[U-Boot] [PATCH 0/2 v2] OMAP3: Minor code clean up, no functional change
This patch series contains only minor code clean up, no functional changes.
Complete patch series boot tested on OMAP3 BeagleBoard and compile tested with ./MAKEALL ARM_CORTEX_A8.
Note: The third patch [3] is removed from this series, as Jean-Christophe wants to do the rename interrupts.c -> timer.c and the Makefile fix for this in an overall patch.
Best regards
Dirk
[1] http://lists.denx.de/pipermail/u-boot/2009-May/052127.html
Remove duplicated interrupt code. Original, identical code can be found in lib_arm/interrupts.c
From: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Dirk Behme dirk.behme@googlemail.com --- cpu/arm_cortexa8/omap3/interrupts.c | 128 ------------------------------------ 1 file changed, 128 deletions(-)
Index: u-boot-main/cpu/arm_cortexa8/omap3/interrupts.c =================================================================== --- u-boot-main.orig/cpu/arm_cortexa8/omap3/interrupts.c +++ u-boot-main/cpu/arm_cortexa8/omap3/interrupts.c @@ -34,134 +34,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/proc-armv/ptrace.h> - -#ifdef CONFIG_USE_IRQ -/* enable IRQ interrupts */ -void enable_interrupts(void) -{ - unsigned long temp; - __asm__ __volatile__("mrs %0, cpsr\n" - "bic %0, %0, #0x80\n" "msr cpsr_c, %0":"=r"(temp) - ::"memory"); -} - -/* - * disable IRQ/FIQ interrupts - * returns true if interrupts had been enabled before we disabled them - */ -int disable_interrupts(void) -{ - unsigned long old, temp; - __asm__ __volatile__("mrs %0, cpsr\n" - "orr %1, %0, #0xc0\n" - "msr cpsr_c, %1":"=r"(old), "=r"(temp) - ::"memory"); - return (old & 0x80) == 0; -} -#else -void enable_interrupts(void) -{ - return; -} -int disable_interrupts(void) -{ - return 0; -} -#endif - -void bad_mode(void) -{ - panic("Resetting CPU ...\n"); - reset_cpu(0); -} - -void show_regs(struct pt_regs *regs) -{ - unsigned long flags; - const char *processor_modes[] = { - "USER_26", "FIQ_26", "IRQ_26", "SVC_26", - "UK4_26", "UK5_26", "UK6_26", "UK7_26", - "UK8_26", "UK9_26", "UK10_26", "UK11_26", - "UK12_26", "UK13_26", "UK14_26", "UK15_26", - "USER_32", "FIQ_32", "IRQ_32", "SVC_32", - "UK4_32", "UK5_32", "UK6_32", "ABT_32", - "UK8_32", "UK9_32", "UK10_32", "UND_32", - "UK12_32", "UK13_32", "UK14_32", "SYS_32", - }; - - flags = condition_codes(regs); - - printf("pc : [<%08lx>] lr : [<%08lx>]\n" - "sp : %08lx ip : %08lx fp : %08lx\n", - instruction_pointer(regs), - regs->ARM_lr, regs->ARM_sp, regs->ARM_ip, regs->ARM_fp); - printf("r10: %08lx r9 : %08lx r8 : %08lx\n", - regs->ARM_r10, regs->ARM_r9, regs->ARM_r8); - printf("r7 : %08lx r6 : %08lx r5 : %08lx r4 : %08lx\n", - regs->ARM_r7, regs->ARM_r6, regs->ARM_r5, regs->ARM_r4); - printf("r3 : %08lx r2 : %08lx r1 : %08lx r0 : %08lx\n", - regs->ARM_r3, regs->ARM_r2, regs->ARM_r1, regs->ARM_r0); - printf("Flags: %c%c%c%c", - flags & CC_N_BIT ? 'N' : 'n', - flags & CC_Z_BIT ? 'Z' : 'z', - flags & CC_C_BIT ? 'C' : 'c', flags & CC_V_BIT ? 'V' : 'v'); - printf(" IRQs %s FIQs %s Mode %s%s\n", - interrupts_enabled(regs) ? "on" : "off", - fast_interrupts_enabled(regs) ? "on" : "off", - processor_modes[processor_mode(regs)], - thumb_mode(regs) ? " (T)" : ""); -} - -void do_undefined_instruction(struct pt_regs *pt_regs) -{ - printf("undefined instruction\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_software_interrupt(struct pt_regs *pt_regs) -{ - printf("software interrupt\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_prefetch_abort(struct pt_regs *pt_regs) -{ - printf("prefetch abort\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_data_abort(struct pt_regs *pt_regs) -{ - printf("data abort\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_not_used(struct pt_regs *pt_regs) -{ - printf("not used\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_fiq(struct pt_regs *pt_regs) -{ - printf("fast interrupt request\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_irq(struct pt_regs *pt_regs) -{ - printf("interrupt request\n"); - show_regs(pt_regs); - bad_mode(); -} -
static ulong timestamp; static ulong lastinc;
Reformat COBJS handling.
Changes in v2: Rebase to interrupts.o instead of timer.o
cpu/arm_cortexa8/omap3/Makefile | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
Index: u-boot-main/cpu/arm_cortexa8/omap3/Makefile =================================================================== --- u-boot-main.orig/cpu/arm_cortexa8/omap3/Makefile +++ u-boot-main/cpu/arm_cortexa8/omap3/Makefile @@ -26,7 +26,13 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).a
SOBJS := lowlevel_init.o -COBJS := sys_info.o board.o clock.o interrupts.o mem.o syslib.o + +COBJS += board.o +COBJS += clock.o +COBJS += mem.o +COBJS += syslib.o +COBJS += sys_info.o +COBJS += interrupts.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
Dirk Behme
