[U-Boot] [PATCH] spl: typo fix for SPL_ATF_SUPPORT description
Delete one redundant 'which' for SPL_ATF_SUPPORT description.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
common/spl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 29c86a4..6174084 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -696,7 +696,7 @@ config SPL_ATF_SUPPORT bool "Support ARM Trusted Firmware" depends on ARM64 help - ATF(ARM Trusted Firmware) is a component for ARM arch64 which which + ATF(ARM Trusted Firmware) is a component for ARM arch64 which is loaded by SPL(which is considered as BL2 in ATF terminology). More detail at: https://github.com/ARM-software/arm-trusted-firmware
Kever Yang
