[PATCH] rockchip: Use an external TPL binary on RK3588
There is no support to initialize DRAM on RK3588 SoCs using U-Boot TPL and instead an external TPL binary must be used to generate a bootable u-boot-rockchip.bin image.
Enable ROCKCHIP_EXTERNAL_TPL by default for RK3588, add build steps for RK3588 to documentation and clean up CONFIG_BINMAN_FDT options.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/mach-rockchip/Kconfig | 2 +- configs/neu6a-io-rk3588_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/rock5b-rk3588_defconfig | 1 - doc/board/rockchip/rockchip.rst | 9 +++++++++ 5 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 0390431601f9..e5ac58ae60b5 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -428,7 +428,7 @@ config TPL_ROCKCHIP_COMMON_BOARD
config ROCKCHIP_EXTERNAL_TPL bool "Use external TPL binary" - default y if ROCKCHIP_RK3568 + default y if ROCKCHIP_RK3568 || ROCKCHIP_RK3588 help Some Rockchip SoCs require an external TPL to initialize DRAM. Enable this option and build with ROCKCHIP_TPL=/path/to/ddr.bin to diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index fb5a2b7dbceb..33c03b58a16c 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -63,5 +63,4 @@ CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 1686c8c1aa5a..e16d98b07af9 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -70,5 +70,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index f3026c7ea166..66199387195a 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -68,5 +68,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index b5563b8f7f9e..1f88d15aad2a 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -185,6 +185,15 @@ To build rk3568 boards: make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu-
+To build rk3588 boards: + +.. code-block:: bash + + export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.27.elf + export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin + make rock5b-rk3588_defconfig + make CROSS_COMPILE=aarch64-linux-gnu- + Flashing --------
Reviewed-by: Jagan Teki jagan@edgeble.ai
Jagan Teki
Jonas Karlman
