[PATCH v1 0/2] clk: rockchip: rk3568: add clock driver
Add basic clock for rk3568 which including cpu, bus, mmc, i2c, pwm, gmac ...clocks init.
Elaine Zhang (2): rockchip: rk3568: add device tree file rockchip: rk3568: add clock driver
.../include/asm/arch-rockchip/cru_rk3568.h | 504 +++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3568.c | 2908 +++++++++++++++++ include/dt-bindings/clock/rk3568-cru.h | 925 ++++++ 4 files changed, 4338 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3568.h create mode 100644 drivers/clk/rockchip/clk_rk3568.c create mode 100644 include/dt-bindings/clock/rk3568-cru.h
Add dts binding header for rk3568, files origin from kernel.
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- include/dt-bindings/clock/rk3568-cru.h | 925 +++++++++++++++++++++++++ 1 file changed, 925 insertions(+) create mode 100644 include/dt-bindings/clock/rk3568-cru.h
diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h new file mode 100644 index 000000000000..c1942422a438 --- /dev/null +++ b/include/dt-bindings/clock/rk3568-cru.h @@ -0,0 +1,925 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2021 Rockchip Electronics Co. Ltd. + * Author: Elaine Zhang zhangqing@rock-chips.com + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H + +/* pmucru-clocks indices */ + +/* pmucru plls */ +#define PLL_PPLL 1 +#define PLL_HPLL 2 + +/* pmucru clocks */ +#define XIN_OSC0_DIV 4 +#define CLK_RTC_32K 5 +#define CLK_PMU 6 +#define CLK_I2C0 7 +#define CLK_RTC32K_FRAC 8 +#define CLK_UART0_DIV 9 +#define CLK_UART0_FRAC 10 +#define SCLK_UART0 11 +#define DBCLK_GPIO0 12 +#define CLK_PWM0 13 +#define CLK_CAPTURE_PWM0_NDFT 14 +#define CLK_PMUPVTM 15 +#define CLK_CORE_PMUPVTM 16 +#define CLK_REF24M 17 +#define XIN_OSC0_USBPHY0_G 18 +#define CLK_USBPHY0_REF 19 +#define XIN_OSC0_USBPHY1_G 20 +#define CLK_USBPHY1_REF 21 +#define XIN_OSC0_MIPIDSIPHY0_G 22 +#define CLK_MIPIDSIPHY0_REF 23 +#define XIN_OSC0_MIPIDSIPHY1_G 24 +#define CLK_MIPIDSIPHY1_REF 25 +#define CLK_WIFI_DIV 26 +#define CLK_WIFI_OSC0 27 +#define CLK_WIFI 28 +#define CLK_PCIEPHY0_DIV 29 +#define CLK_PCIEPHY0_OSC0 30 +#define CLK_PCIEPHY0_REF 31 +#define CLK_PCIEPHY1_DIV 32 +#define CLK_PCIEPHY1_OSC0 33 +#define CLK_PCIEPHY1_REF 34 +#define CLK_PCIEPHY2_DIV 35 +#define CLK_PCIEPHY2_OSC0 36 +#define CLK_PCIEPHY2_REF 37 +#define CLK_PCIE30PHY_REF_M 38 +#define CLK_PCIE30PHY_REF_N 39 +#define CLK_HDMI_REF 40 +#define XIN_OSC0_EDPPHY_G 41 +#define PCLK_PDPMU 42 +#define PCLK_PMU 43 +#define PCLK_UART0 44 +#define PCLK_I2C0 45 +#define PCLK_GPIO0 46 +#define PCLK_PMUPVTM 47 +#define PCLK_PWM0 48 +#define CLK_PDPMU 49 +#define SCLK_32K_IOE 50 + +#define CLKPMU_NR_CLKS (SCLK_32K_IOE + 1) + +/* cru-clocks indices */ + +/* cru plls */ +#define PLL_APLL 1 +#define PLL_DPLL 2 +#define PLL_CPLL 3 +#define PLL_GPLL 4 +#define PLL_VPLL 5 +#define PLL_NPLL 6 + +/* cru clocks */ +#define CPLL_333M 9 +#define ARMCLK 10 +#define USB480M 11 +#define ACLK_CORE_NIU2BUS 18 +#define CLK_CORE_PVTM 19 +#define CLK_CORE_PVTM_CORE 20 +#define CLK_CORE_PVTPLL 21 +#define CLK_GPU_SRC 22 +#define CLK_GPU_PRE_NDFT 23 +#define CLK_GPU_PRE_MUX 24 +#define ACLK_GPU_PRE 25 +#define PCLK_GPU_PRE 26 +#define CLK_GPU 27 +#define CLK_GPU_NP5 28 +#define PCLK_GPU_PVTM 29 +#define CLK_GPU_PVTM 30 +#define CLK_GPU_PVTM_CORE 31 +#define CLK_GPU_PVTPLL 32 +#define CLK_NPU_SRC 33 +#define CLK_NPU_PRE_NDFT 34 +#define CLK_NPU 35 +#define CLK_NPU_NP5 36 +#define HCLK_NPU_PRE 37 +#define PCLK_NPU_PRE 38 +#define ACLK_NPU_PRE 39 +#define ACLK_NPU 40 +#define HCLK_NPU 41 +#define PCLK_NPU_PVTM 42 +#define CLK_NPU_PVTM 43 +#define CLK_NPU_PVTM_CORE 44 +#define CLK_NPU_PVTPLL 45 +#define CLK_DDRPHY1X_SRC 46 +#define CLK_DDRPHY1X_HWFFC_SRC 47 +#define CLK_DDR1X 48 +#define CLK_MSCH 49 +#define CLK24_DDRMON 50 +#define ACLK_GIC_AUDIO 51 +#define HCLK_GIC_AUDIO 52 +#define HCLK_SDMMC_BUFFER 53 +#define DCLK_SDMMC_BUFFER 54 +#define ACLK_GIC600 55 +#define ACLK_SPINLOCK 56 +#define HCLK_I2S0_8CH 57 +#define HCLK_I2S1_8CH 58 +#define HCLK_I2S2_2CH 59 +#define HCLK_I2S3_2CH 60 +#define CLK_I2S0_8CH_TX_SRC 61 +#define CLK_I2S0_8CH_TX_FRAC 62 +#define MCLK_I2S0_8CH_TX 63 +#define I2S0_MCLKOUT_TX 64 +#define CLK_I2S0_8CH_RX_SRC 65 +#define CLK_I2S0_8CH_RX_FRAC 66 +#define MCLK_I2S0_8CH_RX 67 +#define I2S0_MCLKOUT_RX 68 +#define CLK_I2S1_8CH_TX_SRC 69 +#define CLK_I2S1_8CH_TX_FRAC 70 +#define MCLK_I2S1_8CH_TX 71 +#define I2S1_MCLKOUT_TX 72 +#define CLK_I2S1_8CH_RX_SRC 73 +#define CLK_I2S1_8CH_RX_FRAC 74 +#define MCLK_I2S1_8CH_RX 75 +#define I2S1_MCLKOUT_RX 76 +#define CLK_I2S2_2CH_SRC 77 +#define CLK_I2S2_2CH_FRAC 78 +#define MCLK_I2S2_2CH 79 +#define I2S2_MCLKOUT 80 +#define CLK_I2S3_2CH_TX_SRC 81 +#define CLK_I2S3_2CH_TX_FRAC 82 +#define MCLK_I2S3_2CH_TX 83 +#define I2S3_MCLKOUT_TX 84 +#define CLK_I2S3_2CH_RX_SRC 85 +#define CLK_I2S3_2CH_RX_FRAC 86 +#define MCLK_I2S3_2CH_RX 87 +#define I2S3_MCLKOUT_RX 88 +#define HCLK_PDM 89 +#define MCLK_PDM 90 +#define HCLK_VAD 91 +#define HCLK_SPDIF_8CH 92 +#define MCLK_SPDIF_8CH_SRC 93 +#define MCLK_SPDIF_8CH_FRAC 94 +#define MCLK_SPDIF_8CH 95 +#define HCLK_AUDPWM 96 +#define SCLK_AUDPWM_SRC 97 +#define SCLK_AUDPWM_FRAC 98 +#define SCLK_AUDPWM 99 +#define HCLK_ACDCDIG 100 +#define CLK_ACDCDIG_I2C 101 +#define CLK_ACDCDIG_DAC 102 +#define CLK_ACDCDIG_ADC 103 +#define ACLK_SECURE_FLASH 104 +#define HCLK_SECURE_FLASH 105 +#define ACLK_CRYPTO_NS 106 +#define HCLK_CRYPTO_NS 107 +#define CLK_CRYPTO_NS_CORE 108 +#define CLK_CRYPTO_NS_PKA 109 +#define CLK_CRYPTO_NS_RNG 110 +#define HCLK_TRNG_NS 111 +#define CLK_TRNG_NS 112 +#define PCLK_OTPC_NS 113 +#define CLK_OTPC_NS_SBPI 114 +#define CLK_OTPC_NS_USR 115 +#define HCLK_NANDC 116 +#define NCLK_NANDC 117 +#define HCLK_SFC 118 +#define HCLK_SFC_XIP 119 +#define SCLK_SFC 120 +#define ACLK_EMMC 121 +#define HCLK_EMMC 122 +#define BCLK_EMMC 123 +#define CCLK_EMMC 124 +#define TCLK_EMMC 125 +#define ACLK_PIPE 126 +#define PCLK_PIPE 127 +#define PCLK_PIPE_GRF 128 +#define ACLK_PCIE20_MST 129 +#define ACLK_PCIE20_SLV 130 +#define ACLK_PCIE20_DBI 131 +#define PCLK_PCIE20 132 +#define CLK_PCIE20_AUX_NDFT 133 +#define CLK_PCIE20_AUX_DFT 134 +#define CLK_PCIE20_PIPE_DFT 135 +#define ACLK_PCIE30X1_MST 136 +#define ACLK_PCIE30X1_SLV 137 +#define ACLK_PCIE30X1_DBI 138 +#define PCLK_PCIE30X1 139 +#define CLK_PCIE30X1_AUX_NDFT 140 +#define CLK_PCIE30X1_AUX_DFT 141 +#define CLK_PCIE30X1_PIPE_DFT 142 +#define ACLK_PCIE30X2_MST 143 +#define ACLK_PCIE30X2_SLV 144 +#define ACLK_PCIE30X2_DBI 145 +#define PCLK_PCIE30X2 146 +#define CLK_PCIE30X2_AUX_NDFT 147 +#define CLK_PCIE30X2_AUX_DFT 148 +#define CLK_PCIE30X2_PIPE_DFT 149 +#define ACLK_SATA0 150 +#define CLK_SATA0_PMALIVE 151 +#define CLK_SATA0_RXOOB 152 +#define CLK_SATA0_PIPE_NDFT 153 +#define CLK_SATA0_PIPE_DFT 154 +#define ACLK_SATA1 155 +#define CLK_SATA1_PMALIVE 156 +#define CLK_SATA1_RXOOB 157 +#define CLK_SATA1_PIPE_NDFT 158 +#define CLK_SATA1_PIPE_DFT 159 +#define ACLK_SATA2 160 +#define CLK_SATA2_PMALIVE 161 +#define CLK_SATA2_RXOOB 162 +#define CLK_SATA2_PIPE_NDFT 163 +#define CLK_SATA2_PIPE_DFT 164 +#define ACLK_USB3OTG0 165 +#define CLK_USB3OTG0_REF 166 +#define CLK_USB3OTG0_SUSPEND 167 +#define ACLK_USB3OTG1 168 +#define CLK_USB3OTG1_REF 169 +#define CLK_USB3OTG1_SUSPEND 170 +#define CLK_XPCS_EEE 171 +#define PCLK_XPCS 172 +#define ACLK_PHP 173 +#define HCLK_PHP 174 +#define PCLK_PHP 175 +#define HCLK_SDMMC0 176 +#define CLK_SDMMC0 177 +#define HCLK_SDMMC1 178 +#define CLK_SDMMC1 179 +#define ACLK_GMAC0 180 +#define PCLK_GMAC0 181 +#define CLK_MAC0_2TOP 182 +#define CLK_MAC0_OUT 183 +#define CLK_MAC0_REFOUT 184 +#define CLK_GMAC0_PTP_REF 185 +#define ACLK_USB 186 +#define HCLK_USB 187 +#define PCLK_USB 188 +#define HCLK_USB2HOST0 189 +#define HCLK_USB2HOST0_ARB 190 +#define HCLK_USB2HOST1 191 +#define HCLK_USB2HOST1_ARB 192 +#define HCLK_SDMMC2 193 +#define CLK_SDMMC2 194 +#define ACLK_GMAC1 195 +#define PCLK_GMAC1 196 +#define CLK_MAC1_2TOP 197 +#define CLK_MAC1_OUT 198 +#define CLK_MAC1_REFOUT 199 +#define CLK_GMAC1_PTP_REF 200 +#define ACLK_PERIMID 201 +#define HCLK_PERIMID 202 +#define ACLK_VI 203 +#define HCLK_VI 204 +#define PCLK_VI 205 +#define ACLK_VICAP 206 +#define HCLK_VICAP 207 +#define DCLK_VICAP 208 +#define ICLK_VICAP_G 209 +#define ACLK_ISP 210 +#define HCLK_ISP 211 +#define CLK_ISP 212 +#define PCLK_CSI2HOST1 213 +#define CLK_CIF_OUT 214 +#define CLK_CAM0_OUT 215 +#define CLK_CAM1_OUT 216 +#define ACLK_VO 217 +#define HCLK_VO 218 +#define PCLK_VO 219 +#define ACLK_VOP_PRE 220 +#define ACLK_VOP 221 +#define HCLK_VOP 222 +#define DCLK_VOP0 223 +#define DCLK_VOP1 224 +#define DCLK_VOP2 225 +#define CLK_VOP_PWM 226 +#define ACLK_HDCP 227 +#define HCLK_HDCP 228 +#define PCLK_HDCP 229 +#define PCLK_HDMI_HOST 230 +#define CLK_HDMI_SFR 231 +#define PCLK_DSITX_0 232 +#define PCLK_DSITX_1 233 +#define PCLK_EDP_CTRL 234 +#define CLK_EDP_200M 235 +#define ACLK_VPU_PRE 236 +#define HCLK_VPU_PRE 237 +#define ACLK_VPU 238 +#define HCLK_VPU 239 +#define ACLK_RGA_PRE 240 +#define HCLK_RGA_PRE 241 +#define PCLK_RGA_PRE 242 +#define ACLK_RGA 243 +#define HCLK_RGA 244 +#define CLK_RGA_CORE 245 +#define ACLK_IEP 246 +#define HCLK_IEP 247 +#define CLK_IEP_CORE 248 +#define HCLK_EBC 249 +#define DCLK_EBC 250 +#define ACLK_JDEC 251 +#define HCLK_JDEC 252 +#define ACLK_JENC 253 +#define HCLK_JENC 254 +#define PCLK_EINK 255 +#define HCLK_EINK 256 +#define ACLK_RKVENC_PRE 257 +#define HCLK_RKVENC_PRE 258 +#define ACLK_RKVENC 259 +#define HCLK_RKVENC 260 +#define CLK_RKVENC_CORE 261 +#define ACLK_RKVDEC_PRE 262 +#define HCLK_RKVDEC_PRE 263 +#define ACLK_RKVDEC 264 +#define HCLK_RKVDEC 265 +#define CLK_RKVDEC_CA 266 +#define CLK_RKVDEC_CORE 267 +#define CLK_RKVDEC_HEVC_CA 268 +#define ACLK_BUS 269 +#define PCLK_BUS 270 +#define PCLK_TSADC 271 +#define CLK_TSADC_TSEN 272 +#define CLK_TSADC 273 +#define PCLK_SARADC 274 +#define CLK_SARADC 275 +#define PCLK_SCR 276 +#define PCLK_WDT_NS 277 +#define TCLK_WDT_NS 278 +#define ACLK_DMAC0 279 +#define ACLK_DMAC1 280 +#define ACLK_MCU 281 +#define PCLK_INTMUX 282 +#define PCLK_MAILBOX 283 +#define PCLK_UART1 284 +#define CLK_UART1_SRC 285 +#define CLK_UART1_FRAC 286 +#define SCLK_UART1 287 +#define PCLK_UART2 288 +#define CLK_UART2_SRC 289 +#define CLK_UART2_FRAC 290 +#define SCLK_UART2 291 +#define PCLK_UART3 292 +#define CLK_UART3_SRC 293 +#define CLK_UART3_FRAC 294 +#define SCLK_UART3 295 +#define PCLK_UART4 296 +#define CLK_UART4_SRC 297 +#define CLK_UART4_FRAC 298 +#define SCLK_UART4 299 +#define PCLK_UART5 300 +#define CLK_UART5_SRC 301 +#define CLK_UART5_FRAC 302 +#define SCLK_UART5 303 +#define PCLK_UART6 304 +#define CLK_UART6_SRC 305 +#define CLK_UART6_FRAC 306 +#define SCLK_UART6 307 +#define PCLK_UART7 308 +#define CLK_UART7_SRC 309 +#define CLK_UART7_FRAC 310 +#define SCLK_UART7 311 +#define PCLK_UART8 312 +#define CLK_UART8_SRC 313 +#define CLK_UART8_FRAC 314 +#define SCLK_UART8 315 +#define PCLK_UART9 316 +#define CLK_UART9_SRC 317 +#define CLK_UART9_FRAC 318 +#define SCLK_UART9 319 +#define PCLK_CAN0 320 +#define CLK_CAN0 321 +#define PCLK_CAN1 322 +#define CLK_CAN1 323 +#define PCLK_CAN2 324 +#define CLK_CAN2 325 +#define CLK_I2C 326 +#define PCLK_I2C1 327 +#define CLK_I2C1 328 +#define PCLK_I2C2 329 +#define CLK_I2C2 330 +#define PCLK_I2C3 331 +#define CLK_I2C3 332 +#define PCLK_I2C4 333 +#define CLK_I2C4 334 +#define PCLK_I2C5 335 +#define CLK_I2C5 336 +#define PCLK_SPI0 337 +#define CLK_SPI0 338 +#define PCLK_SPI1 339 +#define CLK_SPI1 340 +#define PCLK_SPI2 341 +#define CLK_SPI2 342 +#define PCLK_SPI3 343 +#define CLK_SPI3 344 +#define PCLK_PWM1 345 +#define CLK_PWM1 346 +#define CLK_PWM1_CAPTURE 347 +#define PCLK_PWM2 348 +#define CLK_PWM2 349 +#define CLK_PWM2_CAPTURE 350 +#define PCLK_PWM3 351 +#define CLK_PWM3 352 +#define CLK_PWM3_CAPTURE 353 +#define DBCLK_GPIO 354 +#define PCLK_GPIO1 355 +#define DBCLK_GPIO1 356 +#define PCLK_GPIO2 357 +#define DBCLK_GPIO2 358 +#define PCLK_GPIO3 359 +#define DBCLK_GPIO3 360 +#define PCLK_GPIO4 361 +#define DBCLK_GPIO4 362 +#define OCC_SCAN_CLK_GPIO 363 +#define PCLK_TIMER 364 +#define CLK_TIMER0 365 +#define CLK_TIMER1 366 +#define CLK_TIMER2 367 +#define CLK_TIMER3 368 +#define CLK_TIMER4 369 +#define CLK_TIMER5 370 +#define ACLK_TOP_HIGH 371 +#define ACLK_TOP_LOW 372 +#define HCLK_TOP 373 +#define PCLK_TOP 374 +#define PCLK_PCIE30PHY 375 +#define CLK_OPTC_ARB 376 +#define PCLK_MIPICSIPHY 377 +#define PCLK_MIPIDSIPHY0 378 +#define PCLK_MIPIDSIPHY1 379 +#define PCLK_PIPEPHY0 380 +#define PCLK_PIPEPHY1 381 +#define PCLK_PIPEPHY2 382 +#define PCLK_CPU_BOOST 383 +#define CLK_CPU_BOOST 384 +#define PCLK_OTPPHY 385 +#define SCLK_GMAC0 386 +#define SCLK_GMAC0_RGMII_SPEED 387 +#define SCLK_GMAC0_RMII_SPEED 388 +#define SCLK_GMAC0_RX_TX 389 +#define SCLK_GMAC1 390 +#define SCLK_GMAC1_RGMII_SPEED 391 +#define SCLK_GMAC1_RMII_SPEED 392 +#define SCLK_GMAC1_RX_TX 393 +#define SCLK_SDMMC0_DRV 394 +#define SCLK_SDMMC0_SAMPLE 395 +#define SCLK_SDMMC1_DRV 396 +#define SCLK_SDMMC1_SAMPLE 397 +#define SCLK_SDMMC2_DRV 398 +#define SCLK_SDMMC2_SAMPLE 399 +#define SCLK_EMMC_DRV 400 +#define SCLK_EMMC_SAMPLE 401 +#define PCLK_EDPPHY_GRF 402 +#define CLK_HDMI_CEC 403 +#define CLK_I2S0_8CH_TX 404 +#define CLK_I2S0_8CH_RX 405 +#define CLK_I2S1_8CH_TX 406 +#define CLK_I2S1_8CH_RX 407 +#define CLK_I2S2_2CH 408 +#define CLK_I2S3_2CH_TX 409 +#define CLK_I2S3_2CH_RX 410 +#define CPLL_500M 411 +#define CPLL_250M 412 +#define CPLL_125M 413 +#define CPLL_62P5M 414 +#define CPLL_50M 415 +#define CPLL_25M 416 +#define CPLL_100M 417 + +#define PCLK_CORE_PVTM 450 + +#define CLK_NR_CLKS (PCLK_CORE_PVTM + 1) + +/* pmu soft-reset indices */ +/* pmucru_softrst_con0 */ +#define SRST_P_PDPMU_NIU 0 +#define SRST_P_PMUCRU 1 +#define SRST_P_PMUGRF 2 +#define SRST_P_I2C0 3 +#define SRST_I2C0 4 +#define SRST_P_UART0 5 +#define SRST_S_UART0 6 +#define SRST_P_PWM0 7 +#define SRST_PWM0 8 +#define SRST_P_GPIO0 9 +#define SRST_GPIO0 10 +#define SRST_P_PMUPVTM 11 +#define SRST_PMUPVTM 12 + +/* soft-reset indices */ + +/* cru_softrst_con0 */ +#define SRST_NCORERESET0 0 +#define SRST_NCORERESET1 1 +#define SRST_NCORERESET2 2 +#define SRST_NCORERESET3 3 +#define SRST_NCPUPORESET0 4 +#define SRST_NCPUPORESET1 5 +#define SRST_NCPUPORESET2 6 +#define SRST_NCPUPORESET3 7 +#define SRST_NSRESET 8 +#define SRST_NSPORESET 9 +#define SRST_NATRESET 10 +#define SRST_NGICRESET 11 +#define SRST_NPRESET 12 +#define SRST_NPERIPHRESET 13 + +/* cru_softrst_con1 */ +#define SRST_A_CORE_NIU2DDR 16 +#define SRST_A_CORE_NIU2BUS 17 +#define SRST_P_DBG_NIU 18 +#define SRST_P_DBG 19 +#define SRST_P_DBG_DAPLITE 20 +#define SRST_DAP 21 +#define SRST_A_ADB400_CORE2GIC 22 +#define SRST_A_ADB400_GIC2CORE 23 +#define SRST_P_CORE_GRF 24 +#define SRST_P_CORE_PVTM 25 +#define SRST_CORE_PVTM 26 +#define SRST_CORE_PVTPLL 27 + +/* cru_softrst_con2 */ +#define SRST_GPU 32 +#define SRST_A_GPU_NIU 33 +#define SRST_P_GPU_NIU 34 +#define SRST_P_GPU_PVTM 35 +#define SRST_GPU_PVTM 36 +#define SRST_GPU_PVTPLL 37 +#define SRST_A_NPU_NIU 40 +#define SRST_H_NPU_NIU 41 +#define SRST_P_NPU_NIU 42 +#define SRST_A_NPU 43 +#define SRST_H_NPU 44 +#define SRST_P_NPU_PVTM 45 +#define SRST_NPU_PVTM 46 +#define SRST_NPU_PVTPLL 47 + +/* cru_softrst_con3 */ +#define SRST_A_MSCH 51 +#define SRST_HWFFC_CTRL 52 +#define SRST_DDR_ALWAYSON 53 +#define SRST_A_DDRSPLIT 54 +#define SRST_DDRDFI_CTL 55 +#define SRST_A_DMA2DDR 57 + +/* cru_softrst_con4 */ +#define SRST_A_PERIMID_NIU 64 +#define SRST_H_PERIMID_NIU 65 +#define SRST_A_GIC_AUDIO_NIU 66 +#define SRST_H_GIC_AUDIO_NIU 67 +#define SRST_A_GIC600 68 +#define SRST_A_GIC600_DEBUG 69 +#define SRST_A_GICADB_CORE2GIC 70 +#define SRST_A_GICADB_GIC2CORE 71 +#define SRST_A_SPINLOCK 72 +#define SRST_H_SDMMC_BUFFER 73 +#define SRST_D_SDMMC_BUFFER 74 +#define SRST_H_I2S0_8CH 75 +#define SRST_H_I2S1_8CH 76 +#define SRST_H_I2S2_2CH 77 +#define SRST_H_I2S3_2CH 78 + +/* cru_softrst_con5 */ +#define SRST_M_I2S0_8CH_TX 80 +#define SRST_M_I2S0_8CH_RX 81 +#define SRST_M_I2S1_8CH_TX 82 +#define SRST_M_I2S1_8CH_RX 83 +#define SRST_M_I2S2_2CH 84 +#define SRST_M_I2S3_2CH_TX 85 +#define SRST_M_I2S3_2CH_RX 86 +#define SRST_H_PDM 87 +#define SRST_M_PDM 88 +#define SRST_H_VAD 89 +#define SRST_H_SPDIF_8CH 90 +#define SRST_M_SPDIF_8CH 91 +#define SRST_H_AUDPWM 92 +#define SRST_S_AUDPWM 93 +#define SRST_H_ACDCDIG 94 +#define SRST_ACDCDIG 95 + +/* cru_softrst_con6 */ +#define SRST_A_SECURE_FLASH_NIU 96 +#define SRST_H_SECURE_FLASH_NIU 97 +#define SRST_A_CRYPTO_NS 103 +#define SRST_H_CRYPTO_NS 104 +#define SRST_CRYPTO_NS_CORE 105 +#define SRST_CRYPTO_NS_PKA 106 +#define SRST_CRYPTO_NS_RNG 107 +#define SRST_H_TRNG_NS 108 +#define SRST_TRNG_NS 109 + +/* cru_softrst_con7 */ +#define SRST_H_NANDC 112 +#define SRST_N_NANDC 113 +#define SRST_H_SFC 114 +#define SRST_H_SFC_XIP 115 +#define SRST_S_SFC 116 +#define SRST_A_EMMC 117 +#define SRST_H_EMMC 118 +#define SRST_B_EMMC 119 +#define SRST_C_EMMC 120 +#define SRST_T_EMMC 121 + +/* cru_softrst_con8 */ +#define SRST_A_PIPE_NIU 128 +#define SRST_P_PIPE_NIU 130 +#define SRST_P_PIPE_GRF 133 +#define SRST_A_SATA0 134 +#define SRST_SATA0_PIPE 135 +#define SRST_SATA0_PMALIVE 136 +#define SRST_SATA0_RXOOB 137 +#define SRST_A_SATA1 138 +#define SRST_SATA1_PIPE 139 +#define SRST_SATA1_PMALIVE 140 +#define SRST_SATA1_RXOOB 141 + +/* cru_softrst_con9 */ +#define SRST_A_SATA2 144 +#define SRST_SATA2_PIPE 145 +#define SRST_SATA2_PMALIVE 146 +#define SRST_SATA2_RXOOB 147 +#define SRST_USB3OTG0 148 +#define SRST_USB3OTG1 149 +#define SRST_XPCS 150 +#define SRST_XPCS_TX_DIV10 151 +#define SRST_XPCS_RX_DIV10 152 +#define SRST_XPCS_XGXS_RX 153 + +/* cru_softrst_con10 */ +#define SRST_P_PCIE20 160 +#define SRST_PCIE20_POWERUP 161 +#define SRST_MSTR_ARESET_PCIE20 162 +#define SRST_SLV_ARESET_PCIE20 163 +#define SRST_DBI_ARESET_PCIE20 164 +#define SRST_BRESET_PCIE20 165 +#define SRST_PERST_PCIE20 166 +#define SRST_CORE_RST_PCIE20 167 +#define SRST_NSTICKY_RST_PCIE20 168 +#define SRST_STICKY_RST_PCIE20 169 +#define SRST_PWR_RST_PCIE20 170 + +/* cru_softrst_con11 */ +#define SRST_P_PCIE30X1 176 +#define SRST_PCIE30X1_POWERUP 177 +#define SRST_M_ARESET_PCIE30X1 178 +#define SRST_S_ARESET_PCIE30X1 179 +#define SRST_D_ARESET_PCIE30X1 180 +#define SRST_BRESET_PCIE30X1 181 +#define SRST_PERST_PCIE30X1 182 +#define SRST_CORE_RST_PCIE30X1 183 +#define SRST_NSTC_RST_PCIE30X1 184 +#define SRST_STC_RST_PCIE30X1 185 +#define SRST_PWR_RST_PCIE30X1 186 + +/* cru_softrst_con12 */ +#define SRST_P_PCIE30X2 192 +#define SRST_PCIE30X2_POWERUP 193 +#define SRST_M_ARESET_PCIE30X2 194 +#define SRST_S_ARESET_PCIE30X2 195 +#define SRST_D_ARESET_PCIE30X2 196 +#define SRST_BRESET_PCIE30X2 197 +#define SRST_PERST_PCIE30X2 198 +#define SRST_CORE_RST_PCIE30X2 199 +#define SRST_NSTC_RST_PCIE30X2 200 +#define SRST_STC_RST_PCIE30X2 201 +#define SRST_PWR_RST_PCIE30X2 202 + +/* cru_softrst_con13 */ +#define SRST_A_PHP_NIU 208 +#define SRST_H_PHP_NIU 209 +#define SRST_P_PHP_NIU 210 +#define SRST_H_SDMMC0 211 +#define SRST_SDMMC0 212 +#define SRST_H_SDMMC1 213 +#define SRST_SDMMC1 214 +#define SRST_A_GMAC0 215 +#define SRST_GMAC0_TIMESTAMP 216 + +/* cru_softrst_con14 */ +#define SRST_A_USB_NIU 224 +#define SRST_H_USB_NIU 225 +#define SRST_P_USB_NIU 226 +#define SRST_P_USB_GRF 227 +#define SRST_H_USB2HOST0 228 +#define SRST_H_USB2HOST0_ARB 229 +#define SRST_USB2HOST0_UTMI 230 +#define SRST_H_USB2HOST1 231 +#define SRST_H_USB2HOST1_ARB 232 +#define SRST_USB2HOST1_UTMI 233 +#define SRST_H_SDMMC2 234 +#define SRST_SDMMC2 235 +#define SRST_A_GMAC1 236 +#define SRST_GMAC1_TIMESTAMP 237 + +/* cru_softrst_con15 */ +#define SRST_A_VI_NIU 240 +#define SRST_H_VI_NIU 241 +#define SRST_P_VI_NIU 242 +#define SRST_A_VICAP 247 +#define SRST_H_VICAP 248 +#define SRST_D_VICAP 249 +#define SRST_I_VICAP 250 +#define SRST_P_VICAP 251 +#define SRST_H_ISP 252 +#define SRST_ISP 253 +#define SRST_P_CSI2HOST1 255 + +/* cru_softrst_con16 */ +#define SRST_A_VO_NIU 256 +#define SRST_H_VO_NIU 257 +#define SRST_P_VO_NIU 258 +#define SRST_A_VOP_NIU 259 +#define SRST_A_VOP 260 +#define SRST_H_VOP 261 +#define SRST_VOP0 262 +#define SRST_VOP1 263 +#define SRST_VOP2 264 +#define SRST_VOP_PWM 265 +#define SRST_A_HDCP 266 +#define SRST_H_HDCP 267 +#define SRST_P_HDCP 268 +#define SRST_P_HDMI_HOST 270 +#define SRST_HDMI_HOST 271 + +/* cru_softrst_con17 */ +#define SRST_P_DSITX_0 272 +#define SRST_P_DSITX_1 273 +#define SRST_P_EDP_CTRL 274 +#define SRST_EDP_24M 275 +#define SRST_A_VPU_NIU 280 +#define SRST_H_VPU_NIU 281 +#define SRST_A_VPU 282 +#define SRST_H_VPU 283 +#define SRST_H_EINK 286 +#define SRST_P_EINK 287 + +/* cru_softrst_con18 */ +#define SRST_A_RGA_NIU 288 +#define SRST_H_RGA_NIU 289 +#define SRST_P_RGA_NIU 290 +#define SRST_A_RGA 292 +#define SRST_H_RGA 293 +#define SRST_RGA_CORE 294 +#define SRST_A_IEP 295 +#define SRST_H_IEP 296 +#define SRST_IEP_CORE 297 +#define SRST_H_EBC 298 +#define SRST_D_EBC 299 +#define SRST_A_JDEC 300 +#define SRST_H_JDEC 301 +#define SRST_A_JENC 302 +#define SRST_H_JENC 303 + +/* cru_softrst_con19 */ +#define SRST_A_VENC_NIU 304 +#define SRST_H_VENC_NIU 305 +#define SRST_A_RKVENC 307 +#define SRST_H_RKVENC 308 +#define SRST_RKVENC_CORE 309 + +/* cru_softrst_con20 */ +#define SRST_A_RKVDEC_NIU 320 +#define SRST_H_RKVDEC_NIU 321 +#define SRST_A_RKVDEC 322 +#define SRST_H_RKVDEC 323 +#define SRST_RKVDEC_CA 324 +#define SRST_RKVDEC_CORE 325 +#define SRST_RKVDEC_HEVC_CA 326 + +/* cru_softrst_con21 */ +#define SRST_A_BUS_NIU 336 +#define SRST_P_BUS_NIU 338 +#define SRST_P_CAN0 340 +#define SRST_CAN0 341 +#define SRST_P_CAN1 342 +#define SRST_CAN1 343 +#define SRST_P_CAN2 344 +#define SRST_CAN2 345 +#define SRST_P_GPIO1 346 +#define SRST_GPIO1 347 +#define SRST_P_GPIO2 348 +#define SRST_GPIO2 349 +#define SRST_P_GPIO3 350 +#define SRST_GPIO3 351 + +/* cru_softrst_con22 */ +#define SRST_P_GPIO4 352 +#define SRST_GPIO4 353 +#define SRST_P_I2C1 354 +#define SRST_I2C1 355 +#define SRST_P_I2C2 356 +#define SRST_I2C2 357 +#define SRST_P_I2C3 358 +#define SRST_I2C3 359 +#define SRST_P_I2C4 360 +#define SRST_I2C4 361 +#define SRST_P_I2C5 362 +#define SRST_I2C5 363 +#define SRST_P_OTPC_NS 364 +#define SRST_OTPC_NS_SBPI 365 +#define SRST_OTPC_NS_USR 366 + +/* cru_softrst_con23 */ +#define SRST_P_PWM1 368 +#define SRST_PWM1 369 +#define SRST_P_PWM2 370 +#define SRST_PWM2 371 +#define SRST_P_PWM3 372 +#define SRST_PWM3 373 +#define SRST_P_SPI0 374 +#define SRST_SPI0 375 +#define SRST_P_SPI1 376 +#define SRST_SPI1 377 +#define SRST_P_SPI2 378 +#define SRST_SPI2 379 +#define SRST_P_SPI3 380 +#define SRST_SPI3 381 + +/* cru_softrst_con24 */ +#define SRST_P_SARADC 384 +#define SRST_P_TSADC 385 +#define SRST_TSADC 386 +#define SRST_P_TIMER 387 +#define SRST_TIMER0 388 +#define SRST_TIMER1 389 +#define SRST_TIMER2 390 +#define SRST_TIMER3 391 +#define SRST_TIMER4 392 +#define SRST_TIMER5 393 +#define SRST_P_UART1 394 +#define SRST_S_UART1 395 + +/* cru_softrst_con25 */ +#define SRST_P_UART2 400 +#define SRST_S_UART2 401 +#define SRST_P_UART3 402 +#define SRST_S_UART3 403 +#define SRST_P_UART4 404 +#define SRST_S_UART4 405 +#define SRST_P_UART5 406 +#define SRST_S_UART5 407 +#define SRST_P_UART6 408 +#define SRST_S_UART6 409 +#define SRST_P_UART7 410 +#define SRST_S_UART7 411 +#define SRST_P_UART8 412 +#define SRST_S_UART8 413 +#define SRST_P_UART9 414 +#define SRST_S_UART9 415 + +/* cru_softrst_con26 */ +#define SRST_P_GRF 416 +#define SRST_P_GRF_VCCIO12 417 +#define SRST_P_GRF_VCCIO34 418 +#define SRST_P_GRF_VCCIO567 419 +#define SRST_P_SCR 420 +#define SRST_P_WDT_NS 421 +#define SRST_T_WDT_NS 422 +#define SRST_P_DFT2APB 423 +#define SRST_A_MCU 426 +#define SRST_P_INTMUX 427 +#define SRST_P_MAILBOX 428 + +/* cru_softrst_con27 */ +#define SRST_A_TOP_HIGH_NIU 432 +#define SRST_A_TOP_LOW_NIU 433 +#define SRST_H_TOP_NIU 434 +#define SRST_P_TOP_NIU 435 +#define SRST_P_TOP_CRU 438 +#define SRST_P_DDRPHY 439 +#define SRST_DDRPHY 440 +#define SRST_P_MIPICSIPHY 442 +#define SRST_P_MIPIDSIPHY0 443 +#define SRST_P_MIPIDSIPHY1 444 +#define SRST_P_PCIE30PHY 445 +#define SRST_PCIE30PHY 446 +#define SRST_P_PCIE30PHY_GRF 447 + +/* cru_softrst_con28 */ +#define SRST_P_APB2ASB_LEFT 448 +#define SRST_P_APB2ASB_BOTTOM 449 +#define SRST_P_ASB2APB_LEFT 450 +#define SRST_P_ASB2APB_BOTTOM 451 +#define SRST_P_PIPEPHY0 452 +#define SRST_PIPEPHY0 453 +#define SRST_P_PIPEPHY1 454 +#define SRST_PIPEPHY1 455 +#define SRST_P_PIPEPHY2 456 +#define SRST_PIPEPHY2 457 +#define SRST_P_USB2PHY0_GRF 458 +#define SRST_P_USB2PHY1_GRF 459 +#define SRST_P_CPU_BOOST 460 +#define SRST_CPU_BOOST 461 +#define SRST_P_OTPPHY 462 +#define SRST_OTPPHY 463 + +/* cru_softrst_con29 */ +#define SRST_USB2PHY0_POR 464 +#define SRST_USB2PHY0_USB3OTG0 465 +#define SRST_USB2PHY0_USB3OTG1 466 +#define SRST_USB2PHY1_POR 467 +#define SRST_USB2PHY1_USB2HOST0 468 +#define SRST_USB2PHY1_USB2HOST1 469 +#define SRST_P_EDPPHY_GRF 470 +#define SRST_TSADCPHY 471 +#define SRST_GMAC0_DELAYLINE 472 +#define SRST_GMAC1_DELAYLINE 473 +#define SRST_OTPC_ARB 474 +#define SRST_P_PIPEPHY0_GRF 475 +#define SRST_P_PIPEPHY1_GRF 476 +#define SRST_P_PIPEPHY2_GRF 477 + +#endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks,
- Kever
- Copyright (c) 2021 Rockchip Electronics Co. Ltd.
- Author: Elaine Zhang zhangqing@rock-chips.com
Add rk3568 clock driver and cru structure definition.
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- .../include/asm/arch-rockchip/cru_rk3568.h | 504 +++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3568.c | 2908 +++++++++++++++++ 3 files changed, 3413 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3568.h create mode 100644 drivers/clk/rockchip/clk_rk3568.c
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h new file mode 100644 index 000000000000..6c59033f03a6 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h @@ -0,0 +1,504 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2021 Rockchip Electronics Co. Ltd. + * Author: Elaine Zhang zhangqing@rock-chips.com + */ + +#ifndef _ASM_ARCH_CRU_RK3568_H +#define _ASM_ARCH_CRU_RK3568_H + +#define MHz 1000000 +#define KHz 1000 +#define OSC_HZ (24 * MHz) + +#define APLL_HZ (816 * MHz) +#define GPLL_HZ (1188 * MHz) +#define CPLL_HZ (1000 * MHz) +#define PPLL_HZ (100 * MHz) + +/* RK3568 pll id */ +enum rk3568_pll_id { + APLL, + DPLL, + CPLL, + GPLL, + NPLL, + VPLL, + PPLL, + HPLL, + PLL_COUNT, +}; + +struct rk3568_clk_info { + unsigned long id; + char *name; + bool is_cru; +}; + +/* Private data for the clock driver - used by rockchip_get_cru() */ +struct rk3568_pmuclk_priv { + struct rk3568_pmucru *pmucru; + ulong ppll_hz; + ulong hpll_hz; +}; + +struct rk3568_clk_priv { + struct rk3568_cru *cru; + struct rk3568_grf *grf; + ulong ppll_hz; + ulong hpll_hz; + ulong gpll_hz; + ulong cpll_hz; + ulong npll_hz; + ulong vpll_hz; + ulong armclk_hz; + ulong armclk_enter_hz; + ulong armclk_init_hz; + bool sync_kernel; + bool set_armclk_rate; +}; + +struct rk3568_pll { + unsigned int con0; + unsigned int con1; + unsigned int con2; + unsigned int con3; + unsigned int con4; + unsigned int reserved0[3]; +}; + +struct rk3568_pmucru { + struct rk3568_pll pll[2];/* Address Offset: 0x0000 */ + unsigned int reserved0[16];/* Address Offset: 0x0040 */ + unsigned int mode_con00;/* Address Offset: 0x0080 */ + unsigned int reserved1[31];/* Address Offset: 0x0084 */ + unsigned int pmu_clksel_con[10];/* Address Offset: 0x0100 */ + unsigned int reserved2[22];/* Address Offset: 0x0128 */ + unsigned int pmu_clkgate_con[3];/* Address Offset: 0x0180 */ + unsigned int reserved3[29];/* Address Offset: 0x018C */ + unsigned int pmu_softrst_con[1];/* Address Offset: 0x0200 */ +}; + +check_member(rk3568_pmucru, mode_con00, 0x80); +check_member(rk3568_pmucru, pmu_softrst_con[0], 0x200); + +struct rk3568_cru { + struct rk3568_pll pll[6]; + unsigned int mode_con00;/* Address Offset: 0x00C0 */ + unsigned int misc_con[3];/* Address Offset: 0x00C4 */ + unsigned int glb_cnt_th;/* Address Offset: 0x00D0 */ + unsigned int glb_srst_fst;/* Address Offset: 0x00D4 */ + unsigned int glb_srsr_snd; /* Address Offset: 0x00D8 */ + unsigned int glb_rst_con;/* Address Offset: 0x00DC */ + unsigned int glb_rst_st;/* Address Offset: 0x00E0 */ + unsigned int reserved0[7];/* Address Offset: 0x00E4 */ + unsigned int clksel_con[85]; /* Address Offset: 0x0100 */ + unsigned int reserved1[43];/* Address Offset: 0x0254 */ + unsigned int clkgate_con[36];/* Address Offset: 0x0300 */ + unsigned int reserved2[28]; /* Address Offset: 0x0390 */ + unsigned int softrst_con[30];/* Address Offset: 0x0400 */ + unsigned int reserved3[2];/* Address Offset: 0x0478 */ + unsigned int ssgtbl[32];/* Address Offset: 0x0480 */ + unsigned int reserved4[32];/* Address Offset: 0x0500 */ + unsigned int sdmmc0_con[2];/* Address Offset: 0x0580 */ + unsigned int sdmmc1_con[2];/* Address Offset: 0x058C */ + unsigned int sdmmc2_con[2];/* Address Offset: 0x0590 */ + unsigned int emmc_con[2];/* Address Offset: 0x0598 */ +}; + +check_member(rk3568_cru, mode_con00, 0xc0); +check_member(rk3568_cru, softrst_con[0], 0x400); + +struct pll_rate_table { + unsigned long rate; + unsigned int fbdiv; + unsigned int postdiv1; + unsigned int refdiv; + unsigned int postdiv2; + unsigned int dsmpd; + unsigned int frac; +}; + +#define RK3568_PMU_MODE 0x80 +#define RK3568_PMU_PLL_CON(x) ((x) * 0x4) +#define RK3568_PLL_CON(x) ((x) * 0x4) +#define RK3568_MODE_CON 0xc0 + +enum { + /* CRU_PMU_CLK_SEL0_CON */ + RTC32K_SEL_SHIFT = 6, + RTC32K_SEL_MASK = 0x3 << RTC32K_SEL_SHIFT, + RTC32K_SEL_PMUPVTM = 0, + RTC32K_SEL_OSC1_32K, + RTC32K_SEL_OSC0_DIV32K, + + /* CRU_PMU_CLK_SEL1_CON */ + RTC32K_FRAC_NUMERATOR_SHIFT = 16, + RTC32K_FRAC_NUMERATOR_MASK = 0xffff << 16, + RTC32K_FRAC_DENOMINATOR_SHIFT = 0, + RTC32K_FRAC_DENOMINATOR_MASK = 0xffff, + + /* CRU_PMU_CLK_SEL2_CON */ + PCLK_PDPMU_SEL_SHIFT = 15, + PCLK_PDPMU_SEL_MASK = 1 << PCLK_PDPMU_SEL_SHIFT, + PCLK_PDPMU_SEL_PPLL = 0, + PCLK_PDPMU_SEL_GPLL, + PCLK_PDPMU_DIV_SHIFT = 0, + PCLK_PDPMU_DIV_MASK = 0x1f, + + /* CRU_PMU_CLK_SEL3_CON */ + CLK_I2C0_DIV_SHIFT = 0, + CLK_I2C0_DIV_MASK = 0x7f, + + /* CRU_PMU_CLK_SEL6_CON */ + CLK_PWM0_SEL_SHIFT = 7, + CLK_PWM0_SEL_MASK = 1 << CLK_PWM0_SEL_SHIFT, + CLK_PWM0_SEL_XIN24M = 0, + CLK_PWM0_SEL_PPLL, + CLK_PWM0_DIV_SHIFT = 0, + CLK_PWM0_DIV_MASK = 0x7f, + + /* CRU_CLK_SEL0_CON */ + CLK_CORE_PRE_SEL_SHIFT = 7, + CLK_CORE_PRE_SEL_MASK = 1 << CLK_CORE_PRE_SEL_SHIFT, + CLK_CORE_PRE_SEL_SRC = 0, + CLK_CORE_PRE_SEL_APLL, + + /* CRU_CLK_SEL2_CON */ + SCLK_CORE_PRE_SEL_SHIFT = 15, + SCLK_CORE_PRE_SEL_MASK = 1 << SCLK_CORE_PRE_SEL_SHIFT, + SCLK_CORE_PRE_SEL_SRC = 0, + SCLK_CORE_PRE_SEL_NPLL, + SCLK_CORE_SRC_SEL_SHIFT = 8, + SCLK_CORE_SRC_SEL_MASK = 3 << SCLK_CORE_SRC_SEL_SHIFT, + SCLK_CORE_SRC_SEL_APLL = 0, + SCLK_CORE_SRC_SEL_GPLL, + SCLK_CORE_SRC_SEL_NPLL, + SCLK_CORE_SRC_DIV_SHIFT = 0, + SCLK_CORE_SRC_DIV_MASK = 0x1f << SCLK_CORE_SRC_DIV_SHIFT, + + /* CRU_CLK_SEL3_CON */ + GICCLK_CORE_DIV_SHIFT = 8, + GICCLK_CORE_DIV_MASK = 0x1f << GICCLK_CORE_DIV_SHIFT, + ATCLK_CORE_DIV_SHIFT = 0, + ATCLK_CORE_DIV_MASK = 0x1f << ATCLK_CORE_DIV_SHIFT, + + /* CRU_CLK_SEL4_CON */ + PERIPHCLK_CORE_PRE_DIV_SHIFT = 8, + PERIPHCLK_CORE_PRE_DIV_MASK = 0x1f << PERIPHCLK_CORE_PRE_DIV_SHIFT, + PCLK_CORE_PRE_DIV_SHIFT = 0, + PCLK_CORE_PRE_DIV_MASK = 0x1f << PCLK_CORE_PRE_DIV_SHIFT, + + /* CRU_CLK_SEL5_CON */ + ACLK_CORE_NIU2BUS_SEL_SHIFT = 14, + ACLK_CORE_NIU2BUS_SEL_MASK = 0x3 << ACLK_CORE_NIU2BUS_SEL_SHIFT, + ACLK_CORE_NDFT_DIV_SHIFT = 8, + ACLK_CORE_NDFT_DIV_MASK = 0x1f << ACLK_CORE_NDFT_DIV_SHIFT, + + /* CRU_CLK_SEL10_CON */ + HCLK_PERIMID_SEL_SHIFT = 6, + HCLK_PERIMID_SEL_MASK = 3 << HCLK_PERIMID_SEL_SHIFT, + HCLK_PERIMID_SEL_150M = 0, + HCLK_PERIMID_SEL_100M, + HCLK_PERIMID_SEL_75M, + HCLK_PERIMID_SEL_24M, + ACLK_PERIMID_SEL_SHIFT = 4, + ACLK_PERIMID_SEL_MASK = 3 << ACLK_PERIMID_SEL_SHIFT, + ACLK_PERIMID_SEL_300M = 0, + ACLK_PERIMID_SEL_200M, + ACLK_PERIMID_SEL_100M, + ACLK_PERIMID_SEL_24M, + + /* CRU_CLK_SEL27_CON */ + CLK_CRYPTO_PKA_SEL_SHIFT = 6, + CLK_CRYPTO_PKA_SEL_MASK = 3 << CLK_CRYPTO_PKA_SEL_SHIFT, + CLK_CRYPTO_PKA_SEL_300M = 0, + CLK_CRYPTO_PKA_SEL_200M, + CLK_CRYPTO_PKA_SEL_100M, + CLK_CRYPTO_CORE_SEL_SHIFT = 4, + CLK_CRYPTO_CORE_SEL_MASK = 3 << CLK_CRYPTO_CORE_SEL_SHIFT, + CLK_CRYPTO_CORE_SEL_200M = 0, + CLK_CRYPTO_CORE_SEL_150M, + CLK_CRYPTO_CORE_SEL_100M, + HCLK_SECURE_FLASH_SEL_SHIFT = 2, + HCLK_SECURE_FLASH_SEL_MASK = 3 << HCLK_SECURE_FLASH_SEL_SHIFT, + HCLK_SECURE_FLASH_SEL_150M = 0, + HCLK_SECURE_FLASH_SEL_100M, + HCLK_SECURE_FLASH_SEL_75M, + HCLK_SECURE_FLASH_SEL_24M, + ACLK_SECURE_FLASH_SEL_SHIFT = 0, + ACLK_SECURE_FLASH_SEL_MASK = 3 << ACLK_SECURE_FLASH_SEL_SHIFT, + ACLK_SECURE_FLASH_SEL_200M = 0, + ACLK_SECURE_FLASH_SEL_150M, + ACLK_SECURE_FLASH_SEL_100M, + ACLK_SECURE_FLASH_SEL_24M, + + /* CRU_CLK_SEL28_CON */ + CCLK_EMMC_SEL_SHIFT = 12, + CCLK_EMMC_SEL_MASK = 7 << CCLK_EMMC_SEL_SHIFT, + CCLK_EMMC_SEL_24M = 0, + CCLK_EMMC_SEL_200M, + CCLK_EMMC_SEL_150M, + CCLK_EMMC_SEL_100M, + CCLK_EMMC_SEL_50M, + CCLK_EMMC_SEL_375K, + BCLK_EMMC_SEL_SHIFT = 8, + BCLK_EMMC_SEL_MASK = 3 << BCLK_EMMC_SEL_SHIFT, + BCLK_EMMC_SEL_200M = 0, + BCLK_EMMC_SEL_150M, + BCLK_EMMC_SEL_125M, + SCLK_SFC_SEL_SHIFT = 4, + SCLK_SFC_SEL_MASK = 7 << SCLK_SFC_SEL_SHIFT, + SCLK_SFC_SEL_24M = 0, + SCLK_SFC_SEL_50M, + SCLK_SFC_SEL_75M, + SCLK_SFC_SEL_100M, + SCLK_SFC_SEL_125M, + SCLK_SFC_SEL_150M, + NCLK_NANDC_SEL_SHIFT = 0, + NCLK_NANDC_SEL_MASK = 3 << NCLK_NANDC_SEL_SHIFT, + NCLK_NANDC_SEL_200M = 0, + NCLK_NANDC_SEL_150M, + NCLK_NANDC_SEL_100M, + NCLK_NANDC_SEL_24M, + + /* CRU_CLK_SEL30_CON */ + CLK_SDMMC1_SEL_SHIFT = 12, + CLK_SDMMC1_SEL_MASK = 7 << CLK_SDMMC1_SEL_SHIFT, + CLK_SDMMC0_SEL_SHIFT = 8, + CLK_SDMMC0_SEL_MASK = 7 << CLK_SDMMC0_SEL_SHIFT, + CLK_SDMMC_SEL_24M = 0, + CLK_SDMMC_SEL_400M, + CLK_SDMMC_SEL_300M, + CLK_SDMMC_SEL_100M, + CLK_SDMMC_SEL_50M, + CLK_SDMMC_SEL_750K, + + /* CRU_CLK_SEL31_CON */ + CLK_MAC0_OUT_SEL_SHIFT = 14, + CLK_MAC0_OUT_SEL_MASK = 3 << CLK_MAC0_OUT_SEL_SHIFT, + CLK_MAC0_OUT_SEL_125M = 0, + CLK_MAC0_OUT_SEL_50M, + CLK_MAC0_OUT_SEL_25M, + CLK_MAC0_OUT_SEL_24M, + CLK_GMAC0_PTP_REF_SEL_SHIFT = 12, + CLK_GMAC0_PTP_REF_SEL_MASK = 3 << CLK_GMAC0_PTP_REF_SEL_SHIFT, + CLK_GMAC0_PTP_REF_SEL_62_5M = 0, + CLK_GMAC0_PTP_REF_SEL_100M, + CLK_GMAC0_PTP_REF_SEL_50M, + CLK_GMAC0_PTP_REF_SEL_24M, + CLK_MAC0_2TOP_SEL_SHIFT = 8, + CLK_MAC0_2TOP_SEL_MASK = 3 << CLK_MAC0_2TOP_SEL_SHIFT, + CLK_MAC0_2TOP_SEL_125M = 0, + CLK_MAC0_2TOP_SEL_50M, + CLK_MAC0_2TOP_SEL_25M, + CLK_MAC0_2TOP_SEL_PPLL, + RGMII0_CLK_SEL_SHIFT = 4, + RGMII0_CLK_SEL_MASK = 3 << RGMII0_CLK_SEL_SHIFT, + RGMII0_CLK_SEL_125M = 0, + RGMII0_CLK_SEL_125M_1, + RGMII0_CLK_SEL_2_5M, + RGMII0_CLK_SEL_25M, + RMII0_CLK_SEL_SHIFT = 3, + RMII0_CLK_SEL_MASK = 1 << RMII0_CLK_SEL_SHIFT, + RMII0_CLK_SEL_2_5M = 0, + RMII0_CLK_SEL_25M, + RMII0_EXTCLK_SEL_SHIFT = 2, + RMII0_EXTCLK_SEL_MASK = 1 << RMII0_EXTCLK_SEL_SHIFT, + RMII0_EXTCLK_SEL_MAC0_TOP = 0, + RMII0_EXTCLK_SEL_IO, + RMII0_MODE_SHIFT = 0, + RMII0_MODE_MASK = 3 << RMII0_MODE_SHIFT, + RMII0_MODE_SEL_RGMII = 0, + RMII0_MODE_SEL_RMII, + RMII0_MODE_SEL_GMII, + + /* CRU_CLK_SEL32_CON */ + CLK_SDMMC2_SEL_SHIFT = 8, + CLK_SDMMC2_SEL_MASK = 7 << CLK_SDMMC2_SEL_SHIFT, + + /* CRU_CLK_SEL38_CON */ + ACLK_VOP_PRE_SEL_SHIFT = 6, + ACLK_VOP_PRE_SEL_MASK = 3 << ACLK_VOP_PRE_SEL_SHIFT, + ACLK_VOP_PRE_SEL_CPLL = 0, + ACLK_VOP_PRE_SEL_GPLL, + ACLK_VOP_PRE_SEL_HPLL, + ACLK_VOP_PRE_SEL_VPLL, + ACLK_VOP_PRE_DIV_SHIFT = 0, + ACLK_VOP_PRE_DIV_MASK = 0x1f << ACLK_VOP_PRE_DIV_SHIFT, + + /* CRU_CLK_SEL39_CON */ + DCLK0_VOP_SEL_SHIFT = 10, + DCLK0_VOP_SEL_MASK = 3 << DCLK0_VOP_SEL_SHIFT, + DCLK_VOP_SEL_HPLL = 0, + DCLK_VOP_SEL_VPLL, + DCLK_VOP_SEL_GPLL, + DCLK_VOP_SEL_CPLL, + DCLK0_VOP_DIV_SHIFT = 0, + DCLK0_VOP_DIV_MASK = 0xff << DCLK0_VOP_DIV_SHIFT, + + /* CRU_CLK_SEL40_CON */ + DCLK1_VOP_SEL_SHIFT = 10, + DCLK1_VOP_SEL_MASK = 3 << DCLK1_VOP_SEL_SHIFT, + DCLK1_VOP_DIV_SHIFT = 0, + DCLK1_VOP_DIV_MASK = 0xff << DCLK1_VOP_DIV_SHIFT, + + /* CRU_CLK_SEL41_CON */ + DCLK2_VOP_SEL_SHIFT = 10, + DCLK2_VOP_SEL_MASK = 3 << DCLK2_VOP_SEL_SHIFT, + DCLK2_VOP_DIV_SHIFT = 0, + DCLK2_VOP_DIV_MASK = 0xff << DCLK2_VOP_DIV_SHIFT, + + /* CRU_CLK_SEL43_CON */ + DCLK_EBC_SEL_SHIFT = 6, + DCLK_EBC_SEL_MASK = 3 << DCLK_EBC_SEL_SHIFT, + DCLK_EBC_SEL_GPLL_400M = 0, + DCLK_EBC_SEL_CPLL_333M, + DCLK_EBC_SEL_GPLL_200M, + + /* CRU_CLK_SEL47_CON */ + ACLK_RKVDEC_SEL_SHIFT = 7, + ACLK_RKVDEC_SEL_MASK = 1 << ACLK_RKVDEC_SEL_SHIFT, + ACLK_RKVDEC_SEL_GPLL = 0, + ACLK_RKVDEC_SEL_CPLL, + ACLK_RKVDEC_DIV_SHIFT = 0, + ACLK_RKVDEC_DIV_MASK = 0x1f << ACLK_RKVDEC_DIV_SHIFT, + + /* CRU_CLK_SEL49_CON */ + CLK_RKVDEC_CORE_SEL_SHIFT = 14, + CLK_RKVDEC_CORE_SEL_MASK = 0x3 << CLK_RKVDEC_CORE_SEL_SHIFT, + CLK_RKVDEC_CORE_SEL_GPLL = 0, + CLK_RKVDEC_CORE_SEL_CPLL, + CLK_RKVDEC_CORE_SEL_NPLL, + CLK_RKVDEC_CORE_SEL_VPLL, + CLK_RKVDEC_CORE_DIV_SHIFT = 8, + CLK_RKVDEC_CORE_DIV_MASK = 0x1f << CLK_RKVDEC_CORE_DIV_SHIFT, + + /* CRU_CLK_SEL50_CON */ + PCLK_BUS_SEL_SHIFT = 4, + PCLK_BUS_SEL_MASK = 3 << PCLK_BUS_SEL_SHIFT, + PCLK_BUS_SEL_100M = 0, + PCLK_BUS_SEL_75M, + PCLK_BUS_SEL_50M, + PCLK_BUS_SEL_24M, + ACLK_BUS_SEL_SHIFT = 0, + ACLK_BUS_SEL_MASK = 3 << ACLK_BUS_SEL_SHIFT, + ACLK_BUS_SEL_200M = 0, + ACLK_BUS_SEL_150M, + ACLK_BUS_SEL_100M, + ACLK_BUS_SEL_24M, + + /* CRU_CLK_SEL51_CON */ + CLK_TSADC_DIV_SHIFT = 8, + CLK_TSADC_DIV_MASK = 0x7f << CLK_TSADC_DIV_SHIFT, + CLK_TSADC_TSEN_SEL_SHIFT = 4, + CLK_TSADC_TSEN_SEL_MASK = 0x3 << CLK_TSADC_TSEN_SEL_SHIFT, + CLK_TSADC_TSEN_SEL_24M = 0, + CLK_TSADC_TSEN_SEL_100M, + CLK_TSADC_TSEN_SEL_CPLL_100M, + CLK_TSADC_TSEN_DIV_SHIFT = 0, + CLK_TSADC_TSEN_DIV_MASK = 0x7 << CLK_TSADC_TSEN_DIV_SHIFT, + + /* CRU_CLK_SEL52_CON */ + CLK_UART_SEL_SHIFT = 12, + CLK_UART_SEL_MASK = 0x3 << CLK_UART_SEL_SHIFT, + CLK_UART_SEL_SRC = 0, + CLK_UART_SEL_FRAC, + CLK_UART_SEL_XIN24M, + CLK_UART_SRC_SEL_SHIFT = 8, + CLK_UART_SRC_SEL_MASK = 0x3 << CLK_UART_SRC_SEL_SHIFT, + CLK_UART_SRC_SEL_GPLL = 0, + CLK_UART_SRC_SEL_CPLL, + CLK_UART_SRC_SEL_480M, + CLK_UART_SRC_DIV_SHIFT = 0, + CLK_UART_SRC_DIV_MASK = 0x3f << CLK_UART_SRC_DIV_SHIFT, + + /* CRU_CLK_SEL53_CON */ + CLK_UART_FRAC_NUMERATOR_SHIFT = 16, + CLK_UART_FRAC_NUMERATOR_MASK = 0xffff << 16, + CLK_UART_FRAC_DENOMINATOR_SHIFT = 0, + CLK_UART_FRAC_DENOMINATOR_MASK = 0xffff, + + /* CRU_CLK_SEL71_CON */ + CLK_I2C_SEL_SHIFT = 8, + CLK_I2C_SEL_MASK = 3 << CLK_I2C_SEL_SHIFT, + CLK_I2C_SEL_200M = 0, + CLK_I2C_SEL_100M, + CLK_I2C_SEL_24M, + CLK_I2C_SEL_CPLL_100M, + + /* CRU_CLK_SEL72_CON */ + CLK_PWM3_SEL_SHIFT = 12, + CLK_PWM3_SEL_MASK = 3 << CLK_PWM3_SEL_SHIFT, + CLK_PWM2_SEL_SHIFT = 10, + CLK_PWM2_SEL_MASK = 3 << CLK_PWM2_SEL_SHIFT, + CLK_PWM1_SEL_SHIFT = 8, + CLK_PWM1_SEL_MASK = 3 << CLK_PWM1_SEL_SHIFT, + CLK_PWM_SEL_100M = 0, + CLK_PWM_SEL_24M, + CLK_PWM_SEL_CPLL_100M, + CLK_SPI3_SEL_SHIFT = 6, + CLK_SPI3_SEL_MASK = 3 << CLK_SPI3_SEL_SHIFT, + CLK_SPI2_SEL_SHIFT = 4, + CLK_SPI2_SEL_MASK = 3 << CLK_SPI2_SEL_SHIFT, + CLK_SPI1_SEL_SHIFT = 2, + CLK_SPI1_SEL_MASK = 3 << CLK_SPI1_SEL_SHIFT, + CLK_SPI0_SEL_SHIFT = 0, + CLK_SPI0_SEL_MASK = 3 << CLK_SPI0_SEL_SHIFT, + CLK_SPI_SEL_200M = 0, + CLK_SPI_SEL_24M, + CLK_SPI_SEL_CPLL_100M, + + /* CRU_CLK_SEL73_CON */ + PCLK_TOP_SEL_SHIFT = 12, + PCLK_TOP_SEL_MASK = 3 << PCLK_TOP_SEL_SHIFT, + PCLK_TOP_SEL_100M = 0, + PCLK_TOP_SEL_75M, + PCLK_TOP_SEL_50M, + PCLK_TOP_SEL_24M, + HCLK_TOP_SEL_SHIFT = 8, + HCLK_TOP_SEL_MASK = 3 << HCLK_TOP_SEL_SHIFT, + HCLK_TOP_SEL_150M = 0, + HCLK_TOP_SEL_100M, + HCLK_TOP_SEL_75M, + HCLK_TOP_SEL_24M, + ACLK_TOP_LOW_SEL_SHIFT = 4, + ACLK_TOP_LOW_SEL_MASK = 3 << ACLK_TOP_LOW_SEL_SHIFT, + ACLK_TOP_LOW_SEL_400M = 0, + ACLK_TOP_LOW_SEL_300M, + ACLK_TOP_LOW_SEL_200M, + ACLK_TOP_LOW_SEL_24M, + ACLK_TOP_HIGH_SEL_SHIFT = 0, + ACLK_TOP_HIGH_SEL_MASK = 3 << ACLK_TOP_HIGH_SEL_SHIFT, + ACLK_TOP_HIGH_SEL_500M = 0, + ACLK_TOP_HIGH_SEL_400M, + ACLK_TOP_HIGH_SEL_300M, + ACLK_TOP_HIGH_SEL_24M, + + /* CRU_CLK_SEL78_CON */ + CPLL_500M_DIV_SHIFT = 8, + CPLL_500M_DIV_MASK = 0x1f << CPLL_500M_DIV_SHIFT, + + /* CRU_CLK_SEL79_CON */ + CPLL_250M_DIV_SHIFT = 8, + CPLL_250M_DIV_MASK = 0x1f << CPLL_250M_DIV_SHIFT, + CPLL_333M_DIV_SHIFT = 0, + CPLL_333M_DIV_MASK = 0x1f << CPLL_333M_DIV_SHIFT, + + /* CRU_CLK_SEL80_CON */ + CPLL_62P5M_DIV_SHIFT = 8, + CPLL_62P5M_DIV_MASK = 0x1f << CPLL_62P5M_DIV_SHIFT, + CPLL_125M_DIV_SHIFT = 0, + CPLL_125M_DIV_MASK = 0x1f << CPLL_125M_DIV_SHIFT, + + /* CRU_CLK_SEL81_CON */ + CPLL_25M_DIV_SHIFT = 8, + CPLL_25M_DIV_MASK = 0x1f << CPLL_25M_DIV_SHIFT, + CPLL_50M_DIV_SHIFT = 0, + CPLL_50M_DIV_MASK = 0x1f << CPLL_50M_DIV_SHIFT, + + /* CRU_CLK_SEL82_CON */ + CPLL_100M_DIV_SHIFT = 0, + CPLL_100M_DIV_MASK = 0x1f << CPLL_100M_DIV_SHIFT, +}; +#endif diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index 4cfcf8330929..913f611a0ff8 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -14,4 +14,5 @@ obj-$(CONFIG_ROCKCHIP_RK3308) += clk_rk3308.o obj-$(CONFIG_ROCKCHIP_RK3328) += clk_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += clk_rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += clk_rk3399.o +obj-$(CONFIG_ROCKCHIP_RK3568) += clk_rk3568.o obj-$(CONFIG_ROCKCHIP_RV1108) += clk_rv1108.o diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c new file mode 100644 index 000000000000..359aca358e0d --- /dev/null +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -0,0 +1,2908 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2021 Fuzhou Rockchip Electronics Co., Ltd + * Author: Elaine Zhang zhangqing@rock-chips.com + */ + +#include <common.h> +#include <bitfield.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/arch-rockchip/cru_rk3568.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/io.h> +#include <dm/lists.h> +#include <dt-bindings/clock/rk3568-cru.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +struct rk3568_clk_plat { + struct dtd_rockchip_rk3568_cru dtd; +}; + +struct rk3568_pmuclk_plat { + struct dtd_rockchip_rk3568_pmucru dtd; +}; +#endif + +#define RK3568_CPUCLK_RATE(_rate, _aclk_div, _pclk_div) \ +{ \ + .rate = _rate##U, \ + .aclk_div = _aclk_div, \ + .pclk_div = _pclk_div, \ +} + +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + +static struct rockchip_cpu_rate_table rk3568_cpu_rates[] = { + RK3568_CPUCLK_RATE(1416000000, 1, 5), + RK3568_CPUCLK_RATE(1296000000, 1, 5), + RK3568_CPUCLK_RATE(1200000000, 1, 3), + RK3568_CPUCLK_RATE(1104000000, 1, 3), + RK3568_CPUCLK_RATE(1008000000, 1, 3), + RK3568_CPUCLK_RATE(912000000, 1, 3), + RK3568_CPUCLK_RATE(816000000, 1, 3), + RK3568_CPUCLK_RATE(600000000, 1, 1), + RK3568_CPUCLK_RATE(408000000, 1, 1), + { /* sentinel */ }, +}; + +static struct rockchip_pll_rate_table rk3568_pll_rates[] = { + /* _mhz, _refdiv, _fbdiv, _postdiv1, _postdiv2, _dsmpd, _frac */ + RK3036_PLL_RATE(1608000000, 1, 67, 1, 1, 1, 0), + RK3036_PLL_RATE(1416000000, 1, 118, 2, 1, 1, 0), + RK3036_PLL_RATE(1296000000, 1, 108, 2, 1, 1, 0), + RK3036_PLL_RATE(1200000000, 1, 100, 2, 1, 1, 0), + RK3036_PLL_RATE(1188000000, 1, 99, 2, 1, 1, 0), + RK3036_PLL_RATE(1104000000, 1, 92, 2, 1, 1, 0), + RK3036_PLL_RATE(1008000000, 1, 84, 2, 1, 1, 0), + RK3036_PLL_RATE(1000000000, 3, 250, 2, 1, 1, 0), + RK3036_PLL_RATE(912000000, 1, 76, 2, 1, 1, 0), + RK3036_PLL_RATE(816000000, 1, 68, 2, 1, 1, 0), + RK3036_PLL_RATE(600000000, 1, 100, 4, 1, 1, 0), + RK3036_PLL_RATE(594000000, 1, 99, 4, 1, 1, 0), + RK3036_PLL_RATE(500000000, 1, 125, 6, 1, 1, 0), + RK3036_PLL_RATE(408000000, 1, 68, 2, 2, 1, 0), + RK3036_PLL_RATE(400000000, 1, 100, 6, 1, 1, 0), + RK3036_PLL_RATE(200000000, 1, 100, 6, 2, 1, 0), + RK3036_PLL_RATE(100000000, 1, 150, 6, 6, 1, 0), + { /* sentinel */ }, +}; + +static struct rockchip_pll_clock rk3568_pll_clks[] = { + [APLL] = PLL(pll_rk3328, PLL_APLL, RK3568_PLL_CON(0), + RK3568_MODE_CON, 0, 10, 0, rk3568_pll_rates), + [DPLL] = PLL(pll_rk3328, PLL_DPLL, RK3568_PLL_CON(8), + RK3568_MODE_CON, 2, 10, 0, NULL), + [CPLL] = PLL(pll_rk3328, PLL_CPLL, RK3568_PLL_CON(24), + RK3568_MODE_CON, 4, 10, 0, rk3568_pll_rates), + [GPLL] = PLL(pll_rk3328, PLL_HPLL, RK3568_PLL_CON(16), + RK3568_MODE_CON, 6, 10, 0, rk3568_pll_rates), + [NPLL] = PLL(pll_rk3328, PLL_NPLL, RK3568_PLL_CON(32), + RK3568_MODE_CON, 10, 10, 0, rk3568_pll_rates), + [VPLL] = PLL(pll_rk3328, PLL_VPLL, RK3568_PLL_CON(40), + RK3568_MODE_CON, 12, 10, 0, rk3568_pll_rates), + [PPLL] = PLL(pll_rk3328, PLL_PPLL, RK3568_PMU_PLL_CON(0), + RK3568_PMU_MODE, 0, 10, 0, rk3568_pll_rates), + [HPLL] = PLL(pll_rk3328, PLL_HPLL, RK3568_PMU_PLL_CON(16), + RK3568_PMU_MODE, 2, 10, 0, rk3568_pll_rates), +}; + +static ulong __maybe_unused +rk3568_pmu_pll_set_rate(struct rk3568_clk_priv *priv, + ulong pll_id, ulong rate) +{ + struct udevice *pmucru_dev; + struct rk3568_pmuclk_priv *pmu_priv; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(rockchip_rk3568_pmucru), + &pmucru_dev); + if (ret) { + printf("%s: could not find pmucru device\n", __func__); + return ret; + } + pmu_priv = dev_get_priv(pmucru_dev); + + rockchip_pll_set_rate(&rk3568_pll_clks[pll_id], + pmu_priv->pmucru, pll_id, rate); + + return 0; +} + +static ulong rk3568_pmu_pll_get_rate(struct rk3568_clk_priv *priv, + ulong pll_id) +{ + struct udevice *pmucru_dev; + struct rk3568_pmuclk_priv *pmu_priv; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(rockchip_rk3568_pmucru), + &pmucru_dev); + if (ret) { + printf("%s: could not find pmucru device\n", __func__); + return ret; + } + pmu_priv = dev_get_priv(pmucru_dev); + + return rockchip_pll_get_rate(&rk3568_pll_clks[pll_id], + pmu_priv->pmucru, pll_id); +} + +/* + * + * rational_best_approximation(31415, 10000, + * (1 << 8) - 1, (1 << 5) - 1, &n, &d); + * + * you may look at given_numerator as a fixed point number, + * with the fractional part size described in given_denominator. + * + * for theoretical background, see: + * http://en.wikipedia.org/wiki/Continued_fraction + */ +static void rational_best_approximation(unsigned long given_numerator, + unsigned long given_denominator, + unsigned long max_numerator, + unsigned long max_denominator, + unsigned long *best_numerator, + unsigned long *best_denominator) +{ + unsigned long n, d, n0, d0, n1, d1; + + n = given_numerator; + d = given_denominator; + n0 = 0; + d1 = 0; + n1 = 1; + d0 = 1; + for (;;) { + unsigned long t, a; + + if (n1 > max_numerator || d1 > max_denominator) { + n1 = n0; + d1 = d0; + break; + } + if (d == 0) + break; + t = d; + a = n / d; + d = n % d; + n = t; + t = n0 + a * n1; + n0 = n1; + n1 = t; + t = d0 + a * d1; + d0 = d1; + d1 = t; + } + *best_numerator = n1; + *best_denominator = d1; +} + +static ulong rk3568_rtc32k_get_pmuclk(struct rk3568_pmuclk_priv *priv) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + unsigned long m, n; + u32 fracdiv; + + fracdiv = readl(&pmucru->pmu_clksel_con[1]); + m = fracdiv & RTC32K_FRAC_NUMERATOR_MASK; + m >>= RTC32K_FRAC_NUMERATOR_SHIFT; + n = fracdiv & RTC32K_FRAC_DENOMINATOR_MASK; + n >>= RTC32K_FRAC_DENOMINATOR_SHIFT; + + return OSC_HZ * m / n; +} + +static ulong rk3568_rtc32k_set_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong rate) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + unsigned long m, n, val; + + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC0_DIV32K << RTC32K_SEL_SHIFT); + + rational_best_approximation(rate, OSC_HZ, + GENMASK(16 - 1, 0), + GENMASK(16 - 1, 0), + &m, &n); + val = m << RTC32K_FRAC_NUMERATOR_SHIFT | n; + writel(val, &pmucru->pmu_clksel_con[1]); + + return rk3568_rtc32k_get_pmuclk(priv); +} + +static ulong rk3568_i2c_get_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong clk_id) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + u32 div, con; + + switch (clk_id) { + case CLK_I2C0: + con = readl(&pmucru->pmu_clksel_con[3]); + div = (con & CLK_I2C0_DIV_MASK) >> CLK_I2C0_DIV_SHIFT; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(priv->ppll_hz, div); +} + +static ulong rk3568_i2c_set_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->ppll_hz, rate); + assert(src_clk_div - 1 <= 127); + + switch (clk_id) { + case CLK_I2C0: + rk_clrsetreg(&pmucru->pmu_clksel_con[3], CLK_I2C0_DIV_MASK, + (src_clk_div - 1) << CLK_I2C0_DIV_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_i2c_get_pmuclk(priv, clk_id); +} + +static ulong rk3568_pwm_get_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong clk_id) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + u32 div, sel, con, parent; + + switch (clk_id) { + case CLK_PWM0: + con = readl(&pmucru->pmu_clksel_con[6]); + sel = (con & CLK_PWM0_SEL_MASK) >> CLK_PWM0_SEL_SHIFT; + div = (con & CLK_PWM0_DIV_MASK) >> CLK_PWM0_DIV_SHIFT; + if (sel == CLK_PWM0_SEL_XIN24M) + parent = OSC_HZ; + else + parent = priv->ppll_hz; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(parent, div); +} + +static ulong rk3568_pwm_set_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + switch (clk_id) { + case CLK_PWM0: + if (rate == OSC_HZ) { + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_SEL_MASK | CLK_PWM0_DIV_MASK, + (CLK_PWM0_SEL_XIN24M << + CLK_PWM0_SEL_SHIFT) | + 0 << CLK_PWM0_SEL_SHIFT); + } else { + src_clk_div = DIV_ROUND_UP(priv->ppll_hz, rate); + assert(src_clk_div - 1 <= 127); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_DIV_MASK | CLK_PWM0_DIV_MASK, + (CLK_PWM0_SEL_PPLL << CLK_PWM0_SEL_SHIFT) | + (src_clk_div - 1) << CLK_PWM0_DIV_SHIFT); + } + break; + default: + return -ENOENT; + } + + return rk3568_pwm_get_pmuclk(priv, clk_id); +} + +static ulong rk3568_pmu_get_pmuclk(struct rk3568_pmuclk_priv *priv) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + u32 div, con, sel, parent; + + con = readl(&pmucru->pmu_clksel_con[2]); + sel = (con & PCLK_PDPMU_SEL_MASK) >> PCLK_PDPMU_SEL_SHIFT; + div = (con & PCLK_PDPMU_DIV_MASK) >> PCLK_PDPMU_DIV_SHIFT; + if (sel) + parent = GPLL_HZ; + else + parent = priv->ppll_hz; + + return DIV_TO_RATE(parent, div); +} + +static ulong rk3568_pmu_set_pmuclk(struct rk3568_pmuclk_priv *priv, + ulong rate) +{ + struct rk3568_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->ppll_hz, rate); + assert(src_clk_div - 1 <= 31); + + rk_clrsetreg(&pmucru->pmu_clksel_con[2], + PCLK_PDPMU_DIV_MASK | PCLK_PDPMU_SEL_MASK, + (PCLK_PDPMU_SEL_PPLL << PCLK_PDPMU_SEL_SHIFT) | + ((src_clk_div - 1) << PCLK_PDPMU_DIV_SHIFT)); + + return rk3568_pmu_get_pmuclk(priv); +} + +static ulong rk3568_pmuclk_get_rate(struct clk *clk) +{ + struct rk3568_pmuclk_priv *priv = dev_get_priv(clk->dev); + ulong rate = 0; + + if (!priv->ppll_hz) { + printf("%s ppll=%lu\n", __func__, priv->ppll_hz); + return -ENOENT; + } + + debug("%s %ld\n", __func__, clk->id); + switch (clk->id) { + case PLL_PPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[PPLL], + priv->pmucru, PPLL); + break; + case PLL_HPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[HPLL], + priv->pmucru, HPLL); + break; + case CLK_RTC_32K: + case CLK_RTC32K_FRAC: + rate = rk3568_rtc32k_get_pmuclk(priv); + break; + case CLK_I2C0: + rate = rk3568_i2c_get_pmuclk(priv, clk->id); + break; + case CLK_PWM0: + rate = rk3568_pwm_get_pmuclk(priv, clk->id); + break; + case PCLK_PMU: + rate = rk3568_pmu_get_pmuclk(priv); + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk3568_pmuclk_set_rate(struct clk *clk, ulong rate) +{ + struct rk3568_pmuclk_priv *priv = dev_get_priv(clk->dev); + ulong ret = 0; + + if (!priv->ppll_hz) { + printf("%s ppll=%lu\n", __func__, priv->ppll_hz); + return -ENOENT; + } + + debug("%s %ld %ld\n", __func__, clk->id, rate); + switch (clk->id) { + case PLL_PPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[PPLL], + priv->pmucru, PPLL, rate); + priv->ppll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[PPLL], + priv->pmucru, PPLL); + break; + case PLL_HPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[HPLL], + priv->pmucru, HPLL, rate); + priv->hpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[HPLL], + priv->pmucru, HPLL); + break; + case CLK_RTC_32K: + case CLK_RTC32K_FRAC: + ret = rk3568_rtc32k_set_pmuclk(priv, rate); + break; + case CLK_I2C0: + ret = rk3568_i2c_set_pmuclk(priv, clk->id, rate); + break; + case CLK_PWM0: + ret = rk3568_pwm_set_pmuclk(priv, clk->id, rate); + break; + case PCLK_PMU: + ret = rk3568_pmu_set_pmuclk(priv, rate); + break; + default: + return -ENOENT; + } + + return ret; +} + +static int rk3568_rtc32k_set_parent(struct clk *clk, struct clk *parent) +{ + struct rk3568_pmuclk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_pmucru *pmucru = priv->pmucru; + + if (parent->id == CLK_RTC32K_FRAC) + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC0_DIV32K << RTC32K_SEL_SHIFT); + else + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC1_32K << RTC32K_SEL_SHIFT); + + return 0; +} + +static int rk3568_pmuclk_set_parent(struct clk *clk, struct clk *parent) +{ + switch (clk->id) { + case CLK_RTC_32K: + return rk3568_rtc32k_set_parent(clk, parent); + default: + return -ENOENT; + } +} + +static struct clk_ops rk3568_pmuclk_ops = { + .get_rate = rk3568_pmuclk_get_rate, + .set_rate = rk3568_pmuclk_set_rate, + .set_parent = rk3568_pmuclk_set_parent, +}; + +static int rk3568_pmuclk_probe(struct udevice *dev) +{ + struct rk3568_pmuclk_priv *priv = dev_get_priv(dev); + int ret = 0; + + if (priv->ppll_hz != PPLL_HZ) { + ret = rockchip_pll_set_rate(&rk3568_pll_clks[PPLL], + priv->pmucru, + PPLL, PPLL_HZ); + if (!ret) + priv->ppll_hz = PPLL_HZ; + } + + /* Ungate PCIe30phy refclk_m and refclk_n */ + rk_clrsetreg(&priv->pmucru->pmu_clkgate_con[2], 0x3 << 13, 0 << 13); + return 0; +} + +static int rk3568_pmuclk_ofdata_to_platdata(struct udevice *dev) +{ + struct rk3568_pmuclk_priv *priv = dev_get_priv(dev); + + priv->pmucru = dev_read_addr_ptr(dev); + + return 0; +} + +static int rk3568_pmuclk_bind(struct udevice *dev) +{ +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) + int ret = 0; + + ret = offsetof(struct rk3568_pmucru, pmu_softrst_con[0]); + ret = rockchip_reset_bind(dev, ret, 1); + if (ret) + debug("Warning: pmucru software reset driver bind faile\n"); +#endif + + return 0; +} + +static const struct udevice_id rk3568_pmuclk_ids[] = { + { .compatible = "rockchip,rk3568-pmucru" }, + { } +}; + +U_BOOT_DRIVER(rockchip_rk3568_pmucru) = { + .name = "rockchip_rk3568_pmucru", + .id = UCLASS_CLK, + .of_match = rk3568_pmuclk_ids, + .priv_auto = sizeof(struct rk3568_pmuclk_priv), + .of_to_plat = rk3568_pmuclk_ofdata_to_platdata, + .ops = &rk3568_pmuclk_ops, + .bind = rk3568_pmuclk_bind, + .probe = rk3568_pmuclk_probe, +#if CONFIG_IS_ENABLED(OF_PLATDATA) + .plat_auto = sizeof(struct rk3568_pmuclk_plat), +#endif + +}; + +static int rk3568_armclk_set_clk(struct rk3568_clk_priv *priv, ulong hz) +{ + struct rk3568_cru *cru = priv->cru; + const struct rockchip_cpu_rate_table *rate; + ulong old_rate; + + rate = rockchip_get_cpu_settings(rk3568_cpu_rates, hz); + if (!rate) { + printf("%s unsupported rate\n", __func__); + return -EINVAL; + } + + rk_clrsetreg(&cru->clksel_con[0], + CLK_CORE_PRE_SEL_MASK, + (CLK_CORE_PRE_SEL_SRC << CLK_CORE_PRE_SEL_SHIFT)); + rk_clrsetreg(&cru->clksel_con[2], + SCLK_CORE_PRE_SEL_MASK | + SCLK_CORE_SRC_SEL_MASK | + SCLK_CORE_SRC_DIV_MASK, + (SCLK_CORE_PRE_SEL_SRC << + SCLK_CORE_PRE_SEL_SHIFT) | + (SCLK_CORE_SRC_SEL_APLL << + SCLK_CORE_SRC_SEL_SHIFT) | + (1 << SCLK_CORE_SRC_DIV_SHIFT)); + + /* + * set up dependent divisors for DBG and ACLK clocks. + */ + old_rate = rockchip_pll_get_rate(&rk3568_pll_clks[APLL], + priv->cru, APLL); + if (old_rate > hz) { + if (rockchip_pll_set_rate(&rk3568_pll_clks[APLL], + priv->cru, APLL, hz)) + return -EINVAL; + rk_clrsetreg(&cru->clksel_con[3], + GICCLK_CORE_DIV_MASK | ATCLK_CORE_DIV_MASK, + rate->pclk_div << GICCLK_CORE_DIV_SHIFT | + rate->pclk_div << ATCLK_CORE_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[4], + PERIPHCLK_CORE_PRE_DIV_MASK | + PCLK_CORE_PRE_DIV_MASK, + rate->pclk_div << PCLK_CORE_PRE_DIV_SHIFT | + rate->pclk_div << PERIPHCLK_CORE_PRE_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[5], + ACLK_CORE_NDFT_DIV_MASK, + rate->aclk_div << ACLK_CORE_NDFT_DIV_SHIFT); + } else if (old_rate < hz) { + rk_clrsetreg(&cru->clksel_con[3], + GICCLK_CORE_DIV_MASK | ATCLK_CORE_DIV_MASK, + rate->pclk_div << GICCLK_CORE_DIV_SHIFT | + rate->pclk_div << ATCLK_CORE_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[4], + PERIPHCLK_CORE_PRE_DIV_MASK | + PCLK_CORE_PRE_DIV_MASK, + rate->pclk_div << PCLK_CORE_PRE_DIV_SHIFT | + rate->pclk_div << PERIPHCLK_CORE_PRE_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[5], + ACLK_CORE_NDFT_DIV_MASK, + rate->aclk_div << ACLK_CORE_NDFT_DIV_SHIFT); + if (rockchip_pll_set_rate(&rk3568_pll_clks[APLL], + priv->cru, APLL, hz)) + return -EINVAL; + } + + return 0; +} + +static ulong rk3568_cpll_div_get_rate(struct rk3568_clk_priv *priv, + ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + int div, mask, shift, con; + + switch (clk_id) { + case CPLL_500M: + con = 78; + mask = CPLL_500M_DIV_MASK; + shift = CPLL_500M_DIV_SHIFT; + break; + case CPLL_333M: + con = 79; + mask = CPLL_333M_DIV_MASK; + shift = CPLL_333M_DIV_SHIFT; + break; + case CPLL_250M: + con = 79; + mask = CPLL_250M_DIV_MASK; + shift = CPLL_250M_DIV_SHIFT; + break; + case CPLL_125M: + con = 80; + mask = CPLL_125M_DIV_MASK; + shift = CPLL_125M_DIV_SHIFT; + break; + case CPLL_100M: + con = 82; + mask = CPLL_100M_DIV_MASK; + shift = CPLL_100M_DIV_SHIFT; + break; + case CPLL_62P5M: + con = 80; + mask = CPLL_62P5M_DIV_MASK; + shift = CPLL_62P5M_DIV_SHIFT; + break; + case CPLL_50M: + con = 81; + mask = CPLL_50M_DIV_MASK; + shift = CPLL_50M_DIV_SHIFT; + break; + case CPLL_25M: + con = 81; + mask = CPLL_25M_DIV_MASK; + shift = CPLL_25M_DIV_SHIFT; + break; + default: + return -ENOENT; + } + + div = (readl(&cru->clksel_con[con]) & mask) >> shift; + return DIV_TO_RATE(priv->cpll_hz, div); +} + +static ulong rk3568_cpll_div_set_rate(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int div, mask, shift, con; + + switch (clk_id) { + case CPLL_500M: + con = 78; + mask = CPLL_500M_DIV_MASK; + shift = CPLL_500M_DIV_SHIFT; + break; + case CPLL_333M: + con = 79; + mask = CPLL_333M_DIV_MASK; + shift = CPLL_333M_DIV_SHIFT; + break; + case CPLL_250M: + con = 79; + mask = CPLL_250M_DIV_MASK; + shift = CPLL_250M_DIV_SHIFT; + break; + case CPLL_125M: + con = 80; + mask = CPLL_125M_DIV_MASK; + shift = CPLL_125M_DIV_SHIFT; + break; + case CPLL_100M: + con = 82; + mask = CPLL_100M_DIV_MASK; + shift = CPLL_100M_DIV_SHIFT; + break; + case CPLL_62P5M: + con = 80; + mask = CPLL_62P5M_DIV_MASK; + shift = CPLL_62P5M_DIV_SHIFT; + break; + case CPLL_50M: + con = 81; + mask = CPLL_50M_DIV_MASK; + shift = CPLL_50M_DIV_SHIFT; + break; + case CPLL_25M: + con = 81; + mask = CPLL_25M_DIV_MASK; + shift = CPLL_25M_DIV_SHIFT; + break; + default: + return -ENOENT; + } + + div = DIV_ROUND_UP(priv->cpll_hz, rate); + assert(div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[con], + mask, (div - 1) << shift); + return rk3568_cpll_div_get_rate(priv, clk_id); +} + +static ulong rk3568_bus_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, sel, rate; + + switch (clk_id) { + case ACLK_BUS: + con = readl(&cru->clksel_con[50]); + sel = (con & ACLK_BUS_SEL_MASK) >> ACLK_BUS_SEL_SHIFT; + if (sel == ACLK_BUS_SEL_200M) + rate = 200 * MHz; + else if (sel == ACLK_BUS_SEL_150M) + rate = 150 * MHz; + else if (sel == ACLK_BUS_SEL_100M) + rate = 100 * MHz; + else + rate = OSC_HZ; + break; + case PCLK_BUS: + case PCLK_WDT_NS: + con = readl(&cru->clksel_con[50]); + sel = (con & PCLK_BUS_SEL_MASK) >> PCLK_BUS_SEL_SHIFT; + if (sel == PCLK_BUS_SEL_100M) + rate = 100 * MHz; + else if (sel == PCLK_BUS_SEL_75M) + rate = 75 * MHz; + else if (sel == PCLK_BUS_SEL_50M) + rate = 50 * MHz; + else + rate = OSC_HZ; + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk3568_bus_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (clk_id) { + case ACLK_BUS: + if (rate == 200 * MHz) + src_clk = ACLK_BUS_SEL_200M; + else if (rate == 150 * MHz) + src_clk = ACLK_BUS_SEL_150M; + else if (rate == 100 * MHz) + src_clk = ACLK_BUS_SEL_100M; + else + src_clk = ACLK_BUS_SEL_24M; + rk_clrsetreg(&cru->clksel_con[50], + ACLK_BUS_SEL_MASK, + src_clk << ACLK_BUS_SEL_SHIFT); + break; + case PCLK_BUS: + case PCLK_WDT_NS: + if (rate == 100 * MHz) + src_clk = PCLK_BUS_SEL_100M; + else if (rate == 75 * MHz) + src_clk = PCLK_BUS_SEL_75M; + else if (rate == 50 * MHz) + src_clk = PCLK_BUS_SEL_50M; + else + src_clk = PCLK_BUS_SEL_24M; + rk_clrsetreg(&cru->clksel_con[50], + PCLK_BUS_SEL_MASK, + src_clk << PCLK_BUS_SEL_SHIFT); + break; + + default: + printf("do not support this bus freq\n"); + return -EINVAL; + } + + return rk3568_bus_get_clk(priv, clk_id); +} + +static ulong rk3568_perimid_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, sel, rate; + + switch (clk_id) { + case ACLK_PERIMID: + con = readl(&cru->clksel_con[10]); + sel = (con & ACLK_PERIMID_SEL_MASK) >> ACLK_PERIMID_SEL_SHIFT; + if (sel == ACLK_PERIMID_SEL_300M) + rate = 300 * MHz; + else if (sel == ACLK_PERIMID_SEL_200M) + rate = 200 * MHz; + else if (sel == ACLK_PERIMID_SEL_100M) + rate = 100 * MHz; + else + rate = OSC_HZ; + break; + case HCLK_PERIMID: + con = readl(&cru->clksel_con[10]); + sel = (con & HCLK_PERIMID_SEL_MASK) >> HCLK_PERIMID_SEL_SHIFT; + if (sel == HCLK_PERIMID_SEL_150M) + rate = 150 * MHz; + else if (sel == HCLK_PERIMID_SEL_100M) + rate = 100 * MHz; + else if (sel == HCLK_PERIMID_SEL_75M) + rate = 75 * MHz; + else + rate = OSC_HZ; + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk3568_perimid_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (clk_id) { + case ACLK_PERIMID: + if (rate == 300 * MHz) + src_clk = ACLK_PERIMID_SEL_300M; + else if (rate == 200 * MHz) + src_clk = ACLK_PERIMID_SEL_200M; + else if (rate == 100 * MHz) + src_clk = ACLK_PERIMID_SEL_100M; + else + src_clk = ACLK_PERIMID_SEL_24M; + rk_clrsetreg(&cru->clksel_con[10], + ACLK_PERIMID_SEL_MASK, + src_clk << ACLK_PERIMID_SEL_SHIFT); + break; + case HCLK_PERIMID: + if (rate == 150 * MHz) + src_clk = HCLK_PERIMID_SEL_150M; + else if (rate == 100 * MHz) + src_clk = HCLK_PERIMID_SEL_100M; + else if (rate == 75 * MHz) + src_clk = HCLK_PERIMID_SEL_75M; + else + src_clk = HCLK_PERIMID_SEL_24M; + rk_clrsetreg(&cru->clksel_con[10], + HCLK_PERIMID_SEL_MASK, + src_clk << HCLK_PERIMID_SEL_SHIFT); + break; + + default: + printf("do not support this permid freq\n"); + return -EINVAL; + } + + return rk3568_perimid_get_clk(priv, clk_id); +} + +static ulong rk3568_top_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, sel, rate; + + switch (clk_id) { + case ACLK_TOP_HIGH: + con = readl(&cru->clksel_con[73]); + sel = (con & ACLK_TOP_HIGH_SEL_MASK) >> ACLK_TOP_HIGH_SEL_SHIFT; + if (sel == ACLK_TOP_HIGH_SEL_500M) + rate = 500 * MHz; + else if (sel == ACLK_TOP_HIGH_SEL_400M) + rate = 400 * MHz; + else if (sel == ACLK_TOP_HIGH_SEL_300M) + rate = 300 * MHz; + else + rate = OSC_HZ; + break; + case ACLK_TOP_LOW: + con = readl(&cru->clksel_con[73]); + sel = (con & ACLK_TOP_LOW_SEL_MASK) >> ACLK_TOP_LOW_SEL_SHIFT; + if (sel == ACLK_TOP_LOW_SEL_400M) + rate = 400 * MHz; + else if (sel == ACLK_TOP_LOW_SEL_300M) + rate = 300 * MHz; + else if (sel == ACLK_TOP_LOW_SEL_200M) + rate = 200 * MHz; + else + rate = OSC_HZ; + break; + case HCLK_TOP: + con = readl(&cru->clksel_con[73]); + sel = (con & HCLK_TOP_SEL_MASK) >> HCLK_TOP_SEL_SHIFT; + if (sel == HCLK_TOP_SEL_150M) + rate = 150 * MHz; + else if (sel == HCLK_TOP_SEL_100M) + rate = 100 * MHz; + else if (sel == HCLK_TOP_SEL_75M) + rate = 75 * MHz; + else + rate = OSC_HZ; + break; + case PCLK_TOP: + con = readl(&cru->clksel_con[73]); + sel = (con & PCLK_TOP_SEL_MASK) >> PCLK_TOP_SEL_SHIFT; + if (sel == PCLK_TOP_SEL_100M) + rate = 100 * MHz; + else if (sel == PCLK_TOP_SEL_75M) + rate = 75 * MHz; + else if (sel == PCLK_TOP_SEL_50M) + rate = 50 * MHz; + else + rate = OSC_HZ; + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk3568_top_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (clk_id) { + case ACLK_TOP_HIGH: + if (rate == 500 * MHz) + src_clk = ACLK_TOP_HIGH_SEL_500M; + else if (rate == 400 * MHz) + src_clk = ACLK_TOP_HIGH_SEL_400M; + else if (rate == 300 * MHz) + src_clk = ACLK_TOP_HIGH_SEL_300M; + else + src_clk = ACLK_TOP_HIGH_SEL_24M; + rk_clrsetreg(&cru->clksel_con[73], + ACLK_TOP_HIGH_SEL_MASK, + src_clk << ACLK_TOP_HIGH_SEL_SHIFT); + break; + case ACLK_TOP_LOW: + if (rate == 400 * MHz) + src_clk = ACLK_TOP_LOW_SEL_400M; + else if (rate == 300 * MHz) + src_clk = ACLK_TOP_LOW_SEL_300M; + else if (rate == 200 * MHz) + src_clk = ACLK_TOP_LOW_SEL_200M; + else + src_clk = ACLK_TOP_LOW_SEL_24M; + rk_clrsetreg(&cru->clksel_con[73], + ACLK_TOP_LOW_SEL_MASK, + src_clk << ACLK_TOP_LOW_SEL_SHIFT); + break; + case HCLK_TOP: + if (rate == 150 * MHz) + src_clk = HCLK_TOP_SEL_150M; + else if (rate == 100 * MHz) + src_clk = HCLK_TOP_SEL_100M; + else if (rate == 75 * MHz) + src_clk = HCLK_TOP_SEL_75M; + else + src_clk = HCLK_TOP_SEL_24M; + rk_clrsetreg(&cru->clksel_con[73], + HCLK_TOP_SEL_MASK, + src_clk << HCLK_TOP_SEL_SHIFT); + break; + case PCLK_TOP: + if (rate == 100 * MHz) + src_clk = PCLK_TOP_SEL_100M; + else if (rate == 75 * MHz) + src_clk = PCLK_TOP_SEL_75M; + else if (rate == 50 * MHz) + src_clk = PCLK_TOP_SEL_50M; + else + src_clk = PCLK_TOP_SEL_24M; + rk_clrsetreg(&cru->clksel_con[73], + PCLK_TOP_SEL_MASK, + src_clk << PCLK_TOP_SEL_SHIFT); + break; + + default: + printf("do not support this permid freq\n"); + return -EINVAL; + } + + return rk3568_top_get_clk(priv, clk_id); +} + +static ulong rk3568_i2c_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + ulong rate; + + switch (clk_id) { + case CLK_I2C1: + case CLK_I2C2: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + con = readl(&cru->clksel_con[71]); + sel = (con & CLK_I2C_SEL_MASK) >> CLK_I2C_SEL_SHIFT; + if (sel == CLK_I2C_SEL_200M) + rate = 200 * MHz; + else if (sel == CLK_I2C_SEL_100M) + rate = 100 * MHz; + else if (sel == CLK_I2C_SEL_CPLL_100M) + rate = 100 * MHz; + else + rate = OSC_HZ; + break; + default: + return -ENOENT; + } + + return rate; +} + +static ulong rk3568_i2c_set_clk(struct rk3568_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + if (rate == 200 * MHz) + src_clk = CLK_I2C_SEL_200M; + else if (rate == 100 * MHz) + src_clk = CLK_I2C_SEL_100M; + else + src_clk = CLK_I2C_SEL_24M; + + switch (clk_id) { + case CLK_I2C1: + case CLK_I2C2: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + rk_clrsetreg(&cru->clksel_con[71], CLK_I2C_SEL_MASK, + src_clk << CLK_I2C_SEL_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_i2c_get_clk(priv, clk_id); +} + +static ulong rk3568_spi_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[72]); + + switch (clk_id) { + case CLK_SPI0: + sel = (con & CLK_SPI0_SEL_MASK) >> CLK_SPI0_SEL_SHIFT; + break; + case CLK_SPI1: + sel = (con & CLK_SPI1_SEL_MASK) >> CLK_SPI1_SEL_SHIFT; + break; + case CLK_SPI2: + sel = (con & CLK_SPI2_SEL_MASK) >> CLK_SPI2_SEL_SHIFT; + break; + case CLK_SPI3: + sel = (con & CLK_SPI3_SEL_MASK) >> CLK_SPI3_SEL_SHIFT; + break; + default: + return -ENOENT; + } + + switch (sel) { + case CLK_SPI_SEL_200M: + return 200 * MHz; + case CLK_SPI_SEL_24M: + return OSC_HZ; + case CLK_SPI_SEL_CPLL_100M: + return 100 * MHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_spi_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + if (rate == 200 * MHz) + src_clk = CLK_SPI_SEL_200M; + else if (rate == 100 * MHz) + src_clk = CLK_SPI_SEL_CPLL_100M; + else + src_clk = CLK_SPI_SEL_24M; + + switch (clk_id) { + case CLK_SPI0: + rk_clrsetreg(&cru->clksel_con[72], + CLK_SPI0_SEL_MASK, + src_clk << CLK_SPI0_SEL_SHIFT); + break; + case CLK_SPI1: + rk_clrsetreg(&cru->clksel_con[72], + CLK_SPI1_SEL_MASK, + src_clk << CLK_SPI1_SEL_SHIFT); + break; + case CLK_SPI2: + rk_clrsetreg(&cru->clksel_con[72], + CLK_SPI2_SEL_MASK, + src_clk << CLK_SPI2_SEL_SHIFT); + break; + case CLK_SPI3: + rk_clrsetreg(&cru->clksel_con[72], + CLK_SPI3_SEL_MASK, + src_clk << CLK_SPI3_SEL_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_spi_get_clk(priv, clk_id); +} + +static ulong rk3568_pwm_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[72]); + + switch (clk_id) { + case CLK_PWM1: + sel = (con & CLK_PWM1_SEL_MASK) >> CLK_PWM3_SEL_SHIFT; + break; + case CLK_PWM2: + sel = (con & CLK_PWM2_SEL_MASK) >> CLK_PWM2_SEL_SHIFT; + break; + case CLK_PWM3: + sel = (con & CLK_PWM3_SEL_MASK) >> CLK_PWM3_SEL_SHIFT; + break; + default: + return -ENOENT; + } + + switch (sel) { + case CLK_PWM_SEL_100M: + return 100 * MHz; + case CLK_PWM_SEL_24M: + return OSC_HZ; + case CLK_PWM_SEL_CPLL_100M: + return 100 * MHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_pwm_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + if (rate == 100 * MHz) + src_clk = CLK_PWM_SEL_100M; + else + src_clk = CLK_PWM_SEL_24M; + + switch (clk_id) { + case CLK_PWM1: + rk_clrsetreg(&cru->clksel_con[72], + CLK_PWM1_SEL_MASK, + src_clk << CLK_PWM1_SEL_SHIFT); + break; + case CLK_PWM2: + rk_clrsetreg(&cru->clksel_con[72], + CLK_PWM2_SEL_MASK, + src_clk << CLK_PWM2_SEL_SHIFT); + break; + case CLK_PWM3: + rk_clrsetreg(&cru->clksel_con[72], + CLK_PWM3_SEL_MASK, + src_clk << CLK_PWM3_SEL_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_pwm_get_clk(priv, clk_id); +} + +static ulong rk3568_adc_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 div, sel, con, prate; + + switch (clk_id) { + case CLK_SARADC: + return OSC_HZ; + case CLK_TSADC_TSEN: + con = readl(&cru->clksel_con[51]); + div = (con & CLK_TSADC_TSEN_DIV_MASK) >> + CLK_TSADC_TSEN_DIV_SHIFT; + sel = (con & CLK_TSADC_TSEN_SEL_MASK) >> + CLK_TSADC_TSEN_SEL_SHIFT; + if (sel == CLK_TSADC_TSEN_SEL_24M) + prate = OSC_HZ; + else + prate = 100 * MHz; + return DIV_TO_RATE(prate, div); + case CLK_TSADC: + con = readl(&cru->clksel_con[51]); + div = (con & CLK_TSADC_DIV_MASK) >> CLK_TSADC_DIV_SHIFT; + prate = rk3568_adc_get_clk(priv, CLK_TSADC_TSEN); + return DIV_TO_RATE(prate, div); + default: + return -ENOENT; + } +} + +static ulong rk3568_adc_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk_div; + ulong prate = 0; + + switch (clk_id) { + case CLK_SARADC: + return OSC_HZ; + case CLK_TSADC_TSEN: + if (!(OSC_HZ % rate)) { + src_clk_div = DIV_ROUND_UP(OSC_HZ, rate); + assert(src_clk_div - 1 <= 7); + rk_clrsetreg(&cru->clksel_con[51], + CLK_TSADC_TSEN_SEL_MASK | + CLK_TSADC_TSEN_DIV_MASK, + (CLK_TSADC_TSEN_SEL_24M << + CLK_TSADC_TSEN_SEL_SHIFT) | + (src_clk_div - 1) << + CLK_TSADC_TSEN_DIV_SHIFT); + } else { + src_clk_div = DIV_ROUND_UP(100 * MHz, rate); + assert(src_clk_div - 1 <= 7); + rk_clrsetreg(&cru->clksel_con[51], + CLK_TSADC_TSEN_SEL_MASK | + CLK_TSADC_TSEN_DIV_MASK, + (CLK_TSADC_TSEN_SEL_100M << + CLK_TSADC_TSEN_SEL_SHIFT) | + (src_clk_div - 1) << + CLK_TSADC_TSEN_DIV_SHIFT); + } + break; + case CLK_TSADC: + prate = rk3568_adc_get_clk(priv, CLK_TSADC_TSEN); + src_clk_div = DIV_ROUND_UP(prate, rate); + assert(src_clk_div - 1 <= 128); + rk_clrsetreg(&cru->clksel_con[51], + CLK_TSADC_DIV_MASK, + (src_clk_div - 1) << CLK_TSADC_DIV_SHIFT); + break; + default: + return -ENOENT; + } + return rk3568_adc_get_clk(priv, clk_id); +} + +static ulong rk3568_crypto_get_rate(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + switch (clk_id) { + case ACLK_SECURE_FLASH: + case ACLK_CRYPTO_NS: + con = readl(&cru->clksel_con[27]); + sel = (con & ACLK_SECURE_FLASH_SEL_MASK) >> + ACLK_SECURE_FLASH_SEL_SHIFT; + if (sel == ACLK_SECURE_FLASH_SEL_200M) + return 200 * MHz; + else if (sel == ACLK_SECURE_FLASH_SEL_150M) + return 150 * MHz; + else if (sel == ACLK_SECURE_FLASH_SEL_100M) + return 100 * MHz; + else + return 24 * MHz; + case HCLK_SECURE_FLASH: + case HCLK_CRYPTO_NS: + case CLK_CRYPTO_NS_RNG: + con = readl(&cru->clksel_con[27]); + sel = (con & HCLK_SECURE_FLASH_SEL_MASK) >> + HCLK_SECURE_FLASH_SEL_SHIFT; + if (sel == HCLK_SECURE_FLASH_SEL_150M) + return 150 * MHz; + else if (sel == HCLK_SECURE_FLASH_SEL_100M) + return 100 * MHz; + else if (sel == HCLK_SECURE_FLASH_SEL_75M) + return 75 * MHz; + else + return 24 * MHz; + case CLK_CRYPTO_NS_CORE: + con = readl(&cru->clksel_con[27]); + sel = (con & CLK_CRYPTO_CORE_SEL_MASK) >> + CLK_CRYPTO_CORE_SEL_SHIFT; + if (sel == CLK_CRYPTO_CORE_SEL_200M) + return 200 * MHz; + else if (sel == CLK_CRYPTO_CORE_SEL_150M) + return 150 * MHz; + else + return 100 * MHz; + case CLK_CRYPTO_NS_PKA: + con = readl(&cru->clksel_con[27]); + sel = (con & CLK_CRYPTO_PKA_SEL_MASK) >> + CLK_CRYPTO_PKA_SEL_SHIFT; + if (sel == CLK_CRYPTO_PKA_SEL_300M) + return 300 * MHz; + else if (sel == CLK_CRYPTO_PKA_SEL_200M) + return 200 * MHz; + else + return 100 * MHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_crypto_set_rate(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + u32 src_clk, mask, shift; + + switch (clk_id) { + case ACLK_SECURE_FLASH: + case ACLK_CRYPTO_NS: + mask = ACLK_SECURE_FLASH_SEL_MASK; + shift = ACLK_SECURE_FLASH_SEL_SHIFT; + if (rate == 200 * MHz) + src_clk = ACLK_SECURE_FLASH_SEL_200M; + else if (rate == 150 * MHz) + src_clk = ACLK_SECURE_FLASH_SEL_150M; + else if (rate == 100 * MHz) + src_clk = ACLK_SECURE_FLASH_SEL_100M; + else + src_clk = ACLK_SECURE_FLASH_SEL_24M; + break; + case HCLK_SECURE_FLASH: + case HCLK_CRYPTO_NS: + case CLK_CRYPTO_NS_RNG: + mask = HCLK_SECURE_FLASH_SEL_MASK; + shift = HCLK_SECURE_FLASH_SEL_SHIFT; + if (rate == 150 * MHz) + src_clk = HCLK_SECURE_FLASH_SEL_150M; + else if (rate == 100 * MHz) + src_clk = HCLK_SECURE_FLASH_SEL_100M; + else if (rate == 75 * MHz) + src_clk = HCLK_SECURE_FLASH_SEL_75M; + else + src_clk = HCLK_SECURE_FLASH_SEL_24M; + break; + case CLK_CRYPTO_NS_CORE: + mask = CLK_CRYPTO_CORE_SEL_MASK; + shift = CLK_CRYPTO_CORE_SEL_SHIFT; + if (rate == 200 * MHz) + src_clk = CLK_CRYPTO_CORE_SEL_200M; + else if (rate == 150 * MHz) + src_clk = CLK_CRYPTO_CORE_SEL_150M; + else + src_clk = CLK_CRYPTO_CORE_SEL_100M; + break; + case CLK_CRYPTO_NS_PKA: + mask = CLK_CRYPTO_PKA_SEL_MASK; + shift = CLK_CRYPTO_PKA_SEL_SHIFT; + if (rate == 300 * MHz) + src_clk = CLK_CRYPTO_PKA_SEL_300M; + else if (rate == 200 * MHz) + src_clk = CLK_CRYPTO_PKA_SEL_200M; + else + src_clk = CLK_CRYPTO_PKA_SEL_100M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[27], mask, src_clk << shift); + + return rk3568_crypto_get_rate(priv, clk_id); +} + +static ulong rk3568_sdmmc_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + switch (clk_id) { + case HCLK_SDMMC0: + case CLK_SDMMC0: + con = readl(&cru->clksel_con[30]); + sel = (con & CLK_SDMMC0_SEL_MASK) >> CLK_SDMMC0_SEL_SHIFT; + break; + case CLK_SDMMC1: + con = readl(&cru->clksel_con[30]); + sel = (con & CLK_SDMMC1_SEL_MASK) >> CLK_SDMMC1_SEL_SHIFT; + break; + case CLK_SDMMC2: + con = readl(&cru->clksel_con[32]); + sel = (con & CLK_SDMMC2_SEL_MASK) >> CLK_SDMMC2_SEL_SHIFT; + break; + default: + return -ENOENT; + } + + switch (sel) { + case CLK_SDMMC_SEL_24M: + return OSC_HZ; + case CLK_SDMMC_SEL_400M: + return 400 * MHz; + case CLK_SDMMC_SEL_300M: + return 300 * MHz; + case CLK_SDMMC_SEL_100M: + return 100 * MHz; + case CLK_SDMMC_SEL_50M: + return 50 * MHz; + case CLK_SDMMC_SEL_750K: + return 750 * KHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_sdmmc_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case OSC_HZ: + src_clk = CLK_SDMMC_SEL_24M; + break; + case 400 * MHz: + src_clk = CLK_SDMMC_SEL_400M; + break; + case 300 * MHz: + src_clk = CLK_SDMMC_SEL_300M; + break; + case 100 * MHz: + src_clk = CLK_SDMMC_SEL_100M; + break; + case 52 * MHz: + case 50 * MHz: + src_clk = CLK_SDMMC_SEL_50M; + break; + case 750 * KHz: + case 400 * KHz: + src_clk = CLK_SDMMC_SEL_750K; + break; + default: + return -ENOENT; + } + + switch (clk_id) { + case HCLK_SDMMC0: + case CLK_SDMMC0: + rk_clrsetreg(&cru->clksel_con[30], + CLK_SDMMC0_SEL_MASK, + src_clk << CLK_SDMMC0_SEL_SHIFT); + break; + case CLK_SDMMC1: + rk_clrsetreg(&cru->clksel_con[30], + CLK_SDMMC1_SEL_MASK, + src_clk << CLK_SDMMC1_SEL_SHIFT); + break; + case CLK_SDMMC2: + rk_clrsetreg(&cru->clksel_con[32], + CLK_SDMMC2_SEL_MASK, + src_clk << CLK_SDMMC2_SEL_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_sdmmc_get_clk(priv, clk_id); +} + +static ulong rk3568_sfc_get_clk(struct rk3568_clk_priv *priv) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[28]); + sel = (con & SCLK_SFC_SEL_MASK) >> SCLK_SFC_SEL_SHIFT; + switch (sel) { + case SCLK_SFC_SEL_24M: + return OSC_HZ; + case SCLK_SFC_SEL_50M: + return 50 * MHz; + case SCLK_SFC_SEL_75M: + return 75 * MHz; + case SCLK_SFC_SEL_100M: + return 100 * MHz; + case SCLK_SFC_SEL_125M: + return 125 * MHz; + case SCLK_SFC_SEL_150M: + return 150 * KHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_sfc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case OSC_HZ: + src_clk = SCLK_SFC_SEL_24M; + break; + case 50 * MHz: + src_clk = SCLK_SFC_SEL_50M; + break; + case 75 * MHz: + src_clk = SCLK_SFC_SEL_75M; + break; + case 100 * MHz: + src_clk = SCLK_SFC_SEL_100M; + break; + case 125 * MHz: + src_clk = SCLK_SFC_SEL_125M; + break; + case 150 * KHz: + src_clk = SCLK_SFC_SEL_150M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[28], + SCLK_SFC_SEL_MASK, + src_clk << SCLK_SFC_SEL_SHIFT); + + return rk3568_sfc_get_clk(priv); +} + +static ulong rk3568_nand_get_clk(struct rk3568_clk_priv *priv) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[28]); + sel = (con & NCLK_NANDC_SEL_MASK) >> NCLK_NANDC_SEL_SHIFT; + switch (sel) { + case NCLK_NANDC_SEL_200M: + return 200 * MHz; + case NCLK_NANDC_SEL_150M: + return 150 * MHz; + case NCLK_NANDC_SEL_100M: + return 100 * MHz; + case NCLK_NANDC_SEL_24M: + return OSC_HZ; + default: + return -ENOENT; + } +} + +static ulong rk3568_nand_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case OSC_HZ: + src_clk = NCLK_NANDC_SEL_24M; + break; + case 100 * MHz: + src_clk = NCLK_NANDC_SEL_100M; + break; + case 150 * MHz: + src_clk = NCLK_NANDC_SEL_150M; + break; + case 200 * MHz: + src_clk = NCLK_NANDC_SEL_200M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[28], + NCLK_NANDC_SEL_MASK, + src_clk << NCLK_NANDC_SEL_SHIFT); + + return rk3568_nand_get_clk(priv); +} + +static ulong rk3568_emmc_get_clk(struct rk3568_clk_priv *priv) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[28]); + sel = (con & CCLK_EMMC_SEL_MASK) >> CCLK_EMMC_SEL_SHIFT; + switch (sel) { + case CCLK_EMMC_SEL_200M: + return 200 * MHz; + case CCLK_EMMC_SEL_150M: + return 150 * MHz; + case CCLK_EMMC_SEL_100M: + return 100 * MHz; + case CCLK_EMMC_SEL_50M: + return 50 * MHz; + case CCLK_EMMC_SEL_375K: + return 375 * KHz; + case CCLK_EMMC_SEL_24M: + return OSC_HZ; + default: + return -ENOENT; + } +} + +static ulong rk3568_emmc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case OSC_HZ: + src_clk = CCLK_EMMC_SEL_24M; + break; + case 52 * MHz: + case 50 * MHz: + src_clk = CCLK_EMMC_SEL_50M; + break; + case 100 * MHz: + src_clk = CCLK_EMMC_SEL_100M; + break; + case 150 * MHz: + src_clk = CCLK_EMMC_SEL_150M; + break; + case 200 * MHz: + src_clk = CCLK_EMMC_SEL_200M; + break; + case 400 * KHz: + case 375 * KHz: + src_clk = CCLK_EMMC_SEL_375K; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[28], + CCLK_EMMC_SEL_MASK, + src_clk << CCLK_EMMC_SEL_SHIFT); + + return rk3568_emmc_get_clk(priv); +} + +#ifndef CONFIG_SPL_BUILD +static ulong rk3568_aclk_vop_get_clk(struct rk3568_clk_priv *priv) +{ + struct rk3568_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[38]); + div = (con & ACLK_VOP_PRE_DIV_MASK) >> ACLK_VOP_PRE_DIV_SHIFT; + sel = (con & ACLK_VOP_PRE_SEL_MASK) >> ACLK_VOP_PRE_SEL_SHIFT; + if (sel == ACLK_VOP_PRE_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == ACLK_VOP_PRE_SEL_CPLL) + parent = priv->cpll_hz; + else if (sel == ACLK_VOP_PRE_SEL_VPLL) + parent = priv->vpll_hz; + else + parent = priv->hpll_hz; + + return DIV_TO_RATE(parent, div); +} + +static ulong rk3568_aclk_vop_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk_div, src_clk_mux; + + if ((priv->cpll_hz % rate) == 0) { + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + src_clk_mux = ACLK_VOP_PRE_SEL_CPLL; + } else { + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + src_clk_mux = ACLK_VOP_PRE_SEL_GPLL; + } + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[38], + ACLK_VOP_PRE_SEL_MASK | ACLK_VOP_PRE_DIV_MASK, + src_clk_mux << ACLK_VOP_PRE_SEL_SHIFT | + (src_clk_div - 1) << ACLK_VOP_PRE_DIV_SHIFT); + + return rk3568_aclk_vop_get_clk(priv); +} + +static ulong rk3568_dclk_vop_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 conid, div, sel, con, parent; + + switch (clk_id) { + case DCLK_VOP0: + conid = 39; + break; + case DCLK_VOP1: + conid = 40; + break; + case DCLK_VOP2: + conid = 41; + break; + default: + return -ENOENT; + } + + con = readl(&cru->clksel_con[conid]); + div = (con & DCLK0_VOP_DIV_MASK) >> DCLK0_VOP_DIV_SHIFT; + sel = (con & DCLK0_VOP_SEL_MASK) >> DCLK0_VOP_SEL_SHIFT; + if (sel == DCLK_VOP_SEL_HPLL) + parent = rk3568_pmu_pll_get_rate(priv, HPLL); + else if (sel == DCLK_VOP_SEL_VPLL) + parent = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL], + priv->cru, VPLL); + else if (sel == DCLK_VOP_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == DCLK_VOP_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +#define RK3568_VOP_PLL_LIMIT_FREQ 600000000 + +static ulong rk3568_dclk_vop_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + ulong pll_rate, now, best_rate = 0; + u32 i, conid, con, sel, div, best_div = 0, best_sel = 0; + + switch (clk_id) { + case DCLK_VOP0: + conid = 39; + break; + case DCLK_VOP1: + conid = 40; + break; + case DCLK_VOP2: + conid = 41; + break; + default: + return -ENOENT; + } + + con = readl(&cru->clksel_con[conid]); + sel = (con & DCLK0_VOP_SEL_MASK) >> DCLK0_VOP_SEL_SHIFT; + + if (sel == DCLK_VOP_SEL_HPLL) { + div = 1; + rk_clrsetreg(&cru->clksel_con[conid], + DCLK0_VOP_DIV_MASK | DCLK0_VOP_SEL_MASK, + (DCLK_VOP_SEL_HPLL << DCLK0_VOP_SEL_SHIFT) | + ((div - 1) << DCLK0_VOP_DIV_SHIFT)); + rk3568_pmu_pll_set_rate(priv, HPLL, div * rate); + } else if (sel == DCLK_VOP_SEL_VPLL) { + div = DIV_ROUND_UP(RK3568_VOP_PLL_LIMIT_FREQ, rate); + rk_clrsetreg(&cru->clksel_con[conid], + DCLK0_VOP_DIV_MASK | DCLK0_VOP_SEL_MASK, + (DCLK_VOP_SEL_VPLL << DCLK0_VOP_SEL_SHIFT) | + ((div - 1) << DCLK0_VOP_DIV_SHIFT)); + rockchip_pll_set_rate(&rk3568_pll_clks[VPLL], + priv->cru, VPLL, div * rate); + } else { + for (i = 0; i <= DCLK_VOP_SEL_CPLL; i++) { + switch (i) { + case DCLK_VOP_SEL_GPLL: + pll_rate = priv->gpll_hz; + break; + case DCLK_VOP_SEL_CPLL: + pll_rate = priv->cpll_hz; + break; + default: + printf("do not support this vop pll sel\n"); + return -EINVAL; + } + + div = DIV_ROUND_UP(pll_rate, rate); + if (div > 255) + continue; + now = pll_rate / div; + if (abs(rate - now) < abs(rate - best_rate)) { + best_rate = now; + best_div = div; + best_sel = i; + } + debug("p_rate=%lu, best_rate=%lu, div=%u, sel=%u\n", + pll_rate, best_rate, best_div, best_sel); + } + + if (best_rate) { + rk_clrsetreg(&cru->clksel_con[conid], + DCLK0_VOP_DIV_MASK | DCLK0_VOP_SEL_MASK, + best_sel << DCLK0_VOP_SEL_SHIFT | + (best_div - 1) << DCLK0_VOP_DIV_SHIFT); + } else { + printf("do not support this vop freq %lu\n", rate); + return -EINVAL; + } + } + return rk3568_dclk_vop_get_clk(priv, clk_id); +} + +static ulong rk3568_gmac_src_get_clk(struct rk3568_clk_priv *priv, + ulong mac_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[31 + mac_id * 2]); + sel = (con & CLK_MAC0_2TOP_SEL_MASK) >> CLK_MAC0_2TOP_SEL_SHIFT; + + switch (sel) { + case CLK_MAC0_2TOP_SEL_125M: + return 125 * MHz; + case CLK_MAC0_2TOP_SEL_50M: + return 50 * MHz; + case CLK_MAC0_2TOP_SEL_25M: + return 25 * MHz; + case CLK_MAC0_2TOP_SEL_PPLL: + return rk3568_pmu_pll_get_rate(priv, HPLL); + default: + return -ENOENT; + } +} + +static ulong rk3568_gmac_src_set_clk(struct rk3568_clk_priv *priv, + ulong mac_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case 125 * MHz: + src_clk = CLK_MAC0_2TOP_SEL_125M; + break; + case 50 * MHz: + src_clk = CLK_MAC0_2TOP_SEL_50M; + break; + case 25 * MHz: + src_clk = CLK_MAC0_2TOP_SEL_25M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2], + CLK_MAC0_2TOP_SEL_MASK, + src_clk << CLK_MAC0_2TOP_SEL_SHIFT); + + return rk3568_gmac_src_get_clk(priv, mac_id); +} + +static ulong rk3568_gmac_out_get_clk(struct rk3568_clk_priv *priv, + ulong mac_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[31 + mac_id * 2]); + sel = (con & CLK_MAC0_OUT_SEL_MASK) >> CLK_MAC0_OUT_SEL_SHIFT; + + switch (sel) { + case CLK_MAC0_OUT_SEL_125M: + return 125 * MHz; + case CLK_MAC0_OUT_SEL_50M: + return 50 * MHz; + case CLK_MAC0_OUT_SEL_25M: + return 25 * MHz; + case CLK_MAC0_OUT_SEL_24M: + return OSC_HZ; + default: + return -ENOENT; + } +} + +static ulong rk3568_gmac_out_set_clk(struct rk3568_clk_priv *priv, + ulong mac_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case 125 * MHz: + src_clk = CLK_MAC0_OUT_SEL_125M; + break; + case 50 * MHz: + src_clk = CLK_MAC0_OUT_SEL_50M; + break; + case 25 * MHz: + src_clk = CLK_MAC0_OUT_SEL_25M; + break; + case 24 * MHz: + src_clk = CLK_MAC0_OUT_SEL_24M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2], + CLK_MAC0_OUT_SEL_MASK, + src_clk << CLK_MAC0_OUT_SEL_SHIFT); + + return rk3568_gmac_out_get_clk(priv, mac_id); +} + +static ulong rk3568_gmac_ptp_ref_get_clk(struct rk3568_clk_priv *priv, + ulong mac_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 sel, con; + + con = readl(&cru->clksel_con[31 + mac_id * 2]); + sel = (con & CLK_GMAC0_PTP_REF_SEL_MASK) >> CLK_GMAC0_PTP_REF_SEL_SHIFT; + + switch (sel) { + case CLK_GMAC0_PTP_REF_SEL_62_5M: + return 62500 * KHz; + case CLK_GMAC0_PTP_REF_SEL_100M: + return 100 * MHz; + case CLK_GMAC0_PTP_REF_SEL_50M: + return 50 * MHz; + case CLK_GMAC0_PTP_REF_SEL_24M: + return OSC_HZ; + default: + return -ENOENT; + } +} + +static ulong rk3568_gmac_ptp_ref_set_clk(struct rk3568_clk_priv *priv, + ulong mac_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk; + + switch (rate) { + case 62500 * KHz: + src_clk = CLK_GMAC0_PTP_REF_SEL_62_5M; + break; + case 100 * MHz: + src_clk = CLK_GMAC0_PTP_REF_SEL_100M; + break; + case 50 * MHz: + src_clk = CLK_GMAC0_PTP_REF_SEL_50M; + break; + case 24 * MHz: + src_clk = CLK_GMAC0_PTP_REF_SEL_24M; + break; + default: + return -ENOENT; + } + + rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2], + CLK_GMAC0_PTP_REF_SEL_MASK, + src_clk << CLK_GMAC0_PTP_REF_SEL_SHIFT); + + return rk3568_gmac_ptp_ref_get_clk(priv, mac_id); +} + +static ulong rk3568_gmac_tx_rx_set_clk(struct rk3568_clk_priv *priv, + ulong mac_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, sel, div_sel; + + con = readl(&cru->clksel_con[31 + mac_id * 2]); + sel = (con & RMII0_MODE_MASK) >> RMII0_MODE_SHIFT; + + if (sel == RMII0_MODE_SEL_RGMII) { + if (rate == 2500000) + div_sel = RGMII0_CLK_SEL_2_5M; + else if (rate == 25000000) + div_sel = RGMII0_CLK_SEL_25M; + else + div_sel = RGMII0_CLK_SEL_125M; + rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2], + RGMII0_CLK_SEL_MASK, + div_sel << RGMII0_CLK_SEL_SHIFT); + } else if (sel == RMII0_MODE_SEL_RMII) { + if (rate == 2500000) + div_sel = RMII0_CLK_SEL_2_5M; + else + div_sel = RMII0_CLK_SEL_25M; + rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2], + RMII0_CLK_SEL_MASK, + div_sel << RMII0_CLK_SEL_SHIFT); + } + + return 0; +} + +static ulong rk3568_ebc_get_clk(struct rk3568_clk_priv *priv) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, div, p_rate; + + con = readl(&cru->clksel_con[79]); + div = (con & CPLL_333M_DIV_MASK) >> CPLL_333M_DIV_SHIFT; + p_rate = DIV_TO_RATE(priv->cpll_hz, div); + + con = readl(&cru->clksel_con[43]); + div = (con & DCLK_EBC_SEL_MASK) >> DCLK_EBC_SEL_SHIFT; + switch (div) { + case DCLK_EBC_SEL_GPLL_400M: + return 400 * MHz; + case DCLK_EBC_SEL_CPLL_333M: + return p_rate; + case DCLK_EBC_SEL_GPLL_200M: + return 200 * MHz; + default: + return -ENOENT; + } +} + +static ulong rk3568_ebc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[79], + CPLL_333M_DIV_MASK, + (src_clk_div - 1) << CPLL_333M_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[43], + DCLK_EBC_SEL_MASK, + DCLK_EBC_SEL_CPLL_333M << DCLK_EBC_SEL_SHIFT); + + return rk3568_ebc_get_clk(priv); +} + +static ulong rk3568_rkvdec_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 con, div, src, p_rate; + + switch (clk_id) { + case ACLK_RKVDEC_PRE: + case ACLK_RKVDEC: + con = readl(&cru->clksel_con[47]); + src = (con & ACLK_RKVDEC_SEL_MASK) >> ACLK_RKVDEC_SEL_SHIFT; + div = (con & ACLK_RKVDEC_DIV_MASK) >> ACLK_RKVDEC_DIV_SHIFT; + if (src == ACLK_RKVDEC_SEL_CPLL) + p_rate = priv->cpll_hz; + else + p_rate = priv->gpll_hz; + return DIV_TO_RATE(p_rate, div); + case CLK_RKVDEC_CORE: + con = readl(&cru->clksel_con[49]); + src = (con & CLK_RKVDEC_CORE_SEL_MASK) + >> CLK_RKVDEC_CORE_SEL_SHIFT; + div = (con & CLK_RKVDEC_CORE_DIV_MASK) + >> CLK_RKVDEC_CORE_DIV_SHIFT; + if (src == CLK_RKVDEC_CORE_SEL_CPLL) + p_rate = priv->cpll_hz; + else if (src == CLK_RKVDEC_CORE_SEL_NPLL) + p_rate = priv->npll_hz; + else if (src == CLK_RKVDEC_CORE_SEL_VPLL) + p_rate = priv->vpll_hz; + else + p_rate = priv->gpll_hz; + return DIV_TO_RATE(p_rate, div); + default: + return -ENOENT; + } +} + +static ulong rk3568_rkvdec_set_clk(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + int src_clk_div, src, p_rate; + + switch (clk_id) { + case ACLK_RKVDEC_PRE: + case ACLK_RKVDEC: + src = (readl(&cru->clksel_con[47]) & ACLK_RKVDEC_SEL_MASK) + >> ACLK_RKVDEC_SEL_SHIFT; + if (src == ACLK_RKVDEC_SEL_CPLL) + p_rate = priv->cpll_hz; + else + p_rate = priv->gpll_hz; + src_clk_div = DIV_ROUND_UP(p_rate, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[47], + ACLK_RKVDEC_SEL_MASK | + ACLK_RKVDEC_DIV_MASK, + (src << ACLK_RKVDEC_SEL_SHIFT) | + (src_clk_div - 1) << ACLK_RKVDEC_DIV_SHIFT); + break; + case CLK_RKVDEC_CORE: + src = (readl(&cru->clksel_con[49]) & CLK_RKVDEC_CORE_SEL_MASK) + >> CLK_RKVDEC_CORE_SEL_SHIFT; + if (src == CLK_RKVDEC_CORE_SEL_CPLL) + p_rate = priv->cpll_hz; + else if (src == CLK_RKVDEC_CORE_SEL_NPLL) + p_rate = priv->npll_hz; + else if (src == CLK_RKVDEC_CORE_SEL_VPLL) + p_rate = priv->vpll_hz; + else + p_rate = priv->gpll_hz; + src_clk_div = DIV_ROUND_UP(p_rate, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[49], + CLK_RKVDEC_CORE_SEL_MASK | + CLK_RKVDEC_CORE_DIV_MASK, + (src << CLK_RKVDEC_CORE_SEL_SHIFT) | + (src_clk_div - 1) << CLK_RKVDEC_CORE_DIV_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3568_rkvdec_get_clk(priv, clk_id); +} + +static ulong rk3568_uart_get_rate(struct rk3568_clk_priv *priv, ulong clk_id) +{ + struct rk3568_cru *cru = priv->cru; + u32 reg, con, fracdiv, div, src, p_src, p_rate; + unsigned long m, n; + + switch (clk_id) { + case SCLK_UART1: + reg = 52; + break; + case SCLK_UART2: + reg = 54; + break; + case SCLK_UART3: + reg = 56; + break; + case SCLK_UART4: + reg = 58; + break; + case SCLK_UART5: + reg = 60; + break; + case SCLK_UART6: + reg = 62; + break; + case SCLK_UART7: + reg = 64; + break; + case SCLK_UART8: + reg = 66; + break; + case SCLK_UART9: + reg = 68; + break; + default: + return -ENOENT; + } + con = readl(&cru->clksel_con[reg]); + src = (con & CLK_UART_SEL_MASK) >> CLK_UART_SEL_SHIFT; + div = (con & CLK_UART_SRC_DIV_MASK) >> CLK_UART_SRC_DIV_SHIFT; + p_src = (con & CLK_UART_SRC_SEL_MASK) >> CLK_UART_SRC_SEL_SHIFT; + if (p_src == CLK_UART_SRC_SEL_GPLL) + p_rate = priv->gpll_hz; + else if (p_src == CLK_UART_SRC_SEL_CPLL) + p_rate = priv->cpll_hz; + else + p_rate = 480000000; + if (src == CLK_UART_SEL_SRC) { + return DIV_TO_RATE(p_rate, div); + } else if (src == CLK_UART_SEL_FRAC) { + fracdiv = readl(&cru->clksel_con[reg + 1]); + n = fracdiv & CLK_UART_FRAC_NUMERATOR_MASK; + n >>= CLK_UART_FRAC_NUMERATOR_SHIFT; + m = fracdiv & CLK_UART_FRAC_DENOMINATOR_MASK; + m >>= CLK_UART_FRAC_DENOMINATOR_SHIFT; + return DIV_TO_RATE(p_rate, div) * n / m; + } else { + return OSC_HZ; + } +} + +static ulong rk3568_uart_set_rate(struct rk3568_clk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rk3568_cru *cru = priv->cru; + u32 reg, clk_src, uart_src, div; + unsigned long m = 0, n = 0, val; + + if (priv->gpll_hz % rate == 0) { + clk_src = CLK_UART_SRC_SEL_GPLL; + uart_src = CLK_UART_SEL_SRC; + div = DIV_ROUND_UP(priv->gpll_hz, rate); + } else if (priv->cpll_hz % rate == 0) { + clk_src = CLK_UART_SRC_SEL_CPLL; + uart_src = CLK_UART_SEL_SRC; + div = DIV_ROUND_UP(priv->gpll_hz, rate); + } else if (rate == OSC_HZ) { + clk_src = CLK_UART_SRC_SEL_GPLL; + uart_src = CLK_UART_SEL_XIN24M; + div = 2; + } else { + clk_src = CLK_UART_SRC_SEL_GPLL; + uart_src = CLK_UART_SEL_FRAC; + div = 2; + rational_best_approximation(rate, priv->gpll_hz / div, + GENMASK(16 - 1, 0), + GENMASK(16 - 1, 0), + &m, &n); + } + + switch (clk_id) { + case SCLK_UART1: + reg = 52; + break; + case SCLK_UART2: + reg = 54; + break; + case SCLK_UART3: + reg = 56; + break; + case SCLK_UART4: + reg = 58; + break; + case SCLK_UART5: + reg = 60; + break; + case SCLK_UART6: + reg = 62; + break; + case SCLK_UART7: + reg = 64; + break; + case SCLK_UART8: + reg = 66; + break; + case SCLK_UART9: + reg = 68; + break; + default: + return -ENOENT; + } + rk_clrsetreg(&cru->clksel_con[reg], + CLK_UART_SEL_MASK | CLK_UART_SRC_SEL_MASK | + CLK_UART_SRC_DIV_MASK, + (clk_src << CLK_UART_SRC_SEL_SHIFT) | + (uart_src << CLK_UART_SEL_SHIFT) | + ((div - 1) << CLK_UART_SRC_DIV_SHIFT)); + if (m && n) { + val = m << CLK_UART_FRAC_NUMERATOR_SHIFT | n; + writel(val, &cru->clksel_con[reg + 1]); + } + + return rk3568_uart_get_rate(priv, clk_id); +} +#endif + +static ulong rk3568_clk_get_rate(struct clk *clk) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + ulong rate = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + switch (clk->id) { + case PLL_APLL: + case ARMCLK: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[APLL], priv->cru, + APLL); + break; + case PLL_CPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[CPLL], priv->cru, + CPLL); + break; + case PLL_GPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[GPLL], priv->cru, + GPLL); + break; + case PLL_NPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[NPLL], priv->cru, + NPLL); + break; + case PLL_VPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL], priv->cru, + VPLL); + break; + case PLL_DPLL: + rate = rockchip_pll_get_rate(&rk3568_pll_clks[DPLL], priv->cru, + DPLL); + break; + case ACLK_BUS: + case PCLK_BUS: + case PCLK_WDT_NS: + rate = rk3568_bus_get_clk(priv, clk->id); + break; + case ACLK_PERIMID: + case HCLK_PERIMID: + rate = rk3568_perimid_get_clk(priv, clk->id); + break; + case ACLK_TOP_HIGH: + case ACLK_TOP_LOW: + case HCLK_TOP: + case PCLK_TOP: + rate = rk3568_top_get_clk(priv, clk->id); + break; + case CLK_I2C1: + case CLK_I2C2: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + rate = rk3568_i2c_get_clk(priv, clk->id); + break; + case CLK_SPI0: + case CLK_SPI1: + case CLK_SPI2: + case CLK_SPI3: + rate = rk3568_spi_get_clk(priv, clk->id); + break; + case CLK_PWM1: + case CLK_PWM2: + case CLK_PWM3: + rate = rk3568_pwm_get_clk(priv, clk->id); + break; + case CLK_SARADC: + case CLK_TSADC_TSEN: + case CLK_TSADC: + rate = rk3568_adc_get_clk(priv, clk->id); + break; + case HCLK_SDMMC0: + case CLK_SDMMC0: + case CLK_SDMMC1: + case CLK_SDMMC2: + rate = rk3568_sdmmc_get_clk(priv, clk->id); + break; + case SCLK_SFC: + rate = rk3568_sfc_get_clk(priv); + break; + case NCLK_NANDC: + rate = rk3568_nand_get_clk(priv); + break; + case CCLK_EMMC: + rate = rk3568_emmc_get_clk(priv); + break; +#ifndef CONFIG_SPL_BUILD + case ACLK_VOP: + rate = rk3568_aclk_vop_get_clk(priv); + break; + case DCLK_VOP0: + case DCLK_VOP1: + case DCLK_VOP2: + rate = rk3568_dclk_vop_get_clk(priv, clk->id); + break; + case SCLK_GMAC0: + case CLK_MAC0_2TOP: + case CLK_MAC0_REFOUT: + rate = rk3568_gmac_src_get_clk(priv, 0); + break; + case CLK_MAC0_OUT: + rate = rk3568_gmac_out_get_clk(priv, 0); + break; + case CLK_GMAC0_PTP_REF: + rate = rk3568_gmac_ptp_ref_get_clk(priv, 0); + break; + case SCLK_GMAC1: + case CLK_MAC1_2TOP: + case CLK_MAC1_REFOUT: + rate = rk3568_gmac_src_get_clk(priv, 1); + break; + case CLK_MAC1_OUT: + rate = rk3568_gmac_out_get_clk(priv, 1); + break; + case CLK_GMAC1_PTP_REF: + rate = rk3568_gmac_ptp_ref_get_clk(priv, 1); + break; + case DCLK_EBC: + rate = rk3568_ebc_get_clk(priv); + break; + case ACLK_RKVDEC_PRE: + case ACLK_RKVDEC: + case CLK_RKVDEC_CORE: + rate = rk3568_rkvdec_get_clk(priv, clk->id); + break; + case TCLK_WDT_NS: + rate = OSC_HZ; + break; + case SCLK_UART1: + case SCLK_UART2: + case SCLK_UART3: + case SCLK_UART4: + case SCLK_UART5: + case SCLK_UART6: + case SCLK_UART7: + case SCLK_UART8: + case SCLK_UART9: + rate = rk3568_uart_get_rate(priv, clk->id); + break; +#endif + case ACLK_SECURE_FLASH: + case ACLK_CRYPTO_NS: + case HCLK_SECURE_FLASH: + case HCLK_CRYPTO_NS: + case CLK_CRYPTO_NS_RNG: + case CLK_CRYPTO_NS_CORE: + case CLK_CRYPTO_NS_PKA: + rate = rk3568_crypto_get_rate(priv, clk->id); + break; + case CPLL_500M: + case CPLL_333M: + case CPLL_250M: + case CPLL_125M: + case CPLL_100M: + case CPLL_62P5M: + case CPLL_50M: + case CPLL_25M: + rate = rk3568_cpll_div_get_rate(priv, clk->id); + break; + default: + return -ENOENT; + } + + return rate; +}; + +static ulong rk3568_clk_set_rate(struct clk *clk, ulong rate) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + ulong ret = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + switch (clk->id) { + case PLL_APLL: + case ARMCLK: + if (priv->armclk_hz) + rk3568_armclk_set_clk(priv, rate); + priv->armclk_hz = rate; + break; + case PLL_CPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[CPLL], priv->cru, + CPLL, rate); + priv->cpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[CPLL], + priv->cru, CPLL); + break; + case PLL_GPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[GPLL], priv->cru, + GPLL, rate); + priv->gpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[GPLL], + priv->cru, GPLL); + break; + case PLL_NPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[NPLL], priv->cru, + NPLL, rate); + break; + case PLL_VPLL: + ret = rockchip_pll_set_rate(&rk3568_pll_clks[VPLL], priv->cru, + VPLL, rate); + priv->vpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL], + priv->cru, + VPLL); + break; + case ACLK_BUS: + case PCLK_BUS: + case PCLK_WDT_NS: + ret = rk3568_bus_set_clk(priv, clk->id, rate); + break; + case ACLK_PERIMID: + case HCLK_PERIMID: + ret = rk3568_perimid_set_clk(priv, clk->id, rate); + break; + case ACLK_TOP_HIGH: + case ACLK_TOP_LOW: + case HCLK_TOP: + case PCLK_TOP: + ret = rk3568_top_set_clk(priv, clk->id, rate); + break; + case CLK_I2C1: + case CLK_I2C2: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + ret = rk3568_i2c_set_clk(priv, clk->id, rate); + break; + case CLK_SPI0: + case CLK_SPI1: + case CLK_SPI2: + case CLK_SPI3: + ret = rk3568_spi_set_clk(priv, clk->id, rate); + break; + case CLK_PWM1: + case CLK_PWM2: + case CLK_PWM3: + ret = rk3568_pwm_set_clk(priv, clk->id, rate); + break; + case CLK_SARADC: + case CLK_TSADC_TSEN: + case CLK_TSADC: + ret = rk3568_adc_set_clk(priv, clk->id, rate); + break; + case HCLK_SDMMC0: + case CLK_SDMMC0: + case CLK_SDMMC1: + case CLK_SDMMC2: + ret = rk3568_sdmmc_set_clk(priv, clk->id, rate); + break; + case SCLK_SFC: + ret = rk3568_sfc_set_clk(priv, rate); + break; + case NCLK_NANDC: + ret = rk3568_nand_set_clk(priv, rate); + break; + case CCLK_EMMC: + ret = rk3568_emmc_set_clk(priv, rate); + break; +#ifndef CONFIG_SPL_BUILD + case ACLK_VOP: + ret = rk3568_aclk_vop_set_clk(priv, rate); + break; + case DCLK_VOP0: + case DCLK_VOP1: + case DCLK_VOP2: + ret = rk3568_dclk_vop_set_clk(priv, clk->id, rate); + break; + case SCLK_GMAC0: + case CLK_MAC0_2TOP: + case CLK_MAC0_REFOUT: + ret = rk3568_gmac_src_set_clk(priv, 0, rate); + break; + case CLK_MAC0_OUT: + ret = rk3568_gmac_out_set_clk(priv, 0, rate); + break; + case SCLK_GMAC0_RX_TX: + ret = rk3568_gmac_tx_rx_set_clk(priv, 0, rate); + break; + case CLK_GMAC0_PTP_REF: + ret = rk3568_gmac_ptp_ref_set_clk(priv, 0, rate); + break; + case SCLK_GMAC1: + case CLK_MAC1_2TOP: + case CLK_MAC1_REFOUT: + ret = rk3568_gmac_src_set_clk(priv, 1, rate); + break; + case CLK_MAC1_OUT: + ret = rk3568_gmac_out_set_clk(priv, 1, rate); + break; + case SCLK_GMAC1_RX_TX: + ret = rk3568_gmac_tx_rx_set_clk(priv, 1, rate); + break; + case CLK_GMAC1_PTP_REF: + ret = rk3568_gmac_ptp_ref_set_clk(priv, 1, rate); + break; + case DCLK_EBC: + ret = rk3568_ebc_set_clk(priv, rate); + break; + case ACLK_RKVDEC_PRE: + case ACLK_RKVDEC: + case CLK_RKVDEC_CORE: + ret = rk3568_rkvdec_set_clk(priv, clk->id, rate); + break; + case TCLK_WDT_NS: + ret = OSC_HZ; + break; + case SCLK_UART1: + case SCLK_UART2: + case SCLK_UART3: + case SCLK_UART4: + case SCLK_UART5: + case SCLK_UART6: + case SCLK_UART7: + case SCLK_UART8: + case SCLK_UART9: + ret = rk3568_uart_set_rate(priv, clk->id, rate); + break; +#endif + case ACLK_SECURE_FLASH: + case ACLK_CRYPTO_NS: + case HCLK_SECURE_FLASH: + case HCLK_CRYPTO_NS: + case CLK_CRYPTO_NS_RNG: + case CLK_CRYPTO_NS_CORE: + case CLK_CRYPTO_NS_PKA: + ret = rk3568_crypto_set_rate(priv, clk->id, rate); + break; + case CPLL_500M: + case CPLL_333M: + case CPLL_250M: + case CPLL_125M: + case CPLL_100M: + case CPLL_62P5M: + case CPLL_50M: + case CPLL_25M: + ret = rk3568_cpll_div_set_rate(priv, clk->id, rate); + break; + default: + return -ENOENT; + } + + return ret; +}; + +#if (IS_ENABLED(OF_CONTROL)) || (!IS_ENABLED(OF_PLATDATA)) +static int rk3568_gmac0_src_set_parent(struct clk *clk, struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + + if (parent->id == CLK_MAC0_2TOP) + rk_clrsetreg(&cru->clksel_con[31], + RMII0_EXTCLK_SEL_MASK, + RMII0_EXTCLK_SEL_MAC0_TOP << + RMII0_EXTCLK_SEL_SHIFT); + else + rk_clrsetreg(&cru->clksel_con[31], + RMII0_EXTCLK_SEL_MASK, + RMII0_EXTCLK_SEL_IO << RMII0_EXTCLK_SEL_SHIFT); + return 0; +} + +static int rk3568_gmac1_src_set_parent(struct clk *clk, struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + + if (parent->id == CLK_MAC1_2TOP) + rk_clrsetreg(&cru->clksel_con[33], + RMII0_EXTCLK_SEL_MASK, + RMII0_EXTCLK_SEL_MAC0_TOP << + RMII0_EXTCLK_SEL_SHIFT); + else + rk_clrsetreg(&cru->clksel_con[33], + RMII0_EXTCLK_SEL_MASK, + RMII0_EXTCLK_SEL_IO << RMII0_EXTCLK_SEL_SHIFT); + return 0; +} + +static int rk3568_gmac0_tx_rx_set_parent(struct clk *clk, struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + + if (parent->id == SCLK_GMAC0_RGMII_SPEED) + rk_clrsetreg(&cru->clksel_con[31], + RMII0_MODE_MASK, + RMII0_MODE_SEL_RGMII << RMII0_MODE_SHIFT); + else if (parent->id == SCLK_GMAC0_RMII_SPEED) + rk_clrsetreg(&cru->clksel_con[31], + RMII0_MODE_MASK, + RMII0_MODE_SEL_RMII << RMII0_MODE_SHIFT); + else + rk_clrsetreg(&cru->clksel_con[31], + RMII0_MODE_MASK, + RMII0_MODE_SEL_GMII << RMII0_MODE_SHIFT); + + return 0; +} + +static int rk3568_gmac1_tx_rx_set_parent(struct clk *clk, struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + + if (parent->id == SCLK_GMAC1_RGMII_SPEED) + rk_clrsetreg(&cru->clksel_con[33], + RMII0_MODE_MASK, + RMII0_MODE_SEL_RGMII << RMII0_MODE_SHIFT); + else if (parent->id == SCLK_GMAC1_RMII_SPEED) + rk_clrsetreg(&cru->clksel_con[33], + RMII0_MODE_MASK, + RMII0_MODE_SEL_RMII << RMII0_MODE_SHIFT); + else + rk_clrsetreg(&cru->clksel_con[33], + RMII0_MODE_MASK, + RMII0_MODE_SEL_GMII << RMII0_MODE_SHIFT); + + return 0; +} + +static int __maybe_unused rk3568_dclk_vop_set_parent(struct clk *clk, + struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + u32 con_id; + + switch (clk->id) { + case DCLK_VOP0: + con_id = 39; + break; + case DCLK_VOP1: + con_id = 40; + break; + case DCLK_VOP2: + con_id = 41; + break; + default: + return -EINVAL; + } + if (parent->id == PLL_VPLL) { + rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, + DCLK_VOP_SEL_VPLL << DCLK0_VOP_SEL_SHIFT); + } else { + rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK, + DCLK_VOP_SEL_HPLL << DCLK0_VOP_SEL_SHIFT); + } + + return 0; +} + +static int __maybe_unused rk3568_rkvdec_set_parent(struct clk *clk, + struct clk *parent) +{ + struct rk3568_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3568_cru *cru = priv->cru; + u32 con_id, mask, shift; + + switch (clk->id) { + case ACLK_RKVDEC_PRE: + con_id = 47; + mask = ACLK_RKVDEC_SEL_MASK; + shift = ACLK_RKVDEC_SEL_SHIFT; + break; + case CLK_RKVDEC_CORE: + con_id = 49; + mask = CLK_RKVDEC_CORE_SEL_MASK; + shift = CLK_RKVDEC_CORE_SEL_SHIFT; + break; + default: + return -EINVAL; + } + if (parent->id == PLL_CPLL) { + rk_clrsetreg(&cru->clksel_con[con_id], mask, + ACLK_RKVDEC_SEL_CPLL << shift); + } else { + rk_clrsetreg(&cru->clksel_con[con_id], mask, + ACLK_RKVDEC_SEL_GPLL << shift); + } + + return 0; +} + +static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) +{ + switch (clk->id) { + case SCLK_GMAC0: + return rk3568_gmac0_src_set_parent(clk, parent); + case SCLK_GMAC1: + return rk3568_gmac1_src_set_parent(clk, parent); + case SCLK_GMAC0_RX_TX: + return rk3568_gmac0_tx_rx_set_parent(clk, parent); + case SCLK_GMAC1_RX_TX: + return rk3568_gmac1_tx_rx_set_parent(clk, parent); + case DCLK_VOP0: + case DCLK_VOP1: + case DCLK_VOP2: + return rk3568_dclk_vop_set_parent(clk, parent); + case ACLK_RKVDEC_PRE: + case CLK_RKVDEC_CORE: + return rk3568_rkvdec_set_parent(clk, parent); + default: + return -ENOENT; + } + + return 0; +} +#endif + +static struct clk_ops rk3568_clk_ops = { + .get_rate = rk3568_clk_get_rate, + .set_rate = rk3568_clk_set_rate, +#if (IS_ENABLED(OF_CONTROL)) || (!IS_ENABLED(OF_PLATDATA)) + .set_parent = rk3568_clk_set_parent, +#endif +}; + +static void rk3568_clk_init(struct rk3568_clk_priv *priv) +{ + int ret; + + priv->sync_kernel = false; + if (!priv->armclk_enter_hz) { + priv->armclk_enter_hz = + rockchip_pll_get_rate(&rk3568_pll_clks[APLL], + priv->cru, APLL); + priv->armclk_init_hz = priv->armclk_enter_hz; + } + + if (priv->armclk_init_hz != APLL_HZ) { + ret = rk3568_armclk_set_clk(priv, APLL_HZ); + if (!ret) + priv->armclk_init_hz = APLL_HZ; + } + if (priv->cpll_hz != CPLL_HZ) { + ret = rockchip_pll_set_rate(&rk3568_pll_clks[CPLL], priv->cru, + CPLL, CPLL_HZ); + if (!ret) + priv->cpll_hz = CPLL_HZ; + } + if (priv->gpll_hz != GPLL_HZ) { + ret = rockchip_pll_set_rate(&rk3568_pll_clks[GPLL], priv->cru, + GPLL, GPLL_HZ); + if (!ret) + priv->gpll_hz = GPLL_HZ; + } + +#ifdef CONFIG_SPL_BUILD + ret = rk3568_bus_set_clk(priv, ACLK_BUS, 150000000); + if (ret < 0) + printf("Fail to set the ACLK_BUS clock.\n"); +#endif + + priv->ppll_hz = rk3568_pmu_pll_get_rate(priv, PPLL); + priv->hpll_hz = rk3568_pmu_pll_get_rate(priv, HPLL); +} + +static int rk3568_clk_probe(struct udevice *dev) +{ + struct rk3568_clk_priv *priv = dev_get_priv(dev); + int ret; + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (IS_ERR(priv->grf)) + return PTR_ERR(priv->grf); + + rk3568_clk_init(priv); + + /* Process 'assigned-{clocks/clock-parents/clock-rates}' properties */ + ret = clk_set_defaults(dev, 1); + if (ret) + debug("%s clk_set_defaults failed %d\n", __func__, ret); + else + priv->sync_kernel = true; + + return 0; +} + +static int rk3568_clk_ofdata_to_platdata(struct udevice *dev) +{ + struct rk3568_clk_priv *priv = dev_get_priv(dev); + + priv->cru = dev_read_addr_ptr(dev); + + return 0; +} + +static int rk3568_clk_bind(struct udevice *dev) +{ + int ret; + struct udevice *sys_child; + struct sysreset_reg *priv; + + /* The reset driver does not have a device node, so bind it here */ + ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset", + &sys_child); + if (ret) { + debug("Warning: No sysreset driver: ret=%d\n", ret); + } else { + priv = malloc(sizeof(struct sysreset_reg)); + priv->glb_srst_fst_value = offsetof(struct rk3568_cru, + glb_srst_fst); + priv->glb_srst_snd_value = offsetof(struct rk3568_cru, + glb_srsr_snd); + } + +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) + ret = offsetof(struct rk3568_cru, softrst_con[0]); + ret = rockchip_reset_bind(dev, ret, 30); + if (ret) + debug("Warning: software reset driver bind faile\n"); +#endif + + return 0; +} + +static const struct udevice_id rk3568_clk_ids[] = { + { .compatible = "rockchip,rk3568-cru" }, + { } +}; + +U_BOOT_DRIVER(rockchip_rk3568_cru) = { + .name = "rockchip_rk3568_cru", + .id = UCLASS_CLK, + .of_match = rk3568_clk_ids, + .priv_auto = sizeof(struct rk3568_clk_priv), + .of_to_plat = rk3568_clk_ofdata_to_platdata, + .ops = &rk3568_clk_ops, + .bind = rk3568_clk_bind, + .probe = rk3568_clk_probe, +#if CONFIG_IS_ENABLED(OF_PLATDATA) + .plat_auto = sizeof(struct rk3568_clk_plat), +#endif +};
Hi Elaine,
Thanks for your patch, pls update the copyright info and remove unused clock set/get.
On 2021/5/19 下午4:49, Elaine Zhang wrote:
Add rk3568 clock driver and cru structure definition.
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com
.../include/asm/arch-rockchip/cru_rk3568.h | 504 +++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk3568.c | 2908 +++++++++++++++++ 3 files changed, 3413 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3568.h create mode 100644 drivers/clk/rockchip/clk_rk3568.c
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h new file mode 100644 index 000000000000..6c59033f03a6 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h @@ -0,0 +1,504 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Copyright (c) 2021 Rockchip Electronics Co. Ltd.
- Author: Elaine Zhang zhangqing@rock-chips.com
+#ifndef _ASM_ARCH_CRU_RK3568_H +#define _ASM_ARCH_CRU_RK3568_H
+#define MHz 1000000 +#define KHz 1000 +#define OSC_HZ (24 * MHz)
+#define APLL_HZ (816 * MHz) +#define GPLL_HZ (1188 * MHz) +#define CPLL_HZ (1000 * MHz) +#define PPLL_HZ (100 * MHz)
+/* RK3568 pll id */ +enum rk3568_pll_id {
- APLL,
- DPLL,
- CPLL,
- GPLL,
- NPLL,
- VPLL,
- PPLL,
- HPLL,
- PLL_COUNT,
+struct rk3568_clk_info {
- unsigned long id;
- char *name;
- bool is_cru;
+/* Private data for the clock driver - used by rockchip_get_cru() */ +struct rk3568_pmuclk_priv {
- struct rk3568_pmucru *pmucru;
- ulong ppll_hz;
- ulong hpll_hz;
+struct rk3568_clk_priv {
- struct rk3568_cru *cru;
- struct rk3568_grf *grf;
- ulong ppll_hz;
- ulong hpll_hz;
- ulong gpll_hz;
- ulong cpll_hz;
- ulong npll_hz;
- ulong vpll_hz;
- ulong armclk_hz;
- ulong armclk_enter_hz;
- ulong armclk_init_hz;
- bool sync_kernel;
- bool set_armclk_rate;
+struct rk3568_pll {
- unsigned int con0;
- unsigned int con1;
- unsigned int con2;
- unsigned int con3;
- unsigned int con4;
- unsigned int reserved0[3];
+struct rk3568_pmucru {
- struct rk3568_pll pll[2];/* Address Offset: 0x0000 */
- unsigned int reserved0[16];/* Address Offset: 0x0040 */
- unsigned int mode_con00;/* Address Offset: 0x0080 */
- unsigned int reserved1[31];/* Address Offset: 0x0084 */
- unsigned int pmu_clksel_con[10];/* Address Offset: 0x0100 */
- unsigned int reserved2[22];/* Address Offset: 0x0128 */
- unsigned int pmu_clkgate_con[3];/* Address Offset: 0x0180 */
- unsigned int reserved3[29];/* Address Offset: 0x018C */
- unsigned int pmu_softrst_con[1];/* Address Offset: 0x0200 */
+check_member(rk3568_pmucru, mode_con00, 0x80); +check_member(rk3568_pmucru, pmu_softrst_con[0], 0x200);
+struct rk3568_cru {
- struct rk3568_pll pll[6];
- unsigned int mode_con00;/* Address Offset: 0x00C0 */
- unsigned int misc_con[3];/* Address Offset: 0x00C4 */
- unsigned int glb_cnt_th;/* Address Offset: 0x00D0 */
- unsigned int glb_srst_fst;/* Address Offset: 0x00D4 */
- unsigned int glb_srsr_snd; /* Address Offset: 0x00D8 */
- unsigned int glb_rst_con;/* Address Offset: 0x00DC */
- unsigned int glb_rst_st;/* Address Offset: 0x00E0 */
- unsigned int reserved0[7];/* Address Offset: 0x00E4 */
- unsigned int clksel_con[85]; /* Address Offset: 0x0100 */
- unsigned int reserved1[43];/* Address Offset: 0x0254 */
- unsigned int clkgate_con[36];/* Address Offset: 0x0300 */
- unsigned int reserved2[28]; /* Address Offset: 0x0390 */
- unsigned int softrst_con[30];/* Address Offset: 0x0400 */
- unsigned int reserved3[2];/* Address Offset: 0x0478 */
- unsigned int ssgtbl[32];/* Address Offset: 0x0480 */
- unsigned int reserved4[32];/* Address Offset: 0x0500 */
- unsigned int sdmmc0_con[2];/* Address Offset: 0x0580 */
- unsigned int sdmmc1_con[2];/* Address Offset: 0x058C */
- unsigned int sdmmc2_con[2];/* Address Offset: 0x0590 */
- unsigned int emmc_con[2];/* Address Offset: 0x0598 */
+check_member(rk3568_cru, mode_con00, 0xc0); +check_member(rk3568_cru, softrst_con[0], 0x400);
+struct pll_rate_table {
- unsigned long rate;
- unsigned int fbdiv;
- unsigned int postdiv1;
- unsigned int refdiv;
- unsigned int postdiv2;
- unsigned int dsmpd;
- unsigned int frac;
+#define RK3568_PMU_MODE 0x80 +#define RK3568_PMU_PLL_CON(x) ((x) * 0x4) +#define RK3568_PLL_CON(x) ((x) * 0x4) +#define RK3568_MODE_CON 0xc0
+enum {
- /* CRU_PMU_CLK_SEL0_CON */
- RTC32K_SEL_SHIFT = 6,
- RTC32K_SEL_MASK = 0x3 << RTC32K_SEL_SHIFT,
- RTC32K_SEL_PMUPVTM = 0,
- RTC32K_SEL_OSC1_32K,
- RTC32K_SEL_OSC0_DIV32K,
- /* CRU_PMU_CLK_SEL1_CON */
- RTC32K_FRAC_NUMERATOR_SHIFT = 16,
- RTC32K_FRAC_NUMERATOR_MASK = 0xffff << 16,
- RTC32K_FRAC_DENOMINATOR_SHIFT = 0,
- RTC32K_FRAC_DENOMINATOR_MASK = 0xffff,
- /* CRU_PMU_CLK_SEL2_CON */
- PCLK_PDPMU_SEL_SHIFT = 15,
- PCLK_PDPMU_SEL_MASK = 1 << PCLK_PDPMU_SEL_SHIFT,
- PCLK_PDPMU_SEL_PPLL = 0,
- PCLK_PDPMU_SEL_GPLL,
- PCLK_PDPMU_DIV_SHIFT = 0,
- PCLK_PDPMU_DIV_MASK = 0x1f,
- /* CRU_PMU_CLK_SEL3_CON */
- CLK_I2C0_DIV_SHIFT = 0,
- CLK_I2C0_DIV_MASK = 0x7f,
- /* CRU_PMU_CLK_SEL6_CON */
- CLK_PWM0_SEL_SHIFT = 7,
- CLK_PWM0_SEL_MASK = 1 << CLK_PWM0_SEL_SHIFT,
- CLK_PWM0_SEL_XIN24M = 0,
- CLK_PWM0_SEL_PPLL,
- CLK_PWM0_DIV_SHIFT = 0,
- CLK_PWM0_DIV_MASK = 0x7f,
- /* CRU_CLK_SEL0_CON */
- CLK_CORE_PRE_SEL_SHIFT = 7,
- CLK_CORE_PRE_SEL_MASK = 1 << CLK_CORE_PRE_SEL_SHIFT,
- CLK_CORE_PRE_SEL_SRC = 0,
- CLK_CORE_PRE_SEL_APLL,
- /* CRU_CLK_SEL2_CON */
- SCLK_CORE_PRE_SEL_SHIFT = 15,
- SCLK_CORE_PRE_SEL_MASK = 1 << SCLK_CORE_PRE_SEL_SHIFT,
- SCLK_CORE_PRE_SEL_SRC = 0,
- SCLK_CORE_PRE_SEL_NPLL,
- SCLK_CORE_SRC_SEL_SHIFT = 8,
- SCLK_CORE_SRC_SEL_MASK = 3 << SCLK_CORE_SRC_SEL_SHIFT,
- SCLK_CORE_SRC_SEL_APLL = 0,
- SCLK_CORE_SRC_SEL_GPLL,
- SCLK_CORE_SRC_SEL_NPLL,
- SCLK_CORE_SRC_DIV_SHIFT = 0,
- SCLK_CORE_SRC_DIV_MASK = 0x1f << SCLK_CORE_SRC_DIV_SHIFT,
- /* CRU_CLK_SEL3_CON */
- GICCLK_CORE_DIV_SHIFT = 8,
- GICCLK_CORE_DIV_MASK = 0x1f << GICCLK_CORE_DIV_SHIFT,
- ATCLK_CORE_DIV_SHIFT = 0,
- ATCLK_CORE_DIV_MASK = 0x1f << ATCLK_CORE_DIV_SHIFT,
- /* CRU_CLK_SEL4_CON */
- PERIPHCLK_CORE_PRE_DIV_SHIFT = 8,
- PERIPHCLK_CORE_PRE_DIV_MASK = 0x1f << PERIPHCLK_CORE_PRE_DIV_SHIFT,
- PCLK_CORE_PRE_DIV_SHIFT = 0,
- PCLK_CORE_PRE_DIV_MASK = 0x1f << PCLK_CORE_PRE_DIV_SHIFT,
- /* CRU_CLK_SEL5_CON */
- ACLK_CORE_NIU2BUS_SEL_SHIFT = 14,
- ACLK_CORE_NIU2BUS_SEL_MASK = 0x3 << ACLK_CORE_NIU2BUS_SEL_SHIFT,
- ACLK_CORE_NDFT_DIV_SHIFT = 8,
- ACLK_CORE_NDFT_DIV_MASK = 0x1f << ACLK_CORE_NDFT_DIV_SHIFT,
- /* CRU_CLK_SEL10_CON */
- HCLK_PERIMID_SEL_SHIFT = 6,
- HCLK_PERIMID_SEL_MASK = 3 << HCLK_PERIMID_SEL_SHIFT,
- HCLK_PERIMID_SEL_150M = 0,
- HCLK_PERIMID_SEL_100M,
- HCLK_PERIMID_SEL_75M,
- HCLK_PERIMID_SEL_24M,
- ACLK_PERIMID_SEL_SHIFT = 4,
- ACLK_PERIMID_SEL_MASK = 3 << ACLK_PERIMID_SEL_SHIFT,
- ACLK_PERIMID_SEL_300M = 0,
- ACLK_PERIMID_SEL_200M,
- ACLK_PERIMID_SEL_100M,
- ACLK_PERIMID_SEL_24M,
- /* CRU_CLK_SEL27_CON */
- CLK_CRYPTO_PKA_SEL_SHIFT = 6,
- CLK_CRYPTO_PKA_SEL_MASK = 3 << CLK_CRYPTO_PKA_SEL_SHIFT,
- CLK_CRYPTO_PKA_SEL_300M = 0,
- CLK_CRYPTO_PKA_SEL_200M,
- CLK_CRYPTO_PKA_SEL_100M,
- CLK_CRYPTO_CORE_SEL_SHIFT = 4,
- CLK_CRYPTO_CORE_SEL_MASK = 3 << CLK_CRYPTO_CORE_SEL_SHIFT,
- CLK_CRYPTO_CORE_SEL_200M = 0,
- CLK_CRYPTO_CORE_SEL_150M,
- CLK_CRYPTO_CORE_SEL_100M,
- HCLK_SECURE_FLASH_SEL_SHIFT = 2,
- HCLK_SECURE_FLASH_SEL_MASK = 3 << HCLK_SECURE_FLASH_SEL_SHIFT,
- HCLK_SECURE_FLASH_SEL_150M = 0,
- HCLK_SECURE_FLASH_SEL_100M,
- HCLK_SECURE_FLASH_SEL_75M,
- HCLK_SECURE_FLASH_SEL_24M,
- ACLK_SECURE_FLASH_SEL_SHIFT = 0,
- ACLK_SECURE_FLASH_SEL_MASK = 3 << ACLK_SECURE_FLASH_SEL_SHIFT,
- ACLK_SECURE_FLASH_SEL_200M = 0,
- ACLK_SECURE_FLASH_SEL_150M,
- ACLK_SECURE_FLASH_SEL_100M,
- ACLK_SECURE_FLASH_SEL_24M,
- /* CRU_CLK_SEL28_CON */
- CCLK_EMMC_SEL_SHIFT = 12,
- CCLK_EMMC_SEL_MASK = 7 << CCLK_EMMC_SEL_SHIFT,
- CCLK_EMMC_SEL_24M = 0,
- CCLK_EMMC_SEL_200M,
- CCLK_EMMC_SEL_150M,
- CCLK_EMMC_SEL_100M,
- CCLK_EMMC_SEL_50M,
- CCLK_EMMC_SEL_375K,
- BCLK_EMMC_SEL_SHIFT = 8,
- BCLK_EMMC_SEL_MASK = 3 << BCLK_EMMC_SEL_SHIFT,
- BCLK_EMMC_SEL_200M = 0,
- BCLK_EMMC_SEL_150M,
- BCLK_EMMC_SEL_125M,
- SCLK_SFC_SEL_SHIFT = 4,
- SCLK_SFC_SEL_MASK = 7 << SCLK_SFC_SEL_SHIFT,
- SCLK_SFC_SEL_24M = 0,
- SCLK_SFC_SEL_50M,
- SCLK_SFC_SEL_75M,
- SCLK_SFC_SEL_100M,
- SCLK_SFC_SEL_125M,
- SCLK_SFC_SEL_150M,
- NCLK_NANDC_SEL_SHIFT = 0,
- NCLK_NANDC_SEL_MASK = 3 << NCLK_NANDC_SEL_SHIFT,
- NCLK_NANDC_SEL_200M = 0,
- NCLK_NANDC_SEL_150M,
- NCLK_NANDC_SEL_100M,
- NCLK_NANDC_SEL_24M,
- /* CRU_CLK_SEL30_CON */
- CLK_SDMMC1_SEL_SHIFT = 12,
- CLK_SDMMC1_SEL_MASK = 7 << CLK_SDMMC1_SEL_SHIFT,
- CLK_SDMMC0_SEL_SHIFT = 8,
- CLK_SDMMC0_SEL_MASK = 7 << CLK_SDMMC0_SEL_SHIFT,
- CLK_SDMMC_SEL_24M = 0,
- CLK_SDMMC_SEL_400M,
- CLK_SDMMC_SEL_300M,
- CLK_SDMMC_SEL_100M,
- CLK_SDMMC_SEL_50M,
- CLK_SDMMC_SEL_750K,
- /* CRU_CLK_SEL31_CON */
- CLK_MAC0_OUT_SEL_SHIFT = 14,
- CLK_MAC0_OUT_SEL_MASK = 3 << CLK_MAC0_OUT_SEL_SHIFT,
- CLK_MAC0_OUT_SEL_125M = 0,
- CLK_MAC0_OUT_SEL_50M,
- CLK_MAC0_OUT_SEL_25M,
- CLK_MAC0_OUT_SEL_24M,
- CLK_GMAC0_PTP_REF_SEL_SHIFT = 12,
- CLK_GMAC0_PTP_REF_SEL_MASK = 3 << CLK_GMAC0_PTP_REF_SEL_SHIFT,
- CLK_GMAC0_PTP_REF_SEL_62_5M = 0,
- CLK_GMAC0_PTP_REF_SEL_100M,
- CLK_GMAC0_PTP_REF_SEL_50M,
- CLK_GMAC0_PTP_REF_SEL_24M,
- CLK_MAC0_2TOP_SEL_SHIFT = 8,
- CLK_MAC0_2TOP_SEL_MASK = 3 << CLK_MAC0_2TOP_SEL_SHIFT,
- CLK_MAC0_2TOP_SEL_125M = 0,
- CLK_MAC0_2TOP_SEL_50M,
- CLK_MAC0_2TOP_SEL_25M,
- CLK_MAC0_2TOP_SEL_PPLL,
- RGMII0_CLK_SEL_SHIFT = 4,
- RGMII0_CLK_SEL_MASK = 3 << RGMII0_CLK_SEL_SHIFT,
- RGMII0_CLK_SEL_125M = 0,
- RGMII0_CLK_SEL_125M_1,
- RGMII0_CLK_SEL_2_5M,
- RGMII0_CLK_SEL_25M,
- RMII0_CLK_SEL_SHIFT = 3,
- RMII0_CLK_SEL_MASK = 1 << RMII0_CLK_SEL_SHIFT,
- RMII0_CLK_SEL_2_5M = 0,
- RMII0_CLK_SEL_25M,
- RMII0_EXTCLK_SEL_SHIFT = 2,
- RMII0_EXTCLK_SEL_MASK = 1 << RMII0_EXTCLK_SEL_SHIFT,
- RMII0_EXTCLK_SEL_MAC0_TOP = 0,
- RMII0_EXTCLK_SEL_IO,
- RMII0_MODE_SHIFT = 0,
- RMII0_MODE_MASK = 3 << RMII0_MODE_SHIFT,
- RMII0_MODE_SEL_RGMII = 0,
- RMII0_MODE_SEL_RMII,
- RMII0_MODE_SEL_GMII,
- /* CRU_CLK_SEL32_CON */
- CLK_SDMMC2_SEL_SHIFT = 8,
- CLK_SDMMC2_SEL_MASK = 7 << CLK_SDMMC2_SEL_SHIFT,
- /* CRU_CLK_SEL38_CON */
- ACLK_VOP_PRE_SEL_SHIFT = 6,
- ACLK_VOP_PRE_SEL_MASK = 3 << ACLK_VOP_PRE_SEL_SHIFT,
- ACLK_VOP_PRE_SEL_CPLL = 0,
- ACLK_VOP_PRE_SEL_GPLL,
- ACLK_VOP_PRE_SEL_HPLL,
- ACLK_VOP_PRE_SEL_VPLL,
- ACLK_VOP_PRE_DIV_SHIFT = 0,
- ACLK_VOP_PRE_DIV_MASK = 0x1f << ACLK_VOP_PRE_DIV_SHIFT,
- /* CRU_CLK_SEL39_CON */
- DCLK0_VOP_SEL_SHIFT = 10,
- DCLK0_VOP_SEL_MASK = 3 << DCLK0_VOP_SEL_SHIFT,
- DCLK_VOP_SEL_HPLL = 0,
- DCLK_VOP_SEL_VPLL,
- DCLK_VOP_SEL_GPLL,
- DCLK_VOP_SEL_CPLL,
- DCLK0_VOP_DIV_SHIFT = 0,
- DCLK0_VOP_DIV_MASK = 0xff << DCLK0_VOP_DIV_SHIFT,
- /* CRU_CLK_SEL40_CON */
- DCLK1_VOP_SEL_SHIFT = 10,
- DCLK1_VOP_SEL_MASK = 3 << DCLK1_VOP_SEL_SHIFT,
- DCLK1_VOP_DIV_SHIFT = 0,
- DCLK1_VOP_DIV_MASK = 0xff << DCLK1_VOP_DIV_SHIFT,
- /* CRU_CLK_SEL41_CON */
- DCLK2_VOP_SEL_SHIFT = 10,
- DCLK2_VOP_SEL_MASK = 3 << DCLK2_VOP_SEL_SHIFT,
- DCLK2_VOP_DIV_SHIFT = 0,
- DCLK2_VOP_DIV_MASK = 0xff << DCLK2_VOP_DIV_SHIFT,
- /* CRU_CLK_SEL43_CON */
- DCLK_EBC_SEL_SHIFT = 6,
- DCLK_EBC_SEL_MASK = 3 << DCLK_EBC_SEL_SHIFT,
- DCLK_EBC_SEL_GPLL_400M = 0,
- DCLK_EBC_SEL_CPLL_333M,
- DCLK_EBC_SEL_GPLL_200M,
- /* CRU_CLK_SEL47_CON */
- ACLK_RKVDEC_SEL_SHIFT = 7,
- ACLK_RKVDEC_SEL_MASK = 1 << ACLK_RKVDEC_SEL_SHIFT,
- ACLK_RKVDEC_SEL_GPLL = 0,
- ACLK_RKVDEC_SEL_CPLL,
- ACLK_RKVDEC_DIV_SHIFT = 0,
- ACLK_RKVDEC_DIV_MASK = 0x1f << ACLK_RKVDEC_DIV_SHIFT,
- /* CRU_CLK_SEL49_CON */
- CLK_RKVDEC_CORE_SEL_SHIFT = 14,
- CLK_RKVDEC_CORE_SEL_MASK = 0x3 << CLK_RKVDEC_CORE_SEL_SHIFT,
- CLK_RKVDEC_CORE_SEL_GPLL = 0,
- CLK_RKVDEC_CORE_SEL_CPLL,
- CLK_RKVDEC_CORE_SEL_NPLL,
- CLK_RKVDEC_CORE_SEL_VPLL,
- CLK_RKVDEC_CORE_DIV_SHIFT = 8,
- CLK_RKVDEC_CORE_DIV_MASK = 0x1f << CLK_RKVDEC_CORE_DIV_SHIFT,
- /* CRU_CLK_SEL50_CON */
- PCLK_BUS_SEL_SHIFT = 4,
- PCLK_BUS_SEL_MASK = 3 << PCLK_BUS_SEL_SHIFT,
- PCLK_BUS_SEL_100M = 0,
- PCLK_BUS_SEL_75M,
- PCLK_BUS_SEL_50M,
- PCLK_BUS_SEL_24M,
- ACLK_BUS_SEL_SHIFT = 0,
- ACLK_BUS_SEL_MASK = 3 << ACLK_BUS_SEL_SHIFT,
- ACLK_BUS_SEL_200M = 0,
- ACLK_BUS_SEL_150M,
- ACLK_BUS_SEL_100M,
- ACLK_BUS_SEL_24M,
- /* CRU_CLK_SEL51_CON */
- CLK_TSADC_DIV_SHIFT = 8,
- CLK_TSADC_DIV_MASK = 0x7f << CLK_TSADC_DIV_SHIFT,
- CLK_TSADC_TSEN_SEL_SHIFT = 4,
- CLK_TSADC_TSEN_SEL_MASK = 0x3 << CLK_TSADC_TSEN_SEL_SHIFT,
- CLK_TSADC_TSEN_SEL_24M = 0,
- CLK_TSADC_TSEN_SEL_100M,
- CLK_TSADC_TSEN_SEL_CPLL_100M,
- CLK_TSADC_TSEN_DIV_SHIFT = 0,
- CLK_TSADC_TSEN_DIV_MASK = 0x7 << CLK_TSADC_TSEN_DIV_SHIFT,
- /* CRU_CLK_SEL52_CON */
- CLK_UART_SEL_SHIFT = 12,
- CLK_UART_SEL_MASK = 0x3 << CLK_UART_SEL_SHIFT,
- CLK_UART_SEL_SRC = 0,
- CLK_UART_SEL_FRAC,
- CLK_UART_SEL_XIN24M,
- CLK_UART_SRC_SEL_SHIFT = 8,
- CLK_UART_SRC_SEL_MASK = 0x3 << CLK_UART_SRC_SEL_SHIFT,
- CLK_UART_SRC_SEL_GPLL = 0,
- CLK_UART_SRC_SEL_CPLL,
- CLK_UART_SRC_SEL_480M,
- CLK_UART_SRC_DIV_SHIFT = 0,
- CLK_UART_SRC_DIV_MASK = 0x3f << CLK_UART_SRC_DIV_SHIFT,
- /* CRU_CLK_SEL53_CON */
- CLK_UART_FRAC_NUMERATOR_SHIFT = 16,
- CLK_UART_FRAC_NUMERATOR_MASK = 0xffff << 16,
- CLK_UART_FRAC_DENOMINATOR_SHIFT = 0,
- CLK_UART_FRAC_DENOMINATOR_MASK = 0xffff,
- /* CRU_CLK_SEL71_CON */
- CLK_I2C_SEL_SHIFT = 8,
- CLK_I2C_SEL_MASK = 3 << CLK_I2C_SEL_SHIFT,
- CLK_I2C_SEL_200M = 0,
- CLK_I2C_SEL_100M,
- CLK_I2C_SEL_24M,
- CLK_I2C_SEL_CPLL_100M,
- /* CRU_CLK_SEL72_CON */
- CLK_PWM3_SEL_SHIFT = 12,
- CLK_PWM3_SEL_MASK = 3 << CLK_PWM3_SEL_SHIFT,
- CLK_PWM2_SEL_SHIFT = 10,
- CLK_PWM2_SEL_MASK = 3 << CLK_PWM2_SEL_SHIFT,
- CLK_PWM1_SEL_SHIFT = 8,
- CLK_PWM1_SEL_MASK = 3 << CLK_PWM1_SEL_SHIFT,
- CLK_PWM_SEL_100M = 0,
- CLK_PWM_SEL_24M,
- CLK_PWM_SEL_CPLL_100M,
- CLK_SPI3_SEL_SHIFT = 6,
- CLK_SPI3_SEL_MASK = 3 << CLK_SPI3_SEL_SHIFT,
- CLK_SPI2_SEL_SHIFT = 4,
- CLK_SPI2_SEL_MASK = 3 << CLK_SPI2_SEL_SHIFT,
- CLK_SPI1_SEL_SHIFT = 2,
- CLK_SPI1_SEL_MASK = 3 << CLK_SPI1_SEL_SHIFT,
- CLK_SPI0_SEL_SHIFT = 0,
- CLK_SPI0_SEL_MASK = 3 << CLK_SPI0_SEL_SHIFT,
- CLK_SPI_SEL_200M = 0,
- CLK_SPI_SEL_24M,
- CLK_SPI_SEL_CPLL_100M,
- /* CRU_CLK_SEL73_CON */
- PCLK_TOP_SEL_SHIFT = 12,
- PCLK_TOP_SEL_MASK = 3 << PCLK_TOP_SEL_SHIFT,
- PCLK_TOP_SEL_100M = 0,
- PCLK_TOP_SEL_75M,
- PCLK_TOP_SEL_50M,
- PCLK_TOP_SEL_24M,
- HCLK_TOP_SEL_SHIFT = 8,
- HCLK_TOP_SEL_MASK = 3 << HCLK_TOP_SEL_SHIFT,
- HCLK_TOP_SEL_150M = 0,
- HCLK_TOP_SEL_100M,
- HCLK_TOP_SEL_75M,
- HCLK_TOP_SEL_24M,
- ACLK_TOP_LOW_SEL_SHIFT = 4,
- ACLK_TOP_LOW_SEL_MASK = 3 << ACLK_TOP_LOW_SEL_SHIFT,
- ACLK_TOP_LOW_SEL_400M = 0,
- ACLK_TOP_LOW_SEL_300M,
- ACLK_TOP_LOW_SEL_200M,
- ACLK_TOP_LOW_SEL_24M,
- ACLK_TOP_HIGH_SEL_SHIFT = 0,
- ACLK_TOP_HIGH_SEL_MASK = 3 << ACLK_TOP_HIGH_SEL_SHIFT,
- ACLK_TOP_HIGH_SEL_500M = 0,
- ACLK_TOP_HIGH_SEL_400M,
- ACLK_TOP_HIGH_SEL_300M,
- ACLK_TOP_HIGH_SEL_24M,
- /* CRU_CLK_SEL78_CON */
- CPLL_500M_DIV_SHIFT = 8,
- CPLL_500M_DIV_MASK = 0x1f << CPLL_500M_DIV_SHIFT,
- /* CRU_CLK_SEL79_CON */
- CPLL_250M_DIV_SHIFT = 8,
- CPLL_250M_DIV_MASK = 0x1f << CPLL_250M_DIV_SHIFT,
- CPLL_333M_DIV_SHIFT = 0,
- CPLL_333M_DIV_MASK = 0x1f << CPLL_333M_DIV_SHIFT,
- /* CRU_CLK_SEL80_CON */
- CPLL_62P5M_DIV_SHIFT = 8,
- CPLL_62P5M_DIV_MASK = 0x1f << CPLL_62P5M_DIV_SHIFT,
- CPLL_125M_DIV_SHIFT = 0,
- CPLL_125M_DIV_MASK = 0x1f << CPLL_125M_DIV_SHIFT,
- /* CRU_CLK_SEL81_CON */
- CPLL_25M_DIV_SHIFT = 8,
- CPLL_25M_DIV_MASK = 0x1f << CPLL_25M_DIV_SHIFT,
- CPLL_50M_DIV_SHIFT = 0,
- CPLL_50M_DIV_MASK = 0x1f << CPLL_50M_DIV_SHIFT,
- /* CRU_CLK_SEL82_CON */
- CPLL_100M_DIV_SHIFT = 0,
- CPLL_100M_DIV_MASK = 0x1f << CPLL_100M_DIV_SHIFT,
+}; +#endif diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index 4cfcf8330929..913f611a0ff8 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -14,4 +14,5 @@ obj-$(CONFIG_ROCKCHIP_RK3308) += clk_rk3308.o obj-$(CONFIG_ROCKCHIP_RK3328) += clk_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += clk_rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += clk_rk3399.o +obj-$(CONFIG_ROCKCHIP_RK3568) += clk_rk3568.o obj-$(CONFIG_ROCKCHIP_RV1108) += clk_rv1108.o diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c new file mode 100644 index 000000000000..359aca358e0d --- /dev/null +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -0,0 +1,2908 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (c) 2021 Fuzhou Rockchip Electronics Co., Ltd
Please remove "Fuzhou".
+#include <common.h> +#include <bitfield.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/arch-rockchip/cru_rk3568.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/io.h> +#include <dm/lists.h> +#include <dt-bindings/clock/rk3568-cru.h>
+DECLARE_GLOBAL_DATA_PTR;
+#if CONFIG_IS_ENABLED(OF_PLATDATA) +struct rk3568_clk_plat {
- struct dtd_rockchip_rk3568_cru dtd;
+struct rk3568_pmuclk_plat {
- struct dtd_rockchip_rk3568_pmucru dtd;
+}; +#endif
+#define RK3568_CPUCLK_RATE(_rate, _aclk_div, _pclk_div) \ +{ \
- .rate = _rate##U, \
- .aclk_div = _aclk_div, \
- .pclk_div = _pclk_div, \
+#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1))
+static struct rockchip_cpu_rate_table rk3568_cpu_rates[] = {
- RK3568_CPUCLK_RATE(1416000000, 1, 5),
- RK3568_CPUCLK_RATE(1296000000, 1, 5),
- RK3568_CPUCLK_RATE(1200000000, 1, 3),
- RK3568_CPUCLK_RATE(1104000000, 1, 3),
- RK3568_CPUCLK_RATE(1008000000, 1, 3),
- RK3568_CPUCLK_RATE(912000000, 1, 3),
- RK3568_CPUCLK_RATE(816000000, 1, 3),
- RK3568_CPUCLK_RATE(600000000, 1, 1),
- RK3568_CPUCLK_RATE(408000000, 1, 1),
- { /* sentinel */ },
+static struct rockchip_pll_rate_table rk3568_pll_rates[] = {
- /* _mhz, _refdiv, _fbdiv, _postdiv1, _postdiv2, _dsmpd, _frac */
- RK3036_PLL_RATE(1608000000, 1, 67, 1, 1, 1, 0),
- RK3036_PLL_RATE(1416000000, 1, 118, 2, 1, 1, 0),
- RK3036_PLL_RATE(1296000000, 1, 108, 2, 1, 1, 0),
- RK3036_PLL_RATE(1200000000, 1, 100, 2, 1, 1, 0),
- RK3036_PLL_RATE(1188000000, 1, 99, 2, 1, 1, 0),
- RK3036_PLL_RATE(1104000000, 1, 92, 2, 1, 1, 0),
- RK3036_PLL_RATE(1008000000, 1, 84, 2, 1, 1, 0),
- RK3036_PLL_RATE(1000000000, 3, 250, 2, 1, 1, 0),
- RK3036_PLL_RATE(912000000, 1, 76, 2, 1, 1, 0),
- RK3036_PLL_RATE(816000000, 1, 68, 2, 1, 1, 0),
- RK3036_PLL_RATE(600000000, 1, 100, 4, 1, 1, 0),
- RK3036_PLL_RATE(594000000, 1, 99, 4, 1, 1, 0),
- RK3036_PLL_RATE(500000000, 1, 125, 6, 1, 1, 0),
- RK3036_PLL_RATE(408000000, 1, 68, 2, 2, 1, 0),
- RK3036_PLL_RATE(400000000, 1, 100, 6, 1, 1, 0),
- RK3036_PLL_RATE(200000000, 1, 100, 6, 2, 1, 0),
- RK3036_PLL_RATE(100000000, 1, 150, 6, 6, 1, 0),
+static struct rockchip_pll_clock rk3568_pll_clks[] = {
- [APLL] = PLL(pll_rk3328, PLL_APLL, RK3568_PLL_CON(0),
RK3568_MODE_CON, 0, 10, 0, rk3568_pll_rates),
- [DPLL] = PLL(pll_rk3328, PLL_DPLL, RK3568_PLL_CON(8),
RK3568_MODE_CON, 2, 10, 0, NULL),
- [CPLL] = PLL(pll_rk3328, PLL_CPLL, RK3568_PLL_CON(24),
RK3568_MODE_CON, 4, 10, 0, rk3568_pll_rates),
- [GPLL] = PLL(pll_rk3328, PLL_HPLL, RK3568_PLL_CON(16),
RK3568_MODE_CON, 6, 10, 0, rk3568_pll_rates),
- [NPLL] = PLL(pll_rk3328, PLL_NPLL, RK3568_PLL_CON(32),
RK3568_MODE_CON, 10, 10, 0, rk3568_pll_rates),
- [VPLL] = PLL(pll_rk3328, PLL_VPLL, RK3568_PLL_CON(40),
RK3568_MODE_CON, 12, 10, 0, rk3568_pll_rates),
- [PPLL] = PLL(pll_rk3328, PLL_PPLL, RK3568_PMU_PLL_CON(0),
RK3568_PMU_MODE, 0, 10, 0, rk3568_pll_rates),
- [HPLL] = PLL(pll_rk3328, PLL_HPLL, RK3568_PMU_PLL_CON(16),
RK3568_PMU_MODE, 2, 10, 0, rk3568_pll_rates),
+static ulong __maybe_unused +rk3568_pmu_pll_set_rate(struct rk3568_clk_priv *priv,
ulong pll_id, ulong rate)
- struct udevice *pmucru_dev;
- struct rk3568_pmuclk_priv *pmu_priv;
- int ret;
- ret = uclass_get_device_by_driver(UCLASS_CLK,
DM_DRIVER_GET(rockchip_rk3568_pmucru),
&pmucru_dev);
- if (ret) {
printf("%s: could not find pmucru device\n", __func__);
return ret;
- pmu_priv = dev_get_priv(pmucru_dev);
- rockchip_pll_set_rate(&rk3568_pll_clks[pll_id],
pmu_priv->pmucru, pll_id, rate);
+static ulong rk3568_pmu_pll_get_rate(struct rk3568_clk_priv *priv,
ulong pll_id)
- int ret;
&pmucru_dev);
- if (ret) {
return ret;
- return rockchip_pll_get_rate(&rk3568_pll_clks[pll_id],
pmu_priv->pmucru, pll_id);
- rational_best_approximation(31415, 10000,
(1 << 8) - 1, (1 << 5) - 1, &n, &d);
- you may look at given_numerator as a fixed point number,
- with the fractional part size described in given_denominator.
- for theoretical background, see:
+static void rational_best_approximation(unsigned long given_numerator,
unsigned long given_denominator,
unsigned long max_numerator,
unsigned long max_denominator,
unsigned long *best_numerator,
unsigned long *best_denominator)
- unsigned long n, d, n0, d0, n1, d1;
- n = given_numerator;
- d = given_denominator;
- n0 = 0;
- d1 = 0;
- n1 = 1;
- d0 = 1;
- for (;;) {
unsigned long t, a;
if (n1 > max_numerator || d1 > max_denominator) {
n1 = n0;
d1 = d0;
break;
if (d == 0)
break;
t = d;
a = n / d;
d = n % d;
n = t;
t = n0 + a * n1;
n0 = n1;
n1 = t;
t = d0 + a * d1;
d0 = d1;
d1 = t;
- *best_numerator = n1;
- *best_denominator = d1;
+static ulong rk3568_rtc32k_get_pmuclk(struct rk3568_pmuclk_priv *priv) +{
- struct rk3568_pmucru *pmucru = priv->pmucru;
- unsigned long m, n;
- u32 fracdiv;
- fracdiv = readl(&pmucru->pmu_clksel_con[1]);
- m = fracdiv & RTC32K_FRAC_NUMERATOR_MASK;
- m >>= RTC32K_FRAC_NUMERATOR_SHIFT;
- n = fracdiv & RTC32K_FRAC_DENOMINATOR_MASK;
- n >>= RTC32K_FRAC_DENOMINATOR_SHIFT;
- return OSC_HZ * m / n;
+static ulong rk3568_rtc32k_set_pmuclk(struct rk3568_pmuclk_priv *priv,
ulong rate)
- unsigned long m, n, val;
- rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK,
RTC32K_SEL_OSC0_DIV32K << RTC32K_SEL_SHIFT);
- rational_best_approximation(rate, OSC_HZ,
GENMASK(16 - 1, 0),
GENMASK(16 - 1, 0),
&m, &n);
- val = m << RTC32K_FRAC_NUMERATOR_SHIFT | n;
- writel(val, &pmucru->pmu_clksel_con[1]);
- return rk3568_rtc32k_get_pmuclk(priv);
+static ulong rk3568_i2c_get_pmuclk(struct rk3568_pmuclk_priv *priv,
ulong clk_id)
- u32 div, con;
- switch (clk_id) {
- case CLK_I2C0:
con = readl(&pmucru->pmu_clksel_con[3]);
div = (con & CLK_I2C0_DIV_MASK) >> CLK_I2C0_DIV_SHIFT;
break;
- default:
return -ENOENT;
- return DIV_TO_RATE(priv->ppll_hz, div);
+static ulong rk3568_i2c_set_pmuclk(struct rk3568_pmuclk_priv *priv,
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(priv->ppll_hz, rate);
- assert(src_clk_div - 1 <= 127);
- switch (clk_id) {
- case CLK_I2C0:
rk_clrsetreg(&pmucru->pmu_clksel_con[3], CLK_I2C0_DIV_MASK,
(src_clk_div - 1) << CLK_I2C0_DIV_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_i2c_get_pmuclk(priv, clk_id);
+static ulong rk3568_pwm_get_pmuclk(struct rk3568_pmuclk_priv *priv,
ulong clk_id)
- u32 div, sel, con, parent;
- switch (clk_id) {
- case CLK_PWM0:
con = readl(&pmucru->pmu_clksel_con[6]);
sel = (con & CLK_PWM0_SEL_MASK) >> CLK_PWM0_SEL_SHIFT;
div = (con & CLK_PWM0_DIV_MASK) >> CLK_PWM0_DIV_SHIFT;
if (sel == CLK_PWM0_SEL_XIN24M)
parent = OSC_HZ;
else
parent = priv->ppll_hz;
break;
- default:
return -ENOENT;
- return DIV_TO_RATE(parent, div);
+static ulong rk3568_pwm_set_pmuclk(struct rk3568_pmuclk_priv *priv,
- int src_clk_div;
- switch (clk_id) {
- case CLK_PWM0:
rk_clrsetreg(&pmucru->pmu_clksel_con[6],
CLK_PWM0_SEL_MASK | CLK_PWM0_DIV_MASK,
(CLK_PWM0_SEL_XIN24M <<
CLK_PWM0_SEL_SHIFT) |
0 << CLK_PWM0_SEL_SHIFT);
} else {
CLK_PWM0_DIV_MASK | CLK_PWM0_DIV_MASK,
(CLK_PWM0_SEL_PPLL << CLK_PWM0_SEL_SHIFT) |
(src_clk_div - 1) << CLK_PWM0_DIV_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_pwm_get_pmuclk(priv, clk_id);
+static ulong rk3568_pmu_get_pmuclk(struct rk3568_pmuclk_priv *priv) +{
- u32 div, con, sel, parent;
- con = readl(&pmucru->pmu_clksel_con[2]);
- sel = (con & PCLK_PDPMU_SEL_MASK) >> PCLK_PDPMU_SEL_SHIFT;
- div = (con & PCLK_PDPMU_DIV_MASK) >> PCLK_PDPMU_DIV_SHIFT;
- if (sel)
parent = GPLL_HZ;
- else
+static ulong rk3568_pmu_set_pmuclk(struct rk3568_pmuclk_priv *priv,
ulong rate)
- int src_clk_div;
- assert(src_clk_div - 1 <= 31);
- rk_clrsetreg(&pmucru->pmu_clksel_con[2],
PCLK_PDPMU_DIV_MASK | PCLK_PDPMU_SEL_MASK,
(PCLK_PDPMU_SEL_PPLL << PCLK_PDPMU_SEL_SHIFT) |
((src_clk_div - 1) << PCLK_PDPMU_DIV_SHIFT));
- return rk3568_pmu_get_pmuclk(priv);
+static ulong rk3568_pmuclk_get_rate(struct clk *clk) +{
- struct rk3568_pmuclk_priv *priv = dev_get_priv(clk->dev);
- ulong rate = 0;
- if (!priv->ppll_hz) {
printf("%s ppll=%lu\n", __func__, priv->ppll_hz);
return -ENOENT;
- debug("%s %ld\n", __func__, clk->id);
- switch (clk->id) {
- case PLL_PPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[PPLL],
priv->pmucru, PPLL);
break;
- case PLL_HPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[HPLL],
priv->pmucru, HPLL);
break;
- case CLK_RTC_32K:
- case CLK_RTC32K_FRAC:
rate = rk3568_rtc32k_get_pmuclk(priv);
break;
- case CLK_I2C0:
rate = rk3568_i2c_get_pmuclk(priv, clk->id);
break;
- case CLK_PWM0:
rate = rk3568_pwm_get_pmuclk(priv, clk->id);
break;
- case PCLK_PMU:
rate = rk3568_pmu_get_pmuclk(priv);
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_pmuclk_set_rate(struct clk *clk, ulong rate) +{
- ulong ret = 0;
return -ENOENT;
- debug("%s %ld %ld\n", __func__, clk->id, rate);
- case PLL_PPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[PPLL],
priv->pmucru, PPLL, rate);
priv->ppll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[PPLL],
break;
- case PLL_HPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[HPLL],
priv->pmucru, HPLL, rate);
priv->hpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[HPLL],
break;
- case CLK_RTC_32K:
ret = rk3568_rtc32k_set_pmuclk(priv, rate);
break;
- case CLK_I2C0:
ret = rk3568_i2c_set_pmuclk(priv, clk->id, rate);
break;
- case CLK_PWM0:
ret = rk3568_pwm_set_pmuclk(priv, clk->id, rate);
break;
- case PCLK_PMU:
ret = rk3568_pmu_set_pmuclk(priv, rate);
break;
- default:
return -ENOENT;
- return ret;
+static int rk3568_rtc32k_set_parent(struct clk *clk, struct clk *parent) +{
- if (parent->id == CLK_RTC32K_FRAC)
- else
RTC32K_SEL_OSC1_32K << RTC32K_SEL_SHIFT);
+static int rk3568_pmuclk_set_parent(struct clk *clk, struct clk *parent) +{
- case CLK_RTC_32K:
return rk3568_rtc32k_set_parent(clk, parent);
- default:
return -ENOENT;
+static struct clk_ops rk3568_pmuclk_ops = {
- .get_rate = rk3568_pmuclk_get_rate,
- .set_rate = rk3568_pmuclk_set_rate,
- .set_parent = rk3568_pmuclk_set_parent,
+static int rk3568_pmuclk_probe(struct udevice *dev) +{
- struct rk3568_pmuclk_priv *priv = dev_get_priv(dev);
- int ret = 0;
- if (priv->ppll_hz != PPLL_HZ) {
priv->pmucru,
PPLL, PPLL_HZ);
if (!ret)
priv->ppll_hz = PPLL_HZ;
- /* Ungate PCIe30phy refclk_m and refclk_n */
- rk_clrsetreg(&priv->pmucru->pmu_clkgate_con[2], 0x3 << 13, 0 << 13);
+static int rk3568_pmuclk_ofdata_to_platdata(struct udevice *dev) +{
- priv->pmucru = dev_read_addr_ptr(dev);
+static int rk3568_pmuclk_bind(struct udevice *dev) +{ +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP)
- int ret = 0;
- ret = offsetof(struct rk3568_pmucru, pmu_softrst_con[0]);
- ret = rockchip_reset_bind(dev, ret, 1);
- if (ret)
debug("Warning: pmucru software reset driver bind faile\n");
+static const struct udevice_id rk3568_pmuclk_ids[] = {
- { .compatible = "rockchip,rk3568-pmucru" },
+U_BOOT_DRIVER(rockchip_rk3568_pmucru) = {
- .name = "rockchip_rk3568_pmucru",
- .id = UCLASS_CLK,
- .of_match = rk3568_pmuclk_ids,
- .priv_auto = sizeof(struct rk3568_pmuclk_priv),
- .of_to_plat = rk3568_pmuclk_ofdata_to_platdata,
- .ops = &rk3568_pmuclk_ops,
- .bind = rk3568_pmuclk_bind,
- .probe = rk3568_pmuclk_probe,
- .plat_auto = sizeof(struct rk3568_pmuclk_plat),
+static int rk3568_armclk_set_clk(struct rk3568_clk_priv *priv, ulong hz) +{
- struct rk3568_cru *cru = priv->cru;
- const struct rockchip_cpu_rate_table *rate;
- ulong old_rate;
- rate = rockchip_get_cpu_settings(rk3568_cpu_rates, hz);
- if (!rate) {
printf("%s unsupported rate\n", __func__);
return -EINVAL;
- rk_clrsetreg(&cru->clksel_con[0],
CLK_CORE_PRE_SEL_MASK,
(CLK_CORE_PRE_SEL_SRC << CLK_CORE_PRE_SEL_SHIFT));
- rk_clrsetreg(&cru->clksel_con[2],
SCLK_CORE_PRE_SEL_MASK |
SCLK_CORE_SRC_SEL_MASK |
SCLK_CORE_SRC_DIV_MASK,
(SCLK_CORE_PRE_SEL_SRC <<
SCLK_CORE_PRE_SEL_SHIFT) |
(SCLK_CORE_SRC_SEL_APLL <<
SCLK_CORE_SRC_SEL_SHIFT) |
(1 << SCLK_CORE_SRC_DIV_SHIFT));
* set up dependent divisors for DBG and ACLK clocks.
- old_rate = rockchip_pll_get_rate(&rk3568_pll_clks[APLL],
priv->cru, APLL);
- if (old_rate > hz) {
if (rockchip_pll_set_rate(&rk3568_pll_clks[APLL],
priv->cru, APLL, hz))
return -EINVAL;
rk_clrsetreg(&cru->clksel_con[3],
GICCLK_CORE_DIV_MASK | ATCLK_CORE_DIV_MASK,
rate->pclk_div << GICCLK_CORE_DIV_SHIFT |
rate->pclk_div << ATCLK_CORE_DIV_SHIFT);
rk_clrsetreg(&cru->clksel_con[4],
PERIPHCLK_CORE_PRE_DIV_MASK |
PCLK_CORE_PRE_DIV_MASK,
rate->pclk_div << PCLK_CORE_PRE_DIV_SHIFT |
rate->pclk_div << PERIPHCLK_CORE_PRE_DIV_SHIFT);
rk_clrsetreg(&cru->clksel_con[5],
ACLK_CORE_NDFT_DIV_MASK,
rate->aclk_div << ACLK_CORE_NDFT_DIV_SHIFT);
- } else if (old_rate < hz) {
return -EINVAL;
+static ulong rk3568_cpll_div_get_rate(struct rk3568_clk_priv *priv,
ulong clk_id)
- int div, mask, shift, con;
- switch (clk_id) {
- case CPLL_500M:
con = 78;
mask = CPLL_500M_DIV_MASK;
shift = CPLL_500M_DIV_SHIFT;
break;
- case CPLL_333M:
con = 79;
mask = CPLL_333M_DIV_MASK;
shift = CPLL_333M_DIV_SHIFT;
break;
- case CPLL_250M:
con = 79;
mask = CPLL_250M_DIV_MASK;
shift = CPLL_250M_DIV_SHIFT;
break;
- case CPLL_125M:
con = 80;
mask = CPLL_125M_DIV_MASK;
shift = CPLL_125M_DIV_SHIFT;
break;
- case CPLL_100M:
con = 82;
mask = CPLL_100M_DIV_MASK;
shift = CPLL_100M_DIV_SHIFT;
break;
- case CPLL_62P5M:
con = 80;
mask = CPLL_62P5M_DIV_MASK;
shift = CPLL_62P5M_DIV_SHIFT;
break;
- case CPLL_50M:
con = 81;
mask = CPLL_50M_DIV_MASK;
shift = CPLL_50M_DIV_SHIFT;
break;
- case CPLL_25M:
con = 81;
mask = CPLL_25M_DIV_MASK;
shift = CPLL_25M_DIV_SHIFT;
break;
- default:
return -ENOENT;
- div = (readl(&cru->clksel_con[con]) & mask) >> shift;
- return DIV_TO_RATE(priv->cpll_hz, div);
+static ulong rk3568_cpll_div_set_rate(struct rk3568_clk_priv *priv,
- switch (clk_id) {
- case CPLL_500M:
con = 78;
break;
- case CPLL_333M:
con = 79;
break;
- case CPLL_250M:
con = 79;
break;
- case CPLL_125M:
con = 80;
break;
- case CPLL_100M:
con = 82;
break;
- case CPLL_62P5M:
con = 80;
break;
- case CPLL_50M:
con = 81;
break;
- case CPLL_25M:
con = 81;
break;
- default:
return -ENOENT;
- div = DIV_ROUND_UP(priv->cpll_hz, rate);
- assert(div - 1 <= 31);
- rk_clrsetreg(&cru->clksel_con[con],
mask, (div - 1) << shift);
- return rk3568_cpll_div_get_rate(priv, clk_id);
+static ulong rk3568_bus_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 con, sel, rate;
- switch (clk_id) {
- case ACLK_BUS:
con = readl(&cru->clksel_con[50]);
sel = (con & ACLK_BUS_SEL_MASK) >> ACLK_BUS_SEL_SHIFT;
if (sel == ACLK_BUS_SEL_200M)
rate = 200 * MHz;
else if (sel == ACLK_BUS_SEL_150M)
rate = 150 * MHz;
else if (sel == ACLK_BUS_SEL_100M)
rate = 100 * MHz;
else
rate = OSC_HZ;
break;
- case PCLK_BUS:
- case PCLK_WDT_NS:
sel = (con & PCLK_BUS_SEL_MASK) >> PCLK_BUS_SEL_SHIFT;
if (sel == PCLK_BUS_SEL_100M)
rate = 100 * MHz;
else if (sel == PCLK_BUS_SEL_75M)
rate = 75 * MHz;
else if (sel == PCLK_BUS_SEL_50M)
rate = 50 * MHz;
else
rate = OSC_HZ;
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_bus_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- switch (clk_id) {
- case ACLK_BUS:
if (rate == 200 * MHz)
src_clk = ACLK_BUS_SEL_200M;
else if (rate == 150 * MHz)
src_clk = ACLK_BUS_SEL_150M;
else if (rate == 100 * MHz)
src_clk = ACLK_BUS_SEL_100M;
else
src_clk = ACLK_BUS_SEL_24M;
rk_clrsetreg(&cru->clksel_con[50],
ACLK_BUS_SEL_MASK,
src_clk << ACLK_BUS_SEL_SHIFT);
break;
- case PCLK_BUS:
- case PCLK_WDT_NS:
src_clk = PCLK_BUS_SEL_100M;
else if (rate == 75 * MHz)
src_clk = PCLK_BUS_SEL_75M;
else if (rate == 50 * MHz)
src_clk = PCLK_BUS_SEL_50M;
else
src_clk = PCLK_BUS_SEL_24M;
PCLK_BUS_SEL_MASK,
src_clk << PCLK_BUS_SEL_SHIFT);
break;
- default:
printf("do not support this bus freq\n");
return -EINVAL;
- return rk3568_bus_get_clk(priv, clk_id);
+static ulong rk3568_perimid_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- switch (clk_id) {
- case ACLK_PERIMID:
con = readl(&cru->clksel_con[10]);
sel = (con & ACLK_PERIMID_SEL_MASK) >> ACLK_PERIMID_SEL_SHIFT;
if (sel == ACLK_PERIMID_SEL_300M)
rate = 300 * MHz;
else if (sel == ACLK_PERIMID_SEL_200M)
rate = 200 * MHz;
else if (sel == ACLK_PERIMID_SEL_100M)
rate = 100 * MHz;
else
rate = OSC_HZ;
break;
- case HCLK_PERIMID:
sel = (con & HCLK_PERIMID_SEL_MASK) >> HCLK_PERIMID_SEL_SHIFT;
if (sel == HCLK_PERIMID_SEL_150M)
rate = 150 * MHz;
else if (sel == HCLK_PERIMID_SEL_100M)
rate = 100 * MHz;
else if (sel == HCLK_PERIMID_SEL_75M)
rate = 75 * MHz;
else
rate = OSC_HZ;
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_perimid_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- switch (clk_id) {
if (rate == 300 * MHz)
src_clk = ACLK_PERIMID_SEL_300M;
else if (rate == 200 * MHz)
src_clk = ACLK_PERIMID_SEL_200M;
src_clk = ACLK_PERIMID_SEL_100M;
else
src_clk = ACLK_PERIMID_SEL_24M;
rk_clrsetreg(&cru->clksel_con[10],
ACLK_PERIMID_SEL_MASK,
src_clk << ACLK_PERIMID_SEL_SHIFT);
break;
src_clk = HCLK_PERIMID_SEL_150M;
src_clk = HCLK_PERIMID_SEL_100M;
src_clk = HCLK_PERIMID_SEL_75M;
else
src_clk = HCLK_PERIMID_SEL_24M;
HCLK_PERIMID_SEL_MASK,
src_clk << HCLK_PERIMID_SEL_SHIFT);
break;
- default:
printf("do not support this permid freq\n");
return -EINVAL;
- return rk3568_perimid_get_clk(priv, clk_id);
+static ulong rk3568_top_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- switch (clk_id) {
- case ACLK_TOP_HIGH:
con = readl(&cru->clksel_con[73]);
sel = (con & ACLK_TOP_HIGH_SEL_MASK) >> ACLK_TOP_HIGH_SEL_SHIFT;
if (sel == ACLK_TOP_HIGH_SEL_500M)
rate = 500 * MHz;
else if (sel == ACLK_TOP_HIGH_SEL_400M)
rate = 400 * MHz;
else if (sel == ACLK_TOP_HIGH_SEL_300M)
rate = 300 * MHz;
else
rate = OSC_HZ;
break;
- case ACLK_TOP_LOW:
sel = (con & ACLK_TOP_LOW_SEL_MASK) >> ACLK_TOP_LOW_SEL_SHIFT;
if (sel == ACLK_TOP_LOW_SEL_400M)
rate = 400 * MHz;
else if (sel == ACLK_TOP_LOW_SEL_300M)
rate = 300 * MHz;
else if (sel == ACLK_TOP_LOW_SEL_200M)
rate = 200 * MHz;
else
rate = OSC_HZ;
break;
- case HCLK_TOP:
sel = (con & HCLK_TOP_SEL_MASK) >> HCLK_TOP_SEL_SHIFT;
if (sel == HCLK_TOP_SEL_150M)
rate = 150 * MHz;
else if (sel == HCLK_TOP_SEL_100M)
rate = 100 * MHz;
else if (sel == HCLK_TOP_SEL_75M)
rate = 75 * MHz;
else
rate = OSC_HZ;
break;
- case PCLK_TOP:
sel = (con & PCLK_TOP_SEL_MASK) >> PCLK_TOP_SEL_SHIFT;
if (sel == PCLK_TOP_SEL_100M)
rate = 100 * MHz;
else if (sel == PCLK_TOP_SEL_75M)
rate = 75 * MHz;
else if (sel == PCLK_TOP_SEL_50M)
rate = 50 * MHz;
else
rate = OSC_HZ;
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_top_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- switch (clk_id) {
if (rate == 500 * MHz)
src_clk = ACLK_TOP_HIGH_SEL_500M;
else if (rate == 400 * MHz)
src_clk = ACLK_TOP_HIGH_SEL_400M;
else if (rate == 300 * MHz)
src_clk = ACLK_TOP_HIGH_SEL_300M;
else
src_clk = ACLK_TOP_HIGH_SEL_24M;
rk_clrsetreg(&cru->clksel_con[73],
ACLK_TOP_HIGH_SEL_MASK,
src_clk << ACLK_TOP_HIGH_SEL_SHIFT);
break;
src_clk = ACLK_TOP_LOW_SEL_400M;
src_clk = ACLK_TOP_LOW_SEL_300M;
src_clk = ACLK_TOP_LOW_SEL_200M;
else
src_clk = ACLK_TOP_LOW_SEL_24M;
ACLK_TOP_LOW_SEL_MASK,
src_clk << ACLK_TOP_LOW_SEL_SHIFT);
break;
- case HCLK_TOP:
src_clk = HCLK_TOP_SEL_150M;
src_clk = HCLK_TOP_SEL_100M;
src_clk = HCLK_TOP_SEL_75M;
else
src_clk = HCLK_TOP_SEL_24M;
HCLK_TOP_SEL_MASK,
src_clk << HCLK_TOP_SEL_SHIFT);
break;
- case PCLK_TOP:
src_clk = PCLK_TOP_SEL_100M;
src_clk = PCLK_TOP_SEL_75M;
src_clk = PCLK_TOP_SEL_50M;
else
src_clk = PCLK_TOP_SEL_24M;
PCLK_TOP_SEL_MASK,
src_clk << PCLK_TOP_SEL_SHIFT);
break;
- default:
return -EINVAL;
- return rk3568_top_get_clk(priv, clk_id);
+static ulong rk3568_i2c_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 sel, con;
- ulong rate;
- switch (clk_id) {
- case CLK_I2C1:
- case CLK_I2C2:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
con = readl(&cru->clksel_con[71]);
sel = (con & CLK_I2C_SEL_MASK) >> CLK_I2C_SEL_SHIFT;
if (sel == CLK_I2C_SEL_200M)
rate = 200 * MHz;
else if (sel == CLK_I2C_SEL_100M)
rate = 100 * MHz;
else if (sel == CLK_I2C_SEL_CPLL_100M)
rate = 100 * MHz;
else
rate = OSC_HZ;
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_i2c_set_clk(struct rk3568_clk_priv *priv, ulong clk_id,
ulong rate)
- int src_clk;
- if (rate == 200 * MHz)
src_clk = CLK_I2C_SEL_200M;
- else if (rate == 100 * MHz)
src_clk = CLK_I2C_SEL_100M;
- else
src_clk = CLK_I2C_SEL_24M;
- switch (clk_id) {
- case CLK_I2C1:
- case CLK_I2C2:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
rk_clrsetreg(&cru->clksel_con[71], CLK_I2C_SEL_MASK,
src_clk << CLK_I2C_SEL_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_i2c_get_clk(priv, clk_id);
+static ulong rk3568_spi_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 sel, con;
- con = readl(&cru->clksel_con[72]);
- switch (clk_id) {
- case CLK_SPI0:
sel = (con & CLK_SPI0_SEL_MASK) >> CLK_SPI0_SEL_SHIFT;
break;
- case CLK_SPI1:
sel = (con & CLK_SPI1_SEL_MASK) >> CLK_SPI1_SEL_SHIFT;
break;
- case CLK_SPI2:
sel = (con & CLK_SPI2_SEL_MASK) >> CLK_SPI2_SEL_SHIFT;
break;
- case CLK_SPI3:
sel = (con & CLK_SPI3_SEL_MASK) >> CLK_SPI3_SEL_SHIFT;
break;
- default:
return -ENOENT;
- switch (sel) {
- case CLK_SPI_SEL_200M:
return 200 * MHz;
- case CLK_SPI_SEL_24M:
return OSC_HZ;
- case CLK_SPI_SEL_CPLL_100M:
return 100 * MHz;
- default:
return -ENOENT;
+static ulong rk3568_spi_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
src_clk = CLK_SPI_SEL_200M;
src_clk = CLK_SPI_SEL_CPLL_100M;
- else
src_clk = CLK_SPI_SEL_24M;
- switch (clk_id) {
- case CLK_SPI0:
rk_clrsetreg(&cru->clksel_con[72],
CLK_SPI0_SEL_MASK,
src_clk << CLK_SPI0_SEL_SHIFT);
break;
- case CLK_SPI1:
CLK_SPI1_SEL_MASK,
src_clk << CLK_SPI1_SEL_SHIFT);
break;
- case CLK_SPI2:
CLK_SPI2_SEL_MASK,
src_clk << CLK_SPI2_SEL_SHIFT);
break;
- case CLK_SPI3:
CLK_SPI3_SEL_MASK,
src_clk << CLK_SPI3_SEL_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_spi_get_clk(priv, clk_id);
+static ulong rk3568_pwm_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 sel, con;
- switch (clk_id) {
- case CLK_PWM1:
sel = (con & CLK_PWM1_SEL_MASK) >> CLK_PWM3_SEL_SHIFT;
break;
- case CLK_PWM2:
sel = (con & CLK_PWM2_SEL_MASK) >> CLK_PWM2_SEL_SHIFT;
break;
- case CLK_PWM3:
sel = (con & CLK_PWM3_SEL_MASK) >> CLK_PWM3_SEL_SHIFT;
break;
- default:
return -ENOENT;
- switch (sel) {
- case CLK_PWM_SEL_100M:
return 100 * MHz;
- case CLK_PWM_SEL_24M:
return OSC_HZ;
- case CLK_PWM_SEL_CPLL_100M:
return 100 * MHz;
- default:
return -ENOENT;
+static ulong rk3568_pwm_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- if (rate == 100 * MHz)
src_clk = CLK_PWM_SEL_100M;
- else
src_clk = CLK_PWM_SEL_24M;
- switch (clk_id) {
- case CLK_PWM1:
CLK_PWM1_SEL_MASK,
src_clk << CLK_PWM1_SEL_SHIFT);
break;
- case CLK_PWM2:
CLK_PWM2_SEL_MASK,
src_clk << CLK_PWM2_SEL_SHIFT);
break;
- case CLK_PWM3:
CLK_PWM3_SEL_MASK,
src_clk << CLK_PWM3_SEL_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_pwm_get_clk(priv, clk_id);
+static ulong rk3568_adc_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 div, sel, con, prate;
- switch (clk_id) {
- case CLK_SARADC:
return OSC_HZ;
- case CLK_TSADC_TSEN:
con = readl(&cru->clksel_con[51]);
div = (con & CLK_TSADC_TSEN_DIV_MASK) >>
CLK_TSADC_TSEN_DIV_SHIFT;
sel = (con & CLK_TSADC_TSEN_SEL_MASK) >>
CLK_TSADC_TSEN_SEL_SHIFT;
if (sel == CLK_TSADC_TSEN_SEL_24M)
prate = OSC_HZ;
else
prate = 100 * MHz;
return DIV_TO_RATE(prate, div);
- case CLK_TSADC:
div = (con & CLK_TSADC_DIV_MASK) >> CLK_TSADC_DIV_SHIFT;
prate = rk3568_adc_get_clk(priv, CLK_TSADC_TSEN);
- default:
return -ENOENT;
+static ulong rk3568_adc_set_clk(struct rk3568_clk_priv *priv,
- int src_clk_div;
- ulong prate = 0;
- switch (clk_id) {
- case CLK_SARADC:
return OSC_HZ;
if (!(OSC_HZ % rate)) {
src_clk_div = DIV_ROUND_UP(OSC_HZ, rate);
assert(src_clk_div - 1 <= 7);
rk_clrsetreg(&cru->clksel_con[51],
CLK_TSADC_TSEN_SEL_MASK |
CLK_TSADC_TSEN_DIV_MASK,
(CLK_TSADC_TSEN_SEL_24M <<
CLK_TSADC_TSEN_SEL_SHIFT) |
CLK_TSADC_TSEN_DIV_SHIFT);
} else {
src_clk_div = DIV_ROUND_UP(100 * MHz, rate);
(CLK_TSADC_TSEN_SEL_100M <<
break;
- case CLK_TSADC:
src_clk_div = DIV_ROUND_UP(prate, rate);
assert(src_clk_div - 1 <= 128);
CLK_TSADC_DIV_MASK,
(src_clk_div - 1) << CLK_TSADC_DIV_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_adc_get_clk(priv, clk_id);
+static ulong rk3568_crypto_get_rate(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 sel, con;
- switch (clk_id) {
- case ACLK_SECURE_FLASH:
- case ACLK_CRYPTO_NS:
con = readl(&cru->clksel_con[27]);
sel = (con & ACLK_SECURE_FLASH_SEL_MASK) >>
ACLK_SECURE_FLASH_SEL_SHIFT;
if (sel == ACLK_SECURE_FLASH_SEL_200M)
return 200 * MHz;
else if (sel == ACLK_SECURE_FLASH_SEL_150M)
return 150 * MHz;
else if (sel == ACLK_SECURE_FLASH_SEL_100M)
return 100 * MHz;
else
return 24 * MHz;
- case HCLK_SECURE_FLASH:
- case HCLK_CRYPTO_NS:
- case CLK_CRYPTO_NS_RNG:
sel = (con & HCLK_SECURE_FLASH_SEL_MASK) >>
HCLK_SECURE_FLASH_SEL_SHIFT;
if (sel == HCLK_SECURE_FLASH_SEL_150M)
return 150 * MHz;
else if (sel == HCLK_SECURE_FLASH_SEL_100M)
return 100 * MHz;
else if (sel == HCLK_SECURE_FLASH_SEL_75M)
return 75 * MHz;
else
return 24 * MHz;
- case CLK_CRYPTO_NS_CORE:
sel = (con & CLK_CRYPTO_CORE_SEL_MASK) >>
CLK_CRYPTO_CORE_SEL_SHIFT;
if (sel == CLK_CRYPTO_CORE_SEL_200M)
return 200 * MHz;
else if (sel == CLK_CRYPTO_CORE_SEL_150M)
return 150 * MHz;
else
return 100 * MHz;
- case CLK_CRYPTO_NS_PKA:
sel = (con & CLK_CRYPTO_PKA_SEL_MASK) >>
CLK_CRYPTO_PKA_SEL_SHIFT;
if (sel == CLK_CRYPTO_PKA_SEL_300M)
return 300 * MHz;
else if (sel == CLK_CRYPTO_PKA_SEL_200M)
return 200 * MHz;
else
return 100 * MHz;
- default:
return -ENOENT;
+static ulong rk3568_crypto_set_rate(struct rk3568_clk_priv *priv,
- u32 src_clk, mask, shift;
- switch (clk_id) {
mask = ACLK_SECURE_FLASH_SEL_MASK;
shift = ACLK_SECURE_FLASH_SEL_SHIFT;
src_clk = ACLK_SECURE_FLASH_SEL_200M;
src_clk = ACLK_SECURE_FLASH_SEL_150M;
src_clk = ACLK_SECURE_FLASH_SEL_100M;
else
src_clk = ACLK_SECURE_FLASH_SEL_24M;
break;
mask = HCLK_SECURE_FLASH_SEL_MASK;
shift = HCLK_SECURE_FLASH_SEL_SHIFT;
src_clk = HCLK_SECURE_FLASH_SEL_150M;
src_clk = HCLK_SECURE_FLASH_SEL_100M;
src_clk = HCLK_SECURE_FLASH_SEL_75M;
else
src_clk = HCLK_SECURE_FLASH_SEL_24M;
break;
mask = CLK_CRYPTO_CORE_SEL_MASK;
shift = CLK_CRYPTO_CORE_SEL_SHIFT;
src_clk = CLK_CRYPTO_CORE_SEL_200M;
src_clk = CLK_CRYPTO_CORE_SEL_150M;
else
src_clk = CLK_CRYPTO_CORE_SEL_100M;
break;
mask = CLK_CRYPTO_PKA_SEL_MASK;
shift = CLK_CRYPTO_PKA_SEL_SHIFT;
src_clk = CLK_CRYPTO_PKA_SEL_300M;
src_clk = CLK_CRYPTO_PKA_SEL_200M;
else
src_clk = CLK_CRYPTO_PKA_SEL_100M;
break;
- default:
return -ENOENT;
- rk_clrsetreg(&cru->clksel_con[27], mask, src_clk << shift);
- return rk3568_crypto_get_rate(priv, clk_id);
+static ulong rk3568_sdmmc_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 sel, con;
- switch (clk_id) {
- case HCLK_SDMMC0:
- case CLK_SDMMC0:
con = readl(&cru->clksel_con[30]);
sel = (con & CLK_SDMMC0_SEL_MASK) >> CLK_SDMMC0_SEL_SHIFT;
break;
- case CLK_SDMMC1:
sel = (con & CLK_SDMMC1_SEL_MASK) >> CLK_SDMMC1_SEL_SHIFT;
break;
- case CLK_SDMMC2:
con = readl(&cru->clksel_con[32]);
sel = (con & CLK_SDMMC2_SEL_MASK) >> CLK_SDMMC2_SEL_SHIFT;
break;
- default:
return -ENOENT;
- switch (sel) {
- case CLK_SDMMC_SEL_24M:
return OSC_HZ;
- case CLK_SDMMC_SEL_400M:
return 400 * MHz;
- case CLK_SDMMC_SEL_300M:
return 300 * MHz;
- case CLK_SDMMC_SEL_100M:
return 100 * MHz;
- case CLK_SDMMC_SEL_50M:
return 50 * MHz;
- case CLK_SDMMC_SEL_750K:
return 750 * KHz;
- default:
return -ENOENT;
+static ulong rk3568_sdmmc_set_clk(struct rk3568_clk_priv *priv,
ulong clk_id, ulong rate)
- int src_clk;
- switch (rate) {
- case OSC_HZ:
src_clk = CLK_SDMMC_SEL_24M;
break;
- case 400 * MHz:
src_clk = CLK_SDMMC_SEL_400M;
break;
- case 300 * MHz:
src_clk = CLK_SDMMC_SEL_300M;
break;
- case 100 * MHz:
src_clk = CLK_SDMMC_SEL_100M;
break;
- case 52 * MHz:
- case 50 * MHz:
src_clk = CLK_SDMMC_SEL_50M;
break;
- case 750 * KHz:
- case 400 * KHz:
src_clk = CLK_SDMMC_SEL_750K;
break;
- default:
return -ENOENT;
- switch (clk_id) {
- case HCLK_SDMMC0:
- case CLK_SDMMC0:
rk_clrsetreg(&cru->clksel_con[30],
CLK_SDMMC0_SEL_MASK,
src_clk << CLK_SDMMC0_SEL_SHIFT);
break;
- case CLK_SDMMC1:
CLK_SDMMC1_SEL_MASK,
src_clk << CLK_SDMMC1_SEL_SHIFT);
break;
- case CLK_SDMMC2:
rk_clrsetreg(&cru->clksel_con[32],
CLK_SDMMC2_SEL_MASK,
src_clk << CLK_SDMMC2_SEL_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_sdmmc_get_clk(priv, clk_id);
+static ulong rk3568_sfc_get_clk(struct rk3568_clk_priv *priv) +{
- u32 sel, con;
- con = readl(&cru->clksel_con[28]);
- sel = (con & SCLK_SFC_SEL_MASK) >> SCLK_SFC_SEL_SHIFT;
- switch (sel) {
- case SCLK_SFC_SEL_24M:
return OSC_HZ;
- case SCLK_SFC_SEL_50M:
return 50 * MHz;
- case SCLK_SFC_SEL_75M:
return 75 * MHz;
- case SCLK_SFC_SEL_100M:
return 100 * MHz;
- case SCLK_SFC_SEL_125M:
return 125 * MHz;
- case SCLK_SFC_SEL_150M:
return 150 * KHz;
- default:
return -ENOENT;
+static ulong rk3568_sfc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{
- int src_clk;
- switch (rate) {
- case OSC_HZ:
src_clk = SCLK_SFC_SEL_24M;
break;
- case 50 * MHz:
src_clk = SCLK_SFC_SEL_50M;
break;
- case 75 * MHz:
src_clk = SCLK_SFC_SEL_75M;
break;
- case 100 * MHz:
src_clk = SCLK_SFC_SEL_100M;
break;
- case 125 * MHz:
src_clk = SCLK_SFC_SEL_125M;
break;
- case 150 * KHz:
src_clk = SCLK_SFC_SEL_150M;
break;
- default:
return -ENOENT;
- rk_clrsetreg(&cru->clksel_con[28],
SCLK_SFC_SEL_MASK,
src_clk << SCLK_SFC_SEL_SHIFT);
- return rk3568_sfc_get_clk(priv);
+static ulong rk3568_nand_get_clk(struct rk3568_clk_priv *priv) +{
- u32 sel, con;
- sel = (con & NCLK_NANDC_SEL_MASK) >> NCLK_NANDC_SEL_SHIFT;
- switch (sel) {
- case NCLK_NANDC_SEL_200M:
return 200 * MHz;
- case NCLK_NANDC_SEL_150M:
return 150 * MHz;
- case NCLK_NANDC_SEL_100M:
return 100 * MHz;
- case NCLK_NANDC_SEL_24M:
return OSC_HZ;
- default:
return -ENOENT;
+static ulong rk3568_nand_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{
- int src_clk;
- switch (rate) {
- case OSC_HZ:
src_clk = NCLK_NANDC_SEL_24M;
break;
- case 100 * MHz:
src_clk = NCLK_NANDC_SEL_100M;
break;
- case 150 * MHz:
src_clk = NCLK_NANDC_SEL_150M;
break;
- case 200 * MHz:
src_clk = NCLK_NANDC_SEL_200M;
break;
- default:
return -ENOENT;
NCLK_NANDC_SEL_MASK,
src_clk << NCLK_NANDC_SEL_SHIFT);
- return rk3568_nand_get_clk(priv);
+static ulong rk3568_emmc_get_clk(struct rk3568_clk_priv *priv) +{
- u32 sel, con;
- sel = (con & CCLK_EMMC_SEL_MASK) >> CCLK_EMMC_SEL_SHIFT;
- switch (sel) {
- case CCLK_EMMC_SEL_200M:
return 200 * MHz;
- case CCLK_EMMC_SEL_150M:
return 150 * MHz;
- case CCLK_EMMC_SEL_100M:
return 100 * MHz;
- case CCLK_EMMC_SEL_50M:
return 50 * MHz;
- case CCLK_EMMC_SEL_375K:
return 375 * KHz;
- case CCLK_EMMC_SEL_24M:
return OSC_HZ;
- default:
return -ENOENT;
+static ulong rk3568_emmc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{
- int src_clk;
- switch (rate) {
- case OSC_HZ:
src_clk = CCLK_EMMC_SEL_24M;
break;
- case 52 * MHz:
- case 50 * MHz:
src_clk = CCLK_EMMC_SEL_50M;
break;
- case 100 * MHz:
src_clk = CCLK_EMMC_SEL_100M;
break;
- case 150 * MHz:
src_clk = CCLK_EMMC_SEL_150M;
break;
- case 200 * MHz:
src_clk = CCLK_EMMC_SEL_200M;
break;
- case 400 * KHz:
- case 375 * KHz:
src_clk = CCLK_EMMC_SEL_375K;
break;
- default:
return -ENOENT;
CCLK_EMMC_SEL_MASK,
src_clk << CCLK_EMMC_SEL_SHIFT);
- return rk3568_emmc_get_clk(priv);
+#ifndef CONFIG_SPL_BUILD +static ulong rk3568_aclk_vop_get_clk(struct rk3568_clk_priv *priv) +{
- con = readl(&cru->clksel_con[38]);
- div = (con & ACLK_VOP_PRE_DIV_MASK) >> ACLK_VOP_PRE_DIV_SHIFT;
- sel = (con & ACLK_VOP_PRE_SEL_MASK) >> ACLK_VOP_PRE_SEL_SHIFT;
- if (sel == ACLK_VOP_PRE_SEL_GPLL)
parent = priv->gpll_hz;
- else if (sel == ACLK_VOP_PRE_SEL_CPLL)
parent = priv->cpll_hz;
- else if (sel == ACLK_VOP_PRE_SEL_VPLL)
parent = priv->vpll_hz;
- else
parent = priv->hpll_hz;
+static ulong rk3568_aclk_vop_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{
- int src_clk_div, src_clk_mux;
- if ((priv->cpll_hz % rate) == 0) {
src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate);
src_clk_mux = ACLK_VOP_PRE_SEL_CPLL;
- } else {
src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate);
src_clk_mux = ACLK_VOP_PRE_SEL_GPLL;
- rk_clrsetreg(&cru->clksel_con[38],
ACLK_VOP_PRE_SEL_MASK | ACLK_VOP_PRE_DIV_MASK,
src_clk_mux << ACLK_VOP_PRE_SEL_SHIFT |
(src_clk_div - 1) << ACLK_VOP_PRE_DIV_SHIFT);
- return rk3568_aclk_vop_get_clk(priv);
+static ulong rk3568_dclk_vop_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 conid, div, sel, con, parent;
- switch (clk_id) {
- case DCLK_VOP0:
conid = 39;
break;
- case DCLK_VOP1:
conid = 40;
break;
- case DCLK_VOP2:
conid = 41;
break;
- default:
return -ENOENT;
- con = readl(&cru->clksel_con[conid]);
- div = (con & DCLK0_VOP_DIV_MASK) >> DCLK0_VOP_DIV_SHIFT;
- sel = (con & DCLK0_VOP_SEL_MASK) >> DCLK0_VOP_SEL_SHIFT;
- if (sel == DCLK_VOP_SEL_HPLL)
parent = rk3568_pmu_pll_get_rate(priv, HPLL);
- else if (sel == DCLK_VOP_SEL_VPLL)
parent = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL],
priv->cru, VPLL);
- else if (sel == DCLK_VOP_SEL_GPLL)
- else if (sel == DCLK_VOP_SEL_CPLL)
- else
return -ENOENT;
+#define RK3568_VOP_PLL_LIMIT_FREQ 600000000
+static ulong rk3568_dclk_vop_set_clk(struct rk3568_clk_priv *priv,
- ulong pll_rate, now, best_rate = 0;
- u32 i, conid, con, sel, div, best_div = 0, best_sel = 0;
- switch (clk_id) {
- case DCLK_VOP0:
conid = 39;
break;
- case DCLK_VOP1:
conid = 40;
break;
- case DCLK_VOP2:
conid = 41;
break;
- default:
return -ENOENT;
- if (sel == DCLK_VOP_SEL_HPLL) {
div = 1;
rk_clrsetreg(&cru->clksel_con[conid],
DCLK0_VOP_DIV_MASK | DCLK0_VOP_SEL_MASK,
(DCLK_VOP_SEL_HPLL << DCLK0_VOP_SEL_SHIFT) |
((div - 1) << DCLK0_VOP_DIV_SHIFT));
rk3568_pmu_pll_set_rate(priv, HPLL, div * rate);
- } else if (sel == DCLK_VOP_SEL_VPLL) {
div = DIV_ROUND_UP(RK3568_VOP_PLL_LIMIT_FREQ, rate);
(DCLK_VOP_SEL_VPLL << DCLK0_VOP_SEL_SHIFT) |
rockchip_pll_set_rate(&rk3568_pll_clks[VPLL],
priv->cru, VPLL, div * rate);
- } else {
for (i = 0; i <= DCLK_VOP_SEL_CPLL; i++) {
switch (i) {
case DCLK_VOP_SEL_GPLL:
pll_rate = priv->gpll_hz;
break;
case DCLK_VOP_SEL_CPLL:
pll_rate = priv->cpll_hz;
break;
default:
printf("do not support this vop pll sel\n");
return -EINVAL;
div = DIV_ROUND_UP(pll_rate, rate);
if (div > 255)
continue;
now = pll_rate / div;
if (abs(rate - now) < abs(rate - best_rate)) {
best_rate = now;
best_div = div;
best_sel = i;
debug("p_rate=%lu, best_rate=%lu, div=%u, sel=%u\n",
pll_rate, best_rate, best_div, best_sel);
if (best_rate) {
best_sel << DCLK0_VOP_SEL_SHIFT |
(best_div - 1) << DCLK0_VOP_DIV_SHIFT);
} else {
printf("do not support this vop freq %lu\n", rate);
return -EINVAL;
- return rk3568_dclk_vop_get_clk(priv, clk_id);
+static ulong rk3568_gmac_src_get_clk(struct rk3568_clk_priv *priv,
ulong mac_id)
- u32 sel, con;
- con = readl(&cru->clksel_con[31 + mac_id * 2]);
- sel = (con & CLK_MAC0_2TOP_SEL_MASK) >> CLK_MAC0_2TOP_SEL_SHIFT;
- switch (sel) {
- case CLK_MAC0_2TOP_SEL_125M:
return 125 * MHz;
- case CLK_MAC0_2TOP_SEL_50M:
return 50 * MHz;
- case CLK_MAC0_2TOP_SEL_25M:
return 25 * MHz;
- case CLK_MAC0_2TOP_SEL_PPLL:
return rk3568_pmu_pll_get_rate(priv, HPLL);
- default:
return -ENOENT;
+static ulong rk3568_gmac_src_set_clk(struct rk3568_clk_priv *priv,
ulong mac_id, ulong rate)
- int src_clk;
- switch (rate) {
- case 125 * MHz:
src_clk = CLK_MAC0_2TOP_SEL_125M;
break;
- case 50 * MHz:
src_clk = CLK_MAC0_2TOP_SEL_50M;
break;
- case 25 * MHz:
src_clk = CLK_MAC0_2TOP_SEL_25M;
break;
- default:
return -ENOENT;
- rk_clrsetreg(&cru->clksel_con[31 + mac_id * 2],
CLK_MAC0_2TOP_SEL_MASK,
src_clk << CLK_MAC0_2TOP_SEL_SHIFT);
- return rk3568_gmac_src_get_clk(priv, mac_id);
+static ulong rk3568_gmac_out_get_clk(struct rk3568_clk_priv *priv,
ulong mac_id)
- u32 sel, con;
- sel = (con & CLK_MAC0_OUT_SEL_MASK) >> CLK_MAC0_OUT_SEL_SHIFT;
- switch (sel) {
- case CLK_MAC0_OUT_SEL_125M:
return 125 * MHz;
- case CLK_MAC0_OUT_SEL_50M:
return 50 * MHz;
- case CLK_MAC0_OUT_SEL_25M:
return 25 * MHz;
- case CLK_MAC0_OUT_SEL_24M:
return OSC_HZ;
- default:
return -ENOENT;
+static ulong rk3568_gmac_out_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- switch (rate) {
- case 125 * MHz:
src_clk = CLK_MAC0_OUT_SEL_125M;
break;
- case 50 * MHz:
src_clk = CLK_MAC0_OUT_SEL_50M;
break;
- case 25 * MHz:
src_clk = CLK_MAC0_OUT_SEL_25M;
break;
- case 24 * MHz:
src_clk = CLK_MAC0_OUT_SEL_24M;
break;
- default:
return -ENOENT;
CLK_MAC0_OUT_SEL_MASK,
src_clk << CLK_MAC0_OUT_SEL_SHIFT);
- return rk3568_gmac_out_get_clk(priv, mac_id);
+static ulong rk3568_gmac_ptp_ref_get_clk(struct rk3568_clk_priv *priv,
ulong mac_id)
- u32 sel, con;
- sel = (con & CLK_GMAC0_PTP_REF_SEL_MASK) >> CLK_GMAC0_PTP_REF_SEL_SHIFT;
- switch (sel) {
- case CLK_GMAC0_PTP_REF_SEL_62_5M:
return 62500 * KHz;
- case CLK_GMAC0_PTP_REF_SEL_100M:
return 100 * MHz;
- case CLK_GMAC0_PTP_REF_SEL_50M:
return 50 * MHz;
- case CLK_GMAC0_PTP_REF_SEL_24M:
return OSC_HZ;
- default:
return -ENOENT;
+static ulong rk3568_gmac_ptp_ref_set_clk(struct rk3568_clk_priv *priv,
- int src_clk;
- switch (rate) {
- case 62500 * KHz:
src_clk = CLK_GMAC0_PTP_REF_SEL_62_5M;
break;
- case 100 * MHz:
src_clk = CLK_GMAC0_PTP_REF_SEL_100M;
break;
- case 50 * MHz:
src_clk = CLK_GMAC0_PTP_REF_SEL_50M;
break;
- case 24 * MHz:
src_clk = CLK_GMAC0_PTP_REF_SEL_24M;
break;
- default:
return -ENOENT;
CLK_GMAC0_PTP_REF_SEL_MASK,
src_clk << CLK_GMAC0_PTP_REF_SEL_SHIFT);
- return rk3568_gmac_ptp_ref_get_clk(priv, mac_id);
+static ulong rk3568_gmac_tx_rx_set_clk(struct rk3568_clk_priv *priv,
- u32 con, sel, div_sel;
- sel = (con & RMII0_MODE_MASK) >> RMII0_MODE_SHIFT;
- if (sel == RMII0_MODE_SEL_RGMII) {
if (rate == 2500000)
div_sel = RGMII0_CLK_SEL_2_5M;
else if (rate == 25000000)
div_sel = RGMII0_CLK_SEL_25M;
else
div_sel = RGMII0_CLK_SEL_125M;
RGMII0_CLK_SEL_MASK,
div_sel << RGMII0_CLK_SEL_SHIFT);
- } else if (sel == RMII0_MODE_SEL_RMII) {
div_sel = RMII0_CLK_SEL_2_5M;
else
div_sel = RMII0_CLK_SEL_25M;
RMII0_CLK_SEL_MASK,
div_sel << RMII0_CLK_SEL_SHIFT);
+static ulong rk3568_ebc_get_clk(struct rk3568_clk_priv *priv) +{
- u32 con, div, p_rate;
- con = readl(&cru->clksel_con[79]);
- div = (con & CPLL_333M_DIV_MASK) >> CPLL_333M_DIV_SHIFT;
- p_rate = DIV_TO_RATE(priv->cpll_hz, div);
- con = readl(&cru->clksel_con[43]);
- div = (con & DCLK_EBC_SEL_MASK) >> DCLK_EBC_SEL_SHIFT;
- switch (div) {
- case DCLK_EBC_SEL_GPLL_400M:
return 400 * MHz;
- case DCLK_EBC_SEL_CPLL_333M:
return p_rate;
- case DCLK_EBC_SEL_GPLL_200M:
return 200 * MHz;
- default:
return -ENOENT;
+static ulong rk3568_ebc_set_clk(struct rk3568_clk_priv *priv, ulong rate) +{
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate);
- rk_clrsetreg(&cru->clksel_con[79],
CPLL_333M_DIV_MASK,
(src_clk_div - 1) << CPLL_333M_DIV_SHIFT);
- rk_clrsetreg(&cru->clksel_con[43],
DCLK_EBC_SEL_MASK,
DCLK_EBC_SEL_CPLL_333M << DCLK_EBC_SEL_SHIFT);
- return rk3568_ebc_get_clk(priv);
+static ulong rk3568_rkvdec_get_clk(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 con, div, src, p_rate;
- switch (clk_id) {
- case ACLK_RKVDEC_PRE:
- case ACLK_RKVDEC:
con = readl(&cru->clksel_con[47]);
src = (con & ACLK_RKVDEC_SEL_MASK) >> ACLK_RKVDEC_SEL_SHIFT;
div = (con & ACLK_RKVDEC_DIV_MASK) >> ACLK_RKVDEC_DIV_SHIFT;
if (src == ACLK_RKVDEC_SEL_CPLL)
p_rate = priv->cpll_hz;
else
p_rate = priv->gpll_hz;
return DIV_TO_RATE(p_rate, div);
- case CLK_RKVDEC_CORE:
con = readl(&cru->clksel_con[49]);
src = (con & CLK_RKVDEC_CORE_SEL_MASK)
div = (con & CLK_RKVDEC_CORE_DIV_MASK)
>> CLK_RKVDEC_CORE_DIV_SHIFT;
if (src == CLK_RKVDEC_CORE_SEL_CPLL)
else if (src == CLK_RKVDEC_CORE_SEL_NPLL)
p_rate = priv->npll_hz;
else if (src == CLK_RKVDEC_CORE_SEL_VPLL)
p_rate = priv->vpll_hz;
else
- default:
return -ENOENT;
+static ulong rk3568_rkvdec_set_clk(struct rk3568_clk_priv *priv,
- int src_clk_div, src, p_rate;
- switch (clk_id) {
- case ACLK_RKVDEC:
src = (readl(&cru->clksel_con[47]) & ACLK_RKVDEC_SEL_MASK)
else
src_clk_div = DIV_ROUND_UP(p_rate, rate);
rk_clrsetreg(&cru->clksel_con[47],
ACLK_RKVDEC_SEL_MASK |
ACLK_RKVDEC_DIV_MASK,
(src << ACLK_RKVDEC_SEL_SHIFT) |
(src_clk_div - 1) << ACLK_RKVDEC_DIV_SHIFT);
break;
src = (readl(&cru->clksel_con[49]) & CLK_RKVDEC_CORE_SEL_MASK)
>> CLK_RKVDEC_CORE_SEL_SHIFT;
else
rk_clrsetreg(&cru->clksel_con[49],
CLK_RKVDEC_CORE_SEL_MASK |
CLK_RKVDEC_CORE_DIV_MASK,
(src << CLK_RKVDEC_CORE_SEL_SHIFT) |
(src_clk_div - 1) << CLK_RKVDEC_CORE_DIV_SHIFT);
break;
- default:
return -ENOENT;
- return rk3568_rkvdec_get_clk(priv, clk_id);
+static ulong rk3568_uart_get_rate(struct rk3568_clk_priv *priv, ulong clk_id) +{
- u32 reg, con, fracdiv, div, src, p_src, p_rate;
- switch (clk_id) {
- case SCLK_UART1:
reg = 52;
break;
- case SCLK_UART2:
reg = 54;
break;
- case SCLK_UART3:
reg = 56;
break;
- case SCLK_UART4:
reg = 58;
break;
- case SCLK_UART5:
reg = 60;
break;
- case SCLK_UART6:
reg = 62;
break;
- case SCLK_UART7:
reg = 64;
break;
- case SCLK_UART8:
reg = 66;
break;
- case SCLK_UART9:
reg = 68;
break;
- default:
return -ENOENT;
- con = readl(&cru->clksel_con[reg]);
- src = (con & CLK_UART_SEL_MASK) >> CLK_UART_SEL_SHIFT;
- div = (con & CLK_UART_SRC_DIV_MASK) >> CLK_UART_SRC_DIV_SHIFT;
- p_src = (con & CLK_UART_SRC_SEL_MASK) >> CLK_UART_SRC_SEL_SHIFT;
- if (p_src == CLK_UART_SRC_SEL_GPLL)
- else if (p_src == CLK_UART_SRC_SEL_CPLL)
- else
p_rate = 480000000;
- if (src == CLK_UART_SEL_SRC) {
- } else if (src == CLK_UART_SEL_FRAC) {
fracdiv = readl(&cru->clksel_con[reg + 1]);
n = fracdiv & CLK_UART_FRAC_NUMERATOR_MASK;
n >>= CLK_UART_FRAC_NUMERATOR_SHIFT;
m = fracdiv & CLK_UART_FRAC_DENOMINATOR_MASK;
m >>= CLK_UART_FRAC_DENOMINATOR_SHIFT;
return DIV_TO_RATE(p_rate, div) * n / m;
- } else {
return OSC_HZ;
+static ulong rk3568_uart_set_rate(struct rk3568_clk_priv *priv,
- u32 reg, clk_src, uart_src, div;
- unsigned long m = 0, n = 0, val;
- if (priv->gpll_hz % rate == 0) {
clk_src = CLK_UART_SRC_SEL_GPLL;
uart_src = CLK_UART_SEL_SRC;
- } else if (priv->cpll_hz % rate == 0) {
clk_src = CLK_UART_SRC_SEL_CPLL;
- } else if (rate == OSC_HZ) {
uart_src = CLK_UART_SEL_XIN24M;
div = 2;
- } else {
uart_src = CLK_UART_SEL_FRAC;
div = 2;
rational_best_approximation(rate, priv->gpll_hz / div,
GENMASK(16 - 1, 0),
GENMASK(16 - 1, 0),
&m, &n);
- switch (clk_id) {
- case SCLK_UART1:
reg = 52;
break;
- case SCLK_UART2:
reg = 54;
break;
- case SCLK_UART3:
reg = 56;
break;
- case SCLK_UART4:
reg = 58;
break;
- case SCLK_UART5:
reg = 60;
break;
- case SCLK_UART6:
reg = 62;
break;
- case SCLK_UART7:
reg = 64;
break;
- case SCLK_UART8:
reg = 66;
break;
- case SCLK_UART9:
reg = 68;
break;
- default:
return -ENOENT;
- rk_clrsetreg(&cru->clksel_con[reg],
CLK_UART_SEL_MASK | CLK_UART_SRC_SEL_MASK |
CLK_UART_SRC_DIV_MASK,
(clk_src << CLK_UART_SRC_SEL_SHIFT) |
(uart_src << CLK_UART_SEL_SHIFT) |
((div - 1) << CLK_UART_SRC_DIV_SHIFT));
- if (m && n) {
val = m << CLK_UART_FRAC_NUMERATOR_SHIFT | n;
writel(val, &cru->clksel_con[reg + 1]);
- return rk3568_uart_get_rate(priv, clk_id);
+} +#endif
+static ulong rk3568_clk_get_rate(struct clk *clk) +{
- struct rk3568_clk_priv *priv = dev_get_priv(clk->dev);
- ulong rate = 0;
- if (!priv->gpll_hz) {
printf("%s gpll=%lu\n", __func__, priv->gpll_hz);
return -ENOENT;
- case PLL_APLL:
- case ARMCLK:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[APLL], priv->cru,
APLL);
break;
- case PLL_CPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[CPLL], priv->cru,
CPLL);
break;
- case PLL_GPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[GPLL], priv->cru,
GPLL);
break;
- case PLL_NPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[NPLL], priv->cru,
NPLL);
break;
- case PLL_VPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL], priv->cru,
VPLL);
break;
- case PLL_DPLL:
rate = rockchip_pll_get_rate(&rk3568_pll_clks[DPLL], priv->cru,
DPLL);
break;
- case ACLK_BUS:
- case PCLK_BUS:
- case PCLK_WDT_NS:
rate = rk3568_bus_get_clk(priv, clk->id);
break;
rate = rk3568_perimid_get_clk(priv, clk->id);
break;
- case HCLK_TOP:
- case PCLK_TOP:
rate = rk3568_top_get_clk(priv, clk->id);
break;
- case CLK_I2C1:
- case CLK_I2C2:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
rate = rk3568_i2c_get_clk(priv, clk->id);
break;
- case CLK_SPI0:
- case CLK_SPI1:
- case CLK_SPI2:
- case CLK_SPI3:
rate = rk3568_spi_get_clk(priv, clk->id);
break;
- case CLK_PWM1:
- case CLK_PWM2:
- case CLK_PWM3:
rate = rk3568_pwm_get_clk(priv, clk->id);
break;
- case CLK_SARADC:
- case CLK_TSADC:
rate = rk3568_adc_get_clk(priv, clk->id);
break;
- case HCLK_SDMMC0:
- case CLK_SDMMC0:
- case CLK_SDMMC1:
- case CLK_SDMMC2:
rate = rk3568_sdmmc_get_clk(priv, clk->id);
break;
- case SCLK_SFC:
rate = rk3568_sfc_get_clk(priv);
break;
- case NCLK_NANDC:
rate = rk3568_nand_get_clk(priv);
break;
- case CCLK_EMMC:
rate = rk3568_emmc_get_clk(priv);
break;
- case ACLK_VOP:
rate = rk3568_aclk_vop_get_clk(priv);
break;
- case DCLK_VOP0:
- case DCLK_VOP1:
- case DCLK_VOP2:
rate = rk3568_dclk_vop_get_clk(priv, clk->id);
break;
- case SCLK_GMAC0:
- case CLK_MAC0_2TOP:
- case CLK_MAC0_REFOUT:
rate = rk3568_gmac_src_get_clk(priv, 0);
break;
- case CLK_MAC0_OUT:
rate = rk3568_gmac_out_get_clk(priv, 0);
break;
- case CLK_GMAC0_PTP_REF:
rate = rk3568_gmac_ptp_ref_get_clk(priv, 0);
break;
- case SCLK_GMAC1:
- case CLK_MAC1_2TOP:
- case CLK_MAC1_REFOUT:
rate = rk3568_gmac_src_get_clk(priv, 1);
break;
- case CLK_MAC1_OUT:
rate = rk3568_gmac_out_get_clk(priv, 1);
break;
- case CLK_GMAC1_PTP_REF:
rate = rk3568_gmac_ptp_ref_get_clk(priv, 1);
break;
- case DCLK_EBC:
rate = rk3568_ebc_get_clk(priv);
break;
- case ACLK_RKVDEC:
rate = rk3568_rkvdec_get_clk(priv, clk->id);
break;
- case TCLK_WDT_NS:
rate = OSC_HZ;
break;
- case SCLK_UART1:
- case SCLK_UART2:
- case SCLK_UART3:
- case SCLK_UART4:
- case SCLK_UART5:
- case SCLK_UART6:
- case SCLK_UART7:
- case SCLK_UART8:
- case SCLK_UART9:
rate = rk3568_uart_get_rate(priv, clk->id);
break;
rate = rk3568_crypto_get_rate(priv, clk->id);
break;
- case CPLL_500M:
- case CPLL_333M:
- case CPLL_250M:
- case CPLL_125M:
- case CPLL_100M:
- case CPLL_62P5M:
- case CPLL_50M:
- case CPLL_25M:
rate = rk3568_cpll_div_get_rate(priv, clk->id);
break;
- default:
return -ENOENT;
- return rate;
+static ulong rk3568_clk_set_rate(struct clk *clk, ulong rate) +{
- ulong ret = 0;
return -ENOENT;
- case PLL_APLL:
- case ARMCLK:
if (priv->armclk_hz)
rk3568_armclk_set_clk(priv, rate);
priv->armclk_hz = rate;
break;
- case PLL_CPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[CPLL], priv->cru,
CPLL, rate);
priv->cpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[CPLL],
priv->cru, CPLL);
break;
- case PLL_GPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[GPLL], priv->cru,
GPLL, rate);
priv->gpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[GPLL],
priv->cru, GPLL);
break;
- case PLL_NPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[NPLL], priv->cru,
NPLL, rate);
break;
- case PLL_VPLL:
ret = rockchip_pll_set_rate(&rk3568_pll_clks[VPLL], priv->cru,
VPLL, rate);
priv->vpll_hz = rockchip_pll_get_rate(&rk3568_pll_clks[VPLL],
priv->cru,
VPLL);
break;
- case ACLK_BUS:
- case PCLK_BUS:
- case PCLK_WDT_NS:
ret = rk3568_bus_set_clk(priv, clk->id, rate);
break;
ret = rk3568_perimid_set_clk(priv, clk->id, rate);
break;
- case HCLK_TOP:
- case PCLK_TOP:
ret = rk3568_top_set_clk(priv, clk->id, rate);
break;
- case CLK_I2C1:
- case CLK_I2C2:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
ret = rk3568_i2c_set_clk(priv, clk->id, rate);
break;
- case CLK_SPI0:
- case CLK_SPI1:
- case CLK_SPI2:
- case CLK_SPI3:
ret = rk3568_spi_set_clk(priv, clk->id, rate);
break;
- case CLK_PWM1:
- case CLK_PWM2:
- case CLK_PWM3:
ret = rk3568_pwm_set_clk(priv, clk->id, rate);
break;
- case CLK_SARADC:
- case CLK_TSADC:
ret = rk3568_adc_set_clk(priv, clk->id, rate);
break;
- case HCLK_SDMMC0:
- case CLK_SDMMC0:
- case CLK_SDMMC1:
- case CLK_SDMMC2:
ret = rk3568_sdmmc_set_clk(priv, clk->id, rate);
break;
- case SCLK_SFC:
ret = rk3568_sfc_set_clk(priv, rate);
break;
- case NCLK_NANDC:
ret = rk3568_nand_set_clk(priv, rate);
break;
- case CCLK_EMMC:
ret = rk3568_emmc_set_clk(priv, rate);
break;
- case ACLK_VOP:
ret = rk3568_aclk_vop_set_clk(priv, rate);
break;
- case DCLK_VOP0:
- case DCLK_VOP1:
- case DCLK_VOP2:
ret = rk3568_dclk_vop_set_clk(priv, clk->id, rate);
break;
- case SCLK_GMAC0:
ret = rk3568_gmac_src_set_clk(priv, 0, rate);
break;
ret = rk3568_gmac_out_set_clk(priv, 0, rate);
break;
- case SCLK_GMAC0_RX_TX:
ret = rk3568_gmac_tx_rx_set_clk(priv, 0, rate);
break;
ret = rk3568_gmac_ptp_ref_set_clk(priv, 0, rate);
break;
- case SCLK_GMAC1:
ret = rk3568_gmac_src_set_clk(priv, 1, rate);
break;
ret = rk3568_gmac_out_set_clk(priv, 1, rate);
break;
- case SCLK_GMAC1_RX_TX:
ret = rk3568_gmac_tx_rx_set_clk(priv, 1, rate);
break;
ret = rk3568_gmac_ptp_ref_set_clk(priv, 1, rate);
break;
- case DCLK_EBC:
ret = rk3568_ebc_set_clk(priv, rate);
break;
- case ACLK_RKVDEC:
ret = rk3568_rkvdec_set_clk(priv, clk->id, rate);
I don't thing we need to set rkvdec clock in the U-Boot, pls remove it.
Thanks,
- Kever
break;
- case TCLK_WDT_NS:
ret = OSC_HZ;
break;
- case SCLK_UART1:
- case SCLK_UART2:
- case SCLK_UART3:
- case SCLK_UART4:
- case SCLK_UART5:
- case SCLK_UART6:
- case SCLK_UART7:
- case SCLK_UART8:
- case SCLK_UART9:
ret = rk3568_uart_set_rate(priv, clk->id, rate);
break;
ret = rk3568_crypto_set_rate(priv, clk->id, rate);
break;
- case CPLL_500M:
- case CPLL_333M:
- case CPLL_250M:
- case CPLL_125M:
- case CPLL_100M:
- case CPLL_62P5M:
- case CPLL_50M:
- case CPLL_25M:
ret = rk3568_cpll_div_set_rate(priv, clk->id, rate);
break;
- default:
return -ENOENT;
- return ret;
+#if (IS_ENABLED(OF_CONTROL)) || (!IS_ENABLED(OF_PLATDATA)) +static int rk3568_gmac0_src_set_parent(struct clk *clk, struct clk *parent) +{
- if (parent->id == CLK_MAC0_2TOP)
rk_clrsetreg(&cru->clksel_con[31],
RMII0_EXTCLK_SEL_MASK,
RMII0_EXTCLK_SEL_MAC0_TOP <<
RMII0_EXTCLK_SEL_SHIFT);
- else
RMII0_EXTCLK_SEL_IO << RMII0_EXTCLK_SEL_SHIFT);
+static int rk3568_gmac1_src_set_parent(struct clk *clk, struct clk *parent) +{
- if (parent->id == CLK_MAC1_2TOP)
rk_clrsetreg(&cru->clksel_con[33],
- else
+static int rk3568_gmac0_tx_rx_set_parent(struct clk *clk, struct clk *parent) +{
- if (parent->id == SCLK_GMAC0_RGMII_SPEED)
RMII0_MODE_MASK,
RMII0_MODE_SEL_RGMII << RMII0_MODE_SHIFT);
- else if (parent->id == SCLK_GMAC0_RMII_SPEED)
RMII0_MODE_MASK,
RMII0_MODE_SEL_RMII << RMII0_MODE_SHIFT);
- else
RMII0_MODE_MASK,
RMII0_MODE_SEL_GMII << RMII0_MODE_SHIFT);
+static int rk3568_gmac1_tx_rx_set_parent(struct clk *clk, struct clk *parent) +{
- if (parent->id == SCLK_GMAC1_RGMII_SPEED)
RMII0_MODE_MASK,
- else if (parent->id == SCLK_GMAC1_RMII_SPEED)
RMII0_MODE_MASK,
- else
RMII0_MODE_MASK,
+static int __maybe_unused rk3568_dclk_vop_set_parent(struct clk *clk,
struct clk *parent)
- u32 con_id;
- case DCLK_VOP0:
con_id = 39;
break;
- case DCLK_VOP1:
con_id = 40;
break;
- case DCLK_VOP2:
con_id = 41;
break;
- default:
return -EINVAL;
- if (parent->id == PLL_VPLL) {
rk_clrsetreg(&cru->clksel_con[con_id], DCLK0_VOP_SEL_MASK,
DCLK_VOP_SEL_VPLL << DCLK0_VOP_SEL_SHIFT);
- } else {
DCLK_VOP_SEL_HPLL << DCLK0_VOP_SEL_SHIFT);
+static int __maybe_unused rk3568_rkvdec_set_parent(struct clk *clk,
struct clk *parent)
- u32 con_id, mask, shift;
con_id = 47;
mask = ACLK_RKVDEC_SEL_MASK;
shift = ACLK_RKVDEC_SEL_SHIFT;
break;
con_id = 49;
mask = CLK_RKVDEC_CORE_SEL_MASK;
shift = CLK_RKVDEC_CORE_SEL_SHIFT;
break;
- default:
return -EINVAL;
- if (parent->id == PLL_CPLL) {
rk_clrsetreg(&cru->clksel_con[con_id], mask,
ACLK_RKVDEC_SEL_CPLL << shift);
- } else {
ACLK_RKVDEC_SEL_GPLL << shift);
+static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) +{
- case SCLK_GMAC0:
return rk3568_gmac0_src_set_parent(clk, parent);
- case SCLK_GMAC1:
return rk3568_gmac1_src_set_parent(clk, parent);
return rk3568_gmac0_tx_rx_set_parent(clk, parent);
return rk3568_gmac1_tx_rx_set_parent(clk, parent);
- case DCLK_VOP0:
- case DCLK_VOP1:
- case DCLK_VOP2:
return rk3568_dclk_vop_set_parent(clk, parent);
return rk3568_rkvdec_set_parent(clk, parent);
- default:
return -ENOENT;
+} +#endif
+static struct clk_ops rk3568_clk_ops = {
- .get_rate = rk3568_clk_get_rate,
- .set_rate = rk3568_clk_set_rate,
- .set_parent = rk3568_clk_set_parent,
+#endif +};
+static void rk3568_clk_init(struct rk3568_clk_priv *priv) +{
- int ret;
- priv->sync_kernel = false;
- if (!priv->armclk_enter_hz) {
priv->armclk_enter_hz =
priv->cru, APLL);
priv->armclk_init_hz = priv->armclk_enter_hz;
- if (priv->armclk_init_hz != APLL_HZ) {
ret = rk3568_armclk_set_clk(priv, APLL_HZ);
if (!ret)
priv->armclk_init_hz = APLL_HZ;
- if (priv->cpll_hz != CPLL_HZ) {
CPLL, CPLL_HZ);
if (!ret)
priv->cpll_hz = CPLL_HZ;
- if (priv->gpll_hz != GPLL_HZ) {
GPLL, GPLL_HZ);
if (!ret)
priv->gpll_hz = GPLL_HZ;
+#ifdef CONFIG_SPL_BUILD
- ret = rk3568_bus_set_clk(priv, ACLK_BUS, 150000000);
- if (ret < 0)
printf("Fail to set the ACLK_BUS clock.\n");
- priv->ppll_hz = rk3568_pmu_pll_get_rate(priv, PPLL);
- priv->hpll_hz = rk3568_pmu_pll_get_rate(priv, HPLL);
+static int rk3568_clk_probe(struct udevice *dev) +{
- struct rk3568_clk_priv *priv = dev_get_priv(dev);
- int ret;
- priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- if (IS_ERR(priv->grf))
return PTR_ERR(priv->grf);
- rk3568_clk_init(priv);
- /* Process 'assigned-{clocks/clock-parents/clock-rates}' properties */
- ret = clk_set_defaults(dev, 1);
- if (ret)
debug("%s clk_set_defaults failed %d\n", __func__, ret);
- else
priv->sync_kernel = true;
+static int rk3568_clk_ofdata_to_platdata(struct udevice *dev) +{
- priv->cru = dev_read_addr_ptr(dev);
+static int rk3568_clk_bind(struct udevice *dev) +{
- int ret;
- struct udevice *sys_child;
- struct sysreset_reg *priv;
- /* The reset driver does not have a device node, so bind it here */
- ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset",
&sys_child);
- if (ret) {
debug("Warning: No sysreset driver: ret=%d\n", ret);
- } else {
priv = malloc(sizeof(struct sysreset_reg));
priv->glb_srst_fst_value = offsetof(struct rk3568_cru,
glb_srst_fst);
priv->glb_srst_snd_value = offsetof(struct rk3568_cru,
glb_srsr_snd);
- ret = offsetof(struct rk3568_cru, softrst_con[0]);
- ret = rockchip_reset_bind(dev, ret, 30);
- if (ret)
debug("Warning: software reset driver bind faile\n");
+static const struct udevice_id rk3568_clk_ids[] = {
- { .compatible = "rockchip,rk3568-cru" },
+U_BOOT_DRIVER(rockchip_rk3568_cru) = {
- .name = "rockchip_rk3568_cru",
- .id = UCLASS_CLK,
- .of_match = rk3568_clk_ids,
- .priv_auto = sizeof(struct rk3568_clk_priv),
- .of_to_plat = rk3568_clk_ofdata_to_platdata,
- .ops = &rk3568_clk_ops,
- .bind = rk3568_clk_bind,
- .probe = rk3568_clk_probe,
- .plat_auto = sizeof(struct rk3568_clk_plat),
+#endif +};
Elaine@denx.de
Kever Yang
