[U-Boot-Users] Power On Self Tests
Hello Everybody,
During the power on self tests, the bootmode of the board is stored in the processor DPRAM. This location is hardcoded in commproc.h. The following patch adds the opportunity to override this value in the board config file. The position of this value in DPRAM depends on the usage of the DPRAM made by the operating system.
For example, on an MPC860T, I've add #define CFG_CPM_POST_WORD_ADDR 0x0ffc in the board config file to have the bootmode being the last word of the DPRAM.
--- ppcboot-2.0.0/include/commproc.h 2002-10-16 13:31:18.000000000 +0200 +++ ppcboot-2.0.0-m/include/commproc.h 2002-11-21 10:42:31.000000000 +0100 @@ -77,7 +77,11 @@
#endif
+#ifndef CFG_CPM_POST_WORD_ADDR #define CPM_POST_WORD_ADDR 0x07FC +#else +#define CPM_POST_WORD_ADDR CFG_CPM_POST_WORD_ADDR +#endif
#define BD_IIC_START ((uint) 0x0400) // <- please use CPM_I2C_BASE !!
Best regards
Dear Pierre,
Thanks.
Can you please also send the correspoding CHANGELOG entry, plus the patch for README to describe the new CFG_* variable?
Wolfgang Denk wrote:
Dear Pierre,
Please find attached the patch for the README file.
--- ppcboot-2.0.0-cvs/README 2002-11-21 13:50:01.000000000 +0100 +++ ppcboot-2.0.0-m/README 2002-11-21 14:03:17.000000000 +0100 @@ -1653,6 +1653,13 @@ Low Level (hardware related) configurati wrong setting might damage your board. Read doc/README.MBX before setting this variable!
+- CFG_CPM_POST_WORD_ADDR: + (CPM8xx, CPM8260) + Offset of the bootmode word in DPRAM used by post (Power On Self Tests) + This definition overrides hardcoded #define in commproc.h or + cpm_8260.h. + + Building the Software: ======================
CHANGELOG: * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR so the offset of the bootmode word in DPRAM can be redefined in the board config file.
Best regards.
(CPM8xx, CPM8260)
Tests)
cpm_8260.h.
Aha! This points out a shortcoming of your patch: you fixed it only for MPC8xx, but not for MPC8260 (although your comment claims otherwise). OK, I added the code for 8260.
(CPM8xx, CPM8260)
Tests)
cpm_8260.h.
You're right, I've forgotten the cpm_8260.h part. Sorry
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux
Pierre AUBERT
