[U-Boot] [PATCH v4 0/6] arm, imx6: add aristainetos board support
add support for the imx6 based aristainetos board.
- changes for v2: - added comments from Jagan Teki and Stefano Babic - remove patch http://patchwork.ozlabs.org/patch/353324/ - new patches in v2 imx6: add gpr2 usb_otg_id iomux select control define (as patch http://patchwork.ozlabs.org/patch/353324/ is removed in v2) i.MX6: define struct pwm_regs and PWMCR_* defines (as splash screen support added for this board)
- changes for v3 - remove patch http://patchwork.ozlabs.org/patch/369530/ from this patchserie, as Jagannadha Sutradharudu Teki applied it to u-boot-spi/master
- new patch: spi: add config option to enable the WP pin function on st micron flashes as Stefano Babic suggested to move this to common code
- new patch: pwm, imx6: add support for pwm modul on imx6 as Stefano Babic suggested to move this to common code
- changes for v4: - pwm, imx6: add support for pwm modul on imx6 patch - add Acked-by from Stefano Babic - add in the commit message the commit ID from linux on which pieces of the code is based. - add comment from Wolfgang Denk: - move code which is based from linux into a seperate new file drivers/pwm/pwm-imx-util.c, so this can be with the GPL-2.0 license, and the code not taken from linux can be in GPL-2.0+ - arm-imx6-add-aristainetos-board.patch - add comment from Stefano Babic: - remove board_late_init() - remove unnecessary ifdef in board config file
Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Stefano Babic sbabic@denx.de
Heiko Schocher (6): imx6: add gpr2 usb_otg_id iomux select control define i.MX6: define struct pwm_regs and PWMCR_* defines pwm, imx6: add support for pwm modul on imx6 i.MX6: add enable_spi_clk() spi: add config option to enable the WP pin function on st micron flashes arm, imx6: add aristainetos board
README | 15 + arch/arm/cpu/armv7/mx6/clock.c | 18 ++ arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 19 ++ board/aristainetos/Makefile | 9 + board/aristainetos/aristainetos.c | 519 +++++++++++++++++++++++++++++++ board/aristainetos/aristainetos.cfg | 33 ++ board/aristainetos/clocks.cfg | 24 ++ board/aristainetos/ddr-setup.cfg | 61 ++++ board/aristainetos/mt41j128M.cfg | 70 +++++ boards.cfg | 1 + drivers/Makefile | 1 + drivers/mtd/spi/sf_internal.h | 4 + drivers/mtd/spi/sf_probe.c | 30 ++ drivers/pwm/Makefile | 13 + drivers/pwm/pwm-imx-util.c | 73 +++++ drivers/pwm/pwm-imx-util.h | 16 + drivers/pwm/pwm-imx.c | 59 ++++ include/configs/aristainetos.h | 325 +++++++++++++++++++ 19 files changed, 1291 insertions(+) create mode 100644 board/aristainetos/Makefile create mode 100644 board/aristainetos/aristainetos.c create mode 100644 board/aristainetos/aristainetos.cfg create mode 100644 board/aristainetos/clocks.cfg create mode 100644 board/aristainetos/ddr-setup.cfg create mode 100644 board/aristainetos/mt41j128M.cfg create mode 100644 drivers/pwm/Makefile create mode 100644 drivers/pwm/pwm-imx-util.c create mode 100644 drivers/pwm/pwm-imx-util.h create mode 100644 drivers/pwm/pwm-imx.c create mode 100644 include/configs/aristainetos.h
add IOMUXC_GPR1_USB_OTG_ID_OFFSET and IOMUXC_GPR1_USB_OTG_ID_SEL_MASK define for the USB_OTG_ID_SEL bit.
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Stefano Babic sbabic@denx.de
--- - changes for v2: - new - changes for v3: add Acked-by from Stefano Babic - changes for v4: none
arch/arm/include/asm/arch-mx6/imx-regs.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index a69a753..7193118 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -251,6 +251,8 @@ struct src { /* GPR1 bitfields */ #define IOMUXC_GPR1_ENET_CLK_SEL_OFFSET 21 #define IOMUXC_GPR1_ENET_CLK_SEL_MASK (1 << IOMUXC_GPR1_ENET_CLK_SEL_OFFSET) +#define IOMUXC_GPR1_USB_OTG_ID_OFFSET 13 +#define IOMUXC_GPR1_USB_OTG_ID_SEL_MASK (1 << IOMUXC_GPR1_USB_OTG_ID_OFFSET)
/* GPR3 bitfields */ #define IOMUXC_GPR3_GPU_DBG_OFFSET 29
add defines for pwm modul found on imx6.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Stefano Babic sbabic@denx.de
--- - changes for v2: - new - changes for v3: none - changes for v4: none
arch/arm/include/asm/arch-mx6/imx-regs.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 7193118..2135051 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -669,5 +669,21 @@ struct wdog_regs { u16 wmcr; /* Miscellaneous Control */ };
+#define PWMCR_PRESCALER(x) (((x - 1) & 0xFFF) << 4) +#define PWMCR_DOZEEN (1 << 24) +#define PWMCR_WAITEN (1 << 23) +#define PWMCR_DBGEN (1 << 22) +#define PWMCR_CLKSRC_IPG_HIGH (2 << 16) +#define PWMCR_CLKSRC_IPG (1 << 16) +#define PWMCR_EN (1 << 0) + +struct pwm_regs { + u32 cr; + u32 sr; + u32 ir; + u32 sar; + u32 pr; + u32 cnr; +}; #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
add basic support for the pwm modul found on imx6. Pieces of this code are based on linux code from drivers/pwm/pwm-imx.c Commit "cd3de83f1476 Linux 3.16-rc4"
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Stefano Babic sbabic@denx.de Cc: Wolfgang Denk wd@denx.de
--- - changes for v3: new in v3, as Stefano Babic suggested - changes for v4: - add Acked-by from Stefano Babic - add in the commit message the commit ID from linux on which pieces the code is based. - add comment from Wolfgang Denk: - move code which is based from linux into a seperate new file drivers/pwm/pwm-imx-util.c, so this can be with the GPL-2.0 license, and the code not taken from linux can be in GPL-2.0+
README | 4 +++ drivers/Makefile | 1 + drivers/pwm/Makefile | 13 +++++++++ drivers/pwm/pwm-imx-util.c | 73 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/pwm/pwm-imx-util.h | 16 ++++++++++ drivers/pwm/pwm-imx.c | 59 +++++++++++++++++++++++++++++++++++++ 6 files changed, 166 insertions(+) create mode 100644 drivers/pwm/Makefile create mode 100644 drivers/pwm/pwm-imx-util.c create mode 100644 drivers/pwm/pwm-imx-util.h create mode 100644 drivers/pwm/pwm-imx.c
diff --git a/README b/README index 1eecba6..9f07831 100644 --- a/README +++ b/README @@ -1377,6 +1377,10 @@ The following options need to be configured: CONFIG_SH_ETHER_CACHE_WRITEBACK If this option is set, the driver enables cache flush.
+- PWM Support: + CONFIG_PWM_IMX + Support for PWM modul on the imx6. + - TPM Support: CONFIG_TPM Support TPM devices. diff --git a/drivers/Makefile b/drivers/Makefile index b23076f..b22b109 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -15,3 +15,4 @@ obj-y += video/ obj-y += watchdog/ obj-$(CONFIG_QE) += qe/ obj-y += memory/ +obj-y += pwm/ diff --git a/drivers/pwm/Makefile b/drivers/pwm/Makefile new file mode 100644 index 0000000..c0c4883 --- /dev/null +++ b/drivers/pwm/Makefile @@ -0,0 +1,13 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2001 +# Erik Theisen, Wave 7 Optics, etheisen@mindspring.com. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +#ccflags-y += -DDEBUG + +obj-$(CONFIG_PWM_IMX) += pwm-imx.o pwm-imx-util.o diff --git a/drivers/pwm/pwm-imx-util.c b/drivers/pwm/pwm-imx-util.c new file mode 100644 index 0000000..f1d0b35 --- /dev/null +++ b/drivers/pwm/pwm-imx-util.c @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Basic support for the pwm modul on imx6. + * + * Based on linux:drivers/pwm/pwm-imx.c + * from + * Sascha Hauer s.hauer@pengutronix.de + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <div64.h> +#include <asm/arch/imx-regs.h> + +/* pwm_id from 0..3 */ +struct pwm_regs *pwm_id_to_reg(int pwm_id) +{ + switch (pwm_id) { + case 0: + return (struct pwm_regs *)PWM1_BASE_ADDR; + break; + case 1: + return (struct pwm_regs *)PWM2_BASE_ADDR; + break; + case 2: + return (struct pwm_regs *)PWM3_BASE_ADDR; + break; + case 3: + return (struct pwm_regs *)PWM4_BASE_ADDR; + break; + default: + printf("unknown pwm_id: %d\n", pwm_id); + break; + } + return NULL; +} + +int pwm_imx_get_parms(int period_ns, int duty_ns, unsigned long *period_c, + unsigned long *duty_c, unsigned long *prescale) +{ + unsigned long long c; + + /* + * we have not yet a clock framework for imx6, so add the clock + * value here as a define. Replace it when we have the clock + * framework. + */ + c = CONFIG_IMX6_PWM_PER_CLK; + c = c * period_ns; + do_div(c, 1000000000); + *period_c = c; + + *prescale = *period_c / 0x10000 + 1; + + *period_c /= *prescale; + c = (unsigned long long)(*period_c * duty_ns); + do_div(c, period_ns); + *duty_c = c; + + /* + * according to imx pwm RM, the real period value should be + * PERIOD value in PWMPR plus 2. + */ + if (*period_c > 2) + *period_c -= 2; + else + *period_c = 0; + + return 0; +} diff --git a/drivers/pwm/pwm-imx-util.h b/drivers/pwm/pwm-imx-util.h new file mode 100644 index 0000000..45465c4 --- /dev/null +++ b/drivers/pwm/pwm-imx-util.h @@ -0,0 +1,16 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Basic support for the pwm modul on imx6. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _pwm_imx_util_h_ +#define _pwm_imx_util_h_ + +struct pwm_regs *pwm_id_to_reg(int pwm_id); +int pwm_imx_get_parms(int period_ns, int duty_ns, unsigned long *period_c, + unsigned long *duty_c, unsigned long *prescale); +#endif diff --git a/drivers/pwm/pwm-imx.c b/drivers/pwm/pwm-imx.c new file mode 100644 index 0000000..40bf027 --- /dev/null +++ b/drivers/pwm/pwm-imx.c @@ -0,0 +1,59 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Basic support for the pwm modul on imx6. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <pwm.h> +#include <asm/arch/imx-regs.h> +#include <asm/io.h> +#include "pwm-imx-util.h" + +int pwm_init(int pwm_id, int div, int invert) +{ + struct pwm_regs *pwm = (struct pwm_regs *)pwm_id_to_reg(pwm_id); + + writel(0, &pwm->ir); + return 0; +} + +int pwm_config(int pwm_id, int duty_ns, int period_ns) +{ + struct pwm_regs *pwm = (struct pwm_regs *)pwm_id_to_reg(pwm_id); + unsigned long period_cycles, duty_cycles, prescale; + u32 cr; + + pwm_imx_get_parms(period_ns, duty_ns, &period_cycles, &duty_cycles, + &prescale); + + cr = PWMCR_PRESCALER(prescale) | + PWMCR_DOZEEN | PWMCR_WAITEN | + PWMCR_DBGEN | PWMCR_CLKSRC_IPG_HIGH; + + writel(cr, &pwm->cr); + /* set duty cycles */ + writel(duty_cycles, &pwm->sar); + /* set period cycles */ + writel(period_cycles, &pwm->pr); + return 0; +} + +int pwm_enable(int pwm_id) +{ + struct pwm_regs *pwm = (struct pwm_regs *)pwm_id_to_reg(pwm_id); + + setbits_le32(&pwm->cr, PWMCR_EN); + return 0; +} + +void pwm_disable(int pwm_id) +{ + struct pwm_regs *pwm = (struct pwm_regs *)pwm_id_to_reg(pwm_id); + + clrbits_le32(&pwm->cr, PWMCR_EN); +}
add enable_spi_clk(), so board code can enable spi clocks.
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Cc: Eric Nelson eric.nelson@boundarydevices.com Cc: Stefano Babic sbabic@denx.de
--- - changes for v2: - add comment from Stefano Babic: - add comment for spi_num range - add SPI_MAX_NUM in imx-regs.h - changes for v3: - add Reviewed-by from Jagannadha Sutradharudu Teki - changes for v4: none
arch/arm/cpu/armv7/mx6/clock.c | 18 ++++++++++++++++++ arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 1 + 3 files changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 7dd83ec..e60cd46 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -71,6 +71,24 @@ int enable_i2c_clk(unsigned char enable, unsigned i2c_num) } #endif
+/* spi_num can be from 0 - SPI_MAX_NUM */ +int enable_spi_clk(unsigned char enable, unsigned spi_num) +{ + u32 reg; + u32 mask; + + if (spi_num > SPI_MAX_NUM) + return -EINVAL; + + mask = MXC_CCM_CCGR_CG_MASK << (spi_num << 1); + reg = __raw_readl(&imx_ccm->CCGR1); + if (enable) + reg |= mask; + else + reg &= ~mask; + __raw_writel(reg, &imx_ccm->CCGR1); + return 0; +} static u32 decode_pll(enum pll_clocks pll, u32 infreq) { u32 div; diff --git a/arch/arm/include/asm/arch-mx6/clock.h b/arch/arm/include/asm/arch-mx6/clock.h index 1b4ded7..339c789 100644 --- a/arch/arm/include/asm/arch-mx6/clock.h +++ b/arch/arm/include/asm/arch-mx6/clock.h @@ -57,6 +57,7 @@ void enable_usboh3_clk(unsigned char enable); int enable_sata_clock(void); int enable_pcie_clock(void); int enable_i2c_clk(unsigned char enable, unsigned i2c_num); +int enable_spi_clk(unsigned char enable, unsigned spi_num); void enable_ipu_clock(void); int enable_fec_anatop_clock(enum enet_freq freq); #endif /* __ASM_ARCH_CLOCK_H */ diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 2135051..aa5bc92 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -405,6 +405,7 @@ struct cspi_regs { #define MXC_CSPICTRL_RXOVF (1 << 6) #define MXC_CSPIPERIOD_32KHZ (1 << 15) #define MAX_SPI_BYTES 32 +#define SPI_MAX_NUM 4
/* Bit position inside CTRL register to be associated with SS */ #define MXC_CSPICTRL_CHAN 18
enable the W#/Vpp signal to disable writing to the status register on ST MICRON flashes like the N25Q128 thorugh the new config option CONFIG_SYS_SPI_ST_ENABLE_WP_PIN
Signed-off-by: Heiko Schocher hs@denx.de Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
--- - changes for v4: none
README | 11 +++++++++++ drivers/mtd/spi/sf_internal.h | 4 ++++ drivers/mtd/spi/sf_probe.c | 30 ++++++++++++++++++++++++++++++ 3 files changed, 45 insertions(+)
diff --git a/README b/README index 9f07831..63617ce 100644 --- a/README +++ b/README @@ -2937,6 +2937,17 @@ CBFS (Coreboot Filesystem) support CONFIG_SPI_FLASH_MTD add MTD translation layer driver.
+ CONFIG_SYS_SPI_ST_ENABLE_WP_PIN + enable the W#/Vpp signal to disable writing to the status + register on ST MICRON flashes like the N25Q128. + The status register write enable/disable bit, combined with + the W#/VPP signal provides hardware data protection for the + device as follows: When the enable/disable bit is set to 1, + and the W#/VPP signal is driven LOW, the status register + nonvolatile bits become read-only and the WRITE STATUS REGISTER + operation will not execute. The only way to exit this + hardware-protected mode is to drive W#/VPP HIGH. + - SystemACE Support: CONFIG_SYSTEMACE
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 5c66d9f..a9f97d1 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -60,6 +60,10 @@ #define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7)
+#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN +#define STATUS_SRWD (1 << 7) /* SR write protect */ +#endif + /* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) #define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index f6d793b..6c50766 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -281,6 +281,34 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) } #endif /* CONFIG_OF_CONTROL */
+#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN +/* enable the W#/Vpp signal to disable writing to the status register */ +static int spi_enable_wp_pin(struct spi_flash *flash) +{ + u8 status; + int ret; + + ret = spi_flash_cmd_read_status(flash, &status); + if (ret < 0) + return ret; + + ret = spi_flash_cmd_write_status(flash, STATUS_SRWD); + if (ret < 0) + return ret; + + ret = spi_flash_cmd_write_disable(flash); + if (ret < 0) + return ret; + + return 0; +} +#else +static int spi_enable_wp_pin(struct spi_flash *flash) +{ + return 0; +} +#endif + static struct spi_flash *spi_flash_probe_slave(struct spi_slave *spi) { struct spi_flash *flash = NULL; @@ -351,6 +379,8 @@ static struct spi_flash *spi_flash_probe_slave(struct spi_slave *spi) puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); } #endif + if (spi_enable_wp_pin(flash)) + puts("Enable WP pin failed\n");
/* Release spi bus */ spi_release_bus(spi);
CPU: Freescale i.MX6DL rev1.1 at 792 MHz Board: aristaitenos I2C: ready DRAM: 1 GiB NAND: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lb07wv8 (800x480)
- UART5 is console - MMC 0 and 1 - USB 0 and 1 - boot from mmc0 and spi nor flash - Splash screen support
--- - changes for v2: - change MUX_PAD_CTRL value for MX6_PAD_GPIO_16__ENET_REF_CLK - set cs1 from ecspi4 to high - add splash screen support - add comment from Stefano babic: - remove mxc_iomux_set_gpr_register instead use setbits_le32 remove patch http://patchwork.ozlabs.org/patch/353324/ from this patchserie, as no longer needed - use for loop for calling enable_spi_clk() - simplify board_mmc_getcd() - simplify board_mmc_init() - remove board_phy_config() - remove setup_fec() and work code into board_eth_init() - use define for i2c slave address - remove udelay in board_ehci_hcd_init() - remove CONFIG_SPL_BUILD, as this board does not use CONFIG_SPL_BUILD - changes for v3: - add comment from Stefano Babic: - simplify setup_iomux_uart() - remove enable_spi() - remove enable wp pin for the st micron flash from board code to spi driver. Enable this new config option only in board config file - use common functions from pwm modul - changes for v4: - add comment from Stefano Babic: - remove board_late_init() - remove unnecessary ifdef in board config file
board/aristainetos/Makefile | 9 + board/aristainetos/aristainetos.c | 519 ++++++++++++++++++++++++++++++++++++ board/aristainetos/aristainetos.cfg | 33 +++ board/aristainetos/clocks.cfg | 24 ++ board/aristainetos/ddr-setup.cfg | 61 +++++ board/aristainetos/mt41j128M.cfg | 70 +++++ boards.cfg | 1 + include/configs/aristainetos.h | 325 ++++++++++++++++++++++ 8 files changed, 1042 insertions(+) create mode 100644 board/aristainetos/Makefile create mode 100644 board/aristainetos/aristainetos.c create mode 100644 board/aristainetos/aristainetos.cfg create mode 100644 board/aristainetos/clocks.cfg create mode 100644 board/aristainetos/ddr-setup.cfg create mode 100644 board/aristainetos/mt41j128M.cfg create mode 100644 include/configs/aristainetos.h
diff --git a/board/aristainetos/Makefile b/board/aristainetos/Makefile new file mode 100644 index 0000000..5de48bc --- /dev/null +++ b/board/aristainetos/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := aristainetos.o diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c new file mode 100644 index 0000000..cf2c88a --- /dev/null +++ b/board/aristainetos/aristainetos.c @@ -0,0 +1,519 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2012 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/video.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <pwm.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +#define DISP_PAD_CTRL (0x10) + +#define ECSPI4_CS1 IMX_GPIO_NR(5, 2) + +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC, + .gp = IMX_GPIO_NR(5, 27) + }, + .sda = { + .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, + .gp = IMX_GPIO_NR(5, 26) + } +}; + +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +struct i2c_pads_info i2c_pad_info3 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D17__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D17__GPIO3_IO17 | PC, + .gp = IMX_GPIO_NR(3, 17) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D18__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D18__GPIO3_IO18 | PC, + .gp = IMX_GPIO_NR(3, 18) + } +}; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart5_pads[] = { + MX6_PAD_CSI0_DAT14__UART5_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const gpio_pads[] = { + /* LED enable */ + MX6_PAD_SD4_DAT5__GPIO2_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* spi flash WP protect */ + MX6_PAD_SD4_DAT7__GPIO2_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* backlight enable */ + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED yellow */ + MX6_PAD_GPIO_3__GPIO1_IO03 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED red */ + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED green */ + MX6_PAD_GPIO_5__GPIO1_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED blue */ + MX6_PAD_GPIO_6__GPIO1_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* i2c4 scl */ + MX6_PAD_GPIO_7__GPIO1_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* i2c4 sda */ + MX6_PAD_GPIO_8__GPIO1_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* spi CS 1 */ + MX6_PAD_EIM_A25__GPIO5_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const misc_pads[] = { + MX6_PAD_GPIO_1__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL), + /* OTG Power enable */ + MX6_PAD_EIM_D31__GPIO3_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(0x4001b0a8), + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TX_EN__ENET_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RX_ER__ENET_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_CRS_DV__ENET_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + /* set GPIO_16 as ENET_REF_CLK_OUT */ + setbits_le32(&iomux->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); +} + +iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +iomux_v3_cfg_t const ecspi4_pads[] = { + MX6_PAD_EIM_D21__ECSPI4_SCLK | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D22__ECSPI4_MISO | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D28__ECSPI4_MOSI | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D20__GPIO3_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const display_pads[] = { + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK | MUX_PAD_CTRL(DISP_PAD_CTRL), + MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02, + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03, + MX6_PAD_DI0_PIN4__GPIO4_IO20, + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00, + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01, + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02, + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03, + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04, + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05, + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06, + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07, + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08, + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09, + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10, + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11, + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12, + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13, + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14, + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15, + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16, + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17, + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18, + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19, + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20, + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21, + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22, + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23, +}; + +static iomux_v3_cfg_t const backlight_pads[] = { + MX6_PAD_GPIO_9__PWM1_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT1__PWM3_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_spi(void) +{ + int i; + + imx_iomux_v3_setup_multiple_pads(ecspi4_pads, ARRAY_SIZE(ecspi4_pads)); + for (i = 0; i < 3; i++) + enable_spi_clk(true, i); + + /* set cs1 to high */ + gpio_direction_output(ECSPI4_CS1, 1); +} + +static void setup_iomux_gpio(void) +{ + imx_iomux_v3_setup_multiple_pads(gpio_pads, ARRAY_SIZE(gpio_pads)); +} + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads)); +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR}, + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]) | + fsl_esdhc_initialize(bis, &usdhc_cfg[1]); +} +#endif + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_eth_init(bd_t *bis) +{ + struct iomuxc_base_regs *iomuxc_regs = + (struct iomuxc_base_regs *)IOMUXC_BASE_ADDR; + int ret; + + setup_iomux_enet(); + /* clear gpr1[14], gpr1[18:17] to select anatop clock */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0); + + ret = enable_fec_anatop_clock(ENET_50MHz); + if (ret) + return ret; + + return cpu_eth_init(bis); +} +#if defined(CONFIG_VIDEO_IPUV3) + +static void enable_lvds(struct display_info_t const *dev) +{ + imx_iomux_v3_setup_multiple_pads( + display_pads, + ARRAY_SIZE(display_pads)); + imx_iomux_v3_setup_multiple_pads( + backlight_pads, + ARRAY_SIZE(backlight_pads)); + + /* enable backlight PWM 3 */ + if (pwm_init(2, 0, 0)) + goto error; + /* duty cycle 200ns, period: 3000ns */ + if (pwm_config(2, 200, 3000)) + goto error; + if (pwm_enable(2)) + goto error; + return; + +error: + puts("error init pwm for backlight\n"); + return; +} + +struct display_info_t const displays[] = { + { + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = NULL, + .enable = enable_lvds, + .mode = { + .name = "lb07wv8", + .refresh = 60, + .xres = 800, + .yres = 480, + .pixclock = 33246, + .left_margin = 88, + .right_margin = 88, + .upper_margin = 10, + .lower_margin = 10, + .hsync_len = 25, + .vsync_len = 1, + .sync = 0, + .vmode = FB_VMODE_NONINTERLACED + } + } +}; +size_t display_count = ARRAY_SIZE(displays); + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + int reg; + + enable_ipu_clock(); + + reg = readl(&mxc_ccm->cs2cdr); + /* select pll 5 clock */ + reg &= MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK; + reg &= MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK; + writel(reg, &mxc_ccm->cs2cdr); + + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); +} + +/* no console on this board */ +int board_cfb_skip(void) +{ + return 1; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + setup_iomux_gpio(); + +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + return 0; +} + +iomux_v3_cfg_t nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS2__NAND_CE2_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS3__NAND_CE3_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, + ARRAY_SIZE(nfc_pads)); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} + +int board_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + setup_spi(); + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info1); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info2); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info3); + + /* i2c4 not used, set it to gpio input */ + gpio_request(IMX_GPIO_NR(1, 7), "i2c4_scl"); + gpio_direction_input(IMX_GPIO_NR(1, 7)); + gpio_request(IMX_GPIO_NR(1, 8), "i2c4_sda"); + gpio_direction_input(IMX_GPIO_NR(1, 8)); + + /* SPI NOR Flash read only */ + gpio_request(CONFIG_GPIO_ENABLE_SPI_FLASH, "ena_spi_nor"); + gpio_direction_output(CONFIG_GPIO_ENABLE_SPI_FLASH, 0); + gpio_free(CONFIG_GPIO_ENABLE_SPI_FLASH); + + /* enable LED */ + gpio_request(IMX_GPIO_NR(2, 13), "LED ena"); + gpio_direction_output(IMX_GPIO_NR(2, 13), 0); + + gpio_request(IMX_GPIO_NR(1, 3), "LED yellow"); + gpio_direction_output(IMX_GPIO_NR(1, 3), 1); + gpio_request(IMX_GPIO_NR(1, 4), "LED red"); + gpio_direction_output(IMX_GPIO_NR(1, 4), 1); + gpio_request(IMX_GPIO_NR(1, 5), "LED green"); + gpio_direction_output(IMX_GPIO_NR(1, 5), 1); + gpio_request(IMX_GPIO_NR(1, 6), "LED blue"); + gpio_direction_output(IMX_GPIO_NR(1, 6), 1); + + setup_gpmi_nand(); + + /* GPIO_1 for USB_OTG_ID */ + setbits_le32(&iomux->gpr[1], IOMUXC_GPR1_USB_OTG_ID_SEL_MASK); + imx_iomux_v3_setup_multiple_pads(misc_pads, ARRAY_SIZE(misc_pads)); + + return 0; +} + +int checkboard(void) +{ + puts("Board: aristaitenos\n"); + return 0; +} + +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + int ret; + + ret = gpio_request(ARISTAINETOS_USB_H1_PWR, "usb-h1-pwr"); + if (!ret) + gpio_direction_output(ARISTAINETOS_USB_H1_PWR, 1); + ret = gpio_request(ARISTAINETOS_USB_OTG_PWR, "usb-OTG-pwr"); + if (!ret) + gpio_direction_output(ARISTAINETOS_USB_OTG_PWR, 1); + return 0; +} + +int board_ehci_power(int port, int on) +{ + if (port) + gpio_set_value(ARISTAINETOS_USB_OTG_PWR, on); + else + gpio_set_value(ARISTAINETOS_USB_H1_PWR, on); + return 0; +} +#endif diff --git a/board/aristainetos/aristainetos.cfg b/board/aristainetos/aristainetos.cfg new file mode 100644 index 0000000..2290180 --- /dev/null +++ b/board/aristainetos/aristainetos.cfg @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer doc/README.imximage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd + */ +BOOT_FROM spi + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "mt41j128M.cfg" +#include "clocks.cfg" diff --git a/board/aristainetos/clocks.cfg b/board/aristainetos/clocks.cfg new file mode 100644 index 0000000..651449e --- /dev/null +++ b/board/aristainetos/clocks.cfg @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00c03f3f +DATA 4, CCM_CCGR1, 0x0030fcff +DATA 4, CCM_CCGR2, 0x0fffcfc0 +DATA 4, CCM_CCGR3, 0x3ff0300f +DATA 4, CCM_CCGR4, 0xfffff30c /* enable NAND/GPMI/BCH clocks */ +DATA 4, CCM_CCGR5, 0x0f0000c3 +DATA 4, CCM_CCGR6, 0x000003ff diff --git a/board/aristainetos/ddr-setup.cfg b/board/aristainetos/ddr-setup.cfg new file mode 100644 index 0000000..c72a3ef --- /dev/null +++ b/board/aristainetos/ddr-setup.cfg @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* DDR IO TYPE */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +/* Clock */ +DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00000030 +/* Address */ +DATA 4, MX6_IOM_DRAM_CAS, 0x00000030 +DATA 4, MX6_IOM_DRAM_RAS, 0x00000030 +DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 +/* Control */ +DATA 4, MX6_IOM_DRAM_RESET, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 +DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 +DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 +/* Data Strobe */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 +DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B4DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B5DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B6DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B7DS, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM0, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM1, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM2, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM3, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM4, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM5, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM6, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM7, 0x00000030 diff --git a/board/aristainetos/mt41j128M.cfg b/board/aristainetos/mt41j128M.cfg new file mode 100644 index 0000000..3561655 --- /dev/null +++ b/board/aristainetos/mt41j128M.cfg @@ -0,0 +1,70 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/* ZQ Calibration */ +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xa1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xa1390003 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x001F001F +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x001F001F +/* + * DQS gating, read delay, write delay calibration values + * based on calibration compare of 0x00ffff00 + */ +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x420E020E +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x02000200 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42020202 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x01720172 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x494C4F4C +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4A4C4C49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3133 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x39373F2E +/* read data bit delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 +/* Complete calibration by forced measurment */ +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +/* in DDR3, 64-bit mode, only MMDC0 is initiated */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002d +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40445323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xb66e8c63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01ff00db +DATA 4, MX6_MMDC_P0_MDMISC, 0x00081740 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026d2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00440e21 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x84190000 +/* MR2 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x0400803a +/* MR3 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x0000803b +/* MR1 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428039 +/* MR0 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x07208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x07208038 +/* ZQ calibration */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008048 +/* final ddr setup */ +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000007 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00000007 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556d +DATA 4, MX6_MMDC_P1_MAPSR, 0x00011006 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 diff --git a/boards.cfg b/boards.cfg index 1ba2081..510c2f4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -311,6 +311,7 @@ Active arm armv7 mx5 freescale mx53smd Active arm armv7 mx5 genesi mx51_efikamx mx51_efikamx mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg - Active arm armv7 mx5 genesi mx51_efikamx mx51_efikasb mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg - Active arm armv7 mx5 ttcontrol vision2 vision2 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx6 - aristainetos aristainetos aristainetos:IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL Heiko Schocher hs@denx.de Active arm armv7 mx6 - udoo udoo_quad udoo:IMX_CONFIG=board/udoo/udoo.cfg,MX6Q,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 - wandboard wandboard_dl wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 - wandboard wandboard_quad wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Fabio Estevam fabio.estevam@freescale.com diff --git a/include/configs/aristainetos.h b/include/configs/aristainetos.h new file mode 100644 index 0000000..20aea85 --- /dev/null +++ b/include/configs/aristainetos.h @@ -0,0 +1,325 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2012 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6Q SabreSD board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __ARISTAINETOS_CONFIG_H +#define __ARISTAINETOS_CONFIG_H + +#define CONFIG_MX6 + +#include "mx6_common.h" +#include <linux/sizes.h> + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_MACH_TYPE 4501 +#define CONFIG_MMCROOT "/dev/mmcblk0p2" +#define CONFIG_DEFAULT_FDT_FILE "aristainetos.dtb" +#define CONFIG_HOSTNAME aristainetos +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) + +#define CONFIG_SYS_GENERIC_BOARD + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (64 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART5_BASE +#define CONFIG_CONSOLE_DEV "ttymxc4" + +#define CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 + +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL + +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_MTD +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 3 +#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 20)<<8)) +#define CONFIG_SF_DEFAULT_SPEED 20000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SYS_SPI_ST_ENABLE_WP_PIN + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_SETEXPR +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "uimage=uImage\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr_r=0x11000000\0" \ + "kernel_addr_r=0x12000000\0" \ + "kernel_file=uImage\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "console=" CONFIG_CONSOLE_DEV "\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "mmcpart=1\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${kernel_addr_r} " \ + "${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} " \ + "${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs;run loadimage loadfdt fdt_setup;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r};\0" \ + "rootpath=/opt/eldk-5.5/armv7a-hf/rootfs-sato-sdk\0" \ + "nfsopts=nfsvers=3 nolock rw\0" \ + "netdev=eth0\0" \ + "fdt_setup=fdt addr ${fdt_addr_r};fdt resize;fdt chosen;fdt board\0"\ + "load_fdt=tftp ${fdt_addr_r} ${fdt_file}\0" \ + "load_kernel=tftp ${kernel_addr_r} ${kernel_file}\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "get_env=mw ${loadaddr} 0x00000000 0x20000;" \ + "tftp ${loadaddr} /tftpboot/aristainetos/env.txt;" \ + "env import -t ${loadaddr}\0" \ + "addmisc=setenv bootargs ${bootargs} maxcpus=1 loglevel=8\0" \ + "bootargs_defaults=setenv bootargs ${console} ${mtdoops} " \ + "${optargs}\0" \ + "net_args=run bootargs_defaults;setenv bootargs ${bootargs} " \ + "root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "${hostname}:${netdev}:off\0" \ + "net_nfs=run load_kernel load_fdt;run net_args addmtd addmisc;" \ + "run fdt_setup;bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "uboot=/tftpboot/aristainetos/u-boot.imx\0" \ + "load_uboot=tftp ${loadaddr} ${uboot}\0" \ + "uboot_sz=c0000\0" \ + "upd_uboot=mw.b ${loadaddr} 0xff ${uboot_sz};" \ + "mw.b 10200000 0x00 ${uboot_sz};" \ + "run load_uboot;sf probe;sf erase 0 ${uboot_sz};" \ + "sf write ${loadaddr} 400 ${filesize};" \ + "sf read 10200000 400 ${uboot_sz};" \ + "cmp.b ${loadaddr} 10200000 bc000\0" \ + "ubi_prep=ubi part ubi 2048;ubifsmount ubi:kernel\0" \ + "load_kernel_ubi=ubifsload ${kernel_addr_r} uImage\0" \ + "load_fdt_ubi=ubifsload ${fdt_addr_r} aristainetos.dtb\0" \ + "ubi_nfs=run ubiprep load_kernel_ubi load_fdt_ubi;" \ + "run net_args addmtd addmisc;run fdt_setup;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "rootfsname=rootfs\0" \ + "ubi_args=run bootargs_defaults;setenv bootargs ${bootargs} " \ + "ubi.mtd=0,2048 root=ubi0:${rootfsname} rootfstype=ubifs " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "${hostname}:${netdev}:off\0" \ + "ubi_ubi=run ubi_prep load_kernel_ubi load_fdt_ubi;" \ + "run bootargs_defaults ubi_args addmtd addmisc;" \ + "run fdt_setup;bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "ubirootfs_file=/tftpboot/aristainetos/rootfs-minimal.ubifs\0" \ + "upd_ubirootfs=run ubi_prep;tftp ${loadaddr} ${ubirootfs_file};" \ + "ubi write ${loadaddr} rootfs ${filesize}\0" \ + "ksz=800000\0" \ + "rootsz=2000000\0" \ + "usersz=8000000\0" \ + "ubi_make=run ubi_prep;ubi create kernel ${ksz};" \ + "ubi create rootfs ${rootsz};ubi create userfs ${usersz}\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "if mmc rescan; then " \ + "run mmcboot;" \ + "else run ubi_ubi; fi" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x100000) +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE (128 * 1024) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (12 * 1024) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SECT_SIZE (0x010000) +#define CONFIG_ENV_OFFSET (0x0c0000) +#define CONFIG_ENV_OFFSET_REDUND (0x0d0000) + +#define CONFIG_OF_LIBFDT + +#define CONFIG_CMD_CACHE + +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x00} } + +#define CONFIG_CMD_GPIO +#define CONFIG_GPIO_ENABLE_SPI_FLASH IMX_GPIO_NR(2, 15) + +/* NAND stuff */ +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_NAND_MXS +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* DMA stuff, needed for GPMI/MXS NAND support */ +#define CONFIG_APBH_DMA +#define CONFIG_APBH_DMA_BURST +#define CONFIG_APBH_DMA_BURST8 + +/* RTC */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_RTC_BUS_NUM 2 +#define CONFIG_RTC_M41T11 +#define CONFIG_CMD_DATE + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +#define ARISTAINETOS_USB_OTG_PWR IMX_GPIO_NR(4, 15) +#define ARISTAINETOS_USB_H1_PWR IMX_GPIO_NR(3, 31) + +/* UBI support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS + +#define MTDIDS_DEFAULT "nand0=gpmi-nand" +#define MTDPARTS_DEFAULT "mtdparts=gpmi-nand:-(ubi)" + +#define CONFIG_MTD_UBI_FASTMAP +#define CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT 1 + +#define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_WATCHDOG + +#define CONFIG_FIT + +/* Framebuffer */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +/* check this console not needed, after test remove it */ +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_IPUV3_CLK 198000000 +#define CONFIG_IMX_VIDEO_SKIP + +#define CONFIG_CMD_BMP + +#define CONFIG_PWM_IMX +#define CONFIG_IMX6_PWM_PER_CLK 66000000 + +#endif /* __ARISTAINETOS_CONFIG_H */
Hi Heiko,
On 18/07/2014 06:07, Heiko Schocher wrote:
All series applied with the following change due to inclusion Fabios's cleanup for iomuxc register (http://patchwork.ozlabs.org/patch/368335/)
int board_eth_init(bd_t *bis) { - struct iomuxc_base_regs *iomuxc_regs = - (struct iomuxc_base_regs *)IOMUXC_BASE_ADDR; + struct iomuxc *iomuxc_regs = + (struct iomuxc *)IOMUXC_BASE_ADDR;
Best regards, Stefano Babic
Heiko Schocher
Stefano Babic
