[PATCH v3 00/10] ClearFog Base static variant support
This patch series adds support for ClearFog Base static configuration, as well as updating and fixing the ClearFog support for MMC and SPI booting.
Stefan - I think everything is straight forward, with the only known unresolved question being handling of the duplicated Kconfig entries for the board-specific overrides. I've laid out the description in that particular commit, if you have guidance on a preferred approach I'm all ears.
V2 changes: - updated against, and dependent on, https://patchwork.ozlabs.org/cover/1200324 V3 changes: - rebased against ClearFog runtime TLV EEPROM changes merged into mvebu/master
Joel Johnson (10): arm: mvebu: fix SerDes table alignment arm: mvebu: solidrun: remove hardcoded DTS MAC address arm: mvebu: clearfog: initial ClearFog Base variant arm: mvebu: clearfog: Use Pro DT by default arm: mvebu: clearfog: Add SATA mode flags arm: mvebu: clearfog: Add option for 2.5 Gbps SFP arm: mvebu: clearfog: add SPI offsets arm: mvebu: enable working default boot support arm: mvebu: clearfog: move ENV params to Kconfig arm: mvebu: clearfog: reduce MMC boot assumptions
.../arm/dts/armada-38x-solidrun-microsom.dtsi | 1 - arch/arm/mach-mvebu/Kconfig | 13 ++++ .../serdes/a38x/high_speed_env_spec.c | 6 +- board/solidrun/clearfog/Kconfig | 62 +++++++++++++++++++ board/solidrun/clearfog/clearfog.c | 26 +++++++- configs/clearfog_defconfig | 5 -- include/configs/clearfog.h | 1 - 7 files changed, 103 insertions(+), 11 deletions(-) create mode 100644 board/solidrun/clearfog/Kconfig
Tested on Solidrun ClearFog Base. Table alignment was: | Lane # | Speed | Type | -------------------------------- | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 3 | SATA1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | USB3 HOST0 | | 5 | 4 | SGMII2 | --------------------------------
After the change, it's correctly aligned as: | Lane # | Speed | Type | -------------------------------- | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 5 | PCIe1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | PCIe2 | | 5 | 0 | SGMII2 | --------------------------------
Signed-off-by: Joel Johnson mrjoel@lixil.net
v2 changes - none v3 changes - none
--- arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c index 33e70569bc..66409a50c0 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c +++ b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c @@ -1366,16 +1366,16 @@ static void print_topology_details(const struct serdes_map *serdes_map,
DEBUG_INIT_S("board SerDes lanes topology details:\n");
- DEBUG_INIT_S(" | Lane # | Speed | Type |\n"); + DEBUG_INIT_S(" | Lane # | Speed | Type |\n"); DEBUG_INIT_S(" --------------------------------\n"); for (lane_num = 0; lane_num < count; lane_num++) { if (serdes_map[lane_num].serdes_type == DEFAULT_SERDES) continue; DEBUG_INIT_S(" | "); DEBUG_INIT_D(hws_get_physical_serdes_num(lane_num), 1); - DEBUG_INIT_S(" | "); + DEBUG_INIT_S(" | "); DEBUG_INIT_D(serdes_map[lane_num].serdes_speed, 2); - DEBUG_INIT_S(" | "); + DEBUG_INIT_S(" | "); DEBUG_INIT_S((char *) serdes_type_to_string[serdes_map[lane_num]. serdes_type]);
Using a consistent hardcoded MAC address from the DTS file causes issues when using multiple devices on the same network segment. Instead rely on environment configuration or random generation.
v2 changes: - none v3 changes: - none
--- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi index a322a28c21..9bbeafc53b 100644 --- a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi +++ b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi @@ -39,7 +39,6 @@
ð0 { /* ethernet@70000 */ - mac-address = [00 50 43 02 02 01]; pinctrl-0 = <&ge0_rgmii_pins>; pinctrl-names = "default"; phy = <&phy_dedicated>;
Add a unique entry for ClearFog Base variant, reflected in the board name and adjusted SerDes topology.
v2 changes: - reworked based on Baruch's run-time TLV EEPROM detection series v3 changes: - rebased on mvebu merged run-time TLV EEPROM detection series - minor update to help test regarding runtime detection failures
--- arch/arm/mach-mvebu/Kconfig | 2 ++ board/solidrun/clearfog/Kconfig | 18 ++++++++++++++++++ board/solidrun/clearfog/clearfog.c | 12 ++++++++++++ 3 files changed, 32 insertions(+) create mode 100644 board/solidrun/clearfog/Kconfig
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index bc5eaa5a76..161dee937f 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -280,4 +280,6 @@ config SECURED_MODE_CSK_INDEX default 0 depends on SECURED_MODE_IMAGE
+source "board/solidrun/clearfog/Kconfig" + endif diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig new file mode 100644 index 0000000000..936d5918f8 --- /dev/null +++ b/board/solidrun/clearfog/Kconfig @@ -0,0 +1,18 @@ +menu "ClearFog configuration" + depends on TARGET_CLEARFOG + +config TARGET_CLEARFOG_BASE + bool "Use ClearFog Base static configuration" + help + Use the ClearFog Base as the static configuration instead of the + default which uses the ClearFog Pro. + + Runtime board detection is always attempted and used if available. The + static configuration is used as a fallback in cases where runtime + detection is disabled, is not available in hardware, or otherwise fails. + + Only newer revisions of the ClearFog product line support runtime + detection via additional EEPROM hardware. This option enables selecting + the Base variant for older hardware revisions. + +endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index e268ef55a2..e77b9465d4 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -47,7 +47,11 @@ static struct serdes_map board_serdes_map[] = { {SGMII1, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, +#endif {SGMII2, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, };
@@ -170,7 +174,11 @@ int board_init(void)
int checkboard(void) { +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + char *board = "ClearFog Base"; +#else char *board = "ClearFog"; +#endif
cf_read_tlv_data(); if (strlen(cf_tlv_data.tlv_product_name[0]) > 0) @@ -200,6 +208,10 @@ int board_late_init(void) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb"); else if (sr_product_is(&cf_tlv_data, "Clearfog GTR L8")) env_set("fdtfile", "armada-385-clearfog-gtr-l8.dtb"); +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + else + env_set("fdtfile", "armada-388-clearfog-base.dtb"); +#endif
return 0; }
Hi Joel,
v2 changes:
v3 changes:
- depends on TARGET_CLEARFOG
- bool "Use ClearFog Base static configuration"
- help
- {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0},
I'd prefer run-time test instead of '#ifdefs' that IMO make the code harder to read. Something like this (build tested only):
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index e268ef55a2a0..202c60cb7841 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -55,7 +55,8 @@ int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count) { cf_read_tlv_data();
- if (sr_product_is(&cf_tlv_data, "Clearfog GTR")) { + if (sr_product_is(&cf_tlv_data, "Clearfog GTR") || + CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE)) { board_serdes_map[0].serdes_type = PEX0; board_serdes_map[0].serdes_speed = SERDES_SPEED_5_GBPS; board_serdes_map[0].serdes_mode = PEX_ROOT_COMPLEX_X1; @@ -172,6 +173,9 @@ int checkboard(void) { char *board = "ClearFog";
+ if (CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE)) + board = "ClearFog Base"; + cf_read_tlv_data(); if (strlen(cf_tlv_data.tlv_product_name[0]) > 0) board = cf_tlv_data.tlv_product_name[0]; @@ -194,7 +198,8 @@ int board_late_init(void) { cf_read_tlv_data();
- if (sr_product_is(&cf_tlv_data, "Clearfog Base")) + if (sr_product_is(&cf_tlv_data, "Clearfog Base") || + CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE)) env_set("fdtfile", "armada-388-clearfog-base.dtb"); else if (sr_product_is(&cf_tlv_data, "Clearfog GTR S4")) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb");
What do you think?
baruch
On 2020-01-21 10:49, Baruch Siach wrote:
Hi Joel,
v2 changes:
v3 changes:
- help
The
fails.
selecting
- if (sr_product_is(&cf_tlv_data, "Clearfog GTR") ||
board_serdes_map[0].serdes_type = PEX0; board_serdes_map[0].serdes_speed = SERDES_SPEED_5_GBPS; board_serdes_map[0].serdes_mode = PEX_ROOT_COMPLEX_X1;CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE)) {
- if (CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE))
- cf_read_tlv_data(); if (strlen(cf_tlv_data.tlv_product_name[0]) > 0) board = cf_tlv_data.tlv_product_name[0];
- if (sr_product_is(&cf_tlv_data, "Clearfog Base") ||
env_set("fdtfile", "armada-388-clearfog-base.dtb"); else if (sr_product_is(&cf_tlv_data, "Clearfog GTR S4")) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb");CONFIG_IS_ENABLED(TARGET_CLEARFOG_BASE))
What do you think?
baruch
I'll have to revisit and test to be sure, but I believe the reason I didn't go that route is because I wasn't able to get the CONFIG_IS_ENABLED macro version to trigger when building SPL, although it worked for the main path. I know that was the case for something I was working up, but I don't recall whether it was this patch specifically or not.
A bit of a nit, but just using the macro isn't really runtime detection, however adding the separate code path for naming and serdes manipulation dynamically tends that way. I'm already running into several cases (not the default build options) where the SPL doesn't fit in the default 128K offset size, so I'm leery of adding paths that add actual binary size increase. I'm all for switching to CONFIG_IS_ENABLED if I test and can get it to work, but still would lean towards just replacing the ifdef in place; after all it is meant to be the static configuration, not dynamic.
Joel
Hi Joel,
v2 changes:
v3 changes:
- help
available. The
fails.
selecting
What do you think?
baruch
Right. We need the IS_ENABLED() macro here. For CONFIG_IS_ENABLED() we would need another SPL_FOO config symbol. See include/linux/kconfig.h.
It probably makes more sense to reverse the order of ORed conditions:
if (IS_ENABLED(TARGET_CLEARFOG_BASE) || sr_product_is(&cf_tlv_data, "Clearfog Base"))
IS_ENABLED() is evaluated at build time. When it is true, the compiler drops all other 'if' branches, thus saving space. That also means that the build time configuration overrides the EEPROM set value, which is a Good Thing I believe.
I would really like to avoid additional #ifdefs if possible.
baruch
-- http://baruch.siach.name/blog/ ~. .~ Tk Open Systems =}------------------------------------------------ooO--U--Ooo------------{= - baruch@tkos.co.il - tel: +972.52.368.4656, http://www.tkos.co.il -
On January 22, 2020 10:32:58 AM UTC, Baruch Siach baruch@tkos.co.il wrote:
Hi Joel,
board
v2 changes:
v3 changes:
- help
the
available. The
runtime
otherwise
fails.
runtime
selecting
harder
What do you think?
baruch
didn't go
macro version
know
whether
detection,
manipulation
(not the
offset
increase. I'm
work, but
it is
I'll take a look and do testing and size comparison in the next day or two.
Note that I intended (and wrote the Base target help docs accordingly) that runtime detection, if both enabled and supported in hardware, should be preferred to the static configuration, with static config being only a fallback. This seems to be different from what your thought about it being good for build configuration to override EEPROM detected values, and I'm curious as to your reasoning.
There are a few gaps here related to what you point out (e.g. booting on a Pro with EEPROM and Base static config won't give the expected results). Relocating the static adjustment may be fine and help with that case as well.
I'll want to add support in such handling for the EEPROM Pro devices but don't have one available. You seem to have them available, can you confirm that "Clearfog Pro" would match those devices using sr_product_is?
Thanks, Joel
On 22.01.20 20:28, Joel Johnson wrote:
<snip>
This sounds reasonable.
I currently don't have any of these boards available, so I also would like to see some reviewed-by and even better tested-by comments from Baruch (or someone else at SolidRun).
Thanks, Stefan
Hi Joel,
board
v2 changes:
v3 changes:
- help
the
available. The
runtime
otherwise
fails.
runtime
selecting
harder
What do you think?
baruch
didn't go
macro version
know
whether
detection,
manipulation
(not the
offset
increase. I'm
work, but
it is
I was thinking about forcing board configuration for the manufacturing use case, when the EEPROM is not initialized. But I understand that this use case is not generally useful, unless the EEPROM data is damaged.
But if build time configuration serves as fallback, then you have to keep the run-time detection code anyway. How would '#ifdef' make your code smaller?
I considered Clearfog Pro a compatibility fallback. That is why it is not explicitly tested in the code, but assumed.
Clearfog Pro rev 2.2 is not in mass production yet to the best of my knowledge. I testing I used the "Clearfog Pro" string, which is a good match to "Clearfog Base" in current code.
baruch
Switch to explicitly using the Pro variant DT, which has been available since Linux 4.11. Also unify the location of DT selection in board_late_init instead of split between detection and static configuration paths.
v2 changes - newly added in V2 series based on run-time rebasing v2 changes - none
Signed-off-by: Joel Johnson mrjoel@lixil.net --- board/solidrun/clearfog/clearfog.c | 6 ++++-- include/configs/clearfog.h | 1 - 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index e77b9465d4..086912e400 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -177,7 +177,7 @@ int checkboard(void) #if defined (CONFIG_TARGET_CLEARFOG_BASE) char *board = "ClearFog Base"; #else - char *board = "ClearFog"; + char *board = "ClearFog Pro"; #endif
cf_read_tlv_data(); @@ -208,9 +208,11 @@ int board_late_init(void) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb"); else if (sr_product_is(&cf_tlv_data, "Clearfog GTR L8")) env_set("fdtfile", "armada-385-clearfog-gtr-l8.dtb"); -#if defined (CONFIG_TARGET_CLEARFOG_BASE) else +#if defined (CONFIG_TARGET_CLEARFOG_BASE) env_set("fdtfile", "armada-388-clearfog-base.dtb"); +#else + env_set("fdtfile", "armada-388-clearfog-pro.dtb"); #endif
return 0; diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 633187d86f..6ca0474461 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -134,7 +134,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ RELOCATION_LIMITS_ENV_SETTINGS \ LOAD_ADDRESS_ENV_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "console=ttyS0,115200\0" \ BOOTENV
Hi Joel,
v2 changes
v2 changes
- none
- char *board = "ClearFog Pro";
#endif
I'd prefer to keep the default here for backwards compatibility. The kernel also keeps armada-388-clearfog.dtb. The -pro variant only updates the 'model' and 'compatible' properties.
Unrelated to that here is another reason to avoid #ifdef. Syntax aware text editor automatic indentation might fail to see that the second env_set() is in the 'else' block. We can workaround that by adding braces around the block, but it's not nice.
baruch
#endif
The mPCIe slots on ClearFog Pro and ClearFog Base may be alternately configured for SATA usage.
v2 changes: - fixed help indentation v3 changes: - none
--- board/solidrun/clearfog/Kconfig | 17 +++++++++++++++++ board/solidrun/clearfog/clearfog.c | 6 ++++++ 2 files changed, 23 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index 936d5918f8..4e189b13e0 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -15,4 +15,21 @@ config TARGET_CLEARFOG_BASE detection via additional EEPROM hardware. This option enables selecting the Base variant for older hardware revisions.
+config CLEARFOG_CON3_SATA + bool "Use CON3 slot in SATA mode" + help + Use the CON3 port with SATA protocol instead of the default PCIe. + The ClearFog port allows usage of either mSATA or miniPCIe + modules, but the desired protocol must be configured at build + time since it affects the SerDes topology layout. + +config CLEARFOG_CON2_SATA + bool "Use CON2 slot in SATA mode" + depends on !TARGET_CLEARFOG_BASE + help + Use the CON2 port with SATA protocol instead of the default PCIe. + The ClearFog port allows usage of either mSATA or miniPCIe + modules, but the desired protocol must be configured at build + time since it affects the SerDes topology layout. + endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 086912e400..7046665d6c 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -45,10 +45,16 @@ static void cf_read_tlv_data(void) static struct serdes_map board_serdes_map[] = { {SATA0, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {SGMII1, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#if defined (CONFIG_CLEARFOG_CON3_SATA) + {SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, +#endif {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, #if defined (CONFIG_TARGET_CLEARFOG_BASE) {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#elif defined(CONFIG_CLEARFOG_CON2_SATA) + {SATA2, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, #else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, #endif
Hi Joel,
v2 changes:
v3 changes:
- none
- bool "Use CON3 slot in SATA mode"
- help
- bool "Use CON2 slot in SATA mode"
- depends on !TARGET_CLEARFOG_BASE
- help
- {SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0},
Have you tested mSATA with this patch?
My testing showed that swap_rx must be set for mSATA. See this pull request:
https://github.com/SolidRun/u-boot/pull/3
To make #ifdef less annoying I would prefer something like this instead (build tested only):
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index e268ef55a2a0..5bbb7906b681 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -29,6 +29,12 @@ DECLARE_GLOBAL_DATA_PTR; #define BOARD_GPP_POL_LOW 0x0 #define BOARD_GPP_POL_MID 0x0
+#if defined (CONFIG_CLEARFOG_CON3_SATA) +#define SERDES2_CONFIG {SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 1, 0} +#else +#define SERDES2_CONFIG {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0} +#endif + static struct tlv_data cf_tlv_data;
static void cf_read_tlv_data(void) @@ -45,7 +51,7 @@ static void cf_read_tlv_data(void) static struct serdes_map board_serdes_map[] = { {SATA0, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {SGMII1, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, - {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, + SERDES2_CONFIG, {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, {SGMII2, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0},
baruch
- {SATA2, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0},
--- board/solidrun/clearfog/Kconfig | 7 +++++++ board/solidrun/clearfog/clearfog.c | 4 ++++ 2 files changed, 11 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index 4e189b13e0..44224d903d 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -32,4 +32,11 @@ config CLEARFOG_CON2_SATA modules, but the desired protocol must be configured at build time since it affects the SerDes topology layout.
+config CLEARFOG_SFP_25GB + bool "Enable 2.5 Gbps mode for SFP" + help + Set the SFP module connection to support 2.5 Gbps transfer speed for the + SGMII connection (requires a supporting SFP). By default, transfer speed + of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module. + endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 7046665d6c..5064bde378 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -58,7 +58,11 @@ static struct serdes_map board_serdes_map[] = { #else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, #endif +#if defined (CONFIG_CLEARFOG_SFP_25GB) + {SGMII2, SERDES_SPEED_3_125_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {SGMII2, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#endif };
Add reasonable default SPI offsets and ENV size when configured to boot from SPI flash.
There was some reasonable concern raised about duplicating config entries within a board specific config file rather than making board specific configurations within defconfig. This seems to offer a more board localized mechanism to provide platform defaults for core values. As mentioned in the review, this usage seems to match the Kconfig documented intended usage. As noted at https://www.kernel.org/doc/html/latest/kbuild/kconfig-language.html: "Default values are not limited to the menu entry where they are defined. This means the default can be defined somewhere else or be overridden by an earlier definition."
Given that there is some dependency variability with these values I prefer keeping them as Kconfig values, but defer to maintainers. Notably, for the ENV values in this and a later commit, I'm using a pattern already in used several other board configs.
--- board/solidrun/clearfog/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index 44224d903d..ea9c419472 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -39,4 +39,16 @@ config CLEARFOG_SFP_25GB SGMII connection (requires a supporting SFP). By default, transfer speed of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module.
+config ENV_SECT_SIZE + hex "Environment Sector-Size" + # Use SPI flash erase block size of 4 KiB + default 0x1000 if MVEBU_SPL_BOOT_DEVICE_SPI + # Use optimistic 64 KiB erase block, will vary between actual media + default 0x10000 if MVEBU_SPL_BOOT_DEVICE_MMC + +config SYS_SPI_U_BOOT_OFFS + hex "address of u-boot payload in SPI flash" + default 0x20000 + depends on MVEBU_SPL_BOOT_DEVICE_SPI + endmenu
With the move to driver model usage, ensure that the required driver support for SPI and MMC booting is available in SPL.
Tested on SolidRun ClearFog devices.
v2 changes: - change "select" for ENV_IS_IN_X to "imply" to allow disabling the default env location and configuring a different one if desired - remove SPL_DM_GPIO from defconfig, only include if needed for MMC booting v2 changes: - none
--- arch/arm/mach-mvebu/Kconfig | 10 ++++++++++ configs/clearfog_defconfig | 1 - 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 161dee937f..32191e7157 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -235,9 +235,19 @@ choice
config MVEBU_SPL_BOOT_DEVICE_SPI bool "SPI NOR flash" + imply ENV_IS_IN_SPI_FLASH + select SPL_DM_SPI + select SPL_MTD_SUPPORT + select SPL_SPI_FLASH_SUPPORT + select SPL_SPI_LOAD + select SPL_SPI_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_MMC bool "SDIO/MMC card" + imply ENV_IS_IN_MMC + # GPIO required for SD card presence detection line + select SPL_DM_GPIO + select SPL_DM_MMC select SPL_LIBDISK_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_SATA diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 53a51794f0..e2399a9739 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET=0x1 -CONFIG_SPL_DM_GPIO=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_TLV_EEPROM=y CONFIG_SPL_CMD_TLV_EEPROM=y
Migrate the values for ENV_SIZE and ENV_OFFSET into board specific Kconfig defaults so they're more accessible for configuration.
Signed-off-by: Joel Johnson mrjoel@lixil.net --- board/solidrun/clearfog/Kconfig | 8 ++++++++ configs/clearfog_defconfig | 2 -- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index ea9c419472..e8c3f53d84 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -39,6 +39,14 @@ config CLEARFOG_SFP_25GB SGMII connection (requires a supporting SFP). By default, transfer speed of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module.
+config ENV_SIZE + hex "Environment Size" + default 0x10000 + +config ENV_OFFSET + hex "Environment offset" + default 0xF0000 + config ENV_SECT_SIZE hex "Environment Sector-Size" # Use SPI flash erase block size of 4 KiB diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index e2399a9739..37091319be 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -11,8 +11,6 @@ CONFIG_TARGET_CLEARFOG=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xF0000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000
Reduce those MMC booting assumptions from clearfog_defconfig which are already selected by dependent options via Kconfig.
v2 changes: - rebased on master to use Baruch's dynamic MMC/SD offset logic - update description, will revisit removal of CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC in separate future path if a more viable option is identified v3 changes: - none
--- arch/arm/mach-mvebu/Kconfig | 1 + configs/clearfog_defconfig | 2 -- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 32191e7157..4b381a2936 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -249,6 +249,7 @@ config MVEBU_SPL_BOOT_DEVICE_MMC select SPL_DM_GPIO select SPL_DM_MMC select SPL_LIBDISK_SUPPORT + select SPL_MMC_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_SATA bool "SATA" diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 37091319be..4a0df00007 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CLEARFOG=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y -CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y @@ -41,7 +40,6 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" -CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_MVEBU=y
Baruch Siach
Joel Johnson
Stefan Roese
