[U-Boot] [RFC PATCH v2 03/12] arm, da850: Move the definitions of pinmux configurations to the arch tree
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... This patch moves common configurations to a header file in the arch tree for the da850evm and the hawkboard.
Signed-off-by: Christian Riesch christian.riesch@omicron.at Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Heiko Schocher hs@denx.de Cc: Sudhakar Rajashekhara sudhakar.raj@ti.com Cc: Syed Mohammed Khasim sm.khasim@gmail.com Cc: Sughosh Ganu urwithsughosh@gmail.com --- arch/arm/include/asm/arch-davinci/da850_pinmux.h | 152 ++++++++++++++++++++++ board/davinci/da8xxevm/da850evm.c | 135 ++------------------ board/davinci/da8xxevm/hawkboard_nand_spl.c | 43 +------ 3 files changed, 165 insertions(+), 165 deletions(-) create mode 100644 arch/arm/include/asm/arch-davinci/da850_pinmux.h
diff --git a/arch/arm/include/asm/arch-davinci/da850_pinmux.h b/arch/arm/include/asm/arch-davinci/da850_pinmux.h new file mode 100644 index 0000000..53df3f7 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/da850_pinmux.h @@ -0,0 +1,152 @@ +/* + * Pinmux configurations for the DA850 SoCs + * + * Copyright (C) 2011 OMICRON electronics GmbH + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __ASM_ARCH_DA850_PINMUX_H +#define __ASM_ARCH_DA850_PINMUX_H + +#include <asm/arch/hardware.h> +#include <asm/arch/davinci_misc.h> + +/* SPI pin muxer settings */ +const struct pinmux_config spi1_pins[] = { + { pinmux(5), 1, 1 }, + { pinmux(5), 1, 2 }, + { pinmux(5), 1, 4 }, + { pinmux(5), 1, 5 } +}; + +/* UART pin muxer settings */ +const struct pinmux_config uart2_pins[] = { + { pinmux(0), 4, 6 }, + { pinmux(0), 4, 7 }, + { pinmux(4), 2, 4 }, + { pinmux(4), 2, 5 } +}; + +/* EMAC pin muxer settings*/ +const struct pinmux_config emac_pins[] = { +#ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII + { pinmux(14), 8, 2 }, + { pinmux(14), 8, 3 }, + { pinmux(14), 8, 4 }, + { pinmux(14), 8, 5 }, + { pinmux(14), 8, 6 }, + { pinmux(14), 8, 7 }, + { pinmux(15), 8, 1 }, +#else /* ! CONFIG_DRIVER_TI_EMAC_USE_RMII */ + { pinmux(2), 8, 1 }, + { pinmux(2), 8, 2 }, + { pinmux(2), 8, 3 }, + { pinmux(2), 8, 4 }, + { pinmux(2), 8, 5 }, + { pinmux(2), 8, 6 }, + { pinmux(2), 8, 7 }, + { pinmux(3), 8, 0 }, + { pinmux(3), 8, 1 }, + { pinmux(3), 8, 2 }, + { pinmux(3), 8, 3 }, + { pinmux(3), 8, 4 }, + { pinmux(3), 8, 5 }, + { pinmux(3), 8, 6 }, + { pinmux(3), 8, 7 }, +#endif /* CONFIG_DRIVER_TI_EMAC_USE_RMII */ + { pinmux(4), 8, 0 }, + { pinmux(4), 8, 1 } +}; + +/* I2C pin muxer settings */ +const struct pinmux_config i2c0_pins[] = { + { pinmux(4), 2, 2 }, + { pinmux(4), 2, 3 } +}; + +const struct pinmux_config i2c1_pins[] = { + { pinmux(4), 4, 4 }, + { pinmux(4), 4, 5 } +}; + +/* NAND pin muxer settings */ +const struct pinmux_config nand_pins[] = { + { pinmux(7), 1, 1 }, + { pinmux(7), 1, 2 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(9), 1, 0 }, + { pinmux(9), 1, 1 }, + { pinmux(9), 1, 2 }, + { pinmux(9), 1, 3 }, + { pinmux(9), 1, 4 }, + { pinmux(9), 1, 5 }, + { pinmux(9), 1, 6 }, + { pinmux(9), 1, 7 }, + { pinmux(12), 1, 5 }, + { pinmux(12), 1, 6 } +}; + +/* NOR pin muxer settings */ +const struct pinmux_config nor_pins[] = { + { pinmux(5), 1, 6 }, + { pinmux(6), 1, 6 }, + { pinmux(7), 1, 0 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(8), 1, 0 }, + { pinmux(8), 1, 1 }, + { pinmux(8), 1, 2 }, + { pinmux(8), 1, 3 }, + { pinmux(8), 1, 4 }, + { pinmux(8), 1, 5 }, + { pinmux(8), 1, 6 }, + { pinmux(8), 1, 7 }, + { pinmux(9), 1, 0 }, + { pinmux(9), 1, 1 }, + { pinmux(9), 1, 2 }, + { pinmux(9), 1, 3 }, + { pinmux(9), 1, 4 }, + { pinmux(9), 1, 5 }, + { pinmux(9), 1, 6 }, + { pinmux(9), 1, 7 }, + { pinmux(10), 1, 0 }, + { pinmux(10), 1, 1 }, + { pinmux(10), 1, 2 }, + { pinmux(10), 1, 3 }, + { pinmux(10), 1, 4 }, + { pinmux(10), 1, 5 }, + { pinmux(10), 1, 6 }, + { pinmux(10), 1, 7 }, + { pinmux(11), 1, 0 }, + { pinmux(11), 1, 1 }, + { pinmux(11), 1, 2 }, + { pinmux(11), 1, 3 }, + { pinmux(11), 1, 4 }, + { pinmux(11), 1, 5 }, + { pinmux(11), 1, 6 }, + { pinmux(11), 1, 7 }, + { pinmux(12), 1, 0 }, + { pinmux(12), 1, 1 }, + { pinmux(12), 1, 2 }, + { pinmux(12), 1, 3 }, + { pinmux(12), 1, 4 }, + { pinmux(12), 1, 5 }, + { pinmux(12), 1, 6 }, + { pinmux(12), 1, 7 } +}; + +#endif diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 844e585..7bc16e7 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -28,135 +28,14 @@ #include <asm/arch/hardware.h> #include <asm/arch/emif_defs.h> #include <asm/arch/emac_defs.h> +#include <asm/arch/da850_pinmux.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h> #include <hwconfig.h>
DECLARE_GLOBAL_DATA_PTR;
-/* SPI0 pin muxer settings */ -static const struct pinmux_config spi1_pins[] = { - { pinmux(5), 1, 1 }, - { pinmux(5), 1, 2 }, - { pinmux(5), 1, 4 }, - { pinmux(5), 1, 5 } -}; - -/* UART pin muxer settings */ -static const struct pinmux_config uart_pins[] = { - { pinmux(0), 4, 6 }, - { pinmux(0), 4, 7 }, - { pinmux(4), 2, 4 }, - { pinmux(4), 2, 5 } -}; - #ifdef CONFIG_DRIVER_TI_EMAC -static const struct pinmux_config emac_pins[] = { -#ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII - { pinmux(14), 8, 2 }, - { pinmux(14), 8, 3 }, - { pinmux(14), 8, 4 }, - { pinmux(14), 8, 5 }, - { pinmux(14), 8, 6 }, - { pinmux(14), 8, 7 }, - { pinmux(15), 8, 1 }, -#else /* ! CONFIG_DRIVER_TI_EMAC_USE_RMII */ - { pinmux(2), 8, 1 }, - { pinmux(2), 8, 2 }, - { pinmux(2), 8, 3 }, - { pinmux(2), 8, 4 }, - { pinmux(2), 8, 5 }, - { pinmux(2), 8, 6 }, - { pinmux(2), 8, 7 }, - { pinmux(3), 8, 0 }, - { pinmux(3), 8, 1 }, - { pinmux(3), 8, 2 }, - { pinmux(3), 8, 3 }, - { pinmux(3), 8, 4 }, - { pinmux(3), 8, 5 }, - { pinmux(3), 8, 6 }, - { pinmux(3), 8, 7 }, -#endif /* CONFIG_DRIVER_TI_EMAC_USE_RMII */ - { pinmux(4), 8, 0 }, - { pinmux(4), 8, 1 } -}; - -/* I2C pin muxer settings */ -static const struct pinmux_config i2c_pins[] = { - { pinmux(4), 2, 2 }, - { pinmux(4), 2, 3 } -}; - -#ifdef CONFIG_NAND_DAVINCI -const struct pinmux_config nand_pins[] = { - { pinmux(7), 1, 1 }, - { pinmux(7), 1, 2 }, - { pinmux(7), 1, 4 }, - { pinmux(7), 1, 5 }, - { pinmux(9), 1, 0 }, - { pinmux(9), 1, 1 }, - { pinmux(9), 1, 2 }, - { pinmux(9), 1, 3 }, - { pinmux(9), 1, 4 }, - { pinmux(9), 1, 5 }, - { pinmux(9), 1, 6 }, - { pinmux(9), 1, 7 }, - { pinmux(12), 1, 5 }, - { pinmux(12), 1, 6 } -}; -#elif defined(CONFIG_USE_NOR) -/* NOR pin muxer settings */ -const struct pinmux_config nor_pins[] = { - /* GP0[11] is required for NOR to work on Rev 3 EVMs */ - { pinmux(0), 8, 4 }, /* GP0[11] */ - { pinmux(5), 1, 6 }, - { pinmux(6), 1, 6 }, - { pinmux(7), 1, 0 }, - { pinmux(7), 1, 4 }, - { pinmux(7), 1, 5 }, - { pinmux(8), 1, 0 }, - { pinmux(8), 1, 1 }, - { pinmux(8), 1, 2 }, - { pinmux(8), 1, 3 }, - { pinmux(8), 1, 4 }, - { pinmux(8), 1, 5 }, - { pinmux(8), 1, 6 }, - { pinmux(8), 1, 7 }, - { pinmux(9), 1, 0 }, - { pinmux(9), 1, 1 }, - { pinmux(9), 1, 2 }, - { pinmux(9), 1, 3 }, - { pinmux(9), 1, 4 }, - { pinmux(9), 1, 5 }, - { pinmux(9), 1, 6 }, - { pinmux(9), 1, 7 }, - { pinmux(10), 1, 0 }, - { pinmux(10), 1, 1 }, - { pinmux(10), 1, 2 }, - { pinmux(10), 1, 3 }, - { pinmux(10), 1, 4 }, - { pinmux(10), 1, 5 }, - { pinmux(10), 1, 6 }, - { pinmux(10), 1, 7 }, - { pinmux(11), 1, 0 }, - { pinmux(11), 1, 1 }, - { pinmux(11), 1, 2 }, - { pinmux(11), 1, 3 }, - { pinmux(11), 1, 4 }, - { pinmux(11), 1, 5 }, - { pinmux(11), 1, 6 }, - { pinmux(11), 1, 7 }, - { pinmux(12), 1, 0 }, - { pinmux(12), 1, 1 }, - { pinmux(12), 1, 2 }, - { pinmux(12), 1, 3 }, - { pinmux(12), 1, 4 }, - { pinmux(12), 1, 5 }, - { pinmux(12), 1, 6 }, - { pinmux(12), 1, 7 } -}; -#endif - #ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII #define HAS_RMII 1 #else @@ -222,17 +101,25 @@ int misc_init_r(void) return 0; }
+const struct pinmux_config gpio_pins[] = { +#ifdef CONFIG_USE_NOR + /* GP0[11] is required for NOR to work on Rev 3 EVMs */ + { pinmux(0), 8, 4 }, /* GP0[11] */ +#endif +}; + static const struct pinmux_resource pinmuxes[] = { #ifdef CONFIG_SPI_FLASH PINMUX_ITEM(spi1_pins), #endif - PINMUX_ITEM(uart_pins), - PINMUX_ITEM(i2c_pins), + PINMUX_ITEM(uart2_pins), + PINMUX_ITEM(i2c0_pins), #ifdef CONFIG_NAND_DAVINCI PINMUX_ITEM(nand_pins), #elif defined(CONFIG_USE_NOR) PINMUX_ITEM(nor_pins), #endif + PINMUX_ITEM(gpio_pins), };
static const struct lpsc_resource lpsc[] = { diff --git a/board/davinci/da8xxevm/hawkboard_nand_spl.c b/board/davinci/da8xxevm/hawkboard_nand_spl.c index fd130fa..fcc5f23 100644 --- a/board/davinci/da8xxevm/hawkboard_nand_spl.c +++ b/board/davinci/da8xxevm/hawkboard_nand_spl.c @@ -27,53 +27,14 @@ #include <asm/arch/hardware.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h> +#include <asm/arch/da850_pinmux.h> #include <ns16550.h> #include <nand.h>
-static const struct pinmux_config mii_pins[] = { - { pinmux(2), 8, 1 }, - { pinmux(2), 8, 2 }, - { pinmux(2), 8, 3 }, - { pinmux(2), 8, 4 }, - { pinmux(2), 8, 5 }, - { pinmux(2), 8, 6 }, - { pinmux(2), 8, 7 } -}; - -static const struct pinmux_config mdio_pins[] = { - { pinmux(4), 8, 0 }, - { pinmux(4), 8, 1 } -}; - -static const struct pinmux_config nand_pins[] = { - { pinmux(7), 1, 1 }, - { pinmux(7), 1, 2 }, - { pinmux(7), 1, 4 }, - { pinmux(7), 1, 5 }, - { pinmux(9), 1, 0 }, - { pinmux(9), 1, 1 }, - { pinmux(9), 1, 2 }, - { pinmux(9), 1, 3 }, - { pinmux(9), 1, 4 }, - { pinmux(9), 1, 5 }, - { pinmux(9), 1, 6 }, - { pinmux(9), 1, 7 }, - { pinmux(12), 1, 5 }, - { pinmux(12), 1, 6 } -}; - -static const struct pinmux_config uart2_pins[] = { - { pinmux(0), 4, 6 }, - { pinmux(0), 4, 7 }, - { pinmux(4), 2, 4 }, - { pinmux(4), 2, 5 } -}; - static const struct pinmux_resource pinmuxes[] = { - PINMUX_ITEM(mii_pins), - PINMUX_ITEM(mdio_pins), + PINMUX_ITEM(emac_pins), PINMUX_ITEM(nand_pins), PINMUX_ITEM(uart2_pins), };
variable storage should not be in headers. why can't this be in a C file ? -mike
Hello Mike, Thank you for your comments.
Ok, I'll move them to a C file. Regards, Christian
Christian Riesch
Mike Frysinger
