[U-Boot] [PATCH] MIPS: Drop unused PTR_COUNT_SHIFT from u-boot.lds
The u-boot.lds linker script for MIPS defines a PTR_COUNT_SHIFT macro to 2 or 3 for 32 bit or 64 bit builds respectively. This macro is never actually used though, so remove the dead code.
Signed-off-by: Paul Burton paul.burton@imgtec.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
arch/mips/cpu/u-boot.lds | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/arch/mips/cpu/u-boot.lds b/arch/mips/cpu/u-boot.lds index bd5536f013..fc943af923 100644 --- a/arch/mips/cpu/u-boot.lds +++ b/arch/mips/cpu/u-boot.lds @@ -5,12 +5,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#if defined(CONFIG_64BIT) -#define PTR_COUNT_SHIFT 3 -#else -#define PTR_COUNT_SHIFT 2 -#endif - OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS
Am 15.09.2017 um 20:35 schrieb Paul Burton:
applied to u-boot-mips, thanks
Daniel Schwierzeck
Paul Burton
