[U-Boot-Users] [PATCH] Convert MPC8610HPCD to use libfdt.
Assumes the presence of the aliases node in the DTS to locate the pci and serial nodes for fixups.
Use consistent fdtaddr and fdtfile in environment variables.
Signed-off-by: Jon Loeliger jdl@freescale.com --- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 73 ++++++++++++++++------------- include/configs/MPC8610HPCD.h | 31 ++++++------- 2 files changed, 54 insertions(+), 50 deletions(-)
diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 9f32890..264e959 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -29,12 +29,8 @@ #include <i2c.h> #include <spd.h> #include <asm/io.h> - - -#if defined(CONFIG_OF_FLAT_TREE) -#include <ft_build.h> -extern void ft_cpu_setup(void *blob, bd_t *bd); -#endif +#include <libfdt.h> +#include <fdt_support.h>
#include "../common/pixis.h"
@@ -459,46 +455,57 @@ void pci_init_board(void) #endif /* CONFIG_PCI1 */ }
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) +#if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { - u32 *p; - int len; + int node, tmp[2]; + const char *path;
- ft_cpu_setup(blob, bd); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "timebase-frequency", bd->bi_busfreq / 4, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "bus-frequency", bd->bi_busfreq, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "clock-frequency", bd->bi_intfreq, 1); + do_fixup_by_prop_u32(blob, "device_type", "soc", 4, + "bus-frequency", bd->bi_busfreq, 1);
- p = ft_get_prop(blob, "/memory/reg", &len); - if (p != NULL) { - *p++ = cpu_to_be32(bd->bi_memstart); - *p = cpu_to_be32(bd->bi_memsize); - } + do_fixup_by_compat_u32(blob, "ns16550", + "clock-frequency", bd->bi_busfreq, 1); + + fdt_fixup_memory(blob, bd->bi_memstart, bd->bi_memsize); + + + node = fdt_path_offset(blob, "/aliases"); + tmp[0] = 0; + if (node >= 0) {
#ifdef CONFIG_PCI1 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pci@8000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pci1_hose.last_busno - pci1_hose.first_busno; - debug("pci@8000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } + path = fdt_getprop(blob, node, "pci0", NULL); + if (path) { + tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } + #endif #ifdef CONFIG_PCIE1 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pcie@a000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - debug("pcie@9000 first_busno=%d last_busno=%d\n",p[0],p[1]); + path = fdt_getprop(blob, node, "pci1", NULL); + if (path) { + tmp[1] = pcie1_hose.last_busno + - pcie1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); } #endif #ifdef CONFIG_PCIE2 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pcie@9000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; - debug("pcie@9000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } + path = fdt_getprop(blob, node, "pci2", NULL); + if (path) { + tmp[1] = pcie2_hose.last_busno + - pcie2_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } #endif - + } } #endif
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 55df5aa..11c1836 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -245,17 +245,14 @@ /* * Pass open firmware flat tree to kernel */ -#define CONFIG_OF_FLAT_TREE 1 -#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 +
/* maximum size of the flat tree (8K) */ #define OF_FLAT_TREE_MAX_SIZE 8192
-#define OF_CPU "PowerPC,8610@0" -#define OF_SOC "soc@e0000000" -#define OF_TBCLK (bd->bi_busfreq / 4) -#define OF_STDOUT_PATH "/soc@e0000000/serial@4500" - #define CFG_64BIT_VSPRINTF 1 #define CFG_64BIT_STRTOUL 1
@@ -618,8 +615,8 @@ "consoledev=ttyS0\0" \ "ramdiskaddr=2000000\0" \ "ramdiskfile=8610hpcd/ramdisk.uboot\0" \ - "dtbaddr=c00000\0" \ - "dtbfile=8610hpcd/mpc8610_hpcd.dtb\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=8610hpcd/mpc8610_hpcd.dtb\0" \ "bdev=sda3\0" \ "en-wd=mw.b f8100010 0x08; echo -expect:- 08; md.b f8100010 1\0" \ "dis-wd=mw.b f8100010 0x00; echo -expect:- 00; md.b f8100010 1\0" \ @@ -658,8 +655,8 @@ "consoledev=ttyS0\0" \ "ramdiskaddr=2000000\0" \ "ramdiskfile=8610hpcd/ramdisk.uboot\0" \ - "dtbaddr=c00000\0" \ - "dtbfile=8610hpcd/mpc8610_hpcd.dtb\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=8610hpcd/mpc8610_hpcd.dtb\0" \ "bdev=sda3\0" \ "othbootargs=diufb=15M video=fslfb:1280x1024-32@60,monitor=0\0"\ "monitor=0-DVI\0" @@ -671,22 +668,22 @@ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ - "tftp $dtbaddr $dtbfile;" \ - "bootm $loadaddr - $dtbaddr" + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $ramdiskaddr $ramdiskfile;" \ "tftp $loadaddr $bootfile;" \ - "tftp $dtbaddr $dtbfile;" \ - "bootm $loadaddr $ramdiskaddr $dtbaddr" + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr"
#define CONFIG_BOOTCOMMAND \ "setenv bootargs root=/dev/$bdev rw " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ - "tftp $dtbaddr $dtbfile;" \ - "bootm $loadaddr - $dtbaddr" + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#endif /* __CONFIG_H */
Jon Loeliger
