[PATCH v2 00/10] AM642-EVM: Add USB support
The following series of patches add support for the following - Kconfig symbol for giving the load address for ATF - USB Mass storage boot mode in AM642-EVM - DFU boot mode in AM642-EVM - Host and peripheral modes for AM642-EVM in U-Boot - Set the USB PHY core voltage to 0.85V
changes since v1, - Corrected the default load address of ATF to 0x70000000
Aswath Govindraju (10): tools: k3_fit_atf: Add support for providing ATF load address using a Kconfig symbol arm: mach-k3: am642_init: Add support for USB boot mode arm: mach-k3: am642_init: Do USB fixups to facilitate host and device boot modes board: ti: am64x: Set the core voltage of USB PHY to 0.85V arm: dts: k3-am64-main: Add USB DT nodes arm: dts: k3-am642-*-evm: Add USB support arm: dts: k3-am642-evm-u-boot: Add U-Boot tags and fix the dr_mode to peripheral for USB subsystem configs: am64x_evm_*_defconfig: Move the SPL Load address to 0x70000000, move the ATF to a latter location and rearrange EEPROM and BSS data arm: dts: k3-am64-main: Update the location of ATF in SRAM configs: am64: Enable configs to support USB host and device modes
arch/arm/dts/k3-am64-main.dtsi | 32 ++++++++++++- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 13 ++++++ arch/arm/dts/k3-am642-evm.dts | 18 ++++++++ arch/arm/dts/k3-am642-r5-evm.dts | 18 ++++++++ arch/arm/mach-k3/Kconfig | 7 +++ arch/arm/mach-k3/am642_init.c | 46 ++++++++++++++++++- arch/arm/mach-k3/config.mk | 1 + arch/arm/mach-k3/include/mach/am64_hardware.h | 11 +++-- arch/arm/mach-k3/include/mach/am64_spl.h | 6 ++- board/ti/am64x/evm.c | 14 ++++++ configs/am64x_evm_a53_defconfig | 40 ++++++++++++++++ configs/am64x_evm_r5_defconfig | 38 +++++++++++++-- include/configs/am64x_evm.h | 15 +++++- tools/k3_fit_atf.sh | 9 ++-- 14 files changed, 251 insertions(+), 17 deletions(-)
Add support for providing ATF load address with a Kconfig symbol.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/mach-k3/Kconfig | 7 +++++++ arch/arm/mach-k3/config.mk | 1 + tools/k3_fit_atf.sh | 9 ++++++--- 3 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bfbce44bfa59..21b2fc2230d4 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -147,6 +147,13 @@ config SYS_K3_SPL_ATF Enabling this will try to start Cortex-A (typically with ATF) after SPL from R5.
+config K3_ATF_LOAD_ADDR + hex "Load address of ATF image" + default 0x70000000 + help + The load address for the ATF image. This value defaults to 0x70000000 + if not provided in the board defconfig file. + source "board/ti/am65x/Kconfig" source "board/ti/am64x/Kconfig" source "board/ti/j721e/Kconfig" diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index 41fee2b5a172..674489068204 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -67,6 +67,7 @@ endif quiet_cmd_k3_mkits = MKITS $@ cmd_k3_mkits = \ $(srctree)/tools/k3_fit_atf.sh \ + $(CONFIG_K3_ATF_LOAD_ADDR) \ $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(LIST_OF_DTB))) > $@
$(SPL_ITS): FORCE diff --git a/tools/k3_fit_atf.sh b/tools/k3_fit_atf.sh index 4e9f69c08789..2c0287a63394 100755 --- a/tools/k3_fit_atf.sh +++ b/tools/k3_fit_atf.sh @@ -5,7 +5,7 @@ # ATF, OPTEE, SPL and multiple device trees (given on the command line). # Inspired from board/sunxi/mksunxi_fit_atf.sh # -# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] +# usage: $0 <atf_load_addr> <dt_name> [<dt_name> [<dt_name] ...]
[ -z "$ATF" ] && ATF="bl31.bin"
@@ -40,8 +40,8 @@ cat << __HEADER_EOF arch = "arm64"; compression = "none"; os = "arm-trusted-firmware"; - load = <0x70000000>; - entry = <0x70000000>; + load = <$1>; + entry = <$1>; }; tee { description = "OPTEE"; @@ -65,6 +65,9 @@ cat << __HEADER_EOF }; __HEADER_EOF
+# shift through ATF load address in the command line arguments +shift + for dtname in $* do cat << __FDT_IMAGE_EOF
Add support for identifying USB host and device boot modes
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/mach-k3/am642_init.c | 13 +++++++++++-- arch/arm/mach-k3/include/mach/am64_hardware.h | 5 +++++ arch/arm/mach-k3/include/mach/am64_spl.h | 6 ++++-- 3 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/am642_init.c b/arch/arm/mach-k3/am642_init.c index a433702b4e30..1a2bc4bb9048 100644 --- a/arch/arm/mach-k3/am642_init.c +++ b/arch/arm/mach-k3/am642_init.c @@ -192,8 +192,11 @@ static u32 __get_backup_bootmedia(u32 main_devstat) case BACKUP_BOOT_DEVICE_UART: return BOOT_DEVICE_UART;
- case BACKUP_BOOT_DEVICE_USB: - return BOOT_DEVICE_USB; + case BACKUP_BOOT_DEVICE_DFU: + if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; +
case BACKUP_BOOT_DEVICE_ETHERNET: return BOOT_DEVICE_ETHERNET; @@ -245,6 +248,12 @@ static u32 __get_primary_bootmedia(u32 main_devstat) return BOOT_DEVICE_MMC2; return BOOT_DEVICE_MMC1;
+ case BOOT_DEVICE_DFU: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + case BOOT_DEVICE_NOBOOT: return BOOT_DEVICE_RAM; } diff --git a/arch/arm/mach-k3/include/mach/am64_hardware.h b/arch/arm/mach-k3/include/mach/am64_hardware.h index c368aa7e6bf1..4ee41ad762ba 100644 --- a/arch/arm/mach-k3/include/mach/am64_hardware.h +++ b/arch/arm/mach-k3/include/mach/am64_hardware.h @@ -30,6 +30,11 @@ #define MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT 2 #define MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK 0x04
+#define MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT 1 +#define MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK 0x02 + +#define MAIN_DEVSTAT_BACKUP_USB_MODE_MASK 0x01 + /* * The CTRL_MMR and PADCFG_MMR memory space is divided into several * equally-spaced partitions, so defining the partition size allows us to diff --git a/arch/arm/mach-k3/include/mach/am64_spl.h b/arch/arm/mach-k3/include/mach/am64_spl.h index 36826cfc4ed0..607b09c2e5dc 100644 --- a/arch/arm/mach-k3/include/mach/am64_spl.h +++ b/arch/arm/mach-k3/include/mach/am64_spl.h @@ -19,7 +19,8 @@ #define BOOT_DEVICE_MMC 0x08 #define BOOT_DEVICE_EMMC 0x09
-#define BOOT_DEVICE_USB 0x0A +#define BOOT_DEVICE_USB 0x2A +#define BOOT_DEVICE_DFU 0x0A #define BOOT_DEVICE_GPMC_NOR 0x0C #define BOOT_DEVICE_PCIE 0x0D #define BOOT_DEVICE_XSPI 0x0E @@ -32,12 +33,13 @@ #define BOOT_DEVICE_MMC2_2 0x1F
/* Backup BootMode devices */ -#define BACKUP_BOOT_DEVICE_USB 0x01 +#define BACKUP_BOOT_DEVICE_DFU 0x01 #define BACKUP_BOOT_DEVICE_UART 0x03 #define BACKUP_BOOT_DEVICE_ETHERNET 0x04 #define BACKUP_BOOT_DEVICE_MMC 0x05 #define BACKUP_BOOT_DEVICE_SPI 0x06 #define BACKUP_BOOT_DEVICE_I2C 0x07 +#define BACKUP_BOOT_DEVICE_USB 0x09
#define K3_PRIMARY_BOOTMODE 0x0
U-Boot either supports USB host or device mode for a node at a time in the device tree nodes. To support both host and dfu bootmodes, dr_mode is set to "peripheral" by default and then fixed based on the mode selected by the boot mode config dip switches on the board.
This needs to happen before the cdns3 generic layer binds the usb device to a host or a device driver. Therefore, use fdtdec_setup_board() implementation to fixup the device tree property.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/mach-k3/am642_init.c | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/arm/mach-k3/am642_init.c b/arch/arm/mach-k3/am642_init.c index 1a2bc4bb9048..579dbacb7e48 100644 --- a/arch/arm/mach-k3/am642_init.c +++ b/arch/arm/mach-k3/am642_init.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <fdt_support.h> #include <spl.h> #include <asm/io.h> #include <asm/arch/hardware.h> @@ -106,6 +107,38 @@ void do_dt_magic(void) } #endif
+#if CONFIG_IS_ENABLED(USB_STORAGE) +static int fixup_usb_boot(const void *fdt_blob) +{ + int ret = 0; + + switch (spl_boot_device()) { + case BOOT_DEVICE_USB: + /* + * If the boot mode is host, fixup the dr_mode to host + * before cdns3 bind takes place + */ + ret = fdt_find_and_setprop((void *)fdt_blob, + "/bus@f4000/cdns-usb@f900000/usb@f400000", + "dr_mode", "host", 5, 0); + if (ret) + printf("%s: fdt_find_and_setprop() failed:%d\n", + __func__, ret); + fallthrough; + default: + break; + } + + return ret; +} + +int fdtdec_board_setup(const void *fdt_blob) +{ + /* Can use the pointer from the function parameters */ + return fixup_usb_boot(fdt_blob); +} +#endif + void board_init_f(ulong dummy) { #if defined(CONFIG_K3_LOAD_SYSFW)
Set the core voltage of USB PHY in AM64x to 0.85V in spl_board_init().
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- board/ti/am64x/evm.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/board/ti/am64x/evm.c b/board/ti/am64x/evm.c index 35cd9e027c04..cdbb9a87bc44 100644 --- a/board/ti/am64x/evm.c +++ b/board/ti/am64x/evm.c @@ -152,3 +152,17 @@ int board_late_init(void) return 0; } #endif + +#define CTRLMMR_USB0_PHY_CTRL 0x43004008 +#define CORE_VOLTAGE 0x80000000 + +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + u32 val; + /* Set USB PHY core voltage to 0.85V */ + val = readl(CTRLMMR_USB0_PHY_CTRL); + val &= ~(CORE_VOLTAGE); + writel(val, CTRLMMR_USB0_PHY_CTRL); +} +#endif
Add DT node for the single USB subsystem in main dtsi file.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/dts/k3-am64-main.dtsi | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/arch/arm/dts/k3-am64-main.dtsi b/arch/arm/dts/k3-am64-main.dtsi index a65011b396cc..5a58337c1ca7 100644 --- a/arch/arm/dts/k3-am64-main.dtsi +++ b/arch/arm/dts/k3-am64-main.dtsi @@ -499,6 +499,36 @@ clock-names = "gpio"; };
+ usbss0: cdns-usb@f900000{ + compatible = "ti,am64-usb", "ti,j721e-usb"; + reg = <0x00 0xf900000 0x00 0x100>; + power-domains = <&k3_pds 161 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 161 9>, <&k3_clks 161 1>; + clock-names = "ref", "lpm"; + assigned-clocks = <&k3_clks 161 9>; /* USB2_REFCLK */ + assigned-clock-parents = <&k3_clks 161 10>; /* HF0SC0 */ + #address-cells = <2>; + #size-cells = <2>; + ranges; + usb0: usb@f400000{ + compatible = "cdns,usb3"; + reg = <0x00 0xf400000 0x00 0x10000>, + <0x00 0xf410000 0x00 0x10000>, + <0x00 0xf420000 0x00 0x10000>; + reg-names = "otg", + "xhci", + "dev"; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ + <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */ + <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; /* otgirq */ + interrupt-names = "host", + "peripheral", + "otg"; + maximum-speed = "super-speed"; + dr_mode = "otg"; + }; + }; + main_gpio1: gpio@601000 { compatible = "ti,j721e-gpio", "ti,keystone-gpio"; reg = <0x00 0x00601000 0x00 0x100>;
AM64 EVM board has a micro USB 2.0 AB connector and the USB0_VBUS is connected with a resistor divider in between. USB0_DRVVBUS pin is muxed between USB0_DRVVBUS and GPIO1_79 signals.
Add the corresponding properties and set the pinmux mode for USB subsystem in the evm dts file.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/dts/k3-am642-evm.dts | 18 ++++++++++++++++++ arch/arm/dts/k3-am642-r5-evm.dts | 18 ++++++++++++++++++ 2 files changed, 36 insertions(+)
diff --git a/arch/arm/dts/k3-am642-evm.dts b/arch/arm/dts/k3-am642-evm.dts index dc3482bea433..3a505d22c635 100644 --- a/arch/arm/dts/k3-am642-evm.dts +++ b/arch/arm/dts/k3-am642-evm.dts @@ -201,6 +201,12 @@ AM64X_IOPAD(0x0144, PIN_OUTPUT, 4) /* (Y11) PRG1_PRU1_GPO15.RGMII2_TX_CTL */ >; }; + + main_usb0_pins_default: main-usb0-pins-default { + pinctrl-single,pins = < + AM64X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (E19) USB0_DRVVBUS */ + >; + }; };
&main_uart0 { @@ -337,3 +343,15 @@ ti,driver-strength-ohm = <50>; disable-wp; }; + +&usbss0 { + ti,vbus-divider; + ti,usb2-only; +}; + +&usb0 { + dr_mode = "otg"; + maximum-speed = "high-speed"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb0_pins_default>; +}; diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index 1fbf6d2c23a5..cc48fd4cb607 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -141,6 +141,12 @@ AM64X_IOPAD(0x0030, PIN_OUTPUT_PULLUP, 7) /* (L18) OSPI0_CSN1.GPIO0_12 */ >; }; + + main_usb0_pins_default: main-usb0-pins-default { + pinctrl-single,pins = < + AM64X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (E19) USB0_DRVVBUS */ + >; + }; };
&dmsc { @@ -201,4 +207,16 @@ /delete-property/ power-domains; };
+&usbss0 { + ti,vbus-divider; + ti,usb2-only; +}; + +&usb0 { + dr_mode = "otg"; + maximum-speed = "high-speed"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb0_pins_default>; +}; + #include "k3-am642-evm-u-boot.dtsi"
Add U-Boot tags and fix the dr_mode as peripheral in U-Boot to support DFU by default.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index 10dea7a1cc46..ed38b7269ee5 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -50,6 +50,19 @@ u-boot,dm-spl; };
+&usb0 { + dr_mode="peripheral"; + u-boot,dm-spl; +}; + +&usbss0 { + u-boot,dm-spl; +}; + +&main_usb0_pins_default { + u-boot,dm-spl; +}; + &dmss { u-boot,dm-spl; };
For USB DFU boot mode there is a limitation on the load address of boot images that they have to be less than 0x70001000. Therefore, move the SPL_TEXT_BASE address to 0x70000000.
Currently ATF is being loaded at 0x70000000, if the SPL is being loaded at 0x70000000 then ATF would overwrite SPL image when loaded. Therefore, move the location of ATF to a latter location in SRAM, past the SPL image. Also rearrange the EEPROM and BSS data on top of ATF.
Given below is the placement of various data sections in SRAM
┌──────────────────────────────────────┐0x70000000 │ │ │ │ │ │ │ SPL IMAGE (Max size 1.5 MB) │ │ │ │ │ │ │ ├──────────────────────────────────────┤0x7017FFFF │ │ │ SPL STACK │ │ │ ├──────────────────────────────────────┤0x70192727 │ GLOBAL DATA(216 B) │ ├──────────────────────────────────────┤0x701927FF │ │ │ INITIAL HEAP (32 KB) │ │ │ ├──────────────────────────────────────┤0x7019A7FF │ │ │ BSS (20 KB) │ ├──────────────────────────────────────┤0x7019F7FF │ EEPROM DATA (2 KB) │ ├──────────────────────────────────────┤0x7019FFFF │ │ │ │ │ ATF (123 KB) │ │ │ │ │ ├──────────────────────────────────────┤0x701BEBFB │ BOOT PARAMETER INDEX TABLE (5124 B)│ ├──────────────────────────────────────┤0x701BFFFF │ │ │SYSFW FIREWALLED DUE TO A BUG (128 KB)│ │ │ ├──────────────────────────────────────┤0x701DFFFF │ │ │ DMSC CODE AREA (128 KB) │ │ │ └──────────────────────────────────────┘0x701FFFFF
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/mach-k3/include/mach/am64_hardware.h | 6 ++---- configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 2 +- include/configs/am64x_evm.h | 3 ++- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-k3/include/mach/am64_hardware.h b/arch/arm/mach-k3/include/mach/am64_hardware.h index 4ee41ad762ba..96383437d5b1 100644 --- a/arch/arm/mach-k3/include/mach/am64_hardware.h +++ b/arch/arm/mach-k3/include/mach/am64_hardware.h @@ -7,8 +7,6 @@ #ifndef __ASM_ARCH_AM64_HARDWARE_H #define __ASM_ARCH_AM64_HARDWARE_H
-#include <config.h> - #define CTRL_MMR0_BASE 0x43000000 #define CTRLMMR_MAIN_DEVSTAT (CTRL_MMR0_BASE + 0x30)
@@ -54,7 +52,7 @@
#define ROM_ENTENDED_BOOT_DATA_INFO 0x701beb00
-/* Use Last 1K as Scratch pad */ -#define TI_SRAM_SCRATCH_BOARD_EEPROM_START 0x701bfc00 +/* Use Last 2K as Scratch pad */ +#define TI_SRAM_SCRATCH_BOARD_EEPROM_START 0x7019f800
#endif /* __ASM_ARCH_DRA8_HARDWARE_H */ diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 304f5b41a3ae..3b8b7474f845 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM642=y +CONFIG_K3_ATF_LOAD_ADDR=0x701a0000 CONFIG_TARGET_AM642_A53_EVM=y CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 2810fa1fc57d..de0c814222c0 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y -CONFIG_SPL_TEXT_BASE=0x70020000 +CONFIG_SPL_TEXT_BASE=0x70000000 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 7c30e50c5f1e..7c9bdc2d7d3a 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -12,6 +12,7 @@ #include <linux/sizes.h> #include <config_distro_bootcmd.h> #include <environment/ti/mmc.h> +#include <asm/arch/am64_hardware.h>
/* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000 @@ -43,7 +44,7 @@ * location filled in by the boot ROM that we want to read out without any * interference from the C context. */ -#define CONFIG_SPL_BSS_START_ADDR (CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX -\ +#define CONFIG_SPL_BSS_START_ADDR (TI_SRAM_SCRATCH_BOARD_EEPROM_START -\ CONFIG_SPL_BSS_MAX_SIZE) /* Set the stack right below the SPL BSS section */ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SPL_BSS_START_ADDR
For USB DFU boot mode there is a limitation on the load address of boot images that they have to be less than 0x70001000. So, the load address of SPL has been moved to 0x70000000 and ATF has been moved to a latter location, 0x701a0000.
Therefore, update its location accordingly in the device tree file.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/dts/k3-am64-main.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-am64-main.dtsi b/arch/arm/dts/k3-am64-main.dtsi index 5a58337c1ca7..fccf0d2fcfb0 100644 --- a/arch/arm/dts/k3-am64-main.dtsi +++ b/arch/arm/dts/k3-am64-main.dtsi @@ -14,7 +14,7 @@ ranges = <0x0 0x00 0x70000000 0x200000>;
atf-sram@0 { - reg = <0x0 0x1a000>; + reg = <0x1a0000 0x1a000>; }; };
Enable config options required to add support for USB Mass storage boot, USB DFU boot, host and device modes in U-Boot.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- configs/am64x_evm_a53_defconfig | 39 +++++++++++++++++++++++++++++++++ configs/am64x_evm_r5_defconfig | 36 ++++++++++++++++++++++++++++-- include/configs/am64x_evm.h | 12 +++++++++- 3 files changed, 84 insertions(+), 3 deletions(-)
diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 3b8b7474f845..a3aab807c6e7 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -23,6 +23,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k3-am642-evm" CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y @@ -30,12 +31,17 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA=y CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_STORAGE=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y @@ -103,3 +109,36 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y +CONFIG_CMD_USB=y +CONFIG_DFU=y +CONFIG_DFU_OVER_USB=y +# CONFIG_DFU_TFTP is not set +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +# CONFIG_DFU_VIRT is not set +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 +CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_HOST=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_CDNS3=y +CONFIG_USB_CDNS3_GADGET=y +CONFIG_SPL_USB_CDNS3_GADGET=y +CONFIG_USB_CDNS3_HOST=y +CONFIG_SPL_USB_CDNS3_HOST=y +CONFIG_USB_CDNS3_TI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6165 +CONFIG_USB_GADGET_VBUS_DRAW=2 +CONFIG_USB_GADGET_DUALSPEED=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_MASS_STORAGE=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index de0c814222c0..3e9b5650c60d 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="k3-am642-r5-evm" CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -31,19 +32,30 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_REMOTEPROC=y CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_STORAGE=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y @@ -52,8 +64,6 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-am642-r5-evm k3-am642-r5-sk" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_IS_IN_FAT=y -CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y @@ -64,6 +74,10 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x5000 CONFIG_TI_SCI_PROTOCOL=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y @@ -101,4 +115,22 @@ CONFIG_CADENCE_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_SPL_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_CDNS3=y +CONFIG_USB_CDNS3_GADGET=y +CONFIG_SPL_USB_CDNS3_GADGET=y +CONFIG_USB_CDNS3_HOST=y +CONFIG_SPL_USB_CDNS3_HOST=y +CONFIG_USB_CDNS3_TI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6165 +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 7c9bdc2d7d3a..c2c2bf06777c 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -13,6 +13,7 @@ #include <config_distro_bootcmd.h> #include <environment/ti/mmc.h> #include <asm/arch/am64_hardware.h> +#include <environment/ti/k3_dfu.h>
/* DDR Configuration */ #define CONFIG_SYS_SDRAM_BASE1 0x880000000 @@ -95,16 +96,25 @@ "${bootdir}/${name_fit}\0" \ "partitions=" PARTS_DEFAULT
+#define EXTRA_ENV_DFUARGS \ + DFU_ALT_INFO_MMC \ + DFU_ALT_INFO_EMMC \ + DFU_ALT_INFO_RAM \ + DFU_ALT_INFO_OSPI + /* Incorporate settings into the U-Boot environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ DEFAULT_MMC_TI_ARGS \ EXTRA_ENV_AM642_BOARD_SETTINGS \ - EXTRA_ENV_AM642_BOARD_SETTINGS_MMC + EXTRA_ENV_AM642_BOARD_SETTINGS_MMC \ + EXTRA_ENV_DFUARGS
/* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
+#define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1 + /* MMC ENV related defines */ #ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
Aswath Govindraju
