[U-Boot-Users] [PATCH 4/5]: add AcTux-3 board support
Signed-off-by: Michael Schwingen michael@schwingen.org
diff --git a/include/configs/actux3.h b/include/configs/actux3.h new file mode 100644 index 0000000..9492f95 --- /dev/null +++ b/include/configs/actux3.h @@ -0,0 +1,216 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-3 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_IXP425 1 /* This is an IXP425 CPU */ +#define CONFIG_ACTUX3 1 /* on an AcTux-3 Board */ + +#define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info (and speed) */ +#define CONFIG_DISPLAY_BOARDINFO 1 /* display board info */ + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + + + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF + +#define CONFIG_BOOTCOMMAND "run boot_flash" +//#define CONFIG_BOOTARGS "root=/dev/mtdblock2 rootfstype=cramfs console=ttyS0,115200" +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + + + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */ + +#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CFG_LOAD_ADDR 0x00010000 /* default load address */ + +#define CFG_HZ 3333333 /* spec says 66.666 MHz, but it appears to be 33 */ + /* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * Expansion bus settings + */ +#define CFG_EXP_CS0 0xbd113442 + +/* + * SDRAM settings + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ +#define CFG_DRAM_BASE 0x00000000 + + +// 16MB SDRAM +# define CFG_SDR_CONFIG 0x3A +# define PHYS_SDRAM_1_SIZE 0x01000000 /* 16 MB */ +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x01000000 + + +/* + * FLASH organization + */ +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 140 /* max number of sectors on one chip */ +#define PHYS_FLASH_1 0x50000000 /* Flash Bank #1 */ +#define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ + +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT /* no byte writes on IXP4xx */ +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ + +/* + * environment organization + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 /* size of one complete sector */ +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000; loady ${loadaddr}; run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000; tftp ${loadaddr} u-boot.bin; run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff; protect off 50006000 5003ffff; erase 50000000 50003fff; erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000; cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff; erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};era ${rootaddr} +${filesize}; cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};era ${kerneladdr} +${filesize}; cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3 rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3 rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth; bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth; tftpboot ${loadaddr} ${kernelfile}; bootm\0" \ + + +/* + * Ethernet + */ +#define CONFIG_IXP4XX_NPE 1 /* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 /* use separate flash sector with ucode images */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_PHY_ADDR 0x10 /* NPE0 PHY address */ +#define CONFIG_MII 1 /* MII PHY management */ +#define CFG_RX_ETH_BUFFER 16 /* Number of ethernet rx buffers & descriptors */ +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MII_ETHSWITCH 1 /* ethernet switch connected to MII port */ + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS /* NFS support */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Cache Configuration + */ +#define CFG_CACHELINE_SIZE 32 + +#endif /* __CONFIG_H */ diff --git a/board/actux3/actux3.c b/board/actux3/actux3.c new file mode 100644 index 0000000..bc3a128 --- /dev/null +++ b/board/actux3/actux3.c @@ -0,0 +1,165 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> + +#include <miiphy.h> + +#include "actux3_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_ENABLE(CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE(CFG_GPIO_ETHRST); + GPIO_OUTPUT_ENABLE(CFG_GPIO_DSR); + GPIO_OUTPUT_ENABLE(CFG_GPIO_DCD); + GPIO_OUTPUT_ENABLE(CFG_GPIO_LED5_GN); + GPIO_OUTPUT_ENABLE(CFG_GPIO_LED6_RT); + GPIO_OUTPUT_ENABLE(CFG_GPIO_LED6_GN); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_CLEAR (CFG_GPIO_ETHRST); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_DSR); + GPIO_OUTPUT_SET (CFG_GPIO_DCD); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED5_GN); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_RT); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_GN); + + /* + * Setup GPIO's for Interrupt inputs + */ + GPIO_OUTPUT_DISABLE(CFG_GPIO_DBGINT); + GPIO_OUTPUT_DISABLE(CFG_GPIO_ETHINT); + + /* + * Setup GPIO's for 33MHz clock output + */ + GPIO_OUTPUT_ENABLE(CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE(CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + *IXP425_EXP_CS1 = 0x94d10013; // CS1: IPAC-X + *IXP425_EXP_CS5 = 0x9d520003; // CS5: Debug port + *IXP425_EXP_CS6 = 0x81860001; // CS6: HwRel + *IXP425_EXP_CS7 = 0x80900003; // CS7: LED + + udelay (533); + GPIO_OUTPUT_SET(CFG_GPIO_IORST); + GPIO_OUTPUT_SET(CFG_GPIO_ETHRST); + + ACTUX3_LED1_RT(1); + ACTUX3_LED1_GN(0); + ACTUX3_LED2_RT(0); + ACTUX3_LED2_GN(0); + ACTUX3_LED3_RT(0); + ACTUX3_LED3_GN(0); + ACTUX3_LED4_GN(0); + ACTUX3_LED5_RT(0); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard(void) +{ + char revision; + char *s = getenv("serial#"); + + puts("Board: AcTux-3 rev."); + putc(ACTUX3_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + putc('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev(void) +{ + return ACTUX3_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +void reset_phy(void) +{ + int i; + + /* initialize the PHY */ + miiphy_reset("NPE0", CONFIG_PHY_ADDR); + + /* all LED outputs = Link/Act */ + miiphy_write("NPE0", CONFIG_PHY_ADDR, 0x16, 0x0AAA); + + /* set all ethernet switch ports to forwarding state */ + for (i=1; i <=5; i++) + miiphy_write("NPE0", CONFIG_PHY_ADDR+8+i, 0x04, 0x03); + +} diff --git a/board/actux3/actux3_hw.h b/board/actux3/actux3_hw.h new file mode 100644 index 0000000..00e0bad --- /dev/null +++ b/board/actux3/actux3_hw.h @@ -0,0 +1,67 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX3_HW_H +#define _ACTUX3_HW_H + +// 0 = LED off,1 = ON +#define ACTUX3_LED1_RT(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 0)) = (a) +#define ACTUX3_LED1_GN(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 1)) = (a) +#define ACTUX3_LED2_RT(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 2)) = (a) +#define ACTUX3_LED2_GN(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 3)) = (a) +#define ACTUX3_LED3_RT(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 4)) = (a) +#define ACTUX3_LED3_GN(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 5)) = (a) +#define ACTUX3_LED4_GN(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 6)) = ((a)^1) +#define ACTUX3_LED5_RT(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 7)) = (a) + +#define ACTUX3_DBG_PORT ((volatile u8 *)(IXP425_EXP_BUS_CS5_BASE_PHYS)) +#define ACTUX3_BOARDREL ((*(volatile u8 *)IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) +#define ACTUX3_OPTION ((*(volatile u8 *)IXP425_EXP_BUS_CS6_BASE_PHYS) & 0xF0) + + +/* + * GPIO settings + */ +#define CFG_GPIO_DBGINT 0 +#define CFG_GPIO_ETHINT 1 +#define CFG_GPIO_ETHRST 2 // Out +#define CFG_GPIO_LED5_GN 3 // Out +#define CFG_GPIO_LED6_RT 4 // Out +#define CFG_GPIO_LED6_GN 5 // Out +#define CFG_GPIO_DSR 6 // Out +#define CFG_GPIO_DCD 7 // Out +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 // Out +#define CFG_GPIO_PCI_CLK 14 // Out +#define CFG_GPIO_EXTBUS_CLK 15 // Out + + + + +#endif + diff --git a/board/actux3/config.mk b/board/actux3/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux3/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux3/u-boot.lds b/board/actux3/u-boot.lds new file mode 100644 index 0000000..25eb7bf --- /dev/null +++ b/board/actux3/u-boot.lds @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/ixp/start.o (.text) + /* WARNING - the following is hand-optimized to fit within + the sector before the environment sector. If it throws an + error during compilation remove an object here to get it + linked after the configuration sector. */ + lib_generic/string.o (.text) + lib_generic/vsprintf.o (.text) + lib_arm/board.o (.text) + common/dlmalloc.o (.text) + drivers/mtd/cfi_flash.o (.text) + cpu/ixp/cpu.o (.text) + + . = env_offset; + common/environment.o (.ppcenv) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +}
There are coding style issyes: C++ comments, indentation not by TAB, much too long lines, etc.
Indentation in general looks pretty sloppy, especially in the board config files.
Please clean up and resubmit.
This patch adds the AcTux-3 specific files.
diff --git a/board/actux3/Makefile b/board/actux3/Makefile new file mode 100644 index 0000000..f7a6091 --- /dev/null +++ b/board/actux3/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := actux3.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/actux3/actux3.c b/board/actux3/actux3.c new file mode 100644 index 0000000..b00320b --- /dev/null +++ b/board/actux3/actux3.c @@ -0,0 +1,170 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> +#include <asm/io.h> + +#include <miiphy.h> + +#include "actux3_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_ENABLE (CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_ETHRST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_DSR); + GPIO_OUTPUT_ENABLE (CFG_GPIO_DCD); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED5_GN); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED6_RT); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED6_GN); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_CLEAR (CFG_GPIO_ETHRST); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_DSR); + GPIO_OUTPUT_SET (CFG_GPIO_DCD); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED5_GN); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_RT); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_GN); + + /* + * Setup GPIO's for Interrupt inputs + */ + GPIO_OUTPUT_DISABLE (CFG_GPIO_DBGINT); + GPIO_OUTPUT_DISABLE (CFG_GPIO_ETHINT); + + /* + * Setup GPIO's for 33MHz clock output + */ + GPIO_OUTPUT_ENABLE (CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE (CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + /* CS1: IPAC-X */ + *IXP425_EXP_CS1 = 0x94d10013; + /* CS5: Debug port */ + *IXP425_EXP_CS5 = 0x9d520003; + /* CS6: Release/Option register */ + *IXP425_EXP_CS6 = 0x81860001; + /* CS7: LEDs */ + *IXP425_EXP_CS7 = 0x80900003; + + udelay (533); + GPIO_OUTPUT_SET (CFG_GPIO_IORST); + GPIO_OUTPUT_SET (CFG_GPIO_ETHRST); + + ACTUX3_LED1_RT (1); + ACTUX3_LED1_GN (0); + ACTUX3_LED2_RT (0); + ACTUX3_LED2_GN (0); + ACTUX3_LED3_RT (0); + ACTUX3_LED3_GN (0); + ACTUX3_LED4_GN (0); + ACTUX3_LED5_RT (0); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard (void) +{ + char revision; + char *s = getenv ("serial#"); + + puts ("Board: AcTux-3 rev."); + putc (ACTUX3_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts (", serial# "); + puts (s); + } + putc ('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev (void) +{ + return ACTUX3_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +void reset_phy (void) +{ + int i; + + /* initialize the PHY */ + miiphy_reset ("NPE0", CONFIG_PHY_ADDR); + + /* all LED outputs = Link/Act */ + miiphy_write ("NPE0", CONFIG_PHY_ADDR, 0x16, 0x0AAA); + + /* set all ethernet switch ports to forwarding state */ + for (i = 1; i <= 5; i++) + miiphy_write ("NPE0", CONFIG_PHY_ADDR + 8 + i, 0x04, 0x03); + +} diff --git a/board/actux3/actux3_hw.h b/board/actux3/actux3_hw.h new file mode 100644 index 0000000..b427024 --- /dev/null +++ b/board/actux3/actux3_hw.h @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX3_HW_H +#define _ACTUX3_HW_H + +/* 0 = LED off,1 = ON */ +#define ACTUX3_LED1_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 0) +#define ACTUX3_LED1_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 1) +#define ACTUX3_LED2_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 2) +#define ACTUX3_LED2_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 3) +#define ACTUX3_LED3_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 4) +#define ACTUX3_LED3_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 5) +#define ACTUX3_LED4_GN(a) writeb((a)^1, IXP425_EXP_BUS_CS7_BASE_PHYS + 6) +#define ACTUX3_LED5_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 7) + +#define ACTUX3_DBG_PORT IXP425_EXP_BUS_CS5_BASE_PHYS +#define ACTUX3_BOARDREL (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) +#define ACTUX3_OPTION (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0xF0) + +/* GPIO settings */ +#define CFG_GPIO_DBGINT 0 +#define CFG_GPIO_ETHINT 1 +#define CFG_GPIO_ETHRST 2 /* Out */ +#define CFG_GPIO_LED5_GN 3 /* Out */ +#define CFG_GPIO_LED6_RT 4 /* Out */ +#define CFG_GPIO_LED6_GN 5 /* Out */ +#define CFG_GPIO_DSR 6 /* Out */ +#define CFG_GPIO_DCD 7 /* Out */ +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 /* Out */ +#define CFG_GPIO_PCI_CLK 14 /* Out */ +#define CFG_GPIO_EXTBUS_CLK 15 /* Out */ + +#endif diff --git a/board/actux3/config.mk b/board/actux3/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux3/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux3/u-boot.lds b/board/actux3/u-boot.lds new file mode 100644 index 0000000..e3fe00b --- /dev/null +++ b/board/actux3/u-boot.lds @@ -0,0 +1,69 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/ixp/start.o (.text) + /* WARNING - the following is hand-optimized to fit within + the sector before the environment sector. If it throws an + error during compilation remove an object here to get it + linked after the configuration sector. */ + lib_generic/string.o (.text) + lib_generic/vsprintf.o (.text) + lib_arm/board.o (.text) + common/dlmalloc.o (.text) + cpu/ixp/cpu.o (.text) + + . = env_offset; + common/environment.o (.ppcenv) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +} diff --git a/include/configs/actux3.h b/include/configs/actux3.h new file mode 100644 index 0000000..a3ddfd1 --- /dev/null +++ b/include/configs/actux3.h @@ -0,0 +1,224 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-3 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_IXP425 1 +#define CONFIG_ACTUX3 1 + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ + +/* Size of malloc() pool */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +/* size in bytes reserved for initial data */ +#define CFG_GBL_DATA_SIZE 128 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command line configuration. */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF + +#define CONFIG_BOOTCOMMAND "run boot_flash" +/* enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_KGDB_BAUDRATE 230400 +/* which serial port to use */ +# define CONFIG_KGDB_SER_INDEX 1 +#endif + +/* Miscellaneous configurable options */ +#define CFG_LONGHELP +#define CFG_PROMPT "=> " +/* Console I/O Buffer Size */ +#define CFG_CBSIZE 256 +/* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) +/* max number of command args */ +#define CFG_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CFG_BARGSIZE CFG_CBSIZE + +#define CFG_MEMTEST_START 0x00400000 +#define CFG_MEMTEST_END 0x00800000 + +/* everything, incl board info, in Hz */ +#undef CFG_CLKS_IN_HZ +/* spec says 66.666 MHz, but it appears to be 33 */ +#define CFG_HZ 3333333 + +/* default load address */ +#define CFG_LOAD_ADDR 0x00010000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +# define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +# define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* Expansion bus settings */ +#define CFG_EXP_CS0 0xbd113442 + +/* SDRAM settings */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 +#define CFG_DRAM_BASE 0x00000000 + +/* 16MB SDRAM */ +#define CFG_SDR_CONFIG 0x3A +#define PHYS_SDRAM_1_SIZE 0x01000000 +#define CFG_SDRAM_REFRESH_CNT 0x81a +#define CFG_SDR_MODE_CONFIG 0x1 +#define CFG_DRAM_SIZE 0x01000000 + +/* FLASH organization */ +#define CFG_MAX_FLASH_BANKS 1 +/* max number of sectors on one chip */ +#define CFG_MAX_FLASH_SECT 140 +#define PHYS_FLASH_1 0x50000000 +#define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) + +/* Use common CFI driver */ +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_DRIVER +/* no byte writes on IXP4xx */ +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +/* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_EMPTY_INFO + +/* Ethernet */ + +/* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE 1 +/* use separate flash sector with ucode images */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 + +#define CONFIG_NET_MULTI 1 +/* NPE0 PHY address */ +#define CONFIG_PHY_ADDR 0x10 +/* MII PHY management */ +#define CONFIG_MII 1 +/* Number of ethernet rx buffers & descriptors */ +#define CFG_RX_ETH_BUFFER 16 +#define CONFIG_RESET_PHY_R 1 +/* ethernet switch connected to MII port */ +#define CONFIG_MII_ETHSWITCH 1 + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Cache Configuration */ +#define CFG_CACHELINE_SIZE 32 + +/* + environment organization: + one flash sector, embedded in uboot area (bottom bootblock flash) +*/ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000;" \ + " loady ${loadaddr};" \ + " run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000;" \ + " tftp ${loadaddr} u-boot.bin;" \ + " run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff;" \ + " protect off 50006000 5003ffff;" \ + " erase 50000000 50003fff;" \ + " erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000;" \ + " cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff;" \ + " erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};" \ + " era ${rootaddr} +${filesize};" \ + " cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};" \ + " era ${kerneladdr} +${filesize};" \ + " cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth;" \ + " bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth;" \ + " tftpboot ${loadaddr} ${kernelfile};" \ + " bootm\0" + +#endif /* __CONFIG_H */
diff --git a/board/actux3/Makefile b/board/actux3/Makefile new file mode 100644 index 0000000..f7a6091 --- /dev/null +++ b/board/actux3/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := actux3.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/actux3/actux3.c b/board/actux3/actux3.c new file mode 100644 index 0000000..54167a5 --- /dev/null +++ b/board/actux3/actux3.c @@ -0,0 +1,170 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> +#include <asm/io.h> + +#include <miiphy.h> + +#include "actux3_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_ENABLE (CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_ETHRST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_DSR); + GPIO_OUTPUT_ENABLE (CFG_GPIO_DCD); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED5_GN); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED6_RT); + GPIO_OUTPUT_ENABLE (CFG_GPIO_LED6_GN); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_CLEAR (CFG_GPIO_ETHRST); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_DSR); + GPIO_OUTPUT_SET (CFG_GPIO_DCD); + + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED5_GN); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_RT); + GPIO_OUTPUT_CLEAR (CFG_GPIO_LED6_GN); + + /* + * Setup GPIO's for Interrupt inputs + */ + GPIO_OUTPUT_DISABLE (CFG_GPIO_DBGINT); + GPIO_OUTPUT_DISABLE (CFG_GPIO_ETHINT); + + /* + * Setup GPIO's for 33MHz clock output + */ + GPIO_OUTPUT_ENABLE (CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE (CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + /* CS1: IPAC-X */ + *IXP425_EXP_CS1 = 0x94d10013; + /* CS5: Debug port */ + *IXP425_EXP_CS5 = 0x9d520003; + /* CS6: Release/Option register */ + *IXP425_EXP_CS6 = 0x81860001; + /* CS7: LEDs */ + *IXP425_EXP_CS7 = 0x80900003; + + udelay (533); + GPIO_OUTPUT_SET (CFG_GPIO_IORST); + GPIO_OUTPUT_SET (CFG_GPIO_ETHRST); + + ACTUX3_LED1_RT (1); + ACTUX3_LED1_GN (0); + ACTUX3_LED2_RT (0); + ACTUX3_LED2_GN (0); + ACTUX3_LED3_RT (0); + ACTUX3_LED3_GN (0); + ACTUX3_LED4_GN (0); + ACTUX3_LED5_RT (0); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard (void) +{ + char revision; + char *s = getenv ("serial#"); + + puts ("Board: AcTux-3 rev."); + putc (ACTUX3_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts (", serial# "); + puts (s); + } + putc ('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev (void) +{ + return ACTUX3_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +void reset_phy (void) +{ + int i; + + /* initialize the PHY */ + miiphy_reset ("NPE0", CONFIG_PHY_ADDR); + + /* all LED outputs = Link/Act */ + miiphy_write ("NPE0", CONFIG_PHY_ADDR, 0x16, 0x0AAA); + + /* set all ethernet switch ports to forwarding state */ + for (i = 1; i <= 5; i++) + miiphy_write ("NPE0", CONFIG_PHY_ADDR + 8 + i, 0x04, 0x03); + +} diff --git a/board/actux3/actux3_hw.h b/board/actux3/actux3_hw.h new file mode 100644 index 0000000..b427024 --- /dev/null +++ b/board/actux3/actux3_hw.h @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX3_HW_H +#define _ACTUX3_HW_H + +/* 0 = LED off,1 = ON */ +#define ACTUX3_LED1_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 0) +#define ACTUX3_LED1_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 1) +#define ACTUX3_LED2_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 2) +#define ACTUX3_LED2_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 3) +#define ACTUX3_LED3_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 4) +#define ACTUX3_LED3_GN(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 5) +#define ACTUX3_LED4_GN(a) writeb((a)^1, IXP425_EXP_BUS_CS7_BASE_PHYS + 6) +#define ACTUX3_LED5_RT(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 7) + +#define ACTUX3_DBG_PORT IXP425_EXP_BUS_CS5_BASE_PHYS +#define ACTUX3_BOARDREL (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) +#define ACTUX3_OPTION (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0xF0) + +/* GPIO settings */ +#define CFG_GPIO_DBGINT 0 +#define CFG_GPIO_ETHINT 1 +#define CFG_GPIO_ETHRST 2 /* Out */ +#define CFG_GPIO_LED5_GN 3 /* Out */ +#define CFG_GPIO_LED6_RT 4 /* Out */ +#define CFG_GPIO_LED6_GN 5 /* Out */ +#define CFG_GPIO_DSR 6 /* Out */ +#define CFG_GPIO_DCD 7 /* Out */ +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 /* Out */ +#define CFG_GPIO_PCI_CLK 14 /* Out */ +#define CFG_GPIO_EXTBUS_CLK 15 /* Out */ + +#endif diff --git a/board/actux3/config.mk b/board/actux3/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux3/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux3/u-boot.lds b/board/actux3/u-boot.lds new file mode 100644 index 0000000..8024dad --- /dev/null +++ b/board/actux3/u-boot.lds @@ -0,0 +1,74 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT ("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH (arm) +ENTRY (_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN (4); + .text : { + cpu/ixp/start.o (.text) + lib_generic/string.o (.text) + lib_generic/vsprintf.o (.text) + lib_arm/board.o (.text) + common/dlmalloc.o (.text) + cpu/ixp/cpu.o (.text) + + . = env_offset; + common/environment.o (.ppcenv) + + * (.text) + } + + . = ALIGN (4); + .rodata : { + *(.rodata) + } + + . = ALIGN (4); + .data : { + *(.data) + } + + . = ALIGN (4); + .got : { + *(.got) + } + + . =.; + __u_boot_cmd_start =.; + .u_boot_cmd : { + *(.u_boot_cmd) + } + __u_boot_cmd_end =.; + + . = ALIGN (4); + __bss_start =.; + .bss (NOLOAD): { + *(.bss) + } + _end =.; +} diff --git a/include/configs/actux3.h b/include/configs/actux3.h new file mode 100644 index 0000000..8f86ecf --- /dev/null +++ b/include/configs/actux3.h @@ -0,0 +1,224 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-3 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_IXP425 1 +#define CONFIG_ACTUX3 1 + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ + +/* Size of malloc() pool */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +/* size in bytes reserved for initial data */ +#define CFG_GBL_DATA_SIZE 128 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command line configuration. */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF + +#define CONFIG_BOOTCOMMAND "run boot_flash" +/* enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_KGDB_BAUDRATE 230400 +/* which serial port to use */ +# define CONFIG_KGDB_SER_INDEX 1 +#endif + +/* Miscellaneous configurable options */ +#define CFG_LONGHELP +#define CFG_PROMPT "=> " +/* Console I/O Buffer Size */ +#define CFG_CBSIZE 256 +/* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) +/* max number of command args */ +#define CFG_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CFG_BARGSIZE CFG_CBSIZE + +#define CFG_MEMTEST_START 0x00400000 +#define CFG_MEMTEST_END 0x00800000 + +/* everything, incl board info, in Hz */ +#undef CFG_CLKS_IN_HZ +/* spec says 66.666 MHz, but it appears to be 33 */ +#define CFG_HZ 3333333 + +/* default load address */ +#define CFG_LOAD_ADDR 0x00010000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +# define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +# define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* Expansion bus settings */ +#define CFG_EXP_CS0 0xbd113442 + +/* SDRAM settings */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 +#define CFG_DRAM_BASE 0x00000000 + +/* 16MB SDRAM */ +#define CFG_SDR_CONFIG 0x3A +#define PHYS_SDRAM_1_SIZE 0x01000000 +#define CFG_SDRAM_REFRESH_CNT 0x81a +#define CFG_SDR_MODE_CONFIG 0x1 +#define CFG_DRAM_SIZE 0x01000000 + +/* FLASH organization */ +#define CFG_MAX_FLASH_BANKS 1 +/* max number of sectors on one chip */ +#define CFG_MAX_FLASH_SECT 140 +#define PHYS_FLASH_1 0x50000000 +#define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) + +/* Use common CFI driver */ +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_DRIVER +/* no byte writes on IXP4xx */ +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +/* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_EMPTY_INFO + +/* Ethernet */ + +/* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE 1 +/* use separate flash sector with ucode images */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 + +#define CONFIG_NET_MULTI 1 +/* NPE0 PHY address */ +#define CONFIG_PHY_ADDR 0x10 +/* MII PHY management */ +#define CONFIG_MII 1 +/* Number of ethernet rx buffers & descriptors */ +#define CFG_RX_ETH_BUFFER 16 +#define CONFIG_RESET_PHY_R 1 +/* ethernet switch connected to MII port */ +#define CONFIG_MII_ETHSWITCH 1 + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Cache Configuration */ +#define CFG_CACHELINE_SIZE 32 + +/* + * environment organization: + * one flash sector, embedded in uboot area (bottom bootblock flash) + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000;" \ + " loady ${loadaddr};" \ + " run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000;" \ + " tftp ${loadaddr} u-boot.bin;" \ + " run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff;" \ + " protect off 50006000 5003ffff;" \ + " erase 50000000 50003fff;" \ + " erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000;" \ + " cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff;" \ + " erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};" \ + " era ${rootaddr} +${filesize};" \ + " cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};" \ + " era ${kerneladdr} +${filesize};" \ + " cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth;" \ + " bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth;" \ + " tftpboot ${loadaddr} ${kernelfile};" \ + " bootm\0" + +#endif /* __CONFIG_H */
Michael Schwingen
