[U-Boot] [PATCH] serial: Move carriage return before line feed for some serial drivers
In general, a carriage return needs to execute before a line feed. The patch is to change some serial drivers based on this rule, such as serial_mxc.c, serial_pxa.c, serial_s3c24x0.c and usbtty.c.
Signed-off-by: Alison Wang alison.wang@nxp.com --- drivers/serial/serial_mxc.c | 8 ++++---- drivers/serial/serial_pxa.c | 8 ++++---- drivers/serial/serial_s3c24x0.c | 8 ++++---- drivers/serial/usbtty.c | 7 ++++--- 4 files changed, 16 insertions(+), 15 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 51485c0..1563bb3 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -164,15 +164,15 @@ static int mxc_serial_getc(void)
static void mxc_serial_putc(const char c) { + /* If \n, also do \r */ + if (c == '\n') + serial_putc('\r'); + __REG(UART_PHYS + UTXD) = c;
/* wait for transmitter to be ready */ while (!(__REG(UART_PHYS + UTS) & UTS_TXEMPTY)) WATCHDOG_RESET(); - - /* If \n, also do \r */ - if (c == '\n') - serial_putc ('\r'); }
/* diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index 8fbcc10..1eb19ec 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -156,6 +156,10 @@ void pxa_putc_dev(unsigned int uart_index, const char c) { struct pxa_uart_regs *uart_regs;
+ /* If \n, also do \r */ + if (c == '\n') + pxa_putc_dev(uart_index, '\r'); + uart_regs = pxa_uart_index_to_regs(uart_index); if (!uart_regs) hang(); @@ -163,10 +167,6 @@ void pxa_putc_dev(unsigned int uart_index, const char c) while (!(readl(&uart_regs->lsr) & LSR_TEMT)) WATCHDOG_RESET(); writel(c, &uart_regs->thr); - - /* If \n, also do \r */ - if (c == '\n') - pxa_putc_dev (uart_index,'\r'); }
/* diff --git a/drivers/serial/serial_s3c24x0.c b/drivers/serial/serial_s3c24x0.c index d4e7df2..0f0878a 100644 --- a/drivers/serial/serial_s3c24x0.c +++ b/drivers/serial/serial_s3c24x0.c @@ -135,14 +135,14 @@ static void _serial_putc(const char c, const int dev_index) { struct s3c24x0_uart *uart = s3c24x0_get_base_uart(dev_index);
+ /* If \n, also do \r */ + if (c == '\n') + serial_putc('\r'); + while (!(readl(&uart->utrstat) & 0x2)) /* wait for room in the tx FIFO */ ;
writeb(c, &uart->utxh); - - /* If \n, also do \r */ - if (c == '\n') - serial_putc('\r'); }
static inline void serial_putc_dev(unsigned int dev_index, const char c) diff --git a/drivers/serial/usbtty.c b/drivers/serial/usbtty.c index 75f0ec3..2e19813 100644 --- a/drivers/serial/usbtty.c +++ b/drivers/serial/usbtty.c @@ -434,11 +434,12 @@ void usbtty_putc(struct stdio_dev *dev, const char c) if (!usbtty_configured ()) return;
- buf_push (&usbtty_output, &c, 1); /* If \n, also do \r */ if (c == '\n') buf_push (&usbtty_output, "\r", 1);
+ buf_push(&usbtty_output, &c, 1); + /* Poll at end to handle new data... */ if ((usbtty_output.size + 2) >= usbtty_output.totalsize) { usbtty_poll (); @@ -498,8 +499,8 @@ void usbtty_puts(struct stdio_dev *dev, const char *str) n = next_nl_pos (str);
if (str[n] == '\n') { - __usbtty_puts (str, n + 1); - __usbtty_puts ("\r", 1); + __usbtty_puts("\r", 1); + __usbtty_puts(str, n + 1); str += (n + 1); len -= (n + 1); } else {
I guess dm serial drivers will be in another patch?
Regards, Bin
Hi, Bin,
[Alison Wang] Yes, two patches.
Best Regards, Alison Wang
Hi Alison,
On Thu, Feb 25, 2016 at 11:02 AM, Huan Wang alison.wang@nxp.com wrote:
Hi, Bin,
I would suggest in the future you send all these 3 patches (serial-ulass, legacy serial, dm serial) in a series. This helps people to track.
Regards, Bin
Hi, Bin,
Hi, Bin,
[Alison Wang] dm serial? Sorry, I may misunderstand you. I only have 2 patches, one is for serial-ulass(that's my meaning about dm serial), the other is for legacy serial. I didn't find such error in other dm serial drivers.
Hi Alison,
On Thu, Feb 25, 2016 at 12:58 PM, Huan Wang alison.wang@nxp.com wrote:
Hi, Bin,
Hi, Bin,
serial_lpuart.c and serial_arc.c has this handling, and they should be removed.
Regards, Bin
Hi, Bin,
Hi, Bin,
[Alison Wang] Sorry to reply late. I will send a series. Thanks for your advice.
This is a request for more information.
You write "In general, a carriage return needs to execute before a line feed. The patch is to change some serial drivers based on this rule"
Please provide a reference. I'd probably benefit from deeper knowledge of this subject. I had not heard this rule before.
Thank you, Jim
if (c == '\n')
serial_putc('\r');
if (c == '\n')
serial_putc ('\r');
- if (c == '\n')
- uart_regs = pxa_uart_index_to_regs(uart_index); if (!uart_regs) hang();
if (c == '\n')
if (c == '\n')
serial_putc('\r');
if (c == '\n')
serial_putc('\r');
- buf_push(&usbtty_output, &c, 1);
- /* Poll at end to handle new data... */ if ((usbtty_output.size + 2) >= usbtty_output.totalsize) { usbtty_poll ();
} else {__usbtty_puts(str, n + 1); str += (n + 1); len -= (n + 1);
Hi, Jim,
-----Original Message----- From: James Chargin [mailto:jimccrown@gmail.com] Sent: Thursday, February 25, 2016 10:19 PM To: u-boot@lists.denx.de; b18965@freescale.com Subject: Re: [U-Boot] [PATCH] serial: Move carriage return before line feed for some serial drivers
[Alison Wang] I think you could refer to https://en.wikipedia.org/wiki/Newline#History .
Why isn't this CR-LF stuff handled in common code instead ? It'd be much better than having billion copies of the exact same logic (some of them more buggy than the others) in drivers.
Hi Marek,
The CR-LF stuff is already handled in the common code, but only for the DM version, see serial-uclass.c. This patch is to fix non-DM version serial drivers. When those drivers get converted to DM, these handling should be removed.
Regards, Bin
Hi Marek,
With driver model it is.
On 02/26/2016 02:56 AM, Simon Glass wrote:
Hi Marek,
On 25 February 2016 at 10:55, Marek Vasut <marex@denx.de mailto:marex@denx.de> wrote:
Signed-off-by: Alison Wang <alison.wang@nxp.com
OK, thanks.
participants (6)
Alison Wang
Bin Meng
Huan Wang
James Chargin
