[U-Boot] [PATCH 1/3] ARM: relocate: fix hang when CONFIG_ARMV7_SECURE_BASE
When added above configuration, iram fix up plus relocate offset may locate in invalidate space. Write back fix up value will cause data abort.
Add address check, skip psci code.
Signed-off-by: Frank Li Frank.Li@freescale.com --- arch/arm/lib/relocate.S | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/lib/relocate.S b/arch/arm/lib/relocate.S index 475d503..6795a1b 100644 --- a/arch/arm/lib/relocate.S +++ b/arch/arm/lib/relocate.S @@ -99,6 +99,10 @@ fixloop: cmp r1, #23 /* relative fixup? */ bne fixnext
+ ldr r1, =__image_copy_start + cmp r0, r1 + blo fixnext + /* relative fix: increase location by offset */ add r0, r0, r4 ldr r1, [r0]
add basic psci support for imx7 chip. support cpu_on and cpu_off. linux kernel boot at nosecure mode. set csu allow nosecure mode kernel to access all peripherial register
Signed-off-by: Frank Li Frank.Li@freescale.com --- arch/arm/cpu/armv7/mx7/Makefile | 4 ++ arch/arm/cpu/armv7/mx7/psci-mx7.c | 79 +++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/psci.S | 54 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/soc.c | 9 +++++ 4 files changed, 146 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/psci-mx7.c create mode 100644 arch/arm/cpu/armv7/mx7/psci.S
diff --git a/arch/arm/cpu/armv7/mx7/Makefile b/arch/arm/cpu/armv7/mx7/Makefile index e6ecef0..f25461c 100644 --- a/arch/arm/cpu/armv7/mx7/Makefile +++ b/arch/arm/cpu/armv7/mx7/Makefile @@ -6,3 +6,7 @@ #
obj-y := soc.o clock.o clock_slice.o + +ifdef CONFIG_ARMV7_PSCI +obj-y += psci.o psci-mx7.o +endif diff --git a/arch/arm/cpu/armv7/mx7/psci-mx7.c b/arch/arm/cpu/armv7/mx7/psci-mx7.c new file mode 100644 index 0000000..6659332 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci-mx7.c @@ -0,0 +1,79 @@ +#include <common.h> +#include <asm/psci.h> +#include <asm/arch/imx-regs.h> + +#define __secure __attribute__ ((section ("._secure.text"))) + +#define GPC_CPU_PGC_SW_PDN_REQ 0xfc +#define GPC_CPU_PGC_SW_PUP_REQ 0xf0 +#define GPC_PGC_C1 0x840 + +#define BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7 0x2 + +/* below is for i.MX7D */ +#define SRC_GPR1_MX7D 0x074 +#define SRC_A7RCR0 0x004 +#define SRC_A7RCR1 0x008 + +#define BP_SRC_A7RCR0_A7_CORE_RESET0 0 +#define BP_SRC_A7RCR1_A7_CORE1_ENABLE 1 + +static inline void psci_writel(u32 value, u32 reg) +{ + *(volatile u32 *)reg = value; +} + +static inline int psci_readl(u32 reg) +{ + return *(volatile u32*)reg; +} + +static inline void imx_gpcv2_set_m_core_pgc(bool enable, u32 offset) +{ + psci_writel(enable, GPC_IPS_BASE_ADDR + offset); +} + +__secure void imx_gpcv2_set_core1_power(bool pdn) +{ + u32 reg = pdn ? GPC_CPU_PGC_SW_PUP_REQ : GPC_CPU_PGC_SW_PDN_REQ; + u32 val; + + imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C1); + + val = psci_readl(GPC_IPS_BASE_ADDR + reg); + val |= BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7; + psci_writel(val, GPC_IPS_BASE_ADDR + reg); + + while ((psci_readl(GPC_IPS_BASE_ADDR + reg) & BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7) != 0) + ; + + imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C1); +} + +__secure void imx_enable_cpu_ca7(int cpu, bool enable) +{ + u32 mask, val; + + mask = 1 << (BP_SRC_A7RCR1_A7_CORE1_ENABLE + cpu - 1); + val = psci_readl(SRC_BASE_ADDR + SRC_A7RCR1); + val = enable ? val | mask : val & ~mask; + psci_writel(val, SRC_BASE_ADDR + SRC_A7RCR1); +} + + +__secure int imx_cpu_on(int fn, int cpu, int pc) +{ + psci_writel(pc, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D); + imx_gpcv2_set_core1_power(true); + imx_enable_cpu_ca7(cpu, true); + return 0; +} + +__secure int imx_cpu_off(int cpu) +{ + imx_enable_cpu_ca7(cpu, false); + imx_gpcv2_set_core1_power(false); + psci_writel(0, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D + 4); + return 0; +} + diff --git a/arch/arm/cpu/armv7/mx7/psci.S b/arch/arm/cpu/armv7/mx7/psci.S new file mode 100644 index 0000000..4165cf5 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci.S @@ -0,0 +1,54 @@ +#include <config.h> +#include <linux/linkage.h> + +#include <asm/armv7.h> +#include <asm/arch-armv7/generictimer.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + + .arch_extension sec + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_arch_init +psci_arch_init: + mov r6, lr + + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov sp, r0 + + bx r6 + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_cpu_on +psci_cpu_on: + push {lr} + + mov r0, r1 + bl psci_get_cpu_stack_top + str r2, [r0] + dsb + + ldr r2, =psci_cpu_entry + bl imx_cpu_on + + pop {pc} + +.globl psci_cpu_off +psci_cpu_off: + + bl psci_cpu_off_common + bl psci_get_cpu_id + bl imx_cpu_off + +1: wfi + b 1b + + .globl psci_text_end +psci_text_end: + .popsection diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c index 8d50149..cfe2b1c 100644 --- a/arch/arm/cpu/armv7/mx7/soc.c +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -116,10 +116,19 @@ u32 __weak get_board_rev(void) } #endif
+/* enable all periherial can be access in nosec mode */ +static void init_csu(void) +{ + int i = 0; + for (i = 0; i < 64; i++) + writel(0x00FF00FF, 0x303e0000 + i * 4); +} + int arch_cpu_init(void) { init_aips();
+ init_csu(); /* Disable PDE bit of WMCR register */ imx_set_wdog_powerdown(false);
Enable psci and nosec linux boot. So second core can boot at community 4.13 kernel.
Signed-off-by: Frank Li Frank.Li@freescale.com --- include/configs/mx7_common.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index ea2be49..3231d26 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -92,4 +92,15 @@ #define CONFIG_CMD_FUSE #define CONFIG_MXC_OCOTP
+/* Default boot linux kernel in no secure mode. + * If want to boot kernel in secure mode, please define CONFIG_MX7_SEC + */ +#ifndef CONFIG_MX7_SEC +#define CONFIG_ARMV7_VIRT 1 +#define CONFIG_ARMV7_NONSEC 1 +#define CONFIG_ARMV7_PSCI 1 +#define CONFIG_ARMV7_PSCI_NR_CPUS 2 +#define CONFIG_ARMV7_SECURE_BASE 0x00900000 +#endif + #endif
- ldr r1, =__image_copy_start
- cmp r0, r1
- blo fixnext
Hi Tom, Albert,
This is a bug fix, please consider to apply this patch.
The secure code such as PSCI is not relocated, so there is no need to fix the code which generate relocate entry in rel.dyn section. We should only need take code from __image_copy_start to __image_copy_end into consideration.
Regards, Peng.
/* relative fix: increase location by offset */ add r0, r0, r4 ldr r1, [r0] -- 2.5.2
Hello Peng,
- cmp r0, r1
- blo fixnext
Hi Tom, Albert,
Sorry for not spotting your patch earlier.
Took me some time to understand the commit summary. Let me see if I'm getting this right by paraphrasing it:
If CONFIG_ARMV7_SECURE_BASE is defined and if there is a fixup to the location at __image_copy_start, then U-Boot will try to fix that location and since it is write-protected, it will result in a data abort.
If I got this right, then this raises the following questions:
1) if this location cannot be written into for relocation fixup, then how could it be written into for the copying which precedes relocation?
2) if there is a fixup to the location, it means that either this location will not work properly without a fix, or the compiler emitted an erroneous relocation record. In either case, just ignoring the fixup seems like papering over the issue.
Besides, this patch will prevent image base fixups on all targets, even those for which CONFIG_ARMV7_SECURE_BASE is not defined.
So, for now, I would NAK it.
Now, assuming the answers to the two questions above do make a valid point that the fix above should indeed be implemented, then:
If some part of an image needs copying but not relocating, then the right solution is not to hard-code some arbitrary location as 'not relocatable' in the relocation routine; the right solution is to put in place a generic mechanism to allow the linker script to define which part of the image is relocatable. This can be done as follows:
- in the linker script, border the non-relocatable part of the image with two symbols, say 'relocatable_image_start' and '..._end', and ensure that text (code) which should *not* be relocated is mapped either before '..._start' or '..._end'. Not-to-be-relocated code would be recognized by its text section name, e.g. '.nonreloc.text*'.
- in the relocation routine, only fix up those locations which lie between the 'relocatable_image_start' and '..._end' symbols.
- in the relevant makefile(s), make the non-relocatable object files use a test section name of the for defined in the first step (e.g. '.nonreloc.text*').
Again, this is suggested *only* if it is shown that the data abort cannot be avoided some other way.
Regards, Peng.
Amicalement,
Hi Albert, On Mon, Oct 19, 2015 at 08:48:56AM +0200, Albert ARIBAUD wrote:
Hello Peng,
- cmp r0, r1
- blo fixnext
Hi Tom, Albert,
Not from me -:)
The commit msg needs to be refined.
- if this location cannot be written into for relocation fixup, then
- if there is a fixup to the location, it means that either this
From my understanding, U-Boot will be relocated to high address of the DRAM space,
exactly code from __image_copy_start to __image_copy_end.
Following is part of the dump of .rel.dyn section of u-boot elf. SECURE BASE is 0x180000, uboot entry is 0x87800000.
Relocation section '.rel.dyn' at offset 0x577d4 contains 4032 entries: Offset Info Type Sym.Value Sym. Name 0018410c 00000017 R_ARM_RELATIVE 00184154 00000017 R_ARM_RELATIVE 0018415c 00000017 R_ARM_RELATIVE 00184164 00000017 R_ARM_RELATIVE 0018416c 00000017 R_ARM_RELATIVE 00184304 00000017 R_ARM_RELATIVE 00184368 00000017 R_ARM_RELATIVE 87800020 00000017 R_ARM_RELATIVE 87800024 00000017 R_ARM_RELATIVE 87800028 00000017 R_ARM_RELATIVE 8780002c 00000017 R_ARM_RELATIVE
We can see that there are several relocate entries for secure code which is not copied to high address of DRAM.
However SECURE code will not be copied to high address and should not be copied. The code locates from __image_copy_start to __image_copy_end are copied to high address, after copied, we need to fix variable and function reference, means we need to fix this according to the relocation entry. The relocation entry for SECURE code is not needed and should not to be fixed, alought they are in the rel.dyn section.
If some part of an image needs copying but not relocating,then the
part of an image not needs copying and not needs relocating.
We have another fix is to add the following linker in u-boot.lds for arm + .rel.secure : + { + *(.rel._secure*) + }
Then relocation entry for secure code will not be touched.
But from my point, when doing relocation fix like the following c code:
if ((entry < __image_copy_end) && (entry > __image_copy_start)) { /* fixup according relocation entry */ }
Regards, Peng.
Regards, Peng.
Amicalement,
Albert.
Hello Peng,
Hello Peng,
- cmp r0, r1
- blo fixnext
Hi Tom, Albert,
Not from me -:)
From my understanding, U-Boot will be relocated to high address of the DRAM space, exactly code from __image_copy_start to __image_copy_end.
Correct [minus the pedantic nitpick that __image_copy_start is included in the copy while __image_copy_end is excluded from it].
Thanks, this makes the situation much clearer -- though not entirely.
Relocation is done by:
a) compiling and linking the image as relocatable code;
a) linking the image for loading and execution at the link-time base address (here 0x87800000); the image won't work at any other address without relocation;
b) copying the code from wherever it was loaded (which may or may not be the link-time base address) to its run-time base address (as high in DDR as possible); this makes the code unfit for execution until it is relocated [pedantry: ... unless the run-time base address happens to be the link-time base address] ;
c) fixing the image based on the relocation records, the link-time base address, and the run-time base address; this makes the code fit for execution again.
So obviously, phase c should only operate on code which was linked between __image_copy_start [included] and __image_copy_end [excluded].
This could be an argument for checking relocation targets against those limits... But then, only code that *requires* relocation should have any relocation record -- IOW, there is no reason for the PSCI code to have such records if it is not going to be relocated like the rest of the image.
This, in turn, leads to new questions:
1. How is this PSCI code put in place? Is it bundled with the image, with a specificy copy routine which puts it in place then locks the memory range against writing? Or is it loaded in place by some other agent than U-Boot, and how does this agent know what to put where?
2. Does this code and the relocatable image refer to symbols of one another, or do they interact through an IPC independent of their respective location (in which case, one wonders why they are built into a single ELF file)?
More generally... which target do you see this problem on? Reproducing the build myself would save both you and me some time, I guess. :)
This seems to imply the PSCI code is not even put in place by U-Boot. So how does it end up in place?
- .rel.secure :
*(.rel._secure*)
Do you need these relocation records? If not, then just append the '*(.rel._secure*) input section spec (with a suitable comment) to the already existing DISCARD output section. By the way, doesn't this linker script change alone fix the data abort?
Still, if there *are* relocation records emitted, that's because the toolchain considered them necessary -- IOW, it was (wrongly) told the PSCI code must be relocatable [or the code really is relocatable and we just haven't not hit a bug about this yet].
So the real root cause fix would be to add suitable compiler and linker flags to the PSCI object files so that they are generated as really non- relocatable.
(still, I am wondering how this code ends up in place without U-Boot at least copying it from the loaded image into its target location; I'll certainly get a better understanding of it once I know which target we're talking about.)
Testing every single relocation record target against __image_copy_start and __image_copy_end would be rather costly in the tight loop of the relocation routine, which should run as fast as possible.
There is at least one fix to your problem which removes the out-of- bounds relocation records, and quite probably one better fix which prevents generating them in the first place.
Therefore, instead of the currently proposed patch which increases the size (very slightly) and boot time (statistically in O(n) proportion) of the image, I prefer one of the two alternative solutions which decrease the image size (by removing useless relocation records) and leave the boot time unchanged (since the fix is at build time only).
Regards, Peng.
Amicalement,
Hi Albert, On Mon, Oct 19, 2015 at 10:23:40AM +0200, Albert ARIBAUD wrote:
Hello Peng,
Hello Peng,
- cmp r0, r1
- blo fixnext
Hi Tom, Albert,
Not from me -:)
- How is this PSCI code put in place? Is it bundled with the image,
Yeah.
In arch/arm/cpu/armv7/virt-v7.c, relocate_secure_section() does this job.
CONFIG_ARMV7_SECURE_BASE is the location that secure code will be copied to. To ARMV7, PSCI code is bundled with the uboot image.
- Does this code and the relocatable image refer to symbols of one
another,
Yeah. There is asm function reference. You can see arch/arm/cpu/armv7/psci.S
This comes a question, why PSCI framework intergated into U-Boot? I have no idea.
Build target: mx7dsabresd
Needs to apply the three patches: https://patchwork.ozlabs.org/patch/527040/ https://patchwork.ozlabs.org/patch/527038/ https://patchwork.ozlabs.org/patch/527039/
There is a small difference from my previous log, since my previous log use 0x180000 as the secure address, but the patches use 0x900000 as the secure address. But sure there will be relocation entry there.
- .rel.secure :
*(.rel._secure*)
Yeah. Since the relocation entry for secure section will be stored in rel.secure section. And this section will not be touched in relocate.S
The PSCI code is bundled with the u-boot image. But it's running address is not same with u-boot. In my example, u-boot is compiled with starting address 0x87800000, but to PSCI, it's running address is 0x180000. relocate_secure_section is just copy the psci code from uboot to 0x180000.
compliation address is same with running address, to PSCI part.
Agree.
Regards, Peng.
Regards, Peng.
Amicalement,
Albert.
Hello Peng,
(cutting a bit through the previous mails quoting)
Yeah.
Hmm, the 'relocate' part of the function name is a somewhat non-optimal choice, since the routine just copies data without modifying it.
Looking at relocate_secure_section(), I see that it it is called long after the U-Boot code was relocated -- actually, it is called during bootm.
This means that for any one of the other boards around that seem to use PSCI, either "their" PSCI code does not have any relocations (which I doubt), or it has but they don't cause any data abort when done by the relocate_code() routine.
So what's the difference between those and your board? My bet is that their CONFIG_ARMV7_SECURE_BASE is not write-protected at the time the relocate_code() routine executes (whereas on your board it is), and will be unlocked in some way by the time relocate_secure_section() executes.
I'm not saying that the correct solution would be to enable write access to CONFIG_ARMV7_SECURE_BASE before running relocate_code(), because doing that would be obviously wrong: relocate_code() would try to fix code which is not there yet.
I'm just saying that's what actually happens, and if I am right, then it confirms that the correct fix is to not let relocations to the secure stay in the U-Boot ELF, or better yet, to not let them happen to boot [pun half-intended].
another,
Looking at this file, I suspect that actually, PSCI is called through a software interrupt / exception vector, not through a function name, and the only symbolic relationship is via __secure_start and __secure_end -- and those must (and will) be correctly relocated along with the U-Boot image.
There could have been alternative designs, indeed. Here is the design now, so let's handle it.
Thanks. I'll try and play with compiler / linker options, but from my own experience, this can be tricky. Meanwhile, I suggest you for for the not-too-quick-and-not-too-dirty linker script solution.
Ok, so that's our first clean, linker-script-based, solution confirmed.
(I understand that. My question was not "why is PSCI built for its run-time address?" but "Since PSCI is built for its run-time address, and since there is little dependency on how come it is built as relocatable?")
Agree.
OK. So, for now, I suggest that you:
- resubmit v2 of this series with patch 1/3 reworked into a linker script change rather than a relocate routine change (and collect the secure relocation records input sections into the DISCARD output section rather than into a purposeless non-discarded section);
- make sure that you CC: the maintainers for the other boards which use PSCI and explicitly ask them to test the change on their boards and give their "Tested-by". It seems like the list of candidates for testing includes jetson-tk1, ls1021aqds, ls1021atwr and all sun[678]i boards, but I am by no means a PSCI specialist, so anyone feel free to correct me about this list.
Regards, Peng.
Amicalement,
Hi Albert, On Mon, Oct 19, 2015 at 01:48:25PM +0200, Albert ARIBAUD wrote:
Hello Peng,
Yeah.
oh. You remind me, thanks. There maybe something wrong with my previous analysis.
I am not the one who finds the issue, just my understanding. The data abort may be triggered by line 104 or line 106. 96 fixloop: 97 ldmia r2!, {r0-r1} /* (r0,r1) <- (SRC location,fixup) */ 98 and r1, r1, #0xff 99 cmp r1, #23 /* relative fixup? */ 100 bne fixnext 101 102 /* relative fix: increase location by offset */ 103 add r0, r0, r4 104 ldr r1, [r0] 105 add r1, r1, r4 106 str r1, [r0]
At line 104 or 106, the value of r0 may be an address that can not be accessed which trigger data abort.
Frank, am I right?
I'll set up one board to test this.
There maybe something wrong from me. See above.
Yeah. This is true, relocate_code may fix code which is not there.
They do not happen to boot. My bad. See above.
another,
uboot will not effect after switch to kernel, and its image will be overriden by kernel. But PSCI will always effect during kernel lifecyle. Maybe built PSCI part non-relocatable is an alternative choice.
Agree.
Regards, Peng.
Amicalement,
Albert.
-----Original Message----- From: Peng Fan [mailto:b51431@freescale.com] Sent: Monday, October 19, 2015 7:47 AM To: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Li Frank-B20596 Frank.Li@freescale.com; lznuaa@gmail.com; u- boot@lists.denx.de; sbabic@denx.de; Estevam Fabio-R49496 Fabio.Estevam@freescale.com; otavio@ossystems.com.br; trini@konsulko.com; hdegoede@redhat.com; Fan Peng-B51431 Peng.Fan@freescale.com Subject: Re: [U-Boot] [PATCH 1/3] ARM: relocate: fix hang when CONFIG_ARMV7_SECURE_BASE
Hello Peng,
Yeah.
Frank, am I right?
Yes. Secure_text + relocate_offset will be invalidate address. So generate data abort.
Best regards Frank Li
Their secure_text + relocate_offset is possible in unused validate memory region. If not data abort, this don't hurt anything.
another,
no idea.
0x180000.
build time only).
Agree.
Regards, Peng.
Amicalement,
Albert.
Albert ARIBAUD
Frank Li
Li Frank
Peng Fan
