[PATCH v1 1/2] imx: imx8qm_rom7720: added missing USDHC Base address defines
Added missing USDHC Base address defines
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- include/configs/imx8qm_rom7720.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index 865863eb7c..8e1427da8a 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -18,6 +18,10 @@
#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define USDHC3_BASE_ADDR 0x5B030000 + #define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
#define CONFIG_ENV_OVERWRITE
Fix broken fsl_esdhc_imx conversion
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Ye Li ye.li@nxp.com Cc: uboot-imx uboot-imx@nxp.com --- board/advantech/imx8qm_rom7720_a1/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/advantech/imx8qm_rom7720_a1/spl.c b/board/advantech/imx8qm_rom7720_a1/spl.c index 3f31a8f9c3..24d216921d 100644 --- a/board/advantech/imx8qm_rom7720_a1/spl.c +++ b/board/advantech/imx8qm_rom7720_a1/spl.c @@ -55,7 +55,7 @@ DECLARE_GLOBAL_DATA_PTR; (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX
#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 22) #define USDHC2_CD_GPIO IMX_GPIO_NR(4, 12) @@ -164,7 +164,7 @@ int board_mmc_getcd(struct mmc *mmc) return ret; }
-#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */
void spl_board_init(void) {
On Thu, Dec 19, 2019 at 11:27 AM Oliver Graute oliver.graute@kococonnector.com wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
I agree to merge this, now it is enabled, code is compiled and I get a warning:
aarch64: w+ imx8qm_rom7720_a1_4G functional + 115 | init_clk_usdhc(0); + | ^~~~~~~~~~~~~~
w+board/advantech/imx8qm_rom7720_a1/spl.c:115:4: warning: implicit declaration of function 'init_clk_usdhc' [-Wimplicit-function-declaration] w+board/advantech/imx8qm_rom7720_a1/spl.c:137:9: warning: implicit declaration of function 'fsl_esdhc_initialize'; did you mean 'eth_initialize'? [-Wimplicit-function-declaration]
Can you check and repost ? Thanks !
Best regards, Stefano Babic
- 115 | init_clk_usdhc(0);
is this the right place to fix this warning?
--- a/arch/arm/include/asm/arch-imx8/clock.h +++ b/arch/arm/include/asm/arch-imx8/clock.h @@ -23,5 +23,6 @@ enum mxc_clock { };
u32 mxc_get_clock(enum mxc_clock clk); +void init_clk_usdhc(u32 index);
I`ll replace this to fix this warning
+++ b/board/advantech/imx8qm_rom7720_a1/spl.c @@ -8,7 +8,7 @@ #include <init.h> #include <log.h> #include <spl.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h>
Oliver
Hi Oliver,
sorry, lost your mail, and I see your question is still open:
I think yes, we have the same for imx8m.
Oliver
Regards, Stefano
Hi Oliver,
On Thu, Dec 19, 2019 at 11:25 AM Oliver Graute oliver.graute@kococonnector.com wrote:
These defines would be better placed in a common SoC header file instead of in the board file.
It is OK for now to do like this and we can do a cleanup later:
Fabio Estevam
Oliver Graute
Oliver Graute
Stefano Babic
