[U-Boot] [PATCH] blackfin: mmc: Correct mmc_host_is_spi and bfin_sdh.c
In the recent mmc cleanup, the mmc_host_is_spi macro was broken and bfin_sdh.c had mmc->bus_width turned into mmc_bus_width(mmc), both of which were incorrect.
Signed-off-by: Tom Rini trini@ti.com --- drivers/mmc/bfin_sdh.c | 2 +- include/mmc.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/bfin_sdh.c b/drivers/mmc/bfin_sdh.c index 7b35d8e..bcd6a3e 100644 --- a/drivers/mmc/bfin_sdh.c +++ b/drivers/mmc/bfin_sdh.c @@ -238,7 +238,7 @@ static void bfin_sdh_set_ios(struct mmc *mmc) u16 cfg = 0; u16 clk_ctl = 0;
- if (mmc_bus_width(mmc) == 4) { + if (mmc->bus_width == 4) { cfg = bfin_read_SDH_CFG(); #ifndef RSI_BLKSZ cfg &= ~PD_SDDAT3; diff --git a/include/mmc.h b/include/mmc.h index 0172979..8a82974 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -360,7 +360,7 @@ void mmc_set_preinit(struct mmc *mmc, int preinit);
#ifdef CONFIG_GENERIC_MMC #ifdef CONFIG_MMC_SPI -#define mmc_host_is_spi(mmc) ((mmc)->cfg.host_caps & MMC_MODE_SPI) +#define mmc_host_is_spi(mmc) ((mmc)->cfg->host_caps & MMC_MODE_SPI) #else #define mmc_host_is_spi(mmc) 0 #endif
