[U-Boot] [PATCH] arm: update Kconfig help for ENABLE_ARM_SOC_BOOT0_HOOK
When this config is enabled, <asm/arch/boot0.h> is included, but the Kconfig help says this should be a define (ARM_SOC_BOOT0_HOOK).
The code for this in arch/arm/lib/vectors.s was changed on 01/02/2017 with commit ce62e57fc571 ("ARM: boot0 hook: remove macro, include whole header file").
Signed-off-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com ---
arch/arm/Kconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 225f57e847..7b618d6881 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -287,9 +287,8 @@ config ENABLE_ARM_SOC_BOOT0_HOOK bool "prepare BOOT0 header" help If the SoC's BOOT0 requires a header area filled with (magic) - values, then choose this option, and create a define called - ARM_SOC_BOOT0_HOOK which contains the required assembler - preprocessor code. + values, then choose this option, and create a file included as + <asm/arch/boot0.h> which contains the required assembler code.
config ARM_CORTEX_CPU_IS_UP bool
Simon Goldschmidt
