Re: [U-Boot] [PATCH 1/1] cmd: add eficfg command
This relates to a patch in https://git.linaro.org/people/takahiro.akashi/u-boot.git branch efi/for_sct.
On 05/29/2018 08:47 AM, AKASHI Takahiro wrote:
Thanks for providing a possibility to edit EFI variables.
Before submitting, please, split the patch into a patch series.
E.g. moving definitions from cmd/bootefi.c to include/efi_loader.h could be in a separate patch.
cmd/Makefile | 2 +- cmd/bootefi.c | 52 +++- cmd/eficfg.c | 530 +++++++++++++++++++++++++++++++++++ include/efi_loader.h | 24 ++ lib/efi_loader/efi_bootmgr.c | 65 +++-- 5 files changed, 639 insertions(+), 34 deletions(-) create mode 100644 cmd/eficfg.c
diff --git a/cmd/Makefile b/cmd/Makefile index 13cf7bf6c2..6794eb9dcc 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -23,7 +23,7 @@ obj-$(CONFIG_CMD_BINOP) += binop.o obj-$(CONFIG_CMD_BLOCK_CACHE) += blkcache.o obj-$(CONFIG_CMD_BMP) += bmp.o obj-$(CONFIG_CMD_BOOTCOUNT) += bootcount.o -obj-$(CONFIG_CMD_BOOTEFI) += bootefi.o +obj-$(CONFIG_CMD_BOOTEFI) += bootefi.o eficfg.o obj-$(CONFIG_CMD_BOOTMENU) += bootmenu.o obj-$(CONFIG_CMD_BOOTSTAGE) += bootstage.o obj-$(CONFIG_CMD_BOOTZ) += bootz.o diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 28cc64bd02..9c1f5ffc89 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -544,32 +544,43 @@ U_BOOT_CMD( bootefi_help_text );
-void efi_set_bootdev(const char *dev, const char *devnr, const char *path) +efi_status_t __efi_set_bootdev(const char *dev, const char *devnr,
const char *path,
struct efi_device_path **device,
struct efi_device_path **file)
- int is_net;
- struct blk_desc *desc = NULL;
- disk_partition_t fs_partition;
- int part = 0;
- struct efi_device_path *dp; char filename[32] = { 0 }; /* dp->str is u16[32] long */ char *s;
- if (strcmp(dev, "Net")) {
struct blk_desc *desc;
int part;
- is_net = !strcmp(dev, "Net");
- if (!is_net) { part = blk_get_device_part_str(dev, devnr, &desc, &fs_partition, 1); if (part < 0)
return;
return CMD_RET_FAILURE;
bootefi_device_path = efi_dp_from_part(desc, part);
} else {dp = efi_dp_from_part(desc, part);
#ifdef CONFIG_NET
bootefi_device_path = efi_dp_from_eth();
dp = efi_dp_from_eth();
#endif }
- if (device)
*device = dp;
+#if 0 /* FIXME */
- else
free(dp);
if (!path)
return;
- if (!is_net) { /* Add leading / to fs paths, because they're absolute */ snprintf(filename, sizeof(filename), "/%s", path); } else {
@@ -579,5 +590,22 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) s = filename; while ((s = strchr(s, '/'))) *s++ = '\';
- bootefi_image_path = efi_dp_from_file(NULL, 0, filename);
- if (device || is_net)
*file = efi_dp_from_file(NULL, 0, filename);
- else
*file = efi_dp_from_file(desc, part, filename);
- return EFI_SUCCESS;
+void efi_set_bootdev(const char *dev, const char *devnr, const char *path) +{
- struct efi_device_path *device, *image;
- efi_status_t ret;
- ret = __efi_set_bootdev(dev, devnr, path, &device, &image);
- if (ret == EFI_SUCCESS) {
bootefi_device_path = device;
bootefi_image_path = image;
} diff --git a/cmd/eficfg.c b/cmd/eficfg.c new file mode 100644 index 0000000000..3a0dc3afe0 --- /dev/null +++ b/cmd/eficfg.c @@ -0,0 +1,530 @@ +/*
- EFI Shell-like configuration command
- Copyright (c) 2018 Takahiro AKASHI, Linaro Limited
+#include <charset.h> +#include <common.h> +#include <command.h> +#include <efi_loader.h> +#include <environment.h> +#include <errno.h> +#include <exports.h> +#include <search.h> +#include <asm/global_data.h>
+DECLARE_GLOBAL_DATA_PTR;
+/* TODO: move this to somewhere */ +efi_status_t __efi_set_bootdev(const char *dev, const char *devnr,
const char *path,
struct efi_device_path **file);
- From efi_variable.c,
- Mapping between EFI variables and u-boot variables:
- efi_$guid_$varname = {attributes}(type)value
+static efi_status_t do_efi_get_var(int argc, char * const argv[]) +{
- char regex[256];
- char *regexlist[] = {regex};
- char *res = NULL;
- int len;
- if (argc > 2)
return CMD_RET_USAGE;
- if (argc == 2)
snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_%s", argv[1]);
- else
snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_.*");
- debug("%s:%d grep uefi var %s\n", __func__, __LINE__, regex);
- len = hexport_r(&env_htab, '\n', H_MATCH_REGEX | H_MATCH_KEY,
&res, 0, 1, regexlist);
- if (len < 0)
- if (len > 0) {
/* TODO: pretty-print */
puts(res);
free(res);
if (len < 2 && argc == 2)
printf("%s: not found\n", argv[1]);
+static bool isalnum(char c) +{
- if (c >= '0' && c <= '9')
return true;
- if (c >= 'A' && c <= 'F')
return true;
- if (c >= 'a' && c <= 'f')
return true;
- return false;
Please, use isxdigit() defined in include/linux/ctype.h.
+static efi_status_t do_efi_set_var(int argc, char * const argv[]) +{
- char *value, *data, *ptr, *ptr2 = NULL, num[3] = {'\0', '\0', '\0'};
- unsigned long len, size;
efi_uintn_t len, size;
to avoid
warning: passing argument 4 of ‘efi_set_variable’ from incompatible pointer type
on 32bit build.
- u16 *var_name;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc == 1)
return EFI_SUCCESS;
- if (argc == 2) {
value = NULL;
size = 0;
- } else if (argc == 3) {
value = argv[2];
if (value[0] == '=')
value++;
len = strlen(value);
if ((len > 2) && !strncmp(value, "0x", 2)) {
if ((len % 2))
data = value + 2;
size = (len - 2) / 2;
ptr2 = ptr = malloc(size);
len = 0;
+printf("+++ value: %s, data: %s, size:%ld\n", value, data, size);
But this line will anyway be removed from the final patch.
while (len < size * 2) {
num[0] = data[len++];
num[1] = data[len++];
if (!isalnum(num[0]) || !isalnum(num[1])) {
printf("Invalid format: %s\n\n", value);
ret = CMD_RET_USAGE;
goto out;
+printf("+++ num: %s, len:%ld\n", num, len);
*ptr++ = (char)simple_strtoul(num, NULL, 16);
value = data;
} else
size = len;
- } else
- var_name = malloc((strlen(argv[1]) + 1) * 2);
- utf8_to_utf16(var_name, (u8 *)argv[1], strlen(argv[1]) + 1);
- /* FIXME: guid and attributes */
- guid = efi_global_variable_guid;
- ret = efi_set_variable(var_name, &guid,
EFI_VARIABLE_BOOTSERVICE_ACCESS |
EFI_VARIABLE_RUNTIME_ACCESS, size, value);
+out:
- if (ptr2)
free(ptr2);
- return ret;
+static int show_efi_device_path(struct efi_device_path *dp0) +{
- char *type, *sub_type;
Please, reuse efi_convert_device_path_to_text().
- while (dp0->type != DEVICE_PATH_TYPE_END) {
switch (dp0->type) {
case DEVICE_PATH_TYPE_HARDWARE_DEVICE:
type = "hardware";
switch (dp0->sub_type) {
struct efi_device_path_memory *dp_mem;
struct efi_device_path_vendor *dp_vendor;
case DEVICE_PATH_SUB_TYPE_MEMORY:
dp_mem = (typeof(dp_mem))dp0;
printf("\t\t%s/memory: %llx-%llx\n",
type,
dp_mem->start_address,
dp_mem->end_address);
break;
case DEVICE_PATH_SUB_TYPE_VENDOR:
dp_vendor = (typeof(dp_vendor))dp0;
/* TODO: print guid */
printf("\t\t%s/vendor:\n", type);
break;
default:
printf("\t\tUnknown subtype:%s/%02x\n",
type, dp0->sub_type);
break;
break;
case DEVICE_PATH_TYPE_ACPI_DEVICE:
type = "acpi";
struct efi_device_path_acpi_path *dp_acpi;
case DEVICE_PATH_SUB_TYPE_ACPI_DEVICE:
dp_acpi = (typeof(dp_acpi))dp0;
printf("\t\t%s/%s: hid=%08x uid=%08x\n",
type, type,
dp_acpi->hid, dp_acpi->uid);
break;
default:
break;
break;
case DEVICE_PATH_TYPE_MESSAGING_DEVICE:
type = "messaging";
/* TODO */
struct efi_device_path_sd_mmc_path *dp_sd;
case DEVICE_PATH_SUB_TYPE_MSG_ATAPI:
sub_type = "atapi";
printf("\t\ttype:%s/%s\n", type, sub_type);
break;
case DEVICE_PATH_SUB_TYPE_MSG_SCSI:
sub_type = "scsi";
break;
case DEVICE_PATH_SUB_TYPE_MSG_USB:
sub_type = "usb";
break;
case DEVICE_PATH_SUB_TYPE_MSG_MAC_ADDR:
sub_type = "mac-addr";
break;
case DEVICE_PATH_SUB_TYPE_MSG_USB_CLASS:
sub_type = "usb-class";
break;
case DEVICE_PATH_SUB_TYPE_MSG_SD:
sub_type = "sd";
dp_sd = (typeof(dp_sd))dp0;
printf("\t\t%s/sd: slot=%d\n",
type, (int)dp_sd->slot_number);
break;
case DEVICE_PATH_SUB_TYPE_MSG_MMC:
sub_type = "mmc";
break;
default:
sub_type = "unknown";
break;
break;
case DEVICE_PATH_TYPE_MEDIA_DEVICE:
type = "media";
struct efi_device_path_hard_drive_path *dp_hd;
struct efi_device_path_cdrom_path *dp_cdrom;
struct efi_device_path_file_path *dp_file;
char file[256];
case DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH:
dp_hd = (typeof(dp_hd))dp0;
printf("\t\t%s/disk: %d(0x%llx-0x%llx)\n",
type,
dp_hd->partition_number,
dp_hd->partition_start,
dp_hd->partition_end);
break;
case DEVICE_PATH_SUB_TYPE_CDROM_PATH:
dp_cdrom = (typeof(dp_cdrom))dp0;
printf("\t\t%s/cdrom: %d(0x%llx-0x%llx)\n",
type,
dp_cdrom->boot_entry,
dp_cdrom->partition_start,
dp_cdrom->partition_end);
break;
case DEVICE_PATH_SUB_TYPE_FILE_PATH:
dp_file = (typeof(dp_file))dp0;
utf16_to_utf8((u8 *)file, dp_file->str,
utf16_strlen(dp_file->str) + 1);
printf("\t\t%s/file: %s\n", type, file);
break;
default:
break;
break;
default:
printf("\t\tUnknown type:%02x\n", dp0->type);
break;
dp0 = ((void *)dp0 + dp0->length);
+void dump_data(void *data, size_t count) +{
- char *p;
- int i, j;
- for (i = 0, p = data; i < count; i += 8) {
printf("| %p:", data + i);
for (j = 0; j < 8; j++) {
if (i + j < count) {
if (j == 4)
puts(" ");
printf(" %02x", *p++);
} else {
putc('\n');
goto out;
putc('\n');
+out:
- return;
+static efi_status_t show_efi_boot_opt(int id, void *data) +{
- struct load_option lo;
- char *label;
- parse_load_option(&lo, data);
- label = malloc(utf16_strlen(lo.label) + 1);
- if (!label)
return EFI_OUT_OF_RESOURCES;
- utf16_to_utf8((u8 *)label, lo.label, utf16_strlen(lo.label) + 1);
- printf("Boot%04X:\n", id);
- printf("\tattributes: %c%c%c (0x%08x)\n",
/* ACTIVE */
lo.attributes & 0x1 ? 'A' : '-',
/* FORCE RECONNECT */
lo.attributes & 0x2 ? 'R' : '-',
/* HIDDEN */
lo.attributes & 0x8 ? 'H' : '-',
lo.attributes);
- printf("\tlabel: %s\n", label);
- printf("\tfile_path: ");
+{ /* TODO */
- u16 *dp_str = efi_dp_str(lo.file_path);
- printf("%ls\n", dp_str);
- efi_free_pool(dp_str);
- show_efi_device_path((struct efi_device_path *)lo.file_path);
Use efi_convert_device_path_to_text().
- printf("\tdata: %s\n", lo.optional_data);
- free(label);
+static efi_status_t do_efi_boot_opt(int argc, char * const argv[]) +{
- int id;
- char *endp;
- char var_name[9];
- u16 var_name16[9];
- efi_guid_t guid;
- void *data;
- unsigned long size;
efi_uintn_t size;
- int ret;
- uint32_t attr;
- u16 *label;
- char *interface, *device, *file, *option;
- struct efi_device_path *file_path;
- if (argc == 1)
- id = (int)simple_strtoul(argv[1], &endp, 0);
- if (*endp != '\0' || id > 0xffff)
return EFI_INVALID_PARAMETER;
- sprintf(var_name, "Boot%04X", id);
- utf8_to_utf16(var_name16, (u8 *)var_name, 9);
- if (argc == 2) {
size = 0;
ret = efi_get_variable(var_name16, &guid, NULL, &size, NULL);
if (ret == (int)EFI_BUFFER_TOO_SMALL) {
data = malloc(size);
NULL, &size, data);
if (ret != EFI_SUCCESS) {
printf("Boot%04X: not found\n", id);
return EFI_SUCCESS;
+dump_data(data, size+2);
ret = show_efi_boot_opt(id, data);
free(data);
return ret;
- if (argc < 7 || argc > 8)
- attr = (uint32_t)simple_strtoul(argv[2], NULL, 0);
- label = malloc(((strlen(argv[3]) + 1)) * 2);
- if (!label)
- utf8_to_utf16(label, (u8 *)argv[3], strlen(argv[3]) + 1);
- interface = argv[4];
- device = argv[5];
- file = argv[6];
- option = (argc == 7 ? "" : argv[7]);
- ret = __efi_set_bootdev(interface, device, file, NULL, &file_path);
- if (ret != EFI_SUCCESS)
goto out_err;
- size = efi_marshal_load_option(attr, label, file_path, option, &data);
- if (!size) {
ret = CMD_RET_FAILURE;
goto out_err2;
- ret = efi_set_variable(var_name16, &guid,
EFI_VARIABLE_RUNTIME_ACCESS, size, data);
- free(data);
+out_err2: +#if 0 /* FIXME */
- free(file_path);
+#endif +out_err:
- free(label);
- return ret;
+static efi_status_t do_efi_boot_order(int argc, char * const argv[]) +{
- u16 *bootorder = NULL;
- unsigned long size, value;
+ efi_uintn_t size; + unsigned long value;
- efi_guid_t guid;
- efi_status_t ret = EFI_SUCCESS;
- int num, i;
- char *endp;
- if (argc == 1) {
size = 0;
ret = efi_get_variable(u"BootOrder",
if (ret == EFI_BUFFER_TOO_SMALL) {
bootorder = malloc(size);
&guid, NULL, &size, bootorder);
printf("BootOrder not defined\n");
return EFI_SUCCESS;
num = size / sizeof(u16);
for (i = 0; i < num; i++)
/* TODO: more details */
printf("%2d: Boot%04X\n", i + 1, bootorder[i]);
goto out;
- argc--;
- argv++;
- size = argc * sizeof(u16);
- bootorder = malloc(size);
- if (!bootorder)
- for (i = 0; i < argc; i++) {
value = simple_strtoul(argv[i], &endp, 0);
if (*endp != '\0') {
printf("invalid value: %s\n", argv[i]);
goto out;
bootorder[i] = (u16)value;
- ret = efi_set_variable(u"BootOrder", &guid,
EFI_VARIABLE_RUNTIME_ACCESS, size, bootorder);
+out:
- free(bootorder);
- return ret;
+/* Interpreter command to configure EFI environment */ +static int do_eficfg(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
- char *command;
+#if 1 /* FIXME */
- efi_status_t r;
- extern efi_status_t efi_init_obj_list(void);
- /* Initialize EFI drivers */
- r = efi_init_obj_list();
- if (r != EFI_SUCCESS) {
printf("Error: Cannot set up EFI drivers, r = %lu\n",
r & ~EFI_ERROR_MASK);
- if (argc < 2)
- command = argv[1];
- argc--; argv++;
- if (!strcmp(command, "getvar"))
return do_efi_get_var(argc, argv);
- else if (!strcmp(command, "setvar"))
return do_efi_set_var(argc, argv);
- else if (!strcmp(command, "device") || !strcmp(command, "boot"))
return do_efi_boot_opt(argc, argv);
- else if (!strcmp(command, "order"))
return do_efi_boot_order(argc, argv);
- else
+#ifdef CONFIG_SYS_LONGHELP +static char eficfg_help_text[] =
- " - EFI Shell-like interface to configure EFI envrionment\n"
- "\n"
- "eficfg getvar [<name>]\n"
- " - get uefi variable's value\n"
- "eficfg setvar <name> [<value>]\n"
- " - set/delete uefi variable's value\n"
- " <value> may be "="..."", "=0x..." (set) or "=" (delete)\n"
- "\n"
- "eficfg device <bootid> <attr> <label> "
- "<interface> <device>[:<part>] <file path> <option>\n"
- "eficfg order <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n"
- " - set uefi boot order\n";
+U_BOOT_CMD(
- eficfg, 10, 0, do_eficfg,
- "Configure EFI environment",
- eficfg_help_text
+); diff --git a/include/efi_loader.h b/include/efi_loader.h index 664179ba5f..929784002c 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -450,6 +450,30 @@ efi_status_t EFIAPI efi_set_variable(u16 *variable_name, efi_guid_t *vendor, u32 attributes, efi_uintn_t data_size, void *data);
- See section 3.1.3 in the v2.7 UEFI spec for more details on
- the layout of EFI_LOAD_OPTION. In short it is:
- typedef struct _EFI_LOAD_OPTION {
UINT32 Attributes;
UINT16 FilePathListLength;
// CHAR16 Description[]; <-- variable length, NULL terminated
// EFI_DEVICE_PATH_PROTOCOL FilePathList[]; <-- FilePathListLength bytes
// UINT8 OptionalData[];
- } EFI_LOAD_OPTION;
+struct load_option {
- u32 attributes;
- u16 file_path_length;
- u16 *label;
- u8 *optional_data;
+void parse_load_option(struct load_option *lo, void *ptr); +unsigned long efi_marshal_load_option(uint32_t attr, uint16_t *label,
struct efi_device_path *file_path,
char *option, void **data);
void *efi_bootmgr_load(struct efi_device_path **device_path, struct efi_device_path **file_path);
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 853358ab93..3cadccd699 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -4,6 +4,7 @@
- Copyright (c) 2017 Rob Clark
*/ +#define DEBUG
To be removed before submitting.
Best regards
Heinrich
#include <common.h> #include <charset.h> @@ -30,28 +31,8 @@ static const struct efi_runtime_services *rs; */
UINT32 Attributes;
-struct load_option {
- u32 attributes;
- u16 *label;
/* parse an EFI_LOAD_OPTION, as described above */ -static void parse_load_option(struct load_option *lo, void *ptr) +void parse_load_option(struct load_option *lo, void *ptr) { lo->attributes = *(u32 *)ptr; ptr += sizeof(u32); @@ -68,6 +49,48 @@ static void parse_load_option(struct load_option *lo, void *ptr) lo->optional_data = ptr; }
- unsigned long label_len, option_len;
- uint16_t file_path_len;
- void *p;
- label_len = (utf16_strlen(label) + 1) * 2;
- file_path_len = efi_dp_size(file_path)
+ sizeof(struct efi_device_path); /* for END */
- option_len = strlen(option);
- /* total size */
- size = sizeof(attr);
- size += file_path_len;
- size += label_len;
- size += option_len + 1;
- p = malloc(size);
- if (!p)
- /* copy data */
- *data = p;
- memcpy(p, &attr, sizeof(attr));
- p += sizeof(attr);
- memcpy(p, &file_path_len, sizeof(file_path_len));
- p += sizeof(file_path_len);
- memcpy(p, label, label_len);
- p += label_len;
- memcpy(p, file_path, file_path_len);
- p += file_path_len;
- memcpy(p, option, option_len);
- p += option_len;
- *(char *)p = '\0';
- return size;
/* free() the result */ static void *get_var(u16 *name, const efi_guid_t *vendor, efi_uintn_t *size)
<snip>
You can output a device path with printf("%pD\n", device_path);
Missing nodes should be implemented in lib/efi_loader/efi_device_path_to_text.c
Best regards
Heinrich
