[PATCH] Revert "configs: stm32mp1: only support SD card after NOR in bootcmd_stm32mp"
This reverts commit d5d726d3cc47691ace3c68fa31147ad104aaf579, which breaks boards which ship with multiple SD/eMMC sockets.
This stm32mp1.h config is not used only by the ST reference boards, but all the other STM32MP1 based boards in U-Boot, so changes to this stm32mp1.h cannot break the other boards.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- NOTE: I think we might need to split out the env for different boards into different headers instead. Thoughts ? --- include/configs/stm32mp1.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 973a4f1d4b8..a75ed693f57 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -120,7 +120,7 @@ * for serial/usb: execute the stm32prog command * for mmc boot (eMMC, SD card), boot only on the same device * for nand or spi-nand boot, boot with on ubifs partition on UBI partition - * for nor boot, use SD card = mmc0 + * for nor boot, use the default order */ #define STM32MP_BOOTCMD "bootcmd_stm32mp=" \ "echo "Boot over ${boot_device}${boot_instance}!";" \ @@ -133,8 +133,6 @@ "if test ${boot_device} = nand ||" \ " test ${boot_device} = spi-nand ;" \ "then env set boot_targets ubifs0; fi;" \ - "if test ${boot_device} = nor;" \ - "then env set boot_targets mmc0; fi;" \ "run distro_bootcmd;" \ "fi;\0"
- for serial/usb: execute the stm32prog command
- for mmc boot (eMMC, SD card), boot only on the same device
- for nand or spi-nand boot, boot with on ubifs partition on UBI partition
- for nor boot, use SD card = mmc0
- for nor boot, use the default order
"run distro_bootcmd;" \ "fi;\0""then env set boot_targets mmc0; fi;" \
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Sorry to break your board, but I assumed the "stm32mp1.h" was only the default ST configuration
for ST boards and other boards need to be overridden it if it is not align with their needs
as I don't know the expected boot sequence.
for example with:
CONFIG_BOOTCOMMAND="run bootcmd_dh_stm32mp"
with bootcmd_dh_stm32mp to be defined
but today this file is a mix between SOC configuration (generic) and ST boards needs.
So I will merge your revert and I will push a other solution to only support SD card
after NOR in bootcmd_stm32mp but only for STMicroelectronics boards
(because the revert now break the EV1 boot from NOR).
1) stm32mp1.h = common for SOC STMP15x (as today)
2) st_stm32mp1.h = ST boards configuration (override common)
Thanks Patrick
No worries really. No, it isn't only for the ST evalboards, and I don't know whether this is the right approach.
for example with:
Maybe the naming should be the other way around, so we have some sort of namespacing, like this:
stm32mp1_common.h ... common stuff for all boards and SoM and all ...
stm32mp1_st_evalboard.h (or whatever you want to call it) #include <configs/stm32mp1_common.h> #define custom ST env ...
stm32mp1_dh_dhsom.h #include <configs/stm32mp1_common.h> #define custom DH env ...
That's what imx does , except for the namespacing, so the file names are a mess. I think we can do better there. So anything related to stm32mp1 should have stm32mp1_* filename prefix, and then some vendor_ or board_ suffix.
ST Restricted
-----Original Message----- From: Marek Vasut marex@denx.de Sent: lundi 4 octobre 2021 18:45 To: Patrick DELAUNAY patrick.delaunay@foss.st.com; u-boot@lists.denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Subject: Re: [PATCH] Revert "configs: stm32mp1: only support SD card after NOR in bootcmd_stm32mp"
partition
for example with:
Agree it is better and more coherent.
I wasn't want to change the dh files, but I will do it:
configs/stm32mp1_common.h or stm32mp15_common.h
configs/stm32mp1_dh_dhsom.h (as you proposed) or stm32mp15_dh_dhsom.h
configs/stm32mp1_st_stm32mp15.h or stm32mp15_st_common.h or stm32mp15_st_boards.h (name to be confirmed)
with - stm32mp1_* filename prefix for STM32MP1 Series (Cortex arm v7) - stm32mp15_* filename prefix for STM32MP15x lines - stm32mp13_* filename prefix for STM32MP13x lines (coming soon => https://lwn.net/Articles/864174/)
Regards
Patrick
Hi Marek
Applied on u-boot-stm32 for next
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
