[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 131a1e603b3a8438b84b41940bc6a2051a36e087:
ARM: rpi_b: enable SD controller, add related env/cmds (2013-03-20 15:32:16 +0100)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to e0c60ef48bc600bcd06c08a436abfca1a963a1e7:
mmc: omap_hsmmc.c: only register getcd/getwp callbacks if gpio could be used (2013-03-22 12:01:15 -0400)
---------------------------------------------------------------- Enric Balletbo i Serra (2): ARM: AM33XX: Fix typo that causes an AM duplication in CPU name. igep00x0: Enable CONFIG_CMD_BOOTZ
Koen Kooi (3): am335x_evm: add support for BeagleBone Black DT name am335x_evm: Enable CMD_EXT4 and CMD_FS_GENERIC, add bootpart to env am335x_evm: Add more variables and switch to DT booting.
Mark Jackson (2): Allow AM335x MPU core clock speed to be specified in the board config file Initialise correct GPMC WAITx irq for AM33xx
Matt Porter (9): am33xx: convert defines from am33xx-specific to generic names am33xx: refactor emif4/ddr to support multiple EMIF instances am33xx: refactor am33xx clocks and add ti814x support am33xx: refactor am33xx mux support and add ti814x support am33xx: add ti814x specific register definitions am33xx: add dmm support to emif4 library am33xx: support ti814x mmc reference clock ns16550: enable quirks for ti814x ti814x_evm: add ti814x evm board support
Nikita Kiryanov (1): cm-t35: add support for loading splash image from NAND
Peter Korsgaard (2): mmc: mmc_getcd/getwp: use sensible defaults mmc: omap_hsmmc.c: only register getcd/getwp callbacks if gpio could be used
Steve Kipisz (1): am33xx:ddr:Fix config_sdram to work for all DDR
Tom Rini (3): am33xx: Add required includes to some omap/am33xx code am335x_evm: Add better timings for the new BeagleBoard DDR3 part arm: Correct CONFIG_STANDALONE_LOAD_ADDR for AM33XX/OMAP* platforms
hvaibhav@ti.com (1): am335x: Enable DDR PHY dynamic power down bit for DDR3 boards
MAINTAINERS | 4 + Makefile | 2 +- README | 4 + arch/arm/config.mk | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/am33xx/Makefile | 3 +- arch/arm/cpu/armv7/am33xx/board.c | 4 +- .../cpu/armv7/am33xx/{clock.c => clock_am33xx.c} | 33 +- arch/arm/cpu/armv7/am33xx/clock_ti814x.c | 406 ++++++++++++++++++++ arch/arm/cpu/armv7/am33xx/ddr.c | 104 +++-- arch/arm/cpu/armv7/am33xx/emif4.c | 57 ++- arch/arm/cpu/armv7/am33xx/mem.c | 2 +- arch/arm/cpu/armv7/am33xx/sys_info.c | 5 +- arch/arm/cpu/armv7/omap-common/Makefile | 2 +- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 1 + arch/arm/cpu/armv7/omap-common/timer.c | 1 + arch/arm/include/asm/arch-am33xx/clock.h | 2 +- arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 36 +- arch/arm/include/asm/arch-am33xx/cpu.h | 11 +- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 75 +++- arch/arm/include/asm/arch-am33xx/hardware.h | 40 +- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 54 +++ arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 53 +++ arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 5 + arch/arm/include/asm/arch-am33xx/mux.h | 235 +---------- arch/arm/include/asm/arch-am33xx/mux_am33xx.h | 247 ++++++++++++ arch/arm/include/asm/arch-am33xx/mux_ti814x.h | 311 +++++++++++++++ arch/arm/include/asm/arch-am33xx/omap.h | 5 + arch/arm/include/asm/arch-am33xx/spl.h | 5 + arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 + board/cm_t35/cm_t35.c | 61 +++ board/phytec/pcm051/board.c | 8 +- board/ti/am335x/board.c | 57 ++- board/ti/ti814x/Makefile | 46 +++ board/ti/ti814x/evm.c | 198 ++++++++++ board/ti/ti814x/evm.h | 7 + board/ti/ti814x/mux.c | 51 +++ boards.cfg | 1 + drivers/mmc/mmc.c | 16 +- drivers/mmc/omap_hsmmc.c | 8 +- drivers/mtd/nand/omap_gpmc.c | 1 + drivers/net/cpsw.c | 1 + drivers/serial/ns16550.c | 5 +- include/configs/am335x_evm.h | 28 +- include/configs/cm_t35.h | 4 + include/configs/igep00x0.h | 3 +- include/configs/pcm051.h | 3 +- include/configs/ti814x_evm.h | 221 +++++++++++ spl/Makefile | 2 +- 49 files changed, 2037 insertions(+), 397 deletions(-) rename arch/arm/cpu/armv7/am33xx/{clock.c => clock_am33xx.c} (91%) create mode 100644 arch/arm/cpu/armv7/am33xx/clock_ti814x.c create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_am33xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti814x.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_am33xx.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_ti814x.h create mode 100644 board/ti/ti814x/Makefile create mode 100644 board/ti/ti814x/evm.c create mode 100644 board/ti/ti814x/evm.h create mode 100644 board/ti/ti814x/mux.c create mode 100644 include/configs/ti814x_evm.h
And a full set of applied replies to the various patches coming soon, just want this out the door. Thanks!
Hi Tom,
On Fri, 22 Mar 2013 16:18:39 -0400, Tom Rini trini@ti.com wrote:
Hello,
I'd rather have a full name on this one.
Amicalement,
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 03/24/2013 12:48 PM, Albert ARIBAUD wrote:
Hi Tom,
Hello,
Fixed, pushed and author reminded, thanks / sorry!
- -- Tom
Hi Tom,
Hi Tom,
Hello,
No problem :) -- applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
