[U-Boot] [PATCH] powerpc/t4rdb: Add alternate serdes protocols to align with A-007186
A-007186: SerDes Ring VCO does not maintain lock throughout specified temperature range.
Option 1 of the workaround states: ------------------------------------- For all 1.25/2.5/5 GHz protocols, use LC VCO instead of Ring VCO. Rather than selecting the SRDS_PRTCL_Sx in the RCW, use the Alternate SRDS_PRTCL_Sx option. The alternate option has the same functionality as the original option; the only difference being LC VCO rather than Ring VCO.
The alternate Protocols are:
Serdes1: 27 instead of 28 Serdes2: Not impacted Serdes3: 1 instead of 2 Serdes4: 9 instead of 10
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- board/freescale/t4rdb/eth.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/freescale/t4rdb/eth.c b/board/freescale/t4rdb/eth.c index d220475..142c6a8 100644 --- a/board/freescale/t4rdb/eth.c +++ b/board/freescale/t4rdb/eth.c @@ -67,7 +67,7 @@ int board_eth_init(bd_t *bis) /* Register the 10G MDIO bus */ fm_memac_mdio_init(bis, &tgec_mdio_info);
- if (srds_prtcl_s1 == 28) { + if ((srds_prtcl_s1 == 28) || (srds_prtcl_s1 == 27)) { /* SGMII */ fm_info_set_phy_address(FM1_DTSEC1, SGMII_PHY_ADDR1); fm_info_set_phy_address(FM1_DTSEC2, SGMII_PHY_ADDR2);
Chunhe Lan
