[U-Boot] [PATCH] Add "source" command; prepare removal of "autoscr" command
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now.
This patch prepares this change and starts a 6 month transition period as follows:
- The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed when the support for the "autoscr" command get's finally dropped.
Signed-off-by: Wolfgang Denk wd@denx.de --- README | 10 +- board/cray/L1/L1.c | 2 +- board/cray/L1/bootscript.hush | 2 +- board/esd/common/cmd_loadpci.c | 6 +- board/pn62/cmd_pn62.c | 7 +- common/Makefile | 4 +- common/cmd_autoscript.c | 241 ------------------------------------ common/cmd_load.c | 7 +- common/cmd_net.c | 7 +- common/cmd_source.c | 252 ++++++++++++++++++++++++++++++++++++++ doc/feature-removal-schedule.txt | 20 ++- include/common.h | 4 +- include/config_cmd_all.h | 2 +- include/config_cmd_default.h | 2 +- include/configs/APC405.h | 14 +- include/configs/CRAYL1.h | 26 ++-- include/configs/DU440.h | 12 +- include/configs/EP1C20.h | 2 +- include/configs/GEN860T.h | 2 +- include/configs/MVBC_P.h | 12 +- include/configs/MVBLM7.h | 12 +- include/configs/NETPHONE.h | 2 +- include/configs/NETTA2.h | 2 +- include/configs/NX823.h | 4 +- include/configs/PN62.h | 6 +- include/configs/TOP860.h | 8 +- include/configs/TQM5200.h | 2 +- include/configs/VoVPN-GW.h | 4 +- include/configs/afeb9260.h | 6 +- include/configs/apollon.h | 2 +- include/configs/at91cap9adk.h | 4 +- include/configs/at91sam9260ek.h | 6 +- include/configs/at91sam9261ek.h | 6 +- include/configs/at91sam9263ek.h | 6 +- include/configs/at91sam9rlek.h | 6 +- include/configs/atngw100.h | 2 +- include/configs/atstk1002.h | 2 +- include/configs/atstk1006.h | 2 +- include/configs/eNET.h | 6 +- include/configs/favr-32-ezkit.h | 2 +- include/configs/grsim.h | 26 ++-- include/configs/grsim_leon2.h | 22 ++-- include/configs/gth2.h | 14 +- include/configs/keymile-common.h | 2 +- include/configs/lwmon.h | 4 +- include/configs/lwmon5.h | 2 +- include/configs/mp2usb.h | 4 +- include/configs/mx1fs2.h | 6 +- include/configs/omap2420h4.h | 2 +- include/configs/omap3_beagle.h | 2 +- include/configs/omap3_evm.h | 2 +- include/configs/omap3_overo.h | 2 +- include/configs/omap3_pandora.h | 2 +- include/configs/omap3_zoom1.h | 2 +- include/configs/sc3.h | 24 ++-- include/configs/scb9328.h | 4 +- include/configs/stxxtc.h | 2 +- include/configs/vct.h | 38 +++--- include/configs/wepep250.h | 6 +- 59 files changed, 454 insertions(+), 436 deletions(-) delete mode 100644 common/cmd_autoscript.c create mode 100644 common/cmd_source.c
diff --git a/README b/README index 32d9acd..fcc4d7c 100644 --- a/README +++ b/README @@ -593,7 +593,6 @@ The following options need to be configured: except those marked below with a "*".
CONFIG_CMD_ASKENV * ask for env variable - CONFIG_CMD_AUTOSCRIPT Autoscript Support CONFIG_CMD_BDI bdinfo CONFIG_CMD_BEDBUG * Include BedBug Debugger CONFIG_CMD_BMP * BMP support @@ -654,6 +653,7 @@ The following options need to be configured: (requires CONFIG_CMD_I2C) CONFIG_CMD_SETGETDCR Support for DCR Register access (4xx only) + CONFIG_CMD_SOURCE "source" command Support CONFIG_CMD_SPI * SPI serial bus support CONFIG_CMD_USB * USB support CONFIG_CMD_VFD * VFD support (TRAB) @@ -1789,7 +1789,7 @@ The following options need to be configured:
Note: overly (ab)use of the default environment is discouraged. Make sure to check other ways to preset - the environment like the autoscript function or the + the environment like the "source" command or the boot command first.
- DataFlash Support: @@ -1948,8 +1948,8 @@ Legacy uImage format: 81 common/cmd_net.c NetLoop() back without error -82 common/cmd_net.c size == 0 (File with size 0 loaded) 82 common/cmd_net.c trying automatic boot - 83 common/cmd_net.c running autoscript - -83 common/cmd_net.c some error in automatic boot or autoscript + 83 common/cmd_net.c running "source" command + -83 common/cmd_net.c some error in automatic boot or "source" command 84 common/cmd_net.c end without errors
FIT uImage format: @@ -2952,7 +2952,7 @@ Some configuration options can be set using Environment Variables: autoscript - if set to "yes" commands like "loadb", "loady", "bootp", "tftpb", "rarpboot" and "nfs" will attempt to automatically run script images (by internally - calling "autoscript"). + calling "source").
autoscript_uname - if script image is in a format (FIT) this variable is used to get script subimage unit name. diff --git a/board/cray/L1/L1.c b/board/cray/L1/L1.c index 1c82bdf..8a06ecc 100644 --- a/board/cray/L1/L1.c +++ b/board/cray/L1/L1.c @@ -164,7 +164,7 @@ int misc_init_r (void) setenv ("ethaddr", e); } } - sprintf (bootcmd,"autoscript %X",(unsigned)bootscript); + sprintf (bootcmd,"source %X",(unsigned)bootscript); setenv ("bootcmd", bootcmd); return (0); } diff --git a/board/cray/L1/bootscript.hush b/board/cray/L1/bootscript.hush index ec4839b..f2f78ad 100644 --- a/board/cray/L1/bootscript.hush +++ b/board/cray/L1/bootscript.hush @@ -31,7 +31,7 @@ if printenv bootscript tftp $tftp_addr $bootcript if imi $tftp_addr then - autoscript $tftp_addr + source $tftp_addr fi fi
diff --git a/board/esd/common/cmd_loadpci.c b/board/esd/common/cmd_loadpci.c index 0a6626e..c779f79 100644 --- a/board/esd/common/cmd_loadpci.c +++ b/board/esd/common/cmd_loadpci.c @@ -30,7 +30,7 @@ #if defined(CONFIG_CMD_BSP)
extern int do_bootm (cmd_tbl_t *, int, int, char *[]); -extern int do_autoscript (cmd_tbl_t *, int, int, char *[]); +extern int do_source (cmd_tbl_t *, int, int, char *[]);
#define ADDRMASK 0xfffff000
@@ -98,12 +98,12 @@ int do_loadpci(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
case 1: /* - * Boot image via autoscr + * Boot image via "source" command */ printf("executing script at addr 0x%s ...\n", addr); local_args[0] = addr; local_args[1] = NULL; - do_autoscript(cmdtp, 0, 1, local_args); + do_source(cmdtp, 0, 1, local_args); break;
case 2: diff --git a/board/pn62/cmd_pn62.c b/board/pn62/cmd_pn62.c index 10d0df6..b9f3bdb 100644 --- a/board/pn62/cmd_pn62.c +++ b/board/pn62/cmd_pn62.c @@ -152,12 +152,13 @@ int do_loadpci (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_AUTOSCRIPT +#ifdef CONFIG_SOURCE if (load_addr) { char *s;
if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running autoscript at addr 0x%08lX", load_addr); + printf ("Running "source" command at addr 0x%08lX", + load_addr);
s = getenv ("autoscript_uname"); if (s) @@ -165,7 +166,7 @@ int do_loadpci (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) else puts (" ...\n");
- rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } } #endif diff --git a/common/Makefile b/common/Makefile index 23171ca..eb8e283 100644 --- a/common/Makefile +++ b/common/Makefile @@ -61,8 +61,8 @@ COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o -COBJS-$(CONFIG_AUTOSCRIPT) += cmd_autoscript.o -COBJS-$(CONFIG_CMD_AUTOSCRIPT) += cmd_autoscript.o +COBJS-$(CONFIG_SOURCE) += cmd_source.o +COBJS-$(CONFIG_CMD_SOURCE) += cmd_source.o COBJS-$(CONFIG_CMD_BDI) += cmd_bdinfo.o COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o diff --git a/common/cmd_autoscript.c b/common/cmd_autoscript.c deleted file mode 100644 index e5a9bc0..0000000 --- a/common/cmd_autoscript.c +++ /dev/null @@ -1,241 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, kharris@nexus-tech.net - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * autoscript allows a remote host to download a command file and, - * optionally, binary data for automatically updating the target. For - * example, you create a new kernel image and want the user to be - * able to simply download the image and the machine does the rest. - * The kernel image is postprocessed with mkimage, which creates an - * image with a script file prepended. If enabled, autoscript will - * verify the script and contents of the download and execute the - * script portion. This would be responsible for erasing flash, - * copying the new image, and rebooting the machine. - */ - -/* #define DEBUG */ - -#include <common.h> -#include <command.h> -#include <image.h> -#include <malloc.h> -#include <asm/byteorder.h> -#if defined(CONFIG_8xx) -#include <mpc8xx.h> -#endif -#ifdef CONFIG_SYS_HUSH_PARSER -#include <hush.h> -#endif - -int -autoscript (ulong addr, const char *fit_uname) -{ - ulong len; - image_header_t *hdr; - ulong *data; - char *cmd; - int rcode = 0; - int verify; -#if defined(CONFIG_FIT) - const void* fit_hdr; - int noffset; - const void *fit_data; - size_t fit_len; -#endif - - verify = getenv_yesno ("verify"); - - switch (genimg_get_format ((void *)addr)) { - case IMAGE_FORMAT_LEGACY: - hdr = (image_header_t *)addr; - - if (!image_check_magic (hdr)) { - puts ("Bad magic number\n"); - return 1; - } - - if (!image_check_hcrc (hdr)) { - puts ("Bad header crc\n"); - return 1; - } - - if (verify) { - if (!image_check_dcrc (hdr)) { - puts ("Bad data crc\n"); - return 1; - } - } - - if (!image_check_type (hdr, IH_TYPE_SCRIPT)) { - puts ("Bad image type\n"); - return 1; - } - - /* get length of script */ - data = (ulong *)image_get_data (hdr); - - if ((len = uimage_to_cpu (*data)) == 0) { - puts ("Empty Script\n"); - return 1; - } - - /* - * scripts are just multi-image files with one component, seek - * past the zero-terminated sequence of image lengths to get - * to the actual image data - */ - while (*data++); - break; -#if defined(CONFIG_FIT) - case IMAGE_FORMAT_FIT: - if (fit_uname == NULL) { - puts ("No FIT subimage unit name\n"); - return 1; - } - - fit_hdr = (const void *)addr; - if (!fit_check_format (fit_hdr)) { - puts ("Bad FIT image format\n"); - return 1; - } - - /* get script component image node offset */ - noffset = fit_image_get_node (fit_hdr, fit_uname); - if (noffset < 0) { - printf ("Can't find '%s' FIT subimage\n", fit_uname); - return 1; - } - - if (!fit_image_check_type (fit_hdr, noffset, IH_TYPE_SCRIPT)) { - puts ("Not a image image\n"); - return 1; - } - - /* verify integrity */ - if (verify) { - if (!fit_image_check_hashes (fit_hdr, noffset)) { - puts ("Bad Data Hash\n"); - return 1; - } - } - - /* get script subimage data address and length */ - if (fit_image_get_data (fit_hdr, noffset, &fit_data, &fit_len)) { - puts ("Could not find script subimage data\n"); - return 1; - } - - data = (ulong *)fit_data; - len = (ulong)fit_len; - break; -#endif - default: - puts ("Wrong image format for autoscript\n"); - return 1; - } - - debug ("** Script length: %ld\n", len); - - if ((cmd = malloc (len + 1)) == NULL) { - return 1; - } - - /* make sure cmd is null terminated */ - memmove (cmd, (char *)data, len); - *(cmd + len) = 0; - -#ifdef CONFIG_SYS_HUSH_PARSER /*?? */ - rcode = parse_string_outer (cmd, FLAG_PARSE_SEMICOLON); -#else - { - char *line = cmd; - char *next = cmd; - - /* - * break into individual lines, - * and execute each line; - * terminate on error. - */ - while (*next) { - if (*next == '\n') { - *next = '\0'; - /* run only non-empty commands */ - if (*line) { - debug ("** exec: "%s"\n", - line); - if (run_command (line, 0) < 0) { - rcode = 1; - break; - } - } - line = next + 1; - } - ++next; - } - if (rcode == 0 && *line) - rcode = (run_command(line, 0) >= 0); - } -#endif - free (cmd); - return rcode; -} - -/**************************************************/ -#if defined(CONFIG_CMD_AUTOSCRIPT) -int -do_autoscript (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - ulong addr; - int rcode; - const char *fit_uname = NULL; - - /* Find script image */ - if (argc < 2) { - addr = CONFIG_SYS_LOAD_ADDR; - debug ("* autoscr: default load address = 0x%08lx\n", addr); -#if defined(CONFIG_FIT) - } else if (fit_parse_subimage (argv[1], load_addr, &addr, &fit_uname)) { - debug ("* autoscr: subimage '%s' from FIT image at 0x%08lx\n", - fit_uname, addr); -#endif - } else { - addr = simple_strtoul(argv[1], NULL, 16); - debug ("* autoscr: cmdline image address = 0x%08lx\n", addr); - } - - printf ("## Executing script at %08lx\n", addr); - rcode = autoscript (addr, fit_uname); - return rcode; -} - -U_BOOT_CMD( - autoscr, 2, 0, do_autoscript, - "run script from memory", - "[addr] - run script starting at addr" - " - A valid autoscr header must be present\n" -#if defined(CONFIG_FIT) - "For FIT format uImage addr must include subimage\n" - "unit name in the form of addr:<subimg_uname>\n" -#endif -); -#endif diff --git a/common/cmd_load.c b/common/cmd_load.c index 88fba88..d5eaac7 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -513,12 +513,13 @@ int do_load_serial_bin (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } }
s = getenv ("autoscript_uname"); if (s) @@ -526,7 +527,7 @@ int do_load_serial_bin (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) else puts (" ...\n");
- rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } } #endif diff --git a/common/cmd_net.c b/common/cmd_net.c index a687849..9bef7a2 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -222,9 +222,10 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_AUTOSCRIPT +#ifdef CONFIG_SOURCE if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running autoscript at addr 0x%08lX", load_addr); + printf ("Running "source" command at addr 0x%08lX", + load_addr);
s = getenv ("autoscript_uname"); if (s) @@ -233,7 +234,7 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) puts (" ...\n");
show_boot_progress (83); - rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } #endif if (rcode < 0) diff --git a/common/cmd_source.c b/common/cmd_source.c new file mode 100644 index 0000000..62e93a3 --- /dev/null +++ b/common/cmd_source.c @@ -0,0 +1,252 @@ +/* + * (C) Copyright 2001 + * Kyle Harris, kharris@nexus-tech.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * The "source" command allows to define "script images", i. e. files + * that contain command sequences that can be executed by the command + * interpreter. It returns the exit status of the last command + * executed from the script. This is very similar to running a shell + * script in a UNIX shell, hence the name for the command. + */ + +/* #define DEBUG */ + +#include <common.h> +#include <command.h> +#include <image.h> +#include <malloc.h> +#include <asm/byteorder.h> +#if defined(CONFIG_8xx) +#include <mpc8xx.h> +#endif +#ifdef CONFIG_SYS_HUSH_PARSER +#include <hush.h> +#endif + +int +source (ulong addr, const char *fit_uname) +{ + ulong len; + image_header_t *hdr; + ulong *data; + char *cmd; + int rcode = 0; + int verify; +#if defined(CONFIG_FIT) + const void* fit_hdr; + int noffset; + const void *fit_data; + size_t fit_len; +#endif + + verify = getenv_yesno ("verify"); + + switch (genimg_get_format ((void *)addr)) { + case IMAGE_FORMAT_LEGACY: + hdr = (image_header_t *)addr; + + if (!image_check_magic (hdr)) { + puts ("Bad magic number\n"); + return 1; + } + + if (!image_check_hcrc (hdr)) { + puts ("Bad header crc\n"); + return 1; + } + + if (verify) { + if (!image_check_dcrc (hdr)) { + puts ("Bad data crc\n"); + return 1; + } + } + + if (!image_check_type (hdr, IH_TYPE_SCRIPT)) { + puts ("Bad image type\n"); + return 1; + } + + /* get length of script */ + data = (ulong *)image_get_data (hdr); + + if ((len = uimage_to_cpu (*data)) == 0) { + puts ("Empty Script\n"); + return 1; + } + + /* + * scripts are just multi-image files with one component, seek + * past the zero-terminated sequence of image lengths to get + * to the actual image data + */ + while (*data++); + break; +#if defined(CONFIG_FIT) + case IMAGE_FORMAT_FIT: + if (fit_uname == NULL) { + puts ("No FIT subimage unit name\n"); + return 1; + } + + fit_hdr = (const void *)addr; + if (!fit_check_format (fit_hdr)) { + puts ("Bad FIT image format\n"); + return 1; + } + + /* get script component image node offset */ + noffset = fit_image_get_node (fit_hdr, fit_uname); + if (noffset < 0) { + printf ("Can't find '%s' FIT subimage\n", fit_uname); + return 1; + } + + if (!fit_image_check_type (fit_hdr, noffset, IH_TYPE_SCRIPT)) { + puts ("Not a image image\n"); + return 1; + } + + /* verify integrity */ + if (verify) { + if (!fit_image_check_hashes (fit_hdr, noffset)) { + puts ("Bad Data Hash\n"); + return 1; + } + } + + /* get script subimage data address and length */ + if (fit_image_get_data (fit_hdr, noffset, &fit_data, &fit_len)) { + puts ("Could not find script subimage data\n"); + return 1; + } + + data = (ulong *)fit_data; + len = (ulong)fit_len; + break; +#endif + default: + puts ("Wrong image format for "source" command\n"); + return 1; + } + + debug ("** Script length: %ld\n", len); + + if ((cmd = malloc (len + 1)) == NULL) { + return 1; + } + + /* make sure cmd is null terminated */ + memmove (cmd, (char *)data, len); + *(cmd + len) = 0; + +#ifdef CONFIG_SYS_HUSH_PARSER /*?? */ + rcode = parse_string_outer (cmd, FLAG_PARSE_SEMICOLON); +#else + { + char *line = cmd; + char *next = cmd; + + /* + * break into individual lines, + * and execute each line; + * terminate on error. + */ + while (*next) { + if (*next == '\n') { + *next = '\0'; + /* run only non-empty commands */ + if (*line) { + debug ("** exec: "%s"\n", + line); + if (run_command (line, 0) < 0) { + rcode = 1; + break; + } + } + line = next + 1; + } + ++next; + } + if (rcode == 0 && *line) + rcode = (run_command(line, 0) >= 0); + } +#endif + free (cmd); + return rcode; +} + +/**************************************************/ +#if defined(CONFIG_CMD_SOURCE) +int +do_source (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong addr; + int rcode; + const char *fit_uname = NULL; + + /* Find script image */ + if (argc < 2) { + addr = CONFIG_SYS_LOAD_ADDR; + debug ("* source: default load address = 0x%08lx\n", addr); +#if defined(CONFIG_FIT) + } else if (fit_parse_subimage (argv[1], load_addr, &addr, &fit_uname)) { + debug ("* source: subimage '%s' from FIT image at 0x%08lx\n", + fit_uname, addr); +#endif + } else { + addr = simple_strtoul(argv[1], NULL, 16); + debug ("* source: cmdline image address = 0x%08lx\n", addr); + } + + printf ("## Executing script at %08lx\n", addr); + rcode = source (addr, fit_uname); + return rcode; +} + +U_BOOT_CMD( + source, 2, 0, do_source, + "run script from memory", + "[addr] - run script starting at addr" + " - A valid image header must be present\n" +#if defined(CONFIG_FIT) + "For FIT format uImage addr must include subimage\n" + "unit name in the form of addr:<subimg_uname>\n" +#endif +); + +/* + * Keep for now for backward compatibility; + * remove later when support for "autoscr" goes away. + */ +U_BOOT_CMD( + autoscr, 2, 0, do_source, + "run script from memory", + "[addr] - run script starting at addr" + " - A valid image header must be present\n" +#if defined(CONFIG_FIT) + "For FIT format uImage addr must include subimage\n" + "unit name in the form of addr:<subimg_uname>\n" +#endif +); +#endif diff --git a/doc/feature-removal-schedule.txt b/doc/feature-removal-schedule.txt index 9ba7a04..cd429a4 100644 --- a/doc/feature-removal-schedule.txt +++ b/doc/feature-removal-schedule.txt @@ -8,12 +8,20 @@ file. ---------------------------
What: "autoscr" command -When: August 2009 -Why: "autosrc" is an ugly and completely non-standard name. The "autoscr" - command is deprecated and will be replaced the "source" command as - used by other shells such as bash. Both commands will be supported - for a transition period of 6 months after which "autoscr" will be - removed. +When: Release 2009-09 + +Why: "autosrc" is an ugly and completely non-standard name. + The "autoscr" command is deprecated and will be replaced by + + the "source" command as used by other shells such as bash. + + Starting with March 2009, both commands will be supported for + a transition period of 6 months after which "autoscr" will be + removed. During the transition period existing scripts and + environment variable names remain untouched for maximum + compatibiltiy; thse will be changed when support for the + "autoscr" command get's finally dropped. + Who: Peter Tyser ptyser@xes-inc.com
--------------------------- diff --git a/include/common.h b/include/common.h index 952ddff..20c058a 100644 --- a/include/common.h +++ b/include/common.h @@ -234,8 +234,8 @@ int mac_read_from_eeprom(void); /* common/flash.c */ void flash_perror (int);
-/* common/cmd_autoscript.c */ -int autoscript (ulong addr, const char *fit_uname); +/* common/cmd_source.c */ +int source (ulong addr, const char *fit_uname);
extern ulong load_addr; /* Default Load Address */
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index db1f55c..c5e0d26 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -15,7 +15,6 @@
#define CONFIG_CMD_AMBAPP /* AMBA Plug & Play Bus print utility */ #define CONFIG_CMD_ASKENV /* ask for env variable */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BEDBUG /* Include BedBug Debugger */ #define CONFIG_CMD_BMP /* BMP support */ @@ -76,6 +75,7 @@ #define CONFIG_CMD_SETEXPR /* setexpr support */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ #define CONFIG_CMD_SNTP /* SNTP support */ +#define CONFIG_CMD_SOURCE /* "source" command support */ #define CONFIG_CMD_SPI /* SPI utility */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ diff --git a/include/config_cmd_default.h b/include/config_cmd_default.h index 3667602..0376e44 100644 --- a/include/config_cmd_default.h +++ b/include/config_cmd_default.h @@ -16,7 +16,6 @@ * hardware, not fully tested, etc.). */
-#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BOOTD /* bootd */ #define CONFIG_CMD_CONSOLE /* coninfo */ @@ -37,6 +36,7 @@ #define CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_RUN /* run command in env variable */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */
#endif /* _CONFIG_CMD_DEFAULT_H */ diff --git a/include/configs/APC405.h b/include/configs/APC405.h index 7453518..41eaaab 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -124,19 +124,19 @@ */ #include <config_cmd_default.h>
+#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT +#define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF -#define CONFIG_CMD_DATE +#define CONFIG_CMD_FAT #define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ #define CONFIG_CMD_MII +#define CONFIG_CMD_PCI #define CONFIG_CMD_PING -#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_SOURCE #define CONFIG_CMD_USB -#define CONFIG_CMD_AUTOSCRIPT
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION diff --git a/include/configs/CRAYL1.h b/include/configs/CRAYL1.h index 527c846..150bd29 100644 --- a/include/configs/CRAYL1.h +++ b/include/configs/CRAYL1.h @@ -74,32 +74,32 @@ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_AUTOSCRIPT 1 +#define CONFIG_SOURCE 1
/* * Command line configuration. */
+#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BDI -#define CONFIG_CMD_IMI -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_NET -#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_CONSOLE -#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG #define CONFIG_CMD_ECHO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IMI #define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_DATE #define CONFIG_CMD_RUN -#define CONFIG_CMD_I2C -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_DIAG -#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_SETGETDCR +#define CONFIG_CMD_SOURCE
/* diff --git a/include/configs/DU440.h b/include/configs/DU440.h index 85c0e61..e6abbdc 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -290,14 +290,13 @@ int du440_phy_addr(int devnum);
-#define CONFIG_CMD_AUTOSCRIPT -#define CONFIG_CMD_BSP +#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMP +#define CONFIG_CMD_BSP #define CONFIG_CMD_DATE -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DHCP -#define CONFIG_CMD_DTT #define CONFIG_CMD_DIAG +#define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT @@ -309,9 +308,10 @@ int du440_phy_addr(int devnum); #define CONFIG_CMD_NFS #define CONFIG_CMD_PCI #define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SOURCE +#define CONFIG_CMD_USB
#define CONFIG_SUPPORT_VFAT
@@ -428,7 +428,7 @@ int du440_phy_addr(int devnum); #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
#define CONFIG_OF_LIBFDT #define CONFIG_OF_BOARD_SETUP diff --git a/include/configs/EP1C20.h b/include/configs/EP1C20.h index a0904d4..8941e4d 100644 --- a/include/configs/EP1C20.h +++ b/include/configs/EP1C20.h @@ -180,7 +180,6 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
-#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_BOOTD #undef CONFIG_CMD_CONSOLE #undef CONFIG_CMD_FPGA @@ -188,6 +187,7 @@ #undef CONFIG_CMD_ITEST #undef CONFIG_CMD_NFS #undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_XIMG
diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index a399d22..8f18ab2 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -152,7 +152,7 @@
/* * Set default IP stuff just to get bootstrap entries into the - * environment so that we can autoscript the full default environment. + * environment so that we can source the full default environment. */ #define CONFIG_ETHADDR 9a:52:63:15:85:25 #define CONFIG_SERVERIP 10.0.4.201 diff --git a/include/configs/MVBC_P.h b/include/configs/MVBC_P.h index cd910ea..edbc701 100644 --- a/include/configs/MVBC_P.h +++ b/include/configs/MVBC_P.h @@ -73,8 +73,8 @@ #define MV_INITRD_LENGTH 0x00300000 #define MV_SCRATCH_ADDR 0x00000000 #define MV_SCRATCH_LENGTH MV_INITRD_LENGTH -#define MV_AUTOSCR_ADDR 0xff840000 -#define MV_AUTOSCR_ADDR2 0xff850000 +#define MV_SOURCE_ADDR 0xff840000 +#define MV_SOURCE_ADDR2 0xff850000 #define MV_DTB_ADDR 0xfffc0000
#define CONFIG_SHOW_BOOT_PROGRESS 1 @@ -130,8 +130,8 @@ #define CONFIG_RESET_TO_RETRY 1000
#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then autoscr ${autoscr_addr}; \ - else autoscr ${autoscr_addr2}; \ + then source ${autoscr_addr}; \ + else source ${autoscr_addr2}; \ fi;"
#define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs" @@ -149,8 +149,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_AUTOSCR_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_AUTOSCR_ADDR2) "\0" \ + "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ + "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 4ecf806..3cf3bb2 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -411,8 +411,8 @@ #define MV_FPGA_SIZE 0x00076ca2 #define MV_KERNEL_ADDR 0xff810000 #define MV_INITRD_ADDR 0xffb00000 -#define MV_AUTOSCR_ADDR 0xff804000 -#define MV_AUTOSCR_ADDR2 0xff806000 +#define MV_SOURCE_ADDR 0xff804000 +#define MV_SOURCE_ADDR2 0xff806000 #define MV_DTB_ADDR 0xff808000 #define MV_INITRD_LENGTH 0x00400000
@@ -423,8 +423,8 @@ #define MV_INITRD_ADDR_RAM 0x01000000
#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then autoscr ${autoscr_addr}; \ - else autoscr ${autoscr_addr2}; \ + then source ${autoscr_addr}; \ + else source ${autoscr_addr2}; \ fi;" #define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs"
@@ -437,8 +437,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_AUTOSCR_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_AUTOSCR_ADDR2) "\0" \ + "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ + "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index 2d04d89..796938a 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -71,7 +71,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ "bootm"
-#define CONFIG_AUTOSCRIPT +#define CONFIG_SOURCE #define CONFIG_LOADS_ECHO 0 /* echo off for serial download */ #undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */
diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index 4a27027..a14b2dd 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -71,7 +71,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ "bootm"
diff --git a/include/configs/NX823.h b/include/configs/NX823.h index 9182223..5054d5e 100644 --- a/include/configs/NX823.h +++ b/include/configs/NX823.h @@ -55,7 +55,7 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ #undef CONFIG_WATCHDOG /* watchdog disabled, for now */ -#define CONFIG_AUTOSCRIPT +#define CONFIG_SOURCE
/* * BOOTP options @@ -72,7 +72,7 @@ */ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_SOURCE
/* call various generic functions */ diff --git a/include/configs/PN62.h b/include/configs/PN62.h index 06c11e6..562c5c3 100644 --- a/include/configs/PN62.h +++ b/include/configs/PN62.h @@ -59,11 +59,11 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_BSP
-#undef CONFIG_CMD_AUTOSCRIPT -#undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_SAVEENV #undef CONFIG_CMD_FLASH #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_SOURCE
#define CONFIG_BAUDRATE 19200 /* console baudrate */ diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index 8c2befb..b9e450d 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -125,7 +125,7 @@ #define CONFIG_CMD_BEDBUG
-#define CONFIG_AUTOSCRIPT 1 +#define CONFIG_SOURCE 1 #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 #undef CONFIG_LOADS_ECHO /* NO echo on for serial download */
@@ -419,15 +419,12 @@
/* * Set default IP stuff just to get bootstrap entries into the - * environment so that we can autoscript the full default environment. + * environment so that we can source the full default environment. */ #define CONFIG_ETHADDR 9a:52:63:15:85:25 #define CONFIG_SERVERIP 10.0.4.200 #define CONFIG_IPADDR 10.0.4.111
-/*----------------------------------------------------------------------- - * Defaults for Autoscript - */ #define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ #define CONFIG_SYS_TFTP_LOADADDR 0x00100000
@@ -438,5 +435,4 @@ */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
- #endif /* __CONFIG_H */ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index d374981..fe1d102 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -253,7 +253,7 @@ #define CUSTOM_ENV_SETTINGS \ "bootfile=cam5200/uImage\0" \ "u-boot=cam5200/u-boot.bin\0" \ - "setup=tftp 200000 cam5200/setup.img; autoscr 200000\0" + "setup=tftp 200000 cam5200/setup.img; source 200000\0" #endif
#if defined(CONFIG_TQM5200_B) diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h index 5f9a17f..b2d75e3 100644 --- a/include/configs/VoVPN-GW.h +++ b/include/configs/VoVPN-GW.h @@ -150,11 +150,9 @@ * Command line configuration. */
-#define CONFIG_CMD_AUTOSCRIPT #define CONFIG_CMD_BDI #define CONFIG_CMD_CONSOLE #define CONFIG_CMD_ECHO -#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_FLASH #define CONFIG_CMD_IMI #define CONFIG_CMD_IMLS @@ -164,6 +162,8 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_PING #define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_SOURCE
/* diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 33a67ca..fa27119 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -69,11 +69,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/apollon.h b/include/configs/apollon.h index f83dd9c..b0af2a9 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -127,7 +127,7 @@ #define CONFIG_MTD_PARTITIONS #endif
-#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SOURCE
#ifndef CONFIG_SYS_USE_NOR # undef CONFIG_CMD_FLASH diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 7e7f124..2ddbd17 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -91,10 +91,10 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 1fae3a3..1a5f9a4 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -86,11 +86,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 752d7e9..4d50932 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -90,11 +90,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index dd500ca..78e0081 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -91,11 +91,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 7a4039c..a48f2cb 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -82,12 +82,12 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_USB
#define CONFIG_CMD_NAND 1 diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index c998952..4ed5514 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -117,9 +117,9 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_SPI
-#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_XIMG
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 2284277..b258f2d 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -142,9 +142,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index 8cfa312..f93118e 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -142,9 +142,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 84e1aef..8169d10 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -70,16 +70,15 @@ */ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BOOTD /* bootd */ #define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_FLASH /* flinfo, erase, protect */ #define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IMI /* iminfo */ #define CONFIG_CMD_IMLS /* List all found images */ +#define CONFIG_CMD_IRQ /* IRQ Information */ #define CONFIG_CMD_ITEST /* Integer (and string) test */ #define CONFIG_CMD_LOADB /* loadb */ #define CONFIG_CMD_LOADS /* loads */ @@ -88,9 +87,10 @@ #undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command Support */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */ -#define CONFIG_CMD_IRQ /* IRQ Information */
#define CONFIG_BOOTDELAY 15 #define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyS0,9600" diff --git a/include/configs/favr-32-ezkit.h b/include/configs/favr-32-ezkit.h index 21802df..739ff0d 100644 --- a/include/configs/favr-32-ezkit.h +++ b/include/configs/favr-32-ezkit.h @@ -139,9 +139,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/grsim.h b/include/configs/grsim.h index a9eaa4a..c3f1a31 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -65,23 +65,23 @@ /* * Supported commands */ -#define CONFIG_CMD_AMBAPP /* AMBA Plyg&Play information */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ -#define CONFIG_CMD_BDI /* bdinfo */ -#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_AMBAPP /* AMBA Plyg&Play information */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_DIAG -#define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_ITEST /* Integer (and string) test */ -#define CONFIG_CMD_LOADB /* loadb */ -#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc */ -#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_RUN /* run command in env variable */ -#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ -#define CONFIG_CMD_XIMG /* Load part of Multi Image */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */
/* * Autobooting diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 58f26fd..7ebbf25 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -64,21 +64,21 @@ /* * Supported commands */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ -#define CONFIG_CMD_BDI /* bdinfo */ -#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_DIAG -#define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_ITEST /* Integer (and string) test */ -#define CONFIG_CMD_LOADB /* loadb */ -#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_RUN /* run command in env variable */ -#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ -#define CONFIG_CMD_XIMG /* Load part of Multi Image */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */
/* * Autobooting diff --git a/include/configs/gth2.h b/include/configs/gth2.h index b1b4842..677baea 100644 --- a/include/configs/gth2.h +++ b/include/configs/gth2.h @@ -90,18 +90,18 @@ #define CONFIG_CMD_IDE #define CONFIG_CMD_DHCP
-#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_ELF #undef CONFIG_CMD_FAT #undef CONFIG_CMD_FLASH #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MII -#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_ELF -#undef CONFIG_CMD_BDI -#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_MII #undef CONFIG_CMD_NFS -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/keymile-common.h b/include/configs/keymile-common.h index 58b95f4..b2e37ec 100644 --- a/include/configs/keymile-common.h +++ b/include/configs/keymile-common.h @@ -240,7 +240,7 @@ "new_esw_0x${IVM_BoardId}_0x${IVM_HWKey}.scr \0" \ "new_esw=run set_new_esw_script; " \ "tftp ${autoscr_ws} ${new_esw_script}; " \ - "iminfo ${autoscr_ws}; autoscr ${autoscr_ws} \0" \ + "iminfo ${autoscr_ws}; source ${autoscr_ws} \0" \ "bootlimit=0 \0" \ CONFIG_KM_DEF_ENV_IOMUX \ CONFIG_KM_DEF_ENV_PRIVATE \ diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index d52a5e0..8f00773 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -93,7 +93,7 @@ * 3 = 0x3C+0x3F = F3 + F6 : enable test mode */
-#define CONFIG_BOOTCOMMAND "autoscr 40040000;saveenv" +#define CONFIG_BOOTCOMMAND "source 40040000;saveenv"
/* "gatewayip=10.8.211.250\0" \ */ #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -108,7 +108,7 @@ "key_magic2=3A+3C\0" \ "key_cmd2=echo *** Entering Update Mode ***;" \ "if fatload ide 0:3 10000 update.scr;" \ - "then autoscr 10000;" \ + "then source 10000;" \ "else echo *** UPDATE FAILED ***;" \ "fi\0" \ "key_magic3=3C+3F\0" \ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 05055c8..777a4d6 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -313,7 +313,7 @@ "cp.b 200000 FFF80000 80000\0" \ "upd=run load update\0" \ "lwe_env=tftp 200000 /tftpboot.dev/lwmon5/env_uboot.bin;" \ - "autoscr 200000\0" \ + "source 200000\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 9ac7e9a..edaa174 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -163,15 +163,15 @@
#else
- #define CONFIG_CMD_USB #define CONFIG_CMD_CACHE + #define CONFIG_CMD_USB
- #undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_MISC + #undef CONFIG_CMD_SOURCE
#endif
diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index a19eb78..cba0803 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -51,12 +51,12 @@
-#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET #undef CONFIG_CMD_PING -#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 983b5f2..13b89ac 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -135,7 +135,7 @@ #define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2
- #undef CONFIG_CMD_AUTOSCRIPT + #undef CONFIG_CMD_SOURCE #endif
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 0f9344b..c20981c 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -174,7 +174,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index f4498a9..db82899 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -167,7 +167,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index dee0417..64cc1c4 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -161,7 +161,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 00c0374..592ec75 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -163,7 +163,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index f8ae163..70ec036 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -171,7 +171,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/sc3.h b/include/configs/sc3.h index 5b68ef9..97e1da2 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -122,7 +122,7 @@ "rootpath=/opt/eldk/ppc_4xx\0" \ "bootfile=/tftpboot/sc3/uImage\0" \ "u-boot=/tftpboot/sc3/u-boot.bin\0" \ - "setup=tftp 200000 /tftpboot/sc3/setup.img;autoscr 200000\0" \ + "setup=tftp 200000 /tftpboot/sc3/setup.img;source 200000\0" \ "kernel_addr=FFE08000\0" \ "" #undef CONFIG_BOOTCOMMAND @@ -186,20 +186,20 @@ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_NAND -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE +#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_SOURCE
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index 5971df7..a038901 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -53,9 +53,9 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP
-#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index 5a5f772..147233d 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -68,7 +68,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ "bootm"
diff --git a/include/configs/vct.h b/include/configs/vct.h index 5371e2d..d202522 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -301,38 +301,38 @@ int vct_gpio_get(int pin); * (NOR/OneNAND) usage and Linux kernel booting. */ #if defined(CONFIG_VCT_SMALL_IMAGE) +#undef CONFIG_CMD_ASKENV +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_CONSOLE +#undef CONFIG_CMD_CRC32 +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_SNTP #undef CONFIG_CMD_ELF -#undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_BEDBUG -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FAT +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ #undef CONFIG_CMD_ITEST +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADY #undef CONFIG_CMD_MII #undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING #undef CONFIG_CMD_REGINFO +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_STRINGS #undef CONFIG_CMD_TERMINAL -#undef CONFIG_CMD_ASKENV -#undef CONFIG_CMD_CRC32 -#undef CONFIG_CMD_DHCP -#undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_LOADY -#undef CONFIG_CMD_BDI #undef CONFIG_CMD_USB -#undef CONFIG_CMD_FAT
#undef CONFIG_DRIVER_SMC911X #undef CONFIG_SOFT_I2C -#undef CONFIG_AUTOSCRIPT +#undef CONFIG_SOURCE #undef CONFIG_SYS_LONGHELP #undef CONFIG_TIMESTAMP #endif /* CONFIG_VCT_SMALL_IMAGE */ diff --git a/include/configs/wepep250.h b/include/configs/wepep250.h index d0afd29..1d529b3 100644 --- a/include/configs/wepep250.h +++ b/include/configs/wepep250.h @@ -49,10 +49,10 @@ */ #include <config_cmd_default.h>
-#undef CONFIG_CMD_NET -#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_SOURCE
The changes look good to me. 2 comments below:
- Keep for now for backward compatibility;
- remove later when support for "autoscr" goes away.
+U_BOOT_CMD(
- autoscr, 2, 0, do_source,
- " - A valid image header must be present\n"
+#endif +);
I'd vote to change autoscr's help messages to something letting end user's know that the command is deprecated and being replaced by the "source". Eg something like:
+ autoscr, 2, 0, do_source, + "DEPRECATED - see 'source' command", + "DEPRECATED - see 'source' command"
Most U-Boot user's are more likely to see this than the feature-removal-schedule.txt in the source code.
- removed.
There's an out of place newline here.
s/compatibiltiy/compatibility/ s/thse/these/ and s/get's finally/finally gets/
Best, Peter
+U_BOOT_CMD(
+#endif +);
- "DEPRECATED - see 'source' command",
Actually I also like that, but if we head down this direction, then why not go all the way and print a warning on executing autoscr? Thinking about it (and reflecting on how I interact with U-Boot), I fear that even the help message will not get too much attention from people who should get aware of the problem.
What do other people think about this?
Cheers Detlev
Dear Detlev,
Good idea, indeed.
That's an even better idea. I will implement both in the next version of the patch.
Thanks!
Detlev Zundel
Peter Tyser
