[U-Boot] [PATCH 1/2] mmc: sh_mmcif: Use DIV_ROUND_UP and fls instead of calculation loop
Use DIV_ROUND_UP and fls to simplify the code.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/mmc/sh_mmcif.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/sh_mmcif.c b/drivers/mmc/sh_mmcif.c index ed83a14..8f386e2 100644 --- a/drivers/mmc/sh_mmcif.c +++ b/drivers/mmc/sh_mmcif.c @@ -103,20 +103,18 @@ static int mmcif_wait_interrupt_flag(struct sh_mmcif_host *host)
static void sh_mmcif_clock_control(struct sh_mmcif_host *host, unsigned int clk) { - int i; - sh_mmcif_bitclr(CLK_ENABLE, &host->regs->ce_clk_ctrl); sh_mmcif_bitclr(CLK_CLEAR, &host->regs->ce_clk_ctrl);
if (!clk) return; - if (clk == CLKDEV_EMMC_DATA) { + + if (clk == CLKDEV_EMMC_DATA) sh_mmcif_bitset(CLK_PCLK, &host->regs->ce_clk_ctrl); - } else { - for (i = 1; (unsigned int)host->clk / (1 << i) >= clk; i++) - ; - sh_mmcif_bitset((i - 1) << 16, &host->regs->ce_clk_ctrl); - } + else + sh_mmcif_bitset((fls(DIV_ROUND_UP(host->clk, + clk) - 1) - 1) << 16, + &host->regs->ce_clk_ctrl); sh_mmcif_bitset(CLK_ENABLE, &host->regs->ce_clk_ctrl); }
Maximum value and the minimum value of clock for sh_mmcif instead by base of MMC clock. This removes fixed clock, make the changes to be calculated according to environment.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/mmc/sh_mmcif.c | 5 +++-- drivers/mmc/sh_mmcif.h | 3 ++- 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sh_mmcif.c b/drivers/mmc/sh_mmcif.c index 8f386e2..3a2022c 100644 --- a/drivers/mmc/sh_mmcif.c +++ b/drivers/mmc/sh_mmcif.c @@ -579,8 +579,6 @@ static struct mmc_config sh_mmcif_cfg = { .host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT | MMC_MODE_8BIT | MMC_MODE_HC, .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, - .f_min = CLKDEV_MMC_INIT, - .f_max = CLKDEV_EMMC_DATA, .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, };
@@ -597,6 +595,9 @@ int mmcif_mmc_init(void) host->regs = (struct sh_mmcif_regs *)CONFIG_SH_MMCIF_ADDR; host->clk = CONFIG_SH_MMCIF_CLK;
+ sh_mmcif_cfg.f_min = MMC_CLK_DIV_MIN(host->clk); + sh_mmcif_cfg.f_max = MMC_CLK_DIV_MAX; + mmc = mmc_create(&sh_mmcif_cfg, host); if (mmc == NULL) { free(host); diff --git a/drivers/mmc/sh_mmcif.h b/drivers/mmc/sh_mmcif.h index bd6fbf7..70034e2 100644 --- a/drivers/mmc/sh_mmcif.h +++ b/drivers/mmc/sh_mmcif.h @@ -199,7 +199,8 @@ struct sh_mmcif_regs { #define SOFT_RST_OFF (0 << 31)
#define CLKDEV_EMMC_DATA 52000000 /* 52MHz */ -#define CLKDEV_MMC_INIT 400000 /* 100 - 400 KHz */ +#define MMC_CLK_DIV_MIN(clk) (clk / (1 << 8)) +#define MMC_CLK_DIV_MAX CLKDEV_EMMC_DATA
#define MMC_BUS_WIDTH_1 0 #define MMC_BUS_WIDTH_4 2
Nobuhiro Iwamatsu
