[PATCH 1/1] sandbox: add symbol _init for RISC-V compilation
The sandbox does not build on RISC-V when _init is not defined. Errors like the following were observed. Which function was referred to depended on the configuration.
/usr/bin/ld: common/built-in.o: in function `parse_stream_outer': /common/cli_hush.c:3175: undefined reference to `_init' collect2: error: ld returned 1 exit status make: *** [Makefile:1726: u-boot] Error 1
/usr/bin/ld: common/built-in.o: in function `bootdelay_process': common/autoboot.c:335: undefined reference to `_init' collect2: error: ld returned 1 exit status make: *** [Makefile:1726: u-boot] Error 1
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/sandbox/cpu/u-boot.lds | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/sandbox/cpu/u-boot.lds b/arch/sandbox/cpu/u-boot.lds index a1f509c9ab..d9e7ffcea3 100644 --- a/arch/sandbox/cpu/u-boot.lds +++ b/arch/sandbox/cpu/u-boot.lds @@ -9,6 +9,8 @@ SECTIONS {
. = ALIGN(4); + /* RISC-V GCC wants this dummy symbol */ + _init = .; .u_boot_list : { KEEP(*(SORT(.u_boot_list*))); } -- 2.30.2
On Thu, May 13, 2021 at 10:46 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
/usr/bin/ld: common/built-in.o: in function `parse_stream_outer': /common/cli_hush.c:3175: undefined reference to `_init' collect2: error: ld returned 1 exit status make: *** [Makefile:1726: u-boot] Error 1 /usr/bin/ld: common/built-in.o: in function `bootdelay_process': common/autoboot.c:335: undefined reference to `_init' collect2: error: ld returned 1 exit status make: *** [Makefile:1726: u-boot] Error 1
. = ALIGN(4);
Native GCC on RISC-V?
RISC-V GCC sounds like cross-compile for RISC-V
Regards, Bin
. = ALIGN(4);
I was compiling natively on the BeagleV board. The same result can be observed in a chroot using qemu-riscv64-static.
chroot: gcc (Debian 11-20210327-1) 11.0.1 20210327 BeagleV: gcc (GCC) 10.3.1 20210422 (Red Hat 10.3.1-1)
Best regards
Heinrich
Regards, Bin
Hi Heinrich,
Is this a toolchain bug?
. = ALIGN(4);
-- 2.30.2
On Fri, May 14, 2021 at 7:56 AM Simon Glass sjg@chromium.org wrote:
Hi Heinrich,
+Jim who might know.
. = ALIGN(4);
Regards, Bin
In the ELF standard, .init sections were deprecated and replaced with .init_array sections in the early 1990s I think. It took some time for the toolchains to fully migrate from init to init_array, but by 2010 or so everyone was using init_array instead of init, with init support retained only for legacy code that hadn't been fixed to use init_array yet. Because RISC-V is a new target with no legacy code to support, we made the decision to drop support for the obsolete init section. Last I checked there are only two glibc targets that have no init section support, with the other one also being a new arch, like RISC-V. Same goes for the embedded target, so the RISC-V newlib port has no init section support also.
It sounds like you have some legacy user code that hasn't been fixed yet to use init_array instead of init. Or maybe it is a program loader that supports both? In which case it should be extended to not use init on new targets that no longer support it.
Init_array supports stack unwinding (aka C++ EH) and init doesn't, so init_array should always be preferred over init, unless you have a very old toolchain that lacks init_array support. Dropping init support from the RISC-V toolchain allows us to save some bytes of program code size, and save some cycles on program startup, which is good considering that this is a feature that we don't need anymore.
Jim
On 5/18/21 9:29 PM, Jim Wilson wrote:
On Thu, May 13, 2021 at 5:55 PM Bin Meng <bmeng.cn@gmail.com mailto:bmeng.cn@gmail.com> wrote:
On Fri, May 14, 2021 at 7:56 AM Simon Glass <sjg@chromium.org <mailto:sjg@chromium.org>> wrote: > On Thu, 13 May 2021 at 08:46, Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: > > /usr/bin/ld: common/built-in.o: in function `bootdelay_process': > > common/autoboot.c:335: undefined reference to `_init' > > collect2: error: ld returned 1 exit status > > make: *** [Makefile:1726: u-boot] Error 1
I am compiling the sandbox_defconfig target of upstream U-Boot with GCC 11. Please, indicate what "legacy user code" you are referring to.
Best regards
Heinrich
Jim
On Tue, May 18, 2021 at 1:58 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
I have no idea what that is. I'm not a uboot developer.
Jim
By "user code" I mean that it isn't toolchain code, as the toolchain doesn't use init.
Jim
Hi Jim,
Heinrich was using a GCC natively (not cross-compile) on a RISC-V board to build a "user code" and unfortunately it did not build.
Do you think this might be related to how GCC was configured for native RISC-V?
Regards, Bin
On 5/18/21 11:36 PM, Jim Wilson wrote:
On Tue, May 18, 2021 at 2:32 PM Jim Wilson <jimw@sifive.com mailto:jimw@sifive.com> wrote:
On Tue, May 18, 2021 at 1:58 PM Heinrich Schuchardt <xypron.glpk@gmx.de <mailto:xypron.glpk@gmx.de>> wrote: I am compiling the sandbox_defconfig target of upstream U-Boot with GCC 11. Please, indicate what "legacy user code" you are referring to. I have no idea what that is. I'm not a uboot developer.
Jim
This seems to be the culprit:
common/board_f.c:269: #elif defined(CONFIG_SANDBOX) || defined(CONFIG_EFI_APP) gd->mon_len = (ulong)&_end - (ulong)_init;
gd->mon_len is used here:
common/board_f.c:344 gd->ram_top = board_get_usable_ram_top(gd->mon_len);
@Simon: We don't relocate the sandbox code into the mmap'ed memory. Why should we use a nonzero value of gd->mon_len on the sandbox?
When compiling the sandbox on x86_64 u-boot.map has:
.init 0x0000000000031000 0x17 *(SORT_NONE(.init)) .init 0x0000000000031000 0x12 /usr/lib/gcc/x86_64-linux-gnu/11/../../../x86_64-linux-gnu/crti.o 0x0000000000031000 _init .init 0x0000000000031012 0x5 /usr/lib/gcc/x86_64-linux-gnu/11/../../../x86_64-linux-gnu/crtn.o
This relates to https://github.com/gcc-mirror/gcc/blob/master/libgcc/config/i386/crti.S
This file defines symbols _init and _fini.
For aarch64 we have:
https://github.com/gcc-mirror/gcc/blob/master/libgcc/config/aarch64/crti.S This file contains symbols _init and _fini, too.
For RISC-V we have:
https://github.com/gcc-mirror/gcc/blob/master/libgcc/config/riscv/crti.S
It contains only a comment /* crti.S is empty because .init_array/.fini_array are used exclusively. */
Symbols _init and _fini don't exist on RISC-V.
As the usage of _init is deprecated in GCC we should not use it in any U-Boot configuration, neither for SANDBOX nor for EFI_APP.
Best regards
Heinrich
On 5/14/21 1:56 AM, Simon Glass wrote:
Hi Heinrich,
Possibly. _init and _fini are obsolete in current GCC versions.
I saw this both with GCC 10 and GCC 11. So we should work around it.
I did not hit the problem when compiling a simple freestanding program for RISC-V with GCC.
Best regards
Heinrich
. = ALIGN(4);
-- 2.30.2
Bin Meng
Jim Wilson
