[U-Boot] [PULL] u-boot/master
The following changes since commit fbe79a17fddb7f0b11aa15b9c93e9a4a26165ed8:
m68k: define __kernel_size_t as unsinged int again (2014-07-22 09:46:50 -0400)
git://git.denx.de/u-boot-usb.git HEAD
for you to fetch changes up to 401abbf150e55e974829a7cc64584d9e463fc5ea:
usb: ehci: rmobile: Remove xHCI address (2014-07-28 12:47:31 +0200)
---------------------------------------------------------------- Nobuhiro Iwamatsu (2): usb: ehci: rmobile: Add support R8A7794 usb: ehci: rmobile: Remove xHCI address
Stephen Warren (11): fs: implement size/fatsize/ext4size dfu: fix some issues with reads/uploads dfu: add write error handling dfu: defer parsing of device string to IO backend dfu: allow backend to specify a maximum buffer size dfu: add free_entity() to struct dfu_entity dfu: add SF backend test: dfu: script enhancements test: dfu: cleanup before execution test: dfu: add some more test cases dfu: fix readback buffer overflow test
Łukasz Majewski (3): test:dfu: Add test scripts for testing DFU regression test:dfu: README file update thor: defer parsing of device string to IO backend
common/cmd_dfu.c | 3 +-- common/cmd_ext4.c | 14 +++++++++++ common/cmd_fat.c | 13 ++++++++++ common/cmd_fs.c | 13 ++++++++++ common/cmd_thordown.c | 6 ++--- drivers/dfu/Makefile | 1 + drivers/dfu/dfu.c | 105 +++++++++++++++++++++++++++++++++++++++++++++++++------------------------------ drivers/dfu/dfu_mmc.c | 80 ++++++++++++++++++++++++++++++++++++++++++++++-------------- drivers/dfu/dfu_nand.c | 9 +++++-- drivers/dfu/dfu_ram.c | 13 +++++----- drivers/dfu/dfu_sf.c | 139 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/f_dfu.c | 20 ++++++++++++--- drivers/usb/gadget/f_thor.c | 5 ++-- drivers/usb/host/ehci-rmobile.c | 7 ++++-- fs/ext4/ext4fs.c | 5 ++++ fs/fat/fat.c | 5 ++++ fs/fs.c | 43 +++++++++++++++++++++++++++++++++ fs/sandbox/sandboxfs.c | 5 ++++ include/configs/koelsch.h | 2 +- include/configs/lager.h | 2 +- include/dfu.h | 52 +++++++++++++++++++++++++++++++-------- include/ext4fs.h | 1 + include/fat.h | 1 + include/fs.h | 9 +++++++ include/sandboxfs.h | 1 + test/dfu/README | 37 ++++++++++++++++++++++++++++ test/dfu/dfu_gadget_test.sh | 94 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ test/dfu/dfu_gadget_test_init.sh | 31 ++++++++++++++++++++++++ 28 files changed, 626 insertions(+), 90 deletions(-) create mode 100644 drivers/dfu/dfu_sf.c create mode 100644 test/dfu/README create mode 100755 test/dfu/dfu_gadget_test.sh create mode 100755 test/dfu/dfu_gadget_test_init.sh
Thanks!
Best regards, Marek Vasut
