[U-Boot] [PATCH] rockchip: Disable SPL_MMC_SUPPORT if ROCKCHIP_SPL_BACK_TO_BROM is enabled.
CONFIG_SPL_MMC_SUPPORT is used pretty much for every board except jerry, so we can refactor the define into rk3288_common.h. Then only define it if we are using using the Bootrom to load the non SPL U-Boot.
With this change the SPL binary shrinks from 32k to 23k when ROCKCHIP_SPL_BACK_TO_BROM is enabled. This has been tested on the rock2 board. It should work with any rk3288 though since the bootrom is loading the SPL already it should load the main U-Boot as well.
Rock2 has been tested with ROCKCHIP_SPL_BACK_TO_BROM So enabled for rock2.
Signed-off-by: Sandy Patterson apatterson@sightlogix.com ---
configs/rock2_defconfig | 1 + include/configs/chromebook_jerry.h | 1 + include/configs/evb_rk3288.h | 2 -- include/configs/fennec_rk3288.h | 2 -- include/configs/firefly-rk3288.h | 2 -- include/configs/miniarm_rk3288.h | 2 -- include/configs/popmetal_rk3288.h | 2 -- include/configs/rk3288_common.h | 4 ++++ include/configs/rock2.h | 2 -- 9 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 3b6d7d9..8f730e5 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -67,3 +67,4 @@ CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y diff --git a/include/configs/chromebook_jerry.h b/include/configs/chromebook_jerry.h index d1f5b46..9800ffb 100644 --- a/include/configs/chromebook_jerry.h +++ b/include/configs/chromebook_jerry.h @@ -22,6 +22,7 @@
#define CONFIG_CMD_SF_TEST
+#undef CONFIG_SPL_MMC_SUPPORT #undef CONFIG_SPL_GPIO_SUPPORT
#define CONFIG_KEYBOARD diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 342557f..390c243 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
-#define CONFIG_SPL_MMC_SUPPORT - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 342557f..390c243 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
-#define CONFIG_SPL_MMC_SUPPORT - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index a29f557..ee924c3 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -14,8 +14,6 @@
-#define CONFIG_SPL_MMC_SUPPORT - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* SPL @ 32k for ~36k diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_rk3288.h index 342557f..390c243 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
-#define CONFIG_SPL_MMC_SUPPORT - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 342557f..390c243 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
-#define CONFIG_SPL_MMC_SUPPORT - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index d3d4c68..bc0de3d 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -33,6 +33,10 @@ #define CONFIG_SYS_NS16550_MEM32 #define CONFIG_SPL_BOARD_INIT
+#ifndef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#define CONFIG_SPL_MMC_SUPPORT +#endif + #ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM /* Bootrom will load u-boot binary to 0x0 once return from SPL */ #define CONFIG_SYS_TEXT_BASE 0x00000000 diff --git a/include/configs/rock2.h b/include/configs/rock2.h index a29f557..ee924c3 100644 --- a/include/configs/rock2.h +++ b/include/configs/rock2.h @@ -14,8 +14,6 @@
On Fri, Aug 12, 2016 at 8:59 PM, Sandy Patterson apatterson@sightlogix.com wrote:
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_ rk3288.h index 342557f..390c243 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly- rk3288.h index a29f557..ee924c3 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -14,8 +14,6 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* SPL @ 32k for ~36k diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_ rk3288.h index 342557f..390c243 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_ rk3288.h index 342557f..390c243 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -10,8 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SPL @ 32k for ~36k diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_ common.h index d3d4c68..bc0de3d 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -33,6 +33,10 @@ #define CONFIG_SYS_NS16550_MEM32 #define CONFIG_SPL_BOARD_INIT
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* SPL @ 32k for ~36k -- 1.9.1
Hi Simon,
Just wondering if this commit got lost, or maybe there is some advice you could give me on how to make this more helpful.
Sandy
On Wed, Aug 24, 2016 at 9:27 AM, Sandy Patterson apatterson@sightlogix.com wrote:
On Fri, Aug 12, 2016 at 8:59 PM, Sandy Patterson < apatterson@sightlogix.com> wrote:
Hi Simon,
Sandy
Ah, I see why you didn't grab this. I'll resubmit after I've had a chance to digest the SPL Kconfig changeset.
Hi Sandy,
Hi Simon,
Sandy
No it's not that. You patch comes before that series.
But I would like to see review/ tags from others on Rockchip patches - just so that I know that people are on-board with the change.
Will add my tag to encourage people!
Hi Sandy,
On 25 August 2016 at 06:05, Simon Glass sjg@chromium.org wrote:
Hi Sandy,
Hi Simon,
Sandy
But on closer inspection, yes this will be a pain to update after the SPL series. So please can you take a look and resend? It looks like you should do something like this in arch/arm/mach-rockchip/Kconfig or similar:
config SPL_MMC_SUPPORT default y if !ROCKCHIP_SPL_BACK_TO_BROM
Sandy Patterson
