[U-Boot] [PATCH 0/4] Exynos5: Fix warnings and enrich clock_get_periph_rate
This patch series does following changes - 1. Removing compiler warnings for clock_get_periph_rate. 2. Adding and enabling support for Exynos542x in clock_get_periph_rate. 3. Replacing peripheral specific function calls with clock_get_periph_rate. 4. Remove code from clocks file which became useless due to introduction of clock_get_periph_rate.
Akshay Saraswat (4): Exynos5: Fix compiler warnings due to clock_get_periph_rate Exynos542x: Add and enable get_periph_rate support Exynos5: Use clock_get_periph_rate generic API Exynos5: Remove dead code for fetching clocks
arch/arm/cpu/armv7/exynos/clock.c | 572 ++++++++++++++++----------------- arch/arm/include/asm/arch-exynos/clk.h | 8 + 2 files changed, 278 insertions(+), 302 deletions(-)
Apparently, members of clk_bit_info array do not map correctly to the members of enum periph_id. This mapping got broken after we changed periph_id(s) to reflect interrupt number instead of their position in a sequence. This patch intends to fix above mentioned issue.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 81 ++++++++++++++++++++++++--------------- 1 file changed, 50 insertions(+), 31 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index b31c13b..863974a 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -20,42 +20,49 @@ * positions of the peripheral clocks of the src and div registers */ struct clk_bit_info { + enum periph_id id; int8_t src_bit; int8_t div_bit; int8_t prediv_bit; };
-/* src_bit div_bit prediv_bit */ +/* periph_id src_bit div_bit prediv_bit */ static struct clk_bit_info clk_bit_info[] = { - {0, 0, -1}, - {4, 4, -1}, - {8, 8, -1}, - {12, 12, -1}, - {0, 0, 8}, - {4, 16, 24}, - {8, 0, 8}, - {12, 16, 24}, - {-1, -1, -1}, - {16, 0, 8}, - {20, 16, 24}, - {24, 0, 8}, - {0, 0, 4}, - {4, 12, 16}, - {-1, -1, -1}, - {-1, -1, -1}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {-1, 24, 0}, - {24, 0, -1}, - {24, 0, -1}, - {24, 0, -1}, - {24, 0, -1}, - {24, 0, -1}, + {PERIPH_ID_UART0, 0, 0, -1}, + {PERIPH_ID_UART1, 4, 4, -1}, + {PERIPH_ID_UART2, 8, 8, -1}, + {PERIPH_ID_UART3, 12, 12, -1}, + {PERIPH_ID_I2C0, -1, 24, 0}, + {PERIPH_ID_I2C1, -1, 24, 0}, + {PERIPH_ID_I2C2, -1, 24, 0}, + {PERIPH_ID_I2C3, -1, 24, 0}, + {PERIPH_ID_I2C4, -1, 24, 0}, + {PERIPH_ID_I2C5, -1, 24, 0}, + {PERIPH_ID_I2C6, -1, 24, 0}, + {PERIPH_ID_I2C7, -1, 24, 0}, + {PERIPH_ID_SPI0, 16, 0, 8}, + {PERIPH_ID_SPI1, 20, 16, 24}, + {PERIPH_ID_SPI2, 24, 0, 8}, + {PERIPH_ID_SDMMC0, 0, 0, 8}, + {PERIPH_ID_SDMMC1, 4, 16, 24}, + {PERIPH_ID_SDMMC2, 8, 0, 8}, + {PERIPH_ID_SDMMC3, 12, 16, 24}, + {PERIPH_ID_I2C8, -1, -1, -1}, + {PERIPH_ID_I2C9, -1, -1, -1}, + {PERIPH_ID_I2S0, 0, 0, 4}, + {PERIPH_ID_I2S1, 4, 12, 16}, + {PERIPH_ID_SROMC, -1, -1, -1}, + {PERIPH_ID_SPI3, 0, 0, 4}, + {PERIPH_ID_SPI4, 4, 12, 16}, + {PERIPH_ID_SDMMC4, 16, 0, 8}, + {PERIPH_ID_PWM0, 24, 0, -1}, + {PERIPH_ID_PWM1, 24, 0, -1}, + {PERIPH_ID_PWM2, 24, 0, -1}, + {PERIPH_ID_PWM3, 24, 0, -1}, + {PERIPH_ID_PWM4, 24, 0, -1}, + {PERIPH_ID_I2C10, -1, -1, -1}, + + {PERIPH_ID_NONE, -1, -1, -1}, };
/* Epll Clock division values to achive different frequency output */ @@ -260,9 +267,21 @@ static unsigned long exynos5_get_pll_clk(int pllreg) return fout; }
+static struct clk_bit_info *get_clk_bit_info(int peripheral) +{ + int i; + + for (i = 0; exynos5_bit_info[i].id != PERIPH_ID_NONE; i++) { + if (exynos5_bit_info[i].id == peripheral) + break; + } + + return &exynos5_bit_info[i]; +} + static unsigned long exynos5_get_periph_rate(int peripheral) { - struct clk_bit_info *bit_info = &clk_bit_info[peripheral]; + struct clk_bit_info *bit_info = get_clk_bit_info(peripheral); unsigned long sclk, sub_clk; unsigned int src, div, sub_div; struct exynos5_clock *clk =
- positions of the peripheral clocks of the src and div registers
- enum periph_id id; int8_t src_bit; int8_t div_bit; int8_t prediv_bit;
- {0, 0, -1},
- {4, 4, -1},
- {8, 8, -1},
- {12, 12, -1},
- {0, 0, 8},
- {4, 16, 24},
- {8, 0, 8},
- {12, 16, 24},
- {-1, -1, -1},
- {16, 0, 8},
- {20, 16, 24},
- {24, 0, 8},
- {0, 0, 4},
- {4, 12, 16},
- {-1, -1, -1},
- {-1, -1, -1},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {-1, 24, 0},
- {24, 0, -1},
- {24, 0, -1},
- {24, 0, -1},
- {24, 0, -1},
- {24, 0, -1},
- {PERIPH_ID_UART0, 0, 0, -1},
- {PERIPH_ID_UART1, 4, 4, -1},
- {PERIPH_ID_UART2, 8, 8, -1},
- {PERIPH_ID_UART3, 12, 12, -1},
- {PERIPH_ID_I2C0, -1, 24, 0},
- {PERIPH_ID_I2C1, -1, 24, 0},
- {PERIPH_ID_I2C2, -1, 24, 0},
- {PERIPH_ID_I2C3, -1, 24, 0},
- {PERIPH_ID_I2C4, -1, 24, 0},
- {PERIPH_ID_I2C5, -1, 24, 0},
- {PERIPH_ID_I2C6, -1, 24, 0},
- {PERIPH_ID_I2C7, -1, 24, 0},
- {PERIPH_ID_SPI0, 16, 0, 8},
- {PERIPH_ID_SPI1, 20, 16, 24},
- {PERIPH_ID_SPI2, 24, 0, 8},
- {PERIPH_ID_SDMMC0, 0, 0, 8},
- {PERIPH_ID_SDMMC1, 4, 16, 24},
- {PERIPH_ID_SDMMC2, 8, 0, 8},
- {PERIPH_ID_SDMMC3, 12, 16, 24},
- {PERIPH_ID_I2C8, -1, -1, -1},
- {PERIPH_ID_I2C9, -1, -1, -1},
- {PERIPH_ID_I2S0, 0, 0, 4},
- {PERIPH_ID_I2S1, 4, 12, 16},
- {PERIPH_ID_SROMC, -1, -1, -1},
- {PERIPH_ID_SPI3, 0, 0, 4},
- {PERIPH_ID_SPI4, 4, 12, 16},
- {PERIPH_ID_SDMMC4, 16, 0, 8},
- {PERIPH_ID_PWM0, 24, 0, -1},
- {PERIPH_ID_PWM1, 24, 0, -1},
- {PERIPH_ID_PWM2, 24, 0, -1},
- {PERIPH_ID_PWM3, 24, 0, -1},
- {PERIPH_ID_PWM4, 24, 0, -1},
- {PERIPH_ID_I2C10, -1, -1, -1},
- {PERIPH_ID_NONE, -1, -1, -1},
- int i;
- for (i = 0; exynos5_bit_info[i].id != PERIPH_ID_NONE; i++) {
break;
- return &exynos5_bit_info[i];
There is no exynos5_bit_info. Please modify clk_bit_info of top or to clk_bit_info in function.
Thanks.
We planned to fetch peripheral rate through one generic API per peripheral. These generic peripheral functions are in turn expected to fetch apt values from a function refactored as per SoC versions. This patch adds suuport for fetching peripheral rates for Exynos5420 and Exynos5800.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 211 +++++++++++++++++++++++++++------ arch/arm/include/asm/arch-exynos/clk.h | 8 ++ 2 files changed, 183 insertions(+), 36 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 863974a..9ac4579 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -27,7 +27,7 @@ struct clk_bit_info { };
/* periph_id src_bit div_bit prediv_bit */ -static struct clk_bit_info clk_bit_info[] = { +static struct clk_bit_info exynos5_bit_info[] = { {PERIPH_ID_UART0, 0, 0, -1}, {PERIPH_ID_UART1, 4, 4, -1}, {PERIPH_ID_UART2, 8, 8, -1}, @@ -65,6 +65,44 @@ static struct clk_bit_info clk_bit_info[] = { {PERIPH_ID_NONE, -1, -1, -1}, };
+static struct clk_bit_info exynos542x_bit_info[] = { + {PERIPH_ID_UART0, 4, 8, -1}, + {PERIPH_ID_UART1, 8, 12, -1}, + {PERIPH_ID_UART2, 12, 16, -1}, + {PERIPH_ID_UART3, 16, 20, -1}, + {PERIPH_ID_I2C0, -1, 8, -1}, + {PERIPH_ID_I2C1, -1, 8, -1}, + {PERIPH_ID_I2C2, -1, 8, -1}, + {PERIPH_ID_I2C3, -1, 8, -1}, + {PERIPH_ID_I2C4, -1, 8, -1}, + {PERIPH_ID_I2C5, -1, 8, -1}, + {PERIPH_ID_I2C6, -1, 8, -1}, + {PERIPH_ID_I2C7, -1, 8, -1}, + {PERIPH_ID_SPI0, 20, 20, 8}, + {PERIPH_ID_SPI1, 24, 24, 16}, + {PERIPH_ID_SPI2, 28, 28, 24}, + {PERIPH_ID_SDMMC0, 0, 0, -1}, + {PERIPH_ID_SDMMC1, 4, 10, -1}, + {PERIPH_ID_SDMMC2, 8, 20, -1}, + {PERIPH_ID_SDMMC3, -1, -1, -1}, + {PERIPH_ID_I2C8, -1, 8, -1}, + {PERIPH_ID_I2C9, -1, 8, -1}, + {PERIPH_ID_I2S0, 0, 0, 4}, + {PERIPH_ID_I2S1, 4, 12, 16}, + {PERIPH_ID_SROMC, -1, -1, -1}, + {PERIPH_ID_SPI3, 12, 16, 0}, + {PERIPH_ID_SPI4, 16, 20, 8}, + {PERIPH_ID_SDMMC4, 16, 0, 8}, + {PERIPH_ID_PWM0, 24, 28, -1}, + {PERIPH_ID_PWM1, 24, 28, -1}, + {PERIPH_ID_PWM2, 24, 28, -1}, + {PERIPH_ID_PWM3, 24, 28, -1}, + {PERIPH_ID_PWM4, 24, 28, -1}, + {PERIPH_ID_I2C10, -1, 8, -1}, + + {PERIPH_ID_NONE, -1, -1, -1}, +}; + /* Epll Clock division values to achive different frequency output */ static struct set_epll_con_val exynos5_epll_div[] = { { 192000000, 0, 48, 3, 1, 0 }, @@ -267,16 +305,62 @@ static unsigned long exynos5_get_pll_clk(int pllreg) return fout; }
+/* exynos5420: return pll clock frequency */ +static unsigned long exynos5420_get_pll_clk(int pllreg) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long r, k = 0; + + switch (pllreg) { + case APLL: + r = readl(&clk->apll_con0); + break; + case MPLL: + r = readl(&clk->mpll_con0); + break; + case EPLL: + r = readl(&clk->epll_con0); + k = readl(&clk->epll_con1); + break; + case VPLL: + r = readl(&clk->vpll_con0); + k = readl(&clk->vpll_con1); + break; + case BPLL: + r = readl(&clk->bpll_con0); + break; + case RPLL: + r = readl(&clk->rpll_con0); + k = readl(&clk->rpll_con1); + break; + case SPLL: + r = readl(&clk->spll_con0); + break; + default: + printf("Unsupported PLL (%d)\n", pllreg); + return 0; + } + + return exynos_get_pll_clk(pllreg, r, k); +} + static struct clk_bit_info *get_clk_bit_info(int peripheral) { int i; + struct clk_bit_info *info; + + if (proid_is_exynos5420() || proid_is_exynos5800()) + info = exynos542x_bit_info; + else + info = exynos5_bit_info;
- for (i = 0; exynos5_bit_info[i].id != PERIPH_ID_NONE; i++) { - if (exynos5_bit_info[i].id == peripheral) + for (i = 0; info[i].id != PERIPH_ID_NONE; i++) { + if (info[i].id == peripheral) break; }
- return &exynos5_bit_info[i]; + return &info[i]; }
static unsigned long exynos5_get_periph_rate(int peripheral) @@ -375,52 +459,107 @@ static unsigned long exynos5_get_periph_rate(int peripheral) return sub_clk; }
-unsigned long clock_get_periph_rate(int peripheral) -{ - if (cpu_is_exynos5()) - return exynos5_get_periph_rate(peripheral); - else - return 0; -} - -/* exynos5420: return pll clock frequency */ -static unsigned long exynos5420_get_pll_clk(int pllreg) +static unsigned long exynos542x_get_periph_rate(int peripheral) { + struct clk_bit_info *bit_info = get_clk_bit_info(peripheral); + unsigned long sclk, sub_clk; + unsigned int src, div, sub_div = 0; struct exynos5420_clock *clk = - (struct exynos5420_clock *)samsung_get_base_clock(); - unsigned long r, k = 0; + (struct exynos5420_clock *)samsung_get_base_clock();
- switch (pllreg) { - case APLL: - r = readl(&clk->apll_con0); + switch (peripheral) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + src = readl(&clk->src_peric0); + div = readl(&clk->div_peric0); break; - case MPLL: - r = readl(&clk->mpll_con0); + case PERIPH_ID_PWM0: + case PERIPH_ID_PWM1: + case PERIPH_ID_PWM2: + case PERIPH_ID_PWM3: + case PERIPH_ID_PWM4: + src = readl(&clk->src_peric0); + div = readl(&clk->div_peric0); break; - case EPLL: - r = readl(&clk->epll_con0); - k = readl(&clk->epll_con1); + case PERIPH_ID_SPI0: + case PERIPH_ID_SPI1: + case PERIPH_ID_SPI2: + src = readl(&clk->src_peric1); + div = readl(&clk->div_peric1); + sub_div = readl(&clk->div_peric4); break; - case VPLL: - r = readl(&clk->vpll_con0); - k = readl(&clk->vpll_con1); + case PERIPH_ID_SPI3: + case PERIPH_ID_SPI4: + src = readl(&clk->src_isp); + div = readl(&clk->div_isp1); + sub_div = readl(&clk->div_isp1); break; - case BPLL: - r = readl(&clk->bpll_con0); + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC1: + case PERIPH_ID_SDMMC2: + case PERIPH_ID_SDMMC3: + src = readl(&clk->src_fsys); + div = readl(&clk->div_fsys1); break; - case RPLL: - r = readl(&clk->rpll_con0); - k = readl(&clk->rpll_con1); + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + case PERIPH_ID_I2C3: + case PERIPH_ID_I2C4: + case PERIPH_ID_I2C5: + case PERIPH_ID_I2C6: + case PERIPH_ID_I2C7: + case PERIPH_ID_I2C8: + case PERIPH_ID_I2C9: + case PERIPH_ID_I2C10: + sclk = exynos5420_get_pll_clk(MPLL); + sub_div = ((readl(&clk->div_top1) >> bit_info->div_bit) + & 0x7) + 1; + return sclk / sub_div; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; + }; + + src = (src >> bit_info->src_bit) & 0xf; + + switch (src) { + case EXYNOS_SRC_MPLL: + sclk = exynos5420_get_pll_clk(MPLL); break; - case SPLL: - r = readl(&clk->spll_con0); + case EXYNOS_SRC_EPLL: + sclk = exynos5420_get_pll_clk(EPLL); + break; + case EXYNOS_SRC_RPLL: + sclk = exynos5420_get_pll_clk(RPLL); break; default: - printf("Unsupported PLL (%d)\n", pllreg); return 0; }
- return exynos_get_pll_clk(pllreg, r, k); + /* Ratio clock division for this peripheral */ + div = (div >> bit_info->div_bit) & 0xf; + sub_clk = sclk / (div + 1); + + if (bit_info->prediv_bit >= 0) { + sub_div = (sub_div >> bit_info->prediv_bit) & 0xff; + return sub_clk / (sub_div + 1); + } + + return sub_clk; +} + +unsigned long clock_get_periph_rate(int peripheral) +{ + if (cpu_is_exynos5()) { + if (proid_is_exynos5420() || proid_is_exynos5800()) + return exynos542x_get_periph_rate(peripheral); + return exynos5_get_periph_rate(peripheral); + } else { + return 0; + } }
/* exynos4: return ARM clock frequency */ diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index db24dc0..fe8d38c 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -23,9 +23,17 @@ #define SET_RATIO(x, y) ((y & 0xf) << (x << 4))
enum pll_src_bit { +#if defined (CONFIG_EXYNOS5420) || defined (CONFIG_EXYNOS5800) + EXYNOS_SRC_VPLL = -1, + EXYNOS_SRC_MPLL = 3, + EXYNOS_SRC_EPLL = 6, + EXYNOS_SRC_RPLL, +#else + EXYNOS_SRC_RPLL = -1, EXYNOS_SRC_MPLL = 6, EXYNOS_SRC_EPLL, EXYNOS_SRC_VPLL, +#endif };
unsigned long get_pll_clk(int pllreg);
suuport -> support
Please move to patch 1/4.
- {PERIPH_ID_UART0, 4, 8, -1},
- {PERIPH_ID_UART1, 8, 12, -1},
- {PERIPH_ID_UART2, 12, 16, -1},
- {PERIPH_ID_UART3, 16, 20, -1},
- {PERIPH_ID_I2C0, -1, 8, -1},
- {PERIPH_ID_I2C1, -1, 8, -1},
- {PERIPH_ID_I2C2, -1, 8, -1},
- {PERIPH_ID_I2C3, -1, 8, -1},
- {PERIPH_ID_I2C4, -1, 8, -1},
- {PERIPH_ID_I2C5, -1, 8, -1},
- {PERIPH_ID_I2C6, -1, 8, -1},
- {PERIPH_ID_I2C7, -1, 8, -1},
- {PERIPH_ID_SPI0, 20, 20, 8},
- {PERIPH_ID_SPI1, 24, 24, 16},
- {PERIPH_ID_SPI2, 28, 28, 24},
- {PERIPH_ID_SDMMC0, 0, 0, -1},
- {PERIPH_ID_SDMMC1, 4, 10, -1},
- {PERIPH_ID_SDMMC2, 8, 20, -1},
- {PERIPH_ID_SDMMC3, -1, -1, -1},
- {PERIPH_ID_I2C8, -1, 8, -1},
- {PERIPH_ID_I2C9, -1, 8, -1},
- {PERIPH_ID_SPI3, 12, 16, 0},
- {PERIPH_ID_SPI4, 16, 20, 8},
- {PERIPH_ID_PWM0, 24, 28, -1},
- {PERIPH_ID_PWM1, 24, 28, -1},
- {PERIPH_ID_PWM2, 24, 28, -1},
- {PERIPH_ID_PWM3, 24, 28, -1},
- {PERIPH_ID_PWM4, 24, 28, -1},
- {PERIPH_ID_I2C10, -1, 8, -1},
Please make separate patch to move this function. We get diff difficult to read by this change.
- struct exynos5420_clock *clk =
- switch (pllreg) {
- case APLL:
break;
- case MPLL:
break;
- case EPLL:
break;
- case VPLL:
break;
- case BPLL:
break;
- case RPLL:
break;
- case SPLL:
break;
- default:
- struct clk_bit_info *info;
- if (proid_is_exynos5420() || proid_is_exynos5800())
- else
- for (i = 0; info[i].id != PERIPH_ID_NONE; i++) {
}if (info[i].id == peripheral) break;
- return &info[i];
- else
So difficult to read below changes.
- struct clk_bit_info *bit_info = get_clk_bit_info(peripheral);
- unsigned long sclk, sub_clk;
- unsigned int src, div, sub_div = 0; struct exynos5420_clock *clk =
- switch (pllreg) {
- case APLL:
- switch (peripheral) {
- case PERIPH_ID_UART0:
- case PERIPH_ID_UART1:
- case PERIPH_ID_UART2:
- case PERIPH_ID_UART3:
break;div = readl(&clk->div_peric0);
- case MPLL:
- case PERIPH_ID_PWM0:
- case PERIPH_ID_PWM1:
- case PERIPH_ID_PWM2:
- case PERIPH_ID_PWM3:
- case PERIPH_ID_PWM4:
- case EPLL:
- case PERIPH_ID_SPI0:
- case PERIPH_ID_SPI1:
- case PERIPH_ID_SPI2:
break;sub_div = readl(&clk->div_peric4);
- case VPLL:
- case PERIPH_ID_SPI3:
- case PERIPH_ID_SPI4:
break;sub_div = readl(&clk->div_isp1);
- case BPLL:
- case PERIPH_ID_SDMMC0:
- case PERIPH_ID_SDMMC1:
- case PERIPH_ID_SDMMC2:
- case PERIPH_ID_SDMMC3:
break;div = readl(&clk->div_fsys1);
- case RPLL:
- case PERIPH_ID_I2C0:
- case PERIPH_ID_I2C1:
- case PERIPH_ID_I2C2:
- case PERIPH_ID_I2C3:
- case PERIPH_ID_I2C4:
- case PERIPH_ID_I2C5:
- case PERIPH_ID_I2C6:
- case PERIPH_ID_I2C7:
- case PERIPH_ID_I2C8:
- case PERIPH_ID_I2C9:
- case PERIPH_ID_I2C10:
& 0x7) + 1;
- default:
return -1;
- src = (src >> bit_info->src_bit) & 0xf;
- switch (src) {
- case EXYNOS_SRC_MPLL:
break;sclk = exynos5420_get_pll_clk(MPLL);
- case SPLL:
- case EXYNOS_SRC_EPLL:
break;
- case EXYNOS_SRC_RPLL:
break; default:sclk = exynos5420_get_pll_clk(RPLL);
return 0; }
- /* Ratio clock division for this peripheral */
- div = (div >> bit_info->div_bit) & 0xf;
- sub_clk = sclk / (div + 1);
- if (bit_info->prediv_bit >= 0) {
- return sub_clk;
- if (cpu_is_exynos5()) {
- } else {
Please don't use #ifdef because can't support dynamic detection of SoC.
- EXYNOS_SRC_VPLL = -1,
- EXYNOS_SRC_MPLL = 3,
- EXYNOS_SRC_EPLL = 6,
- EXYNOS_SRC_RPLL,
+#else
- EXYNOS_SRC_RPLL = -1, EXYNOS_SRC_MPLL = 6, EXYNOS_SRC_EPLL, EXYNOS_SRC_VPLL,
+#endif };
Thanks.
Replacing SoC and peripheral specific function calls with generic clock_get_periph_rate calls to get the peripheral clocks.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 60 +++++++++++++++++++++++++++++++-------- 1 file changed, 48 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 9ac4579..9c719aa 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -406,10 +406,13 @@ static unsigned long exynos5_get_periph_rate(int peripheral) break; case PERIPH_ID_SDMMC0: case PERIPH_ID_SDMMC1: + src = readl(&clk->src_fsys); + div = readl(&clk->div_fsys1); + break; case PERIPH_ID_SDMMC2: case PERIPH_ID_SDMMC3: src = readl(&clk->src_fsys); - div = readl(&clk->div_fsys1); + div = readl(&clk->div_fsys2); break; case PERIPH_ID_I2C0: case PERIPH_ID_I2C1: @@ -450,8 +453,7 @@ static unsigned long exynos5_get_periph_rate(int peripheral) sub_div = (div >> bit_info->div_bit) & 0xf; sub_clk = sclk / (sub_div + 1);
- /* Pre-ratio clock division for SDMMC0 and 2 */ - if (peripheral == PERIPH_ID_SDMMC0 || peripheral == PERIPH_ID_SDMMC2) { + if (bit_info->prediv_bit >= 0) { div = (div >> bit_info->prediv_bit) & 0xff; return sub_clk / (div + 1); } @@ -1766,7 +1768,7 @@ unsigned long get_arm_clk(void) unsigned long get_i2c_clk(void) { if (cpu_is_exynos5()) { - return exynos5_get_i2c_clk(); + return clock_get_periph_rate(PERIPH_ID_I2C0); } else if (cpu_is_exynos4()) { return exynos4_get_i2c_clk(); } else { @@ -1778,8 +1780,6 @@ unsigned long get_i2c_clk(void) unsigned long get_pwm_clk(void) { if (cpu_is_exynos5()) { - if (proid_is_exynos5420() || proid_is_exynos5800()) - return exynos5420_get_pwm_clk(); return clock_get_periph_rate(PERIPH_ID_PWM0); } else { if (proid_is_exynos4412()) @@ -1790,10 +1790,28 @@ unsigned long get_pwm_clk(void)
unsigned long get_uart_clk(int dev_index) { + enum periph_id id; + + switch (dev_index) { + case 0: + id = PERIPH_ID_UART0; + break; + case 1: + id = PERIPH_ID_UART1; + break; + case 2: + id = PERIPH_ID_UART2; + break; + case 3: + id = PERIPH_ID_UART3; + break; + default: + debug("%s: invalid UART index %d", __func__, dev_index); + return -1; + } + if (cpu_is_exynos5()) { - if (proid_is_exynos5420() || proid_is_exynos5800()) - return exynos5420_get_uart_clk(dev_index); - return exynos5_get_uart_clk(dev_index); + return clock_get_periph_rate(id); } else { if (proid_is_exynos4412()) return exynos4x12_get_uart_clk(dev_index); @@ -1803,10 +1821,28 @@ unsigned long get_uart_clk(int dev_index)
unsigned long get_mmc_clk(int dev_index) { + enum periph_id id; + + switch (dev_index) { + case 0: + id = PERIPH_ID_SDMMC0; + break; + case 1: + id = PERIPH_ID_SDMMC1; + break; + case 2: + id = PERIPH_ID_SDMMC2; + break; + case 3: + id = PERIPH_ID_SDMMC3; + break; + default: + debug("%s: invalid MMC index %d", __func__, dev_index); + return -1; + } + if (cpu_is_exynos5()) { - if (proid_is_exynos5420() || proid_is_exynos5800()) - return exynos5420_get_mmc_clk(dev_index); - return exynos5_get_mmc_clk(dev_index); + return clock_get_periph_rate(id); } else { return exynos4_get_mmc_clk(dev_index); }
case PERIPH_ID_SDMMC2: case PERIPH_ID_SDMMC3: src = readl(&clk->src_fsys);break;
break; case PERIPH_ID_I2C0: case PERIPH_ID_I2C1:div = readl(&clk->div_fsys2);
- if (bit_info->prediv_bit >= 0) { div = (div >> bit_info->prediv_bit) & 0xff; return sub_clk / (div + 1); }
Above changes seem to just fix, please make separate patch.
Thanks.
Removing dead code of peripheral and SoC specific function implementations which was used for fetching peripheral clocks. This code is not being used anymore because of the introduction of generic clock_get_periph_rate function.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 226 -------------------------------------- 1 file changed, 226 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 9c719aa..41af3a6 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -687,27 +687,6 @@ static unsigned long exynos4x12_get_pwm_clk(void) return pclk; }
-/* exynos5420: return pwm clock frequency */ -static unsigned long exynos5420_get_pwm_clk(void) -{ - struct exynos5420_clock *clk = - (struct exynos5420_clock *)samsung_get_base_clock(); - unsigned long pclk, sclk; - unsigned int ratio; - - /* - * CLK_DIV_PERIC0 - * PWM_RATIO [31:28] - */ - ratio = readl(&clk->div_peric0); - ratio = (ratio >> 28) & 0xf; - sclk = get_pll_clk(MPLL); - - pclk = sclk / (ratio + 1); - - return pclk; -} - /* exynos4: return uart clock frequency */ static unsigned long exynos4_get_uart_clk(int dev_index) { @@ -800,100 +779,6 @@ static unsigned long exynos4x12_get_uart_clk(int dev_index) return uclk; }
-/* exynos5: return uart clock frequency */ -static unsigned long exynos5_get_uart_clk(int dev_index) -{ - struct exynos5_clock *clk = - (struct exynos5_clock *)samsung_get_base_clock(); - unsigned long uclk, sclk; - unsigned int sel; - unsigned int ratio; - - /* - * CLK_SRC_PERIC0 - * UART0_SEL [3:0] - * UART1_SEL [7:4] - * UART2_SEL [8:11] - * UART3_SEL [12:15] - * UART4_SEL [16:19] - * UART5_SEL [23:20] - */ - sel = readl(&clk->src_peric0); - sel = (sel >> (dev_index << 2)) & 0xf; - - if (sel == 0x6) - sclk = get_pll_clk(MPLL); - else if (sel == 0x7) - sclk = get_pll_clk(EPLL); - else if (sel == 0x8) - sclk = get_pll_clk(VPLL); - else - return 0; - - /* - * CLK_DIV_PERIC0 - * UART0_RATIO [3:0] - * UART1_RATIO [7:4] - * UART2_RATIO [8:11] - * UART3_RATIO [12:15] - * UART4_RATIO [16:19] - * UART5_RATIO [23:20] - */ - ratio = readl(&clk->div_peric0); - ratio = (ratio >> (dev_index << 2)) & 0xf; - - uclk = sclk / (ratio + 1); - - return uclk; -} - -/* exynos5420: return uart clock frequency */ -static unsigned long exynos5420_get_uart_clk(int dev_index) -{ - struct exynos5420_clock *clk = - (struct exynos5420_clock *)samsung_get_base_clock(); - unsigned long uclk, sclk; - unsigned int sel; - unsigned int ratio; - - /* - * CLK_SRC_PERIC0 - * UART0_SEL [6:4] - * UART1_SEL [10:8] - * UART2_SEL [14:12] - * UART3_SEL [18:16] - * generalised calculation as follows - * sel = (sel >> ((dev_index * 4) + 4)) & mask; - */ - sel = readl(&clk->src_peric0); - sel = (sel >> ((dev_index * 4) + 4)) & 0x7; - - if (sel == 0x3) - sclk = get_pll_clk(MPLL); - else if (sel == 0x6) - sclk = get_pll_clk(EPLL); - else if (sel == 0x7) - sclk = get_pll_clk(RPLL); - else - return 0; - - /* - * CLK_DIV_PERIC0 - * UART0_RATIO [11:8] - * UART1_RATIO [15:12] - * UART2_RATIO [19:16] - * UART3_RATIO [23:20] - * generalised calculation as follows - * ratio = (ratio >> ((dev_index * 4) + 8)) & mask; - */ - ratio = readl(&clk->div_peric0); - ratio = (ratio >> ((dev_index * 4) + 8)) & 0xf; - - uclk = sclk / (ratio + 1); - - return uclk; -} - static unsigned long exynos4_get_mmc_clk(int dev_index) { struct exynos4_clock *clk = @@ -943,94 +828,6 @@ static unsigned long exynos4_get_mmc_clk(int dev_index) return uclk; }
-static unsigned long exynos5_get_mmc_clk(int dev_index) -{ - struct exynos5_clock *clk = - (struct exynos5_clock *)samsung_get_base_clock(); - unsigned long uclk, sclk; - unsigned int sel, ratio, pre_ratio; - int shift = 0; - - sel = readl(&clk->src_fsys); - sel = (sel >> (dev_index << 2)) & 0xf; - - if (sel == 0x6) - sclk = get_pll_clk(MPLL); - else if (sel == 0x7) - sclk = get_pll_clk(EPLL); - else if (sel == 0x8) - sclk = get_pll_clk(VPLL); - else - return 0; - - switch (dev_index) { - case 0: - case 1: - ratio = readl(&clk->div_fsys1); - pre_ratio = readl(&clk->div_fsys1); - break; - case 2: - case 3: - ratio = readl(&clk->div_fsys2); - pre_ratio = readl(&clk->div_fsys2); - break; - default: - return 0; - } - - if (dev_index == 1 || dev_index == 3) - shift = 16; - - ratio = (ratio >> shift) & 0xf; - pre_ratio = (pre_ratio >> (shift + 8)) & 0xff; - uclk = (sclk / (ratio + 1)) / (pre_ratio + 1); - - return uclk; -} - -static unsigned long exynos5420_get_mmc_clk(int dev_index) -{ - struct exynos5420_clock *clk = - (struct exynos5420_clock *)samsung_get_base_clock(); - unsigned long uclk, sclk; - unsigned int sel, ratio; - - /* - * CLK_SRC_FSYS - * MMC0_SEL [10:8] - * MMC1_SEL [14:12] - * MMC2_SEL [18:16] - * generalised calculation as follows - * sel = (sel >> ((dev_index * 4) + 8)) & mask - */ - sel = readl(&clk->src_fsys); - sel = (sel >> ((dev_index * 4) + 8)) & 0x7; - - if (sel == 0x3) - sclk = get_pll_clk(MPLL); - else if (sel == 0x4) - sclk = get_pll_clk(SPLL); - else if (sel == 0x6) - sclk = get_pll_clk(EPLL); - else - return 0; - - /* - * CLK_DIV_FSYS1 - * MMC0_RATIO [9:0] - * MMC1_RATIO [19:10] - * MMC2_RATIO [29:20] - * generalised calculation as follows - * ratio = (ratio >> (dev_index * 10)) & mask - */ - ratio = readl(&clk->div_fsys1); - ratio = (ratio >> (dev_index * 10)) & 0x3ff; - - uclk = (sclk / (ratio + 1)); - - return uclk; -} - /* exynos4: set the mmc clock */ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) { @@ -1409,29 +1206,6 @@ void exynos4_set_mipi_clk(void) clrsetbits_le32(&clk->div_lcd0, 0xf << 16, 0x1 << 16); }
-/* - * I2C - * - * exynos5: obtaining the I2C clock - */ -static unsigned long exynos5_get_i2c_clk(void) -{ - struct exynos5_clock *clk = - (struct exynos5_clock *)samsung_get_base_clock(); - unsigned long aclk_66, aclk_66_pre, sclk; - unsigned int ratio; - - sclk = get_pll_clk(MPLL); - - ratio = (readl(&clk->div_top1)) >> 24; - ratio &= 0x7; - aclk_66_pre = sclk / (ratio + 1); - ratio = readl(&clk->div_top0); - ratio &= 0x7; - aclk_66 = aclk_66_pre / (ratio + 1); - return aclk_66; -} - int exynos5_set_epll_clk(unsigned long rate) { unsigned int epll_con, epll_con_k;
Akshay Saraswat
Joonyoung Shim
