[U-Boot] please pull u-boot-samsung master
Dear Albert,
Merge samsung, imx, tegra into u-boot-arm/master (2012-12-22 11:59:14 +0100)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to a2468dedef569863e1243e802fbe3aa7565e1de1:
EXYNOS5: Enable console multiplexing in u-boot (2013-01-11 17:15:04 +0900)
---------------------------------------------------------------- Ajay Kumar (6): EXYNOS5: Add support for FIMD and DP EXYNOS5: Change parent clock of FIMD to MPLL EXYNOS: Add dummy definition to fix compilation dependency on CONFIG_EXYNOS_MIPI_DSIM video: Modify exynos_fimd driver to support LCD console EXYNOS5: Make all display related code dependent on CONFIG_LCD EXYNOS5: Enable console multiplexing in u-boot
Chander Kashyap (4): EXYNOS: EXYNOS4X12: Populate Exynos4x12 register addresses EXYNOS: EXYNOS4X12: Add clock structure for EXYNOS4X12 EXYNOS: EXYNOS4X12: Add gpio structure for EXYNOS4X12 EXYNOS: EXYNOS4X12: extract Exynos4x12 IPs clock frequency
Hatim RV (5): EXYNOS5: FDT: add initial dts file for EXYNOS5250, SMDK5250 fdt: exynos5: Add DT node definition for SROM and SMSC9215 exynos5: Add DT based driver for SMC911X ethernet exynos5: config: Rename the smdk5250.h to exynos5250-dt.h SMDK5250: config: Add configuration file for SMDK5250 board
Jaehoon Chung (2): Exynos: clock: support get_mmc_clk for exynos Exynos: clock: add CLK_DIV_FSYS3 at set_mmc_clk
Piotr Wilczek (1): arm:exynos4:pinmux: Modify the gpio function for mmc
Rajeshwari Shinde (22): EXYNOS5: FDT: Add I2C device node data EXYNOS5 : FDT: Add Aliases for I2C device FDT: Add compatible string for I2C EXYNOS5: FDT : Decode peripheral id I2C: Driver changes for FDT support SMDK5250: Initialise I2C using FDT EXYNOS5: FDT: Add sound device node data EXYNOS5: FDT: Add sound and codec device node EXYNOS5: FDT: Add compatible strings for sound Sound: Add FDT support to driver Sound: WM8994: Add FDT support to codec Sound: Add FDT support to CMD. EXYNOS5: FDT: Add compatible strings for SPI EXYNOS5 : FDT: Add Aliases for SPI device EXYNOS5: FDT: Add SPI device node data SPI: EXYNOS: Add FDT support to driver. EHCI: Exynos: Add fdt support EXYNOS5: Add device node for USB. EXYNOS5: FDT: Add compatible strings for USB EXYNOS5: FDT: Add compatible strings for PMIC EXYNOS5: Add device node for PMIC PMIC: MAX77686: Add FDT Support
Vivek Gautam (1): SMDK5250: Enable VBus for USB 2.0 controller
Łukasz Majewski (2): spl:falcon:trats Update Trats default board configuration file to support FALCON MODE video:cache:fix: Enable dcache flush at LCD subsystem for Exynos based boards
arch/arm/cpu/armv7/exynos/clock.c | 272 +++++++++++++++++++++- arch/arm/cpu/armv7/exynos/pinmux.c | 74 ++++++ arch/arm/dts/exynos5250.dtsi | 154 ++++++++++++ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 276 ++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 48 +++- arch/arm/include/asm/arch-exynos/dp_info.h | 2 + arch/arm/include/asm/arch-exynos/gpio.h | 85 +++++++ arch/arm/include/asm/arch-exynos/mipi_dsim.h | 7 + arch/arm/include/asm/arch-exynos/periph.h | 33 +-- arch/arm/include/asm/arch-exynos/pinmux.h | 8 + arch/arm/include/asm/arch-exynos/sromc.h | 18 ++ board/samsung/dts/exynos5250-smdk5250.dts | 69 ++++++ board/samsung/smdk5250/smdk5250.c | 237 +++++++++++++++---- board/samsung/trats/trats.c | 2 +- common/cmd_sound.c | 2 +- doc/device-tree-bindings/exynos/isp-spi.txt | 22 ++ doc/device-tree-bindings/exynos/sound.txt | 27 +++ drivers/i2c/s3c24x0_i2c.c | 83 ++++++- drivers/i2c/s3c24x0_i2c.h | 8 + drivers/power/pmic/pmic_max77686.c | 37 ++- drivers/sound/sound.c | 171 ++++++++------ drivers/sound/wm8994.c | 74 +++++- drivers/sound/wm8994.h | 6 +- drivers/spi/exynos_spi.c | 96 +++++++- drivers/usb/host/ehci-exynos.c | 92 +++++++- drivers/video/exynos_fb.c | 5 + drivers/video/exynos_fimd.c | 12 +- include/configs/exynos5250-dt.h | 321 ++++++++++++++++++++++++++ include/configs/smdk5250.h | 278 +--------------------- include/configs/trats.h | 45 +++- include/fdtdec.h | 9 + include/i2c.h | 26 +++ include/sound.h | 4 +- lib/fdtdec.c | 9 + 35 files changed, 2167 insertions(+), 446 deletions(-) create mode 100644 arch/arm/dts/exynos5250.dtsi create mode 100644 board/samsung/dts/exynos5250-smdk5250.dts create mode 100644 doc/device-tree-bindings/exynos/isp-spi.txt create mode 100644 doc/device-tree-bindings/exynos/sound.txt create mode 100644 include/configs/exynos5250-dt.h
Hi Minkyu,
On Fri, 11 Jan 2013 17:23:10 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
-- Thanks, Minkyu Kang.
I'm sorry, but this branch breaks two boards:
- VCMA9 is broken by commit a9d2ae7014d9e66dde6dd4a344308449508e4a22, which causes the following build errors:
In file included from s3c24x0_i2c.c:40:0: s3c24x0_i2c.h:38:17: error: field 'id' has incomplete type s3c24x0_i2c.c:70:39: error: 'CONFIG_MAX_I2C_NUM' undeclared here (not in a function) s3c24x0_i2c.c:70:31: warning: 'i2c_bus' defined but not used [-Wunused-variable] s3c24x0_i2c.c:72:12: warning: 'i2c_busses' defined but not used [-Wunused-variable]
- smdk5250 is broken by commit f482310c6def17ba975a041077f89d984be54b68 which causes the following build errors:
sound.c: In function 'codec_init': sound.c:151:4: warning: passing argument 1 of 'wm8994_init' discards 'const' qualifier from pointer target type [enabled by default] In file included from sound.c:33:0: wm8994.h:83:5: note: expected 'struct sound_codec_info *' but argument is of type 'const void *' cmd_sound.c: In function 'do_init': cmd_sound.c:36:2: error: too few arguments to function 'sound_init' In file included from cmd_sound.c:27:0: /home/albert/src/u-boot-arm/include/sound.h:52:5: note: declared here
Both commits are from Rajeshwari Shinde rajeshwari.s@samsung.com, respectively with summaries:
"I2C: Driver changes for FDT support"
and
"Sound: Add FDT support to driver".
Rajesh, please fix build of VCMA9 and smdk5250. Minkyu, please integrate fixes then resubmit PR.
Amicalement,
On Fri, 11 Jan 2013 22:33:58 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Minkyu,
Dear Albert,
and
... cc:ing Rajesh this time.
Amicalement,
Hi Albert,
I would resolve these errors sorry for inconvenience
Sorry but I am not getting these errors could you please let me know you your environment settings to get the same.
Hi Rajeshwari,
On Mon, 14 Jan 2013 10:16:05 +0530, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Albert,
Thanks.
For some reason -- possibly commits I took in later -- I cannot reproduce the smdk5250 errors above in current u-boot-arm/master. However it still fails with warnings, both in u-boot-samsung/master and when merged into u-boot-arm/master:
exynos_dp.c: In function 'exynos_init_dp': exynos_dp.c:860:23: warning: variable 'disp_info' set but not used [-Wunused-but-set-variable] exynos_fb.c: In function 'draw_logo': exynos_fb.c:74:8: warning: variable 'addr' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:9: warning: variable 'y' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:6: warning: variable 'x' set but not used [-Wunused-but-set-variable]
Tested with with both ELDK 5.3: gcc version 4.7.2, and the Linaro ARM GCC from Ubuntu (gcc version 4.7.2: Ubuntu/Linaro 4.7.2-1ubuntu1.
Regards, Rajeshwari Shinde
Amicalement,
Hi Albert,
On Mon, Jan 14, 2013 at 1:14 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Rajeshwari,
Hi Albert,
Thanks.
Sorry for the warning messages. I have sent the patches to fix these warnings. Hopefully Minkyu will review and get them merged, soon.
Amicalement,
Albert. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Regards, Ajay
Dear Albert,
On 12/01/13 06:33, Albert ARIBAUD wrote:
Hi Minkyu,
Dear Albert,
checked.
But I could not get this result. Did you pull all patches for sound?
commit 2b8a0533449c8c868636def683c04282a89a85cb Sound: Add FDT support to CMD.
commit 6647c7ac8ed6ae8b5bda86df0671aea9ee3bc761 Sound: WM8994: Add FDT support to codec
commit f482310c6def17ba975a041077f89d984be54b68 Sound: Add FDT support to driver
commit 72dbff12a73291fb68d217e534eaed98d69ff5c5 EXYNOS5: FDT: Add compatible strings for sound
commit d1e8d2cad0be2f624d1d39b85c45eec7252017cd EXYNOS5: FDT: Add sound and codec device node
commit f0b16191184e3ada6bda5b3c74302f815b719592 EXYNOS5: FDT: Add sound device node data
and
Amicalement,
Thanks. Minkyu Kang.
Hi Minkyu,
On Mon, 14 Jan 2013 13:56:40 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
Hi Minkyu,
Dear Albert,
checked.
All these are in the u-boot-samsung/master branch, so yes, I necessarily pulled them when merging; besides, I tested the samsung branch alone, and the build errors are there.
Amicalement,
Ajay kumar
Albert ARIBAUD
Minkyu Kang
Rajeshwari Birje
