Re: [U-Boot] [PATCH v2 2/2] powerpc/c29xpcie: 8k page size NAND boot support base on TPL/SPL
On Fri, 2013-12-13 at 21:09 -0600, Liu Po-B43644 wrote:
-----Original Message----- From: Wood Scott-B07421 Sent: Saturday, December 14, 2013 4:26 AM To: Liu Po-B43644 Cc: u-boot@lists.denx.de; Sun York-R58495; Kushwaha Prabhakar-B32579 Subject: Re: [PATCH v2 2/2] powerpc/c29xpcie: 8k page size NAND boot support base on TPL/SPL
On Wed, 2013-12-11 at 00:16 -0600, Liu Po-B43644 wrote:
SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE,
CONFIG_SYS_NAND_BASE_PHYS,
MAS3_SW|MAS3_SR, MAS2_I|MAS2_G,
MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 5, BOOKE_PAGESZ_64K, 1),
No.
Without MAS3_SX, the board can't run in booting from NAND.
Explain why you're executing from this TLB entry. This should be for accessing the NAND as I/O after you've relocated away from the boot buffer. There should be a different mapping for the boot buffer early on. None of the other NAND boot targets have needed this. Perhaps this is related to the other TLB entry that you said you could work without.
This is because for SPL, the #define CONFIG_SPL_TEXT_BASE 0xff800000 #define CONFIG_SYS_NAND_BASE 0xff800000 Code space overlap the nand io space.
OK, I guess we move the NAND buffer before relocating out of it. And for some reason I missed that existing targets do the same thing. Never mind...
-Scott
Scott Wood
