[U-Boot] [PATCH] ppc4xx: Remove duplicated code for Sequoia NAND booting version
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/sequoia/sdram.c | 6 +----- 1 files changed, 1 insertions(+), 5 deletions(-)
diff --git a/board/amcc/sequoia/sdram.c b/board/amcc/sequoia/sdram.c index c26e6ee..6df4c6d 100644 --- a/board/amcc/sequoia/sdram.c +++ b/board/amcc/sequoia/sdram.c @@ -44,7 +44,7 @@ extern void denali_core_search_data_eye(void); * for the 4k NAND boot image so define bus_frequency to 133MHz here * which is save for the refresh counter setup. */ -#define get_bus_freq(val) 133000000 +#define get_bus_freq(val) 133333333 #endif
/************************************************************************* @@ -55,11 +55,7 @@ extern void denali_core_search_data_eye(void); phys_size_t initdram (int board_type) { #if !defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) -#if !defined(CONFIG_NAND_SPL) ulong speed = get_bus_freq(0); -#else - ulong speed = 133333333; /* 133MHz is on the safe side */ -#endif
mtsdram(DDR0_02, 0x00000000);
Dear Stefan Roese,
- for the 4k NAND boot image so define bus_frequency to 133MHz here
- which is save for the refresh counter setup.
To me that does not look exactly like duplicated code removal...
Hi Wolfgang,
Here a closer look at the patch:
As you can see, the top patch part changes the define of get_bus_frequency() to 133333333. This define was only enabled (via ifdef) for the CONFIG_NAND_SPL part:
#if defined(CONFIG_NAND_SPL) /* Using cpu/ppc4xx/speed.c to calculate the bus frequency is too big * for the 4k NAND boot image so define bus_frequency to 133MHz here * which is save for the refresh counter setup. */ #define get_bus_freq(val) 133333333 #endif
And now the 2nd patch part makes sure that this define is really used.
So what the patch does is to remove an unused code part. Is this what you are complaining about? If really needed I could resend this patch with a modified patch subject.
Best regards, Stefan
Dear Stefan Roese,
No, I complain that you also change a vital costant without even mentioning.
Normally, this should be split into two separate patches., but at least it should be stated in the commit message.
The constant was not used at all (as I mentioned in my last mail). So changing it to the really used value seems logical to me.
I'll resend the patch with a changed commit text later.
Stefan Roese
