[U-Boot] [PATCH] ARM: dts: dra74x: Fix iodelay configuration for mmc3
According to the latest am572x[1] and dra74x[2] data manuals, mmc3 default, hs, sdr12 and sdr25 modes use iodelay values given in MMC3_MANUAL1. Set the MODE_SELECT bit for these so that manual mode is selected and correct iodelay values are configured.
[1] http://www.ti.com/lit/ds/symlink/am5728.pdf [2] http://www.ti.com/lit/ds/symlink/dra746.pdf
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- arch/arm/dts/dra74x-mmc-iodelay.dtsi | 50 ++++++++++++++-------------- 1 file changed, 25 insertions(+), 25 deletions(-)
diff --git a/arch/arm/dts/dra74x-mmc-iodelay.dtsi b/arch/arm/dts/dra74x-mmc-iodelay.dtsi index 28ebb4eb88..214b9e6de2 100644 --- a/arch/arm/dts/dra74x-mmc-iodelay.dtsi +++ b/arch/arm/dts/dra74x-mmc-iodelay.dtsi @@ -32,7 +32,7 @@ * * Datamanual Revisions: * - * AM572x Silicon Revision 2.0: SPRS953B, Revised November 2016 + * AM572x Silicon Revision 2.0: SPRS953F, Revised May 2019 * AM572x Silicon Revision 1.1: SPRS915R, Revised November 2016 * */ @@ -229,45 +229,45 @@
mmc3_pins_default: mmc3_pins_default { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ - DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ - DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ - DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ - DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ - DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ + DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ + DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ + DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ + DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ + DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ + DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ >; };
mmc3_pins_hs: mmc3_pins_hs { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ - DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ - DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ - DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ - DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ - DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ + DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ + DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ + DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ + DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ + DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ + DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ >; };
mmc3_pins_sdr12: mmc3_pins_sdr12 { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ - DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ - DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ - DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ - DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ - DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ + DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ + DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ + DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ + DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ + DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ + DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ >; };
mmc3_pins_sdr25: mmc3_pins_sdr25 { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ - DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ - DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ - DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ - DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ - DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ + DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_clk.mmc3_clk */ + DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_cmd.mmc3_cmd */ + DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat0.mmc3_dat0 */ + DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat1.mmc3_dat1 */ + DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat2.mmc3_dat2 */ + DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0)) /* mmc3_dat3.mmc3_dat3 */ >; };
Faiz Abbas
