[U-Boot] [PATCH] arm: socfpga: Enable ubi and ubifs support
When QSPI and NAND is enabled, the ubi and ubifs support will be enabled too.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de --- include/configs/socfpga_common.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index f7c0eb5..7c50100 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -300,6 +300,15 @@ unsigned int cm_get_qspi_controller_clk_hz(void); "-@1536k(UBI)\0" #endif
+/* UBI and UBIFS support */ +#if defined(CONFIG_CMD_SF) || defined(CONFIG_CMD_NAND) +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO +#undef CONFIG_SPI_FLASH_USE_4K_SECTORS +#endif + /* * SPL *
This CONFIG_SPI_FLASH_USE_4K_SECTORS is Kconfig stuff, so it should go into configs/socfpga_* , otherwise this is fine.
- SPL
Best regards, Marek Vasut
oh, not aware of that. Ok let me update this.
Thanks Chin Liang
- SPL
Chin Liang See
