[PATCH] stv0991: remove specific CONFIG_STV0991 configs
Remove the following STV0991 specific configs: - CONFIG_STV0991 (never used) - CONFIG_STV0991_HZ (replaced by generic CONFIG_SYS_HZ) - CONFIG_STV0991_HZ_CLOCK (replaced by generic CONFIG_SYS_HZ_CLOCK)
This patch allows to reduce the file config_whitelist.txt.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/cpu/armv7/stv0991/timer.c | 6 +++--- arch/arm/include/asm/arch-stv0991/stv0991_gpt.h | 4 ++-- scripts/config_whitelist.txt | 3 --- 3 files changed, 5 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/stv0991/timer.c b/arch/arm/cpu/armv7/stv0991/timer.c index 07033acb5c..67764ccf66 100644 --- a/arch/arm/cpu/armv7/stv0991/timer.c +++ b/arch/arm/cpu/armv7/stv0991/timer.c @@ -18,7 +18,7 @@ static struct stv0991_cgu_regs *const stv0991_cgu_regs = \ (struct stv0991_cgu_regs *) (CGU_BASE_ADDR);
#define READ_TIMER() (readl(&gpt1_regs_ptr->cnt) & GPT_FREE_RUNNING) -#define GPT_RESOLUTION (CONFIG_STV0991_HZ_CLOCK / CONFIG_STV0991_HZ) +#define GPT_RESOLUTION (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ)
DECLARE_GLOBAL_DATA_PTR;
@@ -67,7 +67,7 @@ void __udelay(unsigned long usec) { ulong tmo; ulong start = get_timer_masked(); - ulong tenudelcnt = CONFIG_STV0991_HZ_CLOCK / (1000 * 100); + ulong tenudelcnt = CONFIG_SYS_HZ_CLOCK / (1000 * 100); ulong rndoff;
rndoff = (usec % 10) ? 1 : 0; @@ -110,5 +110,5 @@ unsigned long long get_ticks(void) */ ulong get_tbclk(void) { - return CONFIG_STV0991_HZ; + return CONFIG_SYS_HZ; } diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h index cd27472ad7..f1d5667c32 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h @@ -36,7 +36,7 @@ struct gpt_regs *const gpt1_regs_ptr = #define GPT_FREE_RUNNING 0xFFFF
/* Timer, HZ specific defines */ -#define CONFIG_STV0991_HZ 1000 -#define CONFIG_STV0991_HZ_CLOCK (27*1000*1000)/GPT_PRESCALER_128 +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_HZ_CLOCK ((27 * 1000 * 1000) / GPT_PRESCALER_128)
#endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 61ae682dcd..58f4b02f60 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1303,9 +1303,6 @@ CONFIG_STANDALONE_LOAD_ADDR CONFIG_STATIC_BOARD_REV CONFIG_STD_DEVICES_SETTINGS CONFIG_STM32_FLASH -CONFIG_STV0991 -CONFIG_STV0991_HZ -CONFIG_STV0991_HZ_CLOCK CONFIG_SXNI855T CONFIG_SYSFS CONFIG_SYSMGR_ISWGRP_HANDOFF
ST Restricted
-----Original Message----- From: Patrick Delaunay patrick.delaunay@foss.st.com Sent: mercredi 6 octobre 2021 17:19 To: u-boot@lists.denx.de Cc: Patrick Delaunay patrick.delaunay@foss.st.com; Priyanka Jain priyanka.jain@nxp.com; Simon Glass sjg@chromium.org; Stefan Roese sr@denx.de; Vikas Manocha vikas.manocha@st.com; U-Boot STM32 uboot-stm32@st-md-mailman.stormreply.com Subject: [PATCH] stv0991: remove specific CONFIG_STV0991 configs
Even if I don't update patchset version to V2 this patch is replaced by next one http://patchwork.ozlabs.org/project/uboot/list/?series=265724&state=*
It is a push error, sorry.
I need to add a modification to avoid the remaining error
+Error: You must add new CONFIG options using Kconfig +The following new ad-hoc CONFIG options were detected: +CONFIG_STV0991
CONFIG_STV0991 was never used in code but define in autoconfig by CONFIG_SYS_EXTRA_OPTIONS="STV0991"
Patrick
Patrick Delaunay
