[U-Boot-Users] [MPC8555CDS] 1.3.2-rc3 -- TSECx: No link
All,
I just upgraded U-Boot from 1.1.6 to 1.3.2-rc3 on a MPC8555CDS and it seems TSEC isn't working. I see the same on another one, but only after rebooting from FreeBSD. In that case a reset from U-Boot resolves the problem. This board however always has a link problem.
Is this a know issue? Has this been fixed and I simply missed it?
Thanks,
\begin{log} U-Boot 1.3.2-rc3 (Mar 7 2008 - 15:08:02)
CPU: 8555, Version: 1.1, (0x80790011) Core: E500, Version: 2.0, (0x80200020) Clock Configuration: CPU: 825 MHz, CCB: 330 MHz, DDR: 165 MHz, LBC: 82 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: CDS Version 0x11, PCI Slot 1 CPU Board Revision 1.1 (0x0101) PCI1: 32 bit, 33 MHz, sync PCI2: 32 bit, 66 MHz, async I2C: ready DRAM: Initializing Reusing current 256MB configuration SDRAM: 64 MB DDR: 256 MB FLASH: 16 MB L2 cache 256KB: already enabled. PCI-X will only work at 66 MHz 01 02 1957 3fff 0604 00 01 04 1106 0686 0601 00 01 04 1106 0571 0101 0e 01 04 1106 3038 0c03 00 01 04 1106 3038 0c03 00 01 04 1106 3057 0000 00 01 04 1106 3058 0401 00 01 04 1106 3068 0780 00 01 05 10ec 8139 0200 00 00 1c 1014 01a7 0604 ff In: serial Out: serial Err: serial Net: TSEC0, TSEC1 Hit any key to stop autoboot: 0 => ping 192.168.1.1 TSEC0: No link. TSEC1: No link. ping failed; host 192.168.1.1 is not alive \end{log}
Marcel Moolenaar
