[U-Boot] Possible OMAP3 regression with current mainline
I just tried boot with my OMAP3 based board (IGEPv2) and I found that is broken in current mainline and v2015.01. The boot process stops at
reading u-boot.img
Did someone, with another OMAP3 board, have the same problem?
I bisected the problem and looks that was introduced in following commit.
commit b3f4ca1135edd66d14254089bbeb8077c6d0bb72 dm: omap3: Move to driver model for GPIO and serial
Reverting the patch boots again. Any clue?
Thanks in advance Enric
Hi Enric,
reading u-boot.img
It looks like someone else had this problem:
http://patchwork.ozlabs.org/patch/433866/
Hi Simon,
2015-01-30 2:24 GMT+01:00 Simon Glass sjg@chromium.org:
Hi Enric,
reading u-boot.img
This patch is made by me, I sent this patch :)
But the patch only replaces the use of show_boot_progress for the STATUS_LED API, Which is better for that purpose. But the root problem is not solved.
Looks like the problem is the gpio_request call inside the function show_boot_progress. If I'm not wrong the gpio_request implementation is different when device model is used, and for some reason doing a gpio_request inside the show_boot_progress function hangs. If I remove the gpio_request from show_boot_progress it boots as expected. What's the difference between gpio_request implementation when using DM or not? Maybe it's a malloc problem?
Regards, Enric
Hi Enric,
On 30 January 2015 at 01:10, Enric Balletbo Serra eballetbo@gmail.com wrote:
Hi Simon,
Hi Enric,
reading u-boot.img
Well gpio_request() is probably a no-op in the non-driver-model case.
We should call gpio_request() once, in the board init, ideally before any calls to show_boot_progress(), since otherwise GPIO operations will fail.
