Pull request: u-boot-sunxi/master for v2021.04
Hi Tom,
please pull the master branch from u-boot-sunxi, containing some fixes for 2021.04: ------------------------- - H616 clock fix to enable video PLL - sunxi-common.h cleanups - support for UART1 as the console on sun8i - removing wrong linux,stdout-path from DTs -------------------------
Build-tested on all 156 sunxi boards, boot tested on some of them.
Thanks, Andre
============== The following changes since commit a1a652e8016426e2d67148cab225cd5ec45189fb:
Merge tag 'mmc-2021-2-19' of https://gitlab.denx.de/u-boot/custodians/u-boot-mmc (2021-02-19 11:56:14 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-sunxi.git
for you to fetch changes up to e036a1d227112565cdf32b5558ac6ccaf5d1633f:
fdt/sunxi: Remove OF_STDOUT_PATH (2021-02-19 23:29:47 +0000)
---------------------------------------------------------------- Andre Przywara (1): fdt/sunxi: Remove OF_STDOUT_PATH
Jernej Skrabec (1): sunxi: spl: Fix H616 clock initialization
Samuel Holland (1): sunxi: Remove dead ifdefs in sunxi-common.h
Tobias Schramm (1): sunxi: support boot console on uart1 for sun8i
README | 1 - arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 5 +++++ arch/arm/mach-sunxi/clock_sun50i_h6.c | 5 +++++ common/fdt_support.c | 9 +-------- include/configs/sunxi-common.h | 33 --------------------------------- scripts/config_whitelist.txt | 1 - 7 files changed, 12 insertions(+), 43 deletions(-)
Andre Przywara
