[U-Boot] U-boot versions, DHCP difference
Hello, I'm working on booting Linux from a Virtex 5 ml507 board using U-boot version 1.3.4.
I have successfully booted Linux on an AVNET ml405 board before with no problems, but that was with an earlier version of u-boot.
I have narrowed down the problem to DHCP Request errors. It sends the DHCP Request, the Server recognizes it but because of missing fields, the packet is discarded, and the board does not get a response.
This is what is invoked and happens in U-boot:
U-Boot 1.3.4 (Mar 19 2009 - 11:00:58) => dhcp BOOTP broadcast 1 DHCPHandler: got packet: (src=138, dst=138, len=191) state: 3 Filtering pkt = -1 BOOTP broadcast 2 DHCPHandler: got packet: (src=138, dst=138, len=191) state: 3 Filtering pkt = -1 BOOTP broadcast 3 DHCPHandler: got packet: (src=138, dst=138, len=191) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=138, dst=138, len=191) state: 3 Filtering pkt = -1 BOOTP broadcast 4 DHCPHandler: got packet: (src=138, dst=138, len=191) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=137, dst=137, len=68) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=32772, dst=5065, len=16) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=137, dst=137, len=68) state: 3 Filtering pkt = -1 BOOTP broadcast 5 DHCPHandler: got packet: (src=137, dst=137, len=68) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=1044, dst=1947, len=40) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=137, dst=137, len=68) state: 3 Filtering pkt = -1 DHCPHandler: got packet: (src=137, dst=137, len=68) state: 3 Filtering pkt = -1
As you can see, no DHCP responses are received. This is what the Server receives:
New Thread: 92f thread_pool(): calling dhcpServerProtocol()
0 1 2 3 4 5 6 7 8 9 A B C D E F 0123456789ABCDEF ----------------------------------------------------------------- 0x00000 01 01 06 01 35 14 2B A5 04 E7 00 00 00 00 00 00 ....5.+......... 0x00010 00 00 00 00 00 00 00 00 81 81 90 01 00 0A 35 01 ..............5. 0x00020 02 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00060 00 00 00 00 00 00 00 00 00 00 00 00 31 32 39 2E ............129. 0x00070 31 32 39 2E 31 34 34 2E 38 31 3A 74 65 73 74 2E 129.144.81:test. 0x00080 69 6D 67 00 00 00 00 00 00 00 00 00 00 00 00 00 img............. 0x00090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x000A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x000B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x000C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x000D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x000E0 00 00 00 00 00 00 00 00 00 00 00 00 63 82 53 63 ............c.Sc 0x000F0 35 01 01 39 02 02 40 37 00 FF 00 00 00 00 00 00 5..9..@7........
0 1 2 3 4 5 6 7 8 9 A B C D E F 0123456789ABCDEF ----------------------------------------------------------------- 0x00100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0x00120 00 00 00 00 00 00 00 00 00 00 00 00 00 .............
op: 1 hType: 1 hLen: 6 hops: 1 xid: 890514341 secs: 1255 flags: 0 ciAddr: 0.0.0.0 yiAddr: 0.0.0.0 siAddr: 0.0.0.0 giAddr: 129.129.144.1 chAddr: 000a35010203 sName: bootFile: 129.129.144.81:test.img Invalid zero length specified for option=55. Bad packet received on DHCP server port. Discarded. thread_pool(): return from dhcpServerProtocol() thread_pool(): CondWait(S_pool_cv, S_pool_mx)
So a response is not given.
I think that an edit in net/bootp.c could work, adding a case 55 field for option 55 in the *popt switch, but I'm not sure exactly what I should do for that, I may mess up the packet.
Any help, or perhaps a much simpler solution would be greatly appreciated. Thank you!
-Matthew Sattlegger
mcsattle
