[PATCH 01/10] net: Remove armada100_fec driver
This driver is not enabled by any board and not converted to DM_ETH. Remove.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/armada100_fec.c | 739 ------------------------------------ drivers/net/armada100_fec.h | 208 ---------- 3 files changed, 948 deletions(-) delete mode 100644 drivers/net/armada100_fec.c delete mode 100644 drivers/net/armada100_fec.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index a6d0c23f02d3..b57149b33994 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -6,7 +6,6 @@
obj-$(CONFIG_AG7XXX) += ag7xxx.o obj-$(CONFIG_ALTERA_TSE) += altera_tse.o -obj-$(CONFIG_ARMADA100_FEC) += armada100_fec.o obj-$(CONFIG_ASPEED_MDIO) += aspeed_mdio.o obj-$(CONFIG_BCM6348_ETH) += bcm6348-eth.o obj-$(CONFIG_BCM6368_ETH) += bcm6368-eth.o diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c deleted file mode 100644 index 5d4b90c6ba72..000000000000 --- a/drivers/net/armada100_fec.c +++ /dev/null @@ -1,739 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2011 - * eInfochips Ltd. <www.einfochips.com> - * Written-by: Ajay Bhargav contact@8051projects.net - * - * (C) Copyright 2010 - * Marvell Semiconductor <www.marvell.com> - * Contributor: Mahavir Jain mjain@marvell.com - */ - -#include <common.h> -#include <log.h> -#include <net.h> -#include <malloc.h> -#include <miiphy.h> -#include <netdev.h> -#include <asm/types.h> -#include <asm/byteorder.h> -#include <linux/delay.h> -#include <linux/err.h> -#include <linux/mii.h> -#include <asm/io.h> -#include <asm/arch/armada100.h> -#include "armada100_fec.h" - -#define PHY_ADR_REQ 0xFF /* Magic number to read/write PHY address */ - -#ifdef DEBUG -static int eth_dump_regs(struct eth_device *dev) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - unsigned int i = 0; - - printf("\noffset: phy_adr, value: 0x%x\n", readl(®s->phyadr)); - printf("offset: smi, value: 0x%x\n", readl(®s->smi)); - for (i = 0x400; i <= 0x4e4; i += 4) - printf("offset: 0x%x, value: 0x%x\n", - i, readl(ARMD1_FEC_BASE + i)); - return 0; -} -#endif - -static int armdfec_phy_timeout(u32 *reg, u32 flag, int cond) -{ - u32 timeout = PHY_WAIT_ITERATIONS; - u32 reg_val; - - while (--timeout) { - reg_val = readl(reg); - if (cond && (reg_val & flag)) - break; - else if (!cond && !(reg_val & flag)) - break; - udelay(PHY_WAIT_MICRO_SECONDS); - } - return !timeout; -} - -static int smi_reg_read(struct mii_dev *bus, int phy_addr, int devad, - int phy_reg) -{ - u16 value = 0; - struct eth_device *dev = eth_get_dev_by_name(bus->name); - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - u32 val; - - if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { - val = readl(®s->phyadr); - value = val & 0x1f; - return value; - } - - /* check parameters */ - if (phy_addr > PHY_MASK) { - printf("ARMD100 FEC: (%s) Invalid phy address: 0x%X\n", - __func__, phy_addr); - return -EINVAL; - } - if (phy_reg > PHY_MASK) { - printf("ARMD100 FEC: (%s) Invalid register offset: 0x%X\n", - __func__, phy_reg); - return -EINVAL; - } - - /* wait for the SMI register to become available */ - if (armdfec_phy_timeout(®s->smi, SMI_BUSY, false)) { - printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); - return -1; - } - - writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi); - - /* now wait for the data to be valid */ - if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, true)) { - val = readl(®s->smi); - printf("ARMD100 FEC: (%s) PHY Read timeout, val=0x%x\n", - __func__, val); - return -1; - } - val = readl(®s->smi); - value = val & 0xffff; - - return value; -} - -static int smi_reg_write(struct mii_dev *bus, int phy_addr, int devad, - int phy_reg, u16 value) -{ - struct eth_device *dev = eth_get_dev_by_name(bus->name); - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - - if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { - clrsetbits_le32(®s->phyadr, 0x1f, value & 0x1f); - return 0; - } - - /* check parameters */ - if (phy_addr > PHY_MASK) { - printf("ARMD100 FEC: (%s) Invalid phy address\n", __func__); - return -EINVAL; - } - if (phy_reg > PHY_MASK) { - printf("ARMD100 FEC: (%s) Invalid register offset\n", __func__); - return -EINVAL; - } - - /* wait for the SMI register to become available */ - if (armdfec_phy_timeout(®s->smi, SMI_BUSY, false)) { - printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); - return -1; - } - - writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_W | (value & 0xffff), - ®s->smi); - return 0; -} - -/* - * Abort any transmit and receive operations and put DMA - * in idle state. AT and AR bits are cleared upon entering - * in IDLE state. So poll those bits to verify operation. - */ -static void abortdma(struct eth_device *dev) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - int delay; - int maxretries = 40; - u32 tmp; - - while (--maxretries) { - writel(SDMA_CMD_AR | SDMA_CMD_AT, ®s->sdma_cmd); - udelay(100); - - delay = 10; - while (--delay) { - tmp = readl(®s->sdma_cmd); - if (!(tmp & (SDMA_CMD_AR | SDMA_CMD_AT))) - break; - udelay(10); - } - if (delay) - break; - } - - if (!maxretries) - printf("ARMD100 FEC: (%s) DMA Stuck\n", __func__); -} - -static inline u32 nibble_swapping_32_bit(u32 x) -{ - return ((x & 0xf0f0f0f0) >> 4) | ((x & 0x0f0f0f0f) << 4); -} - -static inline u32 nibble_swapping_16_bit(u32 x) -{ - return ((x & 0x0000f0f0) >> 4) | ((x & 0x00000f0f) << 4); -} - -static inline u32 flip_4_bits(u32 x) -{ - return ((x & 0x01) << 3) | ((x & 0x002) << 1) - | ((x & 0x04) >> 1) | ((x & 0x008) >> 3); -} - -/* - * This function will calculate the hash function of the address. - * depends on the hash mode and hash size. - * Inputs - * mach - the 2 most significant bytes of the MAC address. - * macl - the 4 least significant bytes of the MAC address. - * Outputs - * return the calculated entry. - */ -static u32 hash_function(u32 mach, u32 macl) -{ - u32 hashresult; - u32 addrh; - u32 addrl; - u32 addr0; - u32 addr1; - u32 addr2; - u32 addr3; - u32 addrhswapped; - u32 addrlswapped; - - addrh = nibble_swapping_16_bit(mach); - addrl = nibble_swapping_32_bit(macl); - - addrhswapped = flip_4_bits(addrh & 0xf) - + ((flip_4_bits((addrh >> 4) & 0xf)) << 4) - + ((flip_4_bits((addrh >> 8) & 0xf)) << 8) - + ((flip_4_bits((addrh >> 12) & 0xf)) << 12); - - addrlswapped = flip_4_bits(addrl & 0xf) - + ((flip_4_bits((addrl >> 4) & 0xf)) << 4) - + ((flip_4_bits((addrl >> 8) & 0xf)) << 8) - + ((flip_4_bits((addrl >> 12) & 0xf)) << 12) - + ((flip_4_bits((addrl >> 16) & 0xf)) << 16) - + ((flip_4_bits((addrl >> 20) & 0xf)) << 20) - + ((flip_4_bits((addrl >> 24) & 0xf)) << 24) - + ((flip_4_bits((addrl >> 28) & 0xf)) << 28); - - addrh = addrhswapped; - addrl = addrlswapped; - - addr0 = (addrl >> 2) & 0x03f; - addr1 = (addrl & 0x003) | (((addrl >> 8) & 0x7f) << 2); - addr2 = (addrl >> 15) & 0x1ff; - addr3 = ((addrl >> 24) & 0x0ff) | ((addrh & 1) << 8); - - hashresult = (addr0 << 9) | (addr1 ^ addr2 ^ addr3); - hashresult = hashresult & 0x07ff; - return hashresult; -} - -/* - * This function will add an entry to the address table. - * depends on the hash mode and hash size that was initialized. - * Inputs - * mach - the 2 most significant bytes of the MAC address. - * macl - the 4 least significant bytes of the MAC address. - * skip - if 1, skip this address. - * rd - the RD field in the address table. - * Outputs - * address table entry is added. - * 0 if success. - * -ENOSPC if table full - */ -static int add_del_hash_entry(struct armdfec_device *darmdfec, u32 mach, - u32 macl, u32 rd, u32 skip, int del) -{ - struct addr_table_entry_t *entry, *start; - u32 newhi; - u32 newlo; - u32 i; - - newlo = (((mach >> 4) & 0xf) << 15) - | (((mach >> 0) & 0xf) << 11) - | (((mach >> 12) & 0xf) << 7) - | (((mach >> 8) & 0xf) << 3) - | (((macl >> 20) & 0x1) << 31) - | (((macl >> 16) & 0xf) << 27) - | (((macl >> 28) & 0xf) << 23) - | (((macl >> 24) & 0xf) << 19) - | (skip << HTESKIP) | (rd << HTERDBIT) - | HTEVALID; - - newhi = (((macl >> 4) & 0xf) << 15) - | (((macl >> 0) & 0xf) << 11) - | (((macl >> 12) & 0xf) << 7) - | (((macl >> 8) & 0xf) << 3) - | (((macl >> 21) & 0x7) << 0); - - /* - * Pick the appropriate table, start scanning for free/reusable - * entries at the index obtained by hashing the specified MAC address - */ - start = (struct addr_table_entry_t *)(darmdfec->htpr); - entry = start + hash_function(mach, macl); - for (i = 0; i < HOP_NUMBER; i++) { - if (!(entry->lo & HTEVALID)) { - break; - } else { - /* if same address put in same position */ - if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8)) - && (entry->hi == newhi)) - break; - } - if (entry == start + 0x7ff) - entry = start; - else - entry++; - } - - if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) && - (entry->hi != newhi) && del) - return 0; - - if (i == HOP_NUMBER) { - if (!del) { - printf("ARMD100 FEC: (%s) table section is full\n", - __func__); - return -ENOSPC; - } else { - return 0; - } - } - - /* - * Update the selected entry - */ - if (del) { - entry->hi = 0; - entry->lo = 0; - } else { - entry->hi = newhi; - entry->lo = newlo; - } - - return 0; -} - -/* - * Create an addressTable entry from MAC address info - * found in the specifed net_device struct - * - * Input : pointer to ethernet interface network device structure - * Output : N/A - */ -static void update_hash_table_mac_address(struct armdfec_device *darmdfec, - u8 *oaddr, u8 *addr) -{ - u32 mach; - u32 macl; - - /* Delete old entry */ - if (oaddr) { - mach = (oaddr[0] << 8) | oaddr[1]; - macl = (oaddr[2] << 24) | (oaddr[3] << 16) | - (oaddr[4] << 8) | oaddr[5]; - add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_DELETE); - } - - /* Add new entry */ - mach = (addr[0] << 8) | addr[1]; - macl = (addr[2] << 24) | (addr[3] << 16) | (addr[4] << 8) | addr[5]; - add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_ADD); -} - -/* Address Table Initialization */ -static void init_hashtable(struct eth_device *dev) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - memset(darmdfec->htpr, 0, HASH_ADDR_TABLE_SIZE); - writel((u32)darmdfec->htpr, ®s->htpr); -} - -/* - * This detects PHY chip from address 0-31 by reading PHY status - * registers. PHY chip can be connected at any of this address. - */ -static int ethernet_phy_detect(struct eth_device *dev) -{ - u32 val; - u16 tmp, mii_status; - u8 addr; - - for (addr = 0; addr < 32; addr++) { - if (miiphy_read(dev->name, addr, MII_BMSR, &mii_status) != 0) - /* try next phy */ - continue; - - /* invalid MII status. More validation required here... */ - if (mii_status == 0 || mii_status == 0xffff) - /* try next phy */ - continue; - - if (miiphy_read(dev->name, addr, MII_PHYSID1, &tmp) != 0) - /* try next phy */ - continue; - - val = tmp << 16; - if (miiphy_read(dev->name, addr, MII_PHYSID2, &tmp) != 0) - /* try next phy */ - continue; - - val |= tmp; - - if ((val & 0xfffffff0) != 0) - return addr; - } - return -1; -} - -static void armdfec_init_rx_desc_ring(struct armdfec_device *darmdfec) -{ - struct rx_desc *p_rx_desc; - int i; - - /* initialize the Rx descriptors ring */ - p_rx_desc = darmdfec->p_rxdesc; - for (i = 0; i < RINGSZ; i++) { - p_rx_desc->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; - p_rx_desc->buf_size = PKTSIZE_ALIGN; - p_rx_desc->byte_cnt = 0; - p_rx_desc->buf_ptr = darmdfec->p_rxbuf + i * PKTSIZE_ALIGN; - if (i == (RINGSZ - 1)) { - p_rx_desc->nxtdesc_p = darmdfec->p_rxdesc; - } else { - p_rx_desc->nxtdesc_p = (struct rx_desc *) - ((u32)p_rx_desc + ARMDFEC_RXQ_DESC_ALIGNED_SIZE); - p_rx_desc = p_rx_desc->nxtdesc_p; - } - } - darmdfec->p_rxdesc_curr = darmdfec->p_rxdesc; -} - -static int armdfec_init(struct eth_device *dev, struct bd_info *bd) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - int phy_adr; - u32 temp; - - armdfec_init_rx_desc_ring(darmdfec); - - /* Disable interrupts */ - writel(0, ®s->im); - writel(0, ®s->ic); - /* Write to ICR to clear interrupts. */ - writel(0, ®s->iwc); - - /* - * Abort any transmit and receive operations and put DMA - * in idle state. - */ - abortdma(dev); - - /* Initialize address hash table */ - init_hashtable(dev); - - /* SDMA configuration */ - writel(SDCR_BSZ8 | /* Burst size = 32 bytes */ - SDCR_RIFB | /* Rx interrupt on frame */ - SDCR_BLMT | /* Little endian transmit */ - SDCR_BLMR | /* Little endian receive */ - SDCR_RC_MAX_RETRANS, /* Max retransmit count */ - ®s->sdma_conf); - /* Port Configuration */ - writel(PCR_HS, ®s->pconf); /* Hash size is 1/2kb */ - - /* Set extended port configuration */ - writel(PCXR_2BSM | /* Two byte suffix aligns IP hdr */ - PCXR_DSCP_EN | /* Enable DSCP in IP */ - PCXR_MFL_1536 | /* Set MTU = 1536 */ - PCXR_FLP | /* do not force link pass */ - PCXR_TX_HIGH_PRI, /* Transmit - high priority queue */ - ®s->pconf_ext); - - update_hash_table_mac_address(darmdfec, NULL, dev->enetaddr); - - /* Update TX and RX queue descriptor register */ - temp = (u32)®s->txcdp[TXQ]; - writel((u32)darmdfec->p_txdesc, temp); - temp = (u32)®s->rxfdp[RXQ]; - writel((u32)darmdfec->p_rxdesc, temp); - temp = (u32)®s->rxcdp[RXQ]; - writel((u32)darmdfec->p_rxdesc_curr, temp); - - /* Enable Interrupts */ - writel(ALL_INTS, ®s->im); - - /* Enable Ethernet Port */ - setbits_le32(®s->pconf, PCR_EN); - - /* Enable RX DMA engine */ - setbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); - -#ifdef DEBUG - eth_dump_regs(dev); -#endif - -#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) - -#if defined(CONFIG_PHY_BASE_ADR) - miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, CONFIG_PHY_BASE_ADR); -#else - /* Search phy address from range 0-31 */ - phy_adr = ethernet_phy_detect(dev); - if (phy_adr < 0) { - printf("ARMD100 FEC: PHY not detected at address range 0-31\n"); - return -1; - } else { - debug("ARMD100 FEC: PHY detected at addr %d\n", phy_adr); - miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, phy_adr); - } -#endif - -#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) - /* Wait up to 5s for the link status */ - for (i = 0; i < 5; i++) { - u16 phy_adr; - - miiphy_read(dev->name, 0xFF, 0xFF, &phy_adr); - /* Return if we get link up */ - if (miiphy_link(dev->name, phy_adr)) - return 0; - udelay(1000000); - } - - printf("ARMD100 FEC: No link on %s\n", dev->name); - return -1; -#endif -#endif - return 0; -} - -static void armdfec_halt(struct eth_device *dev) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - - /* Stop RX DMA */ - clrbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); - - /* - * Abort any transmit and receive operations and put DMA - * in idle state. - */ - abortdma(dev); - - /* Disable interrupts */ - writel(0, ®s->im); - writel(0, ®s->ic); - writel(0, ®s->iwc); - - /* Disable Port */ - clrbits_le32(®s->pconf, PCR_EN); -} - -static int armdfec_send(struct eth_device *dev, void *dataptr, int datasize) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct armdfec_reg *regs = darmdfec->regs; - struct tx_desc *p_txdesc = darmdfec->p_txdesc; - void *p = (void *)dataptr; - int retry = PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS; - u32 cmd_sts, temp; - - /* Copy buffer if it's misaligned */ - if ((u32)dataptr & 0x07) { - if (datasize > PKTSIZE_ALIGN) { - printf("ARMD100 FEC: Non-aligned data too large (%d)\n", - datasize); - return -1; - } - memcpy(darmdfec->p_aligned_txbuf, p, datasize); - p = darmdfec->p_aligned_txbuf; - } - - p_txdesc->cmd_sts = TX_ZERO_PADDING | TX_GEN_CRC; - p_txdesc->cmd_sts |= TX_FIRST_DESC | TX_LAST_DESC; - p_txdesc->cmd_sts |= BUF_OWNED_BY_DMA; - p_txdesc->cmd_sts |= TX_EN_INT; - p_txdesc->buf_ptr = p; - p_txdesc->byte_cnt = datasize; - - /* Apply send command using high priority TX queue */ - temp = (u32)®s->txcdp[TXQ]; - writel((u32)p_txdesc, temp); - writel(SDMA_CMD_TXDL | SDMA_CMD_TXDH | SDMA_CMD_ERD, ®s->sdma_cmd); - - /* - * wait for packet xmit completion - */ - cmd_sts = readl(&p_txdesc->cmd_sts); - while (cmd_sts & BUF_OWNED_BY_DMA) { - /* return fail if error is detected */ - if ((cmd_sts & (TX_ERROR | TX_LAST_DESC)) == - (TX_ERROR | TX_LAST_DESC)) { - printf("ARMD100 FEC: (%s) in xmit packet\n", __func__); - return -1; - } - cmd_sts = readl(&p_txdesc->cmd_sts); - if (!(retry--)) { - printf("ARMD100 FEC: (%s) xmit packet timeout!\n", - __func__); - return -1; - } - } - - return 0; -} - -static int armdfec_recv(struct eth_device *dev) -{ - struct armdfec_device *darmdfec = to_darmdfec(dev); - struct rx_desc *p_rxdesc_curr = darmdfec->p_rxdesc_curr; - u32 cmd_sts; - u32 timeout = 0; - u32 temp; - - /* wait untill rx packet available or timeout */ - do { - if (timeout < PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS) { - timeout++; - } else { - debug("ARMD100 FEC: %s time out...\n", __func__); - return -1; - } - } while (readl(&p_rxdesc_curr->cmd_sts) & BUF_OWNED_BY_DMA); - - if (p_rxdesc_curr->byte_cnt != 0) { - debug("ARMD100 FEC: %s: Received %d byte Packet @ 0x%x" - "(cmd_sts= %08x)\n", __func__, - (u32)p_rxdesc_curr->byte_cnt, - (u32)p_rxdesc_curr->buf_ptr, - (u32)p_rxdesc_curr->cmd_sts); - } - - /* - * In case received a packet without first/last bits on - * OR the error summary bit is on, - * the packets needs to be dropeed. - */ - cmd_sts = readl(&p_rxdesc_curr->cmd_sts); - - if ((cmd_sts & (RX_FIRST_DESC | RX_LAST_DESC)) != - (RX_FIRST_DESC | RX_LAST_DESC)) { - printf("ARMD100 FEC: (%s) Dropping packet spread on" - " multiple descriptors\n", __func__); - } else if (cmd_sts & RX_ERROR) { - printf("ARMD100 FEC: (%s) Dropping packet with errors\n", - __func__); - } else { - /* !!! call higher layer processing */ - debug("ARMD100 FEC: (%s) Sending Received packet to" - " upper layer (net_process_received_packet)\n", __func__); - - /* - * let the upper layer handle the packet, subtract offset - * as two dummy bytes are added in received buffer see - * PORT_CONFIG_EXT register bit TWO_Byte_Stuff_Mode bit. - */ - net_process_received_packet( - p_rxdesc_curr->buf_ptr + RX_BUF_OFFSET, - (int)(p_rxdesc_curr->byte_cnt - RX_BUF_OFFSET)); - } - /* - * free these descriptors and point next in the ring - */ - p_rxdesc_curr->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; - p_rxdesc_curr->buf_size = PKTSIZE_ALIGN; - p_rxdesc_curr->byte_cnt = 0; - - temp = (u32)&darmdfec->p_rxdesc_curr; - writel((u32)p_rxdesc_curr->nxtdesc_p, temp); - - return 0; -} - -int armada100_fec_register(unsigned long base_addr) -{ - struct armdfec_device *darmdfec; - struct eth_device *dev; - - darmdfec = malloc(sizeof(struct armdfec_device)); - if (!darmdfec) - goto error; - - memset(darmdfec, 0, sizeof(struct armdfec_device)); - - darmdfec->htpr = memalign(8, HASH_ADDR_TABLE_SIZE); - if (!darmdfec->htpr) - goto error1; - - darmdfec->p_rxdesc = memalign(PKTALIGN, - ARMDFEC_RXQ_DESC_ALIGNED_SIZE * RINGSZ + 1); - - if (!darmdfec->p_rxdesc) - goto error1; - - darmdfec->p_rxbuf = memalign(PKTALIGN, RINGSZ * PKTSIZE_ALIGN + 1); - if (!darmdfec->p_rxbuf) - goto error1; - - darmdfec->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN); - if (!darmdfec->p_aligned_txbuf) - goto error1; - - darmdfec->p_txdesc = memalign(PKTALIGN, sizeof(struct tx_desc) + 1); - if (!darmdfec->p_txdesc) - goto error1; - - dev = &darmdfec->dev; - /* Assign ARMADA100 Fast Ethernet Controller Base Address */ - darmdfec->regs = (void *)base_addr; - - /* must be less than sizeof(dev->name) */ - strcpy(dev->name, "armd-fec0"); - - dev->init = armdfec_init; - dev->halt = armdfec_halt; - dev->send = armdfec_send; - dev->recv = armdfec_recv; - - eth_register(dev); - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - int retval; - struct mii_dev *mdiodev = mdio_alloc(); - if (!mdiodev) - return -ENOMEM; - strlcpy(mdiodev->name, dev->name, MDIO_NAME_LEN); - mdiodev->read = smi_reg_read; - mdiodev->write = smi_reg_write; - - retval = mdio_register(mdiodev); - if (retval < 0) - return retval; -#endif - return 0; - -error1: - free(darmdfec->p_aligned_txbuf); - free(darmdfec->p_rxbuf); - free(darmdfec->p_rxdesc); - free(darmdfec->htpr); -error: - free(darmdfec); - printf("AMD100 FEC: (%s) Failed to allocate memory\n", __func__); - return -1; -} diff --git a/drivers/net/armada100_fec.h b/drivers/net/armada100_fec.h deleted file mode 100644 index e6f286cfd387..000000000000 --- a/drivers/net/armada100_fec.h +++ /dev/null @@ -1,208 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2011 - * eInfochips Ltd. <www.einfochips.com> - * Written-by: Ajay Bhargav contact@8051projects.net - * - * (C) Copyright 2010 - * Marvell Semiconductor <www.marvell.com> - * Contributor: Mahavir Jain mjain@marvell.com - */ - -#ifndef __ARMADA100_FEC_H__ -#define __ARMADA100_FEC_H__ - -#define PORT_NUM 0x0 - -/* RX & TX descriptor command */ -#define BUF_OWNED_BY_DMA (1<<31) - -/* RX descriptor status */ -#define RX_EN_INT (1<<23) -#define RX_FIRST_DESC (1<<17) -#define RX_LAST_DESC (1<<16) -#define RX_ERROR (1<<15) - -/* TX descriptor command */ -#define TX_EN_INT (1<<23) -#define TX_GEN_CRC (1<<22) -#define TX_ZERO_PADDING (1<<18) -#define TX_FIRST_DESC (1<<17) -#define TX_LAST_DESC (1<<16) -#define TX_ERROR (1<<15) - -/* smi register */ -#define SMI_BUSY (1<<28) /* 0 - Write, 1 - Read */ -#define SMI_R_VALID (1<<27) /* 0 - Write, 1 - Read */ -#define SMI_OP_W (0<<26) /* Write operation */ -#define SMI_OP_R (1<<26) /* Read operation */ - -#define HASH_ADD 0 -#define HASH_DELETE 1 -#define HASH_ADDR_TABLE_SIZE 0x4000 /* 16K (1/2K address - PCR_HS == 1) */ -#define HOP_NUMBER 12 - -#define PHY_WAIT_ITERATIONS 1000 /* 1000 iterations * 10uS = 10mS max */ -#define PHY_WAIT_MICRO_SECONDS 10 - -#define ETH_HW_IP_ALIGN 2 /* hw aligns IP header */ -#define ETH_EXTRA_HEADER (6+6+2+4) - /* dest+src addr+protocol id+crc */ -#define MAX_PKT_SIZE 1536 - - -/* Bit definitions of the SDMA Config Reg */ -#define SDCR_BSZ_OFF 12 -#define SDCR_BSZ8 (3<<SDCR_BSZ_OFF) -#define SDCR_BSZ4 (2<<SDCR_BSZ_OFF) -#define SDCR_BSZ2 (1<<SDCR_BSZ_OFF) -#define SDCR_BSZ1 (0<<SDCR_BSZ_OFF) -#define SDCR_BLMR (1<<6) -#define SDCR_BLMT (1<<7) -#define SDCR_RIFB (1<<9) -#define SDCR_RC_OFF 2 -#define SDCR_RC_MAX_RETRANS (0xf << SDCR_RC_OFF) - -/* SDMA_CMD */ -#define SDMA_CMD_AT (1<<31) -#define SDMA_CMD_TXDL (1<<24) -#define SDMA_CMD_TXDH (1<<23) -#define SDMA_CMD_AR (1<<15) -#define SDMA_CMD_ERD (1<<7) - - -/* Bit definitions of the Port Config Reg */ -#define PCR_HS (1<<12) -#define PCR_EN (1<<7) -#define PCR_PM (1<<0) - -/* Bit definitions of the Port Config Extend Reg */ -#define PCXR_2BSM (1<<28) -#define PCXR_DSCP_EN (1<<21) -#define PCXR_MFL_1518 (0<<14) -#define PCXR_MFL_1536 (1<<14) -#define PCXR_MFL_2048 (2<<14) -#define PCXR_MFL_64K (3<<14) -#define PCXR_FLP (1<<11) -#define PCXR_PRIO_TX_OFF 3 -#define PCXR_TX_HIGH_PRI (7<<PCXR_PRIO_TX_OFF) - -/* - * * Bit definitions of the Interrupt Cause Reg - * * and Interrupt MASK Reg is the same - * */ -#define ICR_RXBUF (1<<0) -#define ICR_TXBUF_H (1<<2) -#define ICR_TXBUF_L (1<<3) -#define ICR_TXEND_H (1<<6) -#define ICR_TXEND_L (1<<7) -#define ICR_RXERR (1<<8) -#define ICR_TXERR_H (1<<10) -#define ICR_TXERR_L (1<<11) -#define ICR_TX_UDR (1<<13) -#define ICR_MII_CH (1<<28) - -#define ALL_INTS (ICR_TXBUF_H | ICR_TXBUF_L | ICR_TX_UDR |\ - ICR_TXERR_H | ICR_TXERR_L |\ - ICR_TXEND_H | ICR_TXEND_L |\ - ICR_RXBUF | ICR_RXERR | ICR_MII_CH) - -#define PHY_MASK 0x0000001f - -#define to_darmdfec(_kd) container_of(_kd, struct armdfec_device, dev) -/* Size of a Tx/Rx descriptor used in chain list data structure */ -#define ARMDFEC_RXQ_DESC_ALIGNED_SIZE \ - (((sizeof(struct rx_desc) / PKTALIGN) + 1) * PKTALIGN) - -#define RX_BUF_OFFSET 0x2 -#define RXQ 0x0 /* RX Queue 0 */ -#define TXQ 0x1 /* TX Queue 1 */ - -struct addr_table_entry_t { - u32 lo; - u32 hi; -}; - -/* Bit fields of a Hash Table Entry */ -enum hash_table_entry { - HTEVALID = 1, - HTESKIP = 2, - HTERD = 4, - HTERDBIT = 2 -}; - -struct tx_desc { - u32 cmd_sts; /* Command/status field */ - u16 reserved; - u16 byte_cnt; /* buffer byte count */ - u8 *buf_ptr; /* pointer to buffer for this descriptor */ - struct tx_desc *nextdesc_p; /* Pointer to next descriptor */ -}; - -struct rx_desc { - u32 cmd_sts; /* Descriptor command status */ - u16 byte_cnt; /* Descriptor buffer byte count */ - u16 buf_size; /* Buffer size */ - u8 *buf_ptr; /* Descriptor buffer pointer */ - struct rx_desc *nxtdesc_p; /* Next descriptor pointer */ -}; - -/* - * Armada100 Fast Ethernet controller Registers - * Refer Datasheet Appendix A.22 - */ -struct armdfec_reg { - u32 phyadr; /* PHY Address */ - u32 pad1[3]; - u32 smi; /* SMI */ - u32 pad2[0xFB]; - u32 pconf; /* Port configuration */ - u32 pad3; - u32 pconf_ext; /* Port configuration extend */ - u32 pad4; - u32 pcmd; /* Port Command */ - u32 pad5; - u32 pstatus; /* Port Status */ - u32 pad6; - u32 spar; /* Serial Parameters */ - u32 pad7; - u32 htpr; /* Hash table pointer */ - u32 pad8; - u32 fcsal; /* Flow control source address low */ - u32 pad9; - u32 fcsah; /* Flow control source address high */ - u32 pad10; - u32 sdma_conf; /* SDMA configuration */ - u32 pad11; - u32 sdma_cmd; /* SDMA command */ - u32 pad12; - u32 ic; /* Interrupt cause */ - u32 iwc; /* Interrupt write to clear */ - u32 im; /* Interrupt mask */ - u32 pad13; - u32 *eth_idscpp[4]; /* Eth0 IP Differentiated Services Code - Point to Priority 0 Low */ - u32 eth_vlan_p; /* Eth0 VLAN Priority Tag to Priority */ - u32 pad14[3]; - struct rx_desc *rxfdp[4]; /* Ethernet First Rx Descriptor - Pointer */ - u32 pad15[4]; - struct rx_desc *rxcdp[4]; /* Ethernet Current Rx Descriptor - Pointer */ - u32 pad16[0x0C]; - struct tx_desc *txcdp[2]; /* Ethernet Current Tx Descriptor - Pointer */ -}; - -struct armdfec_device { - struct eth_device dev; - struct armdfec_reg *regs; - struct tx_desc *p_txdesc; - struct rx_desc *p_rxdesc; - struct rx_desc *p_rxdesc_curr; - u8 *p_rxbuf; - u8 *p_aligned_txbuf; - u8 *htpr; /* hash pointer */ -}; - -#endif /* __ARMADA100_FEC_H__ */
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/ax88180.c | 755 ------------------------------------------ drivers/net/ax88180.h | 396 ---------------------- 3 files changed, 1152 deletions(-) delete mode 100644 drivers/net/ax88180.c delete mode 100644 drivers/net/ax88180.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index b57149b33994..1d753bb7c202 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -18,7 +18,6 @@ obj-$(CONFIG_CORTINA_NI_ENET) += cortina_ni.o obj-$(CONFIG_CS8900) += cs8900.o obj-$(CONFIG_DM_ETH_PHY) += eth-phy-uclass.o obj-$(CONFIG_DNET) += dnet.o -obj-$(CONFIG_DRIVER_AX88180) += ax88180.o obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o obj-$(CONFIG_DSA_SANDBOX) += dsa_sandbox.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o diff --git a/drivers/net/ax88180.c b/drivers/net/ax88180.c deleted file mode 100644 index 402bcdb63ed7..000000000000 --- a/drivers/net/ax88180.c +++ /dev/null @@ -1,755 +0,0 @@ -/* - * ax88180: ASIX AX88180 Non-PCI Gigabit Ethernet u-boot driver - * - * This program is free software; you can distribute it and/or modify - * it under the terms of the GNU General Public License (Version 2) as - * published by the Free Software Foundation. - * This program is distributed in the hope it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. - * See the GNU General Public License for more details. - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place - Suite 330, Boston MA 02111-1307, - * USA. - */ - -/* - * ======================================================================== - * ASIX AX88180 Non-PCI 16/32-bit Gigabit Ethernet Linux Driver - * - * The AX88180 Ethernet controller is a high performance and highly - * integrated local CPU bus Ethernet controller with embedded 40K bytes - * SRAM and supports both 16-bit and 32-bit SRAM-Like interfaces for any - * embedded systems. - * The AX88180 is a single chip 10/100/1000Mbps Gigabit Ethernet - * controller that supports both MII and RGMII interfaces and is - * compliant to IEEE 802.3, IEEE 802.3u and IEEE 802.3z standards. - * - * Please visit ASIX's web site (http://www.asix.com.tw) for more - * details. - * - * Module Name : ax88180.c - * Date : 2008-07-07 - * History - * 09/06/2006 : New release for AX88180 US2 chip. - * 07/07/2008 : Fix up the coding style and using inline functions - * instead of macros - * ======================================================================== - */ -#include <common.h> -#include <command.h> -#include <log.h> -#include <net.h> -#include <malloc.h> -#include <linux/delay.h> -#include <linux/mii.h> -#include "ax88180.h" - -/* - * =========================================================================== - * Local SubProgram Declaration - * =========================================================================== - */ -static void ax88180_rx_handler (struct eth_device *dev); -static int ax88180_phy_initial (struct eth_device *dev); -static void ax88180_media_config (struct eth_device *dev); -static unsigned long get_CicadaPHY_media_mode (struct eth_device *dev); -static unsigned long get_MarvellPHY_media_mode (struct eth_device *dev); -static unsigned short ax88180_mdio_read (struct eth_device *dev, - unsigned long regaddr); -static void ax88180_mdio_write (struct eth_device *dev, - unsigned long regaddr, unsigned short regdata); - -/* - * =========================================================================== - * Local SubProgram Bodies - * =========================================================================== - */ -static int ax88180_mdio_check_complete (struct eth_device *dev) -{ - int us_cnt = 10000; - unsigned short tmpval; - - /* MDIO read/write should not take more than 10 ms */ - while (--us_cnt) { - tmpval = INW (dev, MDIOCTRL); - if (((tmpval & READ_PHY) == 0) && ((tmpval & WRITE_PHY) == 0)) - break; - } - - return us_cnt; -} - -static unsigned short -ax88180_mdio_read (struct eth_device *dev, unsigned long regaddr) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned long tmpval = 0; - - OUTW (dev, (READ_PHY | (regaddr << 8) | priv->PhyAddr), MDIOCTRL); - - if (ax88180_mdio_check_complete (dev)) - tmpval = INW (dev, MDIODP); - else - printf ("Failed to read PHY register!\n"); - - return (unsigned short)(tmpval & 0xFFFF); -} - -static void -ax88180_mdio_write (struct eth_device *dev, unsigned long regaddr, - unsigned short regdata) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - - OUTW (dev, regdata, MDIODP); - - OUTW (dev, (WRITE_PHY | (regaddr << 8) | priv->PhyAddr), MDIOCTRL); - - if (!ax88180_mdio_check_complete (dev)) - printf ("Failed to write PHY register!\n"); -} - -static int ax88180_phy_reset (struct eth_device *dev) -{ - unsigned short delay_cnt = 500; - - ax88180_mdio_write (dev, MII_BMCR, (BMCR_RESET | BMCR_ANENABLE)); - - /* Wait for the reset to complete, or time out (500 ms) */ - while (ax88180_mdio_read (dev, MII_BMCR) & BMCR_RESET) { - udelay(1000); - if (--delay_cnt == 0) { - printf ("Failed to reset PHY!\n"); - return -1; - } - } - - return 0; -} - -static void ax88180_mac_reset (struct eth_device *dev) -{ - unsigned long tmpval; - unsigned char i; - - struct { - unsigned short offset, value; - } program_seq[] = { - { - MISC, MISC_NORMAL}, { - RXINDICATOR, DEFAULT_RXINDICATOR}, { - TXCMD, DEFAULT_TXCMD}, { - TXBS, DEFAULT_TXBS}, { - TXDES0, DEFAULT_TXDES0}, { - TXDES1, DEFAULT_TXDES1}, { - TXDES2, DEFAULT_TXDES2}, { - TXDES3, DEFAULT_TXDES3}, { - TXCFG, DEFAULT_TXCFG}, { - MACCFG2, DEFAULT_MACCFG2}, { - MACCFG3, DEFAULT_MACCFG3}, { - TXLEN, DEFAULT_TXLEN}, { - RXBTHD0, DEFAULT_RXBTHD0}, { - RXBTHD1, DEFAULT_RXBTHD1}, { - RXFULTHD, DEFAULT_RXFULTHD}, { - DOGTHD0, DEFAULT_DOGTHD0}, { - DOGTHD1, DEFAULT_DOGTHD1},}; - - OUTW (dev, MISC_RESET_MAC, MISC); - tmpval = INW (dev, MISC); - - for (i = 0; i < ARRAY_SIZE(program_seq); i++) - OUTW (dev, program_seq[i].value, program_seq[i].offset); -} - -static int ax88180_poll_tx_complete (struct eth_device *dev) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned long tmpval, txbs_txdp; - int TimeOutCnt = 10000; - - txbs_txdp = 1 << priv->NextTxDesc; - - while (TimeOutCnt--) { - - tmpval = INW (dev, TXBS); - - if ((tmpval & txbs_txdp) == 0) - break; - - udelay(100); - } - - if (TimeOutCnt) - return 0; - else - return -TimeOutCnt; -} - -static void ax88180_rx_handler (struct eth_device *dev) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned long data_size; - unsigned short rxcurt_ptr, rxbound_ptr, next_ptr; - int i; -#if defined (CONFIG_DRIVER_AX88180_16BIT) - unsigned short *rxdata = (unsigned short *)net_rx_packets[0]; -#else - unsigned long *rxdata = (unsigned long *)net_rx_packets[0]; -#endif - unsigned short count; - - rxcurt_ptr = INW (dev, RXCURT); - rxbound_ptr = INW (dev, RXBOUND); - next_ptr = (rxbound_ptr + 1) & RX_PAGE_NUM_MASK; - - debug ("ax88180: RX original RXBOUND=0x%04x," - " RXCURT=0x%04x\n", rxbound_ptr, rxcurt_ptr); - - while (next_ptr != rxcurt_ptr) { - - OUTW (dev, RX_START_READ, RXINDICATOR); - - data_size = READ_RXBUF (dev) & 0xFFFF; - - if ((data_size == 0) || (data_size > MAX_RX_SIZE)) { - - OUTW (dev, RX_STOP_READ, RXINDICATOR); - - ax88180_mac_reset (dev); - printf ("ax88180: Invalid Rx packet length!" - " (len=0x%04lx)\n", data_size); - - debug ("ax88180: RX RXBOUND=0x%04x," - "RXCURT=0x%04x\n", rxbound_ptr, rxcurt_ptr); - return; - } - - rxbound_ptr += (((data_size + 0xF) & 0xFFF0) >> 4) + 1; - rxbound_ptr &= RX_PAGE_NUM_MASK; - - /* Comput access times */ - count = (data_size + priv->PadSize) >> priv->BusWidth; - - for (i = 0; i < count; i++) { - *(rxdata + i) = READ_RXBUF (dev); - } - - OUTW (dev, RX_STOP_READ, RXINDICATOR); - - /* Pass the packet up to the protocol layers. */ - net_process_received_packet(net_rx_packets[0], data_size); - - OUTW (dev, rxbound_ptr, RXBOUND); - - rxcurt_ptr = INW (dev, RXCURT); - rxbound_ptr = INW (dev, RXBOUND); - next_ptr = (rxbound_ptr + 1) & RX_PAGE_NUM_MASK; - - debug ("ax88180: RX updated RXBOUND=0x%04x," - "RXCURT=0x%04x\n", rxbound_ptr, rxcurt_ptr); - } - - return; -} - -static int ax88180_phy_initial (struct eth_device *dev) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned long tmp_regval; - unsigned short phyaddr; - - /* Search for first avaliable PHY chipset */ -#ifdef CONFIG_PHY_ADDR - phyaddr = CONFIG_PHY_ADDR; -#else - for (phyaddr = 0; phyaddr < 32; ++phyaddr) -#endif - { - priv->PhyAddr = phyaddr; - priv->PhyID0 = ax88180_mdio_read(dev, MII_PHYSID1); - priv->PhyID1 = ax88180_mdio_read(dev, MII_PHYSID2); - - switch (priv->PhyID0) { - case MARVELL_ALASKA_PHYSID0: - debug("ax88180: Found Marvell Alaska PHY family." - " (PHY Addr=0x%x)\n", priv->PhyAddr); - - switch (priv->PhyID1) { - case MARVELL_88E1118_PHYSID1: - ax88180_mdio_write(dev, M88E1118_PAGE_SEL, 2); - ax88180_mdio_write(dev, M88E1118_CR, - M88E1118_CR_DEFAULT); - ax88180_mdio_write(dev, M88E1118_PAGE_SEL, 3); - ax88180_mdio_write(dev, M88E1118_LEDCTL, - M88E1118_LEDCTL_DEFAULT); - ax88180_mdio_write(dev, M88E1118_LEDMIX, - M88E1118_LEDMIX_LED050 | M88E1118_LEDMIX_LED150 | 0x15); - ax88180_mdio_write(dev, M88E1118_PAGE_SEL, 0); - default: /* Default to 88E1111 Phy */ - tmp_regval = ax88180_mdio_read(dev, M88E1111_EXT_SSR); - if ((tmp_regval & HWCFG_MODE_MASK) != RGMII_COPPER_MODE) - ax88180_mdio_write(dev, M88E1111_EXT_SCR, - DEFAULT_EXT_SCR); - } - - if (ax88180_phy_reset(dev) < 0) - return 0; - ax88180_mdio_write(dev, M88_IER, LINK_CHANGE_INT); - - return 1; - - case CICADA_CIS8201_PHYSID0: - debug("ax88180: Found CICADA CIS8201 PHY" - " chipset. (PHY Addr=0x%x)\n", priv->PhyAddr); - - ax88180_mdio_write(dev, CIS_IMR, - (CIS_INT_ENABLE | LINK_CHANGE_INT)); - - /* Set CIS_SMI_PRIORITY bit before force the media mode */ - tmp_regval = ax88180_mdio_read(dev, CIS_AUX_CTRL_STATUS); - tmp_regval &= ~CIS_SMI_PRIORITY; - ax88180_mdio_write(dev, CIS_AUX_CTRL_STATUS, tmp_regval); - - return 1; - - case 0xffff: - /* No PHY at this addr */ - break; - - default: - printf("ax88180: Unknown PHY chipset %#x at addr %#x\n", - priv->PhyID0, priv->PhyAddr); - break; - } - } - - printf("ax88180: Unknown PHY chipset!!\n"); - return 0; -} - -static void ax88180_media_config (struct eth_device *dev) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned long bmcr_val, bmsr_val; - unsigned long rxcfg_val, maccfg0_val, maccfg1_val; - unsigned long RealMediaMode; - int i; - - /* Waiting 2 seconds for PHY link stable */ - for (i = 0; i < 20000; i++) { - bmsr_val = ax88180_mdio_read (dev, MII_BMSR); - if (bmsr_val & BMSR_LSTATUS) { - break; - } - udelay(100); - } - - bmsr_val = ax88180_mdio_read (dev, MII_BMSR); - debug ("ax88180: BMSR=0x%04x\n", (unsigned int)bmsr_val); - - if (bmsr_val & BMSR_LSTATUS) { - bmcr_val = ax88180_mdio_read (dev, MII_BMCR); - - if (bmcr_val & BMCR_ANENABLE) { - - /* - * Waiting for Auto-negotiation completion, this may - * take up to 5 seconds. - */ - debug ("ax88180: Auto-negotiation is " - "enabled. Waiting for NWay completion..\n"); - for (i = 0; i < 50000; i++) { - bmsr_val = ax88180_mdio_read (dev, MII_BMSR); - if (bmsr_val & BMSR_ANEGCOMPLETE) { - break; - } - udelay(100); - } - } else - debug ("ax88180: Auto-negotiation is disabled.\n"); - - debug ("ax88180: BMCR=0x%04x, BMSR=0x%04x\n", - (unsigned int)bmcr_val, (unsigned int)bmsr_val); - - /* Get real media mode here */ - switch (priv->PhyID0) { - case MARVELL_ALASKA_PHYSID0: - RealMediaMode = get_MarvellPHY_media_mode(dev); - break; - case CICADA_CIS8201_PHYSID0: - RealMediaMode = get_CicadaPHY_media_mode(dev); - break; - default: - RealMediaMode = MEDIA_1000FULL; - break; - } - - priv->LinkState = INS_LINK_UP; - - switch (RealMediaMode) { - case MEDIA_1000FULL: - debug ("ax88180: 1000Mbps Full-duplex mode.\n"); - rxcfg_val = RXFLOW_ENABLE | DEFAULT_RXCFG; - maccfg0_val = TXFLOW_ENABLE | DEFAULT_MACCFG0; - maccfg1_val = GIGA_MODE_EN | RXFLOW_EN | - FULLDUPLEX | DEFAULT_MACCFG1; - break; - - case MEDIA_1000HALF: - debug ("ax88180: 1000Mbps Half-duplex mode.\n"); - rxcfg_val = DEFAULT_RXCFG; - maccfg0_val = DEFAULT_MACCFG0; - maccfg1_val = GIGA_MODE_EN | DEFAULT_MACCFG1; - break; - - case MEDIA_100FULL: - debug ("ax88180: 100Mbps Full-duplex mode.\n"); - rxcfg_val = RXFLOW_ENABLE | DEFAULT_RXCFG; - maccfg0_val = SPEED100 | TXFLOW_ENABLE - | DEFAULT_MACCFG0; - maccfg1_val = RXFLOW_EN | FULLDUPLEX | DEFAULT_MACCFG1; - break; - - case MEDIA_100HALF: - debug ("ax88180: 100Mbps Half-duplex mode.\n"); - rxcfg_val = DEFAULT_RXCFG; - maccfg0_val = SPEED100 | DEFAULT_MACCFG0; - maccfg1_val = DEFAULT_MACCFG1; - break; - - case MEDIA_10FULL: - debug ("ax88180: 10Mbps Full-duplex mode.\n"); - rxcfg_val = RXFLOW_ENABLE | DEFAULT_RXCFG; - maccfg0_val = TXFLOW_ENABLE | DEFAULT_MACCFG0; - maccfg1_val = RXFLOW_EN | FULLDUPLEX | DEFAULT_MACCFG1; - break; - - case MEDIA_10HALF: - debug ("ax88180: 10Mbps Half-duplex mode.\n"); - rxcfg_val = DEFAULT_RXCFG; - maccfg0_val = DEFAULT_MACCFG0; - maccfg1_val = DEFAULT_MACCFG1; - break; - default: - debug ("ax88180: Unknow media mode.\n"); - rxcfg_val = DEFAULT_RXCFG; - maccfg0_val = DEFAULT_MACCFG0; - maccfg1_val = DEFAULT_MACCFG1; - - priv->LinkState = INS_LINK_DOWN; - break; - } - - } else { - rxcfg_val = DEFAULT_RXCFG; - maccfg0_val = DEFAULT_MACCFG0; - maccfg1_val = DEFAULT_MACCFG1; - - priv->LinkState = INS_LINK_DOWN; - } - - OUTW (dev, rxcfg_val, RXCFG); - OUTW (dev, maccfg0_val, MACCFG0); - OUTW (dev, maccfg1_val, MACCFG1); - - return; -} - -static unsigned long get_MarvellPHY_media_mode (struct eth_device *dev) -{ - unsigned long m88_ssr; - unsigned long MediaMode; - - m88_ssr = ax88180_mdio_read (dev, M88_SSR); - switch (m88_ssr & SSR_MEDIA_MASK) { - case SSR_1000FULL: - MediaMode = MEDIA_1000FULL; - break; - case SSR_1000HALF: - MediaMode = MEDIA_1000HALF; - break; - case SSR_100FULL: - MediaMode = MEDIA_100FULL; - break; - case SSR_100HALF: - MediaMode = MEDIA_100HALF; - break; - case SSR_10FULL: - MediaMode = MEDIA_10FULL; - break; - case SSR_10HALF: - MediaMode = MEDIA_10HALF; - break; - default: - MediaMode = MEDIA_UNKNOWN; - break; - } - - return MediaMode; -} - -static unsigned long get_CicadaPHY_media_mode (struct eth_device *dev) -{ - unsigned long tmp_regval; - unsigned long MediaMode; - - tmp_regval = ax88180_mdio_read (dev, CIS_AUX_CTRL_STATUS); - switch (tmp_regval & CIS_MEDIA_MASK) { - case CIS_1000FULL: - MediaMode = MEDIA_1000FULL; - break; - case CIS_1000HALF: - MediaMode = MEDIA_1000HALF; - break; - case CIS_100FULL: - MediaMode = MEDIA_100FULL; - break; - case CIS_100HALF: - MediaMode = MEDIA_100HALF; - break; - case CIS_10FULL: - MediaMode = MEDIA_10FULL; - break; - case CIS_10HALF: - MediaMode = MEDIA_10HALF; - break; - default: - MediaMode = MEDIA_UNKNOWN; - break; - } - - return MediaMode; -} - -static void ax88180_halt (struct eth_device *dev) -{ - /* Disable AX88180 TX/RX functions */ - OUTW (dev, WAKEMOD, CMD); -} - -static int ax88180_init (struct eth_device *dev, struct bd_info * bd) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned short tmp_regval; - - ax88180_mac_reset (dev); - - /* Disable interrupt */ - OUTW (dev, CLEAR_IMR, IMR); - - /* Disable AX88180 TX/RX functions */ - OUTW (dev, WAKEMOD, CMD); - - /* Fill the MAC address */ - tmp_regval = - dev->enetaddr[0] | (((unsigned short)dev->enetaddr[1]) << 8); - OUTW (dev, tmp_regval, MACID0); - - tmp_regval = - dev->enetaddr[2] | (((unsigned short)dev->enetaddr[3]) << 8); - OUTW (dev, tmp_regval, MACID1); - - tmp_regval = - dev->enetaddr[4] | (((unsigned short)dev->enetaddr[5]) << 8); - OUTW (dev, tmp_regval, MACID2); - - ax88180_media_config (dev); - - OUTW (dev, DEFAULT_RXFILTER, RXFILTER); - - /* Initial variables here */ - priv->FirstTxDesc = TXDP0; - priv->NextTxDesc = TXDP0; - - /* Check if there is any invalid interrupt status and clear it. */ - OUTW (dev, INW (dev, ISR), ISR); - - /* Start AX88180 TX/RX functions */ - OUTW (dev, (RXEN | TXEN | WAKEMOD), CMD); - - return 0; -} - -/* Get a data block via Ethernet */ -static int ax88180_recv (struct eth_device *dev) -{ - unsigned short ISR_Status; - unsigned short tmp_regval; - - /* Read and check interrupt status here. */ - ISR_Status = INW (dev, ISR); - - while (ISR_Status) { - /* Clear the interrupt status */ - OUTW (dev, ISR_Status, ISR); - - debug ("\nax88180: The interrupt status = 0x%04x\n", - ISR_Status); - - if (ISR_Status & ISR_PHY) { - /* Read ISR register once to clear PHY interrupt bit */ - tmp_regval = ax88180_mdio_read (dev, M88_ISR); - ax88180_media_config (dev); - } - - if ((ISR_Status & ISR_RX) || (ISR_Status & ISR_RXBUFFOVR)) { - ax88180_rx_handler (dev); - } - - /* Read and check interrupt status again */ - ISR_Status = INW (dev, ISR); - } - - return 0; -} - -/* Send a data block via Ethernet. */ -static int ax88180_send(struct eth_device *dev, void *packet, int length) -{ - struct ax88180_private *priv = (struct ax88180_private *)dev->priv; - unsigned short TXDES_addr; - unsigned short txcmd_txdp, txbs_txdp; - unsigned short tmp_data; - int i; -#if defined (CONFIG_DRIVER_AX88180_16BIT) - volatile unsigned short *txdata = (volatile unsigned short *)packet; -#else - volatile unsigned long *txdata = (volatile unsigned long *)packet; -#endif - unsigned short count; - - if (priv->LinkState != INS_LINK_UP) { - return 0; - } - - priv->FirstTxDesc = priv->NextTxDesc; - txbs_txdp = 1 << priv->FirstTxDesc; - - debug ("ax88180: TXDP%d is available\n", priv->FirstTxDesc); - - txcmd_txdp = priv->FirstTxDesc << 13; - TXDES_addr = TXDES0 + (priv->FirstTxDesc << 2); - - OUTW (dev, (txcmd_txdp | length | TX_START_WRITE), TXCMD); - - /* Comput access times */ - count = (length + priv->PadSize) >> priv->BusWidth; - - for (i = 0; i < count; i++) { - WRITE_TXBUF (dev, *(txdata + i)); - } - - OUTW (dev, txcmd_txdp | length, TXCMD); - OUTW (dev, txbs_txdp, TXBS); - OUTW (dev, (TXDPx_ENABLE | length), TXDES_addr); - - priv->NextTxDesc = (priv->NextTxDesc + 1) & TXDP_MASK; - - /* - * Check the available transmit descriptor, if we had exhausted all - * transmit descriptor ,then we have to wait for at least one free - * descriptor - */ - txbs_txdp = 1 << priv->NextTxDesc; - tmp_data = INW (dev, TXBS); - - if (tmp_data & txbs_txdp) { - if (ax88180_poll_tx_complete (dev) < 0) { - ax88180_mac_reset (dev); - priv->FirstTxDesc = TXDP0; - priv->NextTxDesc = TXDP0; - printf ("ax88180: Transmit time out occurred!\n"); - } - } - - return 0; -} - -static void ax88180_read_mac_addr (struct eth_device *dev) -{ - unsigned short macid0_val, macid1_val, macid2_val; - unsigned short tmp_regval; - unsigned short i; - - /* Reload MAC address from EEPROM */ - OUTW (dev, RELOAD_EEPROM, PROMCTRL); - - /* Waiting for reload eeprom completion */ - for (i = 0; i < 500; i++) { - tmp_regval = INW (dev, PROMCTRL); - if ((tmp_regval & RELOAD_EEPROM) == 0) - break; - udelay(1000); - } - - /* Get MAC addresses */ - macid0_val = INW (dev, MACID0); - macid1_val = INW (dev, MACID1); - macid2_val = INW (dev, MACID2); - - if (((macid0_val | macid1_val | macid2_val) != 0) && - ((macid0_val & 0x01) == 0)) { - dev->enetaddr[0] = (unsigned char)macid0_val; - dev->enetaddr[1] = (unsigned char)(macid0_val >> 8); - dev->enetaddr[2] = (unsigned char)macid1_val; - dev->enetaddr[3] = (unsigned char)(macid1_val >> 8); - dev->enetaddr[4] = (unsigned char)macid2_val; - dev->enetaddr[5] = (unsigned char)(macid2_val >> 8); - } -} - -/* Exported SubProgram Bodies */ -int ax88180_initialize (struct bd_info * bis) -{ - struct eth_device *dev; - struct ax88180_private *priv; - - dev = (struct eth_device *)malloc (sizeof *dev); - - if (NULL == dev) - return 0; - - memset (dev, 0, sizeof *dev); - - priv = (struct ax88180_private *)malloc (sizeof (*priv)); - - if (NULL == priv) - return 0; - - memset (priv, 0, sizeof *priv); - - strcpy(dev->name, "ax88180"); - dev->iobase = AX88180_BASE; - dev->priv = priv; - dev->init = ax88180_init; - dev->halt = ax88180_halt; - dev->send = ax88180_send; - dev->recv = ax88180_recv; - - priv->BusWidth = BUS_WIDTH_32; - priv->PadSize = 3; -#if defined (CONFIG_DRIVER_AX88180_16BIT) - OUTW (dev, (START_BASE >> 8), BASE); - OUTW (dev, DECODE_EN, DECODE); - - priv->BusWidth = BUS_WIDTH_16; - priv->PadSize = 1; -#endif - - ax88180_mac_reset (dev); - - /* Disable interrupt */ - OUTW (dev, CLEAR_IMR, IMR); - - /* Disable AX88180 TX/RX functions */ - OUTW (dev, WAKEMOD, CMD); - - ax88180_read_mac_addr (dev); - - eth_register (dev); - - return ax88180_phy_initial (dev); - -} diff --git a/drivers/net/ax88180.h b/drivers/net/ax88180.h deleted file mode 100644 index daf18e015709..000000000000 --- a/drivers/net/ax88180.h +++ /dev/null @@ -1,396 +0,0 @@ -/* ax88180.h: ASIX AX88180 Non-PCI Gigabit Ethernet u-boot driver */ -/* - * - * This program is free software; you can distribute it and/or modify it - * under the terms of the GNU General Public License (Version 2) as - * published by the Free Software Foundation. - * - * This program is distributed in the hope it will be useful, but WITHOUT - * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or - * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License - * for more details. - * - * You should have received a copy of the GNU General Public License along - * with this program; if not, write to the Free Software Foundation, Inc., - * 59 Temple Place - Suite 330, Boston MA 02111-1307, USA. - * - */ - -#ifndef _AX88180_H_ -#define _AX88180_H_ - -#include <asm/io.h> -#include <asm/types.h> -#include <config.h> - -typedef enum _ax88180_link_state { - INS_LINK_DOWN, - INS_LINK_UP, - INS_LINK_UNKNOWN -} ax88180_link_state; - -struct ax88180_private { - unsigned char BusWidth; - unsigned char PadSize; - unsigned short PhyAddr; - unsigned short PhyID0; - unsigned short PhyID1; - unsigned short FirstTxDesc; - unsigned short NextTxDesc; - ax88180_link_state LinkState; -}; - -#define BUS_WIDTH_16 1 -#define BUS_WIDTH_32 2 - -#define ENABLE_JUMBO 1 -#define DISABLE_JUMBO 0 - -#define ENABLE_BURST 1 -#define DISABLE_BURST 0 - -#define NORMAL_RX_MODE 0 -#define RX_LOOPBACK_MODE 1 -#define RX_INIFINIT_LOOP_MODE 2 -#define TX_INIFINIT_LOOP_MODE 3 - -#define DEFAULT_ETH_MTU 1500 - -/* Jumbo packet size 4086 bytes included 4 bytes CRC*/ -#define MAX_JUMBO_MTU 4072 - -/* Max Tx Jumbo size 4086 bytes included 4 bytes CRC */ -#define MAX_TX_JUMBO_SIZE 4086 - -/* Max Rx Jumbo size is 15K Bytes */ -#define MAX_RX_SIZE 0x3C00 - -#define MARVELL_ALASKA_PHYSID0 0x141 -#define MARVELL_88E1118_PHYSID1 0xE40 - -#define CICADA_CIS8201_PHYSID0 0x000F - -#define MEDIA_AUTO 0 -#define MEDIA_1000FULL 1 -#define MEDIA_1000HALF 2 -#define MEDIA_100FULL 3 -#define MEDIA_100HALF 4 -#define MEDIA_10FULL 5 -#define MEDIA_10HALF 6 -#define MEDIA_UNKNOWN 7 - -#define AUTO_MEDIA 0 -#define FORCE_MEDIA 1 - -#define TXDP_MASK 3 -#define TXDP0 0 -#define TXDP1 1 -#define TXDP2 2 -#define TXDP3 3 - -#define CMD_MAP_SIZE 0x100 - -#if defined (CONFIG_DRIVER_AX88180_16BIT) - #define AX88180_MEMORY_SIZE 0x00004000 - #define START_BASE 0x1000 - - #define RX_BUF_SIZE 0x1000 - #define TX_BUF_SIZE 0x0F00 - - #define TX_BASE START_BASE - #define CMD_BASE (TX_BASE + TX_BUF_SIZE) - #define RX_BASE (CMD_BASE + CMD_MAP_SIZE) -#else - #define AX88180_MEMORY_SIZE 0x00010000 - - #define RX_BUF_SIZE 0x8000 - #define TX_BUF_SIZE 0x7C00 - - #define RX_BASE 0x0000 - #define TX_BASE (RX_BASE + RX_BUF_SIZE) - #define CMD_BASE (TX_BASE + TX_BUF_SIZE) -#endif - -/* AX88180 Memory Mapping Definition */ -#define RXBUFFER_START RX_BASE - #define RX_PACKET_LEN_OFFSET 0 - #define RX_PAGE_NUM_MASK 0x7FF /* RX pages 0~7FFh */ -#define TXBUFFER_START TX_BASE - -/* AX88180 MAC Register Definition */ -#define DECODE (0) - #define DECODE_EN 0x00000001 -#define BASE (6) -#define CMD (CMD_BASE + 0x0000) - #define WAKEMOD 0x00000001 - #define TXEN 0x00000100 - #define RXEN 0x00000200 - #define DEFAULT_CMD WAKEMOD -#define IMR (CMD_BASE + 0x0004) - #define IMR_RXBUFFOVR 0x00000001 - #define IMR_WATCHDOG 0x00000002 - #define IMR_TX 0x00000008 - #define IMR_RX 0x00000010 - #define IMR_PHY 0x00000020 - #define CLEAR_IMR 0x00000000 - #define DEFAULT_IMR (IMR_PHY | IMR_RX | IMR_TX |\ - IMR_RXBUFFOVR | IMR_WATCHDOG) -#define ISR (CMD_BASE + 0x0008) - #define ISR_RXBUFFOVR 0x00000001 - #define ISR_WATCHDOG 0x00000002 - #define ISR_TX 0x00000008 - #define ISR_RX 0x00000010 - #define ISR_PHY 0x00000020 -#define TXCFG (CMD_BASE + 0x0010) - #define AUTOPAD_CRC 0x00000050 - #define DEFAULT_TXCFG AUTOPAD_CRC -#define TXCMD (CMD_BASE + 0x0014) - #define TXCMD_TXDP_MASK 0x00006000 - #define TXCMD_TXDP0 0x00000000 - #define TXCMD_TXDP1 0x00002000 - #define TXCMD_TXDP2 0x00004000 - #define TXCMD_TXDP3 0x00006000 - #define TX_START_WRITE 0x00008000 - #define TX_STOP_WRITE 0x00000000 - #define DEFAULT_TXCMD 0x00000000 -#define TXBS (CMD_BASE + 0x0018) - #define TXDP0_USED 0x00000001 - #define TXDP1_USED 0x00000002 - #define TXDP2_USED 0x00000004 - #define TXDP3_USED 0x00000008 - #define DEFAULT_TXBS 0x00000000 -#define TXDES0 (CMD_BASE + 0x0020) - #define TXDPx_ENABLE 0x00008000 - #define TXDPx_LEN_MASK 0x00001FFF - #define DEFAULT_TXDES0 0x00000000 -#define TXDES1 (CMD_BASE + 0x0024) - #define TXDPx_ENABLE 0x00008000 - #define TXDPx_LEN_MASK 0x00001FFF - #define DEFAULT_TXDES1 0x00000000 -#define TXDES2 (CMD_BASE + 0x0028) - #define TXDPx_ENABLE 0x00008000 - #define TXDPx_LEN_MASK 0x00001FFF - #define DEFAULT_TXDES2 0x00000000 -#define TXDES3 (CMD_BASE + 0x002C) - #define TXDPx_ENABLE 0x00008000 - #define TXDPx_LEN_MASK 0x00001FFF - #define DEFAULT_TXDES3 0x00000000 -#define RXCFG (CMD_BASE + 0x0030) - #define RXBUFF_PROTECT 0x00000001 - #define RXTCPCRC_CHECK 0x00000010 - #define RXFLOW_ENABLE 0x00000100 - #define DEFAULT_RXCFG RXBUFF_PROTECT -#define RXCURT (CMD_BASE + 0x0034) - #define DEFAULT_RXCURT 0x00000000 -#define RXBOUND (CMD_BASE + 0x0038) - #define DEFAULT_RXBOUND 0x7FF /* RX pages 0~7FFh */ -#define MACCFG0 (CMD_BASE + 0x0040) - #define MACCFG0_BIT3_0 0x00000007 - #define IPGT_VAL 0x00000150 - #define TXFLOW_ENABLE 0x00001000 - #define SPEED100 0x00008000 - #define DEFAULT_MACCFG0 (IPGT_VAL | MACCFG0_BIT3_0) -#define MACCFG1 (CMD_BASE + 0x0044) - #define RGMII_EN 0x00000002 - #define RXFLOW_EN 0x00000020 - #define FULLDUPLEX 0x00000040 - #define MAX_JUMBO_LEN 0x00000780 - #define RXJUMBO_EN 0x00000800 - #define GIGA_MODE_EN 0x00001000 - #define RXCRC_CHECK 0x00002000 - #define RXPAUSE_DA_CHECK 0x00004000 - - #define JUMBO_LEN_4K 0x00000200 - #define JUMBO_LEN_15K 0x00000780 - #define DEFAULT_MACCFG1 (RXCRC_CHECK | RXPAUSE_DA_CHECK | \ - RGMII_EN) - #define CICADA_DEFAULT_MACCFG1 (RXCRC_CHECK | RXPAUSE_DA_CHECK) -#define MACCFG2 (CMD_BASE + 0x0048) - #define MACCFG2_BIT15_8 0x00000100 - #define JAM_LIMIT_MASK 0x000000FC - #define DEFAULT_JAM_LIMIT 0x00000064 - #define DEFAULT_MACCFG2 MACCFG2_BIT15_8 -#define MACCFG3 (CMD_BASE + 0x004C) - #define IPGR2_VAL 0x0000000E - #define IPGR1_VAL 0x00000600 - #define NOABORT 0x00008000 - #define DEFAULT_MACCFG3 (IPGR1_VAL | IPGR2_VAL) -#define TXPAUT (CMD_BASE + 0x0054) - #define DEFAULT_TXPAUT 0x001FE000 -#define RXBTHD0 (CMD_BASE + 0x0058) - #define DEFAULT_RXBTHD0 0x00000300 -#define RXBTHD1 (CMD_BASE + 0x005C) - #define DEFAULT_RXBTHD1 0x00000600 -#define RXFULTHD (CMD_BASE + 0x0060) - #define DEFAULT_RXFULTHD 0x00000100 -#define MISC (CMD_BASE + 0x0068) - /* Normal operation mode */ - #define MISC_NORMAL 0x00000003 - /* Clear bit 0 to reset MAC */ - #define MISC_RESET_MAC 0x00000002 - /* Clear bit 1 to reset PHY */ - #define MISC_RESET_PHY 0x00000001 - /* Clear bit 0 and 1 to reset MAC and PHY */ - #define MISC_RESET_MAC_PHY 0x00000000 - #define DEFAULT_MISC MISC_NORMAL -#define MACID0 (CMD_BASE + 0x0070) -#define MACID1 (CMD_BASE + 0x0074) -#define MACID2 (CMD_BASE + 0x0078) -#define TXLEN (CMD_BASE + 0x007C) - #define DEFAULT_TXLEN 0x000005FC -#define RXFILTER (CMD_BASE + 0x0080) - #define RX_RXANY 0x00000001 - #define RX_MULTICAST 0x00000002 - #define RX_UNICAST 0x00000004 - #define RX_BROADCAST 0x00000008 - #define RX_MULTI_HASH 0x00000010 - #define DISABLE_RXFILTER 0x00000000 - #define DEFAULT_RXFILTER (RX_BROADCAST + RX_UNICAST) -#define MDIOCTRL (CMD_BASE + 0x0084) - #define PHY_ADDR_MASK 0x0000001F - #define REG_ADDR_MASK 0x00001F00 - #define READ_PHY 0x00004000 - #define WRITE_PHY 0x00008000 -#define MDIODP (CMD_BASE + 0x0088) -#define GPIOCTRL (CMD_BASE + 0x008C) -#define RXINDICATOR (CMD_BASE + 0x0090) - #define RX_START_READ 0x00000001 - #define RX_STOP_READ 0x00000000 - #define DEFAULT_RXINDICATOR RX_STOP_READ -#define TXST (CMD_BASE + 0x0094) -#define MDCCLKPAT (CMD_BASE + 0x00A0) -#define RXIPCRCCNT (CMD_BASE + 0x00A4) -#define RXCRCCNT (CMD_BASE + 0x00A8) -#define TXFAILCNT (CMD_BASE + 0x00AC) -#define PROMDP (CMD_BASE + 0x00B0) -#define PROMCTRL (CMD_BASE + 0x00B4) - #define RELOAD_EEPROM 0x00000200 -#define MAXRXLEN (CMD_BASE + 0x00B8) -#define HASHTAB0 (CMD_BASE + 0x00C0) -#define HASHTAB1 (CMD_BASE + 0x00C4) -#define HASHTAB2 (CMD_BASE + 0x00C8) -#define HASHTAB3 (CMD_BASE + 0x00CC) -#define DOGTHD0 (CMD_BASE + 0x00E0) - #define DEFAULT_DOGTHD0 0x0000FFFF -#define DOGTHD1 (CMD_BASE + 0x00E4) - #define START_WATCHDOG_TIMER 0x00008000 - #define DEFAULT_DOGTHD1 0x00000FFF -#define SOFTRST (CMD_BASE + 0x00EC) - #define SOFTRST_NORMAL 0x00000003 - #define SOFTRST_RESET_MAC 0x00000002 - -/* Marvell 88E1111 Gigabit PHY Register Definition */ -#define M88_SSR 0x0011 - #define SSR_SPEED_MASK 0xC000 - #define SSR_SPEED_1000 0x8000 - #define SSR_SPEED_100 0x4000 - #define SSR_SPEED_10 0x0000 - #define SSR_DUPLEX 0x2000 - #define SSR_MEDIA_RESOLVED_OK 0x0800 - - #define SSR_MEDIA_MASK (SSR_SPEED_MASK | SSR_DUPLEX) - #define SSR_1000FULL (SSR_SPEED_1000 | SSR_DUPLEX) - #define SSR_1000HALF SSR_SPEED_1000 - #define SSR_100FULL (SSR_SPEED_100 | SSR_DUPLEX) - #define SSR_100HALF SSR_SPEED_100 - #define SSR_10FULL (SSR_SPEED_10 | SSR_DUPLEX) - #define SSR_10HALF SSR_SPEED_10 -#define M88_IER 0x0012 - #define LINK_CHANGE_INT 0x0400 -#define M88_ISR 0x0013 - #define LINK_CHANGE_STATUS 0x0400 -#define M88E1111_EXT_SCR 0x0014 - #define RGMII_RXCLK_DELAY 0x0080 - #define RGMII_TXCLK_DELAY 0x0002 - #define DEFAULT_EXT_SCR (RGMII_TXCLK_DELAY | RGMII_RXCLK_DELAY) -#define M88E1111_EXT_SSR 0x001B - #define HWCFG_MODE_MASK 0x000F - #define RGMII_COPPER_MODE 0x000B - -/* Marvell 88E1118 Gigabit PHY Register Definition */ -#define M88E1118_CR 0x14 - #define M88E1118_CR_RGMII_RXCLK_DELAY 0x0020 - #define M88E1118_CR_RGMII_TXCLK_DELAY 0x0010 - #define M88E1118_CR_DEFAULT (M88E1118_CR_RGMII_TXCLK_DELAY | \ - M88E1118_CR_RGMII_RXCLK_DELAY) -#define M88E1118_LEDCTL 0x10 /* Reg 16 on page 3 */ - #define M88E1118_LEDCTL_LED2INT 0x200 - #define M88E1118_LEDCTL_LED2BLNK 0x400 - #define M88E1118_LEDCTL_LED0DUALMODE1 0xc - #define M88E1118_LEDCTL_LED0DUALMODE2 0xd - #define M88E1118_LEDCTL_LED0DUALMODE3 0xe - #define M88E1118_LEDCTL_LED0DUALMODE4 0xf - #define M88E1118_LEDCTL_DEFAULT (M88E1118_LEDCTL_LED2BLNK | \ - M88E1118_LEDCTL_LED0DUALMODE4) - -#define M88E1118_LEDMIX 0x11 /* Reg 17 on page 3 */ - #define M88E1118_LEDMIX_LED050 0x4 - #define M88E1118_LEDMIX_LED150 0x8 - -#define M88E1118_PAGE_SEL 0x16 /* Reg page select */ - -/* CICADA CIS8201 Gigabit PHY Register Definition */ -#define CIS_IMR 0x0019 - #define CIS_INT_ENABLE 0x8000 - #define CIS_LINK_CHANGE_INT 0x2000 -#define CIS_ISR 0x001A - #define CIS_INT_PENDING 0x8000 - #define CIS_LINK_CHANGE_STATUS 0x2000 -#define CIS_AUX_CTRL_STATUS 0x001C - #define CIS_AUTONEG_COMPLETE 0x8000 - #define CIS_SPEED_MASK 0x0018 - #define CIS_SPEED_1000 0x0010 - #define CIS_SPEED_100 0x0008 - #define CIS_SPEED_10 0x0000 - #define CIS_DUPLEX 0x0020 - - #define CIS_MEDIA_MASK (CIS_SPEED_MASK | CIS_DUPLEX) - #define CIS_1000FULL (CIS_SPEED_1000 | CIS_DUPLEX) - #define CIS_1000HALF CIS_SPEED_1000 - #define CIS_100FULL (CIS_SPEED_100 | CIS_DUPLEX) - #define CIS_100HALF CIS_SPEED_100 - #define CIS_10FULL (CIS_SPEED_10 | CIS_DUPLEX) - #define CIS_10HALF CIS_SPEED_10 - #define CIS_SMI_PRIORITY 0x0004 - -static inline unsigned short INW (struct eth_device *dev, unsigned long addr) -{ - return le16_to_cpu(readw(addr + (void *)dev->iobase)); -} - -/* - Access RXBUFFER_START/TXBUFFER_START to read RX buffer/write TX buffer -*/ -#if defined (CONFIG_DRIVER_AX88180_16BIT) -static inline void OUTW (struct eth_device *dev, unsigned short command, unsigned long addr) -{ - writew(cpu_to_le16(command), addr + (void *)dev->iobase); -} - -static inline unsigned short READ_RXBUF (struct eth_device *dev) -{ - return le16_to_cpu(readw(RXBUFFER_START + (void *)dev->iobase)); -} - -static inline void WRITE_TXBUF (struct eth_device *dev, unsigned short data) -{ - writew(cpu_to_le16(data), TXBUFFER_START + (void *)dev->iobase); -} -#else -static inline void OUTW (struct eth_device *dev, unsigned short command, unsigned long addr) -{ - writel(cpu_to_le32(command), addr + (void *)dev->iobase); -} - -static inline unsigned long READ_RXBUF (struct eth_device *dev) -{ - return le32_to_cpu(readl(RXBUFFER_START + (void *)dev->iobase)); -} - -static inline void WRITE_TXBUF (struct eth_device *dev, unsigned long data) -{ - writel(cpu_to_le32(data), TXBUFFER_START + (void *)dev->iobase); -} -#endif - -#endif /* _AX88180_H_ */
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/cs8900.c | 320 ------------------------------------------- drivers/net/cs8900.h | 248 --------------------------------- 3 files changed, 569 deletions(-) delete mode 100644 drivers/net/cs8900.c delete mode 100644 drivers/net/cs8900.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1d753bb7c202..967f82c5157e 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -15,7 +15,6 @@ obj-$(CONFIG_BCM_SF2_ETH_GMAC) += bcm-sf2-eth-gmac.o obj-$(CONFIG_BNXT_ETH) += bnxt/ obj-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o obj-$(CONFIG_CORTINA_NI_ENET) += cortina_ni.o -obj-$(CONFIG_CS8900) += cs8900.o obj-$(CONFIG_DM_ETH_PHY) += eth-phy-uclass.o obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o diff --git a/drivers/net/cs8900.c b/drivers/net/cs8900.c deleted file mode 100644 index 9440a91882f9..000000000000 --- a/drivers/net/cs8900.c +++ /dev/null @@ -1,320 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Cirrus Logic CS8900A Ethernet - * - * (C) 2009 Ben Warren , biggerbadderben@gmail.com - * Converted to use CONFIG_NET_MULTI API - * - * (C) 2003 Wolfgang Denk, wd@denx.de - * Extension to synchronize ethaddr environment variable - * against value in EEPROM - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * Copyright (C) 1999 Ben Williamson benw@pobox.com - * - * This program is loaded into SRAM in bootstrap mode, where it waits - * for commands on UART1 to read and write memory, jump to code etc. - * A design goal for this program is to be entirely independent of the - * target board. Anything with a CL-PS7111 or EP7211 should be able to run - * this code in bootstrap mode. All the board specifics can be handled on - * the host. - */ - -#include <common.h> -#include <command.h> -#include <log.h> -#include <asm/io.h> -#include <net.h> -#include <malloc.h> -#include <linux/delay.h> -#include "cs8900.h" - -#undef DEBUG - -/* packet page register access functions */ - -#ifdef CONFIG_CS8900_BUS32 - -#define REG_WRITE(v, a) writel((v),(a)) -#define REG_READ(a) readl((a)) - -/* we don't need 16 bit initialisation on 32 bit bus */ -#define get_reg_init_bus(r,d) get_reg((r),(d)) - -#else - -#define REG_WRITE(v, a) writew((v),(a)) -#define REG_READ(a) readw((a)) - -static u16 get_reg_init_bus(struct eth_device *dev, int regno) -{ - /* force 16 bit busmode */ - struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); - uint8_t volatile * const iob = (uint8_t volatile * const)dev->iobase; - - readb(iob); - readb(iob + 1); - readb(iob); - readb(iob + 1); - readb(iob); - - REG_WRITE(regno, &priv->regs->pptr); - return REG_READ(&priv->regs->pdata); -} -#endif - -static u16 get_reg(struct eth_device *dev, int regno) -{ - struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); - REG_WRITE(regno, &priv->regs->pptr); - return REG_READ(&priv->regs->pdata); -} - - -static void put_reg(struct eth_device *dev, int regno, u16 val) -{ - struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); - REG_WRITE(regno, &priv->regs->pptr); - REG_WRITE(val, &priv->regs->pdata); -} - -static void cs8900_reset(struct eth_device *dev) -{ - int tmo; - u16 us; - - /* reset NIC */ - put_reg(dev, PP_SelfCTL, get_reg(dev, PP_SelfCTL) | PP_SelfCTL_Reset); - - /* wait for 200ms */ - udelay(200000); - /* Wait until the chip is reset */ - - tmo = get_timer(0) + 1 * CONFIG_SYS_HZ; - while ((((us = get_reg_init_bus(dev, PP_SelfSTAT)) & - PP_SelfSTAT_InitD) == 0) && tmo < get_timer(0)) - /*NOP*/; -} - -static void cs8900_reginit(struct eth_device *dev) -{ - /* receive only error free packets addressed to this card */ - put_reg(dev, PP_RxCTL, - PP_RxCTL_IA | PP_RxCTL_Broadcast | PP_RxCTL_RxOK); - /* do not generate any interrupts on receive operations */ - put_reg(dev, PP_RxCFG, 0); - /* do not generate any interrupts on transmit operations */ - put_reg(dev, PP_TxCFG, 0); - /* do not generate any interrupts on buffer operations */ - put_reg(dev, PP_BufCFG, 0); - /* enable transmitter/receiver mode */ - put_reg(dev, PP_LineCTL, PP_LineCTL_Rx | PP_LineCTL_Tx); -} - -void cs8900_get_enetaddr(struct eth_device *dev) -{ - int i; - - /* verify chip id */ - if (get_reg_init_bus(dev, PP_ChipID) != 0x630e) - return; - cs8900_reset(dev); - if ((get_reg(dev, PP_SelfSTAT) & - (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) == - (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) { - - /* Load the MAC from EEPROM */ - for (i = 0; i < 3; i++) { - u32 Addr; - - Addr = get_reg(dev, PP_IA + i * 2); - dev->enetaddr[i * 2] = Addr & 0xFF; - dev->enetaddr[i * 2 + 1] = Addr >> 8; - } - } -} - -void cs8900_halt(struct eth_device *dev) -{ - /* disable transmitter/receiver mode */ - put_reg(dev, PP_LineCTL, 0); - - /* "shutdown" to show ChipID or kernel wouldn't find he cs8900 ... */ - get_reg_init_bus(dev, PP_ChipID); -} - -static int cs8900_init(struct eth_device *dev, struct bd_info * bd) -{ - uchar *enetaddr = dev->enetaddr; - u16 id; - - /* verify chip id */ - id = get_reg_init_bus(dev, PP_ChipID); - if (id != 0x630e) { - printf ("CS8900 Ethernet chip not found: " - "ID=0x%04x instead 0x%04x\n", id, 0x630e); - return 1; - } - - cs8900_reset (dev); - /* set the ethernet address */ - put_reg(dev, PP_IA + 0, enetaddr[0] | (enetaddr[1] << 8)); - put_reg(dev, PP_IA + 2, enetaddr[2] | (enetaddr[3] << 8)); - put_reg(dev, PP_IA + 4, enetaddr[4] | (enetaddr[5] << 8)); - - cs8900_reginit(dev); - return 0; -} - -/* Get a data block via Ethernet */ -static int cs8900_recv(struct eth_device *dev) -{ - int i; - u16 rxlen; - u16 *addr; - u16 status; - - struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); - - status = get_reg(dev, PP_RER); - - if ((status & PP_RER_RxOK) == 0) - return 0; - - status = REG_READ(&priv->regs->rtdata); - rxlen = REG_READ(&priv->regs->rtdata); - - if (rxlen > PKTSIZE_ALIGN + PKTALIGN) - debug("packet too big!\n"); - for (addr = (u16 *)net_rx_packets[0], i = rxlen >> 1; i > 0; i--) - *addr++ = REG_READ(&priv->regs->rtdata); - if (rxlen & 1) - *addr++ = REG_READ(&priv->regs->rtdata); - - /* Pass the packet up to the protocol layers. */ - net_process_received_packet(net_rx_packets[0], rxlen); - return rxlen; -} - -/* Send a data block via Ethernet. */ -static int cs8900_send(struct eth_device *dev, void *packet, int length) -{ - volatile u16 *addr; - int tmo; - u16 s; - struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); - -retry: - /* initiate a transmit sequence */ - REG_WRITE(PP_TxCmd_TxStart_Full, &priv->regs->txcmd); - REG_WRITE(length, &priv->regs->txlen); - - /* Test to see if the chip has allocated memory for the packet */ - if ((get_reg(dev, PP_BusSTAT) & PP_BusSTAT_TxRDY) == 0) { - /* Oops... this should not happen! */ - debug("cs: unable to send packet; retrying...\n"); - for (tmo = get_timer(0) + 5 * CONFIG_SYS_HZ; - get_timer(0) < tmo;) - /*NOP*/; - cs8900_reset(dev); - cs8900_reginit(dev); - goto retry; - } - - /* Write the contents of the packet */ - /* assume even number of bytes */ - for (addr = packet; length > 0; length -= 2) - REG_WRITE(*addr++, &priv->regs->rtdata); - - /* wait for transfer to succeed */ - tmo = get_timer(0) + 5 * CONFIG_SYS_HZ; - while ((s = get_reg(dev, PP_TER) & ~0x1F) == 0) { - if (get_timer(0) >= tmo) - break; - } - - /* nothing */ ; - if((s & (PP_TER_CRS | PP_TER_TxOK)) != PP_TER_TxOK) { - debug("\ntransmission error %#x\n", s); - } - - return 0; -} - -static void cs8900_e2prom_ready(struct eth_device *dev) -{ - while (get_reg(dev, PP_SelfSTAT) & SI_BUSY) - ; -} - -/***********************************************************/ -/* read a 16-bit word out of the EEPROM */ -/***********************************************************/ - -int cs8900_e2prom_read(struct eth_device *dev, - u8 addr, u16 *value) -{ - cs8900_e2prom_ready(dev); - put_reg(dev, PP_EECMD, EEPROM_READ_CMD | addr); - cs8900_e2prom_ready(dev); - *value = get_reg(dev, PP_EEData); - - return 0; -} - - -/***********************************************************/ -/* write a 16-bit word into the EEPROM */ -/***********************************************************/ - -int cs8900_e2prom_write(struct eth_device *dev, u8 addr, u16 value) -{ - cs8900_e2prom_ready(dev); - put_reg(dev, PP_EECMD, EEPROM_WRITE_EN); - cs8900_e2prom_ready(dev); - put_reg(dev, PP_EEData, value); - put_reg(dev, PP_EECMD, EEPROM_WRITE_CMD | addr); - cs8900_e2prom_ready(dev); - put_reg(dev, PP_EECMD, EEPROM_WRITE_DIS); - cs8900_e2prom_ready(dev); - - return 0; -} - -int cs8900_initialize(u8 dev_num, int base_addr) -{ - struct eth_device *dev; - struct cs8900_priv *priv; - - dev = malloc(sizeof(*dev)); - if (!dev) { - return 0; - } - memset(dev, 0, sizeof(*dev)); - - priv = malloc(sizeof(*priv)); - if (!priv) { - free(dev); - return 0; - } - memset(priv, 0, sizeof(*priv)); - priv->regs = (struct cs8900_regs *)base_addr; - - dev->iobase = base_addr; - dev->priv = priv; - dev->init = cs8900_init; - dev->halt = cs8900_halt; - dev->send = cs8900_send; - dev->recv = cs8900_recv; - - /* Load MAC address from EEPROM */ - cs8900_get_enetaddr(dev); - - sprintf(dev->name, "%s-%hu", CS8900_DRIVERNAME, dev_num); - - eth_register(dev); - return 0; -} diff --git a/drivers/net/cs8900.h b/drivers/net/cs8900.h deleted file mode 100644 index 1a566ff7b2ec..000000000000 --- a/drivers/net/cs8900.h +++ /dev/null @@ -1,248 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -#ifndef CS8900_H -#define CS8900_H -/* - * Cirrus Logic CS8900A Ethernet - * - * (C) 2009 Ben Warren , biggerbadderben@gmail.com - * Converted to use CONFIG_NET_MULTI API - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * Copyright (C) 1999 Ben Williamson benw@pobox.com - * - * This program is loaded into SRAM in bootstrap mode, where it waits - * for commands on UART1 to read and write memory, jump to code etc. - * A design goal for this program is to be entirely independent of the - * target board. Anything with a CL-PS7111 or EP7211 should be able to run - * this code in bootstrap mode. All the board specifics can be handled on - * the host. - */ - -#include <asm/types.h> -#include <config.h> - -#define CS8900_DRIVERNAME "CS8900" -/* although the registers are 16 bit, they are 32-bit aligned on the - EDB7111. so we have to read them as 32-bit registers and ignore the - upper 16-bits. i'm not sure if this holds for the EDB7211. */ - -#ifdef CONFIG_CS8900_BUS16 - /* 16 bit aligned registers, 16 bit wide */ - #define CS8900_REG u16 -#elif defined(CONFIG_CS8900_BUS32) - /* 32 bit aligned registers, 16 bit wide (we ignore upper 16 bits) */ - #define CS8900_REG u32 -#else - #error unknown bussize ... -#endif - -struct cs8900_regs { - CS8900_REG rtdata; - CS8900_REG pad0; - CS8900_REG txcmd; - CS8900_REG txlen; - CS8900_REG isq; - CS8900_REG pptr; - CS8900_REG pdata; -}; - -struct cs8900_priv { - struct cs8900_regs *regs; -}; - -#define ISQ_RxEvent 0x04 -#define ISQ_TxEvent 0x08 -#define ISQ_BufEvent 0x0C -#define ISQ_RxMissEvent 0x10 -#define ISQ_TxColEvent 0x12 -#define ISQ_EventMask 0x3F - -/* packet page register offsets */ - -/* bus interface registers */ -#define PP_ChipID 0x0000 /* Chip identifier - must be 0x630E */ -#define PP_ChipRev 0x0002 /* Chip revision, model codes */ - -#define PP_IntReg 0x0022 /* Interrupt configuration */ -#define PP_IntReg_IRQ0 0x0000 /* Use INTR0 pin */ -#define PP_IntReg_IRQ1 0x0001 /* Use INTR1 pin */ -#define PP_IntReg_IRQ2 0x0002 /* Use INTR2 pin */ -#define PP_IntReg_IRQ3 0x0003 /* Use INTR3 pin */ - -/* status and control registers */ - -#define PP_RxCFG 0x0102 /* Receiver configuration */ -#define PP_RxCFG_Skip1 0x0040 /* Skip (i.e. discard) current frame */ -#define PP_RxCFG_Stream 0x0080 /* Enable streaming mode */ -#define PP_RxCFG_RxOK 0x0100 /* RxOK interrupt enable */ -#define PP_RxCFG_RxDMAonly 0x0200 /* Use RxDMA for all frames */ -#define PP_RxCFG_AutoRxDMA 0x0400 /* Select RxDMA automatically */ -#define PP_RxCFG_BufferCRC 0x0800 /* Include CRC characters in frame */ -#define PP_RxCFG_CRC 0x1000 /* Enable interrupt on CRC error */ -#define PP_RxCFG_RUNT 0x2000 /* Enable interrupt on RUNT frames */ -#define PP_RxCFG_EXTRA 0x4000 /* Enable interrupt on frames with extra data */ - -#define PP_RxCTL 0x0104 /* Receiver control */ -#define PP_RxCTL_IAHash 0x0040 /* Accept frames that match hash */ -#define PP_RxCTL_Promiscuous 0x0080 /* Accept any frame */ -#define PP_RxCTL_RxOK 0x0100 /* Accept well formed frames */ -#define PP_RxCTL_Multicast 0x0200 /* Accept multicast frames */ -#define PP_RxCTL_IA 0x0400 /* Accept frame that matches IA */ -#define PP_RxCTL_Broadcast 0x0800 /* Accept broadcast frames */ -#define PP_RxCTL_CRC 0x1000 /* Accept frames with bad CRC */ -#define PP_RxCTL_RUNT 0x2000 /* Accept runt frames */ -#define PP_RxCTL_EXTRA 0x4000 /* Accept frames that are too long */ - -#define PP_TxCFG 0x0106 /* Transmit configuration */ -#define PP_TxCFG_CRS 0x0040 /* Enable interrupt on loss of carrier */ -#define PP_TxCFG_SQE 0x0080 /* Enable interrupt on Signal Quality Error */ -#define PP_TxCFG_TxOK 0x0100 /* Enable interrupt on successful xmits */ -#define PP_TxCFG_Late 0x0200 /* Enable interrupt on "out of window" */ -#define PP_TxCFG_Jabber 0x0400 /* Enable interrupt on jabber detect */ -#define PP_TxCFG_Collision 0x0800 /* Enable interrupt if collision */ -#define PP_TxCFG_16Collisions 0x8000 /* Enable interrupt if > 16 collisions */ - -#define PP_TxCmd 0x0108 /* Transmit command status */ -#define PP_TxCmd_TxStart_5 0x0000 /* Start after 5 bytes in buffer */ -#define PP_TxCmd_TxStart_381 0x0040 /* Start after 381 bytes in buffer */ -#define PP_TxCmd_TxStart_1021 0x0080 /* Start after 1021 bytes in buffer */ -#define PP_TxCmd_TxStart_Full 0x00C0 /* Start after all bytes loaded */ -#define PP_TxCmd_Force 0x0100 /* Discard any pending packets */ -#define PP_TxCmd_OneCollision 0x0200 /* Abort after a single collision */ -#define PP_TxCmd_NoCRC 0x1000 /* Do not add CRC */ -#define PP_TxCmd_NoPad 0x2000 /* Do not pad short packets */ - -#define PP_BufCFG 0x010A /* Buffer configuration */ -#define PP_BufCFG_SWI 0x0040 /* Force interrupt via software */ -#define PP_BufCFG_RxDMA 0x0080 /* Enable interrupt on Rx DMA */ -#define PP_BufCFG_TxRDY 0x0100 /* Enable interrupt when ready for Tx */ -#define PP_BufCFG_TxUE 0x0200 /* Enable interrupt in Tx underrun */ -#define PP_BufCFG_RxMiss 0x0400 /* Enable interrupt on missed Rx packets */ -#define PP_BufCFG_Rx128 0x0800 /* Enable Rx interrupt after 128 bytes */ -#define PP_BufCFG_TxCol 0x1000 /* Enable int on Tx collision ctr overflow */ -#define PP_BufCFG_Miss 0x2000 /* Enable int on Rx miss ctr overflow */ -#define PP_BufCFG_RxDest 0x8000 /* Enable int on Rx dest addr match */ - -#define PP_LineCTL 0x0112 /* Line control */ -#define PP_LineCTL_Rx 0x0040 /* Enable receiver */ -#define PP_LineCTL_Tx 0x0080 /* Enable transmitter */ -#define PP_LineCTL_AUIonly 0x0100 /* AUI interface only */ -#define PP_LineCTL_AutoAUI10BT 0x0200 /* Autodetect AUI or 10BaseT interface */ -#define PP_LineCTL_ModBackoffE 0x0800 /* Enable modified backoff algorithm */ -#define PP_LineCTL_PolarityDis 0x1000 /* Disable Rx polarity autodetect */ -#define PP_LineCTL_2partDefDis 0x2000 /* Disable two-part defferal */ -#define PP_LineCTL_LoRxSquelch 0x4000 /* Reduce receiver squelch threshold */ - -#define PP_SelfCTL 0x0114 /* Chip self control */ -#define PP_SelfCTL_Reset 0x0040 /* Self-clearing reset */ -#define PP_SelfCTL_SWSuspend 0x0100 /* Initiate suspend mode */ -#define PP_SelfCTL_HWSleepE 0x0200 /* Enable SLEEP input */ -#define PP_SelfCTL_HWStandbyE 0x0400 /* Enable standby mode */ -#define PP_SelfCTL_HC0E 0x1000 /* use HCB0 for LINK LED */ -#define PP_SelfCTL_HC1E 0x2000 /* use HCB1 for BSTATUS LED */ -#define PP_SelfCTL_HCB0 0x4000 /* control LINK LED if HC0E set */ -#define PP_SelfCTL_HCB1 0x8000 /* control BSTATUS LED if HC1E set */ - -#define PP_BusCTL 0x0116 /* Bus control */ -#define PP_BusCTL_ResetRxDMA 0x0040 /* Reset RxDMA pointer */ -#define PP_BusCTL_DMAextend 0x0100 /* Extend DMA cycle */ -#define PP_BusCTL_UseSA 0x0200 /* Assert MEMCS16 on address decode */ -#define PP_BusCTL_MemoryE 0x0400 /* Enable memory mode */ -#define PP_BusCTL_DMAburst 0x0800 /* Limit DMA access burst */ -#define PP_BusCTL_IOCHRDYE 0x1000 /* Set IOCHRDY high impedence */ -#define PP_BusCTL_RxDMAsize 0x2000 /* Set DMA buffer size 64KB */ -#define PP_BusCTL_EnableIRQ 0x8000 /* Generate interrupt on interrupt event */ - -#define PP_TestCTL 0x0118 /* Test control */ -#define PP_TestCTL_DisableLT 0x0080 /* Disable link status */ -#define PP_TestCTL_ENDECloop 0x0200 /* Internal loopback */ -#define PP_TestCTL_AUIloop 0x0400 /* AUI loopback */ -#define PP_TestCTL_DisBackoff 0x0800 /* Disable backoff algorithm */ -#define PP_TestCTL_FDX 0x4000 /* Enable full duplex mode */ - -#define PP_ISQ 0x0120 /* Interrupt Status Queue */ - -#define PP_RER 0x0124 /* Receive event */ -#define PP_RER_IAHash 0x0040 /* Frame hash match */ -#define PP_RER_Dribble 0x0080 /* Frame had 1-7 extra bits after last byte */ -#define PP_RER_RxOK 0x0100 /* Frame received with no errors */ -#define PP_RER_Hashed 0x0200 /* Frame address hashed OK */ -#define PP_RER_IA 0x0400 /* Frame address matched IA */ -#define PP_RER_Broadcast 0x0800 /* Broadcast frame */ -#define PP_RER_CRC 0x1000 /* Frame had CRC error */ -#define PP_RER_RUNT 0x2000 /* Runt frame */ -#define PP_RER_EXTRA 0x4000 /* Frame was too long */ - -#define PP_TER 0x0128 /* Transmit event */ -#define PP_TER_CRS 0x0040 /* Carrier lost */ -#define PP_TER_SQE 0x0080 /* Signal Quality Error */ -#define PP_TER_TxOK 0x0100 /* Packet sent without error */ -#define PP_TER_Late 0x0200 /* Out of window */ -#define PP_TER_Jabber 0x0400 /* Stuck transmit? */ -#define PP_TER_NumCollisions 0x7800 /* Number of collisions */ -#define PP_TER_16Collisions 0x8000 /* > 16 collisions */ - -#define PP_BER 0x012C /* Buffer event */ -#define PP_BER_SWint 0x0040 /* Software interrupt */ -#define PP_BER_RxDMAFrame 0x0080 /* Received framed DMAed */ -#define PP_BER_Rdy4Tx 0x0100 /* Ready for transmission */ -#define PP_BER_TxUnderrun 0x0200 /* Transmit underrun */ -#define PP_BER_RxMiss 0x0400 /* Received frame missed */ -#define PP_BER_Rx128 0x0800 /* 128 bytes received */ -#define PP_BER_RxDest 0x8000 /* Received framed passed address filter */ - -#define PP_RxMiss 0x0130 /* Receiver miss counter */ - -#define PP_TxCol 0x0132 /* Transmit collision counter */ - -#define PP_LineSTAT 0x0134 /* Line status */ -#define PP_LineSTAT_LinkOK 0x0080 /* Line is connected and working */ -#define PP_LineSTAT_AUI 0x0100 /* Connected via AUI */ -#define PP_LineSTAT_10BT 0x0200 /* Connected via twisted pair */ -#define PP_LineSTAT_Polarity 0x1000 /* Line polarity OK (10BT only) */ -#define PP_LineSTAT_CRS 0x4000 /* Frame being received */ - -#define PP_SelfSTAT 0x0136 /* Chip self status */ -#define PP_SelfSTAT_33VActive 0x0040 /* supply voltage is 3.3V */ -#define PP_SelfSTAT_InitD 0x0080 /* Chip initialization complete */ -#define PP_SelfSTAT_SIBSY 0x0100 /* EEPROM is busy */ -#define PP_SelfSTAT_EEPROM 0x0200 /* EEPROM present */ -#define PP_SelfSTAT_EEPROM_OK 0x0400 /* EEPROM checks out */ -#define PP_SelfSTAT_ELPresent 0x0800 /* External address latch logic available */ -#define PP_SelfSTAT_EEsize 0x1000 /* Size of EEPROM */ - -#define PP_BusSTAT 0x0138 /* Bus status */ -#define PP_BusSTAT_TxBid 0x0080 /* Tx error */ -#define PP_BusSTAT_TxRDY 0x0100 /* Ready for Tx data */ - -#define PP_TDR 0x013C /* AUI Time Domain Reflectometer */ - -/* initiate transmit registers */ - -#define PP_TxCommand 0x0144 /* Tx Command */ -#define PP_TxLength 0x0146 /* Tx Length */ - - -/* address filter registers */ - -#define PP_LAF 0x0150 /* Logical address filter (6 bytes) */ -#define PP_IA 0x0158 /* Individual address (MAC) */ - -/* EEPROM Kram */ -#define SI_BUSY 0x0100 -#define PP_EECMD 0x0040 /* NVR Interface Command register */ -#define PP_EEData 0x0042 /* NVR Interface Data Register */ -#define EEPROM_WRITE_EN 0x00F0 -#define EEPROM_WRITE_DIS 0x0000 -#define EEPROM_WRITE_CMD 0x0100 -#define EEPROM_READ_CMD 0x0200 -#define EEPROM_ERASE_CMD 0x0300 - -/* Exported functions */ -int cs8900_e2prom_read(struct eth_device *dev, uchar, ushort *); -int cs8900_e2prom_write(struct eth_device *dev, uchar, ushort); - -#endif /* CS8900_H */
On Thu, Mar 31, 2022 at 01:46:46PM -0400, Tom Rini wrote:
This driver is not enabled by any board and not converted to DM_ETH. Remove.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/dnet.c | 395 ------------------------------------------- drivers/net/dnet.h | 166 ------------------ 3 files changed, 562 deletions(-) delete mode 100644 drivers/net/dnet.c delete mode 100644 drivers/net/dnet.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 967f82c5157e..1fcd1b2d0b8d 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -16,7 +16,6 @@ obj-$(CONFIG_BNXT_ETH) += bnxt/ obj-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o obj-$(CONFIG_CORTINA_NI_ENET) += cortina_ni.o obj-$(CONFIG_DM_ETH_PHY) += eth-phy-uclass.o -obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o obj-$(CONFIG_DSA_SANDBOX) += dsa_sandbox.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o diff --git a/drivers/net/dnet.c b/drivers/net/dnet.c deleted file mode 100644 index fbcf15f26801..000000000000 --- a/drivers/net/dnet.c +++ /dev/null @@ -1,395 +0,0 @@ -/* - * Dave Ethernet Controller driver - * - * Copyright (C) 2008 Dave S.r.l. <www.dave.eu> - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#include <common.h> -#include <log.h> -#include <linux/delay.h> - -#ifndef CONFIG_DNET_AUTONEG_TIMEOUT -#define CONFIG_DNET_AUTONEG_TIMEOUT 5000000 /* default value */ -#endif - -#include <net.h> -#include <malloc.h> -#include <linux/mii.h> - -#include <miiphy.h> -#include <asm/io.h> -#include <asm/unaligned.h> - -#include "dnet.h" - -struct dnet_device { - struct dnet_registers *regs; - const struct device *dev; - struct eth_device netdev; - unsigned short phy_addr; -}; - -/* get struct dnet_device from given struct netdev */ -#define to_dnet(_nd) container_of(_nd, struct dnet_device, netdev) - -/* function for reading internal MAC register */ -u16 dnet_readw_mac(struct dnet_device *dnet, u16 reg) -{ - u16 data_read; - - /* issue a read */ - writel(reg, &dnet->regs->MACREG_ADDR); - - /* since a read/write op to the MAC is very slow, - * we must wait before reading the data */ - udelay(1); - - /* read data read from the MAC register */ - data_read = readl(&dnet->regs->MACREG_DATA); - - /* all done */ - return data_read; -} - -/* function for writing internal MAC register */ -void dnet_writew_mac(struct dnet_device *dnet, u16 reg, u16 val) -{ - /* load data to write */ - writel(val, &dnet->regs->MACREG_DATA); - - /* issue a write */ - writel(reg | DNET_INTERNAL_WRITE, &dnet->regs->MACREG_ADDR); - - /* since a read/write op to the MAC is very slow, - * we must wait before exiting */ - udelay(1); -} - -static void dnet_mdio_write(struct dnet_device *dnet, u8 reg, u16 value) -{ - u16 tmp; - - debug(DRIVERNAME "dnet_mdio_write %02x:%02x <- %04x\n", - dnet->phy_addr, reg, value); - - while (!(dnet_readw_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG) & - DNET_INTERNAL_GMII_MNG_CMD_FIN)) - ; - - /* prepare for a write operation */ - tmp = (1 << 13); - - /* only 5 bits allowed for register offset */ - reg &= 0x1f; - - /* prepare reg_value for a write */ - tmp |= (dnet->phy_addr << 8); - tmp |= reg; - - /* write data to write first */ - dnet_writew_mac(dnet, DNET_INTERNAL_GMII_MNG_DAT_REG, value); - - /* write control word */ - dnet_writew_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG, tmp); - - while (!(dnet_readw_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG) & - DNET_INTERNAL_GMII_MNG_CMD_FIN)) - ; -} - -static u16 dnet_mdio_read(struct dnet_device *dnet, u8 reg) -{ - u16 value; - - while (!(dnet_readw_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG) & - DNET_INTERNAL_GMII_MNG_CMD_FIN)) - ; - - /* only 5 bits allowed for register offset*/ - reg &= 0x1f; - - /* prepare reg_value for a read */ - value = (dnet->phy_addr << 8); - value |= reg; - - /* write control word */ - dnet_writew_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG, value); - - /* wait for end of transfer */ - while (!(dnet_readw_mac(dnet, DNET_INTERNAL_GMII_MNG_CTL_REG) & - DNET_INTERNAL_GMII_MNG_CMD_FIN)) - ; - - value = dnet_readw_mac(dnet, DNET_INTERNAL_GMII_MNG_DAT_REG); - - debug(DRIVERNAME "dnet_mdio_read %02x:%02x <- %04x\n", - dnet->phy_addr, reg, value); - - return value; -} - -static int dnet_send(struct eth_device *netdev, void *packet, int length) -{ - struct dnet_device *dnet = to_dnet(netdev); - int i, wrsz; - unsigned int *bufp; - unsigned int tx_cmd; - - debug(DRIVERNAME "[%s] Sending %u bytes\n", __func__, length); - - bufp = (unsigned int *) (((u32)packet) & 0xFFFFFFFC); - wrsz = (u32)length + 3; - wrsz += ((u32)packet) & 0x3; - wrsz >>= 2; - tx_cmd = ((((unsigned int)(packet)) & 0x03) << 16) | (u32)length; - - /* check if there is enough room for the current frame */ - if (wrsz < (DNET_FIFO_SIZE - readl(&dnet->regs->TX_FIFO_WCNT))) { - for (i = 0; i < wrsz; i++) - writel(*bufp++, &dnet->regs->TX_DATA_FIFO); - /* - * inform MAC that a packet's written and ready - * to be shipped out - */ - writel(tx_cmd, &dnet->regs->TX_LEN_FIFO); - } else { - printf(DRIVERNAME "No free space (actual %d, required %d " - "(words))\n", DNET_FIFO_SIZE - - readl(&dnet->regs->TX_FIFO_WCNT), wrsz); - } - - /* No one cares anyway */ - return 0; -} - - -static int dnet_recv(struct eth_device *netdev) -{ - struct dnet_device *dnet = to_dnet(netdev); - unsigned int *data_ptr; - int pkt_len, poll, i; - u32 cmd_word; - - debug("Waiting for pkt (polling)\n"); - poll = 50; - while ((readl(&dnet->regs->RX_FIFO_WCNT) >> 16) == 0) { - udelay(10); /* wait 10 usec */ - if (--poll == 0) - return 0; /* no pkt available */ - } - - cmd_word = readl(&dnet->regs->RX_LEN_FIFO); - pkt_len = cmd_word & 0xFFFF; - - debug("Got pkt with size %d bytes\n", pkt_len); - - if (cmd_word & 0xDF180000) - printf("%s packet receive error %x\n", __func__, cmd_word); - - data_ptr = (unsigned int *)net_rx_packets[0]; - - for (i = 0; i < (pkt_len + 3) >> 2; i++) - *data_ptr++ = readl(&dnet->regs->RX_DATA_FIFO); - - /* ok + 5 ?? */ - net_process_received_packet(net_rx_packets[0], pkt_len + 5); - - return 0; -} - -static void dnet_set_hwaddr(struct eth_device *netdev) -{ - struct dnet_device *dnet = to_dnet(netdev); - u16 tmp; - - tmp = get_unaligned_be16(netdev->enetaddr); - dnet_writew_mac(dnet, DNET_INTERNAL_MAC_ADDR_0_REG, tmp); - tmp = get_unaligned_be16(&netdev->enetaddr[2]); - dnet_writew_mac(dnet, DNET_INTERNAL_MAC_ADDR_1_REG, tmp); - tmp = get_unaligned_be16(&netdev->enetaddr[4]); - dnet_writew_mac(dnet, DNET_INTERNAL_MAC_ADDR_2_REG, tmp); -} - -static void dnet_phy_reset(struct dnet_device *dnet) -{ - struct eth_device *netdev = &dnet->netdev; - int i; - u16 status, adv; - - adv = ADVERTISE_CSMA | ADVERTISE_ALL; - dnet_mdio_write(dnet, MII_ADVERTISE, adv); - printf("%s: Starting autonegotiation...\n", netdev->name); - dnet_mdio_write(dnet, MII_BMCR, (BMCR_ANENABLE - | BMCR_ANRESTART)); - - for (i = 0; i < CONFIG_DNET_AUTONEG_TIMEOUT / 100; i++) { - status = dnet_mdio_read(dnet, MII_BMSR); - if (status & BMSR_ANEGCOMPLETE) - break; - udelay(100); - } - - if (status & BMSR_ANEGCOMPLETE) - printf("%s: Autonegotiation complete\n", netdev->name); - else - printf("%s: Autonegotiation timed out (status=0x%04x)\n", - netdev->name, status); -} - -static int dnet_phy_init(struct dnet_device *dnet) -{ - struct eth_device *netdev = &dnet->netdev; - u16 phy_id, status, adv, lpa; - int media, speed, duplex; - int i; - u32 ctl_reg; - - /* Find a PHY */ - for (i = 0; i < 32; i++) { - dnet->phy_addr = i; - phy_id = dnet_mdio_read(dnet, MII_PHYSID1); - if (phy_id != 0xffff) { - /* ok we found it */ - printf("Found PHY at address %d PHYID (%04x:%04x)\n", - i, phy_id, - dnet_mdio_read(dnet, MII_PHYSID2)); - break; - } - } - - /* Check if the PHY is up to snuff... */ - phy_id = dnet_mdio_read(dnet, MII_PHYSID1); - if (phy_id == 0xffff) { - printf("%s: No PHY present\n", netdev->name); - return -1; - } - - status = dnet_mdio_read(dnet, MII_BMSR); - if (!(status & BMSR_LSTATUS)) { - /* Try to re-negotiate if we don't have link already. */ - dnet_phy_reset(dnet); - - for (i = 0; i < CONFIG_DNET_AUTONEG_TIMEOUT / 100; i++) { - status = dnet_mdio_read(dnet, MII_BMSR); - if (status & BMSR_LSTATUS) - break; - udelay(100); - } - } - - if (!(status & BMSR_LSTATUS)) { - printf("%s: link down (status: 0x%04x)\n", - netdev->name, status); - return -1; - } else { - adv = dnet_mdio_read(dnet, MII_ADVERTISE); - lpa = dnet_mdio_read(dnet, MII_LPA); - media = mii_nway_result(lpa & adv); - speed = (media & (ADVERTISE_100FULL | ADVERTISE_100HALF) - ? 1 : 0); - duplex = (media & ADVERTISE_FULL) ? 1 : 0; - /* 1000BaseT ethernet is not supported */ - printf("%s: link up, %sMbps %s-duplex (lpa: 0x%04x)\n", - netdev->name, - speed ? "100" : "10", - duplex ? "full" : "half", - lpa); - - ctl_reg = dnet_readw_mac(dnet, DNET_INTERNAL_RXTX_CONTROL_REG); - - if (duplex) - ctl_reg &= ~(DNET_INTERNAL_RXTX_CONTROL_ENABLEHALFDUP); - else - ctl_reg |= DNET_INTERNAL_RXTX_CONTROL_ENABLEHALFDUP; - - dnet_writew_mac(dnet, DNET_INTERNAL_RXTX_CONTROL_REG, ctl_reg); - - return 0; - } -} - -static int dnet_init(struct eth_device *netdev, struct bd_info *bd) -{ - struct dnet_device *dnet = to_dnet(netdev); - u32 config; - - /* - * dnet_halt should have been called at some point before now, - * so we'll assume the controller is idle. - */ - - /* set hardware address */ - dnet_set_hwaddr(netdev); - - if (dnet_phy_init(dnet) < 0) - return -1; - - /* flush rx/tx fifos */ - writel(DNET_SYS_CTL_RXFIFOFLUSH | DNET_SYS_CTL_TXFIFOFLUSH, - &dnet->regs->SYS_CTL); - udelay(1000); - writel(0, &dnet->regs->SYS_CTL); - - config = dnet_readw_mac(dnet, DNET_INTERNAL_RXTX_CONTROL_REG); - - config |= DNET_INTERNAL_RXTX_CONTROL_RXPAUSE | - DNET_INTERNAL_RXTX_CONTROL_RXBROADCAST | - DNET_INTERNAL_RXTX_CONTROL_DROPCONTROL | - DNET_INTERNAL_RXTX_CONTROL_DISCFXFCS; - - dnet_writew_mac(dnet, DNET_INTERNAL_RXTX_CONTROL_REG, config); - - /* Enable TX and RX */ - dnet_writew_mac(dnet, DNET_INTERNAL_MODE_REG, - DNET_INTERNAL_MODE_RXEN | DNET_INTERNAL_MODE_TXEN); - - return 0; -} - -static void dnet_halt(struct eth_device *netdev) -{ - struct dnet_device *dnet = to_dnet(netdev); - - /* Disable TX and RX */ - dnet_writew_mac(dnet, DNET_INTERNAL_MODE_REG, 0); -} - -int dnet_eth_initialize(int id, void *regs, unsigned int phy_addr) -{ - struct dnet_device *dnet; - struct eth_device *netdev; - unsigned int dev_capa; - - dnet = malloc(sizeof(struct dnet_device)); - if (!dnet) { - printf("Error: Failed to allocate memory for DNET%d\n", id); - return -1; - } - memset(dnet, 0, sizeof(struct dnet_device)); - - netdev = &dnet->netdev; - - dnet->regs = (struct dnet_registers *)regs; - dnet->phy_addr = phy_addr; - - sprintf(netdev->name, "dnet%d", id); - netdev->init = dnet_init; - netdev->halt = dnet_halt; - netdev->send = dnet_send; - netdev->recv = dnet_recv; - - dev_capa = readl(&dnet->regs->VERCAPS) & 0xFFFF; - debug("%s: has %smdio, %sirq, %sgigabit, %sdma \n", netdev->name, - (dev_capa & DNET_HAS_MDIO) ? "" : "no ", - (dev_capa & DNET_HAS_IRQ) ? "" : "no ", - (dev_capa & DNET_HAS_GIGABIT) ? "" : "no ", - (dev_capa & DNET_HAS_DMA) ? "" : "no "); - - eth_register(netdev); - - return 0; -} diff --git a/drivers/net/dnet.h b/drivers/net/dnet.h deleted file mode 100644 index fdb4fd2d391a..000000000000 --- a/drivers/net/dnet.h +++ /dev/null @@ -1,166 +0,0 @@ -/* - * Dave Ethernet Controller driver - * - * Copyright (C) 2008 Dave S.r.l. <www.dave.eu> - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#ifndef __DRIVERS_DNET_H__ -#define __DRIVERS_DNET_H__ - -#define DRIVERNAME "dnet" - -struct dnet_registers { - /* ALL DNET FIFO REGISTERS */ - u32 RX_LEN_FIFO; - u32 RX_DATA_FIFO; - u32 TX_LEN_FIFO; - u32 TX_DATA_FIFO; - u32 pad1[0x3c]; - /* ALL DNET CONTROL/STATUS REGISTERS */ - u32 VERCAPS; - u32 INTR_SRC; - u32 INTR_ENB; - u32 RX_STATUS; - u32 TX_STATUS; - u32 RX_FRAMES_CNT; - u32 TX_FRAMES_CNT; - u32 RX_FIFO_TH; - u32 TX_FIFO_TH; - u32 SYS_CTL; - u32 PAUSE_TMR; - u32 RX_FIFO_WCNT; - u32 TX_FIFO_WCNT; - u32 pad2[0x33]; - /* ALL DNET MAC REGISTERS */ - u32 MACREG_DATA; /* Mac-Reg Data */ - u32 MACREG_ADDR; /* Mac-Reg Addr */ - u32 pad3[0x3e]; - /* ALL DNET RX STATISTICS COUNTERS */ - u32 RX_PKT_IGNR_CNT; - u32 RX_LEN_CHK_ERR_CNT; - u32 RX_LNG_FRM_CNT; - u32 RX_SHRT_FRM_CNT; - u32 RX_IPG_VIOL_CNT; - u32 RX_CRC_ERR_CNT; - u32 RX_OK_PKT_CNT; - u32 RX_CTL_FRM_CNT; - u32 RX_PAUSE_FRM_CNT; - u32 RX_MULTICAST_CNT; - u32 RX_BROADCAST_CNT; - u32 RX_VLAN_TAG_CNT; - u32 RX_PRE_SHRINK_CNT; - u32 RX_DRIB_NIB_CNT; - u32 RX_UNSUP_OPCD_CNT; - u32 RX_BYTE_CNT; - u32 pad4[0x30]; - /* DNET TX STATISTICS COUNTERS */ - u32 TX_UNICAST_CNT; - u32 TX_PAUSE_FRM_CNT; - u32 TX_MULTICAST_CNT; - u32 TX_BRDCAST_CNT; - u32 TX_VLAN_TAG_CNT; - u32 TX_BAD_FCS_CNT; - u32 TX_JUMBO_CNT; - u32 TX_BYTE_CNT; -}; - -/* SOME INTERNAL MAC-CORE REGISTER */ -#define DNET_INTERNAL_MODE_REG 0x0 -#define DNET_INTERNAL_RXTX_CONTROL_REG 0x2 -#define DNET_INTERNAL_MAX_PKT_SIZE_REG 0x4 -#define DNET_INTERNAL_IGP_REG 0x8 -#define DNET_INTERNAL_MAC_ADDR_0_REG 0xa -#define DNET_INTERNAL_MAC_ADDR_1_REG 0xc -#define DNET_INTERNAL_MAC_ADDR_2_REG 0xe -#define DNET_INTERNAL_TX_RX_STS_REG 0x12 -#define DNET_INTERNAL_GMII_MNG_CTL_REG 0x14 -#define DNET_INTERNAL_GMII_MNG_DAT_REG 0x16 - -#define DNET_INTERNAL_GMII_MNG_CMD_FIN (1 << 14) - -#define DNET_INTERNAL_WRITE (1 << 31) - -/* MAC-CORE REGISTER FIELDS */ - -/* MAC-CORE MODE REGISTER FIELDS */ -#define DNET_INTERNAL_MODE_GBITEN (1 << 0) -#define DNET_INTERNAL_MODE_FCEN (1 << 1) -#define DNET_INTERNAL_MODE_RXEN (1 << 2) -#define DNET_INTERNAL_MODE_TXEN (1 << 3) - -/* MAC-CORE RXTX CONTROL REGISTER FIELDS */ -#define DNET_INTERNAL_RXTX_CONTROL_RXSHORTFRAME (1 << 8) -#define DNET_INTERNAL_RXTX_CONTROL_RXBROADCAST (1 << 7) -#define DNET_INTERNAL_RXTX_CONTROL_RXMULTICAST (1 << 4) -#define DNET_INTERNAL_RXTX_CONTROL_RXPAUSE (1 << 3) -#define DNET_INTERNAL_RXTX_CONTROL_DISTXFCS (1 << 2) -#define DNET_INTERNAL_RXTX_CONTROL_DISCFXFCS (1 << 1) -#define DNET_INTERNAL_RXTX_CONTROL_ENPROMISC (1 << 0) -#define DNET_INTERNAL_RXTX_CONTROL_DROPCONTROL (1 << 6) -#define DNET_INTERNAL_RXTX_CONTROL_ENABLEHALFDUP (1 << 5) - -/* SYSTEM CONTROL REGISTER FIELDS */ -#define DNET_SYS_CTL_IGNORENEXTPKT (1 << 0) -#define DNET_SYS_CTL_SENDPAUSE (1 << 2) -#define DNET_SYS_CTL_RXFIFOFLUSH (1 << 3) -#define DNET_SYS_CTL_TXFIFOFLUSH (1 << 4) - -/* TX STATUS REGISTER FIELDS */ -#define DNET_TX_STATUS_FIFO_ALMOST_EMPTY (1 << 2) -#define DNET_TX_STATUS_FIFO_ALMOST_FULL (1 << 1) - -/* INTERRUPT SOURCE REGISTER FIELDS */ -#define DNET_INTR_SRC_TX_PKTSENT (1 << 0) -#define DNET_INTR_SRC_TX_FIFOAF (1 << 1) -#define DNET_INTR_SRC_TX_FIFOAE (1 << 2) -#define DNET_INTR_SRC_TX_DISCFRM (1 << 3) -#define DNET_INTR_SRC_TX_FIFOFULL (1 << 4) -#define DNET_INTR_SRC_RX_CMDFIFOAF (1 << 8) -#define DNET_INTR_SRC_RX_CMDFIFOFF (1 << 9) -#define DNET_INTR_SRC_RX_DATAFIFOFF (1 << 10) -#define DNET_INTR_SRC_TX_SUMMARY (1 << 16) -#define DNET_INTR_SRC_RX_SUMMARY (1 << 17) -#define DNET_INTR_SRC_PHY (1 << 19) - -/* INTERRUPT ENABLE REGISTER FIELDS */ -#define DNET_INTR_ENB_TX_PKTSENT (1 << 0) -#define DNET_INTR_ENB_TX_FIFOAF (1 << 1) -#define DNET_INTR_ENB_TX_FIFOAE (1 << 2) -#define DNET_INTR_ENB_TX_DISCFRM (1 << 3) -#define DNET_INTR_ENB_TX_FIFOFULL (1 << 4) -#define DNET_INTR_ENB_RX_PKTRDY (1 << 8) -#define DNET_INTR_ENB_RX_FIFOAF (1 << 9) -#define DNET_INTR_ENB_RX_FIFOERR (1 << 10) -#define DNET_INTR_ENB_RX_ERROR (1 << 11) -#define DNET_INTR_ENB_RX_FIFOFULL (1 << 12) -#define DNET_INTR_ENB_RX_FIFOAE (1 << 13) -#define DNET_INTR_ENB_TX_SUMMARY (1 << 16) -#define DNET_INTR_ENB_RX_SUMMARY (1 << 17) -#define DNET_INTR_ENB_GLOBAL_ENABLE (1 << 18) - -/* - * Capabilities. Used by the driver to know the capabilities that - * the ethernet controller inside the FPGA have. - */ - -#define DNET_HAS_MDIO (1 << 0) -#define DNET_HAS_IRQ (1 << 1) -#define DNET_HAS_GIGABIT (1 << 2) -#define DNET_HAS_DMA (1 << 3) - -#define DNET_HAS_MII (1 << 4) /* or GMII */ -#define DNET_HAS_RMII (1 << 5) /* or RGMII */ - -#define DNET_CAPS_MASK 0xFFFF - -#define DNET_FIFO_SIZE 2048 /* 2K x 32 bit */ -#define DNET_FIFO_TX_DATA_AF_TH (DNET_FIFO_SIZE - 384) /* 384 = 1536 / 4 */ -#define DNET_FIFO_TX_DATA_AE_TH (384) - -#define DNET_FIFO_RX_CMD_AF_TH (1 << 16) /* just one frame inside the FIFO */ - -#endif
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/ftmac110.c | 491 ----------------------------------------- drivers/net/ftmac110.h | 175 --------------- 3 files changed, 667 deletions(-) delete mode 100644 drivers/net/ftmac110.c delete mode 100644 drivers/net/ftmac110.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1fcd1b2d0b8d..4c4fe9b0b396 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -43,7 +43,6 @@ obj-$(CONFIG_FSL_MEMAC) += fm/memac_phy.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ obj-$(CONFIG_FTGMAC100) += ftgmac100.o obj-$(CONFIG_FTMAC100) += ftmac100.o -obj-$(CONFIG_FTMAC110) += ftmac110.o obj-$(CONFIG_GMAC_ROCKCHIP) += gmac_rockchip.o obj-$(CONFIG_HIGMACV300_ETH) += higmacv300.o obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c deleted file mode 100644 index 7e54d4642ddf..000000000000 --- a/drivers/net/ftmac110.c +++ /dev/null @@ -1,491 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Faraday 10/100Mbps Ethernet Controller - * - * (C) Copyright 2013 Faraday Technology - * Dante Su dantesu@faraday-tech.com - */ - -#include <common.h> -#include <command.h> -#include <log.h> -#include <malloc.h> -#include <net.h> -#include <asm/cache.h> -#include <linux/errno.h> -#include <asm/io.h> -#include <linux/dma-mapping.h> - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) -#include <miiphy.h> -#endif - -#include "ftmac110.h" - -#define CFG_RXDES_NUM 8 -#define CFG_TXDES_NUM 2 -#define CFG_XBUF_SIZE 1536 - -#define CFG_MDIORD_TIMEOUT (CONFIG_SYS_HZ >> 1) /* 500 ms */ -#define CFG_MDIOWR_TIMEOUT (CONFIG_SYS_HZ >> 1) /* 500 ms */ -#define CFG_LINKUP_TIMEOUT (CONFIG_SYS_HZ << 2) /* 4 sec */ - -/* - * FTMAC110 DMA design issue - * - * Its DMA engine has a weird restriction that its Rx DMA engine - * accepts only 16-bits aligned address, 32-bits aligned is not - * acceptable. However this restriction does not apply to Tx DMA. - * - * Conclusion: - * (1) Tx DMA Buffer Address: - * 1 bytes aligned: Invalid - * 2 bytes aligned: O.K - * 4 bytes aligned: O.K (-> u-boot ZeroCopy is possible) - * (2) Rx DMA Buffer Address: - * 1 bytes aligned: Invalid - * 2 bytes aligned: O.K - * 4 bytes aligned: Invalid - */ - -struct ftmac110_chip { - void __iomem *regs; - uint32_t imr; - uint32_t maccr; - uint32_t lnkup; - uint32_t phy_addr; - - struct ftmac110_desc *rxd; - ulong rxd_dma; - uint32_t rxd_idx; - - struct ftmac110_desc *txd; - ulong txd_dma; - uint32_t txd_idx; -}; - -static int ftmac110_reset(struct eth_device *dev); - -static uint16_t mdio_read(struct eth_device *dev, - uint8_t phyaddr, uint8_t phyreg) -{ - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs *regs = chip->regs; - uint32_t tmp, ts; - uint16_t ret = 0xffff; - - tmp = PHYCR_READ - | (phyaddr << PHYCR_ADDR_SHIFT) - | (phyreg << PHYCR_REG_SHIFT); - - writel(tmp, ®s->phycr); - - for (ts = get_timer(0); get_timer(ts) < CFG_MDIORD_TIMEOUT; ) { - tmp = readl(®s->phycr); - if (tmp & PHYCR_READ) - continue; - break; - } - - if (tmp & PHYCR_READ) - printf("ftmac110: mdio read timeout\n"); - else - ret = (uint16_t)(tmp & 0xffff); - - return ret; -} - -static void mdio_write(struct eth_device *dev, - uint8_t phyaddr, uint8_t phyreg, uint16_t phydata) -{ - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs *regs = chip->regs; - uint32_t tmp, ts; - - tmp = PHYCR_WRITE - | (phyaddr << PHYCR_ADDR_SHIFT) - | (phyreg << PHYCR_REG_SHIFT); - - writel(phydata, ®s->phydr); - writel(tmp, ®s->phycr); - - for (ts = get_timer(0); get_timer(ts) < CFG_MDIOWR_TIMEOUT; ) { - if (readl(®s->phycr) & PHYCR_WRITE) - continue; - break; - } - - if (readl(®s->phycr) & PHYCR_WRITE) - printf("ftmac110: mdio write timeout\n"); -} - -static uint32_t ftmac110_phyqry(struct eth_device *dev) -{ - ulong ts; - uint32_t maccr; - uint16_t pa, tmp, bmsr, bmcr; - struct ftmac110_chip *chip = dev->priv; - - /* Default = 100Mbps Full */ - maccr = MACCR_100M | MACCR_FD; - - /* 1. find the phy device */ - for (pa = 0; pa < 32; ++pa) { - tmp = mdio_read(dev, pa, MII_PHYSID1); - if (tmp == 0xFFFF || tmp == 0x0000) - continue; - chip->phy_addr = pa; - break; - } - if (pa >= 32) { - puts("ftmac110: phy device not found!\n"); - goto exit; - } - - /* 2. wait until link-up & auto-negotiation complete */ - chip->lnkup = 0; - bmcr = mdio_read(dev, chip->phy_addr, MII_BMCR); - ts = get_timer(0); - do { - bmsr = mdio_read(dev, chip->phy_addr, MII_BMSR); - chip->lnkup = (bmsr & BMSR_LSTATUS) ? 1 : 0; - if (!chip->lnkup) - continue; - if (!(bmcr & BMCR_ANENABLE) || (bmsr & BMSR_ANEGCOMPLETE)) - break; - } while (get_timer(ts) < CFG_LINKUP_TIMEOUT); - if (!chip->lnkup) { - puts("ftmac110: link down\n"); - goto exit; - } - if (!(bmcr & BMCR_ANENABLE)) - puts("ftmac110: auto negotiation disabled\n"); - else if (!(bmsr & BMSR_ANEGCOMPLETE)) - puts("ftmac110: auto negotiation timeout\n"); - - /* 3. derive MACCR */ - if ((bmcr & BMCR_ANENABLE) && (bmsr & BMSR_ANEGCOMPLETE)) { - tmp = mdio_read(dev, chip->phy_addr, MII_ADVERTISE); - tmp &= mdio_read(dev, chip->phy_addr, MII_LPA); - if (tmp & LPA_100FULL) /* 100Mbps full-duplex */ - maccr = MACCR_100M | MACCR_FD; - else if (tmp & LPA_100HALF) /* 100Mbps half-duplex */ - maccr = MACCR_100M; - else if (tmp & LPA_10FULL) /* 10Mbps full-duplex */ - maccr = MACCR_FD; - else if (tmp & LPA_10HALF) /* 10Mbps half-duplex */ - maccr = 0; - } else { - if (bmcr & BMCR_SPEED100) - maccr = MACCR_100M; - else - maccr = 0; - if (bmcr & BMCR_FULLDPLX) - maccr |= MACCR_FD; - } - -exit: - printf("ftmac110: %d Mbps, %s\n", - (maccr & MACCR_100M) ? 100 : 10, - (maccr & MACCR_FD) ? "Full" : "half"); - return maccr; -} - -static int ftmac110_reset(struct eth_device *dev) -{ - uint8_t *a; - uint32_t i, maccr; - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs *regs = chip->regs; - - /* 1. MAC reset */ - writel(MACCR_RESET, ®s->maccr); - for (i = get_timer(0); get_timer(i) < 1000; ) { - if (readl(®s->maccr) & MACCR_RESET) - continue; - break; - } - if (readl(®s->maccr) & MACCR_RESET) { - printf("ftmac110: reset failed\n"); - return -ENXIO; - } - - /* 1-1. Init tx ring */ - for (i = 0; i < CFG_TXDES_NUM; ++i) { - /* owned by SW */ - chip->txd[i].ctrl &= cpu_to_le64(FTMAC110_TXD_CLRMASK); - } - chip->txd_idx = 0; - - /* 1-2. Init rx ring */ - for (i = 0; i < CFG_RXDES_NUM; ++i) { - /* owned by HW */ - chip->rxd[i].ctrl &= cpu_to_le64(FTMAC110_RXD_CLRMASK); - chip->rxd[i].ctrl |= cpu_to_le64(FTMAC110_RXD_OWNER); - } - chip->rxd_idx = 0; - - /* 2. PHY status query */ - maccr = ftmac110_phyqry(dev); - - /* 3. Fix up the MACCR value */ - chip->maccr = maccr | MACCR_CRCAPD | MACCR_RXALL | MACCR_RXRUNT - | MACCR_RXEN | MACCR_TXEN | MACCR_RXDMAEN | MACCR_TXDMAEN; - - /* 4. MAC address setup */ - a = dev->enetaddr; - writel(a[1] | (a[0] << 8), ®s->mac[0]); - writel(a[5] | (a[4] << 8) | (a[3] << 16) - | (a[2] << 24), ®s->mac[1]); - - /* 5. MAC registers setup */ - writel(chip->rxd_dma, ®s->rxba); - writel(chip->txd_dma, ®s->txba); - /* interrupt at each tx/rx */ - writel(ITC_DEFAULT, ®s->itc); - /* no tx pool, rx poll = 1 normal cycle */ - writel(APTC_DEFAULT, ®s->aptc); - /* rx threshold = [6/8 fifo, 2/8 fifo] */ - writel(DBLAC_DEFAULT, ®s->dblac); - /* disable & clear all interrupt status */ - chip->imr = 0; - writel(ISR_ALL, ®s->isr); - writel(chip->imr, ®s->imr); - /* enable mac */ - writel(chip->maccr, ®s->maccr); - - return 0; -} - -static int ftmac110_probe(struct eth_device *dev, struct bd_info *bis) -{ - debug("ftmac110: probe\n"); - - if (ftmac110_reset(dev)) - return -1; - - return 0; -} - -static void ftmac110_halt(struct eth_device *dev) -{ - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs *regs = chip->regs; - - writel(0, ®s->imr); - writel(0, ®s->maccr); - - debug("ftmac110: halt\n"); -} - -static int ftmac110_send(struct eth_device *dev, void *pkt, int len) -{ - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs *regs = chip->regs; - struct ftmac110_desc *txd; - uint64_t ctrl; - - if (!chip->lnkup) - return 0; - - if (len <= 0 || len > CFG_XBUF_SIZE) { - printf("ftmac110: bad tx pkt len(%d)\n", len); - return 0; - } - - len = max(60, len); - - txd = &chip->txd[chip->txd_idx]; - ctrl = le64_to_cpu(txd->ctrl); - if (ctrl & FTMAC110_TXD_OWNER) { - /* kick-off Tx DMA */ - writel(0xffffffff, ®s->txpd); - printf("ftmac110: out of txd\n"); - return 0; - } - - memcpy(txd->vbuf, (void *)pkt, len); - dma_map_single(txd->vbuf, len, DMA_TO_DEVICE); - - /* clear control bits */ - ctrl &= FTMAC110_TXD_CLRMASK; - /* set len, fts and lts */ - ctrl |= FTMAC110_TXD_LEN(len) | FTMAC110_TXD_FTS | FTMAC110_TXD_LTS; - /* set owner bit */ - ctrl |= FTMAC110_TXD_OWNER; - /* write back to descriptor */ - txd->ctrl = cpu_to_le64(ctrl); - - /* kick-off Tx DMA */ - writel(0xffffffff, ®s->txpd); - - chip->txd_idx = (chip->txd_idx + 1) % CFG_TXDES_NUM; - - return len; -} - -static int ftmac110_recv(struct eth_device *dev) -{ - struct ftmac110_chip *chip = dev->priv; - struct ftmac110_desc *rxd; - uint32_t len, rlen = 0; - uint64_t ctrl; - uint8_t *buf; - - if (!chip->lnkup) - return 0; - - do { - rxd = &chip->rxd[chip->rxd_idx]; - ctrl = le64_to_cpu(rxd->ctrl); - if (ctrl & FTMAC110_RXD_OWNER) - break; - - len = (uint32_t)FTMAC110_RXD_LEN(ctrl); - buf = rxd->vbuf; - - if (ctrl & FTMAC110_RXD_ERRMASK) { - printf("ftmac110: rx error\n"); - } else { - dma_map_single(buf, len, DMA_FROM_DEVICE); - net_process_received_packet(buf, len); - rlen += len; - } - - /* owned by hardware */ - ctrl &= FTMAC110_RXD_CLRMASK; - ctrl |= FTMAC110_RXD_OWNER; - rxd->ctrl |= cpu_to_le64(ctrl); - - chip->rxd_idx = (chip->rxd_idx + 1) % CFG_RXDES_NUM; - } while (0); - - return rlen; -} - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - -static int ftmac110_mdio_read(struct mii_dev *bus, int addr, int devad, - int reg) -{ - uint16_t value = 0; - int ret = 0; - struct eth_device *dev; - - dev = eth_get_dev_by_name(bus->name); - if (dev == NULL) { - printf("%s: no such device\n", bus->name); - ret = -1; - } else { - value = mdio_read(dev, addr, reg); - } - - if (ret < 0) - return ret; - return value; -} - -static int ftmac110_mdio_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 value) -{ - int ret = 0; - struct eth_device *dev; - - dev = eth_get_dev_by_name(bus->name); - if (dev == NULL) { - printf("%s: no such device\n", bus->name); - ret = -1; - } else { - mdio_write(dev, addr, reg, value); - } - - return ret; -} - -#endif /* #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) */ - -int ftmac110_initialize(struct bd_info *bis) -{ - int i, card_nr = 0; - struct eth_device *dev; - struct ftmac110_chip *chip; - - dev = malloc(sizeof(*dev) + sizeof(*chip)); - if (dev == NULL) { - panic("ftmac110: out of memory 1\n"); - return -1; - } - chip = (struct ftmac110_chip *)(dev + 1); - memset(dev, 0, sizeof(*dev) + sizeof(*chip)); - - sprintf(dev->name, "FTMAC110#%d", card_nr); - - dev->iobase = CONFIG_FTMAC110_BASE; - chip->regs = (void __iomem *)dev->iobase; - dev->priv = chip; - dev->init = ftmac110_probe; - dev->halt = ftmac110_halt; - dev->send = ftmac110_send; - dev->recv = ftmac110_recv; - - /* allocate tx descriptors (it must be 16 bytes aligned) */ - chip->txd = dma_alloc_coherent( - sizeof(struct ftmac110_desc) * CFG_TXDES_NUM, &chip->txd_dma); - if (!chip->txd) - panic("ftmac110: out of memory 3\n"); - memset(chip->txd, 0, - sizeof(struct ftmac110_desc) * CFG_TXDES_NUM); - for (i = 0; i < CFG_TXDES_NUM; ++i) { - void *va = memalign(ARCH_DMA_MINALIGN, CFG_XBUF_SIZE); - - if (!va) - panic("ftmac110: out of memory 4\n"); - chip->txd[i].vbuf = va; - chip->txd[i].pbuf = cpu_to_le32(virt_to_phys(va)); - chip->txd[i].ctrl = 0; /* owned by SW */ - } - chip->txd[i - 1].ctrl |= cpu_to_le64(FTMAC110_TXD_END); - chip->txd_idx = 0; - - /* allocate rx descriptors (it must be 16 bytes aligned) */ - chip->rxd = dma_alloc_coherent( - sizeof(struct ftmac110_desc) * CFG_RXDES_NUM, &chip->rxd_dma); - if (!chip->rxd) - panic("ftmac110: out of memory 4\n"); - memset((void *)chip->rxd, 0, - sizeof(struct ftmac110_desc) * CFG_RXDES_NUM); - for (i = 0; i < CFG_RXDES_NUM; ++i) { - void *va = memalign(ARCH_DMA_MINALIGN, CFG_XBUF_SIZE + 2); - - if (!va) - panic("ftmac110: out of memory 5\n"); - /* it needs to be exactly 2 bytes aligned */ - va = ((uint8_t *)va + 2); - chip->rxd[i].vbuf = va; - chip->rxd[i].pbuf = cpu_to_le32(virt_to_phys(va)); - chip->rxd[i].ctrl = cpu_to_le64(FTMAC110_RXD_OWNER - | FTMAC110_RXD_BUFSZ(CFG_XBUF_SIZE)); - } - chip->rxd[i - 1].ctrl |= cpu_to_le64(FTMAC110_RXD_END); - chip->rxd_idx = 0; - - eth_register(dev); - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) - int retval; - struct mii_dev *mdiodev = mdio_alloc(); - if (!mdiodev) - return -ENOMEM; - strlcpy(mdiodev->name, dev->name, MDIO_NAME_LEN); - mdiodev->read = ftmac110_mdio_read; - mdiodev->write = ftmac110_mdio_write; - - retval = mdio_register(mdiodev); - if (retval < 0) - return retval; -#endif - - card_nr++; - - return card_nr; -} diff --git a/drivers/net/ftmac110.h b/drivers/net/ftmac110.h deleted file mode 100644 index a792b515b446..000000000000 --- a/drivers/net/ftmac110.h +++ /dev/null @@ -1,175 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Faraday 10/100Mbps Ethernet Controller - * - * (C) Copyright 2013 Faraday Technology - * Dante Su dantesu@faraday-tech.com - */ - -#ifndef _FTMAC110_H -#define _FTMAC110_H - -struct ftmac110_regs { - uint32_t isr; /* 0x00: Interrups Status Register */ - uint32_t imr; /* 0x04: Interrupt Mask Register */ - uint32_t mac[2]; /* 0x08: MAC Address */ - uint32_t mht[2]; /* 0x10: Multicast Hash Table Register */ - uint32_t txpd; /* 0x18: Tx Poll Demand Register */ - uint32_t rxpd; /* 0x1c: Rx Poll Demand Register */ - uint32_t txba; /* 0x20: Tx Ring Base Address Register */ - uint32_t rxba; /* 0x24: Rx Ring Base Address Register */ - uint32_t itc; /* 0x28: Interrupt Timer Control Register */ - uint32_t aptc; /* 0x2C: Automatic Polling Timer Control Register */ - uint32_t dblac; /* 0x30: DMA Burst Length&Arbitration Control */ - uint32_t revr; /* 0x34: Revision Register */ - uint32_t fear; /* 0x38: Feature Register */ - uint32_t rsvd[19]; - uint32_t maccr; /* 0x88: MAC Control Register */ - uint32_t macsr; /* 0x8C: MAC Status Register */ - uint32_t phycr; /* 0x90: PHY Control Register */ - uint32_t phydr; /* 0x94: PHY Data Register */ - uint32_t fcr; /* 0x98: Flow Control Register */ - uint32_t bpr; /* 0x9C: Back Pressure Register */ -}; - -/* - * Interrupt status/mask register(ISR/IMR) bits - */ -#define ISR_ALL 0x3ff -#define ISR_PHYSTCHG (1 << 9) /* phy status change */ -#define ISR_AHBERR (1 << 8) /* bus error */ -#define ISR_RXLOST (1 << 7) /* rx lost */ -#define ISR_RXFIFO (1 << 6) /* rx to fifo */ -#define ISR_TXLOST (1 << 5) /* tx lost */ -#define ISR_TXOK (1 << 4) /* tx to ethernet */ -#define ISR_NOTXBUF (1 << 3) /* out of tx buffer */ -#define ISR_TXFIFO (1 << 2) /* tx to fifo */ -#define ISR_NORXBUF (1 << 1) /* out of rx buffer */ -#define ISR_RXOK (1 << 0) /* rx to buffer */ - -/* - * MACCR control bits - */ -#define MACCR_100M (1 << 18) /* 100Mbps mode */ -#define MACCR_RXBCST (1 << 17) /* rx broadcast packet */ -#define MACCR_RXMCST (1 << 16) /* rx multicast packet */ -#define MACCR_FD (1 << 15) /* full duplex */ -#define MACCR_CRCAPD (1 << 14) /* tx crc append */ -#define MACCR_RXALL (1 << 12) /* rx all packets */ -#define MACCR_RXFTL (1 << 11) /* rx packet even it's > 1518 byte */ -#define MACCR_RXRUNT (1 << 10) /* rx packet even it's < 64 byte */ -#define MACCR_RXMCSTHT (1 << 9) /* rx multicast hash table */ -#define MACCR_RXEN (1 << 8) /* rx enable */ -#define MACCR_RXINHDTX (1 << 6) /* rx in half duplex tx */ -#define MACCR_TXEN (1 << 5) /* tx enable */ -#define MACCR_CRCDIS (1 << 4) /* tx packet even it's crc error */ -#define MACCR_LOOPBACK (1 << 3) /* loop-back */ -#define MACCR_RESET (1 << 2) /* reset */ -#define MACCR_RXDMAEN (1 << 1) /* rx dma enable */ -#define MACCR_TXDMAEN (1 << 0) /* tx dma enable */ - -/* - * PHYCR control bits - */ -#define PHYCR_READ (1 << 26) -#define PHYCR_WRITE (1 << 27) -#define PHYCR_REG_SHIFT 21 -#define PHYCR_ADDR_SHIFT 16 - -/* - * ITC control bits - */ - -/* Tx Cycle Length */ -#define ITC_TX_CYCLONG (1 << 15) /* 100Mbps=81.92us; 10Mbps=819.2us */ -#define ITC_TX_CYCNORM (0 << 15) /* 100Mbps=5.12us; 10Mbps=51.2us */ -/* Tx Threshold: Aggregate n interrupts as 1 interrupt */ -#define ITC_TX_THR(n) (((n) & 0x7) << 12) -/* Tx Interrupt Timeout = n * Tx Cycle */ -#define ITC_TX_ITMO(n) (((n) & 0xf) << 8) -/* Rx Cycle Length */ -#define ITC_RX_CYCLONG (1 << 7) /* 100Mbps=81.92us; 10Mbps=819.2us */ -#define ITC_RX_CYCNORM (0 << 7) /* 100Mbps=5.12us; 10Mbps=51.2us */ -/* Rx Threshold: Aggregate n interrupts as 1 interrupt */ -#define ITC_RX_THR(n) (((n) & 0x7) << 4) -/* Rx Interrupt Timeout = n * Rx Cycle */ -#define ITC_RX_ITMO(n) (((n) & 0xf) << 0) - -#define ITC_DEFAULT \ - (ITC_TX_THR(1) | ITC_TX_ITMO(0) | ITC_RX_THR(1) | ITC_RX_ITMO(0)) - -/* - * APTC contrl bits - */ - -/* Tx Cycle Length */ -#define APTC_TX_CYCLONG (1 << 12) /* 100Mbps=81.92us; 10Mbps=819.2us */ -#define APTC_TX_CYCNORM (0 << 12) /* 100Mbps=5.12us; 10Mbps=51.2us */ -/* Tx Poll Timeout = n * Tx Cycle, 0=No auto polling */ -#define APTC_TX_PTMO(n) (((n) & 0xf) << 8) -/* Rx Cycle Length */ -#define APTC_RX_CYCLONG (1 << 4) /* 100Mbps=81.92us; 10Mbps=819.2us */ -#define APTC_RX_CYCNORM (0 << 4) /* 100Mbps=5.12us; 10Mbps=51.2us */ -/* Rx Poll Timeout = n * Rx Cycle, 0=No auto polling */ -#define APTC_RX_PTMO(n) (((n) & 0xf) << 0) - -#define APTC_DEFAULT (APTC_TX_PTMO(0) | APTC_RX_PTMO(1)) - -/* - * DBLAC contrl bits - */ -#define DBLAC_BURST_MAX_ANY (0 << 14) /* un-limited */ -#define DBLAC_BURST_MAX_32X4 (2 << 14) /* max = 32 x 4 bytes */ -#define DBLAC_BURST_MAX_64X4 (3 << 14) /* max = 64 x 4 bytes */ -#define DBLAC_RXTHR_EN (1 << 9) /* enable rx threshold arbitration */ -#define DBLAC_RXTHR_HIGH(n) (((n) & 0x7) << 6) /* upper bound = n/8 fifo */ -#define DBLAC_RXTHR_LOW(n) (((n) & 0x7) << 3) /* lower bound = n/8 fifo */ -#define DBLAC_BURST_CAP16 (1 << 2) /* support burst 16 */ -#define DBLAC_BURST_CAP8 (1 << 1) /* support burst 8 */ -#define DBLAC_BURST_CAP4 (1 << 0) /* support burst 4 */ - -#define DBLAC_DEFAULT \ - (DBLAC_RXTHR_EN | DBLAC_RXTHR_HIGH(6) | DBLAC_RXTHR_LOW(2)) - -/* - * descriptor structure - */ -struct ftmac110_desc { - uint64_t ctrl; - uint32_t pbuf; - void *vbuf; -}; - -#define FTMAC110_RXD_END ((uint64_t)1 << 63) -#define FTMAC110_RXD_BUFSZ(x) (((uint64_t)(x) & 0x7ff) << 32) - -#define FTMAC110_RXD_OWNER ((uint64_t)1 << 31) /* owner: 1=HW, 0=SW */ -#define FTMAC110_RXD_FRS ((uint64_t)1 << 29) /* first pkt desc */ -#define FTMAC110_RXD_LRS ((uint64_t)1 << 28) /* last pkt desc */ -#define FTMAC110_RXD_ODDNB ((uint64_t)1 << 22) /* odd nibble */ -#define FTMAC110_RXD_RUNT ((uint64_t)1 << 21) /* runt pkt */ -#define FTMAC110_RXD_FTL ((uint64_t)1 << 20) /* frame too long */ -#define FTMAC110_RXD_CRC ((uint64_t)1 << 19) /* pkt crc error */ -#define FTMAC110_RXD_ERR ((uint64_t)1 << 18) /* bus error */ -#define FTMAC110_RXD_ERRMASK ((uint64_t)0x1f << 18) -#define FTMAC110_RXD_BCST ((uint64_t)1 << 17) /* Bcst pkt */ -#define FTMAC110_RXD_MCST ((uint64_t)1 << 16) /* Mcst pkt */ -#define FTMAC110_RXD_LEN(x) ((uint64_t)((x) & 0x7ff)) - -#define FTMAC110_RXD_CLRMASK \ - (FTMAC110_RXD_END | FTMAC110_RXD_BUFSZ(0x7ff)) - -#define FTMAC110_TXD_END ((uint64_t)1 << 63) /* end of ring */ -#define FTMAC110_TXD_TXIC ((uint64_t)1 << 62) /* tx done interrupt */ -#define FTMAC110_TXD_TX2FIC ((uint64_t)1 << 61) /* tx fifo interrupt */ -#define FTMAC110_TXD_FTS ((uint64_t)1 << 60) /* first pkt desc */ -#define FTMAC110_TXD_LTS ((uint64_t)1 << 59) /* last pkt desc */ -#define FTMAC110_TXD_LEN(x) ((uint64_t)((x) & 0x7ff) << 32) - -#define FTMAC110_TXD_OWNER ((uint64_t)1 << 31) /* owner: 1=HW, 0=SW */ -#define FTMAC110_TXD_COL ((uint64_t)3) /* collision */ - -#define FTMAC110_TXD_CLRMASK \ - (FTMAC110_TXD_END) - -#endif /* FTMAC110_H */
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/lan91c96.c | 799 ----------------------------------------- drivers/net/lan91c96.h | 616 ------------------------------- 3 files changed, 1416 deletions(-) delete mode 100644 drivers/net/lan91c96.c delete mode 100644 drivers/net/lan91c96.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 4c4fe9b0b396..be3264e04133 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -47,7 +47,6 @@ obj-$(CONFIG_GMAC_ROCKCHIP) += gmac_rockchip.o obj-$(CONFIG_HIGMACV300_ETH) += higmacv300.o obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o obj-$(CONFIG_KSZ9477) += ksz9477.o -obj-$(CONFIG_LAN91C96) += lan91c96.o obj-$(CONFIG_LPC32XX_ETH) += lpc32xx_eth.o obj-$(CONFIG_MACB) += macb.o obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c deleted file mode 100644 index c2f611144db6..000000000000 --- a/drivers/net/lan91c96.c +++ /dev/null @@ -1,799 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/*------------------------------------------------------------------------ - * lan91c96.c - * This is a driver for SMSC's LAN91C96 single-chip Ethernet device, based - * on the SMC91111 driver from U-Boot. - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Rolf Offermanns rof@sysgo.de - * - * Copyright (C) 2001 Standard Microsystems Corporation (SMSC) - * Developed by Simple Network Magic Corporation (SNMC) - * Copyright (C) 1996 by Erik Stahlman (ES) - * - * Information contained in this file was obtained from the LAN91C96 - * manual from SMC. To get a copy, if you really want one, you can find - * information under www.smsc.com. - * - * "Features" of the SMC chip: - * 6144 byte packet memory. ( for the 91C96 ) - * EEPROM for configuration - * AUI/TP selection ( mine has 10Base2/10BaseT select ) - * - * Arguments: - * io = for the base address - * irq = for the IRQ - * - * author: - * Erik Stahlman ( erik@vt.edu ) - * Daris A Nevil ( dnevil@snmc.com ) - * - * - * Hardware multicast code from Peter Cammaert ( pc@denkart.be ) - * - * Sources: - * o SMSC LAN91C96 databook (www.smsc.com) - * o smc91111.c (u-boot driver) - * o smc9194.c (linux kernel driver) - * o lan91c96.c (Intel Diagnostic Manager driver) - * - * History: - * 04/30/03 Mathijs Haarman Modified smc91111.c (u-boot version) - * for lan91c96 - *--------------------------------------------------------------------------- - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <malloc.h> -#include <linux/delay.h> -#include "lan91c96.h" -#include <net.h> -#include <linux/compiler.h> - -/*------------------------------------------------------------------------ - * - * Configuration options, for the experienced user to change. - * - -------------------------------------------------------------------------*/ - -/* Use power-down feature of the chip */ -#define POWER_DOWN 0 - -/* - * Wait time for memory to be free. This probably shouldn't be - * tuned that much, as waiting for this means nothing else happens - * in the system -*/ -#define MEMORY_WAIT_TIME 16 - -#define SMC_DEBUG 0 - -#if (SMC_DEBUG > 2 ) -#define PRINTK3(args...) printf(args) -#else -#define PRINTK3(args...) -#endif - -#if SMC_DEBUG > 1 -#define PRINTK2(args...) printf(args) -#else -#define PRINTK2(args...) -#endif - -#ifdef SMC_DEBUG -#define PRINTK(args...) printf(args) -#else -#define PRINTK(args...) -#endif - - -/*------------------------------------------------------------------------ - * - * The internal workings of the driver. If you are changing anything - * here with the SMC stuff, you should have the datasheet and know - * what you are doing. - * - *------------------------------------------------------------------------ - */ -#define DRIVER_NAME "LAN91C96" -#define SMC_ALLOC_MAX_TRY 5 -#define SMC_TX_TIMEOUT 30 - -#define ETH_ZLEN 60 - -#ifdef CONFIG_LAN91C96_USE_32_BIT -#define USE_32_BIT 1 -#else -#undef USE_32_BIT -#endif - -/* See if a MAC address is defined in the current environment. If so use it. If not - . print a warning and set the environment and other globals with the default. - . If an EEPROM is present it really should be consulted. -*/ -static int smc_get_ethaddr(struct bd_info *bd, struct eth_device *dev); -static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac); - -/* ------------------------------------------------------------ - * Internal routines - * ------------------------------------------------------------ - */ - -static unsigned char smc_mac_addr[] = { 0xc0, 0x00, 0x00, 0x1b, 0x62, 0x9c }; - -/* - * This function must be called before smc_open() if you want to override - * the default mac address. - */ - -static void smc_set_mac_addr(const unsigned char *addr) -{ - int i; - - for (i = 0; i < sizeof (smc_mac_addr); i++) { - smc_mac_addr[i] = addr[i]; - } -} - -/*********************************************** - * Show available memory * - ***********************************************/ -void dump_memory_info(struct eth_device *dev) -{ - __maybe_unused word mem_info; - word old_bank; - - old_bank = SMC_inw(dev, LAN91C96_BANK_SELECT) & 0xF; - - SMC_SELECT_BANK(dev, 0); - mem_info = SMC_inw(dev, LAN91C96_MIR); - PRINTK2 ("Memory: %4d available\n", (mem_info >> 8) * 2048); - - SMC_SELECT_BANK(dev, old_bank); -} - -/* - * A rather simple routine to print out a packet for debugging purposes. - */ -#if SMC_DEBUG > 2 -static void print_packet (byte *, int); -#endif - -static int poll4int (struct eth_device *dev, byte mask, int timeout) -{ - int tmo = get_timer (0) + timeout * CONFIG_SYS_HZ; - int is_timeout = 0; - word old_bank = SMC_inw(dev, LAN91C96_BANK_SELECT); - - PRINTK2 ("Polling...\n"); - SMC_SELECT_BANK(dev, 2); - while ((SMC_inw(dev, LAN91C96_INT_STATS) & mask) == 0) { - if (get_timer (0) >= tmo) { - is_timeout = 1; - break; - } - } - - /* restore old bank selection */ - SMC_SELECT_BANK(dev, old_bank); - - if (is_timeout) - return 1; - else - return 0; -} - -/* - * Function: smc_reset - * Purpose: - * This sets the SMC91111 chip to its normal state, hopefully from whatever - * mess that any other DOS driver has put it in. - * - * Maybe I should reset more registers to defaults in here? SOFTRST should - * do that for me. - * - * Method: - * 1. send a SOFT RESET - * 2. wait for it to finish - * 3. enable autorelease mode - * 4. reset the memory management unit - * 5. clear all interrupts - * -*/ -static void smc_reset(struct eth_device *dev) -{ - PRINTK2("%s:smc_reset\n", dev->name); - - /* This resets the registers mostly to defaults, but doesn't - affect EEPROM. That seems unnecessary */ - SMC_SELECT_BANK(dev, 0); - SMC_outw(dev, LAN91C96_RCR_SOFT_RST, LAN91C96_RCR); - - udelay(10); - - /* Disable transmit and receive functionality */ - SMC_outw(dev, 0, LAN91C96_RCR); - SMC_outw(dev, 0, LAN91C96_TCR); - - /* set the control register */ - SMC_SELECT_BANK(dev, 1); - SMC_outw(dev, SMC_inw(dev, LAN91C96_CONTROL) | LAN91C96_CTR_BIT_8, - LAN91C96_CONTROL); - - /* Disable all interrupts */ - SMC_outb(dev, 0, LAN91C96_INT_MASK); -} - -/* - * Function: smc_enable - * Purpose: let the chip talk to the outside work - * Method: - * 1. Initialize the Memory Configuration Register - * 2. Enable the transmitter - * 3. Enable the receiver -*/ -static void smc_enable(struct eth_device *dev) -{ - PRINTK2("%s:smc_enable\n", dev->name); - SMC_SELECT_BANK(dev, 0); - - /* Initialize the Memory Configuration Register. See page - 49 of the LAN91C96 data sheet for details. */ - SMC_outw(dev, LAN91C96_MCR_TRANSMIT_PAGES, LAN91C96_MCR); - - /* Initialize the Transmit Control Register */ - SMC_outw(dev, LAN91C96_TCR_TXENA, LAN91C96_TCR); - /* Initialize the Receive Control Register - * FIXME: - * The promiscuous bit set because I could not receive ARP reply - * packets from the server when I send a ARP request. It only works - * when I set the promiscuous bit - */ - SMC_outw(dev, LAN91C96_RCR_RXEN | LAN91C96_RCR_PRMS, LAN91C96_RCR); -} - -/* - * Function: smc_shutdown - * Purpose: closes down the SMC91xxx chip. - * Method: - * 1. zero the interrupt mask - * 2. clear the enable receive flag - * 3. clear the enable xmit flags - * - * TODO: - * (1) maybe utilize power down mode. - * Why not yet? Because while the chip will go into power down mode, - * the manual says that it will wake up in response to any I/O requests - * in the register space. Empirical results do not show this working. - */ -static void smc_shutdown(struct eth_device *dev) -{ - PRINTK2("%s:smc_shutdown\n", dev->name); - - /* no more interrupts for me */ - SMC_SELECT_BANK(dev, 2); - SMC_outb(dev, 0, LAN91C96_INT_MASK); - - /* and tell the card to stay away from that nasty outside world */ - SMC_SELECT_BANK(dev, 0); - SMC_outb(dev, 0, LAN91C96_RCR); - SMC_outb(dev, 0, LAN91C96_TCR); -} - - -/* - * Function: smc_hardware_send_packet(struct net_device * ) - * Purpose: - * This sends the actual packet to the SMC9xxx chip. - * - * Algorithm: - * First, see if a saved_skb is available. - * ( this should NOT be called if there is no 'saved_skb' - * Now, find the packet number that the chip allocated - * Point the data pointers at it in memory - * Set the length word in the chip's memory - * Dump the packet to chip memory - * Check if a last byte is needed ( odd length packet ) - * if so, set the control flag right - * Tell the card to send it - * Enable the transmit interrupt, so I know if it failed - * Free the kernel data if I actually sent it. - */ -static int smc_send_packet(struct eth_device *dev, void *packet, - int packet_length) -{ - byte packet_no; - byte *buf; - int length; - int numPages; - int try = 0; - int time_out; - byte status; - - - PRINTK3("%s:smc_hardware_send_packet\n", dev->name); - - length = ETH_ZLEN < packet_length ? packet_length : ETH_ZLEN; - - /* allocate memory - ** The MMU wants the number of pages to be the number of 256 bytes - ** 'pages', minus 1 ( since a packet can't ever have 0 pages :) ) - ** - ** The 91C111 ignores the size bits, but the code is left intact - ** for backwards and future compatibility. - ** - ** Pkt size for allocating is data length +6 (for additional status - ** words, length and ctl!) - ** - ** If odd size then last byte is included in this header. - */ - numPages = ((length & 0xfffe) + 6); - numPages >>= 8; /* Divide by 256 */ - - if (numPages > 7) { - printf("%s: Far too big packet error. \n", dev->name); - return 0; - } - - /* now, try to allocate the memory */ - - SMC_SELECT_BANK(dev, 2); - SMC_outw(dev, LAN91C96_MMUCR_ALLOC_TX | numPages, LAN91C96_MMU); - - again: - try++; - time_out = MEMORY_WAIT_TIME; - do { - status = SMC_inb(dev, LAN91C96_INT_STATS); - if (status & LAN91C96_IST_ALLOC_INT) { - - SMC_outb(dev, LAN91C96_IST_ALLOC_INT, - LAN91C96_INT_STATS); - break; - } - } while (--time_out); - - if (!time_out) { - PRINTK2 ("%s: memory allocation, try %d failed ...\n", - dev->name, try); - if (try < SMC_ALLOC_MAX_TRY) - goto again; - else - return 0; - } - - PRINTK2 ("%s: memory allocation, try %d succeeded ...\n", - dev->name, try); - - /* I can send the packet now.. */ - buf = (byte *) packet; - - /* If I get here, I _know_ there is a packet slot waiting for me */ - packet_no = SMC_inb(dev, LAN91C96_ARR); - if (packet_no & LAN91C96_ARR_FAILED) { - /* or isn't there? BAD CHIP! */ - printf("%s: Memory allocation failed. \n", dev->name); - return 0; - } - - /* we have a packet address, so tell the card to use it */ - SMC_outb(dev, packet_no, LAN91C96_PNR); - - /* point to the beginning of the packet */ - SMC_outw(dev, LAN91C96_PTR_AUTO_INCR, LAN91C96_POINTER); - - PRINTK3("%s: Trying to xmit packet of length %x\n", - dev->name, length); - -#if SMC_DEBUG > 2 - printf ("Transmitting Packet\n"); - print_packet (buf, length); -#endif - - /* send the packet length ( +6 for status, length and ctl byte ) - and the status word ( set to zeros ) */ -#ifdef USE_32_BIT - SMC_outl(dev, (length + 6) << 16, LAN91C96_DATA_HIGH); -#else - SMC_outw(dev, 0, LAN91C96_DATA_HIGH); - /* send the packet length ( +6 for status words, length, and ctl */ - SMC_outw(dev, (length + 6), LAN91C96_DATA_HIGH); -#endif /* USE_32_BIT */ - - /* send the actual data - * I _think_ it's faster to send the longs first, and then - * mop up by sending the last word. It depends heavily - * on alignment, at least on the 486. Maybe it would be - * a good idea to check which is optimal? But that could take - * almost as much time as is saved? - */ -#ifdef USE_32_BIT - SMC_outsl(dev, LAN91C96_DATA_HIGH, buf, length >> 2); - if (length & 0x2) - SMC_outw(dev, *((word *) (buf + (length & 0xFFFFFFFC))), - LAN91C96_DATA_HIGH); -#else - SMC_outsw(dev, LAN91C96_DATA_HIGH, buf, (length) >> 1); -#endif /* USE_32_BIT */ - - /* Send the last byte, if there is one. */ - if ((length & 1) == 0) { - SMC_outw(dev, 0, LAN91C96_DATA_HIGH); - } else { - SMC_outw(dev, buf[length - 1] | 0x2000, LAN91C96_DATA_HIGH); - } - - /* and let the chipset deal with it */ - SMC_outw(dev, LAN91C96_MMUCR_ENQUEUE, LAN91C96_MMU); - - /* poll for TX INT */ - if (poll4int (dev, LAN91C96_MSK_TX_INT, SMC_TX_TIMEOUT)) { - /* sending failed */ - PRINTK2("%s: TX timeout, sending failed...\n", dev->name); - - /* release packet */ - SMC_outw(dev, LAN91C96_MMUCR_RELEASE_TX, LAN91C96_MMU); - - /* wait for MMU getting ready (low) */ - while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) - udelay(10); - - PRINTK2("MMU ready\n"); - - - return 0; - } else { - /* ack. int */ - SMC_outw(dev, LAN91C96_IST_TX_INT, LAN91C96_INT_STATS); - - PRINTK2("%s: Sent packet of length %d \n", dev->name, length); - - /* release packet */ - SMC_outw(dev, LAN91C96_MMUCR_RELEASE_TX, LAN91C96_MMU); - - /* wait for MMU getting ready (low) */ - while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) - udelay(10); - - PRINTK2 ("MMU ready\n"); - } - - return length; -} - - -/* - * Open and Initialize the board - * - * Set up everything, reset the card, etc .. - * - */ -static int smc_open(struct bd_info *bd, struct eth_device *dev) -{ - int i, err; /* used to set hw ethernet address */ - - PRINTK2("%s:smc_open\n", dev->name); - - /* reset the hardware */ - - smc_reset(dev); - smc_enable(dev); - - SMC_SELECT_BANK(dev, 1); - /* set smc_mac_addr, and sync it with u-boot globals */ - err = smc_get_ethaddr(bd, dev); - if (err < 0) - return -1; -#ifdef USE_32_BIT - for (i = 0; i < 6; i += 2) { - word address; - - address = smc_mac_addr[i + 1] << 8; - address |= smc_mac_addr[i]; - SMC_outw(dev, address, LAN91C96_IA0 + i); - } -#else - for (i = 0; i < 6; i++) - SMC_outb(dev, smc_mac_addr[i], LAN91C96_IA0 + i); -#endif - return 0; -} - -/*------------------------------------------------------------- - * - * smc_rcv - receive a packet from the card - * - * There is ( at least ) a packet waiting to be read from - * chip-memory. - * - * o Read the status - * o If an error, record it - * o otherwise, read in the packet - *------------------------------------------------------------- - */ -static int smc_rcv(struct eth_device *dev) -{ - int packet_number; - word status; - word packet_length; - int is_error = 0; - -#ifdef USE_32_BIT - dword stat_len; -#endif - - - SMC_SELECT_BANK(dev, 2); - packet_number = SMC_inw(dev, LAN91C96_FIFO); - - if (packet_number & LAN91C96_FIFO_RXEMPTY) { - return 0; - } - - PRINTK3("%s:smc_rcv\n", dev->name); - /* start reading from the start of the packet */ - SMC_outw(dev, LAN91C96_PTR_READ | LAN91C96_PTR_RCV | - LAN91C96_PTR_AUTO_INCR, LAN91C96_POINTER); - - /* First two words are status and packet_length */ -#ifdef USE_32_BIT - stat_len = SMC_inl(dev, LAN91C96_DATA_HIGH); - status = stat_len & 0xffff; - packet_length = stat_len >> 16; -#else - status = SMC_inw(dev, LAN91C96_DATA_HIGH); - packet_length = SMC_inw(dev, LAN91C96_DATA_HIGH); -#endif - - packet_length &= 0x07ff; /* mask off top bits */ - - PRINTK2 ("RCV: STATUS %4x LENGTH %4x\n", status, packet_length); - - if (!(status & FRAME_FILTER)) { - /* Adjust for having already read the first two words */ - packet_length -= 4; /*4; */ - - - /* set odd length for bug in LAN91C111, */ - /* which never sets RS_ODDFRAME */ - /* TODO ? */ - - -#ifdef USE_32_BIT - PRINTK3 (" Reading %d dwords (and %d bytes) \n", - packet_length >> 2, packet_length & 3); - /* QUESTION: Like in the TX routine, do I want - to send the DWORDs or the bytes first, or some - mixture. A mixture might improve already slow PIO - performance */ - SMC_insl(dev, LAN91C96_DATA_HIGH, net_rx_packets[0], - packet_length >> 2); - /* read the left over bytes */ - if (packet_length & 3) { - int i; - - byte *tail = (byte *)(net_rx_packets[0] + - (packet_length & ~3)); - dword leftover = SMC_inl(dev, LAN91C96_DATA_HIGH); - - for (i = 0; i < (packet_length & 3); i++) - *tail++ = (byte) (leftover >> (8 * i)) & 0xff; - } -#else - PRINTK3(" Reading %d words and %d byte(s)\n", - (packet_length >> 1), packet_length & 1); - SMC_insw(dev, LAN91C96_DATA_HIGH, net_rx_packets[0], - packet_length >> 1); - -#endif /* USE_32_BIT */ - -#if SMC_DEBUG > 2 - printf ("Receiving Packet\n"); - print_packet((byte *)net_rx_packets[0], packet_length); -#endif - } else { - /* error ... */ - /* TODO ? */ - is_error = 1; - } - - while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) - udelay(1); /* Wait until not busy */ - - /* error or good, tell the card to get rid of this packet */ - SMC_outw(dev, LAN91C96_MMUCR_RELEASE_RX, LAN91C96_MMU); - - while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) - udelay(1); /* Wait until not busy */ - - if (!is_error) { - /* Pass the packet up to the protocol layers. */ - net_process_received_packet(net_rx_packets[0], packet_length); - return packet_length; - } else { - return 0; - } - -} - -/*---------------------------------------------------- - * smc_close - * - * this makes the board clean up everything that it can - * and not talk to the outside world. Caused by - * an 'ifconfig ethX down' - * - -----------------------------------------------------*/ -static int smc_close(struct eth_device *dev) -{ - PRINTK2("%s:smc_close\n", dev->name); - - /* clear everything */ - smc_shutdown(dev); - - return 0; -} - -#if SMC_DEBUG > 2 -static void print_packet(byte *buf, int length) -{ -#if 0 - int i; - int remainder; - int lines; - - printf ("Packet of length %d \n", length); - - lines = length / 16; - remainder = length % 16; - - for (i = 0; i < lines; i++) { - int cur; - - for (cur = 0; cur < 8; cur++) { - byte a, b; - - a = *(buf++); - b = *(buf++); - printf ("%02x%02x ", a, b); - } - printf ("\n"); - } - for (i = 0; i < remainder / 2; i++) { - byte a, b; - - a = *(buf++); - b = *(buf++); - printf ("%02x%02x ", a, b); - } - printf ("\n"); -#endif /* 0 */ -} -#endif /* SMC_DEBUG > 2 */ - -static int lan91c96_init(struct eth_device *dev, struct bd_info *bd) -{ - return smc_open(bd, dev); -} - -static void lan91c96_halt(struct eth_device *dev) -{ - smc_close(dev); -} - -static int lan91c96_recv(struct eth_device *dev) -{ - return smc_rcv(dev); -} - -static int lan91c96_send(struct eth_device *dev, void *packet, - int length) -{ - return smc_send_packet(dev, packet, length); -} - -/* smc_get_ethaddr - * - * This checks both the environment and the ROM for an ethernet address. If - * found, the environment takes precedence. - */ - -static int smc_get_ethaddr(struct bd_info *bd, struct eth_device *dev) -{ - uchar v_mac[6]; - - if (!eth_env_get_enetaddr("ethaddr", v_mac)) { - /* get ROM mac value if any */ - if (!get_rom_mac(dev, v_mac)) { - printf("\n*** ERROR: ethaddr is NOT set !!\n"); - return -1; - } - eth_env_set_enetaddr("ethaddr", v_mac); - } - - smc_set_mac_addr(v_mac); /* use old function to update smc default */ - PRINTK("Using MAC Address %pM\n", v_mac); - return 0; -} - -/* - * get_rom_mac() - * Note, this has omly been tested for the OMAP730 P2. - */ - -static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac) -{ - int i; - SMC_SELECT_BANK(dev, 1); - for (i=0; i<6; i++) - { - v_rom_mac[i] = SMC_inb(dev, LAN91C96_IA0 + i); - } - return (1); -} - -/* Structure to detect the device IDs */ -struct id_type { - u8 id; - char *name; -}; -static struct id_type supported_chips[] = { - {0, ""}, /* Dummy entry to prevent id check failure */ - {9, "LAN91C110"}, - {8, "LAN91C100FD"}, - {7, "LAN91C100"}, - {5, "LAN91C95"}, - {4, "LAN91C94/96"}, - {3, "LAN91C90/92"}, -}; -/* lan91c96_detect_chip - * See: - * http://www.embeddedsys.com/subpages/resources/images/documents/LAN91C96_data... - * page 71 - that is the closest we get to detect this device - */ -static int lan91c96_detect_chip(struct eth_device *dev) -{ - u8 chip_id; - int r; - SMC_SELECT_BANK(dev, 3); - chip_id = (SMC_inw(dev, 0xA) & LAN91C96_REV_CHIPID) >> 4; - SMC_SELECT_BANK(dev, 0); - for (r = 0; r < ARRAY_SIZE(supported_chips); r++) - if (chip_id == supported_chips[r].id) - return r; - return 0; -} - -int lan91c96_initialize(u8 dev_num, int base_addr) -{ - struct eth_device *dev; - int r = 0; - - dev = malloc(sizeof(*dev)); - if (!dev) { - return 0; - } - memset(dev, 0, sizeof(*dev)); - - dev->iobase = base_addr; - - /* Try to detect chip. Will fail if not present. */ - r = lan91c96_detect_chip(dev); - if (!r) { - free(dev); - return 0; - } - get_rom_mac(dev, dev->enetaddr); - - dev->init = lan91c96_init; - dev->halt = lan91c96_halt; - dev->send = lan91c96_send; - dev->recv = lan91c96_recv; - sprintf(dev->name, "%s-%hu", supported_chips[r].name, dev_num); - - eth_register(dev); - return 0; -} diff --git a/drivers/net/lan91c96.h b/drivers/net/lan91c96.h deleted file mode 100644 index c76348084a33..000000000000 --- a/drivers/net/lan91c96.h +++ /dev/null @@ -1,616 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/*------------------------------------------------------------------------ - * lan91c96.h - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Rolf Offermanns rof@sysgo.de - * Copyright (C) 2001 Standard Microsystems Corporation (SMSC) - * Developed by Simple Network Magic Corporation (SNMC) - * Copyright (C) 1996 by Erik Stahlman (ES) - * - * This file contains register information and access macros for - * the LAN91C96 single chip ethernet controller. It is a modified - * version of the smc9111.h file. - * - * Information contained in this file was obtained from the LAN91C96 - * manual from SMC. To get a copy, if you really want one, you can find - * information under www.smsc.com. - * - * Authors - * Erik Stahlman ( erik@vt.edu ) - * Daris A Nevil ( dnevil@snmc.com ) - * - * History - * 04/30/03 Mathijs Haarman Modified smc91111.h (u-boot version) - * for lan91c96 - *------------------------------------------------------------------------- - */ -#ifndef _LAN91C96_H_ -#define _LAN91C96_H_ - -#include <asm/types.h> -#include <asm/io.h> -#include <config.h> - -/* I want some simple types */ - -typedef unsigned char byte; -typedef unsigned short word; -typedef unsigned long int dword; - -/* - * DEBUGGING LEVELS - * - * 0 for normal operation - * 1 for slightly more details - * >2 for various levels of increasingly useless information - * 2 for interrupt tracking, status flags - * 3 for packet info - * 4 for complete packet dumps - */ -/*#define SMC_DEBUG 0 */ - -/* Because of bank switching, the LAN91xxx uses only 16 I/O ports */ - -#define SMC_IO_EXTENT 16 - -#ifdef CONFIG_CPU_PXA25X - -#define SMC_IO_SHIFT 0 - -#define SMCREG(edev, r) ((edev)->iobase+((r)<<SMC_IO_SHIFT)) - -#define SMC_inl(edev, r) (*((volatile dword *)SMCREG(edev, r))) -#define SMC_inw(edev, r) (*((volatile word *)SMCREG(edev, r))) -#define SMC_inb(edev, p) ({ \ - unsigned int __p = p; \ - unsigned int __v = SMC_inw(edev, __p & ~1); \ - if (__p & 1) __v >>= 8; \ - else __v &= 0xff; \ - __v; }) - -#define SMC_outl(edev, d, r) (*((volatile dword *)SMCREG(edev, r)) = d) -#define SMC_outw(edev, d, r) (*((volatile word *)SMCREG(edev, r)) = d) -#define SMC_outb(edev, d, r) ({ word __d = (byte)(d); \ - word __w = SMC_inw(edev, (r)&~1); \ - __w &= ((r)&1) ? 0x00FF : 0xFF00; \ - __w |= ((r)&1) ? __d<<8 : __d; \ - SMC_outw(edev, __w, (r)&~1); \ - }) - -#define SMC_outsl(edev, r, b, l) ({ int __i; \ - dword *__b2; \ - __b2 = (dword *) b; \ - for (__i = 0; __i < l; __i++) { \ - SMC_outl(edev, *(__b2 + __i),\ - r); \ - } \ - }) - -#define SMC_outsw(edev, r, b, l) ({ int __i; \ - word *__b2; \ - __b2 = (word *) b; \ - for (__i = 0; __i < l; __i++) { \ - SMC_outw(edev, *(__b2 + __i),\ - r); \ - } \ - }) - -#define SMC_insl(edev, r, b, l) ({ int __i ; \ - dword *__b2; \ - __b2 = (dword *) b; \ - for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inl(edev,\ - r); \ - SMC_inl(edev, 0); \ - }; \ - }) - -#define SMC_insw(edev, r, b, l) ({ int __i ; \ - word *__b2; \ - __b2 = (word *) b; \ - for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inw(edev,\ - r); \ - SMC_inw(edev, 0); \ - }; \ - }) - -#define SMC_insb(edev, r, b, l) ({ int __i ; \ - byte *__b2; \ - __b2 = (byte *) b; \ - for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inb(edev,\ - r); \ - SMC_inb(edev, 0); \ - }; \ - }) - -#else /* if not CONFIG_CPU_PXA25X */ - -/* - * We have only 16 Bit PCMCIA access on Socket 0 - */ - -#define SMC_inw(edev, r) (*((volatile word *)((edev)->iobase+(r)))) -#define SMC_inb(edev, r) (((r)&1) ? SMC_inw(edev, (r)&~1)>>8 :\ - SMC_inw(edev, r)&0xFF) - -#define SMC_outw(edev, d, r) (*((volatile word *)((edev)->iobase+(r))) = d) -#define SMC_outb(edev, d, r) ({ word __d = (byte)(d); \ - word __w = SMC_inw(edev, (r)&~1); \ - __w &= ((r)&1) ? 0x00FF : 0xFF00; \ - __w |= ((r)&1) ? __d<<8 : __d; \ - SMC_outw(edev, __w, (r)&~1); \ - }) -#define SMC_outsw(edev, r, b, l) ({ int __i; \ - word *__b2; \ - __b2 = (word *) b; \ - for (__i = 0; __i < l; __i++) { \ - SMC_outw(edev, *(__b2 + __i),\ - r); \ - } \ - }) - -#define SMC_insw(edev, r, b, l) ({ int __i ; \ - word *__b2; \ - __b2 = (word *) b; \ - for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inw(edev,\ - r); \ - SMC_inw(edev, 0); \ - }; \ - }) - -#endif - -/* - **************************************************************************** - * Bank Select Field - **************************************************************************** - */ -#define LAN91C96_BANK_SELECT 14 /* Bank Select Register */ -#define LAN91C96_BANKSELECT (0x3UC << 0) -#define BANK0 0x00 -#define BANK1 0x01 -#define BANK2 0x02 -#define BANK3 0x03 -#define BANK4 0x04 - -/* - **************************************************************************** - * EEPROM Addresses. - **************************************************************************** - */ -#define EEPROM_MAC_OFFSET_1 0x6020 -#define EEPROM_MAC_OFFSET_2 0x6021 -#define EEPROM_MAC_OFFSET_3 0x6022 - -/* - **************************************************************************** - * Bank 0 Register Map in I/O Space - **************************************************************************** - */ -#define LAN91C96_TCR 0 /* Transmit Control Register */ -#define LAN91C96_EPH_STATUS 2 /* EPH Status Register */ -#define LAN91C96_RCR 4 /* Receive Control Register */ -#define LAN91C96_COUNTER 6 /* Counter Register */ -#define LAN91C96_MIR 8 /* Memory Information Register */ -#define LAN91C96_MCR 10 /* Memory Configuration Register */ - -/* - **************************************************************************** - * Transmit Control Register - Bank 0 - Offset 0 - **************************************************************************** - */ -#define LAN91C96_TCR_TXENA (0x1U << 0) -#define LAN91C96_TCR_LOOP (0x1U << 1) -#define LAN91C96_TCR_FORCOL (0x1U << 2) -#define LAN91C96_TCR_TXP_EN (0x1U << 3) -#define LAN91C96_TCR_PAD_EN (0x1U << 7) -#define LAN91C96_TCR_NOCRC (0x1U << 8) -#define LAN91C96_TCR_MON_CSN (0x1U << 10) -#define LAN91C96_TCR_FDUPLX (0x1U << 11) -#define LAN91C96_TCR_STP_SQET (0x1U << 12) -#define LAN91C96_TCR_EPH_LOOP (0x1U << 13) -#define LAN91C96_TCR_ETEN_TYPE (0x1U << 14) -#define LAN91C96_TCR_FDSE (0x1U << 15) - -/* - **************************************************************************** - * EPH Status Register - Bank 0 - Offset 2 - **************************************************************************** - */ -#define LAN91C96_EPHSR_TX_SUC (0x1U << 0) -#define LAN91C96_EPHSR_SNGL_COL (0x1U << 1) -#define LAN91C96_EPHSR_MUL_COL (0x1U << 2) -#define LAN91C96_EPHSR_LTX_MULT (0x1U << 3) -#define LAN91C96_EPHSR_16COL (0x1U << 4) -#define LAN91C96_EPHSR_SQET (0x1U << 5) -#define LAN91C96_EPHSR_LTX_BRD (0x1U << 6) -#define LAN91C96_EPHSR_TX_DEFR (0x1U << 7) -#define LAN91C96_EPHSR_WAKEUP (0x1U << 8) -#define LAN91C96_EPHSR_LATCOL (0x1U << 9) -#define LAN91C96_EPHSR_LOST_CARR (0x1U << 10) -#define LAN91C96_EPHSR_EXC_DEF (0x1U << 11) -#define LAN91C96_EPHSR_CTR_ROL (0x1U << 12) - -#define LAN91C96_EPHSR_LINK_OK (0x1U << 14) -#define LAN91C96_EPHSR_TX_UNRN (0x1U << 15) - -#define LAN91C96_EPHSR_ERRORS (LAN91C96_EPHSR_SNGL_COL | \ - LAN91C96_EPHSR_MUL_COL | \ - LAN91C96_EPHSR_16COL | \ - LAN91C96_EPHSR_SQET | \ - LAN91C96_EPHSR_TX_DEFR | \ - LAN91C96_EPHSR_LATCOL | \ - LAN91C96_EPHSR_LOST_CARR | \ - LAN91C96_EPHSR_EXC_DEF | \ - LAN91C96_EPHSR_LINK_OK | \ - LAN91C96_EPHSR_TX_UNRN) - -/* - **************************************************************************** - * Receive Control Register - Bank 0 - Offset 4 - **************************************************************************** - */ -#define LAN91C96_RCR_RX_ABORT (0x1U << 0) -#define LAN91C96_RCR_PRMS (0x1U << 1) -#define LAN91C96_RCR_ALMUL (0x1U << 2) -#define LAN91C96_RCR_RXEN (0x1U << 8) -#define LAN91C96_RCR_STRIP_CRC (0x1U << 9) -#define LAN91C96_RCR_FILT_CAR (0x1U << 14) -#define LAN91C96_RCR_SOFT_RST (0x1U << 15) - -/* - **************************************************************************** - * Counter Register - Bank 0 - Offset 6 - **************************************************************************** - */ -#define LAN91C96_ECR_SNGL_COL (0xFU << 0) -#define LAN91C96_ECR_MULT_COL (0xFU << 5) -#define LAN91C96_ECR_DEF_TX (0xFU << 8) -#define LAN91C96_ECR_EXC_DEF_TX (0xFU << 12) - -/* - **************************************************************************** - * Memory Information Register - Bank 0 - OFfset 8 - **************************************************************************** - */ -#define LAN91C96_MIR_SIZE (0x18 << 0) /* 6144 bytes */ - -/* - **************************************************************************** - * Memory Configuration Register - Bank 0 - Offset 10 - **************************************************************************** - */ -#define LAN91C96_MCR_MEM_RES (0xFFU << 0) -#define LAN91C96_MCR_MEM_MULT (0x3U << 9) -#define LAN91C96_MCR_HIGH_ID (0x3U << 12) - -#define LAN91C96_MCR_TRANSMIT_PAGES 0x6 - -/* - **************************************************************************** - * Bank 1 Register Map in I/O Space - **************************************************************************** - */ -#define LAN91C96_CONFIG 0 /* Configuration Register */ -#define LAN91C96_BASE 2 /* Base Address Register */ -#define LAN91C96_IA0 4 /* Individual Address Register - 0 */ -#define LAN91C96_IA1 5 /* Individual Address Register - 1 */ -#define LAN91C96_IA2 6 /* Individual Address Register - 2 */ -#define LAN91C96_IA3 7 /* Individual Address Register - 3 */ -#define LAN91C96_IA4 8 /* Individual Address Register - 4 */ -#define LAN91C96_IA5 9 /* Individual Address Register - 5 */ -#define LAN91C96_GEN_PURPOSE 10 /* General Address Registers */ -#define LAN91C96_CONTROL 12 /* Control Register */ - -/* - **************************************************************************** - * Configuration Register - Bank 1 - Offset 0 - **************************************************************************** - */ -#define LAN91C96_CR_INT_SEL0 (0x1U << 1) -#define LAN91C96_CR_INT_SEL1 (0x1U << 2) -#define LAN91C96_CR_RES (0x3U << 3) -#define LAN91C96_CR_DIS_LINK (0x1U << 6) -#define LAN91C96_CR_16BIT (0x1U << 7) -#define LAN91C96_CR_AUI_SELECT (0x1U << 8) -#define LAN91C96_CR_SET_SQLCH (0x1U << 9) -#define LAN91C96_CR_FULL_STEP (0x1U << 10) -#define LAN91C96_CR_NO_WAIT (0x1U << 12) - -/* - **************************************************************************** - * Base Address Register - Bank 1 - Offset 2 - **************************************************************************** - */ -#define LAN91C96_BAR_RA_BITS (0x27U << 0) -#define LAN91C96_BAR_ROM_SIZE (0x1U << 6) -#define LAN91C96_BAR_A_BITS (0xFFU << 8) - -/* - **************************************************************************** - * Control Register - Bank 1 - Offset 12 - **************************************************************************** - */ -#define LAN91C96_CTR_STORE (0x1U << 0) -#define LAN91C96_CTR_RELOAD (0x1U << 1) -#define LAN91C96_CTR_EEPROM (0x1U << 2) -#define LAN91C96_CTR_TE_ENABLE (0x1U << 5) -#define LAN91C96_CTR_CR_ENABLE (0x1U << 6) -#define LAN91C96_CTR_LE_ENABLE (0x1U << 7) -#define LAN91C96_CTR_BIT_8 (0x1U << 8) -#define LAN91C96_CTR_AUTO_RELEASE (0x1U << 11) -#define LAN91C96_CTR_WAKEUP_EN (0x1U << 12) -#define LAN91C96_CTR_PWRDN (0x1U << 13) -#define LAN91C96_CTR_RCV_BAD (0x1U << 14) - -/* - **************************************************************************** - * Bank 2 Register Map in I/O Space - **************************************************************************** - */ -#define LAN91C96_MMU 0 /* MMU Command Register */ -#define LAN91C96_AUTO_TX_START 1 /* Auto Tx Start Register */ -#define LAN91C96_PNR 2 /* Packet Number Register */ -#define LAN91C96_ARR 3 /* Allocation Result Register */ -#define LAN91C96_FIFO 4 /* FIFO Ports Register */ -#define LAN91C96_POINTER 6 /* Pointer Register */ -#define LAN91C96_DATA_HIGH 8 /* Data High Register */ -#define LAN91C96_DATA_LOW 10 /* Data Low Register */ -#define LAN91C96_INT_STATS 12 /* Interrupt Status Register - RO */ -#define LAN91C96_INT_ACK 12 /* Interrupt Acknowledge Register -WO */ -#define LAN91C96_INT_MASK 13 /* Interrupt Mask Register */ - -/* - **************************************************************************** - * MMU Command Register - Bank 2 - Offset 0 - **************************************************************************** - */ -#define LAN91C96_MMUCR_NO_BUSY (0x1U << 0) -#define LAN91C96_MMUCR_N1 (0x1U << 1) -#define LAN91C96_MMUCR_N2 (0x1U << 2) -#define LAN91C96_MMUCR_COMMAND (0xFU << 4) -#define LAN91C96_MMUCR_ALLOC_TX (0x2U << 4) /* WXYZ = 0010 */ -#define LAN91C96_MMUCR_RESET_MMU (0x4U << 4) /* WXYZ = 0100 */ -#define LAN91C96_MMUCR_REMOVE_RX (0x6U << 4) /* WXYZ = 0110 */ -#define LAN91C96_MMUCR_REMOVE_TX (0x7U << 4) /* WXYZ = 0111 */ -#define LAN91C96_MMUCR_RELEASE_RX (0x8U << 4) /* WXYZ = 1000 */ -#define LAN91C96_MMUCR_RELEASE_TX (0xAU << 4) /* WXYZ = 1010 */ -#define LAN91C96_MMUCR_ENQUEUE (0xCU << 4) /* WXYZ = 1100 */ -#define LAN91C96_MMUCR_RESET_TX (0xEU << 4) /* WXYZ = 1110 */ - -/* - **************************************************************************** - * Auto Tx Start Register - Bank 2 - Offset 1 - **************************************************************************** - */ -#define LAN91C96_AUTOTX (0xFFU << 0) - -/* - **************************************************************************** - * Packet Number Register - Bank 2 - Offset 2 - **************************************************************************** - */ -#define LAN91C96_PNR_TX (0x1FU << 0) - -/* - **************************************************************************** - * Allocation Result Register - Bank 2 - Offset 3 - **************************************************************************** - */ -#define LAN91C96_ARR_ALLOC_PN (0x7FU << 0) -#define LAN91C96_ARR_FAILED (0x1U << 7) - -/* - **************************************************************************** - * FIFO Ports Register - Bank 2 - Offset 4 - **************************************************************************** - */ -#define LAN91C96_FIFO_TX_DONE_PN (0x1FU << 0) -#define LAN91C96_FIFO_TEMPTY (0x1U << 7) -#define LAN91C96_FIFO_RX_DONE_PN (0x1FU << 8) -#define LAN91C96_FIFO_RXEMPTY (0x1U << 15) - -/* - **************************************************************************** - * Pointer Register - Bank 2 - Offset 6 - **************************************************************************** - */ -#define LAN91C96_PTR_LOW (0xFFU << 0) -#define LAN91C96_PTR_HIGH (0x7U << 8) -#define LAN91C96_PTR_AUTO_TX (0x1U << 11) -#define LAN91C96_PTR_ETEN (0x1U << 12) -#define LAN91C96_PTR_READ (0x1U << 13) -#define LAN91C96_PTR_AUTO_INCR (0x1U << 14) -#define LAN91C96_PTR_RCV (0x1U << 15) - -#define LAN91C96_PTR_RX_FRAME (LAN91C96_PTR_RCV | \ - LAN91C96_PTR_AUTO_INCR | \ - LAN91C96_PTR_READ) - -/* - **************************************************************************** - * Data Register - Bank 2 - Offset 8 - **************************************************************************** - */ -#define LAN91C96_CONTROL_CRC (0x1U << 4) /* CRC bit */ -#define LAN91C96_CONTROL_ODD (0x1U << 5) /* ODD bit */ - -/* - **************************************************************************** - * Interrupt Status Register - Bank 2 - Offset 12 - **************************************************************************** - */ -#define LAN91C96_IST_RCV_INT (0x1U << 0) -#define LAN91C96_IST_TX_INT (0x1U << 1) -#define LAN91C96_IST_TX_EMPTY_INT (0x1U << 2) -#define LAN91C96_IST_ALLOC_INT (0x1U << 3) -#define LAN91C96_IST_RX_OVRN_INT (0x1U << 4) -#define LAN91C96_IST_EPH_INT (0x1U << 5) -#define LAN91C96_IST_ERCV_INT (0x1U << 6) -#define LAN91C96_IST_RX_IDLE_INT (0x1U << 7) - -/* - **************************************************************************** - * Interrupt Acknowledge Register - Bank 2 - Offset 12 - **************************************************************************** - */ -#define LAN91C96_ACK_TX_INT (0x1U << 1) -#define LAN91C96_ACK_TX_EMPTY_INT (0x1U << 2) -#define LAN91C96_ACK_RX_OVRN_INT (0x1U << 4) -#define LAN91C96_ACK_ERCV_INT (0x1U << 6) - -/* - **************************************************************************** - * Interrupt Mask Register - Bank 2 - Offset 13 - **************************************************************************** - */ -#define LAN91C96_MSK_RCV_INT (0x1U << 0) -#define LAN91C96_MSK_TX_INT (0x1U << 1) -#define LAN91C96_MSK_TX_EMPTY_INT (0x1U << 2) -#define LAN91C96_MSK_ALLOC_INT (0x1U << 3) -#define LAN91C96_MSK_RX_OVRN_INT (0x1U << 4) -#define LAN91C96_MSK_EPH_INT (0x1U << 5) -#define LAN91C96_MSK_ERCV_INT (0x1U << 6) -#define LAN91C96_MSK_TX_IDLE_INT (0x1U << 7) - -/* - **************************************************************************** - * Bank 3 Register Map in I/O Space - ************************************************************************** - */ -#define LAN91C96_MGMT_MDO (0x1U << 0) -#define LAN91C96_MGMT_MDI (0x1U << 1) -#define LAN91C96_MGMT_MCLK (0x1U << 2) -#define LAN91C96_MGMT_MDOE (0x1U << 3) -#define LAN91C96_MGMT_LOW_ID (0x3U << 4) -#define LAN91C96_MGMT_IOS0 (0x1U << 8) -#define LAN91C96_MGMT_IOS1 (0x1U << 9) -#define LAN91C96_MGMT_IOS2 (0x1U << 10) -#define LAN91C96_MGMT_nXNDEC (0x1U << 11) -#define LAN91C96_MGMT_HIGH_ID (0x3U << 12) - -/* - **************************************************************************** - * Revision Register - Bank 3 - Offset 10 - **************************************************************************** - */ -#define LAN91C96_REV_REVID (0xFU << 0) -#define LAN91C96_REV_CHIPID (0xFU << 4) - -/* - **************************************************************************** - * Early RCV Register - Bank 3 - Offset 12 - **************************************************************************** - */ -#define LAN91C96_ERCV_THRESHOLD (0x1FU << 0) -#define LAN91C96_ERCV_RCV_DISCRD (0x1U << 7) - -/* - **************************************************************************** - * PCMCIA Configuration Registers - **************************************************************************** - */ -#define LAN91C96_ECOR 0x8000 /* Ethernet Configuration Register */ -#define LAN91C96_ECSR 0x8002 /* Ethernet Configuration and Status */ - -/* - **************************************************************************** - * PCMCIA Ethernet Configuration Option Register (ECOR) - **************************************************************************** - */ -#define LAN91C96_ECOR_ENABLE (0x1U << 0) -#define LAN91C96_ECOR_WR_ATTRIB (0x1U << 2) -#define LAN91C96_ECOR_LEVEL_REQ (0x1U << 6) -#define LAN91C96_ECOR_SRESET (0x1U << 7) - -/* - **************************************************************************** - * PCMCIA Ethernet Configuration and Status Register (ECSR) - **************************************************************************** - */ -#define LAN91C96_ECSR_INTR (0x1U << 1) -#define LAN91C96_ECSR_PWRDWN (0x1U << 2) -#define LAN91C96_ECSR_IOIS8 (0x1U << 5) - -/* - **************************************************************************** - * Receive Frame Status Word - See page 38 of the LAN91C96 specification. - **************************************************************************** - */ -#define LAN91C96_TOO_SHORT (0x1U << 10) -#define LAN91C96_TOO_LONG (0x1U << 11) -#define LAN91C96_ODD_FRM (0x1U << 12) -#define LAN91C96_BAD_CRC (0x1U << 13) -#define LAN91C96_BROD_CAST (0x1U << 14) -#define LAN91C96_ALGN_ERR (0x1U << 15) - -#define FRAME_FILTER (LAN91C96_TOO_SHORT | LAN91C96_TOO_LONG | LAN91C96_BAD_CRC | LAN91C96_ALGN_ERR) - -/* - **************************************************************************** - * Default MAC Address - **************************************************************************** - */ -#define MAC_DEF_HI 0x0800 -#define MAC_DEF_MED 0x3333 -#define MAC_DEF_LO 0x0100 - -/* - **************************************************************************** - * Default I/O Signature - 0x33 - **************************************************************************** - */ -#define LAN91C96_LOW_SIGNATURE (0x33U << 0) -#define LAN91C96_HIGH_SIGNATURE (0x33U << 8) -#define LAN91C96_SIGNATURE (LAN91C96_HIGH_SIGNATURE | LAN91C96_LOW_SIGNATURE) - -#define LAN91C96_MAX_PAGES 6 /* Maximum number of 256 pages. */ -#define ETHERNET_MAX_LENGTH 1514 - - -/*------------------------------------------------------------------------- - * I define some macros to make it easier to do somewhat common - * or slightly complicated, repeated tasks. - *------------------------------------------------------------------------- - */ - -/* select a register bank, 0 to 3 */ - -#define SMC_SELECT_BANK(edev, x) { SMC_outw(edev, x, LAN91C96_BANK_SELECT); } - -/* this enables an interrupt in the interrupt mask register */ -#define SMC_ENABLE_INT(edev, x) {\ - unsigned char mask;\ - SMC_SELECT_BANK(edev, 2);\ - mask = SMC_inb(edev, LAN91C96_INT_MASK);\ - mask |= (x);\ - SMC_outb(edev, mask, LAN91C96_INT_MASK); \ -} - -/* this disables an interrupt from the interrupt mask register */ - -#define SMC_DISABLE_INT(edev, x) {\ - unsigned char mask;\ - SMC_SELECT_BANK(edev, 2);\ - mask = SMC_inb(edev, LAN91C96_INT_MASK);\ - mask &= ~(x);\ - SMC_outb(edev, mask, LAN91C96_INT_MASK); \ -} - -/*---------------------------------------------------------------------- - * Define the interrupts that I want to receive from the card - * - * I want: - * LAN91C96_IST_EPH_INT, for nasty errors - * LAN91C96_IST_RCV_INT, for happy received packets - * LAN91C96_IST_RX_OVRN_INT, because I have to kick the receiver - *------------------------------------------------------------------------- - */ -#define SMC_INTERRUPT_MASK (LAN91C96_IST_EPH_INT | LAN91C96_IST_RX_OVRN_INT | LAN91C96_IST_RCV_INT) - -#endif /* _LAN91C96_H_ */
On Thu, Mar 31, 2022 at 01:46:49PM -0400, Tom Rini wrote:
This driver is not enabled by any board and not converted to DM_ETH. Remove.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/natsemi.c | 883 ------------------------------------------ 2 files changed, 884 deletions(-) delete mode 100644 drivers/net/natsemi.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index be3264e04133..f902f0d06c26 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -64,7 +64,6 @@ obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o obj-$(CONFIG_MVPP2) += mvpp2.o -obj-$(CONFIG_NATSEMI) += natsemi.o obj-$(CONFIG_NETCONSOLE) += netconsole.o obj-$(CONFIG_NET_OCTEONTX) += octeontx/ obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ diff --git a/drivers/net/natsemi.c b/drivers/net/natsemi.c deleted file mode 100644 index bfd8cc396b98..000000000000 --- a/drivers/net/natsemi.c +++ /dev/null @@ -1,883 +0,0 @@ -/* - natsemi.c: A U-Boot driver for the NatSemi DP8381x series. - Author: Mark A. Rakes (mark_rakes@vivato.net) - - Adapted from an Etherboot driver written by: - - Copyright (C) 2001 Entity Cyber, Inc. - - This development of this Etherboot driver was funded by - - Sicom Systems: http://www.sicompos.com/ - - Author: Marty Connor (mdc@thinguin.org) - Adapted from a Linux driver which was written by Donald Becker - - This software may be used and distributed according to the terms - of the GNU Public License (GPL), incorporated herein by reference. - - Original Copyright Notice: - - Written/copyright 1999-2001 by Donald Becker. - - This software may be used and distributed according to the terms of - the GNU General Public License (GPL), incorporated herein by reference. - Drivers based on or derived from this code fall under the GPL and must - retain the authorship, copyright and license notice. This file is not - a complete program and may only be used when the entire operating - system is licensed under the GPL. License for under other terms may be - available. Contact the original author for details. - - The original author may be reached as becker@scyld.com, or at - Scyld Computing Corporation - 410 Severn Ave., Suite 210 - Annapolis MD 21403 - - Support information and updates available at - http://www.scyld.com/network/netsemi.html - - References: - http://www.scyld.com/expert/100mbps.html - http://www.scyld.com/expert/NWay.html - Datasheet is available from: - http://www.national.com/pf/DP/DP83815.html -*/ - -/* Revision History - * October 2002 mar 1.0 - * Initial U-Boot Release. Tested with Netgear FA311 board - * and dp83815 chipset on custom board -*/ - -/* Includes */ -#include <common.h> -#include <malloc.h> -#include <net.h> -#include <netdev.h> -#include <asm/io.h> -#include <pci.h> -#include <linux/delay.h> - -/* defines */ -#define EEPROM_SIZE 0xb /*12 16-bit chunks, or 24 bytes*/ - -#define DSIZE 0x00000FFF -#define CRC_SIZE 4 -#define TOUT_LOOP 500000 -#define TX_BUF_SIZE 1536 -#define RX_BUF_SIZE 1536 -#define NUM_RX_DESC 4 /* Number of Rx descriptor registers. */ - -/* Offsets to the device registers. - Unlike software-only systems, device drivers interact with complex hardware. - It's not useful to define symbolic names for every register bit in the - device. */ -enum register_offsets { - ChipCmd = 0x00, - ChipConfig = 0x04, - EECtrl = 0x08, - IntrMask = 0x14, - IntrEnable = 0x18, - TxRingPtr = 0x20, - TxConfig = 0x24, - RxRingPtr = 0x30, - RxConfig = 0x34, - ClkRun = 0x3C, - RxFilterAddr = 0x48, - RxFilterData = 0x4C, - SiliconRev = 0x58, - PCIPM = 0x44, - BasicControl = 0x80, - BasicStatus = 0x84, - /* These are from the spec, around page 78... on a separate table. */ - PGSEL = 0xCC, - PMDCSR = 0xE4, - TSTDAT = 0xFC, - DSPCFG = 0xF4, - SDCFG = 0x8C -}; - -/* Bit in ChipCmd. */ -enum ChipCmdBits { - ChipReset = 0x100, - RxReset = 0x20, - TxReset = 0x10, - RxOff = 0x08, - RxOn = 0x04, - TxOff = 0x02, - TxOn = 0x01 -}; - -enum ChipConfigBits { - LinkSts = 0x80000000, - HundSpeed = 0x40000000, - FullDuplex = 0x20000000, - TenPolarity = 0x10000000, - AnegDone = 0x08000000, - AnegEnBothBoth = 0x0000E000, - AnegDis100Full = 0x0000C000, - AnegEn100Both = 0x0000A000, - AnegDis100Half = 0x00008000, - AnegEnBothHalf = 0x00006000, - AnegDis10Full = 0x00004000, - AnegEn10Both = 0x00002000, - DuplexMask = 0x00008000, - SpeedMask = 0x00004000, - AnegMask = 0x00002000, - AnegDis10Half = 0x00000000, - ExtPhy = 0x00001000, - PhyRst = 0x00000400, - PhyDis = 0x00000200, - BootRomDisable = 0x00000004, - BEMode = 0x00000001, -}; - -enum TxConfig_bits { - TxDrthMask = 0x3f, - TxFlthMask = 0x3f00, - TxMxdmaMask = 0x700000, - TxMxdma_512 = 0x0, - TxMxdma_4 = 0x100000, - TxMxdma_8 = 0x200000, - TxMxdma_16 = 0x300000, - TxMxdma_32 = 0x400000, - TxMxdma_64 = 0x500000, - TxMxdma_128 = 0x600000, - TxMxdma_256 = 0x700000, - TxCollRetry = 0x800000, - TxAutoPad = 0x10000000, - TxMacLoop = 0x20000000, - TxHeartIgn = 0x40000000, - TxCarrierIgn = 0x80000000 -}; - -enum RxConfig_bits { - RxDrthMask = 0x3e, - RxMxdmaMask = 0x700000, - RxMxdma_512 = 0x0, - RxMxdma_4 = 0x100000, - RxMxdma_8 = 0x200000, - RxMxdma_16 = 0x300000, - RxMxdma_32 = 0x400000, - RxMxdma_64 = 0x500000, - RxMxdma_128 = 0x600000, - RxMxdma_256 = 0x700000, - RxAcceptLong = 0x8000000, - RxAcceptTx = 0x10000000, - RxAcceptRunt = 0x40000000, - RxAcceptErr = 0x80000000 -}; - -/* Bits in the RxMode register. */ -enum rx_mode_bits { - AcceptErr = 0x20, - AcceptRunt = 0x10, - AcceptBroadcast = 0xC0000000, - AcceptMulticast = 0x00200000, - AcceptAllMulticast = 0x20000000, - AcceptAllPhys = 0x10000000, - AcceptMyPhys = 0x08000000 -}; - -typedef struct _BufferDesc { - u32 link; - vu_long cmdsts; - u32 bufptr; - u32 software_use; -} BufferDesc; - -/* Bits in network_desc.status */ -enum desc_status_bits { - DescOwn = 0x80000000, DescMore = 0x40000000, DescIntr = 0x20000000, - DescNoCRC = 0x10000000, DescPktOK = 0x08000000, - DescSizeMask = 0xfff, - - DescTxAbort = 0x04000000, DescTxFIFO = 0x02000000, - DescTxCarrier = 0x01000000, DescTxDefer = 0x00800000, - DescTxExcDefer = 0x00400000, DescTxOOWCol = 0x00200000, - DescTxExcColl = 0x00100000, DescTxCollCount = 0x000f0000, - - DescRxAbort = 0x04000000, DescRxOver = 0x02000000, - DescRxDest = 0x01800000, DescRxLong = 0x00400000, - DescRxRunt = 0x00200000, DescRxInvalid = 0x00100000, - DescRxCRC = 0x00080000, DescRxAlign = 0x00040000, - DescRxLoop = 0x00020000, DesRxColl = 0x00010000, -}; - -/* Globals */ -#ifdef NATSEMI_DEBUG -static int natsemi_debug = 0; /* 1 verbose debugging, 0 normal */ -#endif -static u32 SavedClkRun; -static unsigned int cur_rx; -static unsigned int advertising; -static unsigned int rx_config; -static unsigned int tx_config; - -/* Note: transmit and receive buffers and descriptors must be - longword aligned */ -static BufferDesc txd __attribute__ ((aligned(4))); -static BufferDesc rxd[NUM_RX_DESC] __attribute__ ((aligned(4))); - -static unsigned char txb[TX_BUF_SIZE] __attribute__ ((aligned(4))); -static unsigned char rxb[NUM_RX_DESC * RX_BUF_SIZE] - __attribute__ ((aligned(4))); - -/* Function Prototypes */ -#if 0 -static void write_eeprom(struct eth_device *dev, long addr, int location, - short value); -#endif -static int read_eeprom(struct eth_device *dev, long addr, int location); -static int mdio_read(struct eth_device *dev, int phy_id, int location); -static int natsemi_init(struct eth_device *dev, struct bd_info * bis); -static void natsemi_reset(struct eth_device *dev); -static void natsemi_init_rxfilter(struct eth_device *dev); -static void natsemi_init_txd(struct eth_device *dev); -static void natsemi_init_rxd(struct eth_device *dev); -static void natsemi_set_rx_mode(struct eth_device *dev); -static void natsemi_check_duplex(struct eth_device *dev); -static int natsemi_send(struct eth_device *dev, void *packet, int length); -static int natsemi_poll(struct eth_device *dev); -static void natsemi_disable(struct eth_device *dev); - -static struct pci_device_id supported[] = { - {PCI_VENDOR_ID_NS, PCI_DEVICE_ID_NS_83815}, - {} -}; - -#define bus_to_phys(a) pci_mem_to_phys((pci_dev_t)dev->priv, a) -#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) - -static inline int -INW(struct eth_device *dev, u_long addr) -{ - return le16_to_cpu(*(vu_short *) (addr + dev->iobase)); -} - -static int -INL(struct eth_device *dev, u_long addr) -{ - return le32_to_cpu(*(vu_long *) (addr + dev->iobase)); -} - -static inline void -OUTW(struct eth_device *dev, int command, u_long addr) -{ - *(vu_short *) ((addr + dev->iobase)) = cpu_to_le16(command); -} - -static inline void -OUTL(struct eth_device *dev, int command, u_long addr) -{ - *(vu_long *) ((addr + dev->iobase)) = cpu_to_le32(command); -} - -/* - * Function: natsemi_initialize - * - * Description: Retrieves the MAC address of the card, and sets up some - * globals required by other routines, and initializes the NIC, making it - * ready to send and receive packets. - * - * Side effects: - * leaves the natsemi initialized, and ready to receive packets. - * - * Returns: struct eth_device *: pointer to NIC data structure - */ - -int -natsemi_initialize(struct bd_info * bis) -{ - pci_dev_t devno; - int card_number = 0; - struct eth_device *dev; - u32 iobase, status, chip_config; - int i, idx = 0; - int prev_eedata; - u32 tmp; - - while (1) { - /* Find PCI device(s) */ - if ((devno = pci_find_devices(supported, idx++)) < 0) { - break; - } - - pci_read_config_dword(devno, PCI_BASE_ADDRESS_0, &iobase); - iobase &= ~0x3; /* bit 1: unused and bit 0: I/O Space Indicator */ - - pci_write_config_dword(devno, PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); - - /* Check if I/O accesses and Bus Mastering are enabled. */ - pci_read_config_dword(devno, PCI_COMMAND, &status); - if (!(status & PCI_COMMAND_MEMORY)) { - printf("Error: Can not enable MEM access.\n"); - continue; - } else if (!(status & PCI_COMMAND_MASTER)) { - printf("Error: Can not enable Bus Mastering.\n"); - continue; - } - - dev = (struct eth_device *) malloc(sizeof *dev); - if (!dev) { - printf("natsemi: Can not allocate memory\n"); - break; - } - memset(dev, 0, sizeof(*dev)); - - sprintf(dev->name, "dp83815#%d", card_number); - dev->iobase = bus_to_phys(iobase); -#ifdef NATSEMI_DEBUG - printf("natsemi: NatSemi ns8381[56] @ %#x\n", dev->iobase); -#endif - dev->priv = (void *) devno; - dev->init = natsemi_init; - dev->halt = natsemi_disable; - dev->send = natsemi_send; - dev->recv = natsemi_poll; - - eth_register(dev); - - card_number++; - - /* Set the latency timer for value. */ - pci_write_config_byte(devno, PCI_LATENCY_TIMER, 0x20); - - udelay(10 * 1000); - - /* natsemi has a non-standard PM control register - * in PCI config space. Some boards apparently need - * to be brought to D0 in this manner. */ - pci_read_config_dword(devno, PCIPM, &tmp); - if (tmp & (0x03 | 0x100)) { - /* D0 state, disable PME assertion */ - u32 newtmp = tmp & ~(0x03 | 0x100); - pci_write_config_dword(devno, PCIPM, newtmp); - } - - printf("natsemi: EEPROM contents:\n"); - for (i = 0; i <= EEPROM_SIZE; i++) { - short eedata = read_eeprom(dev, EECtrl, i); - printf(" %04hx", eedata); - } - printf("\n"); - - /* get MAC address */ - prev_eedata = read_eeprom(dev, EECtrl, 6); - for (i = 0; i < 3; i++) { - int eedata = read_eeprom(dev, EECtrl, i + 7); - dev->enetaddr[i*2] = (eedata << 1) + (prev_eedata >> 15); - dev->enetaddr[i*2+1] = eedata >> 7; - prev_eedata = eedata; - } - - /* Reset the chip to erase any previous misconfiguration. */ - OUTL(dev, ChipReset, ChipCmd); - - advertising = mdio_read(dev, 1, 4); - chip_config = INL(dev, ChipConfig); -#ifdef NATSEMI_DEBUG - printf("%s: Transceiver status %#08X advertising %#08X\n", - dev->name, (int) INL(dev, BasicStatus), advertising); - printf("%s: Transceiver default autoneg. %s 10%s %s duplex.\n", - dev->name, chip_config & AnegMask ? "enabled, advertise" : - "disabled, force", chip_config & SpeedMask ? "0" : "", - chip_config & DuplexMask ? "full" : "half"); -#endif - chip_config |= AnegEnBothBoth; -#ifdef NATSEMI_DEBUG - printf("%s: changed to autoneg. %s 10%s %s duplex.\n", - dev->name, chip_config & AnegMask ? "enabled, advertise" : - "disabled, force", chip_config & SpeedMask ? "0" : "", - chip_config & DuplexMask ? "full" : "half"); -#endif - /*write new autoneg bits, reset phy*/ - OUTL(dev, (chip_config | PhyRst), ChipConfig); - /*un-reset phy*/ - OUTL(dev, chip_config, ChipConfig); - - /* Disable PME: - * The PME bit is initialized from the EEPROM contents. - * PCI cards probably have PME disabled, but motherboard - * implementations may have PME set to enable WakeOnLan. - * With PME set the chip will scan incoming packets but - * nothing will be written to memory. */ - SavedClkRun = INL(dev, ClkRun); - OUTL(dev, SavedClkRun & ~0x100, ClkRun); - } - return card_number; -} - -/* Read the EEPROM and MII Management Data I/O (MDIO) interfaces. - The EEPROM code is for common 93c06/46 EEPROMs w/ 6bit addresses. */ - -/* Delay between EEPROM clock transitions. - No extra delay is needed with 33MHz PCI, but future 66MHz - access may need a delay. */ -#define eeprom_delay(ee_addr) INL(dev, ee_addr) - -enum EEPROM_Ctrl_Bits { - EE_ShiftClk = 0x04, - EE_DataIn = 0x01, - EE_ChipSelect = 0x08, - EE_DataOut = 0x02 -}; - -#define EE_Write0 (EE_ChipSelect) -#define EE_Write1 (EE_ChipSelect | EE_DataIn) -/* The EEPROM commands include the alway-set leading bit. */ -enum EEPROM_Cmds { - EE_WrEnCmd = (4 << 6), EE_WriteCmd = (5 << 6), - EE_ReadCmd = (6 << 6), EE_EraseCmd = (7 << 6), -}; - -#if 0 -static void -write_eeprom(struct eth_device *dev, long addr, int location, short value) -{ - int i; - int ee_addr = (typeof(ee_addr))addr; - short wren_cmd = EE_WrEnCmd | 0x30; /*wren is 100 + 11XXXX*/ - short write_cmd = location | EE_WriteCmd; - -#ifdef NATSEMI_DEBUG - printf("write_eeprom: %08x, %04hx, %04hx\n", - dev->iobase + ee_addr, write_cmd, value); -#endif - /* Shift the write enable command bits out. */ - for (i = 9; i >= 0; i--) { - short cmdval = (wren_cmd & (1 << i)) ? EE_Write1 : EE_Write0; - OUTL(dev, cmdval, ee_addr); - eeprom_delay(ee_addr); - OUTL(dev, cmdval | EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - } - - OUTL(dev, 0, ee_addr); /*bring chip select low*/ - OUTL(dev, EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - - /* Shift the write command bits out. */ - for (i = 9; i >= 0; i--) { - short cmdval = (write_cmd & (1 << i)) ? EE_Write1 : EE_Write0; - OUTL(dev, cmdval, ee_addr); - eeprom_delay(ee_addr); - OUTL(dev, cmdval | EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - } - - for (i = 0; i < 16; i++) { - short cmdval = (value & (1 << i)) ? EE_Write1 : EE_Write0; - OUTL(dev, cmdval, ee_addr); - eeprom_delay(ee_addr); - OUTL(dev, cmdval | EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - } - - OUTL(dev, 0, ee_addr); /*bring chip select low*/ - OUTL(dev, EE_ShiftClk, ee_addr); - for (i = 0; i < 200000; i++) { - OUTL(dev, EE_Write0, ee_addr); /*poll for done*/ - if (INL(dev, ee_addr) & EE_DataOut) { - break; /*finished*/ - } - } - eeprom_delay(ee_addr); - - /* Terminate the EEPROM access. */ - OUTL(dev, EE_Write0, ee_addr); - OUTL(dev, 0, ee_addr); - return; -} -#endif - -static int -read_eeprom(struct eth_device *dev, long addr, int location) -{ - int i; - int retval = 0; - int ee_addr = (typeof(ee_addr))addr; - int read_cmd = location | EE_ReadCmd; - - OUTL(dev, EE_Write0, ee_addr); - - /* Shift the read command bits out. */ - for (i = 10; i >= 0; i--) { - short dataval = (read_cmd & (1 << i)) ? EE_Write1 : EE_Write0; - OUTL(dev, dataval, ee_addr); - eeprom_delay(ee_addr); - OUTL(dev, dataval | EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - } - OUTL(dev, EE_ChipSelect, ee_addr); - eeprom_delay(ee_addr); - - for (i = 0; i < 16; i++) { - OUTL(dev, EE_ChipSelect | EE_ShiftClk, ee_addr); - eeprom_delay(ee_addr); - retval |= (INL(dev, ee_addr) & EE_DataOut) ? 1 << i : 0; - OUTL(dev, EE_ChipSelect, ee_addr); - eeprom_delay(ee_addr); - } - - /* Terminate the EEPROM access. */ - OUTL(dev, EE_Write0, ee_addr); - OUTL(dev, 0, ee_addr); -#ifdef NATSEMI_DEBUG - if (natsemi_debug) - printf("read_eeprom: %08x, %08x, retval %08x\n", - dev->iobase + ee_addr, read_cmd, retval); -#endif - return retval; -} - -/* MII transceiver control section. - The 83815 series has an internal transceiver, and we present the - management registers as if they were MII connected. */ - -static int -mdio_read(struct eth_device *dev, int phy_id, int location) -{ - if (phy_id == 1 && location < 32) - return INL(dev, BasicControl+(location<<2))&0xffff; - else - return 0xffff; -} - -/* Function: natsemi_init - * - * Description: resets the ethernet controller chip and configures - * registers and data structures required for sending and receiving packets. - * - * Arguments: struct eth_device *dev: NIC data structure - * - * returns: int. - */ - -static int -natsemi_init(struct eth_device *dev, struct bd_info * bis) -{ - - natsemi_reset(dev); - - /* Disable PME: - * The PME bit is initialized from the EEPROM contents. - * PCI cards probably have PME disabled, but motherboard - * implementations may have PME set to enable WakeOnLan. - * With PME set the chip will scan incoming packets but - * nothing will be written to memory. */ - OUTL(dev, SavedClkRun & ~0x100, ClkRun); - - natsemi_init_rxfilter(dev); - natsemi_init_txd(dev); - natsemi_init_rxd(dev); - - /* Configure the PCI bus bursts and FIFO thresholds. */ - tx_config = TxAutoPad | TxCollRetry | TxMxdma_256 | (0x1002); - rx_config = RxMxdma_256 | 0x20; - -#ifdef NATSEMI_DEBUG - printf("%s: Setting TxConfig Register %#08X\n", dev->name, tx_config); - printf("%s: Setting RxConfig Register %#08X\n", dev->name, rx_config); -#endif - OUTL(dev, tx_config, TxConfig); - OUTL(dev, rx_config, RxConfig); - - natsemi_check_duplex(dev); - natsemi_set_rx_mode(dev); - - OUTL(dev, (RxOn | TxOn), ChipCmd); - return 1; -} - -/* - * Function: natsemi_reset - * - * Description: soft resets the controller chip - * - * Arguments: struct eth_device *dev: NIC data structure - * - * Returns: void. - */ -static void -natsemi_reset(struct eth_device *dev) -{ - OUTL(dev, ChipReset, ChipCmd); - - /* On page 78 of the spec, they recommend some settings for "optimum - performance" to be done in sequence. These settings optimize some - of the 100Mbit autodetection circuitry. Also, we only want to do - this for rev C of the chip. */ - if (INL(dev, SiliconRev) == 0x302) { - OUTW(dev, 0x0001, PGSEL); - OUTW(dev, 0x189C, PMDCSR); - OUTW(dev, 0x0000, TSTDAT); - OUTW(dev, 0x5040, DSPCFG); - OUTW(dev, 0x008C, SDCFG); - } - /* Disable interrupts using the mask. */ - OUTL(dev, 0, IntrMask); - OUTL(dev, 0, IntrEnable); -} - -/* Function: natsemi_init_rxfilter - * - * Description: sets receive filter address to our MAC address - * - * Arguments: struct eth_device *dev: NIC data structure - * - * returns: void. - */ - -static void -natsemi_init_rxfilter(struct eth_device *dev) -{ - int i; - - for (i = 0; i < ETH_ALEN; i += 2) { - OUTL(dev, i, RxFilterAddr); - OUTW(dev, dev->enetaddr[i] + (dev->enetaddr[i + 1] << 8), - RxFilterData); - } -} - -/* - * Function: natsemi_init_txd - * - * Description: initializes the Tx descriptor - * - * Arguments: struct eth_device *dev: NIC data structure - * - * returns: void. - */ - -static void -natsemi_init_txd(struct eth_device *dev) -{ - txd.link = (u32) 0; - txd.cmdsts = (u32) 0; - txd.bufptr = (u32) & txb[0]; - - /* load Transmit Descriptor Register */ - OUTL(dev, (u32) & txd, TxRingPtr); -#ifdef NATSEMI_DEBUG - printf("natsemi_init_txd: TX descriptor reg loaded with: %#08X\n", - INL(dev, TxRingPtr)); -#endif -} - -/* Function: natsemi_init_rxd - * - * Description: initializes the Rx descriptor ring - * - * Arguments: struct eth_device *dev: NIC data structure - * - * Returns: void. - */ - -static void -natsemi_init_rxd(struct eth_device *dev) -{ - int i; - - cur_rx = 0; - - /* init RX descriptor */ - for (i = 0; i < NUM_RX_DESC; i++) { - rxd[i].link = - cpu_to_le32((i + 1 < - NUM_RX_DESC) ? (u32) & rxd[i + - 1] : (u32) & - rxd[0]); - rxd[i].cmdsts = cpu_to_le32((u32) RX_BUF_SIZE); - rxd[i].bufptr = cpu_to_le32((u32) & rxb[i * RX_BUF_SIZE]); -#ifdef NATSEMI_DEBUG - printf - ("natsemi_init_rxd: rxd[%d]=%p link=%X cmdsts=%lX bufptr=%X\n", - i, &rxd[i], le32_to_cpu(rxd[i].link), - rxd[i].cmdsts, rxd[i].bufptr); -#endif - } - - /* load Receive Descriptor Register */ - OUTL(dev, (u32) & rxd[0], RxRingPtr); - -#ifdef NATSEMI_DEBUG - printf("natsemi_init_rxd: RX descriptor register loaded with: %X\n", - INL(dev, RxRingPtr)); -#endif -} - -/* Function: natsemi_set_rx_mode - * - * Description: - * sets the receive mode to accept all broadcast packets and packets - * with our MAC address, and reject all multicast packets. - * - * Arguments: struct eth_device *dev: NIC data structure - * - * Returns: void. - */ - -static void -natsemi_set_rx_mode(struct eth_device *dev) -{ - u32 rx_mode = AcceptBroadcast | AcceptMyPhys; - - OUTL(dev, rx_mode, RxFilterAddr); -} - -static void -natsemi_check_duplex(struct eth_device *dev) -{ - int duplex = INL(dev, ChipConfig) & FullDuplex ? 1 : 0; - -#ifdef NATSEMI_DEBUG - printf("%s: Setting %s-duplex based on negotiated link" - " capability.\n", dev->name, duplex ? "full" : "half"); -#endif - if (duplex) { - rx_config |= RxAcceptTx; - tx_config |= (TxCarrierIgn | TxHeartIgn); - } else { - rx_config &= ~RxAcceptTx; - tx_config &= ~(TxCarrierIgn | TxHeartIgn); - } - OUTL(dev, tx_config, TxConfig); - OUTL(dev, rx_config, RxConfig); -} - -/* Function: natsemi_send - * - * Description: transmits a packet and waits for completion or timeout. - * - * Returns: void. */ -static int natsemi_send(struct eth_device *dev, void *packet, int length) -{ - u32 i, status = 0; - u32 tx_status = 0; - u32 *tx_ptr = &tx_status; - vu_long *res = (vu_long *)tx_ptr; - - /* Stop the transmitter */ - OUTL(dev, TxOff, ChipCmd); - -#ifdef NATSEMI_DEBUG - if (natsemi_debug) - printf("natsemi_send: sending %d bytes\n", (int) length); -#endif - - /* set the transmit buffer descriptor and enable Transmit State Machine */ - txd.link = cpu_to_le32(0); - txd.bufptr = cpu_to_le32(phys_to_bus((u32) packet)); - txd.cmdsts = cpu_to_le32(DescOwn | length); - - /* load Transmit Descriptor Register */ - OUTL(dev, phys_to_bus((u32) & txd), TxRingPtr); -#ifdef NATSEMI_DEBUG - if (natsemi_debug) - printf("natsemi_send: TX descriptor register loaded with: %#08X\n", - INL(dev, TxRingPtr)); -#endif - /* restart the transmitter */ - OUTL(dev, TxOn, ChipCmd); - - for (i = 0; - (*res = le32_to_cpu(txd.cmdsts)) & DescOwn; - i++) { - if (i >= TOUT_LOOP) { - printf - ("%s: tx error buffer not ready: txd.cmdsts == %#X\n", - dev->name, tx_status); - goto Done; - } - } - - if (!(tx_status & DescPktOK)) { - printf("natsemi_send: Transmit error, Tx status %X.\n", - tx_status); - goto Done; - } - - status = 1; - Done: - return status; -} - -/* Function: natsemi_poll - * - * Description: checks for a received packet and returns it if found. - * - * Arguments: struct eth_device *dev: NIC data structure - * - * Returns: 1 if packet was received. - * 0 if no packet was received. - * - * Side effects: - * Returns (copies) the packet to the array dev->packet. - * Returns the length of the packet. - */ - -static int -natsemi_poll(struct eth_device *dev) -{ - int retstat = 0; - int length = 0; - u32 rx_status = le32_to_cpu(rxd[cur_rx].cmdsts); - - if (!(rx_status & (u32) DescOwn)) - return retstat; -#ifdef NATSEMI_DEBUG - if (natsemi_debug) - printf("natsemi_poll: got a packet: cur_rx:%d, status:%X\n", - cur_rx, rx_status); -#endif - length = (rx_status & DSIZE) - CRC_SIZE; - - if ((rx_status & (DescMore | DescPktOK | DescRxLong)) != DescPktOK) { - printf - ("natsemi_poll: Corrupted packet received, buffer status = %X\n", - rx_status); - retstat = 0; - } else { /* give packet to higher level routine */ - net_process_received_packet((rxb + cur_rx * RX_BUF_SIZE), - length); - retstat = 1; - } - - /* return the descriptor and buffer to receive ring */ - rxd[cur_rx].cmdsts = cpu_to_le32(RX_BUF_SIZE); - rxd[cur_rx].bufptr = cpu_to_le32((u32) & rxb[cur_rx * RX_BUF_SIZE]); - - if (++cur_rx == NUM_RX_DESC) - cur_rx = 0; - - /* re-enable the potentially idle receive state machine */ - OUTL(dev, RxOn, ChipCmd); - - return retstat; -} - -/* Function: natsemi_disable - * - * Description: Turns off interrupts and stops Tx and Rx engines - * - * Arguments: struct eth_device *dev: NIC data structure - * - * Returns: void. - */ - -static void -natsemi_disable(struct eth_device *dev) -{ - /* Disable interrupts using the mask. */ - OUTL(dev, 0, IntrMask); - OUTL(dev, 0, IntrEnable); - - /* Stop the chip's Tx and Rx processes. */ - OUTL(dev, RxOff | TxOff, ChipCmd); - - /* Restore PME enable bit */ - OUTL(dev, SavedClkRun, ClkRun); -}
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/ns8382x.c | 854 ------------------------------------------ 2 files changed, 855 deletions(-) delete mode 100644 drivers/net/ns8382x.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index f902f0d06c26..02b36582ce46 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -67,7 +67,6 @@ obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NETCONSOLE) += netconsole.o obj-$(CONFIG_NET_OCTEONTX) += octeontx/ obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ -obj-$(CONFIG_NS8382X) += ns8382x.o obj-$(CONFIG_OCTEONTX2_CGX_INTF) += octeontx2/cgx_intf.o obj-$(CONFIG_OCTEONTX_SMI) += octeontx/smi.o obj-$(CONFIG_PCH_GBE) += pch_gbe.o diff --git a/drivers/net/ns8382x.c b/drivers/net/ns8382x.c deleted file mode 100644 index d79872af0936..000000000000 --- a/drivers/net/ns8382x.c +++ /dev/null @@ -1,854 +0,0 @@ -/* - ns8382x.c: A U-Boot driver for the NatSemi DP8382[01]. - ported by: Mark A. Rakes (mark_rakes@vivato.net) - - Adapted from: - 1. an Etherboot driver for DP8381[56] written by: - Copyright (C) 2001 Entity Cyber, Inc. - - This development of this Etherboot driver was funded by - Sicom Systems: http://www.sicompos.com/ - - Author: Marty Connor (mdc@thinguin.org) - Adapted from a Linux driver which was written by Donald Becker - - This software may be used and distributed according to the terms - of the GNU Public License (GPL), incorporated herein by reference. - - 2. A Linux driver by Donald Becker, ns820.c: - Written/copyright 1999-2002 by Donald Becker. - - This software may be used and distributed according to the terms of - the GNU General Public License (GPL), incorporated herein by reference. - Drivers based on or derived from this code fall under the GPL and must - retain the authorship, copyright and license notice. This file is not - a complete program and may only be used when the entire operating - system is licensed under the GPL. License for under other terms may be - available. Contact the original author for details. - - The original author may be reached as becker@scyld.com, or at - Scyld Computing Corporation - 410 Severn Ave., Suite 210 - Annapolis MD 21403 - - Support information and updates available at - http://www.scyld.com/network/netsemi.html - - Datasheets available from: - http://www.national.com/pf/DP/DP83820.html - http://www.national.com/pf/DP/DP83821.html -*/ - -/* Revision History - * October 2002 mar 1.0 - * Initial U-Boot Release. - * Tested with Netgear GA622T (83820) - * and SMC9452TX (83821) - * NOTE: custom boards with these chips may (likely) require - * a programmed EEPROM device (if present) in order to work - * correctly. -*/ - -/* Includes */ -#include <common.h> -#include <log.h> -#include <malloc.h> -#include <net.h> -#include <netdev.h> -#include <asm/io.h> -#include <pci.h> -#include <linux/delay.h> - -/* defines */ -#define DSIZE 0x00000FFF -#define CRC_SIZE 4 -#define TOUT_LOOP 500000 -#define TX_BUF_SIZE 1536 -#define RX_BUF_SIZE 1536 -#define NUM_RX_DESC 4 /* Number of Rx descriptor registers. */ - -enum register_offsets { - ChipCmd = 0x00, - ChipConfig = 0x04, - EECtrl = 0x08, - IntrMask = 0x14, - IntrEnable = 0x18, - TxRingPtr = 0x20, - TxRingPtrHi = 0x24, - TxConfig = 0x28, - RxRingPtr = 0x30, - RxRingPtrHi = 0x34, - RxConfig = 0x38, - PriQueue = 0x3C, - RxFilterAddr = 0x48, - RxFilterData = 0x4C, - ClkRun = 0xCC, - PCIPM = 0x44, -}; - -enum ChipCmdBits { - ChipReset = 0x100, - RxReset = 0x20, - TxReset = 0x10, - RxOff = 0x08, - RxOn = 0x04, - TxOff = 0x02, - TxOn = 0x01 -}; - -enum ChipConfigBits { - LinkSts = 0x80000000, - GigSpeed = 0x40000000, - HundSpeed = 0x20000000, - FullDuplex = 0x10000000, - TBIEn = 0x01000000, - Mode1000 = 0x00400000, - T64En = 0x00004000, - D64En = 0x00001000, - M64En = 0x00000800, - PhyRst = 0x00000400, - PhyDis = 0x00000200, - ExtStEn = 0x00000100, - BEMode = 0x00000001, -}; -#define SpeedStatus_Polarity ( GigSpeed | HundSpeed | FullDuplex) - -enum TxConfig_bits { - TxDrthMask = 0x000000ff, - TxFlthMask = 0x0000ff00, - TxMxdmaMask = 0x00700000, - TxMxdma_8 = 0x00100000, - TxMxdma_16 = 0x00200000, - TxMxdma_32 = 0x00300000, - TxMxdma_64 = 0x00400000, - TxMxdma_128 = 0x00500000, - TxMxdma_256 = 0x00600000, - TxMxdma_512 = 0x00700000, - TxMxdma_1024 = 0x00000000, - TxCollRetry = 0x00800000, - TxAutoPad = 0x10000000, - TxMacLoop = 0x20000000, - TxHeartIgn = 0x40000000, - TxCarrierIgn = 0x80000000 -}; - -enum RxConfig_bits { - RxDrthMask = 0x0000003e, - RxMxdmaMask = 0x00700000, - RxMxdma_8 = 0x00100000, - RxMxdma_16 = 0x00200000, - RxMxdma_32 = 0x00300000, - RxMxdma_64 = 0x00400000, - RxMxdma_128 = 0x00500000, - RxMxdma_256 = 0x00600000, - RxMxdma_512 = 0x00700000, - RxMxdma_1024 = 0x00000000, - RxAcceptLenErr = 0x04000000, - RxAcceptLong = 0x08000000, - RxAcceptTx = 0x10000000, - RxStripCRC = 0x20000000, - RxAcceptRunt = 0x40000000, - RxAcceptErr = 0x80000000, -}; - -/* Bits in the RxMode register. */ -enum rx_mode_bits { - RxFilterEnable = 0x80000000, - AcceptAllBroadcast = 0x40000000, - AcceptAllMulticast = 0x20000000, - AcceptAllUnicast = 0x10000000, - AcceptPerfectMatch = 0x08000000, -}; - -typedef struct _BufferDesc { - u32 link; - u32 bufptr; - vu_long cmdsts; - u32 extsts; /*not used here */ -} BufferDesc; - -/* Bits in network_desc.status */ -enum desc_status_bits { - DescOwn = 0x80000000, DescMore = 0x40000000, DescIntr = 0x20000000, - DescNoCRC = 0x10000000, DescPktOK = 0x08000000, - DescSizeMask = 0xfff, - - DescTxAbort = 0x04000000, DescTxFIFO = 0x02000000, - DescTxCarrier = 0x01000000, DescTxDefer = 0x00800000, - DescTxExcDefer = 0x00400000, DescTxOOWCol = 0x00200000, - DescTxExcColl = 0x00100000, DescTxCollCount = 0x000f0000, - - DescRxAbort = 0x04000000, DescRxOver = 0x02000000, - DescRxDest = 0x01800000, DescRxLong = 0x00400000, - DescRxRunt = 0x00200000, DescRxInvalid = 0x00100000, - DescRxCRC = 0x00080000, DescRxAlign = 0x00040000, - DescRxLoop = 0x00020000, DesRxColl = 0x00010000, -}; - -/* Bits in MEAR */ -enum mii_reg_bits { - MDIO_ShiftClk = 0x0040, - MDIO_EnbOutput = 0x0020, - MDIO_Data = 0x0010, -}; - -/* PHY Register offsets. */ -enum phy_reg_offsets { - BMCR = 0x00, - BMSR = 0x01, - PHYIDR1 = 0x02, - PHYIDR2 = 0x03, - ANAR = 0x04, - KTCR = 0x09, -}; - -/* basic mode control register bits */ -enum bmcr_bits { - Bmcr_Reset = 0x8000, - Bmcr_Loop = 0x4000, - Bmcr_Speed0 = 0x2000, - Bmcr_AutoNegEn = 0x1000, /*if set ignores Duplex, Speed[01] */ - Bmcr_RstAutoNeg = 0x0200, - Bmcr_Duplex = 0x0100, - Bmcr_Speed1 = 0x0040, - Bmcr_Force10H = 0x0000, - Bmcr_Force10F = 0x0100, - Bmcr_Force100H = 0x2000, - Bmcr_Force100F = 0x2100, - Bmcr_Force1000H = 0x0040, - Bmcr_Force1000F = 0x0140, -}; - -/* auto negotiation advertisement register */ -enum anar_bits { - anar_adv_100F = 0x0100, - anar_adv_100H = 0x0080, - anar_adv_10F = 0x0040, - anar_adv_10H = 0x0020, - anar_ieee_8023 = 0x0001, -}; - -/* 1K-base T control register */ -enum ktcr_bits { - ktcr_adv_1000H = 0x0100, - ktcr_adv_1000F = 0x0200, -}; - -/* Globals */ -static u32 SavedClkRun; -static unsigned int cur_rx; -static unsigned int rx_config; -static unsigned int tx_config; - -/* Note: transmit and receive buffers and descriptors must be - long long word aligned */ -static BufferDesc txd __attribute__ ((aligned(8))); -static BufferDesc rxd[NUM_RX_DESC] __attribute__ ((aligned(8))); -static unsigned char txb[TX_BUF_SIZE] __attribute__ ((aligned(8))); -static unsigned char rxb[NUM_RX_DESC * RX_BUF_SIZE] - __attribute__ ((aligned(8))); - -/* Function Prototypes */ -static int mdio_read(struct eth_device *dev, int phy_id, int addr); -static void mdio_write(struct eth_device *dev, int phy_id, int addr, int value); -static void mdio_sync(struct eth_device *dev, u32 offset); -static int ns8382x_init(struct eth_device *dev, struct bd_info * bis); -static void ns8382x_reset(struct eth_device *dev); -static void ns8382x_init_rxfilter(struct eth_device *dev); -static void ns8382x_init_txd(struct eth_device *dev); -static void ns8382x_init_rxd(struct eth_device *dev); -static void ns8382x_set_rx_mode(struct eth_device *dev); -static void ns8382x_check_duplex(struct eth_device *dev); -static int ns8382x_send(struct eth_device *dev, void *packet, int length); -static int ns8382x_poll(struct eth_device *dev); -static void ns8382x_disable(struct eth_device *dev); - -static struct pci_device_id supported[] = { - {PCI_VENDOR_ID_NS, PCI_DEVICE_ID_NS_83820}, - {} -}; - -#define bus_to_phys(a) pci_mem_to_phys((pci_dev_t)dev->priv, a) -#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) - -static inline int -INW(struct eth_device *dev, u_long addr) -{ - return le16_to_cpu(*(vu_short *) (addr + dev->iobase)); -} - -static int -INL(struct eth_device *dev, u_long addr) -{ - return le32_to_cpu(*(vu_long *) (addr + dev->iobase)); -} - -static inline void -OUTW(struct eth_device *dev, int command, u_long addr) -{ - *(vu_short *) ((addr + dev->iobase)) = cpu_to_le16(command); -} - -static inline void -OUTL(struct eth_device *dev, int command, u_long addr) -{ - *(vu_long *) ((addr + dev->iobase)) = cpu_to_le32(command); -} - -/* Function: ns8382x_initialize - * Description: Retrieves the MAC address of the card, and sets up some - * globals required by other routines, and initializes the NIC, making it - * ready to send and receive packets. - * Side effects: initializes ns8382xs, ready to receive packets. - * Returns: int: number of cards found - */ - -int -ns8382x_initialize(struct bd_info * bis) -{ - pci_dev_t devno; - int card_number = 0; - struct eth_device *dev; - u32 iobase, status; - int i, idx = 0; - u32 phyAddress; - u32 tmp; - u32 chip_config; - - while (1) { /* Find PCI device(s) */ - if ((devno = pci_find_devices(supported, idx++)) < 0) - break; - - pci_read_config_dword(devno, PCI_BASE_ADDRESS_1, &iobase); - iobase &= ~0x3; /* 1: unused and 0:I/O Space Indicator */ - - debug("ns8382x: NatSemi dp8382x @ 0x%x\n", iobase); - - pci_write_config_dword(devno, PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); - - /* Check if I/O accesses and Bus Mastering are enabled. */ - pci_read_config_dword(devno, PCI_COMMAND, &status); - if (!(status & PCI_COMMAND_MEMORY)) { - printf("Error: Can not enable MEM access.\n"); - continue; - } else if (!(status & PCI_COMMAND_MASTER)) { - printf("Error: Can not enable Bus Mastering.\n"); - continue; - } - - dev = (struct eth_device *) malloc(sizeof *dev); - if (!dev) { - printf("ns8382x: Can not allocate memory\n"); - break; - } - memset(dev, 0, sizeof(*dev)); - - sprintf(dev->name, "dp8382x#%d", card_number); - dev->iobase = bus_to_phys(iobase); - dev->priv = (void *) devno; - dev->init = ns8382x_init; - dev->halt = ns8382x_disable; - dev->send = ns8382x_send; - dev->recv = ns8382x_poll; - - /* ns8382x has a non-standard PM control register - * in PCI config space. Some boards apparently need - * to be brought to D0 in this manner. */ - pci_read_config_dword(devno, PCIPM, &tmp); - if (tmp & (0x03 | 0x100)) { /* D0 state, disable PME assertion */ - u32 newtmp = tmp & ~(0x03 | 0x100); - pci_write_config_dword(devno, PCIPM, newtmp); - } - - /* get MAC address */ - for (i = 0; i < 3; i++) { - u32 data; - char *mac = (char *)&dev->enetaddr[i * 2]; - - OUTL(dev, i * 2, RxFilterAddr); - data = INL(dev, RxFilterData); - *mac++ = data; - *mac++ = data >> 8; - } - /* get PHY address, can't be zero */ - for (phyAddress = 1; phyAddress < 32; phyAddress++) { - u32 rev, phy1; - - phy1 = mdio_read(dev, phyAddress, PHYIDR1); - if (phy1 == 0x2000) { /*check for 83861/91 */ - rev = mdio_read(dev, phyAddress, PHYIDR2); - if ((rev & ~(0x000f)) == 0x00005c50 || - (rev & ~(0x000f)) == 0x00005c60) { - debug("phy rev is %x\n", rev); - debug("phy address is %x\n", - phyAddress); - break; - } - } - } - - /* set phy to autonegotiate && advertise everything */ - mdio_write(dev, phyAddress, KTCR, - (ktcr_adv_1000H | ktcr_adv_1000F)); - mdio_write(dev, phyAddress, ANAR, - (anar_adv_100F | anar_adv_100H | anar_adv_10H | - anar_adv_10F | anar_ieee_8023)); - mdio_write(dev, phyAddress, BMCR, 0x0); /*restore */ - mdio_write(dev, phyAddress, BMCR, - (Bmcr_AutoNegEn | Bmcr_RstAutoNeg)); - /* Reset the chip to erase any previous misconfiguration. */ - OUTL(dev, (ChipReset), ChipCmd); - - chip_config = INL(dev, ChipConfig); - /* reset the phy */ - OUTL(dev, (chip_config | PhyRst), ChipConfig); - /* power up and initialize transceiver */ - OUTL(dev, (chip_config & ~(PhyDis)), ChipConfig); - - mdio_sync(dev, EECtrl); - - { - u32 chpcfg = - INL(dev, ChipConfig) ^ SpeedStatus_Polarity; - - debug("%s: Transceiver 10%s %s duplex.\n", dev->name, - (chpcfg & GigSpeed) ? "00" : (chpcfg & HundSpeed) - ? "0" : "", - chpcfg & FullDuplex ? "full" : "half"); - debug("%s: %02x:%02x:%02x:%02x:%02x:%02x\n", dev->name, - dev->enetaddr[0], dev->enetaddr[1], - dev->enetaddr[2], dev->enetaddr[3], - dev->enetaddr[4], dev->enetaddr[5]); - } - - /* Disable PME: - * The PME bit is initialized from the EEPROM contents. - * PCI cards probably have PME disabled, but motherboard - * implementations may have PME set to enable WakeOnLan. - * With PME set the chip will scan incoming packets but - * nothing will be written to memory. */ - SavedClkRun = INL(dev, ClkRun); - OUTL(dev, SavedClkRun & ~0x100, ClkRun); - - eth_register(dev); - - card_number++; - - pci_write_config_byte(devno, PCI_LATENCY_TIMER, 0x60); - - udelay(10 * 1000); - } - return card_number; -} - -/* MII transceiver control section. - Read and write MII registers using software-generated serial MDIO - protocol. See the MII specifications or DP83840A data sheet for details. - - The maximum data clock rate is 2.5 MHz. To meet minimum timing we - must flush writes to the PCI bus with a PCI read. */ -#define mdio_delay(mdio_addr) INL(dev, mdio_addr) - -#define MDIO_EnbIn (0) -#define MDIO_WRITE0 (MDIO_EnbOutput) -#define MDIO_WRITE1 (MDIO_Data | MDIO_EnbOutput) - -/* Generate the preamble required for initial synchronization and - a few older transceivers. */ -static void -mdio_sync(struct eth_device *dev, u32 offset) -{ - int bits = 32; - - /* Establish sync by sending at least 32 logic ones. */ - while (--bits >= 0) { - OUTL(dev, MDIO_WRITE1, offset); - mdio_delay(offset); - OUTL(dev, MDIO_WRITE1 | MDIO_ShiftClk, offset); - mdio_delay(offset); - } -} - -static int -mdio_read(struct eth_device *dev, int phy_id, int addr) -{ - int mii_cmd = (0xf6 << 10) | (phy_id << 5) | addr; - int i, retval = 0; - - /* Shift the read command bits out. */ - for (i = 15; i >= 0; i--) { - int dataval = (mii_cmd & (1 << i)) ? MDIO_WRITE1 : MDIO_WRITE0; - - OUTL(dev, dataval, EECtrl); - mdio_delay(EECtrl); - OUTL(dev, dataval | MDIO_ShiftClk, EECtrl); - mdio_delay(EECtrl); - } - /* Read the two transition, 16 data, and wire-idle bits. */ - for (i = 19; i > 0; i--) { - OUTL(dev, MDIO_EnbIn, EECtrl); - mdio_delay(EECtrl); - retval = - (retval << 1) | ((INL(dev, EECtrl) & MDIO_Data) ? 1 : 0); - OUTL(dev, MDIO_EnbIn | MDIO_ShiftClk, EECtrl); - mdio_delay(EECtrl); - } - return (retval >> 1) & 0xffff; -} - -static void -mdio_write(struct eth_device *dev, int phy_id, int addr, int value) -{ - int mii_cmd = (0x5002 << 16) | (phy_id << 23) | (addr << 18) | value; - int i; - - /* Shift the command bits out. */ - for (i = 31; i >= 0; i--) { - int dataval = (mii_cmd & (1 << i)) ? MDIO_WRITE1 : MDIO_WRITE0; - - OUTL(dev, dataval, EECtrl); - mdio_delay(EECtrl); - OUTL(dev, dataval | MDIO_ShiftClk, EECtrl); - mdio_delay(EECtrl); - } - /* Clear out extra bits. */ - for (i = 2; i > 0; i--) { - OUTL(dev, MDIO_EnbIn, EECtrl); - mdio_delay(EECtrl); - OUTL(dev, MDIO_EnbIn | MDIO_ShiftClk, EECtrl); - mdio_delay(EECtrl); - } - return; -} - -/* Function: ns8382x_init - * Description: resets the ethernet controller chip and configures - * registers and data structures required for sending and receiving packets. - * Arguments: struct eth_device *dev: NIC data structure - * returns: int. - */ - -static int -ns8382x_init(struct eth_device *dev, struct bd_info * bis) -{ - u32 config; - - ns8382x_reset(dev); - - /* Disable PME: - * The PME bit is initialized from the EEPROM contents. - * PCI cards probably have PME disabled, but motherboard - * implementations may have PME set to enable WakeOnLan. - * With PME set the chip will scan incoming packets but - * nothing will be written to memory. */ - OUTL(dev, SavedClkRun & ~0x100, ClkRun); - - ns8382x_init_rxfilter(dev); - ns8382x_init_txd(dev); - ns8382x_init_rxd(dev); - - /*set up ChipConfig */ - config = INL(dev, ChipConfig); - /*turn off 64 bit ops && Ten-bit interface - * && big-endian mode && extended status */ - config &= ~(TBIEn | Mode1000 | T64En | D64En | M64En | BEMode | PhyDis | ExtStEn); - OUTL(dev, config, ChipConfig); - - /* Configure the PCI bus bursts and FIFO thresholds. */ - tx_config = TxCarrierIgn | TxHeartIgn | TxAutoPad - | TxCollRetry | TxMxdma_1024 | (0x1002); - rx_config = RxMxdma_1024 | 0x20; - - debug("%s: Setting TxConfig Register %#08X\n", dev->name, tx_config); - debug("%s: Setting RxConfig Register %#08X\n", dev->name, rx_config); - - OUTL(dev, tx_config, TxConfig); - OUTL(dev, rx_config, RxConfig); - - /*turn off priority queueing */ - OUTL(dev, 0x0, PriQueue); - - ns8382x_check_duplex(dev); - ns8382x_set_rx_mode(dev); - - OUTL(dev, (RxOn | TxOn), ChipCmd); - return 1; -} - -/* Function: ns8382x_reset - * Description: soft resets the controller chip - * Arguments: struct eth_device *dev: NIC data structure - * Returns: void. - */ -static void -ns8382x_reset(struct eth_device *dev) -{ - OUTL(dev, ChipReset, ChipCmd); - while (INL(dev, ChipCmd)) - /*wait until done */ ; - OUTL(dev, 0, IntrMask); - OUTL(dev, 0, IntrEnable); -} - -/* Function: ns8382x_init_rxfilter - * Description: sets receive filter address to our MAC address - * Arguments: struct eth_device *dev: NIC data structure - * returns: void. - */ - -static void -ns8382x_init_rxfilter(struct eth_device *dev) -{ - int i; - - for (i = 0; i < ETH_ALEN; i += 2) { - OUTL(dev, i, RxFilterAddr); - OUTW(dev, dev->enetaddr[i] + (dev->enetaddr[i + 1] << 8), - RxFilterData); - } -} - -/* Function: ns8382x_init_txd - * Description: initializes the Tx descriptor - * Arguments: struct eth_device *dev: NIC data structure - * returns: void. - */ - -static void -ns8382x_init_txd(struct eth_device *dev) -{ - txd.link = (u32) 0; - txd.bufptr = cpu_to_le32((u32) & txb[0]); - txd.cmdsts = (u32) 0; - txd.extsts = (u32) 0; - - OUTL(dev, 0x0, TxRingPtrHi); - OUTL(dev, phys_to_bus((u32)&txd), TxRingPtr); - - debug("ns8382x_init_txd: TX descriptor register loaded with: %#08X (&txd: %p)\n", - INL(dev, TxRingPtr), &txd); -} - -/* Function: ns8382x_init_rxd - * Description: initializes the Rx descriptor ring - * Arguments: struct eth_device *dev: NIC data structure - * Returns: void. - */ - -static void -ns8382x_init_rxd(struct eth_device *dev) -{ - int i; - - OUTL(dev, 0x0, RxRingPtrHi); - - cur_rx = 0; - for (i = 0; i < NUM_RX_DESC; i++) { - rxd[i].link = - cpu_to_le32((i + 1 < - NUM_RX_DESC) ? (u32) & rxd[i + - 1] : (u32) & - rxd[0]); - rxd[i].extsts = cpu_to_le32((u32) 0x0); - rxd[i].cmdsts = cpu_to_le32((u32) RX_BUF_SIZE); - rxd[i].bufptr = cpu_to_le32((u32) & rxb[i * RX_BUF_SIZE]); - - debug - ("ns8382x_init_rxd: rxd[%d]=%p link=%X cmdsts=%X bufptr=%X\n", - i, &rxd[i], le32_to_cpu(rxd[i].link), - le32_to_cpu(rxd[i].cmdsts), le32_to_cpu(rxd[i].bufptr)); - } - OUTL(dev, phys_to_bus((u32) & rxd), RxRingPtr); - - debug("ns8382x_init_rxd: RX descriptor register loaded with: %X\n", - INL(dev, RxRingPtr)); -} - -/* Function: ns8382x_set_rx_mode - * Description: - * sets the receive mode to accept all broadcast packets and packets - * with our MAC address, and reject all multicast packets. - * Arguments: struct eth_device *dev: NIC data structure - * Returns: void. - */ - -static void -ns8382x_set_rx_mode(struct eth_device *dev) -{ - u32 rx_mode = 0x0; - /*spec says RxFilterEnable has to be 0 for rest of - * this stuff to be properly configured. Linux driver - * seems to support this*/ -/* OUTL(dev, rx_mode, RxFilterAddr);*/ - rx_mode = (RxFilterEnable | AcceptAllBroadcast | AcceptPerfectMatch); - OUTL(dev, rx_mode, RxFilterAddr); - printf("ns8382x_set_rx_mode: set to %X\n", rx_mode); - /*now we turn RxFilterEnable back on */ - /*rx_mode |= RxFilterEnable; - OUTL(dev, rx_mode, RxFilterAddr);*/ -} - -static void -ns8382x_check_duplex(struct eth_device *dev) -{ - int gig = 0; - int hun = 0; - int duplex = 0; - int config = (INL(dev, ChipConfig) ^ SpeedStatus_Polarity); - - duplex = (config & FullDuplex) ? 1 : 0; - gig = (config & GigSpeed) ? 1 : 0; - hun = (config & HundSpeed) ? 1 : 0; - - debug("%s: Setting 10%s %s-duplex based on negotiated link" - " capability.\n", dev->name, (gig) ? "00" : (hun) ? "0" : "", - duplex ? "full" : "half"); - - if (duplex) { - rx_config |= RxAcceptTx; - tx_config |= (TxCarrierIgn | TxHeartIgn); - } else { - rx_config &= ~RxAcceptTx; - tx_config &= ~(TxCarrierIgn | TxHeartIgn); - } - - debug("%s: Resetting TxConfig Register %#08X\n", dev->name, tx_config); - debug("%s: Resetting RxConfig Register %#08X\n", dev->name, rx_config); - - OUTL(dev, tx_config, TxConfig); - OUTL(dev, rx_config, RxConfig); - - /*if speed is 10 or 100, remove MODE1000, - * if it's 1000, then set it */ - config = INL(dev, ChipConfig); - if (gig) - config |= Mode1000; - else - config &= ~Mode1000; - - debug("%s: %setting Mode1000\n", dev->name, (gig) ? "S" : "Uns"); - - OUTL(dev, config, ChipConfig); -} - -/* Function: ns8382x_send - * Description: transmits a packet and waits for completion or timeout. - * Returns: void. */ -static int ns8382x_send(struct eth_device *dev, void *packet, int length) -{ - u32 i, status = 0; - vu_long tx_stat = 0; - - /* Stop the transmitter */ - OUTL(dev, TxOff, ChipCmd); - - debug("ns8382x_send: sending %d bytes\n", (int)length); - - /* set the transmit buffer descriptor and enable Transmit State Machine */ - txd.link = cpu_to_le32(0x0); - txd.bufptr = cpu_to_le32(phys_to_bus((u32)packet)); - txd.extsts = cpu_to_le32(0x0); - txd.cmdsts = cpu_to_le32(DescOwn | length); - - /* load Transmit Descriptor Register */ - OUTL(dev, phys_to_bus((u32) & txd), TxRingPtr); - - debug("ns8382x_send: TX descriptor register loaded with: %#08X\n", - INL(dev, TxRingPtr)); - debug("\ttxd.link:%X\tbufp:%X\texsts:%X\tcmdsts:%X\n", - le32_to_cpu(txd.link), le32_to_cpu(txd.bufptr), - le32_to_cpu(txd.extsts), le32_to_cpu(txd.cmdsts)); - - /* restart the transmitter */ - OUTL(dev, TxOn, ChipCmd); - - for (i = 0; (tx_stat = le32_to_cpu(txd.cmdsts)) & DescOwn; i++) { - if (i >= TOUT_LOOP) { - printf ("%s: tx error buffer not ready: txd.cmdsts %#lX\n", - dev->name, tx_stat); - goto Done; - } - } - - if (!(tx_stat & DescPktOK)) { - printf("ns8382x_send: Transmit error, Tx status %lX.\n", tx_stat); - goto Done; - } - - debug("ns8382x_send: tx_stat: %#08lX\n", tx_stat); - - status = 1; -Done: - return status; -} - -/* Function: ns8382x_poll - * Description: checks for a received packet and returns it if found. - * Arguments: struct eth_device *dev: NIC data structure - * Returns: 1 if packet was received. - * 0 if no packet was received. - * Side effects: - * Returns (copies) the packet to the array dev->packet. - * Returns the length of the packet. - */ - -static int -ns8382x_poll(struct eth_device *dev) -{ - int retstat = 0; - int length = 0; - vu_long rx_status = le32_to_cpu(rxd[cur_rx].cmdsts); - - if (!(rx_status & (u32) DescOwn)) - return retstat; - - debug("ns8382x_poll: got a packet: cur_rx:%u, status:%lx\n", - cur_rx, rx_status); - - length = (rx_status & DSIZE) - CRC_SIZE; - - if ((rx_status & (DescMore | DescPktOK | DescRxLong)) != DescPktOK) { - /* corrupted packet received */ - printf("ns8382x_poll: Corrupted packet, status:%lx\n", - rx_status); - retstat = 0; - } else { - /* give packet to higher level routine */ - net_process_received_packet((rxb + cur_rx * RX_BUF_SIZE), - length); - retstat = 1; - } - - /* return the descriptor and buffer to receive ring */ - rxd[cur_rx].cmdsts = cpu_to_le32(RX_BUF_SIZE); - rxd[cur_rx].bufptr = cpu_to_le32((u32) & rxb[cur_rx * RX_BUF_SIZE]); - - if (++cur_rx == NUM_RX_DESC) - cur_rx = 0; - - /* re-enable the potentially idle receive state machine */ - OUTL(dev, RxOn, ChipCmd); - - return retstat; -} - -/* Function: ns8382x_disable - * Description: Turns off interrupts and stops Tx and Rx engines - * Arguments: struct eth_device *dev: NIC data structure - * Returns: void. - */ - -static void -ns8382x_disable(struct eth_device *dev) -{ - /* Disable interrupts using the mask. */ - OUTL(dev, 0, IntrMask); - OUTL(dev, 0, IntrEnable); - - /* Stop the chip's Tx and Rx processes. */ - OUTL(dev, (RxOff | TxOff), ChipCmd); - - /* Restore PME enable bit */ - OUTL(dev, SavedClkRun, ClkRun); -}
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/net/Makefile | 1 - drivers/net/uli526x.c | 996 ------------------------------------------ 2 files changed, 997 deletions(-) delete mode 100644 drivers/net/uli526x.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 02b36582ce46..69570bebb447 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -85,7 +85,6 @@ obj-$(CONFIG_SUN4I_EMAC) += sunxi_emac.o obj-$(CONFIG_SUN8I_EMAC) += sun8i_emac.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_TULIP) += dc2114x.o -obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o obj-$(CONFIG_VSC9953) += vsc9953.o obj-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o diff --git a/drivers/net/uli526x.c b/drivers/net/uli526x.c deleted file mode 100644 index 3191868cae5a..000000000000 --- a/drivers/net/uli526x.c +++ /dev/null @@ -1,996 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007, 2010 Freescale Semiconductor, Inc. - * - * Author: Roy Zang tie-fei.zang@freescale.com, Sep, 2007 - * - * Description: - * ULI 526x Ethernet port driver. - * Based on the Linux driver: drivers/net/tulip/uli526x.c - */ - -#include <common.h> -#include <malloc.h> -#include <net.h> -#include <netdev.h> -#include <asm/io.h> -#include <pci.h> -#include <miiphy.h> -#include <linux/delay.h> - -/* some kernel function compatible define */ - -#undef DEBUG - -/* Board/System/Debug information/definition */ -#define ULI_VENDOR_ID 0x10B9 -#define ULI5261_DEVICE_ID 0x5261 -#define ULI5263_DEVICE_ID 0x5263 -/* ULi M5261 ID*/ -#define PCI_ULI5261_ID (ULI5261_DEVICE_ID << 16 | ULI_VENDOR_ID) -/* ULi M5263 ID*/ -#define PCI_ULI5263_ID (ULI5263_DEVICE_ID << 16 | ULI_VENDOR_ID) - -#define ULI526X_IO_SIZE 0x100 -#define TX_DESC_CNT 0x10 /* Allocated Tx descriptors */ -#define RX_DESC_CNT PKTBUFSRX /* Allocated Rx descriptors */ -#define TX_FREE_DESC_CNT (TX_DESC_CNT - 2) /* Max TX packet count */ -#define TX_WAKE_DESC_CNT (TX_DESC_CNT - 3) /* TX wakeup count */ -#define DESC_ALL_CNT (TX_DESC_CNT + RX_DESC_CNT) -#define TX_BUF_ALLOC 0x300 -#define RX_ALLOC_SIZE PKTSIZE -#define ULI526X_RESET 1 -#define CR0_DEFAULT 0 -#define CR6_DEFAULT 0x22200000 -#define CR7_DEFAULT 0x180c1 -#define CR15_DEFAULT 0x06 /* TxJabber RxWatchdog */ -#define TDES0_ERR_MASK 0x4302 /* TXJT, LC, EC, FUE */ -#define MAX_PACKET_SIZE 1514 -#define ULI5261_MAX_MULTICAST 14 -#define RX_COPY_SIZE 100 -#define MAX_CHECK_PACKET 0x8000 - -#define ULI526X_10MHF 0 -#define ULI526X_100MHF 1 -#define ULI526X_10MFD 4 -#define ULI526X_100MFD 5 -#define ULI526X_AUTO 8 - -#define ULI526X_TXTH_72 0x400000 /* TX TH 72 byte */ -#define ULI526X_TXTH_96 0x404000 /* TX TH 96 byte */ -#define ULI526X_TXTH_128 0x0000 /* TX TH 128 byte */ -#define ULI526X_TXTH_256 0x4000 /* TX TH 256 byte */ -#define ULI526X_TXTH_512 0x8000 /* TX TH 512 byte */ -#define ULI526X_TXTH_1K 0xC000 /* TX TH 1K byte */ - -/* CR9 definition: SROM/MII */ -#define CR9_SROM_READ 0x4800 -#define CR9_SRCS 0x1 -#define CR9_SRCLK 0x2 -#define CR9_CRDOUT 0x8 -#define SROM_DATA_0 0x0 -#define SROM_DATA_1 0x4 -#define PHY_DATA_1 0x20000 -#define PHY_DATA_0 0x00000 -#define MDCLKH 0x10000 - -#define PHY_POWER_DOWN 0x800 - -#define SROM_V41_CODE 0x14 - -#define SROM_CLK_WRITE(data, ioaddr) do { \ - outl(data|CR9_SROM_READ|CR9_SRCS, ioaddr); \ - udelay(5); \ - outl(data|CR9_SROM_READ|CR9_SRCS|CR9_SRCLK, ioaddr); \ - udelay(5); \ - outl(data|CR9_SROM_READ|CR9_SRCS, ioaddr); \ - udelay(5); \ - } while (0) - -/* Structure/enum declaration */ - -struct tx_desc { - u32 tdes0, tdes1, tdes2, tdes3; /* Data for the card */ - char *tx_buf_ptr; /* Data for us */ - struct tx_desc *next_tx_desc; -}; - -struct rx_desc { - u32 rdes0, rdes1, rdes2, rdes3; /* Data for the card */ - char *rx_buf_ptr; /* Data for us */ - struct rx_desc *next_rx_desc; -}; - -struct uli526x_board_info { - u32 chip_id; /* Chip vendor/Device ID */ - pci_dev_t pdev; - - long ioaddr; /* I/O base address */ - u32 cr0_data; - u32 cr5_data; - u32 cr6_data; - u32 cr7_data; - u32 cr15_data; - - /* pointer for memory physical address */ - dma_addr_t buf_pool_dma_ptr; /* Tx buffer pool memory */ - dma_addr_t buf_pool_dma_start; /* Tx buffer pool align dword */ - dma_addr_t desc_pool_dma_ptr; /* descriptor pool memory */ - dma_addr_t first_tx_desc_dma; - dma_addr_t first_rx_desc_dma; - - /* descriptor pointer */ - unsigned char *buf_pool_ptr; /* Tx buffer pool memory */ - unsigned char *buf_pool_start; /* Tx buffer pool align dword */ - unsigned char *desc_pool_ptr; /* descriptor pool memory */ - struct tx_desc *first_tx_desc; - struct tx_desc *tx_insert_ptr; - struct tx_desc *tx_remove_ptr; - struct rx_desc *first_rx_desc; - struct rx_desc *rx_ready_ptr; /* packet come pointer */ - unsigned long tx_packet_cnt; /* transmitted packet count */ - - u16 PHY_reg4; /* Saved Phyxcer register 4 value */ - - u8 media_mode; /* user specify media mode */ - u8 op_mode; /* real work dedia mode */ - u8 phy_addr; - - /* NIC SROM data */ - unsigned char srom[128]; -}; - -enum uli526x_offsets { - DCR0 = 0x00, DCR1 = 0x08, DCR2 = 0x10, DCR3 = 0x18, DCR4 = 0x20, - DCR5 = 0x28, DCR6 = 0x30, DCR7 = 0x38, DCR8 = 0x40, DCR9 = 0x48, - DCR10 = 0x50, DCR11 = 0x58, DCR12 = 0x60, DCR13 = 0x68, DCR14 = 0x70, - DCR15 = 0x78 -}; - -enum uli526x_CR6_bits { - CR6_RXSC = 0x2, CR6_PBF = 0x8, CR6_PM = 0x40, CR6_PAM = 0x80, - CR6_FDM = 0x200, CR6_TXSC = 0x2000, CR6_STI = 0x100000, - CR6_SFT = 0x200000, CR6_RXA = 0x40000000, CR6_NO_PURGE = 0x20000000 -}; - -/* Global variable declaration -- */ - -static unsigned char uli526x_media_mode = ULI526X_AUTO; - -static struct tx_desc desc_pool_array[DESC_ALL_CNT + 0x20] - __attribute__ ((aligned(32))); -static char buf_pool[TX_BUF_ALLOC * TX_DESC_CNT + 4]; - -/* For module input parameter */ -static int mode = 8; - -/* function declaration -- */ -static int uli526x_start_xmit(struct eth_device *dev, void *packet, int length); -static u16 read_srom_word(long, int); -static void uli526x_descriptor_init(struct uli526x_board_info *, unsigned long); -static void allocate_rx_buffer(struct uli526x_board_info *); -static void update_cr6(u32, unsigned long); -static u16 uli_phy_read(unsigned long, u8, u8, u32); -static u16 phy_readby_cr10(unsigned long, u8, u8); -static void uli_phy_write(unsigned long, u8, u8, u16, u32); -static void phy_writeby_cr10(unsigned long, u8, u8, u16); -static void phy_write_1bit(unsigned long, u32, u32); -static u16 phy_read_1bit(unsigned long, u32); -static int uli526x_rx_packet(struct eth_device *); -static void uli526x_free_tx_pkt(struct eth_device *, - struct uli526x_board_info *); -static void uli526x_reuse_buf(struct rx_desc *); -static void uli526x_init(struct eth_device *); -static void uli526x_set_phyxcer(struct uli526x_board_info *); - - -static int uli526x_init_one(struct eth_device *, struct bd_info *); -static void uli526x_disable(struct eth_device *); -static void set_mac_addr(struct eth_device *); - -static struct pci_device_id uli526x_pci_tbl[] = { - { ULI_VENDOR_ID, ULI5261_DEVICE_ID}, /* 5261 device */ - { ULI_VENDOR_ID, ULI5263_DEVICE_ID}, /* 5263 device */ - {} -}; - -/* ULI526X network board routine */ - -/* - * Search ULI526X board, register it - */ - -int uli526x_initialize(struct bd_info *bis) -{ - pci_dev_t devno; - int card_number = 0; - struct eth_device *dev; - struct uli526x_board_info *db; /* board information structure */ - - u32 iobase; - int idx = 0; - - while (1) { - /* Find PCI device */ - devno = pci_find_devices(uli526x_pci_tbl, idx++); - if (devno < 0) - break; - - pci_read_config_dword(devno, PCI_BASE_ADDRESS_1, &iobase); - iobase &= ~0xf; - - dev = (struct eth_device *)malloc(sizeof *dev); - if (!dev) { - printf("uli526x: Can not allocate memory\n"); - break; - } - memset(dev, 0, sizeof(*dev)); - sprintf(dev->name, "uli526x#%d", card_number); - db = (struct uli526x_board_info *) - malloc(sizeof(struct uli526x_board_info)); - - dev->priv = db; - db->pdev = devno; - dev->iobase = iobase; - - dev->init = uli526x_init_one; - dev->halt = uli526x_disable; - dev->send = uli526x_start_xmit; - dev->recv = uli526x_rx_packet; - - /* init db */ - db->ioaddr = dev->iobase; - /* get chip id */ - - pci_read_config_dword(devno, PCI_VENDOR_ID, &db->chip_id); -#ifdef DEBUG - printf("uli526x: uli526x @0x%x\n", iobase); - printf("uli526x: chip_id%x\n", db->chip_id); -#endif - eth_register(dev); - card_number++; - pci_write_config_byte(devno, PCI_LATENCY_TIMER, 0x20); - udelay(10 * 1000); - } - return card_number; -} - -static int uli526x_init_one(struct eth_device *dev, struct bd_info *bis) -{ - - struct uli526x_board_info *db = dev->priv; - int i; - - switch (mode) { - case ULI526X_10MHF: - case ULI526X_100MHF: - case ULI526X_10MFD: - case ULI526X_100MFD: - uli526x_media_mode = mode; - break; - default: - uli526x_media_mode = ULI526X_AUTO; - break; - } - - /* Allocate Tx/Rx descriptor memory */ - db->desc_pool_ptr = (uchar *)&desc_pool_array[0]; - db->desc_pool_dma_ptr = (dma_addr_t)&desc_pool_array[0]; - if (db->desc_pool_ptr == NULL) - return -1; - - db->buf_pool_ptr = (uchar *)&buf_pool[0]; - db->buf_pool_dma_ptr = (dma_addr_t)&buf_pool[0]; - if (db->buf_pool_ptr == NULL) - return -1; - - db->first_tx_desc = (struct tx_desc *) db->desc_pool_ptr; - db->first_tx_desc_dma = db->desc_pool_dma_ptr; - - db->buf_pool_start = db->buf_pool_ptr; - db->buf_pool_dma_start = db->buf_pool_dma_ptr; - -#ifdef DEBUG - printf("%s(): db->ioaddr= 0x%x\n", - __FUNCTION__, db->ioaddr); - printf("%s(): media_mode= 0x%x\n", - __FUNCTION__, uli526x_media_mode); - printf("%s(): db->desc_pool_ptr= 0x%x\n", - __FUNCTION__, db->desc_pool_ptr); - printf("%s(): db->desc_pool_dma_ptr= 0x%x\n", - __FUNCTION__, db->desc_pool_dma_ptr); - printf("%s(): db->buf_pool_ptr= 0x%x\n", - __FUNCTION__, db->buf_pool_ptr); - printf("%s(): db->buf_pool_dma_ptr= 0x%x\n", - __FUNCTION__, db->buf_pool_dma_ptr); -#endif - - /* read 64 word srom data */ - for (i = 0; i < 64; i++) - ((u16 *) db->srom)[i] = cpu_to_le16(read_srom_word(db->ioaddr, - i)); - - /* Set Node address */ - if (((db->srom[0] == 0xff) && (db->srom[1] == 0xff)) || - ((db->srom[0] == 0x00) && (db->srom[1] == 0x00))) - /* SROM absent, so write MAC address to ID Table */ - set_mac_addr(dev); - else { /*Exist SROM*/ - for (i = 0; i < 6; i++) - dev->enetaddr[i] = db->srom[20 + i]; - } -#ifdef DEBUG - for (i = 0; i < 6; i++) - printf("%c%02x", i ? ':' : ' ', dev->enetaddr[i]); -#endif - db->PHY_reg4 = 0x1e0; - - /* system variable init */ - db->cr6_data = CR6_DEFAULT ; - db->cr6_data |= ULI526X_TXTH_256; - db->cr0_data = CR0_DEFAULT; - uli526x_init(dev); - return 0; -} - -static void uli526x_disable(struct eth_device *dev) -{ -#ifdef DEBUG - printf("uli526x_disable\n"); -#endif - struct uli526x_board_info *db = dev->priv; - - if (!((inl(db->ioaddr + DCR12)) & 0x8)) { - /* Reset & stop ULI526X board */ - outl(ULI526X_RESET, db->ioaddr + DCR0); - udelay(5); - uli_phy_write(db->ioaddr, db->phy_addr, 0, 0x8000, db->chip_id); - - /* reset the board */ - db->cr6_data &= ~(CR6_RXSC | CR6_TXSC); /* Disable Tx/Rx */ - update_cr6(db->cr6_data, dev->iobase); - outl(0, dev->iobase + DCR7); /* Disable Interrupt */ - outl(inl(dev->iobase + DCR5), dev->iobase + DCR5); - } -} - -/* Initialize ULI526X board - * Reset ULI526X board - * Initialize TX/Rx descriptor chain structure - * Send the set-up frame - * Enable Tx/Rx machine - */ - -static void uli526x_init(struct eth_device *dev) -{ - - struct uli526x_board_info *db = dev->priv; - u8 phy_tmp; - u16 phy_value; - u16 phy_reg_reset; - - /* Reset M526x MAC controller */ - outl(ULI526X_RESET, db->ioaddr + DCR0); /* RESET MAC */ - udelay(100); - outl(db->cr0_data, db->ioaddr + DCR0); - udelay(5); - - /* Phy addr : In some boards,M5261/M5263 phy address != 1 */ - db->phy_addr = 1; - db->tx_packet_cnt = 0; - for (phy_tmp = 0; phy_tmp < 32; phy_tmp++) { - /* peer add */ - phy_value = uli_phy_read(db->ioaddr, phy_tmp, 3, db->chip_id); - if (phy_value != 0xffff && phy_value != 0) { - db->phy_addr = phy_tmp; - break; - } - } - -#ifdef DEBUG - printf("%s(): db->ioaddr= 0x%x\n", __FUNCTION__, db->ioaddr); - printf("%s(): db->phy_addr= 0x%x\n", __FUNCTION__, db->phy_addr); -#endif - if (phy_tmp == 32) - printf("Can not find the phy address!!!"); - - /* Parser SROM and media mode */ - db->media_mode = uli526x_media_mode; - - if (!(inl(db->ioaddr + DCR12) & 0x8)) { - /* Phyxcer capability setting */ - phy_reg_reset = uli_phy_read(db->ioaddr, - db->phy_addr, 0, db->chip_id); - phy_reg_reset = (phy_reg_reset | 0x8000); - uli_phy_write(db->ioaddr, db->phy_addr, 0, - phy_reg_reset, db->chip_id); - udelay(500); - - /* Process Phyxcer Media Mode */ - uli526x_set_phyxcer(db); - } - /* Media Mode Process */ - if (!(db->media_mode & ULI526X_AUTO)) - db->op_mode = db->media_mode; /* Force Mode */ - - /* Initialize Transmit/Receive decriptor and CR3/4 */ - uli526x_descriptor_init(db, db->ioaddr); - - /* Init CR6 to program M526X operation */ - update_cr6(db->cr6_data, db->ioaddr); - - /* Init CR7, interrupt active bit */ - db->cr7_data = CR7_DEFAULT; - outl(db->cr7_data, db->ioaddr + DCR7); - - /* Init CR15, Tx jabber and Rx watchdog timer */ - outl(db->cr15_data, db->ioaddr + DCR15); - - /* Enable ULI526X Tx/Rx function */ - db->cr6_data |= CR6_RXSC | CR6_TXSC; - update_cr6(db->cr6_data, db->ioaddr); - while (!(inl(db->ioaddr + DCR12) & 0x8)) - udelay(10); -} - -/* - * Hardware start transmission. - * Send a packet to media from the upper layer. - */ - -static int uli526x_start_xmit(struct eth_device *dev, void *packet, int length) -{ - struct uli526x_board_info *db = dev->priv; - struct tx_desc *txptr; - unsigned int len = length; - /* Too large packet check */ - if (len > MAX_PACKET_SIZE) { - printf(": big packet = %d\n", len); - return 0; - } - - /* No Tx resource check, it never happen nromally */ - if (db->tx_packet_cnt >= TX_FREE_DESC_CNT) { - printf("No Tx resource %ld\n", db->tx_packet_cnt); - return 0; - } - - /* Disable NIC interrupt */ - outl(0, dev->iobase + DCR7); - - /* transmit this packet */ - txptr = db->tx_insert_ptr; - memcpy((char *)txptr->tx_buf_ptr, (char *)packet, (int)length); - txptr->tdes1 = cpu_to_le32(0xe1000000 | length); - - /* Point to next transmit free descriptor */ - db->tx_insert_ptr = txptr->next_tx_desc; - - /* Transmit Packet Process */ - if ((db->tx_packet_cnt < TX_DESC_CNT)) { - txptr->tdes0 = cpu_to_le32(0x80000000); /* Set owner bit */ - db->tx_packet_cnt++; /* Ready to send */ - outl(0x1, dev->iobase + DCR1); /* Issue Tx polling */ - } - - /* Got ULI526X status */ - db->cr5_data = inl(db->ioaddr + DCR5); - outl(db->cr5_data, db->ioaddr + DCR5); - -#ifdef TX_DEBUG - printf("%s(): length = 0x%x\n", __FUNCTION__, length); - printf("%s(): cr5_data=%x\n", __FUNCTION__, db->cr5_data); -#endif - - outl(db->cr7_data, dev->iobase + DCR7); - uli526x_free_tx_pkt(dev, db); - - return length; -} - -/* - * Free TX resource after TX complete - */ - -static void uli526x_free_tx_pkt(struct eth_device *dev, - struct uli526x_board_info *db) -{ - struct tx_desc *txptr; - u32 tdes0; - - txptr = db->tx_remove_ptr; - while (db->tx_packet_cnt) { - tdes0 = le32_to_cpu(txptr->tdes0); - /* printf(DRV_NAME ": tdes0=%x\n", tdes0); */ - if (tdes0 & 0x80000000) - break; - - /* A packet sent completed */ - db->tx_packet_cnt--; - - if (tdes0 != 0x7fffffff) { -#ifdef TX_DEBUG - printf("%s()tdes0=%x\n", __FUNCTION__, tdes0); -#endif - if (tdes0 & TDES0_ERR_MASK) { - if (tdes0 & 0x0002) { /* UnderRun */ - if (!(db->cr6_data & CR6_SFT)) { - db->cr6_data = db->cr6_data | - CR6_SFT; - update_cr6(db->cr6_data, - db->ioaddr); - } - } - } - } - - txptr = txptr->next_tx_desc; - }/* End of while */ - - /* Update TX remove pointer to next */ - db->tx_remove_ptr = txptr; -} - - -/* - * Receive the come packet and pass to upper layer - */ - -static int uli526x_rx_packet(struct eth_device *dev) -{ - struct uli526x_board_info *db = dev->priv; - struct rx_desc *rxptr; - int rxlen = 0; - u32 rdes0; - - rxptr = db->rx_ready_ptr; - - rdes0 = le32_to_cpu(rxptr->rdes0); -#ifdef RX_DEBUG - printf("%s(): rxptr->rdes0=%x\n", __FUNCTION__, rxptr->rdes0); -#endif - if (!(rdes0 & 0x80000000)) { /* packet owner check */ - if ((rdes0 & 0x300) != 0x300) { - /* A packet without First/Last flag */ - /* reuse this buf */ - printf("A packet without First/Last flag"); - uli526x_reuse_buf(rxptr); - } else { - /* A packet with First/Last flag */ - rxlen = ((rdes0 >> 16) & 0x3fff) - 4; -#ifdef RX_DEBUG - printf("%s(): rxlen =%x\n", __FUNCTION__, rxlen); -#endif - /* error summary bit check */ - if (rdes0 & 0x8000) { - /* This is a error packet */ - printf("Error: rdes0: %x\n", rdes0); - } - - if (!(rdes0 & 0x8000) || - ((db->cr6_data & CR6_PM) && (rxlen > 6))) { - -#ifdef RX_DEBUG - printf("%s(): rx_skb_ptr =%x\n", - __FUNCTION__, rxptr->rx_buf_ptr); - printf("%s(): rxlen =%x\n", - __FUNCTION__, rxlen); - - printf("%s(): buf addr =%x\n", - __FUNCTION__, rxptr->rx_buf_ptr); - printf("%s(): rxlen =%x\n", - __FUNCTION__, rxlen); - int i; - for (i = 0; i < 0x20; i++) - printf("%s(): data[%x] =%x\n", - __FUNCTION__, i, rxptr->rx_buf_ptr[i]); -#endif - - net_process_received_packet( - (uchar *)rxptr->rx_buf_ptr, rxlen); - uli526x_reuse_buf(rxptr); - - } else { - /* Reuse SKB buffer when the packet is error */ - printf("Reuse buffer, rdes0"); - uli526x_reuse_buf(rxptr); - } - } - - rxptr = rxptr->next_rx_desc; - } - - db->rx_ready_ptr = rxptr; - return rxlen; -} - -/* - * Reuse the RX buffer - */ - -static void uli526x_reuse_buf(struct rx_desc *rxptr) -{ - - if (!(rxptr->rdes0 & cpu_to_le32(0x80000000))) - rxptr->rdes0 = cpu_to_le32(0x80000000); - else - printf("Buffer reuse method error"); -} -/* - * Initialize transmit/Receive descriptor - * Using Chain structure, and allocate Tx/Rx buffer - */ - -static void uli526x_descriptor_init(struct uli526x_board_info *db, - unsigned long ioaddr) -{ - struct tx_desc *tmp_tx; - struct rx_desc *tmp_rx; - unsigned char *tmp_buf; - dma_addr_t tmp_tx_dma, tmp_rx_dma; - dma_addr_t tmp_buf_dma; - int i; - /* tx descriptor start pointer */ - db->tx_insert_ptr = db->first_tx_desc; - db->tx_remove_ptr = db->first_tx_desc; - - outl(db->first_tx_desc_dma, ioaddr + DCR4); /* TX DESC address */ - - /* rx descriptor start pointer */ - db->first_rx_desc = (void *)db->first_tx_desc + - sizeof(struct tx_desc) * TX_DESC_CNT; - db->first_rx_desc_dma = db->first_tx_desc_dma + - sizeof(struct tx_desc) * TX_DESC_CNT; - db->rx_ready_ptr = db->first_rx_desc; - outl(db->first_rx_desc_dma, ioaddr + DCR3); /* RX DESC address */ -#ifdef DEBUG - printf("%s(): db->first_tx_desc= 0x%x\n", - __FUNCTION__, db->first_tx_desc); - printf("%s(): db->first_rx_desc_dma= 0x%x\n", - __FUNCTION__, db->first_rx_desc_dma); -#endif - /* Init Transmit chain */ - tmp_buf = db->buf_pool_start; - tmp_buf_dma = db->buf_pool_dma_start; - tmp_tx_dma = db->first_tx_desc_dma; - for (tmp_tx = db->first_tx_desc, i = 0; - i < TX_DESC_CNT; i++, tmp_tx++) { - tmp_tx->tx_buf_ptr = (char *)tmp_buf; - tmp_tx->tdes0 = cpu_to_le32(0); - tmp_tx->tdes1 = cpu_to_le32(0x81000000); /* IC, chain */ - tmp_tx->tdes2 = cpu_to_le32(tmp_buf_dma); - tmp_tx_dma += sizeof(struct tx_desc); - tmp_tx->tdes3 = cpu_to_le32(tmp_tx_dma); - tmp_tx->next_tx_desc = tmp_tx + 1; - tmp_buf = tmp_buf + TX_BUF_ALLOC; - tmp_buf_dma = tmp_buf_dma + TX_BUF_ALLOC; - } - (--tmp_tx)->tdes3 = cpu_to_le32(db->first_tx_desc_dma); - tmp_tx->next_tx_desc = db->first_tx_desc; - - /* Init Receive descriptor chain */ - tmp_rx_dma = db->first_rx_desc_dma; - for (tmp_rx = db->first_rx_desc, i = 0; i < RX_DESC_CNT; - i++, tmp_rx++) { - tmp_rx->rdes0 = cpu_to_le32(0); - tmp_rx->rdes1 = cpu_to_le32(0x01000600); - tmp_rx_dma += sizeof(struct rx_desc); - tmp_rx->rdes3 = cpu_to_le32(tmp_rx_dma); - tmp_rx->next_rx_desc = tmp_rx + 1; - } - (--tmp_rx)->rdes3 = cpu_to_le32(db->first_rx_desc_dma); - tmp_rx->next_rx_desc = db->first_rx_desc; - - /* pre-allocate Rx buffer */ - allocate_rx_buffer(db); -} - -/* - * Update CR6 value - * Firstly stop ULI526X, then written value and start - */ - -static void update_cr6(u32 cr6_data, unsigned long ioaddr) -{ - - outl(cr6_data, ioaddr + DCR6); - udelay(5); -} - -/* - * Allocate rx buffer, - */ - -static void allocate_rx_buffer(struct uli526x_board_info *db) -{ - int index; - struct rx_desc *rxptr; - rxptr = db->first_rx_desc; - u32 addr; - - for (index = 0; index < RX_DESC_CNT; index++) { - addr = (u32)net_rx_packets[index]; - addr += (16 - (addr & 15)); - rxptr->rx_buf_ptr = (char *) addr; - rxptr->rdes2 = cpu_to_le32(addr); - rxptr->rdes0 = cpu_to_le32(0x80000000); -#ifdef DEBUG - printf("%s(): Number 0x%x:\n", __FUNCTION__, index); - printf("%s(): addr 0x%x:\n", __FUNCTION__, addr); - printf("%s(): rxptr address = 0x%x\n", __FUNCTION__, rxptr); - printf("%s(): rxptr buf address = 0x%x\n", \ - __FUNCTION__, rxptr->rx_buf_ptr); - printf("%s(): rdes2 = 0x%x\n", __FUNCTION__, rxptr->rdes2); -#endif - rxptr = rxptr->next_rx_desc; - } -} - -/* - * Read one word data from the serial ROM - */ - -static u16 read_srom_word(long ioaddr, int offset) -{ - int i; - u16 srom_data = 0; - long cr9_ioaddr = ioaddr + DCR9; - - outl(CR9_SROM_READ, cr9_ioaddr); - outl(CR9_SROM_READ | CR9_SRCS, cr9_ioaddr); - - /* Send the Read Command 110b */ - SROM_CLK_WRITE(SROM_DATA_1, cr9_ioaddr); - SROM_CLK_WRITE(SROM_DATA_1, cr9_ioaddr); - SROM_CLK_WRITE(SROM_DATA_0, cr9_ioaddr); - - /* Send the offset */ - for (i = 5; i >= 0; i--) { - srom_data = (offset & (1 << i)) ? SROM_DATA_1 : SROM_DATA_0; - SROM_CLK_WRITE(srom_data, cr9_ioaddr); - } - - outl(CR9_SROM_READ | CR9_SRCS, cr9_ioaddr); - - for (i = 16; i > 0; i--) { - outl(CR9_SROM_READ | CR9_SRCS | CR9_SRCLK, cr9_ioaddr); - udelay(5); - srom_data = (srom_data << 1) | ((inl(cr9_ioaddr) & CR9_CRDOUT) - ? 1 : 0); - outl(CR9_SROM_READ | CR9_SRCS, cr9_ioaddr); - udelay(5); - } - - outl(CR9_SROM_READ, cr9_ioaddr); - return srom_data; -} - -/* - * Set 10/100 phyxcer capability - * AUTO mode : phyxcer register4 is NIC capability - * Force mode: phyxcer register4 is the force media - */ - -static void uli526x_set_phyxcer(struct uli526x_board_info *db) -{ - u16 phy_reg; - - /* Phyxcer capability setting */ - phy_reg = uli_phy_read(db->ioaddr, - db->phy_addr, 4, db->chip_id) & ~0x01e0; - - if (db->media_mode & ULI526X_AUTO) { - /* AUTO Mode */ - phy_reg |= db->PHY_reg4; - } else { - /* Force Mode */ - switch (db->media_mode) { - case ULI526X_10MHF: phy_reg |= 0x20; break; - case ULI526X_10MFD: phy_reg |= 0x40; break; - case ULI526X_100MHF: phy_reg |= 0x80; break; - case ULI526X_100MFD: phy_reg |= 0x100; break; - } - - } - - /* Write new capability to Phyxcer Reg4 */ - if (!(phy_reg & 0x01e0)) { - phy_reg |= db->PHY_reg4; - db->media_mode |= ULI526X_AUTO; - } - uli_phy_write(db->ioaddr, db->phy_addr, 4, phy_reg, db->chip_id); - - /* Restart Auto-Negotiation */ - uli_phy_write(db->ioaddr, db->phy_addr, 0, 0x1200, db->chip_id); - udelay(50); -} - -/* - * Write a word to Phy register - */ - -static void uli_phy_write(unsigned long iobase, u8 phy_addr, u8 offset, - u16 phy_data, u32 chip_id) -{ - u16 i; - unsigned long ioaddr; - - if (chip_id == PCI_ULI5263_ID) { - phy_writeby_cr10(iobase, phy_addr, offset, phy_data); - return; - } - /* M5261/M5263 Chip */ - ioaddr = iobase + DCR9; - - /* Send 33 synchronization clock to Phy controller */ - for (i = 0; i < 35; i++) - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - - /* Send start command(01) to Phy */ - phy_write_1bit(ioaddr, PHY_DATA_0, chip_id); - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - - /* Send write command(01) to Phy */ - phy_write_1bit(ioaddr, PHY_DATA_0, chip_id); - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - - /* Send Phy address */ - for (i = 0x10; i > 0; i = i >> 1) - phy_write_1bit(ioaddr, phy_addr & i ? - PHY_DATA_1 : PHY_DATA_0, chip_id); - - /* Send register address */ - for (i = 0x10; i > 0; i = i >> 1) - phy_write_1bit(ioaddr, offset & i ? - PHY_DATA_1 : PHY_DATA_0, chip_id); - - /* written trasnition */ - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - phy_write_1bit(ioaddr, PHY_DATA_0, chip_id); - - /* Write a word data to PHY controller */ - for (i = 0x8000; i > 0; i >>= 1) - phy_write_1bit(ioaddr, phy_data & i ? - PHY_DATA_1 : PHY_DATA_0, chip_id); -} - -/* - * Read a word data from phy register - */ - -static u16 uli_phy_read(unsigned long iobase, u8 phy_addr, u8 offset, - u32 chip_id) -{ - int i; - u16 phy_data; - unsigned long ioaddr; - - if (chip_id == PCI_ULI5263_ID) - return phy_readby_cr10(iobase, phy_addr, offset); - /* M5261/M5263 Chip */ - ioaddr = iobase + DCR9; - - /* Send 33 synchronization clock to Phy controller */ - for (i = 0; i < 35; i++) - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - - /* Send start command(01) to Phy */ - phy_write_1bit(ioaddr, PHY_DATA_0, chip_id); - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - - /* Send read command(10) to Phy */ - phy_write_1bit(ioaddr, PHY_DATA_1, chip_id); - phy_write_1bit(ioaddr, PHY_DATA_0, chip_id); - - /* Send Phy address */ - for (i = 0x10; i > 0; i = i >> 1) - phy_write_1bit(ioaddr, phy_addr & i ? - PHY_DATA_1 : PHY_DATA_0, chip_id); - - /* Send register address */ - for (i = 0x10; i > 0; i = i >> 1) - phy_write_1bit(ioaddr, offset & i ? - PHY_DATA_1 : PHY_DATA_0, chip_id); - - /* Skip transition state */ - phy_read_1bit(ioaddr, chip_id); - - /* read 16bit data */ - for (phy_data = 0, i = 0; i < 16; i++) { - phy_data <<= 1; - phy_data |= phy_read_1bit(ioaddr, chip_id); - } - - return phy_data; -} - -static u16 phy_readby_cr10(unsigned long iobase, u8 phy_addr, u8 offset) -{ - unsigned long ioaddr, cr10_value; - - ioaddr = iobase + DCR10; - cr10_value = phy_addr; - cr10_value = (cr10_value<<5) + offset; - cr10_value = (cr10_value<<16) + 0x08000000; - outl(cr10_value, ioaddr); - udelay(1); - while (1) { - cr10_value = inl(ioaddr); - if (cr10_value & 0x10000000) - break; - } - return (cr10_value&0x0ffff); -} - -static void phy_writeby_cr10(unsigned long iobase, u8 phy_addr, - u8 offset, u16 phy_data) -{ - unsigned long ioaddr, cr10_value; - - ioaddr = iobase + DCR10; - cr10_value = phy_addr; - cr10_value = (cr10_value<<5) + offset; - cr10_value = (cr10_value<<16) + 0x04000000 + phy_data; - outl(cr10_value, ioaddr); - udelay(1); -} -/* - * Write one bit data to Phy Controller - */ - -static void phy_write_1bit(unsigned long ioaddr, u32 phy_data, u32 chip_id) -{ - outl(phy_data , ioaddr); /* MII Clock Low */ - udelay(1); - outl(phy_data | MDCLKH, ioaddr); /* MII Clock High */ - udelay(1); - outl(phy_data , ioaddr); /* MII Clock Low */ - udelay(1); -} - -/* - * Read one bit phy data from PHY controller - */ - -static u16 phy_read_1bit(unsigned long ioaddr, u32 chip_id) -{ - u16 phy_data; - - outl(0x50000 , ioaddr); - udelay(1); - phy_data = (inl(ioaddr) >> 19) & 0x1; - outl(0x40000 , ioaddr); - udelay(1); - - return phy_data; -} - -/* - * Set MAC address to ID Table - */ - -static void set_mac_addr(struct eth_device *dev) -{ - int i; - u16 addr; - struct uli526x_board_info *db = dev->priv; - outl(0x10000, db->ioaddr + DCR0); /* Diagnosis mode */ - /* Reset dianostic pointer port */ - outl(0x1c0, db->ioaddr + DCR13); - outl(0, db->ioaddr + DCR14); /* Clear reset port */ - outl(0x10, db->ioaddr + DCR14); /* Reset ID Table pointer */ - outl(0, db->ioaddr + DCR14); /* Clear reset port */ - outl(0, db->ioaddr + DCR13); /* Clear CR13 */ - /* Select ID Table access port */ - outl(0x1b0, db->ioaddr + DCR13); - /* Read MAC address from CR14 */ - for (i = 0; i < 3; i++) { - addr = dev->enetaddr[2 * i] | (dev->enetaddr[2 * i + 1] << 8); - outl(addr, db->ioaddr + DCR14); - } - /* write end */ - outl(0, db->ioaddr + DCR13); /* Clear CR13 */ - outl(0, db->ioaddr + DCR0); /* Clear CR0 */ - udelay(10); - return; -}
On Thu, Mar 31, 2022 at 01:46:52PM -0400, Tom Rini wrote:
This driver is not enabled by any board and not converted to DM_ETH. Remove.
There are no platforms for this architecture anymore, remove unused code.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/arm920t/Makefile | 1 - arch/arm/cpu/arm920t/ep93xx/Makefile | 19 - arch/arm/cpu/arm920t/ep93xx/cpu.c | 37 -- arch/arm/cpu/arm920t/ep93xx/led.c | 85 --- arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S | 457 -------------- arch/arm/cpu/arm920t/ep93xx/speed.c | 96 --- arch/arm/cpu/arm920t/ep93xx/timer.c | 117 ---- arch/arm/include/asm/arch-ep93xx/ep93xx.h | 666 -------------------- drivers/net/Makefile | 1 - drivers/net/ep93xx_eth.c | 654 ------------------- drivers/net/ep93xx_eth.h | 126 ---- drivers/usb/host/Makefile | 1 - drivers/usb/host/ohci-ep93xx.c | 37 -- 13 files changed, 2297 deletions(-) delete mode 100644 arch/arm/cpu/arm920t/ep93xx/Makefile delete mode 100644 arch/arm/cpu/arm920t/ep93xx/cpu.c delete mode 100644 arch/arm/cpu/arm920t/ep93xx/led.c delete mode 100644 arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S delete mode 100644 arch/arm/cpu/arm920t/ep93xx/speed.c delete mode 100644 arch/arm/cpu/arm920t/ep93xx/timer.c delete mode 100644 arch/arm/include/asm/arch-ep93xx/ep93xx.h delete mode 100644 drivers/net/ep93xx_eth.c delete mode 100644 drivers/net/ep93xx_eth.h delete mode 100644 drivers/usb/host/ohci-ep93xx.c
diff --git a/arch/arm/cpu/arm920t/Makefile b/arch/arm/cpu/arm920t/Makefile index c63f578f1a95..b70822c67ab9 100644 --- a/arch/arm/cpu/arm920t/Makefile +++ b/arch/arm/cpu/arm920t/Makefile @@ -7,7 +7,6 @@ extra-y = start.o
obj-y += cpu.o
-obj-$(CONFIG_EP93XX) += ep93xx/ obj-$(CONFIG_IMX) += imx/
# some files can only build in ARM mode diff --git a/arch/arm/cpu/arm920t/ep93xx/Makefile b/arch/arm/cpu/arm920t/ep93xx/Makefile deleted file mode 100644 index 152b5e7c5a2e..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/Makefile +++ /dev/null @@ -1,19 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Cirrus Logic EP93xx CPU-specific Makefile -# -# Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net -# -# Copyright (C) 2004, 2005 -# Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com -# -# Copyright (C) 2006 -# Dominic Rath Dominic.Rath@gmx.de -# -# Based on an original Makefile, which is -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. - -obj-y = cpu.o led.o speed.o timer.o -obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/arm920t/ep93xx/cpu.c b/arch/arm/cpu/arm920t/ep93xx/cpu.c deleted file mode 100644 index 3435bdc748a2..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/cpu.c +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Cirrus Logic EP93xx CPU-specific support. - * - * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net - * - * Copyright (C) 2004, 2005 - * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com - */ - -#include <common.h> -#include <cpu_func.h> -#include <asm/arch/ep93xx.h> -#include <asm/io.h> - -/* We reset the CPU by generating a 1-->0 transition on DeviceCfg bit 31. */ -extern void reset_cpu(void) -{ - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - uint32_t value; - - /* Unlock DeviceCfg and set SWRST */ - writel(0xAA, &syscon->sysswlock); - value = readl(&syscon->devicecfg); - value |= SYSCON_DEVICECFG_SWRST; - writel(value, &syscon->devicecfg); - - /* Unlock DeviceCfg and clear SWRST */ - writel(0xAA, &syscon->sysswlock); - value = readl(&syscon->devicecfg); - value &= ~SYSCON_DEVICECFG_SWRST; - writel(value, &syscon->devicecfg); - - /* Dying... */ - while (1) - ; /* noop */ -} diff --git a/arch/arm/cpu/arm920t/ep93xx/led.c b/arch/arm/cpu/arm920t/ep93xx/led.c deleted file mode 100644 index 862663acbab5..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/led.c +++ /dev/null @@ -1,85 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2010, 2009 Matthias Kaehlcke matthias@kaehlcke.net - */ - -#include <asm/io.h> -#include <asm/arch/ep93xx.h> -#include <config.h> -#include <status_led.h> - -static uint8_t saved_state[2] = {CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_OFF}; -static uint32_t gpio_pin[2] = {1 << CONFIG_LED_STATUS_GREEN, - 1 << CONFIG_LED_STATUS_RED}; - -static inline void switch_LED_on(uint8_t led) -{ - register struct gpio_regs *gpio = (struct gpio_regs *)GPIO_BASE; - - writel(readl(&gpio->pedr) | gpio_pin[led], &gpio->pedr); - saved_state[led] = CONFIG_LED_STATUS_ON; -} - -static inline void switch_LED_off(uint8_t led) -{ - register struct gpio_regs *gpio = (struct gpio_regs *)GPIO_BASE; - - writel(readl(&gpio->pedr) & ~gpio_pin[led], &gpio->pedr); - saved_state[led] = CONFIG_LED_STATUS_OFF; -} - -void red_led_on(void) -{ - switch_LED_on(CONFIG_LED_STATUS_RED); -} - -void red_led_off(void) -{ - switch_LED_off(CONFIG_LED_STATUS_RED); -} - -void green_led_on(void) -{ - switch_LED_on(CONFIG_LED_STATUS_GREEN); -} - -void green_led_off(void) -{ - switch_LED_off(CONFIG_LED_STATUS_GREEN); -} - -void __led_init(led_id_t mask, int state) -{ - __led_set(mask, state); -} - -void __led_toggle(led_id_t mask) -{ - if (CONFIG_LED_STATUS_RED == mask) { - if (CONFIG_LED_STATUS_ON == saved_state[CONFIG_LED_STATUS_RED]) - red_led_off(); - else - red_led_on(); - } else if (CONFIG_LED_STATUS_GREEN == mask) { - if (CONFIG_LED_STATUS_ON == - saved_state[CONFIG_LED_STATUS_GREEN]) - green_led_off(); - else - green_led_on(); - } -} - -void __led_set(led_id_t mask, int state) -{ - if (CONFIG_LED_STATUS_RED == mask) { - if (CONFIG_LED_STATUS_ON == state) - red_led_on(); - else - red_led_off(); - } else if (CONFIG_LED_STATUS_GREEN == mask) { - if (CONFIG_LED_STATUS_ON == state) - green_led_on(); - else - green_led_off(); - } -} diff --git a/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S b/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S deleted file mode 100644 index 5239b1053c25..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S +++ /dev/null @@ -1,457 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Low-level initialization for EP93xx - * - * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net - * Copyright (C) 2013 - * Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru> - * - * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de - * Copyright (C) 2006 Cirrus Logic Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - */ - -#include <config.h> -#include <asm/arch-ep93xx/ep93xx.h> - -/* -/* Configure the SDRAM based on the supplied settings. - * - * Input: r0 - SDRAM DEVCFG register - * r2 - configuration for SDRAM chips - * Output: none - * Modifies: r3, r4 - */ -ep93xx_sdram_config: - /* Program the SDRAM device configuration register. */ - ldr r3, =SDRAM_BASE -#ifdef CONFIG_EDB93XX_SDCS0 - str r0, [r3, #SDRAM_OFF_DEVCFG0] -#endif -#ifdef CONFIG_EDB93XX_SDCS1 - str r0, [r3, #SDRAM_OFF_DEVCFG1] -#endif -#ifdef CONFIG_EDB93XX_SDCS2 - str r0, [r3, #SDRAM_OFF_DEVCFG2] -#endif -#ifdef CONFIG_EDB93XX_SDCS3 - str r0, [r3, #SDRAM_OFF_DEVCFG3] -#endif - - /* Set the Initialize and MRS bits (issue continuous NOP commands - * (INIT & MRS set)) - */ - ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_INIT | \ - EP93XX_SDRAMCTRL_GLOBALCFG_MRS | \ - EP93XX_SDRAMCTRL_GLOBALCFG_CKE) - str r4, [r3, #SDRAM_OFF_GLCONFIG] - - /* Delay for 200us. */ - mov r4, #0x3000 -delay1: - subs r4, r4, #1 - bne delay1 - - /* Clear the MRS bit to issue a precharge all. */ - ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_INIT | \ - EP93XX_SDRAMCTRL_GLOBALCFG_CKE) - str r4, [r3, #SDRAM_OFF_GLCONFIG] - - /* Temporarily set the refresh timer to 0x10. Make it really low so - * that refresh cycles are generated. - */ - ldr r4, =0x10 - str r4, [r3, #SDRAM_OFF_REFRSHTIMR] - - /* Delay for at least 80 SDRAM clock cycles. */ - mov r4, #80 -delay2: - subs r4, r4, #1 - bne delay2 - - /* Set the refresh timer to the fastest required for any device - * that might be used. Set 9.6 ms refresh time. - */ - ldr r4, =0x01e0 - str r4, [r3, #SDRAM_OFF_REFRSHTIMR] - - /* Select mode register update mode. */ - ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_CKE | \ - EP93XX_SDRAMCTRL_GLOBALCFG_MRS) - str r4, [r3, #SDRAM_OFF_GLCONFIG] - - /* Program the mode register on the SDRAM by performing fake read */ - ldr r4, [r2] - - /* Select normal operating mode. */ - ldr r4, =EP93XX_SDRAMCTRL_GLOBALCFG_CKE - str r4, [r3, #SDRAM_OFF_GLCONFIG] - - /* Return to the caller. */ - mov pc, lr - -/* - * Test to see if the SDRAM has been configured in a usable mode. - * - * Input: r0 - Test address of SDRAM - * Output: r0 - 0 -- Test OK, -1 -- Failed - * Modifies: r0-r5 - */ -ep93xx_sdram_test: - /* Load the test patterns to be written to SDRAM. */ - ldr r1, =0xf00dface - ldr r2, =0xdeadbeef - ldr r3, =0x08675309 - ldr r4, =0xdeafc0ed - - /* Store the test patterns to SDRAM. */ - stmia r0, {r1-r4} - - /* Load the test patterns from SDRAM one at a time and compare them - * to the actual pattern. - */ - ldr r5, [r0] - cmp r5, r1 - ldreq r5, [r0, #0x0004] - cmpeq r5, r2 - ldreq r5, [r0, #0x0008] - cmpeq r5, r3 - ldreq r5, [r0, #0x000c] - cmpeq r5, r4 - - /* Return -1 if a mismatch was encountered, 0 otherwise. */ - mvnne r0, #0xffffffff - moveq r0, #0x00000000 - - /* Return to the caller. */ - mov pc, lr - -/* - * Determine the size of the SDRAM. Use data=address for the scan. - * - * Input: r0 - Start SDRAM address - * Return: r0 - Single block size - * r1 - Valid block mask - * r2 - Total block count - * Modifies: r0-r5 - */ -ep93xx_sdram_size: - /* Store zero at offset zero. */ - str r0, [r0] - - /* Start checking for an alias at 1MB into SDRAM. */ - ldr r1, =0x00100000 - - /* Store the offset at the current offset. */ -check_block_size: - str r1, [r0, r1] - - /* Read back from zero. */ - ldr r2, [r0] - - /* Stop searching of an alias was found. */ - cmp r1, r2 - beq found_block_size - - /* Advance to the next power of two boundary. */ - mov r1, r1, lsl #1 - - /* Loop back if the size has not reached 256MB. */ - cmp r1, #0x10000000 - bne check_block_size - - /* A full 256MB of memory was found, so return it now. */ - ldr r0, =0x10000000 - ldr r1, =0x00000000 - ldr r2, =0x00000001 - mov pc, lr - - /* An alias was found. See if the first block is 128MB in size. */ -found_block_size: - cmp r1, #0x08000000 - - /* The first block is 128MB, so there is no further memory. Return it - * now. - */ - ldreq r0, =0x08000000 - ldreq r1, =0x00000000 - ldreq r2, =0x00000001 - moveq pc, lr - - /* Save the block size, set the block address bits to zero, and - * initialize the block count to one. - */ - mov r3, r1 - ldr r4, =0x00000000 - ldr r5, =0x00000001 - - /* Look for additional blocks of memory by searching for non-aliases. */ -find_blocks: - /* Store zero back to address zero. It may be overwritten. */ - str r0, [r0] - - /* Advance to the next power of two boundary. */ - mov r1, r1, lsl #1 - - /* Store the offset at the current offset. */ - str r1, [r0, r1] - - /* Read back from zero. */ - ldr r2, [r0] - - /* See if a non-alias was found. */ - cmp r1, r2 - - /* If a non-alias was found, then or in the block address bit and - * multiply the block count by two (since there are two unique - * blocks, one with this bit zero and one with it one). - */ - orrne r4, r4, r1 - movne r5, r5, lsl #1 - - /* Continue searching if there are more address bits to check. */ - cmp r1, #0x08000000 - bne find_blocks - - /* Return the block size, address mask, and count. */ - mov r0, r3 - mov r1, r4 - mov r2, r5 - - /* Return to the caller. */ - mov pc, lr - - -.globl lowlevel_init -lowlevel_init: - - mov r6, lr - - /* Make sure caches are off and invalidated. */ - ldr r0, =0x00000000 - mcr p15, 0, r0, c1, c0, 0 - nop - nop - nop - nop - nop - - /* Turn off the green LED and turn on the red LED. If the red LED - * is left on for too long, the external reset circuit described - * by application note AN258 will cause the system to reset. - */ - ldr r1, =EP93XX_LED_DATA - ldr r0, [r1] - bic r0, r0, #EP93XX_LED_GREEN_ON - orr r0, r0, #EP93XX_LED_RED_ON - str r0, [r1] - - /* Undo the silly static memory controller programming performed - * by the boot rom. - */ - ldr r0, =SMC_BASE - - /* Set WST1 and WST2 to 31 HCLK cycles (slowest access) */ - ldr r1, =0x0000fbe0 - - /* Reset EP93XX_OFF_SMCBCR0 */ - ldr r2, [r0] - orr r2, r2, r1 - str r2, [r0] - - ldr r2, [r0, #EP93XX_OFF_SMCBCR1] - orr r2, r2, r1 - str r2, [r0, #EP93XX_OFF_SMCBCR1] - - ldr r2, [r0, #EP93XX_OFF_SMCBCR2] - orr r2, r2, r1 - str r2, [r0, #EP93XX_OFF_SMCBCR2] - - ldr r2, [r0, #EP93XX_OFF_SMCBCR3] - orr r2, r2, r1 - str r2, [r0, #EP93XX_OFF_SMCBCR3] - - ldr r2, [r0, #EP93XX_OFF_SMCBCR6] - orr r2, r2, r1 - str r2, [r0, #EP93XX_OFF_SMCBCR6] - - ldr r2, [r0, #EP93XX_OFF_SMCBCR7] - orr r2, r2, r1 - str r2, [r0, #EP93XX_OFF_SMCBCR7] - - /* Set the PLL1 and processor clock. */ - ldr r0, =SYSCON_BASE -#ifdef CONFIG_EDB9301 - /* 332MHz, giving a 166MHz processor clock. */ - ldr r1, = 0x02b49907 -#else - -#ifdef CONFIG_EDB93XX_INDUSTRIAL - /* 384MHz, giving a 196MHz processor clock. */ - ldr r1, =0x02a4bb38 -#else - /* 400MHz, giving a 200MHz processor clock. */ - ldr r1, =0x02a4e39e -#endif -#endif - str r1, [r0, #SYSCON_OFF_CLKSET1] - - nop - nop - nop - nop - nop - - /* Need to make sure that SDRAM is configured correctly before - * coping the code into it. - */ - -#ifdef CONFIG_EDB93XX_SDCS0 - mov r11, #SDRAM_DEVCFG0_BASE -#endif -#ifdef CONFIG_EDB93XX_SDCS1 - mov r11, #SDRAM_DEVCFG1_BASE -#endif -#ifdef CONFIG_EDB93XX_SDCS2 - mov r11, #SDRAM_DEVCFG2_BASE -#endif -#ifdef CONFIG_EDB93XX_SDCS3 - ldr r0, =SYSCON_BASE - ldr r0, [r0, #SYSCON_OFF_SYSCFG] - ands r0, r0, #SYSCON_SYSCFG_LASDO - moveq r11, #SDRAM_DEVCFG3_ASD0_BASE - movne r11, #SDRAM_DEVCFG3_ASD1_BASE -#endif - /* See Table 13-5 in EP93xx datasheet for more info about DRAM - * register mapping */ - - /* Try a 32-bit wide configuration of SDRAM. */ - ldr r0, =(EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT | \ - EP93XX_SDRAMCTRL_DEVCFG_SROMLL | \ - EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 | \ - EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2) - - /* Set burst count: 4 and CAS: 2 - * Burst mode [A11:A10]; CAS [A16:A14] - */ - orr r2, r11, #0x00008800 - bl ep93xx_sdram_config - - /* Test the SDRAM. */ - mov r0, r11 - bl ep93xx_sdram_test - cmp r0, #0x00000000 - beq ep93xx_sdram_done - - /* Try a 16-bit wide configuration of SDRAM. */ - ldr r0, =(EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT | \ - EP93XX_SDRAMCTRL_DEVCFG_SROMLL | \ - EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 | \ - EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2 | \ - EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH) - - /* Set burst count: 8, CAS: 2, sequential burst - * Accoring to Table 13-3 for 16bit operations mapping must be shifted. - * Burst mode [A10:A9]; CAS [A15:A13] - */ - orr r2, r11, #0x00004600 - bl ep93xx_sdram_config - - /* Test the SDRAM. */ - mov r0, r11 - bl ep93xx_sdram_test - cmp r0, #0x00000000 - beq ep93xx_sdram_done - - /* Turn off the red LED. */ - ldr r0, =EP93XX_LED_DATA - ldr r1, [r0] - bic r1, r1, #EP93XX_LED_RED_ON - str r1, [r0] - - /* There is no SDRAM so flash the green LED. */ -flash_green: - orr r1, r1, #EP93XX_LED_GREEN_ON - str r1, [r0] - ldr r2, =0x00010000 -flash_green_delay_1: - subs r2, r2, #1 - bne flash_green_delay_1 - bic r1, r1, #EP93XX_LED_GREEN_ON - str r1, [r0] - ldr r2, =0x00010000 -flash_green_delay_2: - subs r2, r2, #1 - bne flash_green_delay_2 - orr r1, r1, #EP93XX_LED_GREEN_ON - str r1, [r0] - ldr r2, =0x00010000 -flash_green_delay_3: - subs r2, r2, #1 - bne flash_green_delay_3 - bic r1, r1, #EP93XX_LED_GREEN_ON - str r1, [r0] - ldr r2, =0x00050000 -flash_green_delay_4: - subs r2, r2, #1 - bne flash_green_delay_4 - b flash_green - - -ep93xx_sdram_done: - ldr r1, =EP93XX_LED_DATA - ldr r0, [r1] - bic r0, r0, #EP93XX_LED_RED_ON - str r0, [r1] - - /* Determine the size of the SDRAM. */ - mov r0, r11 - bl ep93xx_sdram_size - - /* Save the SDRAM characteristics. */ - mov r8, r0 - mov r9, r1 - mov r10, r2 - - /* Compute total memory size into r1 */ - mul r1, r8, r10 -#ifdef CONFIG_EDB93XX_SDCS0 - ldr r2, [r0, #SDRAM_OFF_DEVCFG0] -#endif -#ifdef CONFIG_EDB93XX_SDCS1 - ldr r2, [r0, #SDRAM_OFF_DEVCFG1] -#endif -#ifdef CONFIG_EDB93XX_SDCS2 - ldr r2, [r0, #SDRAM_OFF_DEVCFG2] -#endif -#ifdef CONFIG_EDB93XX_SDCS3 - ldr r2, [r0, #SDRAM_OFF_DEVCFG3] -#endif - - /* Consider small DRAM size as: - * < 32Mb for 32bit bus - * < 64Mb for 16bit bus - */ - tst r2, #EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH - moveq r1, r1, lsr #1 - cmp r1, #0x02000000 - -#if defined(CONFIG_EDB9301) - /* Set refresh counter to 20ms for small DRAM size, otherwise 9.6ms */ - movlt r1, #0x03f0 - movge r1, #0x01e0 -#else - /* Set refresh counter to 30.7ms for small DRAM size, otherwise 15ms */ - movlt r1, #0x0600 - movge r1, #0x2f0 -#endif - str r1, [r0, #SDRAM_OFF_REFRSHTIMR] - - /* Save the memory configuration information. */ - orr r0, r11, #UBOOT_MEMORYCNF_BANK_SIZE - stmia r0, {r8-r11} - - mov lr, r6 - mov pc, lr diff --git a/arch/arm/cpu/arm920t/ep93xx/speed.c b/arch/arm/cpu/arm920t/ep93xx/speed.c deleted file mode 100644 index 8dd3904e82c8..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/speed.c +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Cirrus Logic EP93xx PLL support. - * - * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net - */ - -#include <common.h> -#include <clock_legacy.h> -#include <asm/arch/ep93xx.h> -#include <asm/io.h> -#include <div64.h> - -/* - * get_board_sys_clk() should be defined as the input frequency of the PLL. - * - * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of - * the specified bus in HZ. - */ - -/* - * return the PLL output frequency - * - * PLL rate = get_board_sys_clk() * (X1FBD + 1) * (X2FBD + 1) - * / (X2IPD + 1) / 2^PS - */ -static ulong get_PLLCLK(uint32_t *pllreg) -{ - uint8_t i; - const uint32_t clkset = readl(pllreg); - uint64_t rate = get_board_sys_clk(); - rate *= ((clkset >> SYSCON_CLKSET_PLL_X1FBD1_SHIFT) & 0x1f) + 1; - rate *= ((clkset >> SYSCON_CLKSET_PLL_X2FBD2_SHIFT) & 0x3f) + 1; - do_div(rate, (clkset & 0x1f) + 1); /* X2IPD */ - for (i = 0; i < ((clkset >> SYSCON_CLKSET_PLL_PS_SHIFT) & 3); i++) - rate >>= 1; - - return (ulong)rate; -} - -/* return FCLK frequency */ -ulong get_FCLK(void) -{ - const uint8_t fclk_divisors[] = { 1, 2, 4, 8, 16, 1, 1, 1 }; - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - - const uint32_t clkset1 = readl(&syscon->clkset1); - const uint8_t fclk_div = - fclk_divisors[(clkset1 >> SYSCON_CLKSET1_FCLK_DIV_SHIFT) & 7]; - const ulong fclk_rate = get_PLLCLK(&syscon->clkset1) / fclk_div; - - return fclk_rate; -} - -/* return HCLK frequency */ -ulong get_HCLK(void) -{ - const uint8_t hclk_divisors[] = { 1, 2, 4, 5, 6, 8, 16, 32 }; - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - - const uint32_t clkset1 = readl(&syscon->clkset1); - const uint8_t hclk_div = - hclk_divisors[(clkset1 >> SYSCON_CLKSET1_HCLK_DIV_SHIFT) & 7]; - const ulong hclk_rate = get_PLLCLK(&syscon->clkset1) / hclk_div; - - return hclk_rate; -} - -/* return PCLK frequency */ -ulong get_PCLK(void) -{ - const uint8_t pclk_divisors[] = { 1, 2, 4, 8 }; - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - - const uint32_t clkset1 = readl(&syscon->clkset1); - const uint8_t pclk_div = - pclk_divisors[(clkset1 >> SYSCON_CLKSET1_PCLK_DIV_SHIFT) & 3]; - const ulong pclk_rate = get_HCLK() / pclk_div; - - return pclk_rate; -} - -/* return UCLK frequency */ -ulong get_UCLK(void) -{ - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - ulong uclk_rate; - - const uint32_t value = readl(&syscon->pwrcnt); - if (value & SYSCON_PWRCNT_UART_BAUD) - uclk_rate = get_board_sys_clk(); - else - uclk_rate = get_board_sys_clk() / 2; - - return uclk_rate; -} diff --git a/arch/arm/cpu/arm920t/ep93xx/timer.c b/arch/arm/cpu/arm920t/ep93xx/timer.c deleted file mode 100644 index 892bb06db10e..000000000000 --- a/arch/arm/cpu/arm920t/ep93xx/timer.c +++ /dev/null @@ -1,117 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Cirrus Logic EP93xx timer support. - * - * Copyright (C) 2009, 2010 Matthias Kaehlcke matthias@kaehlcke.net - * - * Copyright (C) 2004, 2005 - * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com - * - * Based on the original intr.c Cirrus Logic EP93xx Rev D. interrupt support, - * author unknown. - */ - -#include <common.h> -#include <init.h> -#include <time.h> -#include <linux/delay.h> -#include <linux/types.h> -#include <asm/arch/ep93xx.h> -#include <asm/io.h> -#include <div64.h> - -#define TIMER_CLKSEL (1 << 3) -#define TIMER_ENABLE (1 << 7) - -#define TIMER_FREQ 508469 /* ticks / second */ -#define TIMER_MAX_VAL 0xFFFFFFFF - -static struct ep93xx_timer -{ - unsigned long long ticks; - unsigned long last_read; -} timer; - -static inline unsigned long long usecs_to_ticks(unsigned long usecs) -{ - unsigned long long ticks = (unsigned long long)usecs * TIMER_FREQ; - do_div(ticks, 1000 * 1000); - - return ticks; -} - -static inline void read_timer(void) -{ - struct timer_regs *timer_regs = (struct timer_regs *)TIMER_BASE; - const unsigned long now = TIMER_MAX_VAL - readl(&timer_regs->timer3.value); - - if (now >= timer.last_read) - timer.ticks += now - timer.last_read; - else - /* an overflow occurred */ - timer.ticks += TIMER_MAX_VAL - timer.last_read + now; - - timer.last_read = now; -} - -/* - * Get the number of ticks (in CONFIG_SYS_HZ resolution) - */ -unsigned long long get_ticks(void) -{ - unsigned long long sys_ticks; - - read_timer(); - - sys_ticks = timer.ticks * CONFIG_SYS_HZ; - do_div(sys_ticks, TIMER_FREQ); - - return sys_ticks; -} - -unsigned long get_timer(unsigned long base) -{ - return get_ticks() - base; -} - -void __udelay(unsigned long usec) -{ - unsigned long long target; - - read_timer(); - - target = timer.ticks + usecs_to_ticks(usec); - - while (timer.ticks < target) - read_timer(); -} - -int timer_init(void) -{ - struct timer_regs *timer_regs = (struct timer_regs *)TIMER_BASE; - - /* use timer 3 with 508KHz and free running, not enabled now */ - writel(TIMER_CLKSEL, &timer_regs->timer3.control); - - /* set initial timer value */ - writel(TIMER_MAX_VAL, &timer_regs->timer3.load); - - /* Enable the timer */ - writel(TIMER_ENABLE | TIMER_CLKSEL, - &timer_regs->timer3.control); - - /* Reset the timer */ - read_timer(); - timer.ticks = 0; - - return 0; -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -unsigned long get_tbclk(void) -{ - return CONFIG_SYS_HZ; -} diff --git a/arch/arm/include/asm/arch-ep93xx/ep93xx.h b/arch/arm/include/asm/arch-ep93xx/ep93xx.h deleted file mode 100644 index 272b64480d1f..000000000000 --- a/arch/arm/include/asm/arch-ep93xx/ep93xx.h +++ /dev/null @@ -1,666 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Cirrus Logic EP93xx register definitions. - * - * Copyright (C) 2013 - * Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru> - * - * Copyright (C) 2009 - * Matthias Kaehlcke matthias@kaehlcke.net - * - * Copyright (C) 2006 - * Dominic Rath Dominic.Rath@gmx.de - * - * Copyright (C) 2004, 2005 - * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com - * - * Based in large part on linux/include/asm-arm/arch-ep93xx/regmap.h, which is - * - * Copyright (C) 2004 Ray Lehtiniemi - * Copyright (C) 2003 Cirrus Logic, Inc - * Copyright (C) 1999 ARM Limited. - */ - -#define EP93XX_AHB_BASE 0x80000000 -#define EP93XX_APB_BASE 0x80800000 - -/* - * 0x80000000 - 0x8000FFFF: DMA - */ -#define DMA_OFFSET 0x000000 -#define DMA_BASE (EP93XX_AHB_BASE | DMA_OFFSET) - -#ifndef __ASSEMBLY__ -struct dma_channel { - uint32_t control; - uint32_t interrupt; - uint32_t ppalloc; - uint32_t status; - uint32_t reserved0; - uint32_t remain; - uint32_t reserved1[2]; - uint32_t maxcnt0; - uint32_t base0; - uint32_t current0; - uint32_t reserved2; - uint32_t maxcnt1; - uint32_t base1; - uint32_t current1; - uint32_t reserved3; -}; - -struct dma_regs { - struct dma_channel m2p_channel_0; - struct dma_channel m2p_channel_1; - struct dma_channel m2p_channel_2; - struct dma_channel m2p_channel_3; - struct dma_channel m2m_channel_0; - struct dma_channel m2m_channel_1; - struct dma_channel reserved0[2]; - struct dma_channel m2p_channel_5; - struct dma_channel m2p_channel_4; - struct dma_channel m2p_channel_7; - struct dma_channel m2p_channel_6; - struct dma_channel m2p_channel_9; - struct dma_channel m2p_channel_8; - uint32_t channel_arbitration; - uint32_t reserved[15]; - uint32_t global_interrupt; -}; -#endif - -/* - * 0x80010000 - 0x8001FFFF: Ethernet MAC - */ -#define MAC_OFFSET 0x010000 -#define MAC_BASE (EP93XX_AHB_BASE | MAC_OFFSET) - -#ifndef __ASSEMBLY__ -struct mac_queue { - uint32_t badd; - union { /* deal with half-word aligned registers */ - uint32_t blen; - union { - uint16_t filler; - uint16_t curlen; - }; - }; - uint32_t curadd; -}; - -struct mac_regs { - uint32_t rxctl; - uint32_t txctl; - uint32_t testctl; - uint32_t reserved0; - uint32_t miicmd; - uint32_t miidata; - uint32_t miists; - uint32_t reserved1; - uint32_t selfctl; - uint32_t inten; - uint32_t intstsp; - uint32_t intstsc; - uint32_t reserved2[2]; - uint32_t diagad; - uint32_t diagdata; - uint32_t gt; - uint32_t fct; - uint32_t fcf; - uint32_t afp; - union { - struct { - uint32_t indad; - uint32_t indad_upper; - }; - uint32_t hashtbl; - }; - uint32_t reserved3[2]; - uint32_t giintsts; - uint32_t giintmsk; - uint32_t giintrosts; - uint32_t giintfrc; - uint32_t txcollcnt; - uint32_t rxmissnct; - uint32_t rxruntcnt; - uint32_t reserved4; - uint32_t bmctl; - uint32_t bmsts; - uint32_t rxbca; - uint32_t reserved5; - struct mac_queue rxdq; - uint32_t rxdqenq; - struct mac_queue rxstsq; - uint32_t rxstsqenq; - struct mac_queue txdq; - uint32_t txdqenq; - struct mac_queue txstsq; - uint32_t reserved6; - uint32_t rxbufthrshld; - uint32_t txbufthrshld; - uint32_t rxststhrshld; - uint32_t txststhrshld; - uint32_t rxdthrshld; - uint32_t txdthrshld; - uint32_t maxfrmlen; - uint32_t maxhdrlen; -}; -#endif - -#define SELFCTL_RWP (1 << 7) -#define SELFCTL_GPO0 (1 << 5) -#define SELFCTL_PUWE (1 << 4) -#define SELFCTL_PDWE (1 << 3) -#define SELFCTL_MIIL (1 << 2) -#define SELFCTL_RESET (1 << 0) - -#define INTSTS_RWI (1 << 30) -#define INTSTS_RXMI (1 << 29) -#define INTSTS_RXBI (1 << 28) -#define INTSTS_RXSQI (1 << 27) -#define INTSTS_TXLEI (1 << 26) -#define INTSTS_ECIE (1 << 25) -#define INTSTS_TXUHI (1 << 24) -#define INTSTS_MOI (1 << 18) -#define INTSTS_TXCOI (1 << 17) -#define INTSTS_RXROI (1 << 16) -#define INTSTS_MIII (1 << 12) -#define INTSTS_PHYI (1 << 11) -#define INTSTS_TI (1 << 10) -#define INTSTS_AHBE (1 << 8) -#define INTSTS_OTHER (1 << 4) -#define INTSTS_TXSQ (1 << 3) -#define INTSTS_RXSQ (1 << 2) - -#define BMCTL_MT (1 << 13) -#define BMCTL_TT (1 << 12) -#define BMCTL_UNH (1 << 11) -#define BMCTL_TXCHR (1 << 10) -#define BMCTL_TXDIS (1 << 9) -#define BMCTL_TXEN (1 << 8) -#define BMCTL_EH2 (1 << 6) -#define BMCTL_EH1 (1 << 5) -#define BMCTL_EEOB (1 << 4) -#define BMCTL_RXCHR (1 << 2) -#define BMCTL_RXDIS (1 << 1) -#define BMCTL_RXEN (1 << 0) - -#define BMSTS_TXACT (1 << 7) -#define BMSTS_TP (1 << 4) -#define BMSTS_RXACT (1 << 3) -#define BMSTS_QID_MASK 0x07 -#define BMSTS_QID_RXDATA 0x00 -#define BMSTS_QID_TXDATA 0x01 -#define BMSTS_QID_RXSTS 0x02 -#define BMSTS_QID_TXSTS 0x03 -#define BMSTS_QID_RXDESC 0x04 -#define BMSTS_QID_TXDESC 0x05 - -#define AFP_MASK 0x07 -#define AFP_IAPRIMARY 0x00 -#define AFP_IASECONDARY1 0x01 -#define AFP_IASECONDARY2 0x02 -#define AFP_IASECONDARY3 0x03 -#define AFP_TX 0x06 -#define AFP_HASH 0x07 - -#define RXCTL_PAUSEA (1 << 20) -#define RXCTL_RXFCE1 (1 << 19) -#define RXCTL_RXFCE0 (1 << 18) -#define RXCTL_BCRC (1 << 17) -#define RXCTL_SRXON (1 << 16) -#define RXCTL_RCRCA (1 << 13) -#define RXCTL_RA (1 << 12) -#define RXCTL_PA (1 << 11) -#define RXCTL_BA (1 << 10) -#define RXCTL_MA (1 << 9) -#define RXCTL_IAHA (1 << 8) -#define RXCTL_IA3 (1 << 3) -#define RXCTL_IA2 (1 << 2) -#define RXCTL_IA1 (1 << 1) -#define RXCTL_IA0 (1 << 0) - -#define TXCTL_DEFDIS (1 << 7) -#define TXCTL_MBE (1 << 6) -#define TXCTL_ICRC (1 << 5) -#define TXCTL_TPD (1 << 4) -#define TXCTL_OCOLL (1 << 3) -#define TXCTL_SP (1 << 2) -#define TXCTL_PB (1 << 1) -#define TXCTL_STXON (1 << 0) - -#define MIICMD_REGAD_MASK (0x001F) -#define MIICMD_PHYAD_MASK (0x03E0) -#define MIICMD_OPCODE_MASK (0xC000) -#define MIICMD_PHYAD_8950 (0x0000) -#define MIICMD_OPCODE_READ (0x8000) -#define MIICMD_OPCODE_WRITE (0x4000) - -#define MIISTS_BUSY (1 << 0) - -/* - * 0x80020000 - 0x8002FFFF: USB OHCI - */ -#define USB_OFFSET 0x020000 -#define USB_BASE (EP93XX_AHB_BASE | USB_OFFSET) - -/* - * 0x80030000 - 0x8003FFFF: Raster engine - */ -#if (defined(CONFIG_EP9307) || defined(CONFIG_EP9312) || defined(CONFIG_EP9315)) -#define RASTER_OFFSET 0x030000 -#define RASTER_BASE (EP93XX_AHB_BASE | RASTER_OFFSET) -#endif - -/* - * 0x80040000 - 0x8004FFFF: Graphics accelerator - */ -#if defined(CONFIG_EP9315) -#define GFX_OFFSET 0x040000 -#define GFX_BASE (EP93XX_AHB_BASE | GFX_OFFSET) -#endif - -/* - * 0x80050000 - 0x8005FFFF: Reserved - */ - -/* - * 0x80060000 - 0x8006FFFF: SDRAM controller - */ -#define SDRAM_OFFSET 0x060000 -#define SDRAM_BASE (EP93XX_AHB_BASE | SDRAM_OFFSET) - -#ifndef __ASSEMBLY__ -struct sdram_regs { - uint32_t reserved; - uint32_t glconfig; - uint32_t refrshtimr; - uint32_t bootsts; - uint32_t devcfg0; - uint32_t devcfg1; - uint32_t devcfg2; - uint32_t devcfg3; -}; -#endif - -#define SDRAM_DEVCFG_EXTBUSWIDTH (1 << 2) -#define SDRAM_DEVCFG_BANKCOUNT (1 << 3) -#define SDRAM_DEVCFG_SROMLL (1 << 5) -#define SDRAM_DEVCFG_CASLAT_2 0x00010000 -#define SDRAM_DEVCFG_RASTOCAS_2 0x00200000 - -#define SDRAM_OFF_GLCONFIG 0x0004 -#define SDRAM_OFF_REFRSHTIMR 0x0008 - -#define SDRAM_OFF_DEVCFG0 0x0010 -#define SDRAM_OFF_DEVCFG1 0x0014 -#define SDRAM_OFF_DEVCFG2 0x0018 -#define SDRAM_OFF_DEVCFG3 0x001C - -#define SDRAM_DEVCFG0_BASE 0xC0000000 -#define SDRAM_DEVCFG1_BASE 0xD0000000 -#define SDRAM_DEVCFG2_BASE 0xE0000000 -#define SDRAM_DEVCFG3_ASD0_BASE 0xF0000000 -#define SDRAM_DEVCFG3_ASD1_BASE 0x00000000 - -#define GLCONFIG_INIT (1 << 0) -#define GLCONFIG_MRS (1 << 1) -#define GLCONFIG_SMEMBUSY (1 << 5) -#define GLCONFIG_LCR (1 << 6) -#define GLCONFIG_REARBEN (1 << 7) -#define GLCONFIG_CLKSHUTDOWN (1 << 30) -#define GLCONFIG_CKE (1 << 31) - -#define EP93XX_SDRAMCTRL 0x80060000 -#define EP93XX_SDRAMCTRL_GLOBALCFG_INIT 0x00000001 -#define EP93XX_SDRAMCTRL_GLOBALCFG_MRS 0x00000002 -#define EP93XX_SDRAMCTRL_GLOBALCFG_SMEMBUSY 0x00000020 -#define EP93XX_SDRAMCTRL_GLOBALCFG_LCR 0x00000040 -#define EP93XX_SDRAMCTRL_GLOBALCFG_REARBEN 0x00000080 -#define EP93XX_SDRAMCTRL_GLOBALCFG_CLKSHUTDOWN 0x40000000 -#define EP93XX_SDRAMCTRL_GLOBALCFG_CKE 0x80000000 - -#define EP93XX_SDRAMCTRL_REFRESH_MASK 0x0000FFFF - -#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_32 0x00000002 -#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_16 0x00000001 -#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_8 0x00000000 -#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_MASK 0x00000003 -#define EP93XX_SDRAMCTRL_BOOTSTATUS_MEDIA 0x00000004 - -#define EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH 0x00000004 -#define EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT 0x00000008 -#define EP93XX_SDRAMCTRL_DEVCFG_SROM512 0x00000010 -#define EP93XX_SDRAMCTRL_DEVCFG_SROMLL 0x00000020 -#define EP93XX_SDRAMCTRL_DEVCFG_2KPAGE 0x00000040 -#define EP93XX_SDRAMCTRL_DEVCFG_SFCONFIGADDR 0x00000080 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_MASK 0x00070000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 0x00010000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_3 0x00020000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_4 0x00030000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_5 0x00040000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_6 0x00050000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_7 0x00060000 -#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_8 0x00070000 -#define EP93XX_SDRAMCTRL_DEVCFG_WBL 0x00080000 -#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_MASK 0x00300000 -#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2 0x00200000 -#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_3 0x00300000 -#define EP93XX_SDRAMCTRL_DEVCFG_AUTOPRECHARGE 0x01000000 - -/* - * 0x80070000 - 0x8007FFFF: Reserved - */ - -/* - * 0x80080000 - 0x8008FFFF: SRAM controller & PCMCIA - */ -#define SMC_OFFSET 0x080000 -#define SMC_BASE (EP93XX_AHB_BASE | SMC_OFFSET) - -#ifndef __ASSEMBLY__ -struct smc_regs { - uint32_t bcr0; - uint32_t bcr1; - uint32_t bcr2; - uint32_t bcr3; - uint32_t reserved0[2]; - uint32_t bcr6; - uint32_t bcr7; -#if defined(CONFIG_EP9315) - uint32_t pcattribute; - uint32_t pccommon; - uint32_t pcio; - uint32_t reserved1[5]; - uint32_t pcmciactrl; -#endif -}; -#endif - -#define EP93XX_OFF_SMCBCR0 0x00 -#define EP93XX_OFF_SMCBCR1 0x04 -#define EP93XX_OFF_SMCBCR2 0x08 -#define EP93XX_OFF_SMCBCR3 0x0C -#define EP93XX_OFF_SMCBCR6 0x18 -#define EP93XX_OFF_SMCBCR7 0x1C - -#define SMC_BCR_IDCY_SHIFT 0 -#define SMC_BCR_WST1_SHIFT 5 -#define SMC_BCR_BLE (1 << 10) -#define SMC_BCR_WST2_SHIFT 11 -#define SMC_BCR_MW_SHIFT 28 - -/* - * 0x80090000 - 0x8009FFFF: Boot ROM - */ - -/* - * 0x800A0000 - 0x800AFFFF: IDE interface - */ - -/* - * 0x800B0000 - 0x800BFFFF: VIC1 - */ - -/* - * 0x800C0000 - 0x800CFFFF: VIC2 - */ - -/* - * 0x800D0000 - 0x800FFFFF: Reserved - */ - -/* - * 0x80800000 - 0x8080FFFF: Reserved - */ - -/* - * 0x80810000 - 0x8081FFFF: Timers - */ -#define TIMER_OFFSET 0x010000 -#define TIMER_BASE (EP93XX_APB_BASE | TIMER_OFFSET) - -#ifndef __ASSEMBLY__ -struct timer { - uint32_t load; - uint32_t value; - uint32_t control; - uint32_t clear; -}; - -struct timer4 { - uint32_t value_low; - uint32_t value_high; -}; - -struct timer_regs { - struct timer timer1; - uint32_t reserved0[4]; - struct timer timer2; - uint32_t reserved1[12]; - struct timer4 timer4; - uint32_t reserved2[6]; - struct timer timer3; -}; -#endif - -/* - * 0x80820000 - 0x8082FFFF: I2S - */ -#define I2S_OFFSET 0x020000 -#define I2S_BASE (EP93XX_APB_BASE | I2S_OFFSET) - -/* - * 0x80830000 - 0x8083FFFF: Security - */ -#define SECURITY_OFFSET 0x030000 -#define SECURITY_BASE (EP93XX_APB_BASE | SECURITY_OFFSET) - -#define EXTENSIONID (SECURITY_BASE + 0x2714) - -/* - * 0x80840000 - 0x8084FFFF: GPIO - */ -#define GPIO_OFFSET 0x040000 -#define GPIO_BASE (EP93XX_APB_BASE | GPIO_OFFSET) - -#ifndef __ASSEMBLY__ -struct gpio_int { - uint32_t inttype1; - uint32_t inttype2; - uint32_t eoi; - uint32_t inten; - uint32_t intsts; - uint32_t rawintsts; - uint32_t db; -}; - -struct gpio_regs { - uint32_t padr; - uint32_t pbdr; - uint32_t pcdr; - uint32_t pddr; - uint32_t paddr; - uint32_t pbddr; - uint32_t pcddr; - uint32_t pdddr; - uint32_t pedr; - uint32_t peddr; - uint32_t reserved0[2]; - uint32_t pfdr; - uint32_t pfddr; - uint32_t pgdr; - uint32_t pgddr; - uint32_t phdr; - uint32_t phddr; - uint32_t reserved1; - uint32_t finttype1; - uint32_t finttype2; - uint32_t reserved2; - struct gpio_int pfint; - uint32_t reserved3[10]; - struct gpio_int paint; - struct gpio_int pbint; - uint32_t eedrive; -}; -#endif - -#define EP93XX_LED_DATA 0x80840020 -#define EP93XX_LED_GREEN_ON 0x0001 -#define EP93XX_LED_RED_ON 0x0002 - -#define EP93XX_LED_DDR 0x80840024 -#define EP93XX_LED_GREEN_ENABLE 0x0001 -#define EP93XX_LED_RED_ENABLE 0x00020000 - -/* - * 0x80850000 - 0x8087FFFF: Reserved - */ - -/* - * 0x80880000 - 0x8088FFFF: AAC - */ -#define AAC_OFFSET 0x080000 -#define AAC_BASE (EP93XX_APB_BASE | AAC_OFFSET) - -/* - * 0x80890000 - 0x8089FFFF: Reserved - */ - -/* - * 0x808A0000 - 0x808AFFFF: SPI - */ -#define SPI_OFFSET 0x0A0000 -#define SPI_BASE (EP93XX_APB_BASE | SPI_OFFSET) - -/* - * 0x808B0000 - 0x808BFFFF: IrDA - */ -#define IRDA_OFFSET 0x0B0000 -#define IRDA_BASE (EP93XX_APB_BASE | IRDA_OFFSET) - -/* - * 0x808C0000 - 0x808CFFFF: UART1 - */ -#define UART1_OFFSET 0x0C0000 -#define UART1_BASE (EP93XX_APB_BASE | UART1_OFFSET) - -/* - * 0x808D0000 - 0x808DFFFF: UART2 - */ -#define UART2_OFFSET 0x0D0000 -#define UART2_BASE (EP93XX_APB_BASE | UART2_OFFSET) - -/* - * 0x808E0000 - 0x808EFFFF: UART3 - */ -#define UART3_OFFSET 0x0E0000 -#define UART3_BASE (EP93XX_APB_BASE | UART3_OFFSET) - -/* - * 0x808F0000 - 0x808FFFFF: Key Matrix - */ -#define KEY_OFFSET 0x0F0000 -#define KEY_BASE (EP93XX_APB_BASE | KEY_OFFSET) - -/* - * 0x80900000 - 0x8090FFFF: Touchscreen - */ -#define TOUCH_OFFSET 0x900000 -#define TOUCH_BASE (EP93XX_APB_BASE | TOUCH_OFFSET) - -/* - * 0x80910000 - 0x8091FFFF: Pulse Width Modulation - */ -#define PWM_OFFSET 0x910000 -#define PWM_BASE (EP93XX_APB_BASE | PWM_OFFSET) - -/* - * 0x80920000 - 0x8092FFFF: Real time clock - */ -#define RTC_OFFSET 0x920000 -#define RTC_BASE (EP93XX_APB_BASE | RTC_OFFSET) - -/* - * 0x80930000 - 0x8093FFFF: Syscon - */ -#define SYSCON_OFFSET 0x930000 -#define SYSCON_BASE (EP93XX_APB_BASE | SYSCON_OFFSET) - -/* Security */ -#define SECURITY_EXTENSIONID 0x80832714 - -#ifndef __ASSEMBLY__ -struct syscon_regs { - uint32_t pwrsts; - uint32_t pwrcnt; - uint32_t halt; - uint32_t stby; - uint32_t reserved0[2]; - uint32_t teoi; - uint32_t stfclr; - uint32_t clkset1; - uint32_t clkset2; - uint32_t reserved1[6]; - uint32_t scratch0; - uint32_t scratch1; - uint32_t reserved2[2]; - uint32_t apbwait; - uint32_t bustmstrarb; - uint32_t bootmodeclr; - uint32_t reserved3[9]; - uint32_t devicecfg; - uint32_t vidclkdiv; - uint32_t mirclkdiv; - uint32_t i2sclkdiv; - uint32_t keytchclkdiv; - uint32_t chipid; - uint32_t reserved4; - uint32_t syscfg; - uint32_t reserved5[8]; - uint32_t sysswlock; -}; -#else -#define SYSCON_SCRATCH0 (SYSCON_BASE + 0x0040) -#endif - -#define SYSCON_OFF_CLKSET1 0x0020 -#define SYSCON_OFF_SYSCFG 0x009c - -#define SYSCON_PWRCNT_UART_BAUD (1 << 29) -#define SYSCON_PWRCNT_USH_EN (1 << 28) - -#define SYSCON_CLKSET_PLL_X2IPD_SHIFT 0 -#define SYSCON_CLKSET_PLL_X2FBD2_SHIFT 5 -#define SYSCON_CLKSET_PLL_X1FBD1_SHIFT 11 -#define SYSCON_CLKSET_PLL_PS_SHIFT 16 -#define SYSCON_CLKSET1_PCLK_DIV_SHIFT 18 -#define SYSCON_CLKSET1_HCLK_DIV_SHIFT 20 -#define SYSCON_CLKSET1_NBYP1 (1 << 23) -#define SYSCON_CLKSET1_FCLK_DIV_SHIFT 25 - -#define SYSCON_CLKSET2_PLL2_EN (1 << 18) -#define SYSCON_CLKSET2_NBYP2 (1 << 19) -#define SYSCON_CLKSET2_USB_DIV_SHIFT 28 - -#define SYSCON_CHIPID_REV_MASK 0xF0000000 -#define SYSCON_DEVICECFG_SWRST (1 << 31) - -#define SYSCON_SYSCFG_LASDO 0x00000020 - -/* - * 0x80930000 - 0x8093FFFF: Watchdog Timer - */ -#define WATCHDOG_OFFSET 0x940000 -#define WATCHDOG_BASE (EP93XX_APB_BASE | WATCHDOG_OFFSET) - -/* - * 0x80950000 - 0x9000FFFF: Reserved - */ - -/* - * During low_level init we store memory layout in memory at specific location - */ -#define UBOOT_MEMORYCNF_BANK_SIZE 0x2000 -#define UBOOT_MEMORYCNF_BANK_MASK 0x2004 -#define UBOOT_MEMORYCNF_BANK_COUNT 0x2008 diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 69570bebb447..16733d2d1f8b 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -22,7 +22,6 @@ obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_E1000) += e1000.o obj-$(CONFIG_E1000_SPI) += e1000_spi.o obj-$(CONFIG_EEPRO100) += eepro100.o -obj-$(CONFIG_EP93XX) += ep93xx_eth.o obj-$(CONFIG_ETHOC) += ethoc.o obj-$(CONFIG_ETH_DESIGNWARE) += designware.o obj-$(CONFIG_ETH_DESIGNWARE_MESON8B) += dwmac_meson8b.o diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c deleted file mode 100644 index 9f8df7de0609..000000000000 --- a/drivers/net/ep93xx_eth.c +++ /dev/null @@ -1,654 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Cirrus Logic EP93xx ethernet MAC / MII driver. - * - * Copyright (C) 2010, 2009 - * Matthias Kaehlcke matthias@kaehlcke.net - * - * Copyright (C) 2004, 2005 - * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com - * - * Based on the original eth.[ch] Cirrus Logic EP93xx Rev D. Ethernet Driver, - * which is - * - * (C) Copyright 2002 2003 - * Adam Bezanson, Network Audio Technologies, Inc. - * bezanson@netaudiotech.com - */ - -#include <command.h> -#include <common.h> -#include <log.h> -#include <net.h> -#include <asm/arch/ep93xx.h> -#include <asm/io.h> -#include <malloc.h> -#include <miiphy.h> -#include <linux/bug.h> -#include <linux/types.h> -#include "ep93xx_eth.h" - -#define GET_PRIV(eth_dev) ((struct ep93xx_priv *)(eth_dev)->priv) -#define GET_REGS(eth_dev) (GET_PRIV(eth_dev)->regs) - -/* ep93xx_miiphy ops forward declarations */ -static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, - int reg); -static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 value); - -#if defined(EP93XX_MAC_DEBUG) -/** - * Dump ep93xx_mac values to the terminal. - */ -static void dump_dev(struct eth_device *dev) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - int i; - - printf("\ndump_dev()\n"); - printf(" rx_dq.base %p\n", priv->rx_dq.base); - printf(" rx_dq.current %p\n", priv->rx_dq.current); - printf(" rx_dq.end %p\n", priv->rx_dq.end); - printf(" rx_sq.base %p\n", priv->rx_sq.base); - printf(" rx_sq.current %p\n", priv->rx_sq.current); - printf(" rx_sq.end %p\n", priv->rx_sq.end); - - for (i = 0; i < NUMRXDESC; i++) - printf(" rx_buffer[%2.d] %p\n", i, net_rx_packets[i]); - - printf(" tx_dq.base %p\n", priv->tx_dq.base); - printf(" tx_dq.current %p\n", priv->tx_dq.current); - printf(" tx_dq.end %p\n", priv->tx_dq.end); - printf(" tx_sq.base %p\n", priv->tx_sq.base); - printf(" tx_sq.current %p\n", priv->tx_sq.current); - printf(" tx_sq.end %p\n", priv->tx_sq.end); -} - -/** - * Dump all RX status queue entries to the terminal. - */ -static void dump_rx_status_queue(struct eth_device *dev) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - int i; - - printf("\ndump_rx_status_queue()\n"); - printf(" descriptor address word1 word2\n"); - for (i = 0; i < NUMRXDESC; i++) { - printf(" [ %p ] %08X %08X\n", - priv->rx_sq.base + i, - (priv->rx_sq.base + i)->word1, - (priv->rx_sq.base + i)->word2); - } -} - -/** - * Dump all RX descriptor queue entries to the terminal. - */ -static void dump_rx_descriptor_queue(struct eth_device *dev) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - int i; - - printf("\ndump_rx_descriptor_queue()\n"); - printf(" descriptor address word1 word2\n"); - for (i = 0; i < NUMRXDESC; i++) { - printf(" [ %p ] %08X %08X\n", - priv->rx_dq.base + i, - (priv->rx_dq.base + i)->word1, - (priv->rx_dq.base + i)->word2); - } -} - -/** - * Dump all TX descriptor queue entries to the terminal. - */ -static void dump_tx_descriptor_queue(struct eth_device *dev) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - int i; - - printf("\ndump_tx_descriptor_queue()\n"); - printf(" descriptor address word1 word2\n"); - for (i = 0; i < NUMTXDESC; i++) { - printf(" [ %p ] %08X %08X\n", - priv->tx_dq.base + i, - (priv->tx_dq.base + i)->word1, - (priv->tx_dq.base + i)->word2); - } -} - -/** - * Dump all TX status queue entries to the terminal. - */ -static void dump_tx_status_queue(struct eth_device *dev) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - int i; - - printf("\ndump_tx_status_queue()\n"); - printf(" descriptor address word1\n"); - for (i = 0; i < NUMTXDESC; i++) { - printf(" [ %p ] %08X\n", - priv->rx_sq.base + i, - (priv->rx_sq.base + i)->word1); - } -} -#else -#define dump_dev(x) -#define dump_rx_descriptor_queue(x) -#define dump_rx_status_queue(x) -#define dump_tx_descriptor_queue(x) -#define dump_tx_status_queue(x) -#endif /* defined(EP93XX_MAC_DEBUG) */ - -/** - * Reset the EP93xx MAC by twiddling the soft reset bit and spinning until - * it's cleared. - */ -static void ep93xx_mac_reset(struct eth_device *dev) -{ - struct mac_regs *mac = GET_REGS(dev); - uint32_t value; - - debug("+ep93xx_mac_reset"); - - value = readl(&mac->selfctl); - value |= SELFCTL_RESET; - writel(value, &mac->selfctl); - - while (readl(&mac->selfctl) & SELFCTL_RESET) - ; /* noop */ - - debug("-ep93xx_mac_reset"); -} - -/* Eth device open */ -static int ep93xx_eth_open(struct eth_device *dev, struct bd_info *bd) -{ - struct ep93xx_priv *priv = GET_PRIV(dev); - struct mac_regs *mac = GET_REGS(dev); - uchar *mac_addr = dev->enetaddr; - int i; - - debug("+ep93xx_eth_open"); - - /* Reset the MAC */ - ep93xx_mac_reset(dev); - - /* Reset the descriptor queues' current and end address values */ - priv->tx_dq.current = priv->tx_dq.base; - priv->tx_dq.end = (priv->tx_dq.base + NUMTXDESC); - - priv->tx_sq.current = priv->tx_sq.base; - priv->tx_sq.end = (priv->tx_sq.base + NUMTXDESC); - - priv->rx_dq.current = priv->rx_dq.base; - priv->rx_dq.end = (priv->rx_dq.base + NUMRXDESC); - - priv->rx_sq.current = priv->rx_sq.base; - priv->rx_sq.end = (priv->rx_sq.base + NUMRXDESC); - - /* - * Set the transmit descriptor and status queues' base address, - * current address, and length registers. Set the maximum frame - * length and threshold. Enable the transmit descriptor processor. - */ - writel((uint32_t)priv->tx_dq.base, &mac->txdq.badd); - writel((uint32_t)priv->tx_dq.base, &mac->txdq.curadd); - writel(sizeof(struct tx_descriptor) * NUMTXDESC, &mac->txdq.blen); - - writel((uint32_t)priv->tx_sq.base, &mac->txstsq.badd); - writel((uint32_t)priv->tx_sq.base, &mac->txstsq.curadd); - writel(sizeof(struct tx_status) * NUMTXDESC, &mac->txstsq.blen); - - writel(0x00040000, &mac->txdthrshld); - writel(0x00040000, &mac->txststhrshld); - - writel((TXSTARTMAX << 0) | (PKTSIZE_ALIGN << 16), &mac->maxfrmlen); - writel(BMCTL_TXEN, &mac->bmctl); - - /* - * Set the receive descriptor and status queues' base address, - * current address, and length registers. Enable the receive - * descriptor processor. - */ - writel((uint32_t)priv->rx_dq.base, &mac->rxdq.badd); - writel((uint32_t)priv->rx_dq.base, &mac->rxdq.curadd); - writel(sizeof(struct rx_descriptor) * NUMRXDESC, &mac->rxdq.blen); - - writel((uint32_t)priv->rx_sq.base, &mac->rxstsq.badd); - writel((uint32_t)priv->rx_sq.base, &mac->rxstsq.curadd); - writel(sizeof(struct rx_status) * NUMRXDESC, &mac->rxstsq.blen); - - writel(0x00040000, &mac->rxdthrshld); - - writel(BMCTL_RXEN, &mac->bmctl); - - writel(0x00040000, &mac->rxststhrshld); - - /* Wait until the receive descriptor processor is active */ - while (!(readl(&mac->bmsts) & BMSTS_RXACT)) - ; /* noop */ - - /* - * Initialize the RX descriptor queue. Clear the TX descriptor queue. - * Clear the RX and TX status queues. Enqueue the RX descriptor and - * status entries to the MAC. - */ - for (i = 0; i < NUMRXDESC; i++) { - /* set buffer address */ - (priv->rx_dq.base + i)->word1 = (uint32_t)net_rx_packets[i]; - - /* set buffer length, clear buffer index and NSOF */ - (priv->rx_dq.base + i)->word2 = PKTSIZE_ALIGN; - } - - memset(priv->tx_dq.base, 0, - (sizeof(struct tx_descriptor) * NUMTXDESC)); - memset(priv->rx_sq.base, 0, - (sizeof(struct rx_status) * NUMRXDESC)); - memset(priv->tx_sq.base, 0, - (sizeof(struct tx_status) * NUMTXDESC)); - - writel(NUMRXDESC, &mac->rxdqenq); - writel(NUMRXDESC, &mac->rxstsqenq); - - /* Set the primary MAC address */ - writel(AFP_IAPRIMARY, &mac->afp); - writel(mac_addr[0] | (mac_addr[1] << 8) | - (mac_addr[2] << 16) | (mac_addr[3] << 24), - &mac->indad); - writel(mac_addr[4] | (mac_addr[5] << 8), &mac->indad_upper); - - /* Turn on RX and TX */ - writel(RXCTL_IA0 | RXCTL_BA | RXCTL_SRXON | - RXCTL_RCRCA | RXCTL_MA, &mac->rxctl); - writel(TXCTL_STXON, &mac->txctl); - - /* Dump data structures if we're debugging */ - dump_dev(dev); - dump_rx_descriptor_queue(dev); - dump_rx_status_queue(dev); - dump_tx_descriptor_queue(dev); - dump_tx_status_queue(dev); - - debug("-ep93xx_eth_open"); - - return 1; -} - -/** - * Halt EP93xx MAC transmit and receive by clearing the TxCTL and RxCTL - * registers. - */ -static void ep93xx_eth_close(struct eth_device *dev) -{ - struct mac_regs *mac = GET_REGS(dev); - - debug("+ep93xx_eth_close"); - - writel(0x00000000, &mac->rxctl); - writel(0x00000000, &mac->txctl); - - debug("-ep93xx_eth_close"); -} - -/** - * Copy a frame of data from the MAC into the protocol layer for further - * processing. - */ -static int ep93xx_eth_rcv_packet(struct eth_device *dev) -{ - struct mac_regs *mac = GET_REGS(dev); - struct ep93xx_priv *priv = GET_PRIV(dev); - int len = -1; - - debug("+ep93xx_eth_rcv_packet"); - - if (RX_STATUS_RFP(priv->rx_sq.current)) { - if (RX_STATUS_RWE(priv->rx_sq.current)) { - /* - * We have a good frame. Extract the frame's length - * from the current rx_status_queue entry, and copy - * the frame's data into net_rx_packets[] of the - * protocol stack. We track the total number of - * bytes in the frame (nbytes_frame) which will be - * used when we pass the data off to the protocol - * layer via net_process_received_packet(). - */ - len = RX_STATUS_FRAME_LEN(priv->rx_sq.current); - - net_process_received_packet( - (uchar *)priv->rx_dq.current->word1, len); - - debug("reporting %d bytes...\n", len); - } else { - /* Do we have an erroneous packet? */ - pr_err("packet rx error, status %08X %08X", - priv->rx_sq.current->word1, - priv->rx_sq.current->word2); - dump_rx_descriptor_queue(dev); - dump_rx_status_queue(dev); - } - - /* - * Clear the associated status queue entry, and - * increment our current pointers to the next RX - * descriptor and status queue entries (making sure - * we wrap properly). - */ - memset((void *)priv->rx_sq.current, 0, - sizeof(struct rx_status)); - - priv->rx_sq.current++; - if (priv->rx_sq.current >= priv->rx_sq.end) - priv->rx_sq.current = priv->rx_sq.base; - - priv->rx_dq.current++; - if (priv->rx_dq.current >= priv->rx_dq.end) - priv->rx_dq.current = priv->rx_dq.base; - - /* - * Finally, return the RX descriptor and status entries - * back to the MAC engine, and loop again, checking for - * more descriptors to process. - */ - writel(1, &mac->rxdqenq); - writel(1, &mac->rxstsqenq); - } else { - len = 0; - } - - debug("-ep93xx_eth_rcv_packet %d", len); - return len; -} - -/** - * Send a block of data via ethernet. - */ -static int ep93xx_eth_send_packet(struct eth_device *dev, - void * const packet, int const length) -{ - struct mac_regs *mac = GET_REGS(dev); - struct ep93xx_priv *priv = GET_PRIV(dev); - int ret = -1; - - debug("+ep93xx_eth_send_packet"); - - /* Parameter check */ - BUG_ON(packet == NULL); - - /* - * Initialize the TX descriptor queue with the new packet's info. - * Clear the associated status queue entry. Enqueue the packet - * to the MAC for transmission. - */ - - /* set buffer address */ - priv->tx_dq.current->word1 = (uint32_t)packet; - - /* set buffer length and EOF bit */ - priv->tx_dq.current->word2 = length | TX_DESC_EOF; - - /* clear tx status */ - priv->tx_sq.current->word1 = 0; - - /* enqueue the TX descriptor */ - writel(1, &mac->txdqenq); - - /* wait for the frame to become processed */ - while (!TX_STATUS_TXFP(priv->tx_sq.current)) - ; /* noop */ - - if (!TX_STATUS_TXWE(priv->tx_sq.current)) { - pr_err("packet tx error, status %08X", - priv->tx_sq.current->word1); - dump_tx_descriptor_queue(dev); - dump_tx_status_queue(dev); - - /* TODO: Add better error handling? */ - goto eth_send_out; - } - - ret = 0; - /* Fall through */ - -eth_send_out: - debug("-ep93xx_eth_send_packet %d", ret); - return ret; -} - -#if defined(CONFIG_MII) -int ep93xx_miiphy_initialize(struct bd_info * const bd) -{ - int retval; - struct mii_dev *mdiodev = mdio_alloc(); - if (!mdiodev) - return -ENOMEM; - strlcpy(mdiodev->name, "ep93xx_eth0", MDIO_NAME_LEN); - mdiodev->read = ep93xx_miiphy_read; - mdiodev->write = ep93xx_miiphy_write; - - retval = mdio_register(mdiodev); - if (retval < 0) - return retval; - return 0; -} -#endif - -/** - * Initialize the EP93xx MAC. The MAC hardware is reset. Buffers are - * allocated, if necessary, for the TX and RX descriptor and status queues, - * as well as for received packets. The EP93XX MAC hardware is initialized. - * Transmit and receive operations are enabled. - */ -int ep93xx_eth_initialize(u8 dev_num, int base_addr) -{ - int ret = -1; - struct eth_device *dev; - struct ep93xx_priv *priv; - - debug("+ep93xx_eth_initialize"); - - priv = malloc(sizeof(*priv)); - if (!priv) { - pr_err("malloc() failed"); - goto eth_init_failed_0; - } - memset(priv, 0, sizeof(*priv)); - - priv->regs = (struct mac_regs *)base_addr; - - priv->tx_dq.base = calloc(NUMTXDESC, - sizeof(struct tx_descriptor)); - if (priv->tx_dq.base == NULL) { - pr_err("calloc() failed"); - goto eth_init_failed_1; - } - - priv->tx_sq.base = calloc(NUMTXDESC, - sizeof(struct tx_status)); - if (priv->tx_sq.base == NULL) { - pr_err("calloc() failed"); - goto eth_init_failed_2; - } - - priv->rx_dq.base = calloc(NUMRXDESC, - sizeof(struct rx_descriptor)); - if (priv->rx_dq.base == NULL) { - pr_err("calloc() failed"); - goto eth_init_failed_3; - } - - priv->rx_sq.base = calloc(NUMRXDESC, - sizeof(struct rx_status)); - if (priv->rx_sq.base == NULL) { - pr_err("calloc() failed"); - goto eth_init_failed_4; - } - - dev = malloc(sizeof *dev); - if (dev == NULL) { - pr_err("malloc() failed"); - goto eth_init_failed_5; - } - memset(dev, 0, sizeof *dev); - - dev->iobase = base_addr; - dev->priv = priv; - dev->init = ep93xx_eth_open; - dev->halt = ep93xx_eth_close; - dev->send = ep93xx_eth_send_packet; - dev->recv = ep93xx_eth_rcv_packet; - - sprintf(dev->name, "ep93xx_eth-%hu", dev_num); - - eth_register(dev); - - /* Done! */ - ret = 1; - goto eth_init_done; - -eth_init_failed_5: - free(priv->rx_sq.base); - /* Fall through */ - -eth_init_failed_4: - free(priv->rx_dq.base); - /* Fall through */ - -eth_init_failed_3: - free(priv->tx_sq.base); - /* Fall through */ - -eth_init_failed_2: - free(priv->tx_dq.base); - /* Fall through */ - -eth_init_failed_1: - free(priv); - /* Fall through */ - -eth_init_failed_0: - /* Fall through */ - -eth_init_done: - debug("-ep93xx_eth_initialize %d", ret); - return ret; -} - -#if defined(CONFIG_MII) - -/** - * Maximum MII address we support - */ -#define MII_ADDRESS_MAX 31 - -/** - * Maximum MII register address we support - */ -#define MII_REGISTER_MAX 31 - -/** - * Read a 16-bit value from an MII register. - */ -static int ep93xx_miiphy_read(struct mii_dev *bus, int addr, int devad, - int reg) -{ - unsigned short value = 0; - struct mac_regs *mac = (struct mac_regs *)MAC_BASE; - int ret = -1; - uint32_t self_ctl; - - debug("+ep93xx_miiphy_read"); - - /* Parameter checks */ - BUG_ON(bus->name == NULL); - BUG_ON(addr > MII_ADDRESS_MAX); - BUG_ON(reg > MII_REGISTER_MAX); - - /* - * Save the current SelfCTL register value. Set MAC to suppress - * preamble bits. Wait for any previous MII command to complete - * before issuing the new command. - */ - self_ctl = readl(&mac->selfctl); -#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) - writel(self_ctl & ~(1 << 8), &mac->selfctl); -#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ - - while (readl(&mac->miists) & MIISTS_BUSY) - ; /* noop */ - - /* - * Issue the MII 'read' command. Wait for the command to complete. - * Read the MII data value. - */ - writel(MIICMD_OPCODE_READ | ((uint32_t)addr << 5) | (uint32_t)reg, - &mac->miicmd); - while (readl(&mac->miists) & MIISTS_BUSY) - ; /* noop */ - - value = (unsigned short)readl(&mac->miidata); - - /* Restore the saved SelfCTL value and return. */ - writel(self_ctl, &mac->selfctl); - - ret = 0; - /* Fall through */ - - debug("-ep93xx_miiphy_read"); - if (ret < 0) - return ret; - return value; -} - -/** - * Write a 16-bit value to an MII register. - */ -static int ep93xx_miiphy_write(struct mii_dev *bus, int addr, int devad, - int reg, u16 value) -{ - struct mac_regs *mac = (struct mac_regs *)MAC_BASE; - int ret = -1; - uint32_t self_ctl; - - debug("+ep93xx_miiphy_write"); - - /* Parameter checks */ - BUG_ON(bus->name == NULL); - BUG_ON(addr > MII_ADDRESS_MAX); - BUG_ON(reg > MII_REGISTER_MAX); - - /* - * Save the current SelfCTL register value. Set MAC to suppress - * preamble bits. Wait for any previous MII command to complete - * before issuing the new command. - */ - self_ctl = readl(&mac->selfctl); -#if defined(CONFIG_MII_SUPPRESS_PREAMBLE) - writel(self_ctl & ~(1 << 8), &mac->selfctl); -#endif /* defined(CONFIG_MII_SUPPRESS_PREAMBLE) */ - - while (readl(&mac->miists) & MIISTS_BUSY) - ; /* noop */ - - /* Issue the MII 'write' command. Wait for the command to complete. */ - writel((uint32_t)value, &mac->miidata); - writel(MIICMD_OPCODE_WRITE | ((uint32_t)addr << 5) | (uint32_t)reg, - &mac->miicmd); - while (readl(&mac->miists) & MIISTS_BUSY) - ; /* noop */ - - /* Restore the saved SelfCTL value and return. */ - writel(self_ctl, &mac->selfctl); - - ret = 0; - /* Fall through */ - - debug("-ep93xx_miiphy_write"); - return ret; -} -#endif /* defined(CONFIG_MII) */ diff --git a/drivers/net/ep93xx_eth.h b/drivers/net/ep93xx_eth.h deleted file mode 100644 index 074fe25f347c..000000000000 --- a/drivers/net/ep93xx_eth.h +++ /dev/null @@ -1,126 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net - * - * Copyright (C) 2004, 2005 - * Cory T. Tusar, Videon Central, Inc., ctusar@videon-central.com - */ - -#ifndef _EP93XX_ETH_H -#define _EP93XX_ETH_H - -#include <net.h> - -/** - * #define this to dump device status and queue info during initialization and - * following errors. - */ -#undef EP93XX_MAC_DEBUG - -/** - * Number of descriptor and status entries in our RX queues. - * It must be power of 2 ! - */ -#define NUMRXDESC PKTBUFSRX - -/** - * Number of descriptor and status entries in our TX queues. - */ -#define NUMTXDESC 1 - -/** - * 944 = (1024 - 64) - 16, Fifo size - Minframesize - 16 (Chip FACT) - */ -#define TXSTARTMAX 944 - -/** - * Receive descriptor queue entry - */ -struct rx_descriptor { - uint32_t word1; - uint32_t word2; -}; - -/** - * Receive status queue entry - */ -struct rx_status { - uint32_t word1; - uint32_t word2; -}; - -#define RX_STATUS_RWE(rx_status) ((rx_status->word1 >> 30) & 0x01) -#define RX_STATUS_RFP(rx_status) ((rx_status->word1 >> 31) & 0x01) -#define RX_STATUS_FRAME_LEN(rx_status) (rx_status->word2 & 0xFFFF) - -/** - * Transmit descriptor queue entry - */ -struct tx_descriptor { - uint32_t word1; - uint32_t word2; -}; - -#define TX_DESC_EOF (1 << 31) - -/** - * Transmit status queue entry - */ -struct tx_status { - uint32_t word1; -}; - -#define TX_STATUS_TXWE(tx_status) (((tx_status)->word1 >> 30) & 0x01) -#define TX_STATUS_TXFP(tx_status) (((tx_status)->word1 >> 31) & 0x01) - -/** - * Transmit descriptor queue - */ -struct tx_descriptor_queue { - struct tx_descriptor *base; - struct tx_descriptor *current; - struct tx_descriptor *end; -}; - -/** - * Transmit status queue - */ -struct tx_status_queue { - struct tx_status *base; - volatile struct tx_status *current; - struct tx_status *end; -}; - -/** - * Receive descriptor queue - */ -struct rx_descriptor_queue { - struct rx_descriptor *base; - struct rx_descriptor *current; - struct rx_descriptor *end; -}; - -/** - * Receive status queue - */ -struct rx_status_queue { - struct rx_status *base; - volatile struct rx_status *current; - struct rx_status *end; -}; - -/** - * EP93xx MAC private data structure - */ -struct ep93xx_priv { - struct rx_descriptor_queue rx_dq; - struct rx_status_queue rx_sq; - void *rx_buffer[NUMRXDESC]; - - struct tx_descriptor_queue tx_dq; - struct tx_status_queue tx_sq; - - struct mac_regs *regs; -}; - -#endif diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index eb6fe9f6b30f..a4472da9f182 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -14,7 +14,6 @@ obj-$(CONFIG_USB_ATMEL) += ohci-at91.o obj-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o obj-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o obj-$(CONFIG_USB_SL811HS) += sl811-hcd.o -obj-$(CONFIG_USB_OHCI_EP93XX) += ohci-ep93xx.o obj-$(CONFIG_USB_OHCI_LPC32XX) += ohci-lpc32xx.o obj-$(CONFIG_USB_OHCI_PCI) += ohci-pci.o obj-$(CONFIG_USB_OHCI_GENERIC) += ohci-generic.o diff --git a/drivers/usb/host/ohci-ep93xx.c b/drivers/usb/host/ohci-ep93xx.c deleted file mode 100644 index 9654fa2996f8..000000000000 --- a/drivers/usb/host/ohci-ep93xx.c +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2013 - * Sergey Kostanbaev < sergey.kostanbaev <at> fairwaves.ru > - */ - -#include <config.h> -#include <common.h> - -#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) -#include <asm/io.h> -#include <asm/arch/ep93xx.h> - -int usb_cpu_init(void) -{ - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - unsigned long pwr = readl(&syscon->pwrcnt); - writel(pwr | SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt); - - return 0; -} - -int usb_cpu_stop(void) -{ - struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; - unsigned long pwr = readl(&syscon->pwrcnt); - writel(pwr & ~SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt); - - return 0; -} - -int usb_cpu_init_fail(void) -{ - return usb_cpu_stop(); -} - -#endif /* defined(CONFIG_USB_OHCI) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */
On Thu, Mar 31, 2022 at 01:46:53PM -0400, Tom Rini wrote:
There are no platforms for this architecture anymore, remove unused code.
Signed-off-by: Tom Rini trini@konsulko.com
On Thu, Mar 31, 2022 at 01:46:44PM -0400, Tom Rini wrote:
This driver is not enabled by any board and not converted to DM_ETH. Remove.
