[PATCH v2] Let the EQoS in imx8mp handle fixed-phy too.
Without that patch it lost track to the node to scan speed and duplex. Patch was created by Marek Vasut, just tested by me.
Signed-off-by: Elmar Psilog <epsi at gmx.de> --- changes v2: fix format issues
drivers/net/dwc_eth_qos.c | 19 ++++++++++++++++--- 1 file changed, 16 insertions(+), 3 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 112deb546d..ff638b0f1e 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -788,9 +788,22 @@ static int eqos_start(struct udevice *dev) */ if (!eqos->phy) { int addr = -1; - addr = eqos_get_phy_addr(eqos, dev); - eqos->phy = phy_connect(eqos->mii, addr, dev, - eqos->config->interface(dev)); + ofnode fixed_node; + + if (IS_ENABLED(CONFIG_PHY_FIXED)) { + fixed_node = ofnode_find_subnode(dev_ofnode(dev), + "fixed-link"); + if (ofnode_valid(fixed_node)) { + eqos->phy = fixed_phy_create(dev_ofnode(dev)); + } + } + + if (!eqos->phy) { + addr = eqos_get_phy_addr(eqos, dev); + eqos->phy = phy_connect(eqos->mii, addr, dev, + eqos->config->interface(dev)); + } + if (!eqos->phy) { pr_err("phy_connect() failed"); goto err_stop_resets; -- 2.34.1
ofnode fixed_node;
"fixed-link");
One more nitpick. Drop the curly brackets {} around this statement, i.e. keep only:
if (ofnode_valid(fixed_node)) eqos->phy = fixed_phy_create(dev_ofnode(dev));
With that fixed in V3, add:
Thanks !
Elmar Psilog
