[U-Boot] [PATCH] Makefile: restore *_config target
The switch to KConfig break the [board]_config target. This breaks backwards compatibility and hence all documentation about how to build u-boot is no longer valid. It is also annoying for general recipes to build u-boot as contained in buildroot, crochet, oe, poky, eldk etc. Hence restore the *_config target.
cc: Tom Rini trini@ti.com cc: Masahiro Yamada yamada.m@jp.panasonic.com cc: Simon Glass sjg@chromium.org Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- Makefile | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 5e49545..2a339aa 100644 --- a/Makefile +++ b/Makefile @@ -413,7 +413,7 @@ endif version_h := include/generated/version_autogenerated.h timestamp_h := include/generated/timestamp_autogenerated.h
-no-dot-config-targets := clean clobber mrproper distclean \ +no-dot-config-targets := clean clobber %_config mrproper distclean \ help %docs check% coccicheck \ ubootversion backup tools-only
@@ -436,6 +436,11 @@ ifeq ($(KBUILD_EXTMOD),) endif endif
+# Before the switch to KConfig the configure target was %_config instead +# of %_defconfig. Just reinvoke make to be backwards compatible. +%_config: FORCE + $(Q)$(MAKE) $(@:_config=_defconfig) + ifeq ($(mixed-targets),1) # =========================================================================== # We're called with mixed targets (*config and build targets).
Hi Jeroen,
OK.
This change is not necessay at all, I think.
- $(Q)$(MAKE) $(@:_config=_defconfig)
Because <board>_config matches "%config" pattern at line 467, could you modify scripts/multiconfig.py, please?
Best Regards Masahiro Yamada
Hello Masahiro,
On 04-08-14 03:51, Masahiro Yamada wrote:
Hi Jeroen,
OK.
Depends on the intention, I do _not_ want to invoke the %config for the %_config target, and this prevents that.
- ifeq ($(mixed-targets),1) # =========================================================================== # We're called with mixed targets (*config and build targets).
Well only when ifeq ($(config-targets),1) was true, which above prevents.
I don't understand what you want to change there... it should only see %_defconfig.
Regards, Jeroen
Hi Jeroen,
On Mon, 04 Aug 2014 19:49:24 +0200 Jeroen Hofstee jeroen@myspectrum.nl wrote:
I am afraid you are misunderstanding the usage of no-dot-config-targets.
This variable contains targets we can run without the configuration, such as cleaning targets, help targets, ...
You are adding the configuration target itself to this variable.
"<board>_config" is now an alias of "<board>_defconfig", right?
I thoght it is more reasonable to handle it in the same place as the other configuration targets.
Could you try the following patch?
diff --git a/scripts/multiconfig.py b/scripts/multiconfig.py index 749abcb..30bfd7f 100755 --- a/scripts/multiconfig.py +++ b/scripts/multiconfig.py @@ -402,6 +402,9 @@ def main(): cmd = sys.argv[1] if cmd.endswith('_defconfig'): do_board_defconfig(cmd) + elif cmd.endswith('_config'): + # backward compatibility + do_board_defconfig(cmd[:-len('_config')] + '_defconfig') else: func = cmd_list.get(cmd, do_others) func(cmd)
Hi Masahiro,
No I am not misunderstanding it. I am adding an alias not a configure target and an alias can obviously run without a configured u-boot (and should in this case). If I move the rule up it can be avoided if you insist on it.
yes, make %_config just invokes make %_defconfig. That is all.
Matter of taste I guess, I like my approach more, since it catches differences earlier and no scripts below have to be altered.
- elif cmd.endswith('_config'):
else: func = cmd_list.get(cmd, do_others) func(cmd)do_board_defconfig(cmd[:-len('_config')] + '_defconfig')
I can't parse this, since I don't know python that well, but it likely works. I do like it more if make already handled it though.
Regards, Jeroen
Hi Jeroen,
On Tue, 05 Aug 2014 21:35:18 +0200 Jeroen Hofstee jeroen@myspectrum.nl wrote:
Hi Masahiro,
Not at all. Confituration targets should go inside "ifeq ($(config-targets),1) ... else", your code is breaking the basic concept of the top Makefile.
NAK. At least, your patch does not work with O= option.
$ git log commit 5981f2917be03463714d8badfc78454c02ca160e Author: Jeroen Hofstee jeroen@myspectrum.nl Date: Fri Aug 1 21:28:54 2014 +0200
commit 25b4adbba018633b943a99322bfb2fb819c0bafb Author: Masahiro Yamada yamada.m@jp.panasonic.com Date: Wed Jul 30 14:08:25 2014 +0900
include: remove CONFIG_SPL/CONFIG_TPL definition in config headers
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Reviewed-by: Simon Glass sjg@chromium.org
$ git clean -x -d -f $ git status On branch jeroen nothing to commit, working directory clean $ make O=foo sandbox_config make[2]: *** No rule to make target `sandbox_defconfig'. Stop. make[1]: *** [sandbox_config] Error 2 make: *** [sub-make] Error 2 $ make O=foo sandbox_defconfig HOSTCC scripts/basic/fixdep GEN /home/yamada/workspace/u-boot-org/foo/Makefile HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf # # configuration written to .config #
On 06-08-14 04:11, Masahiro Yamada wrote:
Hi Jeroen,
Hi Masahiro,
diff --git a/Makefile b/Makefile index 5e49545..2a339aa 100644 --- a/Makefile +++ b/Makefile @@ -413,7 +413,7 @@ endif version_h := include/generated/version_autogenerated.h timestamp_h := include/generated/timestamp_autogenerated.h >> -no-dot-config-targets := clean clobber mrproper distclean \ +no-dot-config-targets := clean clobber %_config mrproper distclean \ help %docs check% coccicheck \ ubootversion backup tools-only
@@ -436,6 +436,11 @@ ifeq ($(KBUILD_EXTMOD),) endif endif >> +# Before the switch to KConfig the configure target was %_config instead +# of %_defconfig. Just reinvoke make to be backwards compatible. +%_config: FORCE
yes, the defconfig needs to be before the change path indeed. (as in, the rule must be moved up to work properly). I it marked it as refused.
Regards, Jeroen
Hi Jeroen,
Is there any way we can emit a deprecation warning without breaking these tools?
Hello Simon,
On 04-08-14 12:09, Simon Glass wrote:
Hi Jeroen,
I guess the number of ways to do that are just limited by our imagination: - abusing the bell character can be quite annoying, but is broken / fixed in the linux distro's I know. - echo "Hi there, U-boot folks over here, please STOP using _config, use _defconfig instead!" | write $USER will scare quite a few users I guess. - sendmail + git config user.email of the OE tree should be annoying enough - lpr ;) - play ? - figure out which oe recipe invoked it and patch it from u-boot ;)
And as a serious answer, no I don't know a decent method to do it. As far as I know OE e.g. just logs to a file and only displays its contents if an error occurred.
Afaiac, the target is just kept. Just to prevent wasting time updating all wikis, docs etc, recipe etc. (it is not that it is a big pile of code or something). I can add an echo of course, but it won't be noticed by such build tools.
Regards, Jeroen
Jeroen Hofstee
Jeroen Hofstee
Masahiro Yamada
