[PATCH] Convert CONFIG_SYS_MEM_TOP_HIDE to Kconfig
This converts the following to Kconfig: CONFIG_SYS_MEM_TOP_HIDE
Signed-off-by: Tom Rini trini@konsulko.com --- Kconfig | 11 +++++++++++ README | 21 --------------------- board/samsung/common/board.c | 4 ++-- common/board_f.c | 2 +- configs/odroid-xu3_defconfig | 3 ++- configs/odroid_defconfig | 3 ++- configs/origen_defconfig | 3 ++- configs/s5pc210_universal_defconfig | 3 ++- configs/theadorable_debug_defconfig | 3 ++- configs/trats2_defconfig | 3 ++- configs/trats_defconfig | 3 ++- include/configs/odroid.h | 3 --- include/configs/odroid_xu3.h | 3 --- include/configs/origen.h | 2 -- include/configs/s5pc210_universal.h | 2 -- include/configs/theadorable.h | 3 --- include/configs/trats.h | 2 -- include/configs/trats2.h | 2 -- 18 files changed, 28 insertions(+), 48 deletions(-)
diff --git a/Kconfig b/Kconfig index 112745440b5a..cd63f6a74e52 100644 --- a/Kconfig +++ b/Kconfig @@ -456,6 +456,17 @@ config STACK_SIZE by the UEFI sub-system. On some boards initrd_high is calculated as base stack pointer minus this stack size.
+config SYS_MEM_TOP_HIDE + hex "Exclude some memory from U-Boot / OS information" + default 0x0 + help + If set, this specified memory area will get subtracted from the top + (end) of RAM and won't get "touched" at all by U-Boot. By fixing up + gd->ram_size the OS / next stage should gets passed the now + "corrected" memory size and won't touch it either. + WARNING: Please make sure that this value is a multiple of the OS + page size. + config SYS_HAS_SRAM bool default y if TARGET_PIC32MZDASK diff --git a/README b/README index f31fcd73f196..4deef2789450 100644 --- a/README +++ b/README @@ -1887,27 +1887,6 @@ Configuration Settings: the RAM base is not zero, or RAM is divided into banks, this variable needs to be recalcuated to get the address.
-- CONFIG_SYS_MEM_TOP_HIDE: - If CONFIG_SYS_MEM_TOP_HIDE is defined in the board config header, - this specified memory area will get subtracted from the top - (end) of RAM and won't get "touched" at all by U-Boot. By - fixing up gd->ram_size the Linux kernel should gets passed - the now "corrected" memory size and won't touch it either. - This should work for arch/ppc and arch/powerpc. Only Linux - board ports in arch/powerpc with bootwrapper support that - recalculate the memory size from the SDRAM controller setup - will have to get fixed in Linux additionally. - - This option can be used as a workaround for the 440EPx/GRx - CHIP 11 errata where the last 256 bytes in SDRAM shouldn't - be touched. - - WARNING: Please make sure that this value is a multiple of - the Linux page size (normally 4k). If this is not the case, - then the end address of the Linux memory will be located at a - non page size aligned address and this could cause major - problems. - - CONFIG_SYS_LOADS_BAUD_CHANGE: Enable temporary baudrate change while serial download
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 97791aaeffe2..ff178b7fe677 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -107,9 +107,9 @@ int board_init(void) } boot_temp_check(); #endif -#ifdef CONFIG_TZSW_RESERVED_DRAM_SIZE +#if CONFIG_VAL(SYS_MEM_TOP_HIDE) /* The last few MB of memory can be reserved for secure firmware */ - ulong size = CONFIG_TZSW_RESERVED_DRAM_SIZE; + ulong size = CONFIG_SYS_MEM_TOP_HIDE;
gd->ram_size -= size; gd->bd->bi_dram[CONFIG_NR_DRAM_BANKS - 1].size -= size; diff --git a/common/board_f.c b/common/board_f.c index 5b655ad6efe4..4d7e40013e1c 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -327,7 +327,7 @@ static int setup_dest_addr(void) * Ram is setup, size stored in gd !! */ debug("Ram size: %08lX\n", (ulong)gd->ram_size); -#if defined(CONFIG_SYS_MEM_TOP_HIDE) +#if CONFIG_VAL(SYS_MEM_TOP_HIDE) /* * Subtract specified amount of memory to hide so that it won't * get "touched" at all by U-Boot. By fixing up gd->ram_size diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 8a507904be9f..250c0b4b3da3 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -10,9 +10,10 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x310000 CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" +CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_LOAD_ADDR=0x43e00000 +CONFIG_SYS_MEM_TOP_HIDE=0x01600000 CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 54ff5799cb73..058e7dc3177c 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -11,9 +11,10 @@ CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x140000 CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" +CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_LOAD_ADDR=0x43e00000 +CONFIG_SYS_MEM_TOP_HIDE=0x00100000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTARGS=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 83a83ab13b14..b4b0d8b1464c 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -14,8 +14,9 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" CONFIG_SPL_TEXT_BASE=0x02021410 CONFIG_SPL=y CONFIG_IDENT_STRING=" for ORIGEN" -CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x43e00000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_BOOTCOMMAND="if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bootenv};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;if run loadbootscript; then run bootscript; fi; fi;load mmc ${mmcdev} ${loadaddr} uImage; bootm ${loadaddr} " CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 3c0c7b53547b..e70ce25b099d 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -11,8 +11,9 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" -CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x44800000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="Please use defined boot" CONFIG_BOOTCOMMAND="run mmcboot" diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 3b841b0c427a..230c086617a5 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -17,9 +17,10 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_LOAD_ADDR=0x800000 +CONFIG_SYS_MEM_TOP_HIDE=0x80000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index b93c9eb7175b..690cdef4c4ab 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -10,9 +10,10 @@ CONFIG_TARGET_TRATS2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" +CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_LOAD_ADDR=0x43e00000 +CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTARGS=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index d55c1d70e64b..18890799535e 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -10,8 +10,9 @@ CONFIG_TARGET_TRATS=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" -CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x44800000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTARGS=y diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 42031bb99344..b8b47af4712b 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -21,9 +21,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ #define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -/* Reserve the last 1 MiB for the secure firmware */ -#define CONFIG_SYS_MEM_TOP_HIDE (1UL << 20UL) -#define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE
#include <linux/sizes.h>
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 616f25eafd3e..eb35d7b4ae2d 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -15,9 +15,6 @@ #define TZPC_BASE_OFFSET 0x10000
#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -/* Reserve the last 22 MiB for the secure firmware */ -#define CONFIG_SYS_MEM_TOP_HIDE (22UL << 20UL) -#define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
diff --git a/include/configs/origen.h b/include/configs/origen.h index 278c204ded8a..c4f5997c3dec 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -19,8 +19,6 @@ #define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - /* Power Down Modes */ #define S5P_CHECK_SLEEP 0x00000BAD #define S5P_CHECK_DIDLE 0xBAD00000 diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 8cbdbc733c0b..ae56c66e15cd 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -24,8 +24,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - /* Actual modem binary size is 16MiB. Add 2MiB for bad block handling */
#define NORMAL_MTDPARTS_DEFAULT CONFIG_MTDPARTS_DEFAULT diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 14817b165cfa..fdf048b27b3c 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -43,9 +43,6 @@ /* SATA support */ #define CONFIG_LBA48
-/* Enable LCD and reserve 512KB from top of memory*/ -#define CONFIG_SYS_MEM_TOP_HIDE 0x80000 - /* FPGA programming support */ #define CONFIG_FPGA_STRATIX_V
diff --git a/include/configs/trats.h b/include/configs/trats.h index 41ac6090c270..910fc150b18b 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -28,8 +28,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOT "boot" diff --git a/include/configs/trats2.h b/include/configs/trats2.h index a980e6c47d11..3e121bc6909a 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -27,8 +27,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE)
