[U-Boot] [PATCH v2] ti_armv7_common: env: Add NFS loading support to default enviroment
NFS loading is similar to net loading except initial files are loaded over NFS instead of TFTP, this removes the need for multiple different protocol servers running on the host and allows the use of a single network file system containing boot related files in their usual in-filesystem directory. Add defaults for this boot style here.
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- Changes from v1: - Remove definition of CONFIG_CMD_NFS, enabled by default
include/configs/ti_armv7_keystone2.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index a7206f4..17d5aa4 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -237,16 +237,21 @@ "run_mon=mon_install ${addr_mon}\0" \ "run_kern=bootz ${loadaddr} - ${fdtaddr}\0" \ "init_net=run args_all args_net\0" \ + "init_nfs=setenv autoload no; dhcp; run args_all args_net\0" \ "init_ubi=run args_all args_ubi; " \ "ubi part ubifs; ubifsmount ubi:boot;" \ "ubifsload ${addr_secdb_key} securedb.key.bin;\0" \ "get_fdt_net=dhcp ${fdtaddr} ${tftp_root}/${name_fdt}\0" \ + "get_fdt_nfs=nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt}\0" \ "get_fdt_ubi=ubifsload ${fdtaddr} ${name_fdt}\0" \ "get_kern_net=dhcp ${loadaddr} ${tftp_root}/${name_kern}\0" \ + "get_kern_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_kern}\0" \ "get_kern_ubi=ubifsload ${loadaddr} ${name_kern}\0" \ "get_mon_net=dhcp ${addr_mon} ${tftp_root}/${name_mon}\0" \ + "get_mon_nfs=nfs ${addr_mon} ${nfs_root}/boot/${name_mon}\0" \ "get_mon_ubi=ubifsload ${addr_mon} ${name_mon}\0" \ "get_uboot_net=dhcp ${loadaddr} ${tftp_root}/${name_uboot}\0" \ + "get_uboot_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_uboot}\0" \ "burn_uboot_spi=sf probe; sf erase 0 0x80000; " \ "sf write ${loadaddr} 0 ${filesize}\0" \ "burn_uboot_nand=nand erase 0 0x100000; " \ @@ -261,6 +266,7 @@ "get_mon_ramfs=dhcp ${addr_mon} ${tftp_root}/${name_mon}\0" \ "get_fs_ramfs=dhcp ${rdaddr} ${tftp_root}/${name_fs}\0" \ "get_ubi_net=dhcp ${addr_ubi} ${tftp_root}/${name_ubi}\0" \ + "get_ubi_nfs=nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi}\0" \ "burn_ubi=nand erase.part ubifs; " \ "nand write ${addr_ubi} ubifs ${filesize}\0" \ "init_ramfs=run args_all args_ramfs get_fs_ramfs\0" \
I guess this patch is dependent on [1]. Please send it as a series and [1] should be applied before this.
Changes from v1:
- "init_nfs=setenv autoload no; dhcp; run args_all args_net\0" \ "init_ubi=run args_all args_ubi; " \ "ubi part ubifs; ubifsmount ubi:boot;" \ "ubifsload ${addr_secdb_key} securedb.key.bin;\0" \ "get_fdt_net=dhcp ${fdtaddr} ${tftp_root}/${name_fdt}\0" \
- "get_fdt_nfs=nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt}\0" \
Can you also add a default nfs_root variable?
[1] http://patchwork.ozlabs.org/patch/596509/
Thanks and regards, Lokesh
No dependency, this is for k2x, [1] is for dra7x.
Changes from v1:
Already defined, used by net boot previously.
Thanks, Andrew
Oops...my bad. Sorry for the noise.
Changes from v1:
Thanks, Andrew
Andrew F. Davis
Lokesh Vutla
