[PATCH 00/12] Puma RK3399 migration to TPL and numerous fixes
From: Quentin Schulz quentin.schulz@theobroma-systems.com
Puma RK3399 SoM struggled for a few releases already to boot because the SPL was too big. Therefore, let's migrate to TPL like most RK3399-boards already did a few releases ago.
This also fixes numerous issues around fallback booting (U-Boot proper corrupted on the storage medium from where TPL/SPL was loaded) and default order of boot targets.
It also forces the environment storage medium to be the same as the one from which U-Boot proper was loaded, for a more consistent user experience.
The environment can also be stored on SPI flash now.
Finally some cleanup and the migration of the flashing instructions to u-boot-rockchip.bin and u-boot-rockchip-spi.bin.
A small patch for Lion RK3368 also, for migrating the flashing instructions to u-boot-rockchip.bin.
Patch 1/12 rockchip: puma-rk3399: fix boot_targets swap depending on U-Boot proper load medium depends on https://lore.kernel.org/u-boot/20220715151552.953654-1-foss+uboot@0leil.net/ https://lore.kernel.org/u-boot/20220715151552.953654-2-foss+uboot@0leil.net/
Patch 2/12 rockchip: puma-rk3399: use gpio-hog instead of fixed-regulator for enabling eMMC/SPI-NOR depends on https://lore.kernel.org/u-boot/20220712154422.265925-2-foss+uboot@0leil.net/
Patch 5/12 rockchip: puma-rk3399: load environment from same MMC as used for loading U-Boot proper depends on https://lore.kernel.org/u-boot/20220715151552.953654-1-foss+uboot@0leil.net/
Patch 7/12 rockchip: puma-rk3399: load environment from same medium as one used to load U-Boot proper depends on https://lore.kernel.org/u-boot/20220715151552.953654-1-foss+uboot@0leil.net/ https://lore.kernel.org/u-boot/20220715151552.953654-2-foss+uboot@0leil.net/
Patches {10,11,12}/12 depend on the following patch series: https://lore.kernel.org/u-boot/20220722113505.3875669-1-foss+uboot@0leil.net...
Cheers, Quentin
Quentin Schulz (12): rockchip: puma-rk3399: fix boot_targets swap depending on U-Boot proper load medium rockchip: puma-rk3399: use gpio-hog instead of fixed-regulator for enabling eMMC/SPI-NOR rockchip: puma-rk3399: allow non-SD-Card-loaded SPL to load U-Boot proper from SD-Card rockchip: puma-rk3399: remove unused default ENV_OFFSET for SPI flashes rockchip: puma-rk3399: load environment from same MMC as used for loading U-Boot proper rockchip: puma-rk3399: allow loading environment from SPI-NOR flash rockchip: puma-rk3399: load environment from same medium as one used to load U-Boot proper rockchip: puma-rk3399: remove useless CONFIG_SYS_SPI_U_BOOT_OFFS rockchip: puma-rk3399: migrate to TPL rockchip: puma-rk3399: migrate to u-boot-rockchip.bin rockchip: lion-rk3368: migrate to u-boot-rockchip.bin rockchip: puma-rk3399: migrate to u-boot-rockchip-spi.bin
arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 69 ++++++++++----- board/theobroma-systems/lion_rk3368/README | 9 +- board/theobroma-systems/puma_rk3399/Kconfig | 3 - board/theobroma-systems/puma_rk3399/README | 22 ++--- .../puma_rk3399/puma-rk3399.c | 84 ++++++++++++++++--- configs/puma-rk3399_defconfig | 16 ++-- 6 files changed, 139 insertions(+), 64 deletions(-)
distroboot should try first on the same MMC medium as the one the SPL loaded U-Boot proper from. This was the case when the introducing commit was merged because the default order was eMMC first and then SD card. The check was therefore made only on whether we booted from SD card, because otherwise the order was the expected one. However, in commit b212ad24a604 ("rockchip: Fix MMC boot order"), the order was swapped. Meaning our simple check is now useless.
Let's fix that by accounting for all scenarii: default boot_targets has mmc0 first but booting from SD Card, mmc1 first but booting from eMMC.
Fixes: b212ad24a604 ("rockchip: Fix MMC boot order") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com ---
Depends on https://lore.kernel.org/u-boot/20220715151552.953654-1-foss+uboot@0leil.net/ https://lore.kernel.org/u-boot/20220715151552.953654-2-foss+uboot@0leil.net/
.../puma_rk3399/puma-rk3399.c | 25 ++++++++++--------- 1 file changed, 13 insertions(+), 12 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index deeba3084a..ce3436b770 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -77,18 +77,16 @@ static int setup_boottargets(void) }
/* - * Only run, if booting from mmc1 (i.e. /mmc@fe320000) and - * only consider cases where the default boot-order first - * tries to boot from mmc0 (eMMC) and then from mmc1 - * (i.e. external SD). - * - * In other words: the SD card will be moved to earlier in the - * order, if U-Boot was also loaded from the SD-card. + * Make the default boot medium between SD Card and eMMC, the one that + * was used to load U-Boot proper. If SPI-NOR flash was used, keep + * original default order. */ - if (!strcmp(boot_device, "/mmc@fe320000")) { + if (strcmp(boot_device, "/spi@ff1d0000/flash@0")) { + bool sd_booted = !strcmp(boot_device, "/mmc@fe320000"); char *mmc0, *mmc1;
- debug("%s: booted from SD-Card\n", __func__); + debug("%s: booted from %s\n", __func__, + sd_booted ? "SD-Card" : "eMMC"); mmc0 = strstr(env, "mmc0"); mmc1 = strstr(env, "mmc1");
@@ -98,10 +96,13 @@ static int setup_boottargets(void) }
/* - * If mmc0 comes first in the boot order, we need to change - * the strings to make mmc1 first. + * If mmc0 comes first in the boot order and U-Boot proper was + * loaded from mmc1, swap mmc0 and mmc1 in the list. + * If mmc1 comes first in the boot order and U-Boot proper was + * loaded from mmc0, swap mmc0 and mmc1 in the list. */ - if (mmc0 < mmc1) { + if ((mmc0 < mmc1 && sd_booted) || + (mmc0 > mmc1 && !sd_booted)) { mmc0[3] = '1'; mmc1[3] = '0'; debug("%s: set boot_targets to: %s\n", __func__, env);
I will apply this first, but it will be better to use boot script, too many logic to get the correct boot dev with this.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
*/* original default order.
- if (strcmp(boot_device, "/spi@ff1d0000/flash@0")) {
char *mmc0, *mmc1;bool sd_booted = !strcmp(boot_device, "/mmc@fe320000");
mmc0 = strstr(env, "mmc0"); mmc1 = strstr(env, "mmc1");sd_booted ? "SD-Card" : "eMMC");
*/* loaded from mmc0, swap mmc0 and mmc1 in the list.
if (mmc0 < mmc1) {
On Haikou devkit, it is possible to disable eMMC and SPI-NOR to force booting from SD card or USB via rkdeveloptool by toggling a switch. This switch needs to be overridden in software to be able to access eMMC and SPI-NOR once the device has booted from SD Card. Puma SoM can override this pin via gpio3_d5.
Until now, fixed regulator device was abused to model this, but since there's now support for GPIO hogs, let's use it.
Since we want to be able to boot the SPL from SD Card but give it the ability to load U-Boot proper from a fallback medium such as eMMC and SPI-NOR, SPL support for GPIO hogs needs to be enabled too. Support for other kinds of regulators are not needed anymore, so let's disable them.
Depends on https://lore.kernel.org/u-boot/20220712154422.265925-2-foss+uboot@0leil.net/
arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 32 +++++++++------------ configs/puma-rk3399_defconfig | 5 ++-- 2 files changed, 16 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index e0476ab25c..b9b6ac3f6c 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -31,24 +31,6 @@ spi5 = &spi5; };
- /* - * The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module - * eMMC and SPI flash powered-down initially (in fact it keeps the - * reset signal asserted). Even though it is an enable signal, we - * model this as a regulator. - */ - bios_enable: bios_enable { - compatible = "regulator-fixed"; - u-boot,dm-pre-reloc; - regulator-name = "bios_enable"; - enable-active-high; - gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vdd_log: vdd-log { compatible = "pwm-regulator"; pwms = <&pwm2 0 25000 1>; @@ -68,6 +50,20 @@
&gpio3 { u-boot,dm-pre-reloc; + + /* + * The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module + * eMMC and SPI flash powered-down initially (in fact it keeps the + * reset signal asserted). BIOS_DISABLE_OVERRIDE pin allows to re-enable + * eMMC and SPI after the SPL has been booted from SD Card. + */ + bios_disable_override { + u-boot,dm-pre-reloc; + gpios = <RK_PD5 GPIO_ACTIVE_LOW>; + output-high; + line-name = "bios_disable_override"; + gpio-hog; + }; };
&norflash { diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 7ce2dc0719..6093943ee8 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_GPIO_HOG=y +CONFIG_SPL_GPIO_HOG=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -72,10 +74,7 @@ CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_DM_PMIC_FAN53555=y CONFIG_PMIC_RK8XX=y CONFIG_SPL_PMIC_RK8XX=y -CONFIG_SPL_DM_REGULATOR=y CONFIG_REGULATOR_PWM=y -CONFIG_SPL_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_DM_RESET=y
Thanks, - Kever
enable-active-high;
regulator-boot-on;
@@ -68,6 +50,20 @@
output-high;
gpio-hog;
&norflash {
Trying to load U-Boot proper from SPL when SPL was not loaded from SD-Card is currently not working because the SDMMC pins aren't muxed correctly. It is assumed the BootROM is doing this for us when booting from SD-Card hence why it's not needed when booting TPL/SPL from SD-Card.
The pinctrl properties are removed from the SPL DT property removal list and the pinctrl configuration nodes made available in the SPL DT, in addition to the pull-up configurations to allow loading U-Boot proper from SD-Card as a fallback mechanism for SPI-NOR and eMMC.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 24 +++++++++++++++++++++ configs/puma-rk3399_defconfig | 2 +- 2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index b9b6ac3f6c..5dc345bbe8 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -66,6 +66,30 @@ }; };
+&gpio4 { + u-boot,dm-pre-reloc; +}; + &norflash { u-boot,dm-pre-reloc; }; + +&pcfg_pull_none { + u-boot,dm-pre-reloc; +}; + +&pcfg_pull_up { + u-boot,dm-pre-reloc; +}; + +&sdmmc_bus4 { + u-boot,dm-pre-reloc; +}; + +&sdmmc_clk { + u-boot,dm-pre-reloc; +}; + +&sdmmc_cmd { + u-boot,dm-pre-reloc; +}; diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 6093943ee8..779fe5a5cd 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -42,7 +42,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y
Thanks, - Kever
+&gpio4 {
- &norflash { u-boot,dm-pre-reloc; };
+&pcfg_pull_none {
+&pcfg_pull_up {
+&sdmmc_bus4 {
+&sdmmc_clk {
+&sdmmc_cmd {
CONFIG_ENV_OFFSET is set in the defconfig to a different value already so this isn't used. Let's remove it as to not confuse users.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- board/theobroma-systems/puma_rk3399/Kconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/Kconfig b/board/theobroma-systems/puma_rk3399/Kconfig index 21946d984d..15af55574c 100644 --- a/board/theobroma-systems/puma_rk3399/Kconfig +++ b/board/theobroma-systems/puma_rk3399/Kconfig @@ -15,9 +15,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy config ENV_SIZE default 0x4000
-config ENV_OFFSET - default 0x3fc000 if ENV_IS_IN_SPI_FLASH - choice prompt "Theobroma Systems RK3399-Q7 DDR Option" default TARGET_PUMA_RK3399_RAM_DDR3_1333
Thanks, - Kever
-config ENV_OFFSET
Automatically detect which MMC device (SD-Card or eMMC) was used to load U-Boot proper and load the environment from that MMC device instead of a hardcoded one.
.../puma_rk3399/puma-rk3399.c | 22 +++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index ce3436b770..5e5e58c88e 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -113,6 +113,28 @@ static int setup_boottargets(void) return 0; }
+int mmc_get_env_dev(void) +{ + const char *boot_device = + ofnode_read_chosen_string("u-boot,spl-boot-device"); + + if (!boot_device) { + debug("%s: /chosen/u-boot,spl-boot-device not set\n", + __func__); + return CONFIG_SYS_MMC_ENV_DEV; + } + + debug("%s: booted from %s\n", __func__, boot_device); + + if (!strcmp(boot_device, "/mmc@fe320000")) + return 1; + + if (!strcmp(boot_device, "/mmc@fe330000")) + return 0; + + return CONFIG_SYS_MMC_ENV_DEV; +} + int misc_init_r(void) { const u32 cpuid_offset = 0x7;
Thanks, - Kever
- const char *boot_device =
- if (!boot_device) {
__func__);
- debug("%s: booted from %s\n", __func__, boot_device);
return 1;
- if (!strcmp(boot_device, "/mmc@fe330000"))
- return CONFIG_SYS_MMC_ENV_DEV;
- int misc_init_r(void) { const u32 cpuid_offset = 0x7;
There's a SPI-NOR flash available from which SPL and U-Boot proper can be booted, it makes sense to also allow this medium to store U-Boot environment so let's enable it.
The Device Tree advertises a max frequency of 50MHz so let's set the config option appropriately.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- configs/puma-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 779fe5a5cd..87d7e4f57c 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -45,6 +45,8 @@ CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
Thanks, - Kever
Chances are when one boots U-Boot proper from a given storage medium, they want the same medium to be used to load and store the environment.
This basically allows to have completely separate U-Boot (TPL/SPL/U-Boot proper/environment) per storage medium which is convenient when working with recovery from SD-Card as one would just need to insert a properly configured SD-Card into the device to have access to their whole debug setup.
No fallback mechanism is provided as to not dirty other storage medium environment by mistake. However, since arch_env_get_location() is called by env_init() which is part of the pre-relocation process, a valid, non-ENVL_UNKNOWN, value shall be returned otherwise the relocation fails with the following message: initcall sequence 00000000002866c0 failed at call 0000000000256b34 (err=-19)
This valid, non-ENVL_UNKNOWN, value is ENVL_NOWHERE which requires to always select CONFIG_ENV_IS_NOWHERE otherwise this work-around does not work.
.../puma_rk3399/puma-rk3399.c | 37 +++++++++++++++++++ configs/puma-rk3399_defconfig | 1 + 2 files changed, 38 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 5e5e58c88e..7ef4bac24b 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <env.h> +#include <env_internal.h> #include <init.h> #include <log.h> #include <misc.h> @@ -135,6 +136,42 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; }
+#if !IS_ENABLED(CONFIG_ENV_IS_NOWHERE) +#error Please enable CONFIG_ENV_IS_NOWHERE +#endif + +enum env_location arch_env_get_location(enum env_operation op, int prio) +{ + const char *boot_device = + ofnode_read_chosen_string("u-boot,spl-boot-device"); + + if (prio > 0) + return ENVL_UNKNOWN; + + if (!boot_device) { + debug("%s: /chosen/u-boot,spl-boot-device not set\n", + __func__); + return ENVL_NOWHERE; + } + + debug("%s: booted from %s\n", __func__, boot_device); + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && + !strcmp(boot_device, "/spi@ff1d0000/flash@0")) + return ENVL_SPI_FLASH; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC) && + (!strcmp(boot_device, "/mmc@fe320000") || + !strcmp(boot_device, "/mmc@fe330000"))) + return ENVL_MMC; + + printf("%s: No environment available: booted from %s but U-Boot " + "config does not allow loading environment from it.", + __func__, boot_device); + + return ENVL_NOWHERE; +} + int misc_init_r(void) { const u32 cpuid_offset = 0x7; diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 87d7e4f57c..e218532d70 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_SPI_MAX_HZ=50000000
Hi Quentin,
- if (prio > 0)
__func__);
- if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) &&
- if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC) &&
return ENVL_MMC;
- printf("%s: No environment available: booted from %s but U-Boot "
- return ENVL_NOWHERE;
This option is conflict with CONFIG_ENV_IS_IN_MMC, please check again where should be this board get the env.
Thanks,
- Kever
Hi Kever
On 9/1/22 15:03, Kever Yang wrote:
Hi Quentin,
Depends on https://urldefense.proofpoint.com/v2/url?u=https-3A__lore.kernel.org_u-2Dboo... https://urldefense.proofpoint.com/v2/url?u=https-3A__lore.kernel.org_u-2Dboo... .../puma_rk3399/puma-rk3399.c | 37 +++++++++++++++++++ configs/puma-rk3399_defconfig | 1 + 2 files changed, 38 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 5e5e58c88e..7ef4bac24b 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <env.h> +#include <env_internal.h> #include <init.h> #include <log.h> #include <misc.h> @@ -135,6 +136,42 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; } +#if !IS_ENABLED(CONFIG_ENV_IS_NOWHERE) +#error Please enable CONFIG_ENV_IS_NOWHERE +#endif
I created the defconfig with make savedefconfig, so if you're talking about KConfig conflict, that is incorrect, there is no conflict.
If you're talking about something else, please clarify because I don't see the issue right now.
Cheers, Quentin
Hi Quentin,
The Kconfig from env/Kconfig
config ENV_IS_NOWHERE bool "Environment is not stored" default y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ !ENV_IS_IN_FAT && !ENV_IS_IN_FLASH && \ !ENV_IS_IN_MMC && !ENV_IS_IN_NAND && \ !ENV_IS_IN_NVRAM && !ENV_IS_IN_ONENAND && \ !ENV_IS_IN_REMOTE && !ENV_IS_IN_SPI_FLASH && \ !ENV_IS_IN_UBI
I think the logic is the env parameter is stored on some kind of storage, or NOWHERE.
And what you want to do is to load from the same medium as SPL boot device(location of U-Boot proper),
this could not be NOWHERE.
Thanks,
- Kever
On 2022/9/1 21:13, Quentin Schulz wrote:
Hi Kever
Hi Quentin,
Cheers, Quentin
Hi Kever,
On 9/4/22 13:49, Kever Yang wrote:
Hi Quentin,
It's *default* to yes if none is defined. It's not a requirement.
This can be nowhere in case the proper config option is not selected. E.g. we're booting from SPI-NOR but the ENV_IS_IN_SPI_FLASH is not set. How does one handle this scenario? Since we don't want fallbacks, it needs to be "nowhere". What you're suggesting is to let the user run a broken build and have it cryptically crash with the following error:
Instead, I suggest to more gracefully error out at runtime by letting the user know that the option is not compiled in but U-Boot is still usable.
If you have another way to forbid fallbacks but not crash U-Boot in case the option is not selected, let me know.
Cheers, Quentin
Thanks,
- Kever
Hi Kever
Hi Quentin,
Cheers, Quentin
ST Restricted
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Quentin Schulz Sent: mardi 6 septembre 2022 11:23 To: Kever Yang kever.yang@rock-chips.com; Quentin Schulz foss+uboot@0leil.net Cc: sjg@chromium.org; philipp.tomsich@vrull.eu; klaus.goger@theobroma- systems.com; knaerzche@gmail.com; u-boot@lists.denx.de Subject: Re: [PATCH 07/12] rockchip: puma-rk3399: load environment from same medium as one used to load U-Boot proper
Hi Kever,
Hi Quentin,
For information : It is exactly that I do to stm32mp15 platform
See board/st/stm32mp1/stm32mp1.c::env_get_location()
ENV_IS_NOWHERE = use the default environment, embedded in U-Boot and env
It is the fallback if environment not activated ENV_IS_IN_* for the boot device, even it is not the case by default in stm32mp15_defconfig.
And it is why , I change Kconfig to allow activation of any ENV_IS_IN_* and ENV_IS_NOWHERE
Patrick
Cheers, Quentin
Thanks,
- Kever
Hi Kever
Hi Quentin,
environment.
requires
Depends on https://urldefense.proofpoint.com/v2/url?u=https-3A__lore.kernel.or g_u-2Dboot_20220715151552.953654-2D1-2Dfoss-2Buboot-400leil.net_&d=
DwIDaQ&c=_sEr5x9kUWhuk4_nFwjJtA&r=LYjLexDn7rXIzVmkNPvw5ymA1XTSq HGq8
yBP6m6qZZ4njZguQhZhkI_-
172IIy1t&m=TZndtGz1ePTd2Il6YcEjqzo9oXv73RCWH
IRVSiFVsnp2OzyCJEDzZ2KPz56AcWdn&s=wgEMbr3EjeCtvcWU_UoXqNOwQula VN-0Q
b2yL2ysaOs&e= https://urldefense.proofpoint.com/v2/url?u=https-3A__lore.kernel.or g_u-2Dboot_20220715151552.953654-2D2-2Dfoss-2Buboot-400leil.net_&d=
IRVSiFVsnp2OzyCJEDzZ2KPz56AcWdn&s=PKwYBMB7r8ekIPV1ZG7xkj7vF60YN FlYX
QRrvaVgJR8&e= .../puma_rk3399/puma-rk3399.c | 37 +++++++++++++++++++ configs/puma-rk3399_defconfig | 1 + 2 files changed, 38 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 5e5e58c88e..7ef4bac24b 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <env.h> +#include <env_internal.h> #include <init.h> #include <log.h> #include <misc.h> @@ -135,6 +136,42 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; } +#if !IS_ENABLED(CONFIG_ENV_IS_NOWHERE) +#error Please enable CONFIG_ENV_IS_NOWHERE #endif
- if (prio > 0)
__func__);
return ENVL_MMC;
- int misc_init_r(void) { const u32 cpuid_offset = 0x7; diff --git
Cheers, Quentin
Hi Patrick, Quentin,
Here is the definition about the ENV_IS_NOWHERE:
config ENV_IS_NOWHERE bool "Environment is not stored" help Define this if you don't want to or can't have an environment stored on a storage medium. In this case the environemnt will still exist while U-Boot is running, but once U-Boot exits it will not be stored. U-Boot will therefore always start up with a default environment.
Which means ENV_IS_NOWHERE is ALWAYS use default environment,
but not stored on a storage medium.
I think what you want is a new ENV_IS_ANYWHERE which not able to
decide when the firmware is build but must be some where when the boot
device is decided.
Thanks, - Kever On 2022/9/14 17:17, patrick.delaunay@foss.st.com wrote:
ST Restricted
Hi Kever,
Hi Quentin,
Patrick
Cheers, Quentin
Thanks,
- Kever
Hi Kever
Hi Quentin,
environment.
requires
172IIy1t&m=TZndtGz1ePTd2Il6YcEjqzo9oXv73RCWH IRVSiFVsnp2OzyCJEDzZ2KPz56AcWdn&s=wgEMbr3EjeCtvcWU_UoXqNOwQula VN-0Q
172IIy1t&m=TZndtGz1ePTd2Il6YcEjqzo9oXv73RCWH IRVSiFVsnp2OzyCJEDzZ2KPz56AcWdn&s=PKwYBMB7r8ekIPV1ZG7xkj7vF60YN FlYX
- if (prio > 0)
__func__);
return ENVL_MMC;
Cheers, Quentin
Hi Kever,
device is decided.
I do not share the same understanding. For me, ENV_IS_NOWHERE means the environment is stored in RAM, once you exit U-Boot or reset the board, it's gone. That's my understanding of the code, I can concede that the help message of the Kconfig option is confusing. It's just another "kind" of environment to me.
If the point was to ALWAYS use the default environment, one wouldn't be able to enable the option while other ENV_IS_IN_* are enabled. It is however possible.
ENV_IS_ANYWHERE is not a correct name for what I want, because I specifically do NOT want to load from anywhere. I want to load from a specific medium, and if not possible have a fallback to avoid U-Boot cryptically crashing.
Maybe we should rename ENV_IS_NOWHERE to ENV_IS_IN_RAM, maybe we could also stop crashing if there's no medium to load the environment from that is available, maybe we could rephrase the help text of the Kconfig option, but this is unrelated to this patch series.
Finally, STM32, some i.MX and a couple of Xilinx based boards actually have ENV_IS_NOWHERE enabled at the same time as other ENV_IS_IN_* options, so I'm clearly not the first one to use it this way. Also, see arch/arm/mach-imx/imx8m/soc.c for an implementation of arch_env_get_location that requires ENV_IS_NOWHERE to work and has almost the same logic as I'm trying to implement.
I'm trying to fix a non-booting board. This patch series is also only impacting the board I'm maintaining and nothing else. If merging the v2 of this patch series is really asking you something unimaginable, just drop this patch from the series, merge the rest and we'll continue arguing on a resend.
Quentin
The SPL payload offset when booting from SPI defaults to CONFIG_SYS_SPI_U_BOOT_OFFS but can be overridden by u-boot,spl-payload-offset. The Device Tree for Puma Haikou has this property so there's no need to have this one option in the defconfig, especially since they are not in sync and therefore confusing.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- configs/puma-rk3399_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index e218532d70..3567cd078b 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y
Thanks, - Kever
Depending on the toolchain used to compile the SPL for Puma RK3399-Q7 module, the board does not boot because the resulting binary is too big to fit in SRAM.
Let's add a TPL so that there's no need to fiddle with or hack the defconfig to have a working bootloader.
This follows what's been done for the majority of other RK3399-based boards.
See the original commit for the first migrations: bdc00080111f "rockchip: rk3399: update defconfig for TPL"
Unfortunately, the offset in SPI-NOR for U-Boot proper needs to be modified, since the move from SPL to TPL+SPL for idbloader.img (and the "only the first 2KB per 4KB blocks are written" "hack" for rkspi format) increased the size above 256KB. Let's move it to 512KB to, hopefully, be safe.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 2 +- board/theobroma-systems/puma_rk3399/README | 8 ++++---- configs/puma-rk3399_defconfig | 4 ++-- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index 5dc345bbe8..27a792fe6d 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -14,7 +14,7 @@
/ { config { - u-boot,spl-payload-offset = <0x40000>; /* @ 256KB */ + u-boot,spl-payload-offset = <0x80000>; /* @ 512KB */ u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ u-boot,boot-led = "module_led"; diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index 254c3bbe96..550bdfb1f4 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -51,13 +51,13 @@ The SPL image for SD-Card/eMMC is readily available in idbloader.img at the root of U-Boot after compilation.
Creating an SPL image for SPI-NOR: - > tools/mkimage -n rk3399 -T rkspi -d spl/u-boot-spl.bin idbloader-spi.img + > tools/mkimage -n rk3399 -T rkspi -d tpl/u-boot-tpl.bin:spl/u-boot-spl.bin idbloader-spi.img
Flash the image ===============
-Copy the SPL to offset 32k for SD/eMMC, offset 0 for NOR-Flash and the FIT -image to offset 256k. +Copy the SPL to offset 32k and the FIT image to offset 256k for SD/eMMC. +Copy the SPL to offset 0 and the FIT image to offset 512k for NOR-Flash.
SD-Card ------- @@ -98,4 +98,4 @@ help of the Rockchip loader binary.
./rkdeveloptool db rkbin/rk3399_loader_spinor_v1.25.114.bin ./rkdeveloptool ef ./rkdeveloptool wl 0 ../idbloader-spi.img
- > ./rkdeveloptool wl 512 ../u-boot.itb + > ./rkdeveloptool wl 1024 ../u-boot.itb diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3567cd078b..c70dbe9ed5 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 CONFIG_TARGET_PUMA_RK3399=y @@ -22,11 +21,12 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_SPI_LOAD=y +CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y
Thanks, - Kever
/ { config {
u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ u-boot,boot-led = "module_led";u-boot,spl-payload-offset = <0x80000>; /* @ 512KB */
Flash the image
SD-Card
@@ -98,4 +98,4 @@ help of the Rockchip loader binary. > ./rkdeveloptool db rkbin/rk3399_loader_spinor_v1.25.114.bin > ./rkdeveloptool ef > ./rkdeveloptool wl 0 ../idbloader-spi.img
./rkdeveloptool wl 1024 ../u-boot.itbdiff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3567cd078b..c70dbe9ed5 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -7,7 +7,6 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" -CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 CONFIG_TARGET_PUMA_RK3399=y @@ -22,11 +21,12 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y CONFIG_SPL_SPI_LOAD=y +CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y
Hi Quentin,
I got below error when apply this patch, please rebase this patch set.
Applying: rockchip: puma-rk3399: migrate to TPL error: sha1 information is lacking or useless (configs/puma-rk3399_defconfig). error: could not build fake ancestor hint: Use 'git am --show-current-patch' to see the failed patch Patch failed at 0009 rockchip: puma-rk3399: migrate to TPL
Thanks,
- Kever
/ { config {
Flash the image
SD-Card
Now that the offset for u-boot.itb in the u-boot-rockchip.bin matches the one required for Puma, let's tell users to use it instead of flashing the TPL/SPL and U-Boot proper separately.
Depends on follwing patch series: https://lore.kernel.org/u-boot/20220722113505.3875669-1-foss+uboot@0leil.net...
board/theobroma-systems/puma_rk3399/README | 11 +++-------- 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index 550bdfb1f4..2e3785c986 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -47,23 +47,19 @@ Compile the U-Boot Package the image =================
-The SPL image for SD-Card/eMMC is readily available in idbloader.img at the -root of U-Boot after compilation. - Creating an SPL image for SPI-NOR:
-Copy the SPL to offset 32k and the FIT image to offset 256k for SD/eMMC. +Copy u-boot-rockchip.bin to offset 32k for SD/eMMC. Copy the SPL to offset 0 and the FIT image to offset 512k for NOR-Flash.
SD-Card -------
- > dd if=idbloader.img of=/dev/sdb seek=64 - > dd if=u-boot.itb of=/dev/sdb seek=512 + > dd if=u-boot-rockchip.bin of=/dev/sdb seek=64
eMMC ---- @@ -79,8 +75,7 @@ help of the Rockchip loader binary.
./tools/boot_merger RKBOOT/RK3399MINIALL.ini cd .. ./rkdeveloptool db rkbin/rk3399_loader_v1.25.126.bin
- > ./rkdeveloptool wl 64 ../idbloader.img - > ./rkdeveloptool wl 512 ../u-boot.itb + > ./rkdeveloptool wl 64 ../u-boot-rockchip.bin
NOR-Flash ---------
Thanks, - Kever
Flash the image
SD-Card
dd if=idbloader.img of=/dev/sdb seek=64 dd if=u-boot.itb of=/dev/sdb seek=512
eMMC
@@ -79,8 +75,7 @@ help of the Rockchip loader binary. > ./tools/boot_merger RKBOOT/RK3399MINIALL.ini > cd .. > ./rkdeveloptool db rkbin/rk3399_loader_v1.25.126.bin
./rkdeveloptool wl 64 ../idbloader.img ./rkdeveloptool wl 512 ../u-boot.itb
NOR-Flash
Now that the offset for u-boot.itb in the u-boot-rockchip.bin matches the one required for Lion, let's tell users to use it instead of flashing the TPL/SPL and U-Boot proper separately.
board/theobroma-systems/lion_rk3368/README | 9 +++------ 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/board/theobroma-systems/lion_rk3368/README b/board/theobroma-systems/lion_rk3368/README index 7488b18326..3c15a7bb36 100644 --- a/board/theobroma-systems/lion_rk3368/README +++ b/board/theobroma-systems/lion_rk3368/README @@ -27,14 +27,12 @@ Build the full U-Boot and a FIT image including the ATF Flash the image ===============
-Copy the SPL to offset 32k and the FIT image containing the payloads -(U-Boot proper, ATF, devicetree) to offset 256k card. +Copy u-boot-rockchip.bin at offset 32k on SD-Card/eMMC.
SD-Card -------
- > dd if=idbloader.img of=/dev/sdb seek=64 - > dd if=u-boot.itb of=/dev/sdb seek=512 + > dd if=u-boot-rockchip.bin of=/dev/sdb seekp=64
eMMC ---- @@ -47,8 +45,7 @@ help of the Rockchip loader binary.
autoreconf -i && && ./configure && make git clone https://github.com/rockchip-linux/rkbin.git ./rkdeveloptool db rkbin/rk33/rk3368_loader_v2.00.256.bin
- > ./rkdeveloptool wl 64 ../spl.img - > ./rkdeveloptool wl 512 ../u-boot.itb + > ./rkdeveloptool wl 64 ../u-boot-rockchip.bin
If everything went according to plan, you should see the following
Now that a single binary containing TPL/SPL correctly formatted for SPI flashes and U-Boot proper, can be generated by binman, let's do it.
Also update the documentation to tell the user to use this newly generated file instead of manually generating and flashing the binaries.
arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 11 +++++++++++ board/theobroma-systems/puma_rk3399/README | 11 ++--------- configs/puma-rk3399_defconfig | 1 + 3 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index 27a792fe6d..bfc504b952 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -44,6 +44,17 @@ }; };
+#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +&binman { + simple-bin-spi { + blob { + /* same as u-boot,spl-payload-offset */ + offset = <0x80000>; + }; + }; +}; +#endif + &gpio1 { u-boot,dm-pre-reloc; }; diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index 2e3785c986..649aa3c543 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -44,17 +44,11 @@ Compile the U-Boot
cd ../u-boot make CROSS_COMPILE=aarch64-linux-gnu- puma-rk3399_defconfig all
-Package the image -================= - -Creating an SPL image for SPI-NOR: - > tools/mkimage -n rk3399 -T rkspi -d tpl/u-boot-tpl.bin:spl/u-boot-spl.bin idbloader-spi.img - Flash the image ===============
Copy u-boot-rockchip.bin to offset 32k for SD/eMMC. -Copy the SPL to offset 0 and the FIT image to offset 512k for NOR-Flash. +Copy u-boot-rockchip-spi.bin to offset 0 for NOR-flash.
SD-Card ------- @@ -92,5 +86,4 @@ help of the Rockchip loader binary.
cd .. ./rkdeveloptool db rkbin/rk3399_loader_spinor_v1.25.114.bin ./rkdeveloptool ef
- > ./rkdeveloptool wl 0 ../idbloader-spi.img - > ./rkdeveloptool wl 1024 ../u-boot.itb + > ./rkdeveloptool wl 0 ../u-boot-rockchip-spi.bin diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index c70dbe9ed5..0f532b2776 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_TARGET_PUMA_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF180000 CONFIG_DEBUG_UART_CLOCK=24000000
Thanks, - Kever
- simple-bin-spi {
blob {
offset = <0x80000>;
+}; +#endif
- &gpio1 { u-boot,dm-pre-reloc; };
diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index 2e3785c986..649aa3c543 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -44,17 +44,11 @@ Compile the U-Boot > cd ../u-boot > make CROSS_COMPILE=aarch64-linux-gnu- puma-rk3399_defconfig all
-Package the image
Flash the image
SD-Card
@@ -92,5 +86,4 @@ help of the Rockchip loader binary. > cd .. > ./rkdeveloptool db rkbin/rk3399_loader_spinor_v1.25.114.bin > ./rkdeveloptool ef
./rkdeveloptool wl 0 ../idbloader-spi.img ./rkdeveloptool wl 1024 ../u-boot.itb
./rkdeveloptool wl 0 ../u-boot-rockchip-spi.bindiff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index c70dbe9ed5..0f532b2776 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_TARGET_PUMA_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF180000 CONFIG_DEBUG_UART_CLOCK=24000000
Kever Yang
Quentin Schulz
Quentin Schulz
