[GIT PULL] Pull request: u-boot-imx u-boot-imx-20191228
Hi Tom,
some fixes for 2020.01, please pull from u-boot-imx, thanks !
The following changes since commit 2ce1dbbeecd085be695c00a244c0dcc82aed3b82:
Merge branch '2019-12-26-ti-imports' (2019-12-26 09:07:08 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20191228
for you to fetch changes up to fff7b33ce5b1b3687857ea4184d71bf4ce1f6364:
rtc: rx8010js: add compatible string (2019-12-27 14:34:29 +0100)
---------------------------------------------------------------- Fixes for 2020.01 ----------------- - Fixes for Nitrogen6x - Fix corruption for mx51evk - colibri i.MX6: fix broken ESDHC conversion - mx6sxsabresd: fix broken mmcdev - imx6q_logic: cleanup boot sequence - update ATF for imx8mq_evk - pfuze: fix pmic_get()
Travis CI: https://travis-ci.org/sbabic/u-boot-imx/builds/630007464
---------------------------------------------------------------- Adam Ford (1): ARM: imx6q_logic: Cleanup boot sequence check
Fabio Estevam (6): pfuze: Fix the pmic_get() parameter in the DM case mx6sxsabresd: Adjust the mmcdev after DM conversion mx51evk: Fix U-Boot corruption after saving the environment imx8m: ddr_init: Move ddr_init() messages to debug level imx8m_evk: Remove unneeded earlycon string imx8mq_evk: Update the required ATF branch
Igor Opaniuk (1): colibri_imx6: fix broken fsl_esdhc_imx conversion
Jorge Ramirez-Ortiz (1): tools/imximage: share DCD information via Kconfig
Robert Beckett (3): rtc: rx8010sj: fix DM initialization rtc: s35392a: add compatible strings rtc: rx8010js: add compatible string
Troy Kisky (2): nitrogen6x: prepare for CONFIG_MX6QDL ARM: i.MX6: TARGET_NITROGEN6X: add 'select MX6QDL'
arch/arm/mach-imx/Kconfig | 11 +++ arch/arm/mach-imx/mx6/Kconfig | 1 + board/boundary/nitrogen6x/nitrogen6x.c | 370 ++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------- board/freescale/common/pfuze.c | 2 +- board/freescale/imx8mq_evk/README | 2 +- board/logicpd/imx6/imx6logic.c | 56 ++++++++++----- board/toradex/colibri_imx6/colibri_imx6.c | 4 +- configs/mx51evk_defconfig | 2 +- drivers/ddr/imx/imx8m/ddr_init.c | 6 +- drivers/rtc/rx8010sj.c | 3 +- drivers/rtc/s35392a.c | 2 + include/configs/imx8mm_evk.h | 2 +- include/configs/imx8mn_evk.h | 2 +- include/configs/imx8mq_evk.h | 2 +- include/configs/mx51evk.h | 13 ++++ include/configs/mx6sxsabresd.h | 4 +- tools/imximage.c | 8 ++- 17 files changed, 280 insertions(+), 210 deletions(-)
Stefano
On Sat, Dec 28, 2019 at 11:57:03AM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
