[PATCH] mach-snapdragon: Allow other board vendors apart from Qcom
Qcom SoCs derived boards can come from various OEMs/ODMs and not just Qcom itself. So allow CONFIG_SYS_VENDOR to be set correctly corressponding to the actual board vendor.
Suggested-by: Stephan Gerhold stephan@gerhold.net Signed-off-by: Sumit Garg sumit.garg@linaro.org --- arch/arm/mach-snapdragon/Kconfig | 15 +++++++++------ configs/dragonboard410c_defconfig | 1 + configs/dragonboard820c_defconfig | 1 + 3 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index 96e44e2c549..4615a140d0d 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -4,7 +4,11 @@ config SYS_SOC default "snapdragon"
config SYS_VENDOR - default "qualcomm" + string "Snapdragon board vendor" + help + Allows to specify vendor for the Snapdragon SoCs based boards. + Based on this option board/<CONFIG_SYS_VENDOR>/<CONFIG_SYS_BOARD> + will be used as the custom board directory.
config SYS_MALLOC_F_LEN default 0x2000 @@ -19,12 +23,11 @@ config LNX_KRNL_IMG_TEXT_OFFSET_BASE default 0x80000000
config SYS_BOARD - string "Qualcomm custom board" + string "Snapdragon SoCs based board" help - The Dragonboard 410c and 820c have additional board init - code that isn't shared with other Qualcomm boards. - Based on this option board/qualcomm/<CONFIG_SYS_BOARD> will - be used. + Allows to specify the Snapdragon SoCs based board name. + Based on this option board/<CONFIG_SYS_VENDOR>/<CONFIG_SYS_BOARD> + will be used as the custom board directory.
config SYS_CONFIG_NAME string "Board configuration name" diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 260a8349d3b..3b6f50307a3 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SYS_VENDOR="qualcomm" CONFIG_SYS_BOARD="dragonboard410c" CONFIG_COUNTER_FREQUENCY=19000000 CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index ebc80eb2a46..a795497ef5d 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SYS_VENDOR="qualcomm" CONFIG_SYS_BOARD="dragonboard820c" CONFIG_COUNTER_FREQUENCY=19000000 CONFIG_ARCH_SNAPDRAGON=y
Hi Sumit,
config SYS_VENDOR
Can you keep the default rather than adding it to the defconfig?
With that
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org
help
config SYS_BOARD
- string "Snapdragon SoCs based board" help
be used.
Caleb Connolly
Sumit Garg
