Hello Tom,
please pull from u-boot-i2c:
The following changes since commit a5e490f14e904fd240ccec5d364509b36a3150f9:
socfpga: fix the serial console on DE1-SoC (2023-02-12 15:47:19 -0500)
https://source.denx.de/u-boot/custodians/u-boot-i2c.git tags/i2c-updates-for-v2023.04
for you to fetch changes up to f536fda99fa2c1c88f68d8da54ed6233cec3532e:
i2c: i2c-cdns.c: Update driver to read fifo-depth from device tree (2023-02-13 09:58:27 +0100)
---------------------------------------------------------------- i2c updates for v2023.04
- add new i2c driver ast2600 from Ryan Chen
- i2c-cdns: make read fifo-depth configurable through device tree from Pei Yue Ho
- mxc i2c driver: print base address in hex, not in decimal from Fabio
---------------------------------------------------------------- Fabio Estevam (1): i2c: mxc_i2c: Use hex notation for the base address
Pei Yue Ho (2): dt-bindings: i2c: i2c-cdns.txt: Add description for an optional parameter, fifo-depth i2c: i2c-cdns.c: Update driver to read fifo-depth from device tree
Ryan Chen (2): i2c:aspeed:support ast2600 i2c new register mode driver arm: aspeed: dtsi: add reg for i2c
MAINTAINERS | 6 +++ arch/arm/dts/ast2600.dtsi | 1 + doc/device-tree-bindings/i2c/i2c-cdns.txt | 4 ++ drivers/i2c/Kconfig | 10 ++++ drivers/i2c/Makefile | 1 + drivers/i2c/ast2600_i2c.c | 366 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/ast2600_i2c.h | 120 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/i2c-cdns.c | 30 +++++++----- drivers/i2c/mxc_i2c.c | 2 +- 9 files changed, 527 insertions(+), 13 deletions(-) create mode 100644 drivers/i2c/ast2600_i2c.c create mode 100644 drivers/i2c/ast2600_i2c.h
Azure build is fine:
https://dev.azure.com/hs0298/hs/_build/results?buildId=101&view=results
bye, Heiko
On Mon, Feb 13, 2023 at 03:52:55PM +0100, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
