[U-Boot] [PATCH v2] mx6: clock: Fix the calculation of PLL_ENET frequency
According to the mx6 quad reference manual, the DIV_SELECT field of register CCM_ANALOG_PLL_ENETn has the following meaning:
"Controls the frequency of the ethernet reference clock. - 00 - 25MHz - 01 - 50MHz - 10 - 100MHz - 11 - 125MHz"
Current logic does not handle the 25MHz case correctly, so fix it.
Signed-off-by: Rabeeh Khoury rabeeh@solid-run.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Use a single expression that correctly computes the frequency for all the DIV_SELECT combination (Troy Kisky)
arch/arm/cpu/armv7/mx6/clock.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 873d9d0..20c7e70 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -94,7 +94,7 @@ static u32 decode_pll(enum pll_clocks pll, u32 infreq) div = __raw_readl(&imx_ccm->analog_pll_enet); div &= BM_ANADIG_PLL_ENET_DIV_SELECT;
- return (div == 3 ? 125000000 : 25000000 * (div << 1)); + return 25000000 * (div + (div >> 1) + 1); default: return 0; }
- 00 - 25MHz
- 01 - 50MHz
- 10 - 100MHz
- 11 - 125MHz"
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
