[U-Boot] [PATCH] usb: dfu: thor: gadget: Remove dead code
This code is not used anymore in the current DFU implementation and can be safely removed.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- drivers/usb/gadget/f_dfu.c | 8 -------- drivers/usb/gadget/f_thor.c | 10 ---------- 2 files changed, 18 deletions(-)
diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index 3e4f029..d040606 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -81,14 +81,6 @@ static struct usb_descriptor_header *dfu_runtime_descs[] = { NULL, };
-static const struct usb_qualifier_descriptor dev_qualifier = { - .bLength = sizeof dev_qualifier, - .bDescriptorType = USB_DT_DEVICE_QUALIFIER, - .bcdUSB = __constant_cpu_to_le16(0x0200), - .bDeviceClass = USB_CLASS_VENDOR_SPEC, - .bNumConfigurations = 1, -}; - static const char dfu_name[] = "Device Firmware Upgrade";
/* diff --git a/drivers/usb/gadget/f_thor.c b/drivers/usb/gadget/f_thor.c index c85b0fb..78519fa 100644 --- a/drivers/usb/gadget/f_thor.c +++ b/drivers/usb/gadget/f_thor.c @@ -458,16 +458,6 @@ static struct usb_endpoint_descriptor hs_int_desc = { .bInterval = 0x9, };
-static struct usb_qualifier_descriptor dev_qualifier = { - .bLength = sizeof(dev_qualifier), - .bDescriptorType = USB_DT_DEVICE_QUALIFIER, - - .bcdUSB = __constant_cpu_to_le16(0x0200), - .bDeviceClass = USB_CLASS_VENDOR_SPEC, - - .bNumConfigurations = 2, -}; - /* * This attribute vendor descriptor is necessary for correct operation with * Windows version of THOR download program
How come the compiler didn't spew that this is unused ?
Best regards, Marek Vasut
Hello Marek,
gcc feature, see https://gcc.gnu.org/bugzilla/show_bug.cgi?id=13029.
Regards, Jeroen
On Thursday, September 11, 2014 at 09:17:57 PM, Jeroen Hofstee wrote:
Hello Marek,
I see, thanks for pointing this out!
Hello Lukasz,
Am 11.09.2014 15:26, schrieb Lukasz Majewski:
Signed-off-by: Lukasz Majewskil.majewski@samsung.com
Thanks!
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
Jeroen Hofstee
Lukasz Majewski
