't. Similar comment for run_sizecmd() below, and perhaps elsewhere.
- @pytest.mark.parametrize('dirname', ['', './'])
- def test_fs_ls(self, u_boot_console, dirname):
Is there a "/" or "" prefix tested too? Hopefully the root dir gets tested on FAT.
General comments:
- I don't see anywhere that limits this test to sandbox. I assume it
I have added Sandbox only for next patch version.
Running it from qemu should not be to difficult, "transferring" should be possible by adding the image to the qemu command.
Ideally, the FS image would be created once and then be reused. This had several benefits: 1. Reducing time for creation of the FAT image(s). Creation of the 2.5GB test file is time consuming, as FAT has no sparse files. Storage requirement is quite low if the FAT image is "resparsed" e.g. using "copy --sparse=always". 2. Sudo would be only (mostly) needed for the initial image creation. 3. If the image were created from a template, write tests (to be added later) could always start with a pristine image.
- Doesn't mounting/unmounting require root? Nothing else in test/py
It already uses sudo, the run command is visible from the log. Currently, I just run "sudo true" prior to executing the test, the password is cached for 5 minutes.
If the image were created once, there would be no need for sudo for later runs (save hostfs).
Don't know for other distros, for openSUSE it is.
+""" +Scenarios:
- TODO -
For attributes, the docstring should be in front of the initial assignment, and may be picked up by the doc generator. For functions, it should be the first line(s) of the function.
+class FsImage:
exist_ok only exists in python >= 3.2.
See above. I don't think PersistentRandomFile() does fit here, as the files are created *inside* an image. Maybe it could be used after the image and filesystem is created and mounted ...
- yield fsimage
The image is mounted/unmounted for two different reasons - creating/populating the image, and when accessing it using the hostfs commands.
Its a fixture and will be torn down by pytest.
- if not fsimage:
'0', # address
length, offset)
Because "filesize=1234" is nicer to match
return output[1:3]
filesize is only set if the read succeeds, and "env print filesize" matches bad_pattern_defs in case of an error.
See first parametrize entry.
Kind regards,
Stefan
I don't see sudo used anywhere in test/py; can you point out where you see it using sudo at present?
+class FsImage:
There's no need to use exist_ok; do this (example from conftest.py):
try: os.makedirs(path) except OSError as exc: if exc.errno == errno.EEXIST and os.path.isdir(path): pass else: raise
You missed my point. PersistentRandomFile() is existing code that creates a persistent data file. You can create a new function/... that uses the same techniques to create the data file, but make it create a filesystem image rather than random data.
- yield fsimage
IIRC, there's more duplication than that, but I'll look again when this is reposted.
How does that work? Once the fixture function has yielded the image, surely if an exception is thrown, it'll be "thrown through" the generator function and hence prevent the rest of the function body from running? Or is there some special magic that lets the generator complete, even if the yield effectively threw an exception?
return output[1:3]
What pattern is printed that matches bad_pattern_defs? Nothing in bad_pattern_defs obviously would get printed if $filesize wasn't set.
Also, what if $filesize is still set from an earlier test (e.g. in a different Python file), and a later test fails, yet this isn't detected since that relies on $filesize not being set? I see this script doing "env set filesize" /after/ its own tests which should prevent this, but not /before/ the first test.
it == the fs test
+class FsImage:
Thats not what you wrote. You said "you can avoid the if statement". What you meant is "you can replace the single line if statement with a 6 line exception handling statement". The latter is *only* better iff you have to handle concurrent creation of the wanted directory.
The disk image is a fixture, so it should be created as a fixture. The usage of PersistentRandomFile as currently done is wrong, it is a prerequisite of the test, not part of the test itself.
The correct use of PersistentRandomFile might be as a helper function used by different fixtures.
1. persistent_data_dir may be the better choice, but only if the image is created as a template there and then copied to a different location for each test run - the idea is to modify the image by write tests, and a clean image is needed here. Feel free to implement this yourself.
2. PersistentRandomFile creates single files, the only parameter is the size (although extending it to sparse files is quite possible). Disk images with filesystems have a lot more parameters - filesystem itself, filesystem options, filesystem contents.
Actually you missed my point here - PersistentRandomFile() is existing code, but it is useless here. Shoehorning it in here or extending it until it suits is a bad idea. It does one thing, and it does it fine. Creation of disk images is a different thing it does and should not do.
- yield fsimage
Please read up on pytest: http://pytest.org/dev/yieldfixture.html
return output[1:3]
=> env print foo ## Error: "foo" not defined
There you have a point. *If* filesize where set, *and* the previously set value matches the expected value *and* this is the very first test to check $filesize, an error would have gone unnoticed ...
Regards,
Stefan
Stefan Bruens
Stefan Brüns
Stephen Warren
