[GIT PULL] Pull request: u-boot-imx u-boot-imx-20200825
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 789bfb52668ee609b2043de645e2f94bbd24fd1f:
Merge tag 'efi-2020-10-rc3-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2020-08-15 09:01:01 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20200825
for you to fetch changes up to acbc1d86f16cc8372cccb7b862a0b9dc242f8fe5:
imx8m: config: convert to bootm_size (2020-08-25 10:26:38 +0200)
---------------------------------------------------------------- For 2020.10 -----------
- mx6: SOCs user selectable Fix for imx6q_logic Some DM conversion - mx7: introduce secondary boot device
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/720918010
---------------------------------------------------------------- Adam Ford (1): ARM: imx6q_logic: Fix broken booting by moving fdt_addr_r address
Fabio Estevam (1): pico-imx6: Remove unneeded CONFIG_DM_MDIO
Grygorii Tertychnyi (1): imx8m: config: convert to bootm_size
Marek Vasut (5): ARM: imx: Add bmode support for iMX7 ARM: imx: Add support for switching primary/secondary boot mode to bmode ARM: imx: Add support for reading out the primary/secondary bmode ARM: imx: Add support for reading out the primary/secondary bmode to MX7 ARM: imx: ddr: Add deskew register programming
Matthias Schiffer (1): tools/imximage: fix DCD Blocks message output order
Tom Rini (1): arm: mx6: Make all i.MX6 SoCs user-selectable
Wig Cheng (3): configs: pico-imx6ul: convert DM_USB configs: pico-imx6ul: convert DM_VIDEO pico-imx6ul: convert ethernet function to DM_ETH
arch/arm/include/asm/arch-mx7/mx7-ddr.h | 16 +++++++++++++--- arch/arm/include/asm/mach-imx/boot_mode.h | 2 ++ arch/arm/include/asm/mach-imx/sys_proto.h | 8 +++++++- arch/arm/mach-imx/Kconfig | 2 +- arch/arm/mach-imx/cmd_bmode.c | 12 ++++++++++++ arch/arm/mach-imx/init.c | 30 ++++++++++++++++++++++-------- arch/arm/mach-imx/mx6/Kconfig | 134 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------------------------------------- arch/arm/mach-imx/mx7/ddr.c | 9 +++++++++ arch/arm/mach-imx/mx7/soc.c | 17 +++++++++++++++++ board/seco/Kconfig | 6 +++--- board/tbs/tbs2910/Kconfig | 3 --- board/technexion/pico-imx6ul/pico-imx6ul.c | 53 ----------------------------------------------------- board/tqc/tqma6/Kconfig | 6 +++--- configs/apalis_imx6_defconfig | 3 ++- configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos2bcsl_defconfig | 1 + configs/aristainetos2c_defconfig | 1 + configs/brppt2_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri-imx6ull_defconfig | 3 ++- configs/colibri_imx6_defconfig | 3 ++- configs/dh_imx6_defconfig | 1 + configs/display5_defconfig | 3 ++- configs/display5_factory_defconfig | 3 ++- configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ge_bx50v3_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/marsboard_defconfig | 3 ++- configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 3 ++- configs/mx6dlarm2_lpddr2_defconfig | 3 ++- configs/mx6memcal_defconfig | 3 ++- configs/mx6qarm2_defconfig | 3 ++- configs/mx6qarm2_lpddr2_defconfig | 3 ++- configs/mx6qsabrelite_defconfig | 3 ++- configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/mx6ulz_14x14_evk_defconfig | 1 + configs/myir_mys_6ulx_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 3 ++- configs/nitrogen6dl_defconfig | 3 ++- configs/nitrogen6q2g_defconfig | 3 ++- configs/nitrogen6q_defconfig | 3 ++- configs/nitrogen6s1g_defconfig | 3 ++- configs/nitrogen6s_defconfig | 3 ++- configs/novena_defconfig | 3 ++- configs/opos6uldev_defconfig | 1 + configs/ot1200_defconfig | 3 ++- configs/ot1200_spl_defconfig | 3 ++- configs/pcm058_defconfig | 3 ++- configs/pfla02_defconfig | 1 + configs/phycore_pcl063_defconfig | 1 + configs/phycore_pcl063_ull_defconfig | 1 + configs/pico-dwarf-imx6ul_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-imx6_defconfig | 2 +- configs/pico-imx6ul_defconfig | 6 +++++- configs/pico-pi-imx6ul_defconfig | 1 + configs/platinum_picon_defconfig | 3 ++- configs/platinum_titanium_defconfig | 3 ++- configs/riotboard_defconfig | 3 ++- configs/riotboard_spl_defconfig | 3 ++- configs/secomx6quq7_defconfig | 1 + configs/sksimx6_defconfig | 3 ++- configs/somlabs_visionsom_6ull_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 2 +- configs/tqma6dl_mba6_spi_defconfig | 2 +- configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 2 +- configs/tqma6s_mba6_spi_defconfig | 2 +- configs/tqma6s_wru4_mmc_defconfig | 2 +- configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/variscite_dart6ul_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/zc5202_defconfig | 3 ++- configs/zc5601_defconfig | 3 ++- include/configs/imx6_logic.h | 4 ++-- include/configs/imx8mm_evk.h | 3 +-- include/configs/imx8mn_evk.h | 3 +-- include/configs/imx8mp_evk.h | 3 +-- include/configs/imx8mq_evk.h | 4 +--- include/configs/titanium.h | 2 -- tools/imximage.c | 2 +- 123 files changed, 304 insertions(+), 187 deletions(-)
Best regards, Stefano
On Tue, Aug 25, 2020 at 04:40:48PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
